Active Search engine redirect jump
Discussion in 'Malware and Virus Removal Archive' started by MFapocalypse, 2009/11/20.
  1. 2009/11/20
    MFapocalypse
    MFapocalypse Inactive Thread Starter
    [Active] Search engine redirect jump
    My browser will do a redirect jump anytime i try to go to any search results from a search engine. my security software sweep found something before this calling it malware and supposedly deleted it..but now this. not to savvy about this sort of thing and need help. thank you for your time.
  2. 2009/11/20
    Hi,
    Read this post as indicated at the top of this forum & follow the instructions.
    MFapocalypse
    i have done what that post asked...and turned off my antivirus first...but the logs never seem to pop up...i dont know what i'm doing wrong. some more info...
    so I have an anti virus called "webroot ". it found these:
    virus - "Mal/ObfJS-X "
    hack tool - "App/ForceLib-A "
    That "Mal/ObfJS-X" thing has been found and deleted by the program twice before this. it seems to reappear.
  5. 2009/11/21
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
    Download HijackThis:
    http://www.trendsecure.com/portal/en-US/tools/security_tools/hijackthis/download
    by clicking on Download HijackThis Installer
    Install, and run it.
    Post HijackTHis log.
    Do NOT attempt to fix anything!
    NOTE. If you're using Vista, right click on HijackThis, and click Run as Administrator
  6. 2009/11/21
    MFapocalypse
    okay this is wierd. so i install combofix and hijackthis on my desktop. i turn off webroot. i run combofix...it like stalls at about 3 min in. i shut it down, run again. this time it wants to install some backup thing for windows(?). uh...okay i do it. it freezes. run it again...this time it says i have AVG running<?> i supposedly uninstalled that like a million years ago...i go searching...find parts of it running i never knew of. i try to uninstall again...it says the shortcuts to uninstall go nowhere. i search for anything avg...find lots of stuff. no way to uninstall. add/remove progs doesnt even see it. i delete as much avg stuff as will let me (still sitting in recycle bin). some will not let me delete. no delete/uninstall? so i'm stuck with pieces of an old prog no matter what? anyways i try again after looking in my task manager processes and ending anything with an avg in it. it (combofix) runs. it starts deleting things(?). then it reboots my system on it's own. at relaunch it says it's gonna give me the log, but at start up...webroot wants to run...they freeze each other. i end both. my desktop reverts to some different pic i have in my pics folder. and there is some other indications that somehow it resetted my system to some random point months ago(?). never even got to running hijackthis yet. so i try to run combofix again to get you a log right? well it says avg is still running! what do i do? oh...and i checked my search engine problem...it's gone...this is wierd. i think i got what i wanted but now i'm left with more questions than answers. what do i do?
  7. 2009/11/21
    MFapocalypse
    i disabled webroot, ran avg uninstall. it's not gone, in fact there is even MORE avg files now. cannot get rid of it or turn it off. ran combofix twice now since last i posted, it says it deletes some spysweeper shedule log or something, reboots my comp. then just sits there saying it's going to give me the log, but it was like a half an hour when i finally said ***** it, ran hijack this...here is that log:
    Scan saved at 4:22:53 PM, on 11/22/2009
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\ComboFix\hidec.exe
    C:\WINDOWS\system32\cmd.exe
    C:\Program Files\Webroot\WebrootSecurity\SpySweeper.exe
    C:\ComboFix\Catchme.tmp
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R3 - URLSearchHook: Freecorder Toolbar - {1392b8d2-5c05-419f-a8f6-b9f15a596612} - C:\Program Files\Freecorder\tbFre1.dll
    O2 - BHO: (no name) - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - (no file)
    O2 - BHO: Freecorder Toolbar - {1392b8d2-5c05-419f-a8f6-b9f15a596612} - C:\Program Files\Freecorder\tbFre1.dll
    O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - (no file)
    O2 - BHO: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - (no file)
    O2 - BHO: Ask Toolbar BHO - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll (file missing)
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - (no file)
    O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - c:\progra~1\mcafee.com\vso\mcvsshl.dll
    O3 - Toolbar: Ask && Record Toolbar - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files\Ask.com\GenericAskToolbar.dll (file missing)
    O3 - Toolbar: Freecorder Toolbar - {1392b8d2-5c05-419f-a8f6-b9f15a596612} - C:\Program Files\Freecorder\tbFre1.dll
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
    O16 - DPF: {01111F00-3E00-11D2-8470-0060089874ED} (Support.com Installer) - http://supportsoft.adelphia.net/sdccommon/download/tgctlins.cab
    O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} (Support.com Configuration Class) - http://activation.rr.com/install/downloads/tgctlcm.cab
    O16 - DPF: {37A273C2-5129-11D5-BF37-00A0CCE8754B} (TTestGenXInstallObject) - http://asp.mathxl.com/wizmodules/testgen/installers/TestGenXInstall.cab
    O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} (MySpace Uploader Control) - http://lads.myspace.com/upload/MySpaceUploader1006.cab
    O16 - DPF: {95D88B35-A521-472B-A182-BB1A98356421} (Pearson Installation Assistant 2) - http://asp.mathxl.com/books/_Players/PearsonInstallAsst2.cab
    O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} (Crucial cpcScan) - http://www.crucial.com/controls/cpcScanner.cab
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O16 - DPF: {E6D23284-0E9B-417D-A782-03E4487FC947} (Pearson MathXL Player) - http://asp.mathxl.com/books/_Players/MathPlayer.cab
    O16 - DPF: {FD0B6769-6490-4A91-AA0A-B5AE0DC75AC9} (Performance Viewer Activex Control) - https://secure.logmein.com/activex/ractrl.cab?lmi=100
    O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - (no file)
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: McAfee.com McShield (McShield) - Unknown owner - c:\PROGRA~1\mcafee.com\vso\mcshield.exe
    O23 - Service: McAfee SecurityCenter Update Manager (mcupdmgr.exe) - Unknown owner - C:\PROGRA~1\McAfee.com\Agent\mcupdmgr.exe (file missing)
    O23 - Service: McAfee.com VirusScan Online Realtime Engine (MCVSRte) - Unknown owner - c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe (file missing)
    O23 - Service: Webroot Spy Sweeper Engine (WebrootSpySweeperService) - Webroot Software, Inc. (www.webroot.com) - C:\Program Files\Webroot\WebrootSecurity\SpySweeper.exe
    End of file - 6065 bytes
  9. 2009/11/22
    Delete your Combofix file.
    Download fresh one from HERE and try again.
    I renamed the file for a reason.
  10. 2009/11/23
    MFapocalypse
    That link led to this message:
    "The file you are trying to access is no longer available publicly. "
  11. 2009/11/23
    Sorry for that.
    HERE
  12. 2009/11/24
    MFapocalypse
    okay now i got an error message saying you cannot rename combofix.
  13. 2009/11/24
    Did you delete your Combofix file before downloading mine?
