Solved redirect google search and no sound
Discussion in 'Malware and Virus Removal Archive' started by nysoprano, 2010/10/18.
  1. 2010/10/24
    nysoprano
    nysoprano Inactive Thread Starter
    Wow, no redirect and no lost of sound or usb functionality.
    This is great! Thank you.
    The only thing i noticed is now every time i restart my system, Disk check starts and after its done it goes to restart the system, but i get a blue screen crash saying it's nipalk.sys....after a second restart, it boots to windows xp just fine.
    Could it be anything that was done with combofix?
  2. 2010/10/24
    No, but from my search, it looks like nipalk.sys file may have something to do with your sound driver.
    Are you saying, that after 2nd reboot, there is no problem?
    BTW, I'm glad to hear good news :)
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
    nysoprano
    OTL logfile created on: 10/25/2010 1:18:31 AM - Run 1
    OTL by OldTimer - Version 3.2.17.1 Folder = C:\Documents and Settings\Administrator\Desktop
    Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    3.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 72.00% Memory free
    5.00 Gb Paging File | 4.00 Gb Available in Paging File | 83.00% Paging File free
    Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 48.83 Gb Total Space | 2.87 Gb Free Space | 5.88% Space Free | Partition Type: NTFS
    Drive D: | 55.68 Gb Total Space | 1.06 Gb Free Space | 1.90% Space Free | Partition Type: NTFS
    Drive E: | 43.61 Gb Total Space | 0.47 Gb Free Space | 1.08% Space Free | Partition Type: NTFS
    Drive I: | 465.76 Gb Total Space | 3.95 Gb Free Space | 0.85% Space Free | Partition Type: NTFS
    Drive O: | 44.53 Gb Total Space | 6.25 Gb Free Space | 14.04% Space Free | Partition Type: NTFS
    Computer Name: ALX | User Name: Administrator | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2010/10/24 20:07:13 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
    PRC - [2010/09/28 12:20:24 | 000,328,056 | ---- | M] (BitTorrent, Inc.) -- o:\Program Files\uTorrent\uTorrent.exe
    PRC - [2010/09/15 05:29:10 | 002,745,696 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgtray.exe
    PRC - [2010/09/10 01:45:22 | 000,265,400 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgwdsvc.exe
    PRC - [2010/09/10 01:44:22 | 000,845,664 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgcsrvx.exe
    PRC - [2010/09/09 04:46:42 | 000,652,640 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgrsx.exe
    PRC - [2010/09/07 03:50:58 | 001,065,824 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgnsx.exe
    PRC - [2010/09/07 03:50:22 | 001,047,392 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgemcx.exe
    PRC - [2010/09/07 03:50:14 | 000,647,008 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\avgchsvx.exe
    PRC - [2010/09/03 10:35:52 | 000,725,072 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\Identity Protection\Agent\Bin\AVGIDSMonitor.exe
    PRC - [2010/09/03 10:35:50 | 006,104,144 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG10\Identity Protection\Agent\Bin\AVGIDSAgent.exe
    PRC - [2010/07/12 09:32:48 | 000,074,752 | ---- | M] (Nullsoft, Inc.) -- C:\Program Files\Winamp1\winampa.exe
    PRC - [2010/06/04 14:12:28 | 002,436,664 | ---- | M] (Check Point Software Technologies LTD) -- C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    PRC - [2010/06/04 14:10:32 | 001,038,848 | ---- | M] (Check Point Software Technologies LTD) -- C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
    PRC - [2010/06/02 17:50:58 | 001,144,104 | ---- | M] () -- C:\Program Files\DivX\DivX Update\DivXUpdate.exe
    PRC - [2009/11/30 19:51:09 | 000,364,544 | ---- | M] (Western Digital Technologies, Inc.) -- C:\WINDOWS\system32\WDBtnMgr.exe
    PRC - [2009/07/01 23:12:46 | 000,623,960 | ---- | M] (Research In Motion Limited) -- C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe
    PRC - [2009/04/28 01:11:50 | 000,144,792 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\system32\javaw.exe
    PRC - [2009/03/15 03:15:16 | 000,180,224 | ---- | M] (PowerISO Computing, Inc.) -- C:\Program Files\PowerISO\PWRISOVM.EXE
    PRC - [2009/02/27 12:14:26 | 000,640,376 | ---- | M] (Adobe Systems Inc.) -- O:\Program Files\Adobe\Acrobat 9.0\Acrobat\acrotray.exe
    PRC - [2009/02/19 00:33:08 | 000,809,488 | ---- | M] (Logitech, Inc.) -- O:\Program Files\Logitech\SetPoint\SetPoint.exe
    PRC - [2009/02/19 00:28:52 | 000,076,304 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.exe
    PRC - [2008/11/06 12:41:14 | 000,358,920 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\LGDevAgt.exe
    PRC - [2008/11/06 12:39:46 | 002,816,520 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\G-series Software\LGDCore.exe
    PRC - [2008/11/06 12:22:12 | 000,473,608 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\Applets\LCDPop3.exe
    PRC - [2008/11/06 12:21:42 | 001,548,296 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\LCD Manager\LCDMon.exe
    PRC - [2008/11/06 12:21:32 | 000,526,856 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\Applets\LCDMedia.exe
    PRC - [2008/11/06 12:21:14 | 000,676,360 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\GamePanel Software\LCD Manager\Applets\LCDClock.exe
    PRC - [2008/10/02 09:23:16 | 000,546,288 | ---- | M] (Google) -- C:\Program Files\Google\Google Calendar Sync\GoogleCalendarSync.exe
    PRC - [2008/09/29 05:09:20 | 001,483,800 | ---- | M] (Nero AG) -- I:\Programs\Nero\Nero 9\InCD\InCDSrv.exe
    PRC - [2008/09/29 05:09:20 | 000,108,568 | ---- | M] (Nero AG) -- I:\Programs\Nero\Nero 9\InCD\NBHRegInCDSrv.exe
    PRC - [2008/07/03 02:38:24 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2008/05/02 00:15:46 | 000,015,872 | ---- | M] () -- C:\Program Files\Unlocker\UnlockerAssistant.exe
    PRC - [2007/07/23 09:29:14 | 000,609,384 | ---- | M] (National Instruments Corporation) -- I:\Labview\Shared\Tagger\tagsrv.exe
    PRC - [2007/07/19 16:38:16 | 000,048,704 | ---- | M] (National Instruments Corp.) -- C:\WINDOWS\system32\nisvcloc.exe
    PRC - [2007/07/16 17:15:06 | 000,213,040 | ---- | M] (National Instruments Corporation) -- I:\Labview\Shared\Security\nidmsrv.exe
    PRC - [2007/07/16 17:14:56 | 000,050,736 | ---- | M] (National Instruments Corporation) -- C:\WINDOWS\system32\lktsrv.exe
    PRC - [2007/07/16 17:14:46 | 000,040,488 | ---- | M] (National Instruments Corporation) -- C:\WINDOWS\system32\lkads.exe
    PRC - [2007/03/21 11:35:18 | 000,695,136 | ---- | M] (National Instruments, Inc.) -- C:\WINDOWS\system32\lkcitdl.exe
    PRC - [2007/03/08 17:29:26 | 000,012,696 | ---- | M] (National Instruments Corporation) -- I:\Labview\MAX\nimxs.exe
    PRC - [2007/02/16 11:21:20 | 000,012,696 | ---- | M] (National Instruments Corporation) -- C:\WINDOWS\system32\nipalsm.exe
    PRC - [2006/11/13 14:39:52 | 001,289,000 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\wcescomm.exe
    PRC - [2006/11/13 14:39:34 | 000,199,464 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft ActiveSync\rapimgr.exe
    PRC - [2004/06/30 16:59:24 | 000,724,992 | ---- | M] (Integrated Technology Express, Inc.) -- C:\Program Files\ITE\ITE IT8212 ATA RAID Controller\RaidMgr.exe
    PRC - [2004/01/16 13:39:28 | 000,036,864 | ---- | M] () -- C:\Program Files\Silicon Image\SI3114\SiITray.exe
    MOD - [2010/10/24 20:07:13 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
    MOD - [2010/08/23 09:12:02 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
    MOD - [2009/07/12 02:12:06 | 000,632,656 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\msvcr80.dll
    MOD - [2009/02/19 00:31:16 | 000,045,584 | ---- | M] (Logitech, Inc.) -- O:\Program Files\Logitech\SetPoint\lgscroll.dll
    MOD - [2009/02/19 00:26:28 | 000,064,016 | ---- | M] (Logitech, Inc.) -- O:\Program Files\Logitech\SetPoint\GameHook.dll
    MOD - [2008/05/02 00:15:36 | 000,004,608 | ---- | M] () -- C:\Program Files\Unlocker\UnlockerHook.dll
    SRV - File not found [Auto | Stopped] -- C:\WINDOWS\System32\wscsvc.dll -- (wscsvc)
    SRV - File not found [On_Demand | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe -- (WPFFontCache_v0400)
    SRV - [2010/10/23 00:55:08 | 001,357,464 | ---- | M] (Lavasoft) [Auto | Stopped] -- C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe -- (Lavasoft Ad-Aware Service)
    SRV - [2010/09/10 01:45:22 | 000,265,400 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG10\avgwdsvc.exe -- (avgwd)
    SRV - [2010/09/03 10:35:50 | 006,104,144 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG10\Identity Protection\Agent\Bin\AVGIDSAgent.exe -- (AVGIDSAgent)
    SRV - [2010/06/04 14:12:28 | 002,436,664 | ---- | M] (Check Point Software Technologies LTD) [Auto | Running] -- C:\WINDOWS\System32\ZoneLabs\vsmon.exe -- (vsmon)
    SRV - [2010/02/19 13:37:14 | 000,517,096 | ---- | M] (Adobe Systems Incorporated) [On_Demand | Stopped] -- C:\Program Files\Common Files\Adobe\SwitchBoard\SwitchBoard.exe -- (SwitchBoard)
    SRV - [2009/09/17 12:03:03 | 000,072,704 | ---- | M] (Texas Instruments) [On_Demand | Stopped] -- C:\Program Files\Common Files\Texas Instruments Shared\Service\ccstudio31FET.exe -- (Code Composer Studio Platinum v3.1 Evaluation Tools)
    SRV - [2009/09/03 11:53:00 | 000,048,368 | ---- | M] (NOS Microsystems Ltd.) [On_Demand | Stopped] -- C:\Program Files\NOS\bin\getPlus_Helper.dll -- (getPlusHelper) getPlus(R)
    SRV - [2009/04/28 23:24:28 | 000,655,624 | ---- | M] (Acresso Software Inc.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe -- (FLEXnet Licensing Service)
    SRV - [2009/02/19 00:30:20 | 000,121,360 | ---- | M] (Logitech, Inc.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe -- (LBTServ)
    SRV - [2008/09/29 05:09:20 | 001,483,800 | ---- | M] (Nero AG) [Auto | Running] -- I:\Programs\Nero\Nero 9\InCD\InCDSrv.exe -- (InCDSrv)
    SRV - [2008/09/29 05:09:20 | 000,108,568 | ---- | M] (Nero AG) [Auto | Running] -- I:\Programs\Nero\Nero 9\InCD\NBHRegInCDSrv.exe -- (NeroRegInCDSrv)
