Solved Resident Shield Alert Pop-Ups
Discussion in 'Malware and Virus Removal Archive' started by LuckyMoody, 2011/01/15.
  1. 2011/01/16
    Very well :)
    Update your Java version here: http://www.java.com/en/download/installed.jsp
    Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    Run OTL
      :OTL
      IE - HKU\.DEFAULT\..\URLSearchHook: {A3BC75A2-1F87-4686-AA43-5347D756017C} - Reg Error: Key error. File not found
      IE - HKU\S-1-5-18\..\URLSearchHook: {A3BC75A2-1F87-4686-AA43-5347D756017C} - Reg Error: Key error. File not found
      O2 - BHO: (no name) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - No CLSID value found.
      O3 - HKU\S-1-5-21-1060284298-839522115-1606980848-1003\..\Toolbar\ShellBrowser: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - No CLSID value found.
      O3 - HKU\S-1-5-21-1060284298-839522115-1606980848-1003\..\Toolbar\WebBrowser: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - No CLSID value found.
      O18 - Protocol\Handler\avgsecuritytoolbar {F2DDE6B2-9684-4A55-86D4-E255E237B77C} - File not found
      O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
      [6 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
      [3 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
      [1 C:\Documents and Settings\Julie\Desktop\*.tmp files -> C:\Documents and Settings\Julie\Desktop\*.tmp -> ]
      [2009/06/07 07:13:57 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Julie\Application Data\AVGTOOLBAR
      [2009/06/11 17:57:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\AVGTOOLBAR
      @Alternate Data Stream - 121 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Last scans...
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  2. 2011/01/17
    LuckyMoody
    LuckyMoody Inactive Thread Starter
    Hi Broni,
    It's a work day for me, so I won't be back until this evening.
    Here are the two logs you requested. The ESET window (after you click "yes" to accept the terms) wouldn't open. I'll try again tonight.
    OTL Log:
    All processes killed
    ========== OTL ==========
    Registry value HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\URLSearchHooks\\{A3BC75A2-1F87-4686-AA43-5347D756017C} deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C}\ not found.
    Registry value HKEY_USERS\S-1-5-18\Software\Microsoft\Internet Explorer\URLSearchHooks\\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found.
    Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ not found.
    Registry value HKEY_USERS\S-1-5-21-1060284298-839522115-1606980848-1003\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser\\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}\ not found.
    Registry value HKEY_USERS\S-1-5-21-1060284298-839522115-1606980848-1003\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{A057A204-BACC-4D26-9990-79A187E2698E} deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\avgsecuritytoolbar\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F2DDE6B2-9684-4A55-86D4-E255E237B77C}\ deleted successfully.
    File {F2DDE6B2-9684-4A55-86D4-E255E237B77C} - File not found not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\avgrsstarter\ deleted successfully.
    C:\WINDOWS\system32\avgrsstx.dll moved successfully.
    C:\WINDOWS\System32\CONFIG.TMP deleted successfully.
    C:\WINDOWS\System32\REN37.tmp deleted successfully.
    C:\WINDOWS\System32\SETDD.tmp deleted successfully.
    C:\WINDOWS\System32\SETDF.tmp deleted successfully.
    C:\WINDOWS\System32\SETE3.tmp deleted successfully.
    C:\WINDOWS\System32\SETEB.tmp deleted successfully.
    C:\WINDOWS\System32\SETED.tmp deleted successfully.
    C:\WINDOWS\SET3.tmp deleted successfully.
    C:\WINDOWS\SET4.tmp deleted successfully.
    C:\WINDOWS\SET8.tmp deleted successfully.
    C:\Documents and Settings\Julie\Desktop\~WRL0001.tmp deleted successfully.
    C:\Documents and Settings\Julie\Application Data\AVGTOOLBAR\NewCfg folder moved successfully.
    C:\Documents and Settings\Julie\Application Data\AVGTOOLBAR folder moved successfully.
    C:\Documents and Settings\LocalService\Application Data\AVGTOOLBAR folder moved successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2 deleted successfully.
