reformat a laptop and reinstall xp
Discussion in 'Windows XP' started by stitch, 2003/10/04.
  1. 2003/10/11
    stitch
    stitch Inactive Thread Starter
    I will turn on the firewall which by the way i thought was turned on by default. (now realize it isn't) and i will put on a third party as well just to be sure
    Wish me luck
    If i get on to this site again hopefully it will be with my lap top
    Stitch
  2. 2003/10/11
    Christer
    Christer Geek Member Staff
    stitch,
    glad to hear that You managed to do a clean installation but sorry to hear that You have to do it again.
    However, practise makes perfect ...... ;) ......
    I was wrong in assuming that Your harddisk has only one partition, wasn´t I?
    It requires two partitions to get two copies of XP installed, doesn´t it?
    Christer
    stitch
    Well here I am. On my Lap Top. My CLEAN and Pached Lap Top.
    Downloading more security updates as I type this.
    Thanks to everyone.
    and yes Christer Practice makes perfect (i hope) though too much practice nearly ended with a broken window and a big grrrrr of frustration as laptop went through.
    :) :) :D :) :)
  5. 2003/10/12
    Glad you made it :)
  6. 2003/11/10
    P Karczynski
    P Karczynski Inactive
    2 things to remove dual boot
    1. win xp (home or pro) run msconfig -> boot.ini. If you see two lines that are exactly the same, then then deleting one of them will remove dual boot prompt at startup.
    2. When you do clean reinstall of XP make sure to delete C: partition (or any other partitions). This return the HD to clean state obliterating any previus installations. Then recreate the C: Your new installation will be the only one on the HD.
    If you want to make sure there is nothing left on HD use tool like KillDisk to destroy data
    PS. As always do backups of important files. Download SR1a and other updates (like the one against Blaster) to CD and install them before reconnecting to the net. Blaster can find unprotected computer within minutes of connecting to the internet.
    __________________________________________