    SRV - [2008/08/15 05:46:20 | 000,284,016 | ---- | M] (Adobe Systems Incorporated) [On_Demand | Stopped] -- C:\Program Files\Common Files\Adobe\Adobe Version Cue CS4\Server\bin\VersionCueCS4.exe -- (Adobe Version Cue CS4)
    SRV - [2007/07/23 09:29:14 | 000,609,384 | ---- | M] (National Instruments Corporation) [Auto | Running] -- I:\Labview\Shared\Tagger\tagsrv.exe -- (NITaggerService)
    SRV - [2007/07/19 16:38:16 | 000,048,704 | ---- | M] (National Instruments Corp.) [Auto | Running] -- C:\WINDOWS\System32\nisvcloc.exe -- (niSvcLoc)
    SRV - [2007/07/16 17:15:06 | 000,213,040 | ---- | M] (National Instruments Corporation) [Auto | Running] -- I:\Labview\Shared\Security\nidmsrv.exe -- (NIDomainService)
    SRV - [2007/07/16 17:14:56 | 000,050,736 | ---- | M] (National Instruments Corporation) [Auto | Running] -- C:\WINDOWS\system32\lktsrv.exe -- (lkTimeSync)
    SRV - [2007/07/16 17:14:46 | 000,040,488 | ---- | M] (National Instruments Corporation) [Auto | Running] -- C:\WINDOWS\system32\lkads.exe -- (lkClassAds)
    SRV - [2007/05/09 15:34:34 | 000,098,304 | ---- | M] (OPC Foundation) [On_Demand | Stopped] -- C:\WINDOWS\system32\Opcenum.exe -- (OpcEnum)
    SRV - [2007/03/21 11:35:18 | 000,695,136 | ---- | M] (National Instruments, Inc.) [Auto | Running] -- C:\WINDOWS\system32\lkcitdl.exe -- (LkCitadelServer)
    SRV - [2007/03/08 17:29:26 | 000,012,696 | ---- | M] (National Instruments Corporation) [Auto | Running] -- I:\Labview\MAX\nimxs.exe -- (mxssvr)
    SRV - [2007/02/16 11:21:20 | 000,012,696 | ---- | M] (National Instruments Corporation) [Auto | Running] -- C:\WINDOWS\system32\nipalsm.exe -- (nipxirmu)
    SRV - [2007/02/16 11:21:20 | 000,012,696 | ---- | M] (National Instruments Corporation) [Auto | Running] -- C:\WINDOWS\system32\nipalsm.exe -- (nidevldu)
    SRV - [2007/02/16 11:21:20 | 000,012,696 | ---- | M] (National Instruments Corporation) [Auto | Running] -- C:\WINDOWS\system32\nipalsm.exe -- (ni488enumsvc)
    SRV - [2007/01/29 15:19:48 | 001,007,616 | ---- | M] (Macrovision Corporation) [On_Demand | Stopped] -- I:\Labview\Shared\License Manager\Bin\lmgrd.exe -- (NILM License Manager)
    SRV - [2006/01/06 12:07:26 | 000,077,824 | ---- | M] (HP) [On_Demand | Stopped] -- C:\WINDOWS\system32\hphipm11.exe -- (Pml Driver HPH11)
    SRV - [2004/08/16 09:43:54 | 000,536,576 | ---- | M] () [Auto | Stopped] -- O:\Matlab701\webserver\bin\win32\matlabserver.exe -- (matlabserver)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\WINDOWS\System32\DRIVERS\xds560.sys -- (XDS560)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\WINDOWS\System32\Drivers\usbicp.sys -- (uisp)
    DRV - File not found [Kernel | Boot | Stopped] -- C:\WINDOWS\System32\ZoneLabs\srescan.sys -- (srescan)
    DRV - File not found [Kernel | System | Stopped] -- C:\Program Files\SUPERAntiSpyware\SABKUTIL.sys -- (SABKUTIL)
    DRV - File not found [Kernel | On_Demand | Stopped] -- K:\PciCon.sys -- (PciCon)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\catchme.sys -- (catchme)
    DRV - [2010/09/13 16:27:24 | 000,025,680 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\AVGIDSEH.Sys -- (AVGIDSEH)
    DRV - [2010/09/07 03:49:00 | 000,298,448 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avgtdix.sys -- (Avgtdix)
    DRV - [2010/09/07 03:48:56 | 000,034,384 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\avgmfx86.sys -- (Avgmfx86)
    DRV - [2010/09/07 03:48:54 | 000,249,424 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avgldx86.sys -- (Avgldx86)
    DRV - [2010/09/07 03:48:50 | 000,026,064 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\avgrkx86.sys -- (Avgrkx86)
    DRV - [2010/08/28 00:55:05 | 000,015,008 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\Program Files\Lavasoft\Ad-Aware\kernexplorer.sys -- (Lavasoft Kernexplorer)
    DRV - [2010/08/19 21:42:38 | 000,030,288 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AVGIDSFilter.sys -- (AVGIDSFilter)
    DRV - [2010/08/19 21:42:36 | 000,123,472 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AVGIDSDriver.sys -- (AVGIDSDriver)
    DRV - [2010/08/19 21:42:34 | 000,026,192 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AVGIDSShim.sys -- (AVGIDSShim)
    DRV - [2010/06/02 08:21:06 | 000,528,128 | ---- | M] (Check Point Software Technologies LTD) [Kernel | System | Running] -- C:\WINDOWS\system32\vsdatant.sys -- (vsdatant)
    DRV - [2010/05/10 11:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/02/17 11:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2010/02/02 21:52:08 | 004,605,952 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
    DRV - [2009/10/12 18:15:26 | 000,128,016 | ---- | M] (Kaspersky Lab) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\kl1.sys -- (kl1)
    DRV - [2009/03/15 03:25:46 | 000,056,268 | ---- | M] (PowerISO Computing, Inc.) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\scdemu.sys -- (SCDEmu)
    DRV - [2008/12/18 23:43:48 | 000,037,392 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LMouFilt.Sys -- (LMouFilt)
    DRV - [2008/12/18 23:43:40 | 000,035,472 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LHidFilt.Sys -- (LHidFilt)
    DRV - [2008/12/18 23:43:18 | 000,010,384 | ---- | M] (Logitech, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\LBeepKE.sys -- (LBeepKE)
    DRV - [2008/09/29 05:09:20 | 000,129,560 | ---- | M] (Nero AG) [File_System | On_Demand | Running] -- C:\WINDOWS\system32\drivers\InCDFs.sys -- (InCDFs)
    DRV - [2008/09/29 05:09:20 | 000,041,752 | ---- | M] (Nero AG) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\InCDRm.sys -- (InCDRm)
    DRV - [2008/09/29 05:09:20 | 000,040,216 | ---- | M] (Nero AG) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\InCDPass.sys -- (InCDPass)
    DRV - [2008/08/14 07:57:42 | 000,074,720 | ---- | M] (Adobe Systems, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\adfs.sys -- (adfs)
    DRV - [2008/04/14 03:00:00 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
    DRV - [2008/04/14 00:16:22 | 000,048,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\61883.sys -- (61883)
    DRV - [2008/04/14 00:16:22 | 000,038,912 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\avc.sys -- (Avc)
    DRV - [2008/04/14 00:16:10 | 000,051,200 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\msdv.sys -- (MSDV)
    DRV - [2008/04/14 00:15:14 | 000,060,032 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\USBAUDIO.sys -- (usbaudio) USB Audio Driver (WDM)
    DRV - [2007/07/24 22:01:32 | 000,011,352 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nihsdrkl.sys -- (nihsdrk)
    DRV - [2007/07/24 19:38:00 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nixsrkl.sys -- (nixsrk)
    DRV - [2007/07/24 19:37:56 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niwfrkl.sys -- (niwfrk)
    DRV - [2007/07/24 19:37:56 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nissrkl.sys -- (nissrk)
    DRV - [2007/07/24 19:37:54 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niesrkl.sys -- (niesrk)
    DRV - [2007/07/24 19:37:54 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niemrkl.sys -- (niemrk)
    DRV - [2007/07/24 15:29:20 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nipsdkl.sys -- (nipsdk)
    DRV - [2007/07/24 12:19:12 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nimru2kl.sys -- (nimru2k)
    DRV - [2007/07/24 10:00:00 | 000,004,096 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\cvintdrv.sys -- (cvintdrv)
    DRV - [2007/07/19 13:49:10 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ninshsdkl.sys -- (ninshsdk)
    DRV - [2007/07/19 11:56:44 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\NiViPxiKl.sys -- (NiViPxiK)
    DRV - [2007/07/19 11:56:44 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\NiViPciKl.sys -- (NiViPciK)
    DRV - [2007/07/19 11:48:36 | 000,011,384 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\NiViFWKl.sys -- (NiViFWK)
    DRV - [2007/07/19 03:06:50 | 000,011,344 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nidsarkl.sys -- (nidsark)
    DRV - [2007/07/19 02:32:50 | 000,011,376 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niscdkl.sys -- (niscdk)
    DRV - [2007/07/19 02:32:48 | 000,011,376 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nispdkl.sys -- (nispdk)
    DRV - [2007/07/18 22:15:50 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nitiorkl.sys -- (nitiork)
    DRV - [2007/07/18 21:12:02 | 000,011,896 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nipalusbedl.sys -- (nipalusbedl)
    DRV - [2007/07/18 21:11:38 | 000,580,184 | ---- | M] (National Instruments Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\nipalk.sys -- (NIPALK)
    DRV - [2007/07/18 21:11:02 | 000,011,904 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nipalfwedl.sys -- (nipalfwedl)
    DRV - [2007/07/18 10:47:38 | 000,011,392 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nimsdrkl.sys -- (nimsdrk)
    DRV - [2007/07/17 04:18:04 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niswdkl.sys -- (niswdk)
    DRV - [2007/07/17 00:27:32 | 000,011,352 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nisdigkl.sys -- (nisdigk)
    DRV - [2007/07/16 12:52:40 | 000,011,344 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nisftkl.sys -- (nisftk)
    DRV - [2007/07/15 18:31:46 | 000,011,352 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nifslkl.sys -- (nifslk)
    DRV - [2007/07/15 17:50:40 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nistcrkl.sys -- (nistcrk)
    DRV - [2007/07/15 17:44:52 | 000,011,352 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nicdrkl.sys -- (nicdrk)
    DRV - [2007/07/15 16:48:04 | 000,011,312 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nistc2kl.sys -- (nistc2k)
    DRV - [2007/07/13 22:38:56 | 000,011,336 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nidmxfkl.sys -- (nidmxfk)
    DRV - [2007/07/13 20:01:20 | 000,011,368 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nimxpkl.sys -- (nimxpk)
    DRV - [2007/07/13 20:00:50 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nimstskl.sys -- (nimstsk)
    DRV - [2007/07/12 18:18:14 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nidimkl.sys -- (nidimk)
