Resolved Restore Search Box in IE 9?
Discussion in 'Internet Explorer & Microsoft Edge' started by dkline, 2012/05/07.
  1. 2012/05/09
    dkline
    dkline Inactive Thread Starter
    I just spoke with HP, and manufacturer of my Pavillion notebook. Using my product # and serial #, they looked up the manifest and confirmed that you are absolutely correct, Arie.
    My notebook was originally loaded with IE 8 and then updated prior to shipping to Costco (where I got it with a great $100 off extra discount).
    The nice gentleman in Banmgalore ... er, excuse me, in Mountain View, assured me that it is impossible to uninstall IE 9 and NOT have IE 8 left on it.
    But I'll take your warning of a possible pear-shaped future to heart and download Firefox just in case.
    Btw, how do I set automatic updates so IE 9 won't be re-installed? Can I leave it so that "important" updates are auto installed but recommended updates they have to ask me?
    (P.S. The HP tech said that in his opinion, IE 8 is more stable anyway. He says he gets calls every day from people having problems with video and other things in IE 9.)
  2. 2012/05/09
    dkline
    Different computer now, related question:
    On my office desktop PC, I run IE 8 on a Win 7 64-bit machine. But I was just checking "view update history" under Windows Updates and see that on 3/7/12, IE 9 was supppsedly installed successfully as an "important" update.
    But I know I'm using IE 8 (I just double-checked "about" in IE). And when I check "view installed updates," IE 9 is not listed under the Microsoft Windows section.
    So what's going on?
    It says IE 9 was installed, but it's not.
    My update settings allow all important updates to be installed automatically, but obviously IE 9 is not installed.
    Could it be that "view update history" refers only to downloaded updates, and that "view installed updates" shows the only ones that have been installed?
    Did I do something and forget doing it -- like updating to IE 9, uninstalling it, and somehow telling IE 9 never to try again?
    Weird.
    dkline
    Okay, I'm back at home and ready to uninstall IE 9 tonight.
    One question: if the uninstall goes south on me, will system restore bring IE 9 back?
  5. 2012/05/15
    Yes, I just tried, it worked fine.
  6. 2012/05/15
    dkline
    Thanks, Arie. That was very kind of you to double check that.
  7. 2012/05/15
    I don't think that it will matter as MS is going to force IE 9 on you and you will have no choice. Best thing is to get something like the Google tool bar and be done with it.
  8. 2012/05/15
    dkline
    Stupid thing like eliminating a search bar is something they might correct.
  9. 2012/05/15
    dkline
    It worked, Arie!
    I now have IE 8 running on the machine. And the listing for IE 9 in "turn Windows features on or off" has morphed into IE 8.
    Thank you.
    I want to ask you about your post a long while ago about creating daily automatic restore points -- your method wporked perfectly on my desktop but doesn't work on my new laptop and i'm not sure why -- but should I mark this thread resolved and start a new one?
  10. 2012/05/15
    Yes please... that's an issue not related to this.
  11. 2012/05/15
    MS to force IE 8 and IE 9 on customers. Link is below.
    ZDNet
  12. 2012/05/16
    dkline
    The article notes, however, that you need to have automatic updates enabled (I'm on download only, then I decide).
    It also says: "For business and individuals that don't want the upgrade, perhaps to maintain in-house custom tools, Microsoft provides automatic update blocker kits for IE8 and IE9. "
