simple question, system32.exe need to be remove?
Discussion in 'Malware and Virus Removal Archive' started by Hei, 2009/11/18.
  1. 2009/11/18
    Hei
    Hei Inactive Thread Starter
    I know it is a virus and i know how to remove it, but i just don't know will it affect my computer after remove it. Should i remove it?
    thanks in advance.
    Hei,
  2. 2009/11/18
    tashman847
    tashman847 Inactive
    To be honest i am not a malware expert.
    Before you remove any files that you are unsure of the consequences it is always a good idea to back up.
    Im sure Broni will be able to assist you further with this.
    Tom
    Hi,
    Read this post as indicated at the top of this forum & follow the instructions.
