Windows Vista Safe Mode not working....
Discussion in 'Legacy Windows' started by spiderpug, 2009/09/13.
  1. 2009/09/29
    Cheers :)
  2. 2009/09/29
    spiderpug
    spiderpug Inactive Thread Starter
    Hi
    I am backing up my files with NTI Backup Now 5, I found it already installed on my computer :D
    The EASEUS just didnt want to write on the small HDD?? I dont know whats wrong with it.
    My computer is really playing up after installing windows updates... I cant see my power on my laptop and the internet connection on the tray on the taskbar, so frustrating i feel like smashing the thing!
    Check (from memory, running Windows 7) ....
    Start > Network Connections > right click on your connection and ensure that the 'Show icon ...' box is checked.
    Control Panel > Power Options and on one of the tabs check the 'Show icon .... ' box
  5. 2009/09/29
    spiderpug
    hi
    I cannot find the power or network... doesnt have those tick boxes...
    And I cannot find the programs run when the computer starts up...
  6. 2009/09/29
    Forgot you'running Vista - never used it regularly .....
    Somewhat different from XP - as this problem does not bear any relationship to the thread title please start a new thread on this.
  7. 2009/09/29
    spiderpug
    Hi fixed it now just in 20 seconds!
    Just ran CMD and typed
    taskkill /f /im explorer.exe
    explorer.exe
    Pressed enter , and i reset explorer the task bar went blank and then added the power and internet icon! :D cool!
  8. 2009/09/30
    I'm marking this thread resolved. Start a new thread on any separate topics.
