Solved Slow PC and fake virus warnings
Discussion in 'Malware and Virus Removal Archive' started by palljim23, 2010/01/01.
  1. 2010/02/06
    palljim23
    palljim23 Inactive Thread Starter
    Will do. I am actually doing this for my in-laws and it has been some time before I could post. But, I actually did follow the instructions.
  2. 2010/02/06
    Just make sure, you run that fix, or they'll kill you for all lost pictures, etc. :)
    palljim23
    Done.
  5. 2010/02/06
    OK.
    Uninstall Combofix:
    Go Start > Run [Vista users, go Start> "Start search"]
    Type in:
    Combofix /Uninstall
    Note the space between the "Combofix" and the "/Uninstall "
    Click OK (Vista users - press Enter).
    Restart computer.
    Make sure, following items are gone:
    Combofix, Qoobox folders,and Combofix.txt file from C:
    Combofix from your desktop
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    • Please, never rename Combofix unless instructed.
    • Close any open browsers.
    • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
    • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    NOTE 1. If Combofix asks you to install Recovery Console, please allow it.
    • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    • Double click on combofix.exe & follow the prompts.
    • When finished, it will produce a report for you.
    • Please post the "C:\ComboFix.txt " along with a new HijackThis log for further review.
  6. 2010/02/06
    palljim23
    ComboFix 10-02-06.01 - HP_Administrator 02/06/2010 20:55:05.2.2 - x86
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.485 [GMT -5:00]
    Running from: c:\documents and settings\HP_Administrator\Desktop\ComboFix.exe
    AV: McAfee VirusScan *On-access scanning disabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
    FW: McAfee Personal Firewall *disabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
    c:\docume~1\HP_ADM~1\LOCALS~1\Temp\IadHide5.dll
    c:\documents and settings\HP_Administrator\Local Settings\Temp\IadHide5.dll
    L:\Autorun.inf
    ((((((((((((((((((((((((( Files Created from 2010-01-07 to 2010-02-07 )))))))))))))))))))))))))))))))
    2010-02-07 01:32 . 2010-02-07 01:32 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\SampleView
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\Zeon
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\InterMute
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\documents and settings\HP_Administrator\Saved Games
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Logitech
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\{7148F0A6-6813-11D6-A77B-00B0D0142030}
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Wildtangent
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\PhotoChannel
    2010-02-07 01:13 . 2010-02-07 01:13 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Mozilla
    2010-02-07 01:13 . 2010-02-07 01:13 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\MicroVision Applications
    2010-02-07 01:07 . 2010-02-07 01:07 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\HP
    2010-02-07 01:07 . 2010-02-07 01:07 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Help
    2010-02-07 01:06 . 2010-02-07 01:06 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Google
    2010-02-07 01:06 . 2010-02-07 01:06 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Citrix
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\browser - logitech
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Zeon
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Viewpoint
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\U3
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Talkback
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Symantec
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Spybot - Search & Destroy
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Sonic
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Snapfish
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\ScanSoft
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\MP3Rocket
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Move Networks
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Motive
    2010-02-07 00:57 . 2010-02-07 00:57 -------- d-----w- c:\documents and settings\All Users\DRM
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\zeon
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\WEBREG
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Viewpoint
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Trymedia
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\SBSI
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\RetroExp
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\QuickTime
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\PopCap
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\NeoEdge Networks
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\muvee Technologies
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee.com
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Links 2003
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Lavasoft
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Intuit
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\HP Product Assistant
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Hewlett-Packard
    2010-01-26 22:13 . 2010-01-26 22:13 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Apple
    2010-01-26 03:38 . 2010-02-07 01:51 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\HPAppData
    2010-01-26 03:29 . 2010-01-25 00:10 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Identities
    2010-01-25 11:01 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\VERIZON_BROAD
    2010-01-25 00:39 . 2006-07-23 14:54 139 ----a-w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\fusioncache.dat
    2010-01-25 00:39 . 2010-01-24 22:56 -------- d-----w- c:\documents and settings\All Users\Application Data\InstallShield
    2010-01-25 00:37 . 2009-12-07 01:44 129288 ----a-w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2010-01-25 00:36 . 2010-02-07 01:45 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\ApplicationHistory
    2010-01-25 00:36 . 2010-01-25 00:36 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
    2010-01-25 00:36 . 2010-01-24 23:20 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com
    2010-01-25 00:35 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
    2010-01-25 00:35 . 2010-02-07 01:06 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Apple Computer
    2010-01-25 00:35 . 2010-01-24 23:08 -------- d-----w- c:\documents and settings\All Users\Application Data\Verizon
    2010-01-25 00:35 . 2010-01-24 23:20 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Verizon
    2010-01-25 00:35 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\PCM4Everio
    2010-01-25 00:35 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Cyberlink
    2010-01-25 00:35 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Scansoft
    2010-01-25 00:35 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\Motive
    2010-01-25 00:35 . 2010-01-25 00:10 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\LightScribe
    2010-01-25 00:23 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\ScanSoft
    2010-02-07 00:45 . 2008-04-10 13:36 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Brother
    2010-02-07 00:44 . 2010-01-29 22:27 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple Computer
    2010-02-07 00:43 . 2010-02-07 00:43 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple
    2010-02-07 00:42 . 2010-02-07 00:42 -------- d-----w- c:\documents and settings\Administrator\Application Data\SUPERAntiSpyware.com
    2010-02-07 00:42 . 2010-02-07 00:42 -------- d-----w- c:\documents and settings\Administrator\Application Data\InterMute
    2010-01-25 00:36 . 2010-01-25 00:36 52224 ----a-w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\SD10005.dll
    2010-01-25 00:36 . 2010-01-25 00:36 117760 ----a-w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2010-01-25 00:02 . 2010-02-07 00:58 108 ----a-w- c:\documents and settings\HP_Administrator\_Ÿ9Ÿ9_.zip
    2010-01-05 10:00 . 2004-08-10 12:00 832512 ------w- c:\windows\system32\wininet.dll
    2010-01-05 10:00 . 2004-08-10 12:00 78336 ----a-w- c:\windows\system32\ieencode.dll
    2010-01-05 10:00 . 2004-08-10 12:00 17408 ----a-w- c:\windows\system32\corpol.dll
    2010-01-03 03:28 . 2010-01-03 03:28 388096 ----a-r- c:\documents and settings\HP_Administrator\Application Data\Microsoft\Installer\{0761C9A8-8F3A-4216-B4A7-B7AFBF24A24A}\HiJackThis.exe
    2010-01-03 03:28 . 2010-01-03 03:28 -------- d-----w- c:\program files\TrendMicro
    2010-01-03 00:09 . 2009-01-19 23:58 281 ----a-w- c:\windows\EReg077.dat
    2010-01-02 03:04 . 2010-02-07 00:42 117760 ----a-w- c:\documents and settings\Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2010-01-02 02:51 . 2009-01-03 19:16 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