    DRV - [2007/07/12 18:08:54 | 000,011,344 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nimxdfkl.sys -- (nimxdfk)
    DRV - [2007/07/12 17:41:52 | 000,011,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nimdbgkl.sys -- (nimdbgk)
    DRV - [2007/07/12 17:31:08 | 000,011,344 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\niorbkl.sys -- (niorbk)
    DRV - [2007/07/10 20:08:14 | 000,015,448 | ---- | M] (National Instruments Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\System32\drivers\nipbcfk.sys -- (nipbcfk)
    DRV - [2007/06/30 23:07:58 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\niRFSA2kl.sys -- (nirfsa2k)
    DRV - [2007/06/21 00:19:52 | 000,151,683 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nimsrlk.dll -- (nimsrlk)
    DRV - [2007/06/21 00:19:52 | 000,014,464 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nimslk.dll -- (nimslk)
    DRV - [2007/06/16 00:38:32 | 000,011,624 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nisldkl.sys -- (nisldk)
    DRV - [2007/06/01 15:39:30 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nisrcdkl.sys -- (nisrcdk)
    DRV - [2007/05/25 13:26:12 | 000,022,360 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ni1065k.sys -- (ni1065k)
    DRV - [2007/04/16 17:06:28 | 000,050,688 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nidmmk.dll -- (nidmmk)
    DRV - [2007/04/16 17:04:12 | 000,674,304 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\nidaq32k.sys -- (Nidaq32k)
    DRV - [2007/04/16 15:42:28 | 000,111,616 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\niSTCk.dll -- (nistck)
    DRV - [2007/04/16 15:41:52 | 000,030,208 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nimdsk.dll -- (nimdsk)
    DRV - [2007/04/16 15:40:38 | 000,021,504 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nibffrk.dll -- (nibffrk)
    DRV - [2007/04/16 15:40:36 | 000,037,376 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\niarbk.dll -- (niarbk)
    DRV - [2007/02/26 12:40:24 | 000,016,672 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ni488lock.sys -- (ni488lock)
    DRV - [2007/02/24 00:09:16 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nitnr2kl.sys -- (nitnr2k)
    DRV - [2007/02/23 22:32:04 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nidwgkl.sys -- (nidwgk)
    DRV - [2007/02/23 16:20:54 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nigplkl.sys -- (nigplk)
    DRV - [2007/02/22 12:45:16 | 000,020,768 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nipxigpk.sys -- (nipxigpk)
    DRV - [2007/02/22 12:43:52 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ni1045kl.sys -- (ni1045k)
    DRV - [2007/02/22 12:40:18 | 000,025,888 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ni1006k.sys -- (ni1006k)
    DRV - [2007/02/22 12:18:50 | 000,011,552 | ---- | M] (National Instruments Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\nipxirmkl.sys -- (nipxirmk)
    DRV - [2007/01/11 10:18:38 | 000,020,256 | ---- | M] (National Instruments Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvalarmk.sys -- (lvalarmk)
    DRV - [2006/10/19 03:12:16 | 000,012,664 | ---- | M] () [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\AsIO.sys -- (AsIO)
    DRV - [2006/02/25 07:13:06 | 000,016,877 | ---- | M] (Adaptec) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\aspi32.sys -- (Aspi32)
    DRV - [2006/01/06 12:07:27 | 000,050,276 | ---- | M] (Hewlett-Packard) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hphs2k11.sys -- (Dot4Storage HPH11) Storage Class Driver for IEEE-1284.4 (HPH11)
    DRV - [2006/01/06 12:07:27 | 000,018,928 | ---- | M] (HP) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hphius11.sys -- (Dot4Usb HPH11)
    DRV - [2006/01/06 12:07:27 | 000,016,112 | ---- | M] (HP) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hphipr11.sys -- (Dot4Print HPH11)
    DRV - [2006/01/06 12:07:26 | 000,050,896 | ---- | M] (HP) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hphid411.sys -- (Dot4 HPH11)
    DRV - [2004/10/27 07:24:00 | 000,223,104 | ---- | M] (Marvell) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\yk51x86.sys -- (yukonwxp)
    DRV - [2004/10/21 18:56:08 | 001,275,584 | R--- | M] (C-Media Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\cmudax.sys -- (cmudax)
    DRV - [2004/08/12 19:56:20 | 000,005,810 | R--- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ASACPI.sys -- (MTsensor)
    DRV - [2004/06/01 10:19:44 | 000,024,971 | ---- | M] (Integrated Technology Express, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\iteraid.sys -- (iteraid)
    DRV - [2004/05/20 19:47:22 | 000,258,560 | ---- | M] (Marvell Semiconductor, Inc) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mrv8ka51.sys -- (W8100XP)
    DRV - [2004/02/09 15:27:04 | 000,097,857 | ---- | M] (Silicon Image, Inc) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\SI3114R.sys -- (SI3114r)
    DRV - [2003/10/15 10:28:16 | 000,010,240 | ---- | M] (Silicon Image, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys -- (SiFilter)
    DRV - [2002/09/09 19:54:06 | 000,016,269 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\ASNDIS5.sys -- (ASNDIS5)
    DRV - [2001/11/13 09:47:26 | 000,041,324 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\winio.sys -- (WINIO)
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.google.com/
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..browser.search.selectedEngine: "IMDB "
    FF - prefs.js..browser.search.useDBForOrder: true
    FF - prefs.js..browser.startup.homepage: "http://www.google.com/ "
    FF - prefs.js..extensions.enabledItems: piclens@cooliris.com:1.12.0.36605
    FF - prefs.js..extensions.enabledItems: jqs@sun.com:1.0
    FF - prefs.js..extensions.enabledItems: personas@christopher.beard:1.6.1
    FF - prefs.js..extensions.enabledItems: {d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}:1.2.2
    FF - prefs.js..extensions.enabledItems: {3f963a5b-e555-4543-90e2-c3908898db71}:10.0.0.1143
    FF - prefs.js..network.proxy.http: "PROXYTUBE.INFO "
    FF - prefs.js..network.proxy.type: 4
    FF - HKLM\software\mozilla\Firefox\extensions\\{3f963a5b-e555-4543-90e2-c3908898db71}: C:\Program Files\AVG\AVG10\Firefox\ [2010/10/24 12:26:24 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.11\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/10/21 05:27:25 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.11\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/10/21 05:27:24 | 000,000,000 | ---D | M]
    [2009/06/09 01:51:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Extensions
    [2009/06/09 01:51:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Extensions\uploadr@flickr.com
    [2010/10/24 22:51:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions
    [2010/04/02 23:51:00 | 000,000,000 | ---D | M] (Flashblock) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\{3d7eb24f-2740-49df-8937-200b1cc08f8a}
    [2010/10/02 20:40:49 | 000,000,000 | ---D | M] (Adblock Plus) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}
    [2009/09/12 02:27:27 | 000,000,000 | ---D | M] (Adobe DLM (powered by getPlus(R))) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\{E2883E8F-472F-4fb0-9522-AC9BF37916A7}
    [2010/09/12 22:45:25 | 000,000,000 | ---D | M] (New Tab King) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\{FC5BAC7D-D696-4ba6-B913-CF8F000C33DF}
    [2010/09/12 22:45:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\personas@christopher.beard
    [2010/06/03 12:07:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\piclens@cooliris.com
    [2010/06/03 12:07:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\extensions\piclens@cooliris.com-trash
    [2009/04/28 11:28:25 | 000,000,931 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\searchplugins\dictionary.xml
    [2009/04/28 11:28:38 | 000,001,504 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\8hga98aq.default\searchplugins\imdb.xml
    [2010/10/24 22:51:15 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2006/01/23 10:32:04 | 000,020,992 | ---- | M] (National Instruments) -- C:\Program Files\Mozilla Firefox\plugins\NPLV80Win32.dll
    [2007/02/08 10:48:16 | 000,028,448 | ---- | M] (National Instruments) -- C:\Program Files\Mozilla Firefox\plugins\NPLV82Win32.dll
    [2007/07/24 19:03:42 | 000,023,040 | ---- | M] (National Instruments) -- C:\Program Files\Mozilla Firefox\plugins\nplv85win32.dll
    [2010/07/12 09:33:56 | 000,012,800 | ---- | M] (Nullsoft, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npwachk.dll
    [2007/03/09 16:16:44 | 000,189,496 | ---- | M] (Yahoo! Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npyaxmpb.dll
    O1 HOSTS File: ([2010/10/22 21:01:31 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (ContributeBHO Class) - {074C1DC5-9320-4A9A-947D-C042949C6216} - O:\Program Files\Adobe\/Adobe Contribute CS4/contributeieplugin.dll ()
    O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG10\avgssie.dll (AVG Technologies CZ, s.r.o.)
    O2 - BHO: (Adobe PDF Conversion Toolbar Helper) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll (Google Inc.)
    O2 - BHO: (SmartSelect Class) - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKLM\..\Toolbar: (Spb Wallet) - {2913D3DD-9363-4C21-B205-C19A584A0674} - C:\Program Files\Spb Wallet\SpbWalletToolbar.dll ()
    O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKLM\..\Toolbar: (Contribute Toolbar) - {517BDDE4-E3A7-4570-B21E-2B52B6139FC7} - O:\Program Files\Adobe\/Adobe Contribute CS4/contributeieplugin.dll ()
    O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O4 - HKLM..\Run: [Acrobat Assistant 8.0] O:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe (Adobe Systems Inc.)
    O4 - HKLM..\Run: [Adobe Acrobat Speed Launcher] O:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe (Adobe Systems Incorporated)
    O4 - HKLM..\Run: [AdobeCS4ServiceManager] C:\Program Files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe (Adobe Systems Incorporated)
    O4 - HKLM..\Run: [AVG_TRAY] C:\Program Files\AVG\AVG10\avgtray.exe (AVG Technologies CZ, s.r.o.)
