Resolved shift + c not working
Discussion in 'Windows 7' started by ramjet, 2013/03/19.
  1. 2013/03/19
    ramjet
    ramjet Well-Known Member Thread Starter
    I may be in the wrong area, but I have a problem that I can't resolve. Something, or some program, virus, ect has altered my keyboard so that whenever I try to get a capitol c (shift+c)
    a page(URL) appears on my screen, I've tried several suggestions ,and all that I know (I'm not a programmer) to correct this problem, All I want to do is get my keyboard back to normal so when
    a shift + c is typed, I get a capitol c, can anyone help ???
  2. 2013/03/19
    ramjet
    I should have stated in the original post that many malware and anti virus programs have been run.. No problems detected. Thanks.
  5. 2013/03/19
    Try another keyboard?
    There's a registry key that holds values for keyboard combinations which has probably been altered by malware. If after you post in the Malware forum here, and after following suggested malware removal, the problem still exists, return to this thread and ask for me to post a link to a .reg file that resets the keyboard to its defaults.
    ramjet likes this.
  7. 2013/03/22
    BobbyScot
    BobbyScot Geek Member
    Have you checked that your keyboard is configured for UK!
  8. 2013/03/23
    Ramjet lives in Ohio :D - See location under name.
  9. 2013/03/23
    ramjet
    Hi,
    I've marked this as "RESOLVED" several times but it isn't showing up as so at the thread.
    I've found a "error in the reg. which has been fixed Thanks to all who helped.
  10. 2013/03/23
    Strange - works for me. Marked as Resolved.
  11. 2013/03/23
    BobbyScot
    It pays to read the small print!!
  12. 2013/03/23
