Windows Vista Shared technologies failure
Discussion in 'Legacy Windows' started by digiman59, 2012/02/28.
  1. 2012/02/28
    digiman59
    digiman59 Inactive Thread Starter
    Hi all, looking for assistance again please, but on a laptop this time :)
    Running Home basic 32 bit SP2
    I have tried to install an Adobe program but right at the end of install i continually get the message; Below mentioned application has failed to install; Shared Technologies.
    I have the same program already installed on my tower pc running XP SP3 and didn't have this problem.
    Any suggestions please?
    TIA
    Martin
  2. 2012/02/28
    wildfire
    wildfire Getting Old
    Which Adobe program (including Version)?
    And are you getting it from the Adobe site or some other site?
  5. 2012/02/29
    Appears to be related to Adobe Photoshop - no specific version.
    I suggest you check out the Adobe Forums, etc via this link to a Google Search.
  6. 2012/02/29
    digiman59
    Thank you all for your help. It appears to be a Visual Studio runtime problem. I've downloaded it from MS and hopefully this will resolve the problem....
    The programme i was trying to install was Elements 10..
    Cheers again
    Martin