    2010-01-02 00:24 . 2010-01-01 22:26 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-12-30 19:55 . 2010-01-01 22:26 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-12-30 19:54 . 2010-01-01 22:26 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-12-26 16:18 . 2009-12-26 16:17 -------- d-----w- c:\program files\Veoh Networks
    2009-12-13 22:44 . 2007-09-06 16:06 -------- d-----w- c:\program files\MorpheusBar
    2009-12-10 01:52 . 2010-02-07 00:58 1924200 ----a-w- c:\documents and settings\HP_Administrator\install_flash_player.exe
    2009-12-03 12:22 . 2009-12-03 12:22 152576 ----a-w- c:\documents and settings\HP_Administrator\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
    2009-12-03 12:02 . 2009-11-17 02:19 79488 ----a-w- c:\documents and settings\HP_Administrator\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
    2009-11-21 15:51 . 2004-08-10 12:00 471552 ----a-w- c:\windows\AppPatch\aclayers.dll
    2007-08-03 21:57 . 2007-08-03 21:57 251 -c--a-w- c:\program files\wt3d.ini
    2007-01-06 17:14 . 2007-01-06 17:14 774144 -c--a-w- c:\program files\RngInterstitial.dll
    2007-09-03 00:56 . 2007-06-28 01:32 88 -csha-r- c:\windows\system32\D076182245.sys
    2007-09-03 00:56 . 2007-06-28 01:32 2516 -csha-w- c:\windows\system32\KGyGaAvL.sys
    "MSMSGS "= "c:\program files\Messenger\msmsgs.exe" [2008-04-14 1695232]
    "swg "= "c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-07-27 68856]
    "SpybotSD TeaTimer "= "l:\program files\Security\Spybot - Search & Destroy\TeaTimer.exe" [2009-03-05 2260480]
    "VeohPlugin "= "c:\program files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe" [2010-01-26 2633976]
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2009-12-05 2002160]
    "ehTray "= "c:\windows\ehome\ehtray.exe" [2004-08-10 59392]
    "hpsysdrv "= "c:\windows\system\hpsysdrv.exe" [1998-05-07 52736]
    "High Definition Audio Property Page Shortcut "= "HDAudPropShortcut.exe" [2004-03-18 61952]
    "AGRSMMSG "= "AGRSMMSG.exe" [2004-06-29 88363]
    "HPHUPD06 "= "c:\program files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [2004-06-07 49152]
    "HPHmon06 "= "c:\windows\system32\hphmon06.exe" [2004-06-07 659456]
    "KBD "= "c:\hp\KBD\KBD.EXE" [2003-02-11 61440]
    "Recguard "= "c:\windows\SMINST\RECGUARD.EXE" [2004-04-14 233472]
    "ATIPTA "= "c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2004-11-04 344064]
    "PS2 "= "c:\windows\system32\ps2.exe" [2004-10-25 90112]
    "SoundMan "= "SOUNDMAN.EXE" [2004-10-13 77824]
    "AlcWzrd "= "ALCWZRD.EXE" [2004-10-13 2742272]
    "LSBWatcher "= "c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe" [2004-10-14 253952]
    "MaxtorOneTouch "= "c:\program files\Maxtor\OneTouch\utils\Onetouch.exe" [2004-12-22 823296]
    "ControlCenter2.0 "= "c:\program files\Brother\ControlCenter2\brctrcen.exe" [2005-01-07 864256]
    "EverioService "= "c:\program files\CyberLink\PCM4Everio\EverioService.exe" [2006-11-23 151552]
    "mcagent_exe "= "c:\program files\McAfee.com\Agent\mcagent.exe" [2009-10-29 1218008]
    "AppleSyncNotifier "= "c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-05-14 177472]
    "Verizon_McciTrayApp "= "c:\program files\Verizon\McciTrayApp.exe" [2007-09-28 936960]
    "VerizonServicepoint.exe "= "c:\program files\Verizon\VSP\VerizonServicepoint.exe" [2008-09-17 2065648]
    "SSBkgdUpdate "= "c:\program files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" [2006-10-25 210472]
    "ISUSPM "= "c:\program files\Common Files\InstallShield\UpdateService\ISUSPM.exe" [2006-03-20 213936]
    "PaperPort PTD "= "l:\program files\ScanSoft\PaperPort\pptd40nt.exe" [2008-05-10 29984]
    "IndexSearch "= "l:\program files\ScanSoft\PaperPort\IndexSearch.exe" [2008-05-10 46368]
    "PPort11reminder "= "l:\program files\ScanSoft\PaperPort\Ereg\Ereg.exe" [2007-08-31 328992]
    "hpqSRMon "= "c:\program files\HP\Digital Imaging\bin\hpqSRMon.exe" [2007-08-22 80896]
    "Microsoft Default Manager "= "c:\program files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2009-02-03 233304]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2009-05-26 413696]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-10-03 35696]
    "Adobe ARM "= "c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-09-04 935288]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2009-10-11 149280]
    "McAfee Backup "= "c:\program files\McAfee\MBK\McAfeeDataBackup.exe" [2009-07-09 5134864]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Acrobat Assistant.lnk - c:\program files\Adobe\Acrobat 6.0\Distillr\acrotray.exe [2003-10-23 217194]
    HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2007-10-14 214360]
    Microsoft Office.lnk - c:\program files\Microsoft Office\Office\OSA9.EXE [1999-2-17 65588]
    Updates from HP.lnk - c:\program files\Updates from HP\309731\Program\Updates from HP.exe [2005-3-25 45056]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 19:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\Program Files\\Updates from HP\\309731\\Program\\Updates from HP.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqtra08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpiscnapp.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    "c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe "=
    "c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe "=
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [12/16/2009 4:26 PM 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [12/16/2009 4:26 PM 74480]
    R3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [12/16/2009 4:27 PM 7408]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
    hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
    HPService REG_MULTI_SZ HPSLPSVC
    2010-02-02 c:\windows\Tasks\AppleSoftwareUpdate.job
    - c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 16:34]
    2006-11-01 c:\windows\Tasks\Easy Internet Sign-up.job
    - c:\program files\Easy Internet signup\HPSdpApp.exe [2004-08-13 16:50]
    2009-12-15 c:\windows\Tasks\McDefragTask.job
    - c:\progra~1\mcafee\mqc\QcConsol.exe [2008-04-10 17:22]
    2010-02-01 c:\windows\Tasks\McQcTask.job
    uStart Page = hxxp://www.yahoo.com/
    uDefault_Search_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    mStart Page = hxxp://www.yahoo.com
    mSearch Bar = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    uInternet Connection Wizard,ShellNext = iexplore
    uInternet Settings,ProxyOverride = *.local
    IE: E&xport to Microsoft Excel - c:\progra~1\MI1933~1\Office10\EXCEL.EXE/3000
    Trusted Zone: internet
    Trusted Zone: mcafee.com
    Trusted Zone: turbotax.com
    DPF: {26B2A5DA-BFD6-422F-A89A-28A54C74B12B} - hxxp://www.costcophotocenter.com/upload/activex/v3_0_0_4/PhotoCenter_ActiveX_Control.cab
    DPF: {46D8BEE7-0B27-4466-ABA2-A5F1E157971C} - hxxp://69.3.198.64:100/RemoteWeb.cab
    DPF: {5FFDFC21-AE40-4C7C-955C-415A1ACE01C8} - hxxp://69.3.198.64:100/VideoViewer.cab
    DPF: {ADACAA8F-3595-47FE-9C31-9C7471B9BEC7} - hxxp://webcam.geovision.com.tw/cab/OCXChecker_8000.cab
    DPF: {DBAFE6AD-DC14-45DF-A3F7-F8832289A1CD} - hxxp://webcam.geovision.com.tw/cab/DownloadFile_8000.cab
    DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A}
    Rootkit scan 2010-02-06 21:10
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    - - - - - - - > 'winlogon.exe'(612)
    c:\windows\system32\WININET.dll
    c:\windows\system32\Ati2evxx.dll
    - - - - - - - > 'explorer.exe'(5364)
    c:\windows\system32\ieframe.dll
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\Ati2evxx.exe
    l:\program files\Spyware\aawservice.exe
    c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    c:\program files\Bonjour\mDNSResponder.exe
    c:\windows\eHome\ehRecvr.exe
    c:\windows\eHome\ehSched.exe
    c:\program files\Java\jre6\bin\jqs.exe
    c:\program files\Common Files\LightScribe\LSSrvc.exe
    c:\progra~1\McAfee\MSC\mcmscsvc.exe
    c:\progra~1\COMMON~1\mcafee\mna\mcnasvc.exe
    c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
    c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
    c:\program files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    c:\program files\McAfee\MPF\MPFSrv.exe
    c:\windows\system32\PSIService.exe
    c:\program files\CyberLink\Shared Files\RichVideo.exe
    c:\program files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\windows\system32\wdfmgr.exe
    c:\progra~1\mcafee.com\agent\mcagent.exe
    c:\windows\AGRSMMSG.exe
    c:\windows\SOUNDMAN.EXE
    c:\windows\ALCWZRD.EXE
    c:\windows\system32\wscntfy.exe
    c:\windows\system32\dllhost.exe
    c:\program files\iPod\bin\iPodService.exe
    c:\windows\eHome\ehmsas.exe
    c:\program files\HP\Digital Imaging\bin\hpqSTE08.exe
    c:\program files\HP\Digital Imaging\bin\hpqbam08.exe
    c:\program files\HP\Digital Imaging\bin\hpqgpc01.exe
    Completion time: 2010-02-06 21:19:30 - machine was rebooted
    ComboFix-quarantined-files.txt 2010-02-07 02:19
    Pre-Run: 17,869,049,856 bytes free
    Post-Run: 18,119,516,160 bytes free
