Shutdown hangs
Discussion in 'Legacy Windows' started by mattman, 2006/03/17.
  1. 2006/04/14
    mattman Inactive Alumni Thread Starter
    SUCCESS! (I hope :rolleyes: )
    What I have done:
    I tried removing the entries for mobsync and WinVNC. Only the 04-HKLM WinVNC entry was removed (BTW, the VNC folder is empty).
    I found that mobsync needs to be disabled in 5 or 6 settings of "Synchronize ".
    I noted that there was no listing for the Service Pack. Updated to SP4.
    It seemed to be intermittent (and I was getting depressed).
    Went to Dell and got the latest chipset drivers. No stalled shutdowns since then.
    I will swap back to the original drive and do those steps in the reverse order to see which one is the problem, but I would say the chipset drivers and SP4 did the trick.
    Many thanks for the help from you all.
  2. 2006/04/16
    Rockster2U
    Rockster2U Geek Member
    Good news Matt. Also learned that mobsync is mobile synchronization for hand helds. I haven't used My Own Backup software for a few years now but do have mobile synchronization with my PDA and mobsync is clearly there. Not going to install MOB at this point to see if I gave you a bum steer but it sounds like it all worked out OK. Nice move working with a cloned drive too - makes for very safe problem resolution and I think I might tuck that into my own trick bag.
    kilocharlie7
    kilocharlie7 Inactive
    Similar problem, Shut down... Identified
    Hi all..
    I'm having a problem similar. Shutdown hangs at "please wait while windows shuts down" screen. :eek:
    I realized I had the same problem when I used Mcafee Virus supplied with MSN.
    Last year I bought Norton, and I didn't have the problem. My subscription ran out and I re-installed Mcafee.. and lo and behold the problem is back.
    Any suggestions? I've searched for hangs regarding Mcafee, and have come up dry.