    O4 - HKLM..\Run: [BlackBerryAutoUpdate] C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe (Research In Motion Limited)
    O4 - HKLM..\Run: [Launch Ai Booster] C:\Program Files\ASUS\AI Booster\OverClk.exe ()
    O4 - HKLM..\Run: [Launch LCDMon] C:\Program Files\Logitech\GamePanel Software\LCD Manager\LCDMon.exe (Logitech Inc.)
    O4 - HKLM..\Run: [Launch LGDCore] C:\Program Files\Logitech\GamePanel Software\G-series Software\LGDCore.exe (Logitech Inc.)
    O4 - HKLM..\Run: [Launch LgDevAgt] C:\Program Files\Logitech\GamePanel Software\LgDevAgt.exe (Logitech Inc.)
    O4 - HKLM..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE (PowerISO Computing, Inc.)
    O4 - HKLM..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
    O4 - HKLM..\Run: [UnlockerAssistant] C:\Program Files\Unlocker\UnlockerAssistant.exe ()
    O4 - HKLM..\Run: [WD Button Manager] C:\WINDOWS\System32\WDBtnMgr.exe (Western Digital Technologies, Inc.)
    O4 - HKLM..\Run: [WinampAgent] C:\Program Files\Winamp1\winampa.exe (Nullsoft, Inc.)
    O4 - HKLM..\Run: [ZoneAlarm Client] C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe (Check Point Software Technologies LTD)
    O4 - HKCU..\Run: [H/PC Connection Agent] C:\Program Files\Microsoft ActiveSync\wcescomm.exe (Microsoft Corporation)
    O4 - HKCU..\Run: [Steam] i:\programs\steam\steam.exe (Valve Corporation)
    O4 - HKCU..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERANTISPYWARE.EXE (SUPERAntiSpyware.com)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Google Calendar Sync.lnk = C:\Program Files\Google\Google Calendar Sync\GoogleCalendarSync.exe (Google)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Java SATARaid.lnk = C:\Program Files\Silicon Image\SI3114\run.bat ()
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Logitech SetPoint.lnk = O:\Program Files\Logitech\SetPoint\SetPoint.exe (Logitech, Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\RAID Manager.lnk = C:\Program Files\ITE\ITE IT8212 ATA RAID Controller\RaidMgr.exe (Integrated Technology Express, Inc.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDesktopCleanupWizard = 1
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableStatusMessages = 0
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: VerboseStatus = 0
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoResolveTrack = 1
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: LinkResolveIgnoreLinkInfo = 1
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoResolveSearch = 1
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoLowDiskSpaceChecks = 1
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O8 - Extra context menu item: Append Link Target to Existing PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Append to Existing PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert Link Target to Adobe PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O9 - Extra Button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
    O15 - HKLM\..Trusted Domains: cyber-deployment.com ([]http in Trusted sites)
    O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab (Java Plug-in 1.6.0_13)
    O16 - DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab (Java Plug-in 1.6.0_13)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab (Java Plug-in 1.6.0_13)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 209.18.47.61 209.18.47.62 0.0.0.0
    O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG10\avgpp.dll (AVG Technologies CZ, s.r.o.)
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL (SUPERAntiSpyware.com)
    O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
    O20 - Winlogon\Notify\LBTWlgn: DllName - c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll - c:\Program Files\Common Files\Logishrd\Bluetooth\LBTWLgn.dll (Logitech, Inc.)
    O20 - Winlogon\Notify\WgaLogon: DllName - WgaLogon.dll - C:\WINDOWS\System32\WgaLogon.dll ()
    O24 - Desktop Components:1 (The OFFICIAL Dilbert Widget - Clearspring) - http://www.clearspring.com/widgets/4782b1ae641c3eb6?p=478cf2052d7472a1
    O24 - Desktop WallPaper: C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O28 - HKLM ShellExecuteHooks: {88485281-8b4b-4f8d-9ede-82e29a064277} - C:\Program Files\MarkAny\ContentSafer\MACSMANAGER.dll (MarkAny Cooperation.)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2009/04/27 22:34:21 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O34 - HKLM BootExecute: (lsdelete) - C:\WINDOWS\System32\lsdelete.exe ()
    O34 - HKLM BootExecute: (C:\PROGRA~1\AVG\AVG10\avgchsvx.exe /sync) - C:\Program Files\AVG\AVG10\avgchsvx.exe (AVG Technologies CZ, s.r.o.)
    O34 - HKLM BootExecute: (C:\PROGRA~1\AVG\AVG10\avgrsx.exe /sync /restart) - C:\Program Files\AVG\AVG10\avgrsx.exe (AVG Technologies CZ, s.r.o.)
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: msacm.vorbis - C:\WINDOWS\System32\vorbis.acm (HMS http://hp.vector.co.jp/authors/VA012897/)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.DIVX - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    Drivers32: VIDC.I420 - C:\WINDOWS\System32\i420vfw.dll (www.helixcommunity.org)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.yv12 - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (3100098804318208)
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/10/24 20:07:16 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
    [2010/10/24 12:25:37 | 000,000,000 | -HSD | C] -- C:\Config.Msi
    [2010/10/22 23:42:09 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2010/10/21 20:39:24 | 000,000,000 | ---D | C] -- C:\boot
    [2010/10/21 20:19:57 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Administrator\Recent
    [2010/10/21 05:26:34 | 000,000,000 | ---D | C] -- C:\Program Files\MSXML 4.0
    [2010/10/20 17:49:56 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\SoftwareDistribution
    [2010/10/19 21:34:52 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2010/10/19 21:24:52 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2010/10/19 21:24:52 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2010/10/19 21:24:52 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2010/10/19 21:24:52 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2010/10/19 21:24:31 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/10/19 21:24:06 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2010/10/17 09:39:54 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Administrator\Application Data\AVG10
    [2010/10/17 09:37:33 | 000,000,000 | -H-D | C] -- C:\Documents and Settings\All Users\Application Data\Common Files
    [2010/10/17 09:32:26 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\AVG10
    [2010/10/17 09:32:26 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\drivers\AVG
    [2010/10/16 20:14:01 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\MFAData
    [2010/10/14 17:35:49 | 000,000,000 | ---D | C] -- C:\Program Files\Rosetta Stone
    [2010/10/14 17:35:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Rosetta Stone
    [2010/10/13 00:33:46 | 000,000,000 | ---D | C] -- C:\found.003
    [2010/10/03 03:31:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Apple Computer
    [2010/10/03 03:31:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Application Data\Apple Computer
    [2010/09/28 18:55:12 | 000,000,000 | ---D | C] -- C:\found.002
    [3 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    [3 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
  5. 2010/10/25
    nysoprano
    OTL.txt cont...
    ========== Files - Modified Within 30 Days ==========
    [2010/10/25 01:14:01 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/10/25 01:07:12 | 000,001,010 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-1390067357-682003330-1606980848-500UA.job
    [2010/10/25 00:07:01 | 000,000,958 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-1390067357-682003330-1606980848-500Core.job
    [2010/10/24 23:45:46 | 000,142,336 | ---- | M] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2010/10/24 19:25:43 | 000,004,212 | -H-- | M] () -- C:\WINDOWS\System32\zllictbl.dat
    [2010/10/24 19:13:29 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Weekly).job
    [2010/10/24 19:13:17 | 097,582,199 | ---- | M] () -- C:\WINDOWS\System32\drivers\AVG\incavi.avm
    [2010/10/24 19:08:23 | 000,000,069 | ---- | M] () -- C:\WINDOWS\pxisys.ini
    [2010/10/24 19:08:23 | 000,000,030 | ---- | M] () -- C:\WINDOWS\pxiesys.ini
    [2010/10/24 19:08:07 | 000,000,868 | ---- | M] () -- C:\WINDOWS\tasks\Google Software Updater.job
    [2010/10/24 19:07:53 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/10/24 19:07:20 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/10/24 13:21:19 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/10/24 12:27:01 | 000,000,690 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\AVG 2011.lnk
    [2010/10/24 02:00:02 | 000,000,358 | ---- | M] () -- C:\WINDOWS\tasks\AdobeAAMUpdater-1.0-ALX-Administrator.job
    [2010/10/23 00:51:40 | 000,000,157 | ---- | M] () -- C:\WINDOWS\matlab.ini
    [2010/10/22 21:01:31 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2010/10/22 19:28:36 | 000,451,824 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/10/22 19:28:36 | 000,075,538 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/10/21 20:18:53 | 000,000,562 | ---- | M] () -- C:\hpfr5550.xml
    [2010/10/21 19:07:30 | 003,524,368 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2010/10/21 01:30:54 | 000,012,780 | ---- | M] () -- C:\Documents and Settings\Administrator\My Documents\Hello Aaron.docx
    [2010/10/21 00:37:49 | 000,012,457 | ---- | M] () -- C:\Documents and Settings\Administrator\My Documents\My Action Plan.docx
    [2010/10/19 21:35:00 | 000,000,363 | RHS- | M] () -- C:\boot.ini
    [2010/10/18 23:46:30 | 003,043,840 | ---- | M] () -- C:\Documents and Settings\Administrator\My Documents\Presentation1.ppt
    [2010/10/18 23:29:32 | 001,278,183 | ---- | M] () -- C:\Documents and Settings\Administrator\My Documents\Presentation1.pptx
    [2010/10/15 14:29:02 | 000,000,664 | ---- | M] () -- C:\WINDOWS\System32\d3d9caps.dat
    [2010/10/04 11:31:34 | 000,000,256 | ---- | M] () -- C:\WINDOWS\System32\pool.bin