    - - End Of File - - DCFADB2BCBC5360236C71D68B19120C7
    Logfile of Trend Micro HijackThis v2.0.3 (BETA)
    Scan saved at 9:20:56 PM, on 2/6/2010
    MSIE: Internet Explorer v7.00 (7.00.6000.16981)
    C:\WINDOWS\system32\Ati2evxx.exe
    L:\Program Files\Spyware\aawservice.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\WINDOWS\eHome\ehRecvr.exe
    C:\WINDOWS\eHome\ehSched.exe
    c:\Program Files\Common Files\LightScribe\LSSrvc.exe
    C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
    c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
    c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
    C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
    C:\Program Files\McAfee\MPF\MPFSrv.exe
    C:\WINDOWS\system32\PSIService.exe
    C:\Program Files\CyberLink\Shared Files\RichVideo.exe
    C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\PROGRA~1\mcafee.com\agent\mcagent.exe
    C:\WINDOWS\ehome\ehtray.exe
    C:\windows\system\hpsysdrv.exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\HP\KBD\KBD.EXE
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\WINDOWS\SOUNDMAN.EXE
    C:\WINDOWS\ALCWZRD.EXE
    C:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    C:\Program Files\Brother\ControlCenter2\brctrcen.exe
    C:\Program Files\CyberLink\PCM4Everio\EverioService.exe
    C:\Program Files\Verizon\McciTrayApp.exe
    C:\Program Files\Verizon\VSP\VerizonServicepoint.exe
    C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
    L:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\McAfee\MBK\McAfeeDataBackup.exe
    C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe
    C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\WINDOWS\system32\dllhost.exe
    C:\WINDOWS\eHome\ehmsas.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqgpc01.exe
    C:\WINDOWS\explorer.exe
    C:\WINDOWS\system32\notepad.exe
    C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_clipbook.exe
    C:\Program Files\TrendMicro\HiJackThis\HiJackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
    O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
    O2 - BHO: Verizon Broadband Toolbar - {A057A204-BACC-4D26-8398-26FADCF27386} - C:\PROGRA~1\VERIZO~1\VERIZO~1.DLL
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
    O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
    O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1125.0\msneshellx.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
    O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
    O3 - Toolbar: Verizon Broadband Toolbar - {A057A204-BACC-4D26-8398-26FADCF27386} - C:\PROGRA~1\VERIZO~1\VERIZO~1.DLL
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1125.0\msneshellx.dll
    O3 - Toolbar: Veoh Video Compass - {52836EB0-631A-47B1-94A6-61F9D9112DAE} - C:\Program Files\Veoh Networks\Veoh Video Compass\SearchRecsPlugin.dll
    O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
    O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [HPHUPD06] c:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
    O4 - HKLM\..\Run: [HPHmon06] C:\WINDOWS\system32\hphmon06.exe
    O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
    O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
    O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
    O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
    O4 - HKLM\..\Run: [LSBWatcher] c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    O4 - HKLM\..\Run: [MaxtorOneTouch] C:\Program Files\Maxtor\OneTouch\utils\Onetouch.exe
    O4 - HKLM\..\Run: [ControlCenter2.0] C:\Program Files\Brother\ControlCenter2\brctrcen.exe /autorun
    O4 - HKLM\..\Run: [EverioService] "C:\Program Files\CyberLink\PCM4Everio\EverioService.exe "
    O4 - HKLM\..\Run: [mcagent_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
    O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
    O4 - HKLM\..\Run: [Verizon_McciTrayApp] C:\Program Files\Verizon\McciTrayApp.exe
    O4 - HKLM\..\Run: [VerizonServicepoint.exe] "C:\Program Files\Verizon\VSP\VerizonServicepoint.exe" /AUTORUN
    O4 - HKLM\..\Run: [SSBkgdUpdate] "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
    O4 - HKLM\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
    O4 - HKLM\..\Run: [PaperPort PTD] "L:\Program Files\ScanSoft\PaperPort\pptd40nt.exe "
    O4 - HKLM\..\Run: [IndexSearch] "L:\Program Files\ScanSoft\PaperPort\IndexSearch.exe "
    O4 - HKLM\..\Run: [PPort11reminder] "L:\Program Files\ScanSoft\PaperPort\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\ScanSoft\PaperPort\11\Config\Ereg\Ereg.ini "
    O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe
    O4 - HKLM\..\Run: [Microsoft Default Manager] "C:\Program Files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe "
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKLM\..\Run: [McAfee Backup] "C:\Program Files\McAfee\MBK\McAfeeDataBackup.exe "
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe "
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] L:\Program Files\Security\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [VeohPlugin] "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe "
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    O4 - Global Startup: Acrobat Assistant.lnk = C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
    O4 - Global Startup: Updates from HP.lnk = C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MI1933~1\Office10\EXCEL.EXE/3000
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O15 - Trusted Zone: http://*.mcafee.com
    O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} (Support.com Configuration Class) - https://activatemyfios.verizon.net/sdcCommon/download/FIOS/Verizon FiOS Installer.cab
    O16 - DPF: {10E0E75E-6701-4134-9D95-C0942ED1F1C8} (Snapfish Outlook Import ActiveX Control) - http://www.costcophotocenter.com/CostcoOutlookImport.cab
    O16 - DPF: {26B2A5DA-BFD6-422F-A89A-28A54C74B12B} (Photo Upload Plugin Class) - http://www.costcophotocenter.com/upload/activex/v3_0_0_4/PhotoCenter_ActiveX_Control.cab
    O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - http://www.costcophotocenter.com/CostcoActivia.cab
    O16 - DPF: {40F8967E-34A6-474A-837A-CEC1E7DAC54C} - https://accounting.quickbooks.com/c1/v15.591/qboax9.cab
    O16 - DPF: {46D8BEE7-0B27-4466-ABA2-A5F1E157971C} (Remote200 Control) - http://69.3.198.64:100/RemoteWeb.cab
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
    O16 - DPF: {5FFDFC21-AE40-4C7C-955C-415A1ACE01C8} (CViewerControl Object) - http://69.3.198.64:100/VideoViewer.cab
    O16 - DPF: {843EE768-3A97-455C-9076-741BA3AD7B62} (QuickBooks Online Edition Utilities Class v10) - https://accounting.quickbooks.com/c2/v16.607/qboax10.cab
    O16 - DPF: {ADACAA8F-3595-47FE-9C31-9C7471B9BEC7} (OCXDownloadChecker Control) - http://webcam.geovision.com.tw/cab/OCXChecker_8000.cab
    O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.mcafee.com/molbin/shared/mcgdmgr/1,0,0,26/mcgdmgr.cab
    O16 - DPF: {DBAFE6AD-DC14-45DF-A3F7-F8832289A1CD} (DownloadFile Control) - http://webcam.geovision.com.tw/cab/DownloadFile_8000.cab
    O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} -
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O16 - DPF: {EFD1E13D-1CB3-4545-B754-CA410FE7734F} (Photo Upload Plugin Class) - http://www.costcophotocenter.com/upload/activex/v3_0_0_2/PhotoCenter_ActiveX_Control.cab?
    O16 - DPF: {FFFFFFFF-CACE-BABE-BABE-00AA0055595A} - http://trueswitch.com/TrueInstall.exe
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
    O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
    O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - L:\Program Files\Spyware\aawservice.exe
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Unknown owner - c:\Program Files\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: MBackMonitor - McAfee - C:\Program Files\McAfee\MBK\MBackMonitor.exe
    O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
    O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
    O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
    O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
    O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
    O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
    O23 - Service: ProtexisLicensing - Unknown owner - C:\WINDOWS\system32\PSIService.exe
    O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
    End of file - 16517 bytes
  7. 2010/02/06
    1. Please open Notepad
    • Click Start , then Run
    • Type notepad .exe in the Run Box.
    2. Now copy/paste the entire content of the codebox below into the Notepad window:
    File::
    Folder::
    Driver::
    Registry::
    RegLockDel::
    3. Save the above as CFScript.txt
    4. Then drag the CFScript.txt into ComboFix.exe as depicted in the animation below. This will start ComboFix again.
    5. After reboot, (in case it asks to reboot), please post the following reports/logs into your next reply:
    • Combofix.txt
    • A new HijackThis log.
