Resolved Spell check not working on WindowsBBS
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by PeteC, 2014/09/06.
  1. 2014/09/06
    PeteC SuperGeek Staff Thread Starter
    I recently started using Firefox as my default browser and despite the option to check spelling as I type being checked this does not happen in composing WindowsBBS posts.
    Any thoughts as to a solution?
  2. 2014/09/06
    Works fine for me, so other than to ask if you have language packs installed I'd have no idea.
    Using Firefox 32.0 - I have only the default language packs installed - English/United Kingdom and English.
    Same issue in Firefox 32 on Windows 8.1 on the laptop.
  5. 2014/09/06
    I'm using an old portable version 13 and spell check works ok.
  6. 2014/09/06
    Issue resolved - there was no dictionary installed. Would have thought that would have been done on installation. Subsequently found this on Mozilla forums ....
  7. 2014/09/06
    Update - Installed the US version of Firefox and spell check now working as it should without the dictionary enabled.
  8. 2014/09/06
    James Martin
    James Martin Geek Member
    Might be a bit of a pain when typing words like tyre, instead of tire, and getting a red squiggly line underneath (as I am now).
  9. 2014/09/07
    True, James, but as the majority on this BBS use the 'non English' spelling of some words it is not an issue :) Incidentally the way you spell some words is far more logical!
  10. 2014/09/09
    FYI, in FF you can right click any red-underlined "mis-spelling" and select Add to dictionary.
  11. 2014/09/09
    Thanks Tony - it is the same in IE.
