RTHDCPL.EXE - Illegal Relocation
Discussion in 'Windows XP' started by sniper9228, 2007/04/03.
  1. 2007/04/04
    sniper9228
    sniper9228 Well-Known Member Thread Starter
    Anyway, I installed both patches and it seems to be working perfectly
  2. 2007/04/04
    charlesvar
    charlesvar Inactive Alumni
    A friend called me pointing me to this post at dsl - couldn't resist posting it here :)
    http://www.dslreports.com/forum/remark,18117865
    Regards - Charles
    sniper9228
    Whats this junk about April 10th security updates
  5. 2007/04/04
    mannybj
    mannybj Inactive
    Kb925902
    This is a VISTA FIX....Not XP.
  6. 2007/04/04
    Coleman Smith
    Coleman Smith Inactive
    Thanks for the Help
    I would like to introduce my self as the Buffoon of the Year.
    I spent 4 hours trying to figure this out and then came here and found the error on the first click.
  7. 2007/04/04
    sniper9228
    It is also an XP fix,
    and
    your welcome for the help you needed
  8. 2007/04/04
    Coleman Smith
    sniper9228
    I know, thank you
  10. 2007/04/05
    wmw92258
    wmw92258 Inactive
    Try this microsoft update for this issue http://www.microsoft.com/downloads/...88-3131-429C-8FCB-F7B3B0FD3D86&displaylang=en
    :p
  11. 2007/04/06
    Rockster2U
    Rockster2U Geek Member
    Whiskeyman:
    Thanks - ran into this issue on an Averatec laptop. Patch - Error - Patch - Fixed.
  12. 2007/04/06
    TheWyrm
    TheWyrm Inactive
    RTHDCPL.exe Fix
    Hi All, New here, Just read the group concerning the mentioned RTHDCPL issue, My wife and a friend have had the same issue that seems to relate to Realtek Soundcards on HP machines.
    So far My Wife, a Friend and a Co-Worker have called with same issue and they all have HP machines.
    My Machine does not have Realtek sound so the issue does not apply to me. Good advice from above posts fixed 3 issues in 15 minutes of calls, but what do we tell people about the Auto Update? Wait 2 weeks for a Patch to Patch for the patch and if that patch dosen't work then we have to uninstall ALL the patches to install a Service pack patch for all the patches to be patched?:D
    Good advice thanks. Just say NO to Vista.
  13. 2007/04/06
    charlesvar
    Hello TheWyrm,
    First, yes, wait a while.
    Second, blindly downloading/updating is not the way to go.
    Change the AU options to notify before download and then do one at a time, wait a day or two, then the next.
    Criticals create system restore points and create Add/Remove entries. You should make sure that SR is first, enabled, and that the restore function works. For those that use drive imaging, SR can be optional. For most, SR is the only way to roll back a bad update, or system problems in general.
    To test SR's restore function:
    Take any executable file (extention .exe), and burn it out and/or move it to the My Documents folder and delete it from it's original location. SR does not monitor files in My Documents folder regardless of file type.
    Then restore to the initial restore point created by the system; the deleted executable should be back in it's original location. Afterwards, you can delete the copy in My Documents.
    FYI: The file types (extensions) SR monitors
    http://msdn.microsoft.com/library/default.asp?url=/library/en-us/sr/sr/monitoring_the_system.asp
    Regards - Charles
  14. 2007/04/06
    TheWyrm
    TheWyrm Inactive
    Ya, My Co-Worker who is a little more "Tech Savvy" never clued into the Auto-Update and tried a SR to 2 days prior. All XP did was re-download patch and same issue again.
    He called me last night after work and i told him to change his auto-update to "Download first then ask ". He is All Good, But the others are not so Tech Friendly.
    I just looked for the simplest fix and they asked what they should do now? Explaining to them to check back in 2 weeks dosen't really work cuz they get lost in the Tech aspect.
    The end result will be that they never install updates again.
    Not good, I think MS should have planned this a little better, It's gonna wreak havoc on users that just "Use" their machines but have no idea what makes them tick.
  15. 2007/04/06
    charlesvar
    TheWyrm, I forgot to welcome you to the Board :) and thank you for your posts.
    Regards - Charles
  16. 2007/04/07
    unicorne1
    unicorne1 Inactive