  8. 2010/02/27
    palljim23
    ComboFix 10-02-27.04 - HP_Administrator 02/27/2010 18:01:39.3.2 - x86
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.456 [GMT -5:00]
    Command switches used :: c:\documents and settings\HP_Administrator\Desktop\CFScript.txt
    FILE ::
    "c:\documents and settings\HP_Administrator\_Ÿ9Ÿ9_.zip "
    "c:\windows\EReg077.dat "
    "c:\windows\system32\D076182245.sys "
    "c:\windows\Tasks\Easy Internet Sign-up.job "
    c:\program files\Easy Internet signup\32_32.ico
    c:\program files\Easy Internet signup\basec.bin
    c:\program files\Easy Internet signup\basep.bin
    c:\program files\Easy Internet signup\Common\data\compaq\retailer_list.xml
    c:\program files\Easy Internet signup\Common\data\frontend.ini
    c:\program files\Easy Internet signup\Common\images\bbicon.bmp
    c:\program files\Easy Internet signup\Common\images\blue\brand_bar_hp_logo_orange.gif
    c:\program files\Easy Internet signup\Common\images\blue\brand_bar_hp_logo_orange_reg.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_action_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_orange_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_orange_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_orange_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_start_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_yellow_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_yellow_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\button_yellow_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_gray_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_gray_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_gray_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_yellow_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_yellow_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\tab_yellow_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_gray_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_gray_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_gray_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_yellow_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_yellow_middle.gif
    c:\program files\Easy Internet signup\Common\images\blue\tall_tab_yellow_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\blue\welcome_hp_logo_orange.gif
    c:\program files\Easy Internet signup\Common\images\blue_arrow.gif
    c:\program files\Easy Internet signup\Common\images\blue_arrow_up.gif
    c:\program files\Easy Internet signup\Common\images\clear.gif
    c:\program files\Easy Internet signup\Common\images\cross.gif
    c:\program files\Easy Internet signup\Common\images\eisIcon.gif
    c:\program files\Easy Internet signup\Common\images\exclamation.gif
    c:\program files\Easy Internet signup\Common\images\masthead.jpg
    c:\program files\Easy Internet signup\Common\images\masthead_04.jpg
    c:\program files\Easy Internet signup\Common\images\popupbar_top.gif
    c:\program files\Easy Internet signup\Common\images\popupbar_top_blue.gif
    c:\program files\Easy Internet signup\Common\images\progressbar.gif
    c:\program files\Easy Internet signup\Common\images\red\brand_bar_hp_logo_orange.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_action_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_orange_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_orange_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_orange_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_mouse_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_mouse_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_mouse_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_start_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_yellow_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\button_yellow_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\button_yellow_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_gray_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_gray_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_gray_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_yellow_left_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_yellow_middle.gif
    c:\program files\Easy Internet signup\Common\images\red\tab_yellow_right_cap.gif
    c:\program files\Easy Internet signup\Common\images\red\welcome_hp_logo_orange.gif
    c:\program files\Easy Internet signup\Common\images\reminderimage.gif
    c:\program files\Easy Internet signup\Common\images\secure_session.gif
    c:\program files\Easy Internet signup\Common\images\speeding_train.gif
    c:\program files\Easy Internet signup\Common\images\transparent_bg.gif
    c:\program files\Easy Internet signup\Common\images\warning.gif
    c:\program files\Easy Internet signup\Common\images\welcome.jpg
    c:\program files\Easy Internet signup\Common\images\welcome_04.jpg
    c:\program files\Easy Internet signup\Common\scripts\base_timer.js
    c:\program files\Easy Internet signup\Common\scripts\cssexpr.js
    c:\program files\Easy Internet signup\Common\scripts\dropIcon.js
    c:\program files\Easy Internet signup\Common\scripts\eventhandler.js
    c:\program files\Easy Internet signup\Common\scripts\renderer.js
    c:\program files\Easy Internet signup\Common\scripts\style_helper.js
    c:\program files\Easy Internet signup\Common\styles\compaq\cpq_add.css
    c:\program files\Easy Internet signup\Common\styles\hp\default.css
    c:\program files\Easy Internet signup\Common\templates\general\ad_image.xsl
    c:\program files\Easy Internet signup\Common\templates\general\all_buttons.xsl
    c:\program files\Easy Internet signup\Common\templates\general\base_heading.xsl
    c:\program files\Easy Internet signup\Common\templates\general\base_section.xsl
    c:\program files\Easy Internet signup\Common\templates\general\blank.htm
    c:\program files\Easy Internet signup\Common\templates\general\brand_bar.xsl
    c:\program files\Easy Internet signup\Common\templates\general\call_to_action.xsl
    c:\program files\Easy Internet signup\Common\templates\general\exit_section.xsl
    c:\program files\Easy Internet signup\Common\templates\general\icon_build.xsl
    c:\program files\Easy Internet signup\Common\templates\general\no_offers_section.xsl
    c:\program files\Easy Internet signup\Common\templates\general\offer_actionbutton.xsl
    c:\program files\Easy Internet signup\Common\templates\general\offer_heading.xsl
    c:\program files\Easy Internet signup\Common\templates\general\offer_transferbutton.xsl
    c:\program files\Easy Internet signup\Common\templates\general\reminder.htm
    c:\program files\Easy Internet signup\Common\templates\general\reminder_section.xsl
    c:\program files\Easy Internet signup\Common\templates\general\start.htm
    c:\program files\Easy Internet signup\Common\templates\general\tab_select.xsl
    c:\program files\Easy Internet signup\Common\templates\general\tab_text.xsl
    c:\program files\Easy Internet signup\Common\templates\general\tabhelp_text.xsl
    c:\program files\Easy Internet signup\Common\templates\general\tabtext_slanted.xsl
    c:\program files\Easy Internet signup\Common\templates\general\topbar_navtext.xsl
    c:\program files\Easy Internet signup\Common\templates\general\update_section.xsl
    c:\program files\Easy Internet signup\Common\templates\general\voiceover.xsl
    c:\program files\Easy Internet signup\Common\templates\general\welcome_section.xsl
    c:\program files\Easy Internet signup\Common\templates\offers\0_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\1_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\2_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\3_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\4_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\5_offer_html.htmt
    c:\program files\Easy Internet signup\Common\templates\offers\6_offer_html.htmt
    c:\program files\Easy Internet signup\crc.ini
    c:\program files\Easy Internet signup\cycle_id.ini
    c:\program files\Easy Internet signup\Dialer_phonebook_test.html
    c:\program files\Easy Internet signup\elife.xml
    c:\program files\Easy Internet signup\EQT.SCP
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\01-cable.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\02-consolidated_services.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\03-dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\04-dsl.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\05-eservices.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\06-wireless.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\07-satellite.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\08-value_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\09-aol.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\10-eservices-add.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\12-tell_me_more.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\14-Netscape-Online.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\20-base.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\compaq\21-base_bb.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\01-cable.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\02-consolidated_services.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\03-dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\04-dsl.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\05-eservices.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\06-wireless.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\07-satellite.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\08-value_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\09-aol.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\10-eservices-add.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\12-tell_me_more.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\14-Netscape-Online.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\20-base.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\offer_templates\hp\21-base_bb.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\all_screens.xml
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\all_sounds.xml
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\offers.wav
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\tabs.xml
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\welcome_begin.wav
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\welcome_end.wav
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\welcome_no_refresh.wav
    c:\program files\Easy Internet signup\FrontEnd\en_ca\ui\content\welcome_refresh.wav
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\aol.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\aol.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\base.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\base.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\base_bb.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\base_bb.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\cable.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\cable.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\01-cable.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\02-consolidated_services.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\03-dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\04-dsl.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\05-eservices.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\06-wireless.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\07-satellite.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\08-value_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\09-aol.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\10-eservices-add.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\12-tell_me_more.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\15-premium_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\20-base.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\compaq\21-base_bb.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\consolidated_services.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\consolidated_services.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\dialup.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\dialup.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\dsl.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\dsl.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\eservices-add.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\eservices-add.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\eservices.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\eservices.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\01-cable.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\02-consolidated_services.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\03-dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\04-dsl.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\05-eservices.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\06-wireless.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\07-satellite.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\08-value_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\09-aol.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\10-eservices-add.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\12-tell_me_more.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\15-premium_dialup.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\20-base.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\21-base_bb.tdf