    [2010/10/02 20:34:57 | 000,000,247 | ---- | M] () -- C:\Boot.bak
    [2010/09/30 21:17:47 | 000,001,915 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Earth.lnk
    [2010/10/24 19:13:17 | 097,582,199 | ---- | C] () -- C:\WINDOWS\System32\drivers\AVG\incavi.avm
    [2010/10/21 01:08:48 | 000,012,780 | ---- | C] () -- C:\Documents and Settings\Administrator\My Documents\Hello Aaron.docx
    [2010/10/20 23:58:33 | 000,012,457 | ---- | C] () -- C:\Documents and Settings\Administrator\My Documents\My Action Plan.docx
    [2010/10/20 23:03:31 | 001,291,776 | ---- | C] () -- C:\WINDOWS\System32\dllcache\quartz.dll
    [2010/10/19 21:35:00 | 000,000,247 | ---- | C] () -- C:\Boot.bak
    [2010/10/19 21:34:56 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2010/10/19 21:24:52 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2010/10/19 21:24:52 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2010/10/19 21:24:52 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2010/10/19 21:24:52 | 000,077,312 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2010/10/19 21:24:52 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2010/10/18 23:46:30 | 003,043,840 | ---- | C] () -- C:\Documents and Settings\Administrator\My Documents\Presentation1.ppt
    [2010/10/18 22:03:03 | 001,278,183 | ---- | C] () -- C:\Documents and Settings\Administrator\My Documents\Presentation1.pptx
    [2010/10/17 09:35:45 | 000,000,690 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\AVG 2011.lnk
    [2010/09/30 21:17:47 | 000,001,915 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Google Earth.lnk
    [2010/09/13 20:18:04 | 000,000,069 | ---- | C] () -- C:\WINDOWS\pxisys.ini
    [2010/09/13 20:18:04 | 000,000,030 | ---- | C] () -- C:\WINDOWS\pxiesys.ini
    [2010/09/06 12:12:34 | 000,041,324 | ---- | C] () -- C:\WINDOWS\System32\winio.sys
    [2010/01/12 03:08:36 | 000,038,479 | ---- | C] () -- C:\Documents and Settings\Administrator\Application Data\Microsoft Excel 97-2003.ADR
    [2010/01/12 03:08:25 | 000,000,028 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2009/12/19 00:48:50 | 000,038,489 | ---- | C] () -- C:\Documents and Settings\Administrator\Application Data\Comma Separated Values (Windows).ADR
    [2009/12/03 03:53:12 | 000,000,864 | ---- | C] () -- C:\WINDOWS\_delis32.ini
    [2009/12/03 03:53:10 | 000,001,553 | ---- | C] () -- C:\WINDOWS\_isenv31.ini
    [2009/12/03 03:53:10 | 000,000,521 | ---- | C] () -- C:\WINDOWS\_iserr31.ini
    [2009/11/04 22:09:27 | 000,002,528 | ---- | C] () -- C:\Documents and Settings\Administrator\Application Data\$_hpcst$.hpc
    [2009/10/01 14:53:26 | 000,000,600 | ---- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\PUTTY.RND
    [2009/09/17 12:03:12 | 000,000,000 | ---- | C] () -- C:\WINDOWS\gconf.INI
    [2009/09/07 01:11:30 | 000,000,157 | ---- | C] () -- C:\WINDOWS\matlab.ini
    [2009/08/24 15:33:34 | 000,000,034 | ---- | C] () -- C:\WINDOWS\hpfsched.ini
    [2009/08/24 15:29:29 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\hpodinet.dll
    [2009/07/05 00:31:11 | 000,004,544 | ---- | C] () -- C:\Program Files\trapcode3Dstroke.log
    [2009/07/04 16:13:19 | 000,000,576 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\afl.log
    [2009/07/04 12:50:43 | 000,001,025 | ---- | C] () -- C:\WINDOWS\System32\sysprs7.dll
    [2009/07/04 12:50:43 | 000,001,025 | ---- | C] () -- C:\WINDOWS\System32\clauth2.dll
    [2009/07/04 12:50:43 | 000,001,025 | ---- | C] () -- C:\WINDOWS\System32\clauth1.dll
    [2009/07/04 12:50:43 | 000,000,205 | ---- | C] () -- C:\WINDOWS\System32\lsprst7.dll
    [2009/07/04 12:50:43 | 000,000,073 | ---- | C] () -- C:\WINDOWS\System32\ssprs.dll
    [2009/07/04 12:50:43 | 000,000,021 | ---- | C] () -- C:\WINDOWS\SurCode.INI
    [2009/06/11 01:55:06 | 000,921,600 | ---- | C] () -- C:\WINDOWS\System32\vorbisenc.dll
    [2009/06/11 01:55:06 | 000,188,416 | ---- | C] () -- C:\WINDOWS\System32\vorbis.dll
    [2009/06/11 01:55:01 | 000,237,568 | ---- | C] () -- C:\WINDOWS\System32\OggDS.dll
    [2009/06/11 01:55:01 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\Ogg.dll
    [2009/05/18 19:35:20 | 000,000,069 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2009/05/07 01:37:27 | 000,027,648 | ---- | C] () -- C:\WINDOWS\System32\AVSredirect.dll
    [2009/05/05 02:22:25 | 000,000,165 | ---- | C] () -- C:\WINDOWS\QUICKEN.INI
    [2009/04/28 13:48:52 | 000,001,106 | ---- | C] () -- C:\WINDOWS\WinInit.Ini
    [2009/04/28 10:48:54 | 000,142,336 | ---- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2009/04/27 23:43:04 | 000,024,576 | ---- | C] () -- C:\WINDOWS\System32\AsIO.dll
    [2009/04/27 23:43:04 | 000,012,664 | ---- | C] () -- C:\WINDOWS\System32\drivers\AsIO.sys
    [2009/04/27 23:43:02 | 000,012,096 | ---- | C] () -- C:\WINDOWS\System32\drivers\AsInsHelp64.sys
    [2009/04/27 23:43:02 | 000,010,304 | ---- | C] () -- C:\WINDOWS\System32\drivers\AsInsHelp32.sys
    [2009/04/27 23:41:28 | 000,796,312 | ---- | C] () -- C:\WINDOWS\System32\libeay32_0.9.6l.dll
    [2009/04/27 23:16:29 | 000,028,672 | R--- | C] () -- C:\WINDOWS\System32\cmirmdrv.dll
    [2009/04/27 23:14:10 | 000,005,810 | R--- | C] () -- C:\WINDOWS\System32\drivers\ASACPI.sys
    [2009/04/27 23:14:07 | 000,007,797 | ---- | C] () -- C:\WINDOWS\Ascd_tmp.ini
    [2009/04/27 23:14:05 | 000,005,824 | ---- | C] () -- C:\WINDOWS\System32\drivers\ASUSHWIO.SYS
    [2009/04/27 15:15:50 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2009/04/22 00:19:06 | 000,172,173 | ---- | C] () -- C:\WINDOWS\System32\xlive.dll.cat
    [2009/03/10 22:18:20 | 001,481,728 | ---- | C] () -- C:\WINDOWS\System32\LegitCheckControl.dll
    [2009/03/10 22:18:00 | 000,190,976 | ---- | C] () -- C:\WINDOWS\System32\WgaLogon.dll
    [2008/04/14 03:00:00 | 000,061,440 | ---- | C] () -- C:\WINDOWS\System32\CopyToSendTo.dll
    [2008/02/08 17:03:43 | 000,516,096 | ---- | C] () -- C:\WINDOWS\System32\RegisterDialog.dll
    [2007/07/24 10:00:00 | 000,004,096 | ---- | C] () -- C:\WINDOWS\System32\drivers\cvintdrv.sys
    [2007/07/19 09:25:34 | 000,000,244 | ---- | C] () -- C:\WINDOWS\System32\nirpc.ini
    [2007/07/19 03:13:22 | 000,049,696 | ---- | C] () -- C:\WINDOWS\System32\nispdu.dll
    [2007/07/19 02:32:30 | 000,049,696 | ---- | C] () -- C:\WINDOWS\System32\drivers\nispdk.dll
    [2007/07/19 02:32:24 | 000,031,744 | ---- | C] () -- C:\WINDOWS\System32\niscdrau.dll
    [2007/07/18 21:12:26 | 000,003,520 | ---- | C] () -- C:\WINDOWS\System32\nipalpg.dll
    [2007/07/18 15:17:24 | 000,066,080 | ---- | C] () -- C:\WINDOWS\System32\cfswitch.dll
    [2007/04/16 17:22:06 | 000,005,632 | ---- | C] () -- C:\WINDOWS\System32\nipxiini.dll
    [2007/04/16 16:52:36 | 000,008,704 | ---- | C] () -- C:\WINDOWS\System32\niidaqlv.dll
    [2006/09/12 15:45:14 | 000,012,653 | ---- | C] () -- C:\WINDOWS\System32\GPIB.DLL
    [2003/09/23 05:40:34 | 000,394,240 | ---- | C] () -- C:\WINDOWS\System32\HMTCD.dll
    [1999/11/04 11:00:38 | 000,001,840 | ---- | C] () -- C:\WINDOWS\System32\niidaqs.dll
    [2009/05/01 02:11:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Antares
    [2010/10/17 09:39:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\AVG10
    [2009/05/01 00:18:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Blackberry Desktop
    [2010/08/03 00:15:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
    [2010/07/22 22:00:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\CheckPoint
    [2009/10/18 20:32:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Command & Conquer 3 Kane's Wrath
    [2009/06/11 01:55:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\DataCast
    [2010/02/17 23:37:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Ectaco
    [2009/06/09 01:51:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Flickr
    [2010/05/24 16:03:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\HDRsoft
    [2009/04/30 02:21:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Imagenomic
    [2009/07/06 16:43:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Lucis
    [2009/04/28 01:37:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\MailFrontier
    [2009/07/04 16:14:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Publish Providers
    [2009/04/30 13:27:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Research In Motion
    [2009/06/29 15:08:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\rockbox.org
    [2009/07/04 16:13:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Sony
    [2009/07/04 15:40:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Sony Setup
    [2009/10/11 21:07:57 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\SSH
    [2010/08/13 01:29:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\StageManager.BD092818F67280F4B42B04877600987F0111B594.1
    [2010/10/25 01:22:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\uTorrent
    [2009/11/11 15:24:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Applications
    [2010/10/17 09:38:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AVG10
    [2010/10/16 20:57:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\avg9
    [2010/10/17 09:37:33 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\Common Files
    [2010/08/09 21:18:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\F-Secure
    [2009/04/29 16:04:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\LightScribe
    [2010/10/16 20:53:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\MFAData
    [2009/07/04 12:50:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Minnetonka Audio Software
    [2010/09/13 21:41:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\National Instruments
    [2010/08/11 17:28:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\regid.1986-12.com.adobe
    [2010/10/17 23:31:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Rosetta Stone
    [2009/07/04 16:04:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Sony
    [2009/09/17 12:05:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Texas Instruments
    [2009/09/12 17:27:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
    [2009/05/05 01:48:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
    [2010/07/28 00:38:15 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{BD986C1B-72EC-4B82-B47B-6CAC4E6F494E}
