Slow start and weird shut down
Discussion in 'Windows 7' started by Blufx, 2013/09/14.
  1. 2013/09/16
    Blufx
    Blufx Well-Known Member Thread Starter
    Thanks Pete, let me know if you have anything to try. This is really puzzling.
  2. 2013/09/16
    In Control Panel< System and Security< Power Options< try setting the power plan to High performance and rebooting the machine.
    Blufx
    This is strange. I change it to high performance and it doesn't give me the option to apply. The button is grayed out.
  5. 2013/09/16
    There is no apply button. You should be able to select the High performance option and then close the Power Options window. Then go back into the Power Options window to verify that the selection was set properly.
  6. 2013/09/16
    Blufx
    Power settings
    The pic shows the default power settings. I click advanced settings to see "high performance ". I click OK, and it's still on "balanced ".
  7. 2013/09/16
    Blufx
    OK, I got it to stay on high performance, but still no change.
  8. 2013/09/16
    Have you installed the latest video driver for your laptop?
  9. 2013/09/16
    Blufx
    Yes, I can't find an update for it. That's one of the first things I thought of checking. nVIDIA GeForce Go 6150.
  10. 2013/09/16
    James Martin
    James Martin Geek Member
    I could be totally wrong, but it sounds like it could be a corrupted operating system.
  11. 2013/09/16
    Download and install the latest driver from here, GeForce R304 Driver.
    I doubt it could be a corrupt installation since its a new, clean install of Windows 7.
  12. 2013/09/16
    James Martin
    Very possible, but I have seen times when I had to reinstall XP and W98 less than a month apart. Sometimes, things just don't go right.
  13. 2013/09/17
  14. 2013/09/19
    Blufx
    Another strange one
    Sorry for the delay, Gout has been killing me!
    OK, that didn't work. Everest Ultimate shows I have an Nvidia Go6150, but nvidia says I don't.
  15. 2013/09/19
    Blufx
    @James Martin,
    I don't think it's a corrupt install either. As stated, I've installed twice. and both times the system runs perfect with the exception of this.
  16. 2013/09/19
    SpywareDr
  17. 2013/09/19
    Blufx
    Blufx
    Here's Speccy report
  20. 2013/09/19
    Blufx
    pete, it turns up the same driver I just tried to install
  21. 2013/09/19
    Blufx
    It's probably worth mentioning at this point, I just had a GPU reball performed on on this motherboard. It was dead because of HPs infamous overheat problems in the DV series