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\hp\OfferCount.ini
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\premium_dialup.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\premium_dialup.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\satellite.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\satellite.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\tell_me_more.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\tell_me_more.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\value_dialup.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\value_dialup.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\wireless.htm
    c:\program files\Easy Internet signup\FrontEnd\en_us\offer_templates\wireless.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\all_screens.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\all_sounds.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\buttons.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\message.ini
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\offers.wav
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\reminder.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\tabs.xml
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\welcome_begin.wav
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\welcome_end.wav
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\welcome_no_refresh.wav
    c:\program files\Easy Internet signup\FrontEnd\en_us\ui\content\welcome_refresh.wav
    c:\program files\Easy Internet signup\GEN.SCP
    c:\program files\Easy Internet signup\GRIC.SCP
    c:\program files\Easy Internet signup\HPDialer.dll
    c:\program files\Easy Internet signup\HPHTTP.dll
    c:\program files\Easy Internet signup\HPSDP.cfg
    c:\program files\Easy Internet signup\HPSDP.pbk
    c:\program files\Easy Internet signup\HPSender.dll
    c:\program files\Easy Internet signup\HPUpdater.exe
    c:\program files\Easy Internet signup\HTTPTransport.dll
    c:\program files\Easy Internet signup\ISPSignup.exe
    c:\program files\Easy Internet signup\JTO.scp
    c:\program files\Easy Internet signup\locale.xml
    c:\program files\Easy Internet signup\offers\en_ca\content\aliantdsl00001hpd04\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\aliantdsl00001hpd04\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aliantdsl00001hpd04\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-encadia00011hpd09\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-encadia00011hpd09\adimage.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-encadia00011hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-encadia00011hpd09\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-encadia00011hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-max-bro00001hpd09\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-max-bro00001hpd09\adimage.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-max-bro00001hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-max-bro00001hpd09\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\aol-max-bro00001hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\bellsympdsl00010hpd04\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\bellsympdsl00010hpd04\bb_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_ca\content\bellsympdsl00010hpd04\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\bellsympdsl00010hpd04\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\bellsympdsl00010hpd04\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\eastlinkcab00015hpd01\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\eastlinkcab00015hpd01\bb_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_ca\content\eastlinkcab00015hpd01\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\eastlinkcab00015hpd01\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\eastlinkcab00015hpd01\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq1\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\faq1\question.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq2\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\faq2\question.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq3\base-logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq3\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\faq3\question.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq3\speed_demo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\faq3\speeddemo.swf
    c:\program files\Easy Internet signup\offers\en_ca\content\netscapedia00009hpd14\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\netscapedia00009hpd14\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\netscapedia00009hpd14\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\rogerscab00009hpd01\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\rogerscab00009hpd01\bb_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_ca\content\rogerscab00009hpd01\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\rogerscab00009hpd01\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\rogerscab00009hpd01\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\shawhighcab00007hpd01\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\shawhighcab00007hpd01\bb_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_ca\content\shawhighcab00007hpd01\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\shawhighcab00007hpd01\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\shawhighcab00007hpd01\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\shawlitecab00007hpd01\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\shawlitecab00007hpd01\bb_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_ca\content\shawlitecab00007hpd01\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\shawlitecab00007hpd01\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\shawlitecab00007hpd01\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\telusdsl00001hpd04\content.htm
    c:\program files\Easy Internet signup\offers\en_ca\content\telusdsl00001hpd04\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\content\telusdsl00001hpd04\logo.gif
    c:\program files\Easy Internet signup\offers\en_ca\media\aol_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_ca\media\getbb.swf
    c:\program files\Easy Internet signup\offers\en_ca\media\getbb.txt
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\aliantdsl00001hpd04.odf4
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\aol-encadia00011hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\aol-max-bro00001hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\bellsympdsl00010hpd04.odf4
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\eastlinkcab00015hpd01.odf1
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\faq1.odf12
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\faq2.odf12
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\faq3.odf12
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\netscapedia00009hpd14.odf14
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\rogerscab00009hpd01.odf1
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\shawhighcab00007hpd01.odf1
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\shawlitecab00007hpd01.odf1
    c:\program files\Easy Internet signup\offers\en_ca\offer_definitions\telusdsl00001hpd04.odf4
    c:\program files\Easy Internet signup\offers\en_us\content\aol-latidia00001hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-latidia00001hpd09\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-latidia00001hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\adimage.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\AOL_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00010hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\adimage.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\AOL_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usbro00011hpd05\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\adimage.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\AOL_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00016hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\adimage.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\AOL_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aol-usdia00019hpd15\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\adimage.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\AOL_hp_single.swf
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\det_aol.gif
    c:\program files\Easy Internet signup\offers\en_us\content\aolsmb_udia00007hpd09\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\base\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\base\BASE_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_us\content\base\BaseCookiePolicy.ini
    c:\program files\Easy Internet signup\offers\en_us\content\base\bb.ico
    c:\program files\Easy Internet signup\offers\en_us\content\base\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\base\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\base\getbb.swf
    c:\program files\Easy Internet signup\offers\en_us\content\base\getbb.txt
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\adcontent.htm
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\base_demo_image.jpg
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\elnk_hispeed.ico
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\getbb.txt
    c:\program files\Easy Internet signup\offers\en_us\content\earthlinbro00001hpd21\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\earthlindia00005hpd15\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\earthlindia00005hpd15\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\earthlindia00005hpd15\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\earthlindia00005hpd15\logo_revolves.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq1\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\faq1\question.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq2\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\faq2\question.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\base-logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\question.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\speed_demo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\speeddemo.swf
    c:\program files\Easy Internet signup\offers\en_us\content\faq3\Thumbs.db
    c:\program files\Easy Internet signup\offers\en_us\content\msn-usdia00006hpd15\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\msn-usdia00006hpd15\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\msn-usdia00006hpd15\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\msnbyobvas00004hpd05\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\msnbyobvas00004hpd05\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\msnbyobvas00004hpd05\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00005hpd08\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00005hpd08\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00005hpd08\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00006hpd08\content.htm
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00006hpd08\det_logo.gif
    c:\program files\Easy Internet signup\offers\en_us\content\peoplepcdia00006hpd08\logo.gif
    c:\program files\Easy Internet signup\offers\en_us\media\getbb.swf
