Solved right click issue with wow.dll (seems like a trend)
Discussion in 'Malware and Virus Removal Archive' started by mwdenko, 2013/06/13.
  1. 2013/06/13
    mwdenko
    mwdenko Inactive Thread Starter
    Should I run the next steps?
  2. 2013/06/13
    Yes....
    mwdenko
    All processes killed
    ========== OTL ==========
    64bit-Registry key HKEY_LOCAL_MACHINE\Software\MozillaPlugins\@microsoft.com/GENUINE\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\Software\MozillaPlugins\@Apple.com/iTunes,version=\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\Software\MozillaPlugins\@java.com/JavaPlugin\ deleted successfully.
    Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ deleted successfully.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\cozi\ deleted successfully.
    File Protocol\Handler\cozi - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\livecall\ deleted successfully.
    File Protocol\Handler\livecall - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\ms-help\ deleted successfully.
    File Protocol\Handler\ms-help - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\msnim\ deleted successfully.
    File Protocol\Handler\msnim - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\skype4com\ deleted successfully.
    File Protocol\Handler\skype4com - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\skype-ie-addon-data\ deleted successfully.
    File Protocol\Handler\skype-ie-addon-data - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\wlmailhtml\ deleted successfully.
    File Protocol\Handler\wlmailhtml - No CLSID value found not found.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\wlpg\ deleted successfully.
    File Protocol\Handler\wlpg - No CLSID value found not found.
    64bit-Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\\WebCheck deleted successfully.
    64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E6FB5E20-DE35-11CF-9C87-00AA005127ED}\ not found.
    ========== FILES ==========
    File\Folder C:\FRST not found.
    [EMPTYTEMP]
    User: All Users
    User: Default
    ->Temporary Internet Files folder emptied: 67 bytes
    User: Default User
    User: J
    ->Temp folder emptied: 39087 bytes
    ->Temporary Internet Files folder emptied: 43296569 bytes
    ->Java cache emptied: 4927406 bytes
    ->Google Chrome cache emptied: 8193893 bytes
    ->Flash cache emptied: 534 bytes
    User: Public
    %systemroot%\System32 (64bit) .tmp files removed: 0 bytes
    Windows Temp folder emptied: 7382 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 95336 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 749 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 54.00 mb
    [EMPTYJAVA]
    User: All Users
    User: Default
    User: Default User
    User: J
    ->Java cache emptied: 0 bytes
    User: Public
    Total Java Files Cleaned = 0.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default
    User: Default User
    User: J
    User: Public
    OTL by OldTimer - Version 3.2.69.0 log created on 06132013_215637
    C:\Users\J\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
    PendingFileRenameOperations files...
    Results of screen317's Security Check version 0.99.64
    Windows 7 Service Pack 1 x64 (UAC is enabled)
    Internet Explorer 10
    ``````````````Antivirus/Firewall Check:``````````````
    Windows Firewall Enabled!
    Microsoft Security Essentials
    (On Access scanning disabled!)
    Error obtaining update status for antivirus!
    `````````Anti-malware/Other Utilities Check:`````````
    Malwarebytes Anti-Malware version 1.75.0.1300
    Java(TM) 6 Update 30
    Java(TM) 6 Update 31
    Java version out of Date!
    Adobe Flash Player 10 Flash Player out of Date!
    Adobe Reader 10.1.7 Adobe Reader out of Date!
    Google Chrome 27.0.1453.110
    Google Chrome 27.0.1453.94
    ````````Process Check: objlist.exe by Laurent````````
    Microsoft Security Essentials MSMpEng.exe
    Microsoft Security Essentials msseces.exe
    Malwarebytes Anti-Malware mbamservice.exe
    Malwarebytes Anti-Malware mbamgui.exe
    Malwarebytes' Anti-Malware mbamscheduler.exe
    `````````````````System Health check`````````````````
    Total Fragmentation on Drive C: 0%
    ````````````````````End of Log``````````````````````
    Farbar Service Scanner Version: 31-05-2013 01
    Ran by J (administrator) on 13-06-2013 at 22:07:19
    Running from "C:\Users\J\Desktop\Matthew "
    Windows 7 Home Premium Service Pack 1 (X64)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo IP is accessible.
    Yahoo.com is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Action Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Windows Defender:
    WinDefend Service is not running. Checking service configuration:
    The start type of WinDefend service is set to Demand. The default start type is Auto.
    The ImagePath of WinDefend service is OK.
    The ServiceDll of WinDefend service is OK.