    [2010/10/24 19:13:29 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Weekly).job
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2010/10/24 19:07:11 | 000,048,308 | ---- | M] () -- C:\aaw7boot.log
    [2009/05/03 10:10:35 | 000,001,665 | ---- | M] () -- C:\AdobeRenderServerLog.txt
    [2010/04/13 20:26:37 | 000,034,010 | ---- | M] () -- C:\ASLog.txt
    [2009/04/27 22:34:21 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2010/10/22 22:36:47 | 000,042,412 | ---- | M] () -- C:\ComboFix.txt
    [2009/04/27 22:34:21 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2009/12/31 14:45:41 | 000,003,532 | ---- | M] () -- C:\drmHeader.bin
    [2010/07/28 12:33:24 | 000,036,016 | ---- | M] () -- C:\drwtsn32.log
    [2009/03/31 22:20:06 | 000,217,769 | ---- | M] () -- C:\grldr
    [2010/10/21 20:18:53 | 000,133,038 | ---- | M] () -- C:\hph7550.log
    [2009/04/27 22:34:21 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2010/07/22 21:51:44 | 000,000,109 | ---- | M] () -- C:\mbam-error.txt
    [2009/04/27 22:34:21 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2008/04/14 03:00:00 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2008/04/14 03:00:00 | 000,250,048 | RHS- | M] () -- C:\ntldr
    [2010/10/24 19:07:11 | 2145,386,496 | -HS- | M] () -- C:\pagefile.sys
    [2010/07/20 16:11:51 | 000,002,411 | ---- | M] () -- C:\rollback.ini
    [2010/10/24 19:12:00 | 000,044,854 | ---- | M] () -- C:\sataraidevents.log
    [2009/06/11 01:56:37 | 000,000,040 | ---- | M] () -- C:\SYSTEM.VER
    [2009/09/17 12:04:14 | 000,025,224 | ---- | M] () -- C:\TI_InstallLog.txt
    [2009/06/11 01:56:37 | 000,011,032 | ---- | M] () -- C:\YP-U3.LOG
    < %systemroot%\Fonts\*.com >
    [2006/04/18 15:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 14:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 15:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 14:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2009/04/27 22:33:50 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2006/10/14 16:43:18 | 000,027,648 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2009/09/20 16:43:48 | 000,081,224 | ---- | M] (Microsoft Corporation.) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\lmdippr8.dll
    [2006/10/26 20:56:12 | 000,033,104 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\msonpppr.dll
    [2008/07/06 03:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    [2009/07/05 00:31:13 | 000,004,544 | ---- | M] () -- C:\Program Files\trapcode3Dstroke.log
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2009/04/27 15:13:33 | 000,102,400 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2009/04/27 15:13:33 | 001,089,536 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2009/04/27 15:13:33 | 000,966,656 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2009/04/27 22:34:28 | 000,000,231 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2009/04/27 22:36:50 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\Administrator\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2009/04/27 22:36:50 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    [2009/10/24 22:17:13 | 010,797,270 | ---- | M] () -- C:\Documents and Settings\Administrator\Desktop\mame0134s.exe
    [2010/05/18 13:31:28 | 000,909,176 | ---- | M] (Microsoft Corporation) -- C:\Documents and Settings\Administrator\Desktop\WGAPluginInstall.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    [2010/09/04 22:34:00 | 165,964,728 | ---- | M] (Research In Motion Ltd. ) -- C:\Documents and Settings\Administrator\My Documents\T-Mobile_BlackBerry_Bold_9700_5.0.0.714.exe
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2009/04/27 22:36:50 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Administrator\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2010/10/24 23:08:44 | 000,049,152 | ---- | M] () -- C:\Documents and Settings\Administrator\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2007/07/17 11:38:38 | 000,088,761 | ---- | M] () -- C:\WINDOWS\inf\pxiclean.exe
    [2008/04/14 03:00:00 | 000,208,896 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2008/04/14 03:00:00 | 000,033,792 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2008/04/14 03:00:00 | 000,004,821 | R--- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2007/04/02 23:37:24 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 15:42:10 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2008/04/13 23:00:30 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2008/04/14 05:42:30 | 001,695,232 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2008/04/14 03:00:00 | 000,009,306 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2008/04/14 03:00:00 | 000,018,052 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2008/04/14 03:00:00 | 000,009,306 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2007/04/02 23:37:28 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2007/04/02 23:34:02 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    [2006/02/25 07:13:02 | 000,004,672 | ---- | M] (Adaptec) -- C:\WINDOWS\system\wowpost.exe
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
  6. 2010/10/25
    nysoprano
    nysoprano Inactive Thread Starter
    OTL Extras logfile created on: 10/25/2010 1:18:33 AM - Run 1
    OTL by OldTimer - Version 3.2.17.1 Folder = C:\Documents and Settings\Administrator\Desktop
    Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    3.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 72.00% Memory free
    5.00 Gb Paging File | 4.00 Gb Available in Paging File | 83.00% Paging File free
    Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 48.83 Gb Total Space | 2.87 Gb Free Space | 5.88% Space Free | Partition Type: NTFS
    Drive D: | 55.68 Gb Total Space | 1.06 Gb Free Space | 1.90% Space Free | Partition Type: NTFS
    Drive E: | 43.61 Gb Total Space | 0.47 Gb Free Space | 1.08% Space Free | Partition Type: NTFS
    Drive I: | 465.76 Gb Total Space | 3.95 Gb Free Space | 0.85% Space Free | Partition Type: NTFS
    Drive O: | 44.53 Gb Total Space | 6.25 Gb Free Space | 14.04% Space Free | Partition Type: NTFS
    Computer Name: ALX | User Name: Administrator | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    [HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
    .html [@ = FirefoxHTML] -- C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation)
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l (Microsoft Corporation)
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [AddToPlaylistVLC] -- "o:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
    Directory [Bridge] -- O:\Program Files\Adobe\Photoshop CS5\Adobe Bridge CS5\Bridge.exe "%L" (Adobe Systems, Inc.)
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Directory [PlayWithVLC] -- "o:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
    Directory [Winamp.Bookmark] -- "C:\Program Files\Winamp1\winamp.exe" /BOOKMARK "%1" (Nullsoft, Inc.)
    Directory [Winamp.Enqueue] -- "C:\Program Files\Winamp1\winamp.exe" /ADD "%1" (Nullsoft, Inc.)
    Directory [Winamp.Play] -- "C:\Program Files\Winamp1\winamp.exe" "%1" (Nullsoft, Inc.)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "FirewallDisableNotify" = 0
    "AntiVirusDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "EnableFirewall" = 0
    "DoNotAllowExceptions" = 0
    "DisableNotifications" = 0
    "DisableUnicastResponsesToMulticastBroadcast" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "26675:TCP" = 26675:TCP:169.254.2.0/255.255.255.0:Enabled:ActiveSync Service
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "5353:TCP" = 5353:TCP:*:Enabled:Adobe CSI CS4
    "3703:TCP" = 3703:TCP:*:Enabled:Adobe Version Cue CS4 Server
    "3704:TCP" = 3704:TCP:*:Enabled:Adobe Version Cue CS4 Server
    "51000:TCP" = 51000:TCP:*:Enabled:Adobe Version Cue CS4 Server
    "51001:TCP" = 51001:TCP:*:Enabled:Adobe Version Cue CS4 Server
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "C:\Program Files\Microsoft ActiveSync\rapimgr.exe" = C:\Program Files\Microsoft ActiveSync\rapimgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync RAPI Manager -- (Microsoft Corporation)
    "C:\Program Files\Microsoft ActiveSync\wcescomm.exe" = C:\Program Files\Microsoft ActiveSync\wcescomm.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Connection Manager -- (Microsoft Corporation)
    "C:\Program Files\Microsoft ActiveSync\WCESMgr.exe" = C:\Program Files\Microsoft ActiveSync\WCESMgr.exe:169.254.2.0/255.255.255.0:Enabled:ActiveSync Application -- (Microsoft Corporation)
    "C:\Program Files\Rosetta Stone\Rosetta Stone Version 3\support\bin\win\RosettaStoneLtdServices.exe" = C:\Program Files\Rosetta Stone\Rosetta Stone Version 3\support\bin\win\RosettaStoneLtdServices.exe:*:Enabled:Rosetta Stone Ltd Services -- (Rosetta Stone Ltd. )
    "C:\Program Files\Rosetta Stone\Rosetta Stone Version 3\RosettaStoneVersion3.exe" = C:\Program Files\Rosetta Stone\Rosetta Stone Version 3\RosettaStoneVersion3.exe:*:Enabled:Rosetta Stone Version 3 Application -- (Multidmedia Limited )
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "O:\Program Files\uTorrent\uTorrent.exe" = O:\Program Files\uTorrent\uTorrent.exe:*:Enabled:µTorrent -- (BitTorrent, Inc.)
    "C:\WINDOWS\system32\ZoneLabs\vsmon.exe" = C:\WINDOWS\system32\ZoneLabs\vsmon.exe:*:Enabled:TrueVector Service -- (Check Point Software Technologies LTD)
    "C:\Program Files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe" = C:\Program Files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe:*:Enabled:Adobe CSI CS4 -- (Adobe Systems Incorporated)
    "C:\Program Files\Common Files\Adobe\Adobe Version Cue CS4\Server\bin\VersionCueCS4.exe" = C:\Program Files\Common Files\Adobe\Adobe Version Cue CS4\Server\bin\VersionCueCS4.exe:*:Enabled:Adobe Version Cue CS4 Server -- (Adobe Systems Incorporated)
    "O:\Program Files\iTunes\iTunes.exe" = O:\Program Files\iTunes\iTunes.exe:*:Enabled:iTunes -- (Apple Inc.)
    "C:\Program Files\AVG\AVG10\avgdiagex.exe" = C:\Program Files\AVG\AVG10\avgdiagex.exe:*:Enabled:AVG Diagnostics 2011 -- (AVG Technologies CZ, s.r.o.)
    "C:\Program Files\AVG\AVG10\avgnsx.exe" = C:\Program Files\AVG\AVG10\avgnsx.exe:*:Enabled:Online Shield -- (AVG Technologies CZ, s.r.o.)