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aol-latidia00001hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aol-usbro00010hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aol-usbro00011hpd05.odf5
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aol-usdia00016hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aol-usdia00019hpd15.odf15
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\aolsmb_udia00007hpd09.odf9
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\base.odf20
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\earthlinbro00001hpd21.odf21
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\earthlindia00005hpd15.odf15
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\faq1.odf12
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\faq2.odf12
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\faq3.odf12
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\msn-usdia00006hpd15.odf15
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\msnbyobvas00004hpd05.odf5
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\peoplepcdia00005hpd08.odf8
    c:\program files\Easy Internet signup\offers\en_us\offer_definitions\peoplepcdia00006hpd08.odf8
    c:\program files\Easy Internet signup\protector.ini
    c:\program files\Easy Internet signup\RASDialer.ini
    c:\program files\Easy Internet signup\RASProfile.ini
    c:\program files\Easy Internet signup\RegistrationTags.ini
    c:\program files\Easy Internet signup\sdpapp.ini
    c:\program files\Easy Internet signup\sdpdata.ini
    c:\program files\Easy Internet signup\sdpintl.ini
    c:\program files\Easy Internet signup\SYM.scp
    c:\program files\Easy Internet signup\system\phonebook\hpsdprona.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdprow.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus2.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus3.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus4.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus5.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus6.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus7.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus8.txt
    c:\program files\Easy Internet signup\system\phonebook\hpsdpus9.txt
    c:\program files\Easy Internet signup\system\phonebook\natollfree.txt
    c:\program files\Easy Internet signup\system\phonebook\pbkupdate.udf
    c:\program files\Easy Internet signup\system\phonebook\Schema.ini
    c:\program files\Easy Internet signup\TemplateUpdate.ini
    c:\program files\Easy Internet signup\Thumbs.db
    c:\program files\Easy Internet signup\uupops.scp
    c:\windows\system32\gotomon.log
    c:\windows\system32\Vb40032.dll
    L:\Autorun.inf
    ((((((((((((((((((((((((( Files Created from 2010-01-27 to 2010-02-27 )))))))))))))))))))))))))))))))
    2010-02-07 01:32 . 2010-02-07 01:32 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\SampleView
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\Zeon
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\InterMute
    2010-02-07 01:19 . 2010-02-07 01:19 -------- d-----w- c:\documents and settings\HP_Administrator\Saved Games
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Logitech
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\{7148F0A6-6813-11D6-A77B-00B0D0142030}
    2010-02-07 01:14 . 2010-02-07 01:14 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Wildtangent
    2010-02-07 01:14 . 2010-02-21 18:31 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\PhotoChannel
    2010-02-07 01:13 . 2010-02-07 01:13 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Mozilla
    2010-02-07 01:13 . 2010-02-07 01:13 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\MicroVision Applications
    2010-02-07 01:07 . 2010-02-07 01:07 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\HP
    2010-02-07 01:07 . 2010-02-07 01:07 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Help
    2010-02-07 01:06 . 2010-02-07 01:06 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Google
    2010-02-07 01:06 . 2010-02-07 01:06 -------- d-----w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\Citrix
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\browser - logitech
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Zeon
    2010-02-07 01:00 . 2010-02-07 01:00 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Viewpoint
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\U3
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Talkback
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Symantec
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Spybot - Search & Destroy
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Sonic
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Snapfish
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\ScanSoft
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\MP3Rocket
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Move Networks
    2010-02-07 00:59 . 2010-02-07 00:59 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Motive
    2010-02-07 00:57 . 2010-02-07 00:57 -------- d-----w- c:\documents and settings\All Users\DRM
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\zeon
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\WEBREG
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Viewpoint
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Trymedia
    2010-02-07 00:46 . 2010-02-07 00:46 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\SBSI
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\RetroExp
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\QuickTime
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\PopCap
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\NeoEdge Networks
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\muvee Technologies
    2010-02-07 00:45 . 2010-02-07 00:45 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee.com
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Links 2003
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Lavasoft
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Intuit
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\HP Product Assistant
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Hewlett-Packard
    1601-01-01 00:00 . 1601-01-01 00:00 -------- d-----w- c:\windows\LastGood.Tmp
    2010-02-27 12:49 . 2010-01-26 03:38 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\HPAppData
    2010-02-07 01:00 . 2010-01-25 11:01 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\VERIZON_BROAD
    2010-02-07 00:45 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
    2010-02-07 00:45 . 2010-01-25 00:23 -------- d-----w- c:\documents and settings\All Users\Application Data\ScanSoft
    2010-02-07 00:45 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Motive
    2010-02-07 00:45 . 2008-04-10 13:36 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
    2010-02-07 00:44 . 2010-02-07 00:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Brother
    2010-02-07 00:44 . 2010-01-29 22:27 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple Computer
    2010-02-07 00:44 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Cyberlink
    2010-02-07 00:43 . 2010-02-07 00:43 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple
    2010-02-07 00:42 . 2010-02-07 00:42 -------- d-----w- c:\documents and settings\Administrator\Application Data\SUPERAntiSpyware.com
    2010-02-07 00:42 . 2010-02-07 00:42 -------- d-----w- c:\documents and settings\Administrator\Application Data\InterMute
    2010-01-25 00:36 . 2010-01-25 00:36 52224 ----a-w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\SD10005.dll
    2010-01-25 00:36 . 2010-01-25 00:36 117760 ----a-w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2010-01-25 00:36 . 2010-01-25 00:36 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
    2010-01-24 23:20 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Verizon
    2010-01-24 23:20 . 2010-01-25 00:36 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\SUPERAntiSpyware.com
    2010-01-24 23:08 . 2010-01-25 00:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Verizon
    2010-01-24 22:56 . 2010-01-25 00:39 -------- d-----w- c:\documents and settings\All Users\Application Data\InstallShield
    2010-01-05 10:00 . 2004-08-10 12:00 832512 ------w- c:\windows\system32\wininet.dll
    2010-01-05 10:00 . 2004-08-10 12:00 78336 ----a-w- c:\windows\system32\ieencode.dll
    2010-01-05 10:00 . 2004-08-10 12:00 17408 ----a-w- c:\windows\system32\corpol.dll
    2010-01-03 03:28 . 2010-01-03 03:28 388096 ----a-r- c:\documents and settings\HP_Administrator\Application Data\Microsoft\Installer\{0761C9A8-8F3A-4216-B4A7-B7AFBF24A24A}\HiJackThis.exe
    2010-01-03 03:28 . 2010-01-03 03:28 -------- d-----w- c:\program files\TrendMicro
    2010-01-02 03:04 . 2010-02-07 00:42 117760 ----a-w- c:\documents and settings\Administrator\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2010-01-02 02:51 . 2009-01-03 19:16 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
    2010-01-02 00:24 . 2010-01-01 22:26 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-12-30 19:55 . 2010-01-01 22:26 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-12-30 19:54 . 2010-01-01 22:26 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-12-10 01:52 . 2010-02-07 00:58 1924200 ----a-w- c:\documents and settings\HP_Administrator\install_flash_player.exe
    2009-12-07 01:44 . 2010-01-25 00:37 129288 ----a-w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2009-12-03 12:22 . 2009-12-03 12:22 152576 ----a-w- c:\documents and settings\HP_Administrator\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
    2009-12-03 12:02 . 2009-11-17 02:19 79488 ----a-w- c:\documents and settings\HP_Administrator\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
    2007-08-03 21:57 . 2007-08-03 21:57 251 -c--a-w- c:\program files\wt3d.ini
    2007-01-06 17:14 . 2007-01-06 17:14 774144 -c--a-w- c:\program files\RngInterstitial.dll
    2007-09-03 00:56 . 2007-06-28 01:32 2516 -csha-w- c:\windows\system32\KGyGaAvL.sys
    "MSMSGS "= "c:\program files\Messenger\msmsgs.exe" [2008-04-14 1695232]
    "swg "= "c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-07-27 68856]
    "SpybotSD TeaTimer "= "l:\program files\Security\Spybot - Search & Destroy\TeaTimer.exe" [2009-03-05 2260480]
    "VeohPlugin "= "c:\program files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe" [2010-01-26 2633976]
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2009-12-05 2002160]
    "ehTray "= "c:\windows\ehome\ehtray.exe" [2004-08-10 59392]
    "hpsysdrv "= "c:\windows\system\hpsysdrv.exe" [1998-05-07 52736]
    "High Definition Audio Property Page Shortcut "= "HDAudPropShortcut.exe" [2004-03-18 61952]
    "AGRSMMSG "= "AGRSMMSG.exe" [2004-06-29 88363]
    "HPHUPD06 "= "c:\program files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [2004-06-07 49152]
    "HPHmon06 "= "c:\windows\system32\hphmon06.exe" [2004-06-07 659456]
    "KBD "= "c:\hp\KBD\KBD.EXE" [2003-02-11 61440]
    "Recguard "= "c:\windows\SMINST\RECGUARD.EXE" [2004-04-14 233472]
    "ATIPTA "= "c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2004-11-04 344064]
    "PS2 "= "c:\windows\system32\ps2.exe" [2004-10-25 90112]
    "SoundMan "= "SOUNDMAN.EXE" [2004-10-13 77824]
    "AlcWzrd "= "ALCWZRD.EXE" [2004-10-13 2742272]
    "LSBWatcher "= "c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe" [2004-10-14 253952]
    "MaxtorOneTouch "= "c:\program files\Maxtor\OneTouch\utils\Onetouch.exe" [2004-12-22 823296]
    "ControlCenter2.0 "= "c:\program files\Brother\ControlCenter2\brctrcen.exe" [2005-01-07 864256]
    "EverioService "= "c:\program files\CyberLink\PCM4Everio\EverioService.exe" [2006-11-23 151552]
    "mcagent_exe "= "c:\program files\McAfee.com\Agent\mcagent.exe" [2009-10-29 1218008]
    "AppleSyncNotifier "= "c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-05-14 177472]
    "Verizon_McciTrayApp "= "c:\program files\Verizon\McciTrayApp.exe" [2007-09-28 936960]
    "VerizonServicepoint.exe "= "c:\program files\Verizon\VSP\VerizonServicepoint.exe" [2008-09-17 2065648]
    "SSBkgdUpdate "= "c:\program files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" [2006-10-25 210472]
    "ISUSPM "= "c:\program files\Common Files\InstallShield\UpdateService\ISUSPM.exe" [2006-03-20 213936]
    "PaperPort PTD "= "l:\program files\ScanSoft\PaperPort\pptd40nt.exe" [2008-05-10 29984]