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: Julie
    ->Temp folder emptied: 9268807 bytes
    ->Temporary Internet Files folder emptied: 14586410 bytes
    ->Java cache emptied: 231182335 bytes
    ->Google Chrome cache emptied: 187257413 bytes
    ->Flash cache emptied: 145445 bytes
    User: LocalService
    ->Temp folder emptied: 65536 bytes
    ->Temporary Internet Files folder emptied: 32902 bytes
    ->Google Chrome cache emptied: 6181216 bytes
    User: NetworkService
    ->Temporary Internet Files folder emptied: 67 bytes
    Windows Temp folder emptied: 1118 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 428.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: Julie
    User: LocalService
    OTL by OldTimer - Version 3.2.20.2 log created on 01172011_054705
    File move failed. C:\WINDOWS\temp\_avast5_\Webshlock.txt scheduled to be moved on reboot.
    Checkup Log:
    Results of screen317's Security Check version 0.99.7
    Windows XP Service Pack 3
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Firewall Enabled!
    avast! Free Antivirus
    Antivirus up to date!
    Anti-malware/Other Utilities Check:
    HijackThis 2.0.2
    Java(TM) 6 Update 23
    Out of date Java installed!
    Adobe Flash Player
    Adobe Reader 9.1
    Out of date Adobe Reader installed!
    Process Check:
    objlist.exe by Laurent
    Alwil Software Avast5 AvastSvc.exe
    ALWILS~1 Avast5 avastUI.exe
    ``````````End of Log````````````
    Thanks again for everything! My computer is running faster and the start up process is much faster. I really appreciate it.
    Julie
    Good :)
    Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions.
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader (33.5 MB), download and install Foxit PDF Reader(3.5MB) from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or other garbage.
    If Eset still doesn't want to work, try different browser, or...
    Please run a BitDefender Online Scan
    • Disable your antivirus program.
    • Click Start Scanner button.
    • Click Free scan now button
    • Allow browser plug-in to be installed when prompted.
    • Click I Agree to agree to the EULA.
    • Please refrain from using the computer until the scan is finished.
    • When the scan is finished, click on View report.
    • Notepad will open with scan results.
    • Save the report to your desktop and post its content in your next reply.
  5. 2011/01/17
    LuckyMoody
    Good news...the BitDefender scan worked and no virus were found.
    Here's the report:
    BitDefender Online Scanner
    Scan report generated at: Mon, Jan 17, 2011 - 20:03:54
    Scan path: C:\Documents and Settings\Julie\My Documents;C:\Documents and Settings\All Users\Documents;C:\;D:\;E:\;
    Statistics
    Time
    00:38:58
    Files
    165213
    Folders
    7096
    Boot Sectors
    Archives
    1939
    Packed Files
    7835
    Results
    Identified Viruses
    Infected Files
    Suspect Files
    Warnings
    Disinfected
    Deleted Files
    Engines Info
    Virus Definitions
    6660429
    Engine build
    AVCORE v2.1 Windows/i386 11.0.0.42 (Oct 18 2010)
    Scan plugins
    18
    Archive plugins
    44
    Unpack plugins
    10
    E-mail plugins
    System plugins
    4
    Scan Settings
    First Action
    Disinfect
    Second Action
    Delete
    Heuristics
    Yes
    Enable Warnings
    Yes
    Scanned Extensions
    Exclude Extensions
    Scan Emails
    Yes
    Scan Archives
    Yes
    Scan Packed
    Yes
    Scan Files
    Yes
    Scan Boot
    Yes
    Scanned File
    Status
    No virus found.
    I can't thank you enough!
    Julie
  6. 2011/01/17
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
  7. 2011/01/18
    LuckyMoody
    Hi Broni,
    The computer's never been better! Many thanks to you and this forum.
    I really appreciate all your time and help!
    Here is the OTL log you requested:
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: Julie
    ->Temp folder emptied: 43941 bytes
    ->Temporary Internet Files folder emptied: 69968616 bytes
    ->Java cache emptied: 2027 bytes
    ->Google Chrome cache emptied: 819568 bytes
    ->Flash cache emptied: 8008 bytes
    User: LocalService
    ->Temp folder emptied: 66016 bytes
    ->Google Chrome cache emptied: 0 bytes
    Windows Temp folder emptied: 1137 bytes
    RecycleBin emptied: 17108 bytes
    Total Files Cleaned = 68.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: Julie
    User: LocalService
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.20.2 log created on 01182011_183122
    Many, Many Thank you's.
    Julie
  8. 2011/01/18
    You're very welcome :)
    Good luck and stay safe :)
