Repair XP on dual boot system with Vista Ultimate
Discussion in 'Windows XP' started by PeteC, 2007/03/05.
  1. 2007/06/11
    McTavish
    McTavish Inactive
    Sorry to hear that Pete, I haven’t had to do a complete reinstall either in more that 5 years but have one coming up soon when I replace this machine and I’m not looking forward to it.
    You asked if multiple partitions can affect performance. I don’t believe physical partitions can have any affect, but if you have them all visible to the operating system and mounted with drive letters then I don’t know. I normally have a lot of partitions but only ever have the booted OS and one data partition from each hard drive showing. The only performance issue I’ve heard of is if you were running your OS on a partition at the very end of a drive. The seek and read times from the inner most tracks on the hard drive platters is a little slower than from the outer tracks.
    If you are going for the dualboot again with Vista then I would advise against letting Vista create any of your partitions. Vista’s New Partitioning Rules
  2. 2007/06/11
    Rockster2U
    Rockster2U Geek Member
    Thanks McTavish.
    PeteC SuperGeek Staff Thread Starter
    Thanks McTavish - I have (had :)) a couple of partitions hidden - I was just curious.
    Interesting read - seems that Vista and XP are not 100% compatible one with another.
    Still waiting on the HD - hoping it will arrive today:)