    "IndexSearch "= "l:\program files\ScanSoft\PaperPort\IndexSearch.exe" [2008-05-10 46368]
    "PPort11reminder "= "l:\program files\ScanSoft\PaperPort\Ereg\Ereg.exe" [2007-08-31 328992]
    "hpqSRMon "= "c:\program files\HP\Digital Imaging\bin\hpqSRMon.exe" [2007-08-22 80896]
    "Microsoft Default Manager "= "c:\program files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2009-02-03 233304]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2009-05-26 413696]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-10-03 35696]
    "Adobe ARM "= "c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-09-04 935288]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2009-10-11 149280]
    c:\documents and settings\All Users\Start Menu\Programs\Startup\
    Acrobat Assistant.lnk - c:\program files\Adobe\Acrobat 6.0\Distillr\acrotray.exe [2003-10-23 217194]
    HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2007-10-14 214360]
    Microsoft Office.lnk - c:\program files\Microsoft Office\Office\OSA9.EXE [1999-2-17 65588]
    Updates from HP.lnk - c:\program files\Updates from HP\309731\Program\Updates from HP.exe [2005-3-25 45056]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 19:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\Program Files\\Updates from HP\\309731\\Program\\Updates from HP.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqtra08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpiscnapp.exe "=
    "c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    "c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe "=
    "c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe "=
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [12/16/2009 4:26 PM 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [12/16/2009 4:26 PM 74480]
    R3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [12/16/2009 4:27 PM 7408]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
    hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
    HPService REG_MULTI_SZ HPSLPSVC
    2010-02-23 c:\windows\Tasks\AppleSoftwareUpdate.job
    - c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 16:34]
    2010-02-15 c:\windows\Tasks\McDefragTask.job
    - c:\progra~1\mcafee\mqc\QcConsol.exe [2008-04-10 17:22]
    2010-02-01 c:\windows\Tasks\McQcTask.job
  9. 2010/02/27
    palljim23
    palljim23 Inactive Thread Starter
    ComboFix Part 2 & HTJ Log
    uStart Page = hxxp://www.yahoo.com/
    uDefault_Search_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    mStart Page = hxxp://www.yahoo.com
    mSearch Bar = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    uInternet Connection Wizard,ShellNext = iexplore
    uInternet Settings,ProxyOverride = *.local
    IE: E&xport to Microsoft Excel - c:\progra~1\MI1933~1\Office10\EXCEL.EXE/3000
    Trusted Zone: internet
    Trusted Zone: mcafee.com
    Trusted Zone: turbotax.com
    DPF: {26B2A5DA-BFD6-422F-A89A-28A54C74B12B} - hxxp://www.costcophotocenter.com/upload/activex/v3_0_0_4/PhotoCenter_ActiveX_Control.cab
    DPF: {46D8BEE7-0B27-4466-ABA2-A5F1E157971C} - hxxp://68.239.135.123:100/RemoteWeb.cab
    DPF: {5FFDFC21-AE40-4C7C-955C-415A1ACE01C8} - hxxp://68.239.135.123:100/VideoViewer.cab
    DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} - hxxp://images3.pnimedia.com/ProductAssets/costcous/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab
    DPF: {ADACAA8F-3595-47FE-9C31-9C7471B9BEC7} - hxxp://webcam.geovision.com.tw/cab/OCXChecker_8000.cab
    DPF: {DBAFE6AD-DC14-45DF-A3F7-F8832289A1CD} - hxxp://webcam.geovision.com.tw/cab/DownloadFile_8000.cab
    Rootkit scan 2010-02-27 18:19
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    - - - - - - - > 'winlogon.exe'(628)
    c:\windows\system32\WININET.dll
    c:\windows\system32\Ati2evxx.dll
    - - - - - - - > 'explorer.exe'(5908)
    c:\docume~1\HP_ADM~1\LOCALS~1\Temp\IadHide5.dll
    c:\windows\system32\ieframe.dll
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\Ati2evxx.exe
    l:\program files\Spyware\aawservice.exe
    c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    c:\program files\Bonjour\mDNSResponder.exe
    c:\windows\eHome\ehRecvr.exe
    c:\windows\eHome\ehSched.exe
    c:\program files\Java\jre6\bin\jqs.exe
    c:\program files\Common Files\LightScribe\LSSrvc.exe
    c:\progra~1\McAfee\MSC\mcmscsvc.exe
    c:\progra~1\COMMON~1\mcafee\mna\mcnasvc.exe
    c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
    c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
    c:\program files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    c:\program files\McAfee\MPF\MPFSrv.exe
    c:\windows\system32\PSIService.exe
    c:\program files\CyberLink\Shared Files\RichVideo.exe
    c:\program files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\windows\system32\wdfmgr.exe
    c:\progra~1\mcafee.com\agent\mcagent.exe
    c:\windows\AGRSMMSG.exe
    c:\windows\SOUNDMAN.EXE
    c:\windows\ALCWZRD.EXE
    c:\windows\system32\dllhost.exe
    c:\windows\system32\wscntfy.exe
    c:\program files\iPod\bin\iPodService.exe
    c:\windows\eHome\ehmsas.exe
    c:\program files\HP\Digital Imaging\bin\hpqSTE08.exe
    c:\program files\HP\Digital Imaging\bin\hpqbam08.exe
    c:\program files\HP\Digital Imaging\bin\hpqgpc01.exe
    Completion time: 2010-02-27 18:29:07 - machine was rebooted
    ComboFix-quarantined-files.txt 2010-02-27 23:29
    ComboFix2.txt 2010-02-07 02:19
    Pre-Run: 16,736,739,328 bytes free
    Post-Run: 16,944,148,480 bytes free
    - - End Of File - - 5A553C1065AE3B43EE1FC2BC79707A01
    HJT
    Logfile of Trend Micro HijackThis v2.0.3 (BETA)
    Scan saved at 6:38:00 PM, on 2/27/2010
    MSIE: Internet Explorer v7.00 (7.00.6000.16981)
    C:\WINDOWS\eHome\ehRecvr.exe
    C:\WINDOWS\eHome\ehSched.exe
    C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\PROGRA~1\mcafee.com\agent\mcagent.exe
    C:\WINDOWS\ehome\ehtray.exe
    C:\windows\system\hpsysdrv.exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\HP\KBD\KBD.EXE
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\WINDOWS\SOUNDMAN.EXE
    C:\WINDOWS\ALCWZRD.EXE
    C:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    C:\Program Files\Brother\ControlCenter2\brctrcen.exe
    C:\Program Files\CyberLink\PCM4Everio\EverioService.exe
    C:\Program Files\Verizon\McciTrayApp.exe
    C:\Program Files\Verizon\VSP\VerizonServicepoint.exe
    C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
    L:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe
    C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
    C:\WINDOWS\system32\dllhost.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\WINDOWS\eHome\ehmsas.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqgpc01.exe
    C:\WINDOWS\explorer.exe
    C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE
    C:\Program Files\TrendMicro\HiJackThis\HiJackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
    O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
    O2 - BHO: Verizon Broadband Toolbar - {A057A204-BACC-4D26-8398-26FADCF27386} - C:\PROGRA~1\VERIZO~1\VERIZO~1.DLL
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
    O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
    O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1125.0\msneshellx.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
    O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
    O3 - Toolbar: Verizon Broadband Toolbar - {A057A204-BACC-4D26-8398-26FADCF27386} - C:\PROGRA~1\VERIZO~1\VERIZO~1.DLL
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1125.0\msneshellx.dll
    O3 - Toolbar: Veoh Video Compass - {52836EB0-631A-47B1-94A6-61F9D9112DAE} - C:\Program Files\Veoh Networks\Veoh Video Compass\SearchRecsPlugin.dll
    O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
    O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [HPHUPD06] c:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
    O4 - HKLM\..\Run: [HPHmon06] C:\WINDOWS\system32\hphmon06.exe
    O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
    O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
    O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
    O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
    O4 - HKLM\..\Run: [LSBWatcher] c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    O4 - HKLM\..\Run: [MaxtorOneTouch] C:\Program Files\Maxtor\OneTouch\utils\Onetouch.exe
    O4 - HKLM\..\Run: [ControlCenter2.0] C:\Program Files\Brother\ControlCenter2\brctrcen.exe /autorun
    O4 - HKLM\..\Run: [EverioService] "C:\Program Files\CyberLink\PCM4Everio\EverioService.exe "
    O4 - HKLM\..\Run: [mcagent_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
    O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
    O4 - HKLM\..\Run: [Verizon_McciTrayApp] C:\Program Files\Verizon\McciTrayApp.exe
    O4 - HKLM\..\Run: [VerizonServicepoint.exe] "C:\Program Files\Verizon\VSP\VerizonServicepoint.exe" /AUTORUN
    O4 - HKLM\..\Run: [SSBkgdUpdate] "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
    O4 - HKLM\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
    O4 - HKLM\..\Run: [PaperPort PTD] "L:\Program Files\ScanSoft\PaperPort\pptd40nt.exe "
    O4 - HKLM\..\Run: [IndexSearch] "L:\Program Files\ScanSoft\PaperPort\IndexSearch.exe "
    O4 - HKLM\..\Run: [PPort11reminder] "L:\Program Files\ScanSoft\PaperPort\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\ScanSoft\PaperPort\11\Config\Ereg\Ereg.ini "
    O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe
    O4 - HKLM\..\Run: [Microsoft Default Manager] "C:\Program Files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe "
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe "
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] L:\Program Files\Security\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [VeohPlugin] "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe "
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    O4 - Global Startup: Acrobat Assistant.lnk = C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
    O4 - Global Startup: Updates from HP.lnk = C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MI1933~1\Office10\EXCEL.EXE/3000
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: HP Smart Select - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - L:\Program Files\Security\Spybot - Search & Destroy\SDHelper.dll
    O15 - Trusted Zone: http://*.mcafee.com
    O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} (Support.com Configuration Class) - https://activatemyfios.verizon.net/sdcCommon/download/FIOS/Verizon FiOS Installer.cab
    O16 - DPF: {10E0E75E-6701-4134-9D95-C0942ED1F1C8} (Snapfish Outlook Import ActiveX Control) - http://www.costcophotocenter.com/CostcoOutlookImport.cab
    O16 - DPF: {26B2A5DA-BFD6-422F-A89A-28A54C74B12B} (Photo Upload Plugin Class) - http://www.costcophotocenter.com/upload/activex/v3_0_0_4/PhotoCenter_ActiveX_Control.cab
    O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - http://www.costcophotocenter.com/CostcoActivia.cab
    O16 - DPF: {40F8967E-34A6-474A-837A-CEC1E7DAC54C} - https://accounting.quickbooks.com/c1/v15.591/qboax9.cab
    O16 - DPF: {46D8BEE7-0B27-4466-ABA2-A5F1E157971C} (Remote200 Control) - http://68.239.135.123:100/RemoteWeb.cab
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
    O16 - DPF: {5FFDFC21-AE40-4C7C-955C-415A1ACE01C8} (CViewerControl Object) - http://68.239.135.123:100/VideoViewer.cab
    O16 - DPF: {843EE768-3A97-455C-9076-741BA3AD7B62} (QuickBooks Online Edition Utilities Class v10) - https://accounting.quickbooks.com/c2/v16.607/qboax10.cab
    O16 - DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} (Photo Upload Plugin Class) - http://images3.pnimedia.com/ProductAssets/costcous/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab
    O16 - DPF: {ADACAA8F-3595-47FE-9C31-9C7471B9BEC7} (OCXDownloadChecker Control) - http://webcam.geovision.com.tw/cab/OCXChecker_8000.cab
    O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://download.mcafee.com/molbin/shared/mcgdmgr/1,0,0,26/mcgdmgr.cab
    O16 - DPF: {DBAFE6AD-DC14-45DF-A3F7-F8832289A1CD} (DownloadFile Control) - http://webcam.geovision.com.tw/cab/DownloadFile_8000.cab
    O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} -
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O16 - DPF: {EFD1E13D-1CB3-4545-B754-CA410FE7734F} (Photo Upload Plugin Class) - http://www.costcophotocenter.com/upload/activex/v3_0_0_2/PhotoCenter_ActiveX_Control.cab?