    Windows Defender Disabled Policy:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender]
    "DisableAntiSpyware "=DWORD:1
    Other Services:
    File Check:
    C:\Windows\System32\nsisvc.dll => MD5 is legit
    C:\Windows\System32\drivers\nsiproxy.sys => MD5 is legit
    C:\Windows\System32\dhcpcore.dll => MD5 is legit
    C:\Windows\System32\drivers\afd.sys => MD5 is legit
    C:\Windows\System32\drivers\tdx.sys => MD5 is legit
    C:\Windows\System32\Drivers\tcpip.sys
    [2013-06-11 23:03] - [2013-05-08 02:39] - 1910632 ____A (Microsoft Corporation) 9849EA3843A2ADBDD1497E97A85D8CAE
    C:\Windows\System32\dnsrslvr.dll => MD5 is legit
    C:\Windows\System32\mpssvc.dll => MD5 is legit
    C:\Windows\System32\bfe.dll => MD5 is legit
    C:\Windows\System32\drivers\mpsdrv.sys => MD5 is legit
    C:\Windows\System32\SDRSVC.dll => MD5 is legit
    C:\Windows\System32\vssvc.exe => MD5 is legit
    C:\Windows\System32\wscsvc.dll => MD5 is legit
    C:\Windows\System32\wbem\WMIsvc.dll => MD5 is legit
    C:\Windows\System32\wuaueng.dll => MD5 is legit
    C:\Windows\System32\qmgr.dll => MD5 is legit
    C:\Windows\System32\es.dll => MD5 is legit
    C:\Windows\System32\cryptsvc.dll
    [2013-06-11 23:02] - [2013-05-13 01:51] - 0184320 ____A (Microsoft Corporation) D8129C49798CBBFB2E4351D4B7B8EF9C
    C:\Program Files\Windows Defender\MpSvc.dll => MD5 is legit
    C:\Windows\System32\ipnathlp.dll => MD5 is legit
    C:\Windows\System32\iphlpsvc.dll => MD5 is legit
    C:\Windows\System32\svchost.exe => MD5 is legit
    C:\Windows\System32\rpcss.dll => MD5 is legit
    **** End of log ****
  5. 2013/06/13
    mwdenko
    waiting on on-line scan
  6. 2013/06/13
    mwdenko
    No threats found!
  8. 2013/06/13
    [​IMG] Update Adobe Flash Player: http://get.adobe.com/flashplayer/
    Make sure you UN-check Yes, install McAfee Security Scan Plus
    NOTE 1: Beginning with Adobe Flash Version 11.3, the universal installer includes the 32-bit and 64-bit versions of the Flash Player.
    NOTE 2: While installing make sure you UN-check any extra garbage which wants to install alongside.
    [​IMG] Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions (if present).
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader (33.5 MB), download and install Foxit PDF Reader(3.5MB) from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or any other garbage.
    [​IMG] 1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it.
    • Run JavaRa.exe (Vista and 7 users! Right click on JavaRa.exe, click Run As Administrator), pick the language of your choice and click Select. Then click Remove Older Versions.
    • Accept any prompts.
    • Do NOT post JavaRa log.
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure Windows Updates are current.
    4. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    5. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. (Windows XP only) Run defrag at your convenience.
    12. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    13. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    14. Please, let me know, how your computer is doing.
  9. 2013/06/13
    mwdenko
    [EMPTYTEMP]
    User: All Users
    User: Default
    User: Default User
    User: J
    ->Temp folder emptied: 69943 bytes
    ->Temporary Internet Files folder emptied: 8380258 bytes
    ->Java cache emptied: 37820 bytes
    ->Google Chrome cache emptied: 7442228 bytes
    ->Flash cache emptied: 492 bytes
    User: Public
    Windows Temp folder emptied: 0 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 0 bytes
    Total Files Cleaned = 15.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default
    User: Default User
    User: J
    User: Public
    [EMPTYJAVA]
    User: All Users
    User: Default
    User: Default User
    User: J
    User: Public
    Restore point Set: OTL Restore Point
    OTL by OldTimer - Version 3.2.69.0 log created on 06132013_235740
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\AntiPhishing\7A7E08C8-3FF5-45F2-873D-A84D669DC82F.dat moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\YZ4EL0M2\fastbutton[1].htm moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\YZ4EL0M2\like[1].htm moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\YZ4EL0M2\p-01-0VIaSjnOLg[1].gif moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CIUYC737\105593-active-right-click-issue-wow-dll-seems-like-trend-2[1].htm moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CIUYC737\xd_arbiter[1].htm moved successfully.
    C:\Users\J\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CIUYC737\xd_arbiter[2].htm moved successfully.
  10. 2013/06/13
    mwdenko
    Only issue left is that I can't search or type in a url directly into the top portion of IE.
  11. 2013/06/13
    Reset Internet Explorer.
    Go here: http://support.microsoft.com/kb/923737 and run "FixIt" procedure.
    You can use ANY browser to download "FixIt" file.
    Make sure you follow ALL steps listed there.
  12. 2013/06/13
    mwdenko
    Sweet! Thank you so much. That fixed it!
    My friend will be eternally grateful. Now if I can only get them to keep this laptop up to date!!!
    Thanks again.
    I'll be donating in the morning. I'm exhausted. Thanks!
  13. 2013/06/13
    Way to go!! [​IMG]
    Good luck and stay safe :)