    "C:\Program Files\AVG\AVG10\avgemcx.exe" = C:\Program Files\AVG\AVG10\avgemcx.exe:*:Enabled:personal E-mail Scanner -- (AVG Technologies CZ, s.r.o.)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{00ADFB20-AE75-46F4-AD2C-F48B15AC3100}" = Adobe Color NA Recommended Settings CS4
    "{00D0E2A8-E43E-480E-B9D1-E22C9C1D2F72}" = NI-DAQ C and VB6 API
    "{0228e555-4f9c-4e35-a3ec-b109a192b4c2}" = Google Gmail Notifier
    "{0267E0B4-D9EB-5FB5-B4B8-2F6E6722EE2E}" = Catalyst Control Center Graphics Light
    "{0285C8EA-A48F-4EAF-A485-69C46C464271}" = NI LabVIEW 8.5 VI.lib
    "{02A4A1FD-16E1-AC31-D3BD-B23934D52885}" = CCC Help Hungarian
    "{02E89EFC-7B07-4D5A-AA03-9EC0902914EE}" = VC 9.0 Runtime
    "{02EBDBB9-4600-41D3-B566-40CB861511D2}" = World of Warcraft FREE Trial
    "{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}" = Microsoft_VC90_ATL_x86
    "{03B96C48-4001-46C7-AA89-6D8C5C32A5B8}" = NI Variable Manager
    "{048298C9-A4D3-490B-9FF9-AB023A9238F3}" = Steam
    "{05308C4E-7285-4066-BAE3-6B50DA6ED755}" = Adobe Update Manager CS4
    "{054EFA56-2AC1-48F4-A883-0AB89874B972}" = Adobe Extension Manager CS4
    "{055EE59D-217B-43A7-ABFF-507B966405D8}" = ATI Catalyst Control Center
    "{05B49229-22A2-4F88-842A-BBC2EBE1CCF6}" = Microsoft Games for Windows - LIVE Redistributable
    "{061AE98B-178A-4143-A52A-68ED9279644D}" = NI Legacy DAQmxRF
    "{062F5F8E-03CB-0E7E-2F73-FD4C9DD60341}" = ccc-core-preinstall
    "{0699C67B-F5B5-4CA3-A3A9-B976406FA4DA}" = NI Service Locator
    "{0711500B-9912-4D60-9A49-C577B4503D42}" = Nero Recode Help
    "{071ED036-038F-4F6C-8188-B5E02602C8AD}" = NI LabVIEW MAX XML
    "{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
    "{07FF7593-9DEA-40B5-9F87-F557E65BBF60}" = Nero Recode
    "{08D2E121-7F6A-43EB-97FD-629B44903403}" = Microsoft_VC90_CRT_x86
    "{098727E1-775A-4450-B573-3F441F1CA243}" = kuler
    "{0A0FF37C-514F-4965-8D5E-A424B6D01742}" = NI-SCOPE 3.3.2
    "{0C34B801-6AEC-4667-B053-03A67E2D0415}" = Apple Application Support
    "{0C826C5B-B131-423A-A229-C71B3CACCD6A}" = CDDRV_Installer
    "{0D2DBE8A-43D0-7830-7AE7-CA6C99A832E7}" = Adobe Community Help
    "{0D6013AB-A0C7-41DC-973C-E93129C9A29F}" = Adobe Color JA Extra Settings CS4
    "{0D77EC38-3091-40AE-A028-3C7BBEB0FC09}" = NI LabVIEW 8.5 License
    "{0E7DBD52-B097-4F2B-A7C7-F105B0D20FDB}" = LightScribe System Software 1.14.17.1
    "{0F275E8F-AF20-14ED-633C-E002537A7EDB}" = CCC Help English
    "{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}" = Microsoft_VC80_ATL_x86
    "{0F723FC1-7606-4867-866C-CE80AD292DAF}" = Adobe CSI CS4
    "{0F7E321A-0178-9A17-7CD4-3CD0E091376C}" = CCC Help Chinese Standard
    "{11A84FCA-C3C7-4AFD-A797-111DB8569DBC}" = Nero BurningROM
    "{12285AC5-1F0A-4E74-A870-9E4889A23BCF}" = InCD
    "{122E90F8-A899-4225-AA82-94CBA2AEA98D}" = NI LabVIEW 8.5 Examples
    "{13F3917B56CD4C25848BDC69916971BB}" = DivX Converter
    "{146EE173-D92C-41F6-B184-5335AD8CFA58}" = Adobe Setup
    "{14F70205-1940-4000-88C7-BE799A6B2CAD}" = Adobe Soundbooth CS4
    "{151F473B-9F91-4DAC-B77F-FF7BF8F5EE25}" = NI Instrument I/O Assistant
    "{1538B06D-3F62-4622-B9D2-27B894C3496C}" = NI LVBrokerAux 8.5.0
    "{15BF7AAF-846C-4A6D-80E1-5D1FC7FB461B}" = Adobe SGM CS4
    "{15D5755D-3795-45FE-9ED6-BC0DAFA3B333}" = NI-RPC 3.4.0f1
    "{15FEDA5F-141C-4127-8D7E-B962D1742728}" = Adobe Photoshop CS5
    "{1618734A-3957-4ADD-8199-F973763109A8}" = Adobe Anchor Service CS4
    "{16E16F01-2E2D-4248-A42F-76261C147B6C}" = Adobe Drive CS4
    "{16E6D2C1-7C90-4309-8EC4-D2212690AAA4}" = AdobeColorCommonSetRGB
    "{1829DACB-46DE-4624-808B-7802AC528DDF}" = NI EULA Depot
    "{18F77F9D-3384-69C9-D2F3-BC634BC20E8D}" = Catalyst Control Center Core Implementation
    "{1A710265-096B-46CB-8849-53A209D9A8CF}" = NI Certificates Deployment Support
    "{1B040683-C390-4711-ABC7-DA8D85E470E7}" = NeroBurningROM
    "{1B7C06E1-4888-47A6-992A-0990B9683486}" = Adobe Version Cue CS4 Server
    "{1C885277-8F54-4C07-8E2B-05DE800A07E7}" = NI SCXI 1.8.1
    "{1DCA3EAA-6EB5-4563-A970-EA14D75037BA}" = Adobe InDesign CS4
    "{1DDEC125-1677-E028-67B8-F6D322EBBBEA}" = CCC Help Norwegian
    "{1E04CB54-AF4E-4AC3-B4B7-C0A160BE57F1}" = Adobe InDesign CS4 Icon Handler
    "{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    "{20D21946-CC38-4380-94F7-E49A447AD12F}" = NI-MXDF 1.8.0f0
    "{2168245A-B5AD-40D8-A641-48E3E070B5B6}" = Adobe Flash CS4 STI-en
    "{216886AA-525A-4E20-A845-EBB75FB5AD1E}" = NI PXI-5660 Support
    "{221861B8-D133-4377-803D-F005EB2B733C}" = NI LVBrokerAux1071
    "{243F0DFE-9945-4212-93CD-9B49D38477BE}" = NI Measurement Studio Common .NET Language Assemblies for the .NET Framework 2.0
    "{2461AEFD-6597-4B5F-9174-754B9DB56091}" = NI LabVIEW 8.5 Project
    "{24F9EE02-2628-4F33-BF2C-F24BB4797C8E}" = NI Timing Installer 1.10.0
    "{25087132-D60F-4CF0-BAEB-9C86B2E75ACE}" = NI DAQ Assistant 1.7.0
    "{26A24AE4-039D-4CA4-87B4-2F83216013FF}" = Java(TM) 6 Update 13
    "{26BCC645-5CD6-4864-B779-A38C8C59EC3C}" = NI-VISA 4.2
    "{2827559A-9B86-F074-B3B0-CE5C346BB936}" = CCC Help Portuguese
    "{297190A1-4B0D-4CD6-8B9F-3907F15C3FD8}" = Adobe CS4 American English Speech Analysis Models
    "{297BDF30-471F-4E8C-9C05-09C3882300CD}" = NI LabWindows/CVI 8.1.1 Run-Time Engine
    "{297FA251-FF30-4F16-978C-4A65EA804EFF}" = NI LabVIEW Real-Time Error Dialog
    "{299B4500-C41F-4BA3-AB4A-CC9412E16D67}" = NI LabVIEW Run-Time Engine 8.5
    "{29A816A6-86EF-41ED-806C-012728927595}" = NI Remote Provider for MAX
    "{2A2883FA-6ACB-4FC6-B70E-98110EC6404D}" = NI-488.2 Provider for MAX
    "{2BAF2B96-7560-48B4-87D4-10178DDBE217}" = Adobe InDesign CS4 Application Feature Set Files (Roman)
    "{2CD01C28-454F-4863-B875-55C37454B1A8}" = NI Calibration Provider for MAX
    "{2CDFA015-CE4A-47CE-9071-AF221ABB6420}" = NI-FGEN 2.4.6
    "{2F4C21C2-2BDC-4226-961D-A9D297C4F34C}" = NI LabVIEW 8.5 Applibs
    "{30C8AA56-4088-426F-91D1-0EDFD3A25678}" = Adobe Dreamweaver CS4
    "{3101CB58-3482-4D21-AF1A-7057FC935355}" = KhalInstallWrapper
    "{31E40ADA-5756-440D-8D31-4CE1388FEAD3}" = NI AFW Channel Configuration Tool
    "{33547274-426C-4955-B30E-3CC12190AD3C}" = NI-RFSG 1.2.6
    "{34067EE8-710C-4EDA-965F-C977FB2CEDCC}" = NI Spy 2.5.1
    "{34DBA734-9992-47DC-8E92-F343A18071D0}" = NI-488.2 2.5
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{35D94F92-1D3A-43C5-8605-EA268B1A7BD9}" = PDF Settings CS4
    "{36DC540B-3062-4538-B1D1-E367BC9F47FC}" = NI LVBrokerAux71
    "{37DABC6A-3662-4A68-A1D8-A6E4958F64B6}" = NI Measurement Studio 8.1 Enterprise RunTime for VS2005
    "{38A1EB20-8657-43B1-ADD9-3AD5CDB423AB}" = NI-DAQmx support for LabVIEW
    "{38A4AD83-3492-4A4E-A502-48106D88DD3E}" = NI USI 1.5.0
    "{391E73EB-3AB9-4B7A-8951-621544149E8F}" = NI Script Editor 1.3.1
    "{39F6E2B4-CFE8-C30A-66E8-489651F0F34C}" = Adobe Media Player
    "{3A4E8896-C2E7-4084-A4A4-B8FD1894E739}" = Adobe XMP Panels CS4
    "{3C8C9093-2961-4D25-805E-E12FC0DD2FE1}" = NI-SWITCH 3.6
    "{3DA8DF9A-044E-46C4-8531-DEDBB0EE37FF}" = Adobe WinSoft Linguistics Plugin
    "{3DD41352-B7E6-4A66-625C-6F7D43194733}" = CCC Help Korean
    "{3DD972A1-05F0-48C8-9EC4-AB6D4CA0396A}" = NI-DIO Driver 151f0
    "{3F30CC51-0788-487B-AA83-7214A239C0C0}" = Nero Disc Copy Gadget Help
    "{3FC7CBBC4C1E11DCA1A752EA55D89593}" = DivX Version Checker