    O16 - DPF: {FFFFFFFF-CACE-BABE-BABE-00AA0055595A} - http://trueswitch.com/TrueInstall.exe
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
    O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
    O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - L:\Program Files\Spyware\aawservice.exe
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Unknown owner - c:\Program Files\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: MBackMonitor - McAfee - C:\Program Files\McAfee\MBK\MBackMonitor.exe
    O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
    O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
    O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
    O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
    O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
    O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
    O23 - Service: ProtexisLicensing - Unknown owner - C:\WINDOWS\system32\PSIService.exe
    O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
    End of file - 16420 bytes
  10. 2010/02/27
    Uninstall Combofix:
    Go Start > Run [Vista users, go Start> "Start search"]
    Type in:
    Combofix /Uninstall
    Note the space between the "Combofix" and the "/Uninstall "
    Click OK (Vista users - press Enter).
    Restart computer.
    How is your computer doing at the moment?
    1. Download Temp File Cleaner (TFC)
    2. Go to Kaspersky website and perform an online antivirus scan.
    1. Disable your active antivirus program.
    2. Read through the requirements and privacy statement and click on Accept button.
    3. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
    4. When the downloads have finished, click on Settings.
    5. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
      [*] Archives
      [*] Mail databases
    6. Click on My Computer under Scan.
    7. Once the scan is complete, it will display the results. Click on View Scan Report.
    8. You will see a list of infected items there. Click on Save Report As....
    9. Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button. Then post it here.
    Post fresh HijackThis log as well.
  11. 2010/03/07
    palljim23
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Sunday, February 28, 2010
    Operating system: Microsoft Windows XP Professional Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Saturday, February 27, 2010 12:18:35
    Records in database: 3659349
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    C:\
    D:\
    E:\
    F:\
    G:\
    H:\
    I:\
    J:\
    K:\
    L:\
    W:\
    X:\
    Z:\
    Scan statistics:
    Objects scanned: 219072
    Threats found: 2
    Infected objects found: 4
    Suspicious objects found: 0
    Scan duration: 05:29:20
    File name / Threat / Threats count
    L:\Music\Lance\installm19.exe Infected: not-a-virus:AdWare.Win32.WurldMedia.j 1
    L:\CC_D\Lisa & Lance\installm19.exe Infected: not-a-virus:AdWare.Win32.WurldMedia.j 1
    L:\CC_G\_JIM\_JIM\installm19.exe Infected: not-a-virus:AdWare.Win32.WurldMedia.j 1
    L:\CC_G\_JIM\_JIM\Morph20.exe Infected: not-a-virus:AdWare.Win32.WurldMedia.a 1
    Selected area has been scanned.
  12. 2010/03/07
    Please download OTM
    • Save it to your desktop.
    • Please double-click OTM to run it. (Note: If you are running on Vista, right-click on the file and choose Run As Administrator).
    • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose Copy):
    :Processes
    :Services
    :Reg
    :Files
    :Commands
    [purity]
    [resethosts]
    [emptytemp]
    [Reboot]
    • Return to OTM, right click in the Paste Instructions for Items to be Movedwindow (under the yellow bar) and choose Paste.
    • Click the red Moveit! button.
    • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
    • Close OTM and reboot your PC.
    Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes. In this case, after the reboot, open Notepad (Start->All Programs->Accessories->Notepad), click File->Open, in the File Name box enter *.log and press the Enter key, navigate to the C:\_OTMoveIt\MovedFiles folder, and open the newest .log file present, and copy/paste the contents of that document back here in your next post.
  13. 2010/03/13
    palljim23
    All processes killed
    ========== PROCESSES ==========
    ========== FILES ==========
    L:\Music\Lance\installm19.exe moved successfully.
    L:\CC_D\Lisa & Lance\installm19.exe moved successfully.
    L:\CC_G\_JIM\_JIM\installm19.exe moved successfully.
    L:\CC_G\_JIM\_JIM\Morph20.exe moved successfully.
    C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Default User
    User: HP_Administrator
    ->Temp folder emptied: 100102228 bytes
    ->Temporary Internet Files folder emptied: 302512015 bytes
    ->Java cache emptied: 12340959 bytes
    ->FireFox cache emptied: 0 bytes
    ->Apple Safari cache emptied: 0 bytes
    ->Flash cache emptied: 241486 bytes
    User: LocalService
    User: NetworkService
    ->Temporary Internet Files folder emptied: 533900 bytes
    Windows Temp folder emptied: 981983 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 5034201 bytes
    Total Files Cleaned = 402.00 mb
    OTM by OldTimer - Version 3.1.10.0 log created on 03132010_174445
    Files moved on Reboot...
  14. 2010/03/13
    Please download OTC to your desktop. It'll remove most tools and logs we used so far. If any tool, file or folder (belonging to the program we have used) hasn't been deleted, please delete it manually.
    • Double-click OTC.exe to run it. (Vista and 7 users, please right click on OTC and select "Run as an Administrator ")
    • Click on the CleanUp! button and follow the prompts.
    • You will be asked to reboot the machine to finish the Cleanup process, choose Yes. If it doesn't ask you to reboot, restart computer manually.
    • After the reboot all the tools we used should be gone.
    • The tool will delete itself once it finishes.
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Disable TeaTimer, as it'll interfere with the cleaning process:
    Right click Spybot's TeaTimer System Tray Icon.
    Click Exit Spybot-S&D Resident.
    TeaTimer closes.
    NOTE. If on re-boot, Spybot inquires about registry change(s), allow it.
    Alternatively, I suggest, you uninstall Spybot since it's a tool of the past.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe [unless you have paid version]
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll [unless you have paid version]
    5. Click on Fix checked button.
    6. Restart computer.
    7. Post new HijackThis log.
  15. 2010/03/13
    palljim23
    Scan saved at 8:28:33 PM, on 3/13/2010
    C:\HP\KBD\KBD.EXE
    C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
    C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_clipbook.exe
    O1 - Hosts: ÿþ127.0.0.1 localhost
    O1 - Hosts: ::1 localhost
    O23 - Service: McAfee Application Installer Cleanup (0194961267325653) (0194961267325653mcinstcleanup) - Unknown owner - C:\WINDOWS\TEMP\019496~1.EXE (file missing)
    O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
    End of file - 12566 bytes
  16. 2010/03/13
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  17. 2010/03/15
    palljim23
    Everything seems to be working much better now. Thank you so much for your patience.
    The only issue I have now is an error message when I restart. It states the following:
    hphmon06.exe - Unable to locate component
    This application has failed to start because hpzjrdrd01.dll was not found. Re-installingthis application may fix this problem.
    Otherwise, it is great.
  18. 2010/03/15
    Re-run HJT, checkmark this:
    Click "Fix checked ".
    Restart computer and the error shouldn't be bothering you anymore.
    The above is part of your printer software, so if some printer feature doesn't work, you may need to reinstall printer software.
