Solved Slow computer / unresponsive script
Discussion in 'Malware and Virus Removal Archive' started by Unsprung, 2010/08/16.
  1. 2010/08/24
    Simply delete that file:
    - C:\Documents and Settings\All Users\3d6b3d3\274.mof
    Empty recycle bin afterward.
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
    5. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. Run defrag at your convenience.
    12. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    13. Please, let me know, how your computer is doing.
  2. 2010/08/24
    Unsprung
    Unsprung Inactive Thread Starter
    Here is the ESET report:
    C:\Documents and Settings\All Users\3d6b3d3\274.mof Win32/RogueAV.A trojan
    I will send you the BIOS reading when I next start up.
    Unsprung
    I went into Windows explorer to delete the file with the tojan but ti was not there. There was only one file listed in the All Users folder: NTUSER.dat. So I was unable to rid of the trogan.
    You advice is VERY helpful and appreciated but isn't it premature to say that "your computer is clean" when ESET says that I have a trojan and I am thus far unable to get rid of it?
    I have an icon in the lower right telling me that I am at risk, have no firewall and I should click to update. I didn't. I thought one of the diagnostic tools that you had me run confirmed that I DID have a firewall. Is this bogus? Will it go away if I can successfully get rid of the trogan?
    Because I was unable to delete the trojan file, I did not do steps 1-13.
    I'm worried. Our my credit card numbers safe?
  5. 2010/08/24
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
  6. 2010/08/25
    Unsprung
    Here is the OTL log:
    All processes killed
    ========== OTL ==========
    ========== FILES ==========
    C:\Documents and Settings\All Users\3d6b3d3\274.mof moved successfully.
    [EMPTYTEMP]
    User: All Users
    User: BRITTANY
    User: Default User
    User: HOUSE
    User: KRISTEN
    User: LocalService
    ->Java cache emptied: 0 bytes
    User: MORGAN
    User: NetworkService
    ->Temp folder emptied: 6098 bytes
    User: Peter Blood
    ->Temp folder emptied: 106292792 bytes
    ->Temporary Internet Files folder emptied: 374107 bytes
    ->Java cache emptied: 128094 bytes
    ->FireFox cache emptied: 53208124 bytes
    ->Flash cache emptied: 758 bytes
    Windows Temp folder emptied: 28948 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 153.00 mb
    [EMPTYFLASH]
    User: All Users
    User: BRITTANY
    User: Default User
    User: HOUSE
    User: KRISTEN
    User: LocalService
    User: MORGAN
    User: Peter Blood
    OTL by OldTimer - Version 3.2.10.0 log created on 08242010_205304
    I will now follow the 13 steps that you outlined to reset system restore
  7. 2010/08/25
    Good :)
  8. 2010/08/25
    Unsprung
    Wait, the adobe updater wants to be updated. Its a little squarish icon. Maybe its a wrench or a golf tee. I need to know if it is legit. I'm afraid to update anything. Will PSI or Filehippo do that?
  9. 2010/08/25
    I don't use Reader, so I can't tell you.
    Most likely, it's legit, since your computer is clean.
  10. 2010/08/25
    Unsprung
    Thank you. How do I make sure Windows updates are current?
  11. 2010/08/25
    Unsprung
    There is definitely an issue or two having to do with my firewall. Last night I was unable to run PSI because it says my firewall is interfering with its operation and I must make the firewall allow PSI. On the other hand, the icon that I am unsure about claims that my "computer might be at risk. No firewall is turned on. Click this balloon to fix the problem." Do I even have a firewall? I do not know but I thought one of those diagnostic tools of your said I did. Is it part of Avira Antivirus? Something is wrong.
  12. 2010/08/25
    Go Start>All Programs>Windows Updates and click on it.
    See, if it'll find anything new.
    As for the firewall....
    That may be due to a fact, that, at some point, you had Comodo installed.
    And no, Avira doesn't include firewall.
    That balloon looks legit.
    Click on it and BEFORE you do anything, let me know what you see.
  13. 2010/08/25
    Unsprung
    A menu comes up asking me to install an adobe reader update. "This update addresses customer issues and security vulnerabilities. Adobe recommends that you always install the latest updates. Install or cancel."
    So I do not have a firewall. Do I need one? I don't know much about them accept that they prevent some things from working.
  14. 2010/08/25
    Your computer is clean, so it can't be anything malicious.
    Go for it.
    You do. Windows firewall. Just make sure, it's on.
    Firewall is a very important security tool.
    Go Start>Control Panel. Double click on the Security Center icon. Click on the Windows Firewall icon beneath the status updates. Click On, then OK.
  15. 2010/08/26
    Unsprung
    Thank you so much for taking the time to help. The computer is working safer and I am free of two trojans. I will change my passwords and read through your other precautionary suggestions. Thanks again
  16. 2010/08/26
    You're very welcome :)
    Good luck and stay safe :)