    "{40F3F086-BE93-9D93-F773-EF13B5DCE8AC}" = CCC Help French
    "{4159DD60-49C1-4323-A1A5-FB060CBA35C5}" = NI Measurement Studio Recipe Processor
    "{4175EFAF-1789-4C85-908D-81C620439CE0}" = NI LabVIEW SignalExpress 2.5 Steps
    "{4262645A-40CC-47C7-8934-903FB7E9DC09}" = NI-PAL 2.1.0f1
    "{4286E640-B5FB-11DF-AC4B-005056C00008}" = Google Earth
    "{428FDF9F-E010-4C4C-A8BB-156960AFCA1C}" = Adobe Fireworks CS4
    "{4338ccbf-2455-46c7-a5a2-f039035a2f0c}" = Nero 9
    "{43509E18-076E-40FE-AF38-CA5ED400A5A9}" = Pixel Bender Toolkit
    "{4410D6BF-5A8C-42DD-92B1-315457AB80CC}" = BlackBerry Device Software v5.0.0 for the BlackBerry 9700 smartphone
    "{44E240EC-2224-4078-A88B-2CEE0D3016EF}" = Adobe After Effects CS4 Presets
    "{45A162D5-CF6F-49C5-9B25-A0F5DF512664}" = NI LabVIEW 8.5 Resource
    "{45EC816C-0771-4C14-AE6D-72D1B578F4C8}" = Adobe After Effects CS4
    "{45FA54F6-8574-49D2-9E2D-0BDDE6237822}" = NI LabVIEW Run-Time Engine 8.2.1
    "{46ADF464-9D63-47E0-B59F-0D9C3A60B4C4}" = NI DataSocket 4.5.0
    "{47101908-553A-4767-94F5-1F2B58012F6D}" = NI LabVIEW 8.5 Help
    "{4714870B-283C-3050-41C3-356E7FD946F3}" = CCC Help Swedish
    "{485B90D4-982E-4C9D-B1F4-4CABCE5596E4}" = NI Measurement Studio DAQmx for Visual Studio 2005
    "{4943EFF5-229F-435D-BEA9-BE3CAEA783A7}" = Adobe Service Manager Extension
    "{4A52555C-032A-4083-BDD9-6A85ABFB39A8}" = Adobe SING CS4
    "{4B719A70-F14A-4f5c-90B5-346B24B7FFF1}" = Windows 7 Upgrade Advisor
    "{4BDCB19D-47E3-4C0C-AFC7-B53501B6A65F}" = NI MAX CVI Support
    "{4CF5749D-2D10-4F5F-8AEC-DA808F15D665}" = NI IVI Class Driver LabVIEW 8.5 Support
    "{4D243BA7-9AC4-46D1-90E5-EEB88974F501}" = Microsoft Games for Windows - LIVE
    "{4D42353B-533F-4306-AD0B-7FEF292ADE04}" = Nero CoverDesigner Help
    "{4D5C1D5C-0337-4498-8699-E940CFDDECAD}" = NI-DAQmx MAX Support 1.9.0
    "{4DD8D80C-6AC9-4E19-B3CE-E2CEB656AF2A}" = NI IVI Engine
    "{4E8C27C2-D727-4C00-A90E-C3F6376EEE70}" = Nero ControlCenter
    "{4EE688DD-B990-49C4-8615-BD1B0E66EA81}" = NI LabVIEW SignalExpress 2.5 Datatypes
    "{514E8482-1374-B9AB-D313-D4238596B2D0}" = CCC Help Danish
    "{52232EF4-CC12-4C21-ABCF-ADB79618302D}" = Adobe Soundbooth CS4 Codecs
    "{52E0D7B4-D1FB-46CC-8321-08625F7D291A}" = BlackBerry Device Software v5.0.0 for the BlackBerry 9700 smartphone
    "{53736430-DBEC-4582-B072-2F1F0A2C4EA6}" = NI LabVIEW Run-Time Engine 7.1.1
    "{53C141BA-4F9E-43FB-B4F9-0C01BB716FA8}" = Adobe Audition 3.0
    "{5423BE44-BD51-4BD9-B345-AE16E8A90D5D}" = Traditional NI-DAQ Documentation
    "{5570C7F0-43D0-4916-8A9E-AEDD52FA86F4}" = Adobe Color EU Extra Settings CS4
    "{55762835-9A95-4A89-BFAE-8E46979C8C4B}" = NI LabVIEW 8.5 Manuals
    "{561968FD-56A1-49FD-9ED0-F55482C7C5BC}" = Adobe Media Encoder CS4 Exporter
    "{5626F094-CC8D-497E-948F-BF639800622F}" = NI-TClk 1.6.1
    "{56BE5CC9-95E6-4128-ABEA-968414CA9C80}" = DolbyFiles
    "{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
    "{56CC729C-4986-4590-AAD5-874B8DC970AE}" = NI Sound and Vibration Frequency Analysis 5.0
    "{56EF3E60-A686-71E3-48C9-4C5A8AE87DCE}" = ccc-core-static
    "{57700DD3-0C10-4CE6-95BA-630284EE2CB1}" = NI License Manager
    "{5959B381-569E-9702-A074-08A5EEF7BE23}" = Catalyst Control Center Graphics Previews Common
    "{59DD18B4-3953-4D52-BB1C-C68275F47CE8}" = NI Portable Configuration
    "{5AE12194-3EAA-40DF-B2BF-FE1D6B78BBF4}" = Nero Vision
    "{5C2AD01A-C3FC-4F0E-899A-30D9B86D9941}" = NI-IVI Provider for MAX
    "{5C2E8A0F-80E2-4C68-8CC0-D8D16E7196BF}" = Nero RescueAgent Help
    "{5D7D4CF4-F54B-482C-81B3-1A75CF402B99}" = NI Measurement Studio VISA Support for VS2005
    "{5DBDA3D6-7D16-419C-8434-219011CF652B}" = NI-VISA Runtime 4.2
    "{5EAD5443-7194-46CC-A055-428E6ABB1BAF}" = Adobe Encore CS4
    "{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
    "{5F2318E0-67DD-4772-9581-1515DF87F5BB}" = NI DHV DCMP Installer 108f1
    "{5F408BD6-1488-48EF-A000-92735DEA9957}" = NI LabVIEW SignalExpress 2.5 Licenses
    "{60DB5894-B5A1-4B62-B0F3-669A22C0EE5D}" = Adobe Dynamiclink Support
    "{61D6891E-E822-4448-9F9A-0AAAAEB6AF6C}" = Adobe Creative Suite 4 Master Collection
    "{6236AC09-E2A3-4B42-BAF0-92E803E1A1BB}" = NI-DMM 2.7.2
    "{62449CD1-560F-1E0D-703C-C52268256625}" = Catalyst Control Center Localization All
    "{627BF3DD-2460-4EA1-904D-997BA5D1AB43}" = NI Common Digital 1.7.1
    "{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}" = Microsoft_VC90_MFC_x86
    "{65F1EE0F-F9D2-45E1-8E14-2EBFF34E90A0}" = NI LVBrokerAux8.0
    "{671A5B67-1A00-424A-A902-49BC020FB3D1}" = NI VC2005MSMs x86
    "{67A9747A-E1F5-4E9A-81CC-12B5D5B81B6E}" = Adobe After Effects CS4 Third Party Content
    "{67F0E67A-8E93-4C2C-B29D-47C48262738A}" = Adobe Device Central CS4
    "{681DD3FE-F5D0-4781-B159-E2422524BF98}" = NI IVI Class Simulation Drivers
    "{68243FF8-83CA-466B-B2B8-9F99DA5479C4}" = AdobeColorCommonSetCMYK
    "{68B7F576-5AF2-46D4-857A-763505551BF5}" = NI-DAQmx OPC Support
    "{692288CF-AE9A-EF45-186A-A10B111690FB}" = CCC Help Turkish
    "{6956856F-B6B3-4BE0-BA0B-8F495BE32033}" = Apple Software Update
    "{6AE2664F-E606-1B84-033F-0A1737B2AE4A}" = CCC Help Russian
    "{6B2DC860-5B05-40E6-93DE-F17AAFE0A526}" = NI Variable Engine
    "{6E605604-E2CE-4331-AA19-5FEF273F3CFD}" = NI LabVIEW Real-Time FIFO for Runtime
    "{6F7D11DC-DE87-45C8-A37E-A35B724FC771}" = NI Help Assistant
    "{6FADAF5C-C9AC-49E5-8B14-7021F91EF0B5}" = NI LabVIEW Run-Time Engine 8.0.1
    "{7112A06F-A109-46CC-810E-070679754F77}" = NI LabVIEW Deployable License 8.5.0
    "{71A4CCC4-599D-49ED-8572-84529FE7626E}" = NI Hierarchical Waveform Storage 1.4.5
    "{73935D21-6136-4FF6-8069-33D767E61429}" = NI-DIM 1.7.0f0
    "{739F4CE3-6443-40AB-ACB3-2CF6FD3702AE}" = AVG 2011
    "{7406DF60-016D-476B-A2C7-55D997592047}" = Adobe OnLocation CS4
    "{740D1337-6A35-457B-9D08-562029E62FD9}" = NI Measurement Studio GPIB Support for VS2005
    "{74BF0A46-DF67-4D86-B038-BF0E51871B66}" = AI Booster
    "{74CB3747-1685-46C1-8F02-FCDA36ADDBA9}" = NI TDMS
    "{74E2CD0C-D4A2-11D3-95A6-0000E86CFDE5}" = SSH Secure Shell
    "{74F4EA0E-6E74-4336-BFB7-8B1376CACBB1}" = NI Instrument IO Assistant for LabVIEW 8.5
    "{755ED4DC-D519-4918-8C9E-BAC9765B9696}" = NI LabVIEW SignalExpress 2.5 Core
    "{768ECA63-EB76-4837-A4CC-58DA5A2FDAE9}" = NI LabVIEW 8.5 WWW
    "{793D1D88-6141-43DE-BE58-59BCE31B4090}" = Adobe Flash CS4 Extension - Flash Lite STI en
    "{797D46F1-214B-484F-BCC2-69E0BC0E3359}" = NI-VISA 4.2 MAX Provider
    "{7A6E650E-EFFA-4EF5-B807-E1F1C96F109E}" = NI-HSDIO 1.5.2
    "{7BD2DE9E-5B66-4C99-A5EE-BC2A23932F26}" = NI-DAQ INF Files
    "{7CC7BDD5-6F10-4724-96A1-EAC7D9F2831C}" = Adobe InDesign CS4 Common Base Files
    "{7D25D409-54EC-4836-AB17-AEC0F192DE70}" = BlackBerry Device Software v4.6.1 for the BlackBerry 8900 smartphone
    "{7DE3B2CC-B0EA-4607-B407-7E5E7C8BEAB0}" = NI LabVIEW Broker
    "{7DEA0C8C-2DB7-4311-87D8-A90921BF8B53}" = NI PXI Platform Services Provider for MAX 2.3.1
    "{7E3668CB-1228-416E-B721-C2FA3247B985}" = NI LabVIEW Real-Time FIFO for Runtime
    "{8186FF34-D389-4B7E-9A2F-C197585BCFBD}" = Adobe Media Encoder CS4 Importer
    "{820D3F45-F6EE-4AAF-81EF-CE21FF21D230}" = Adobe Type Support CS4
    "{82D05F0A-8652-4F8F-BCD3-61DFFF4D660E}" = NI LabVIEW 8.5 Help File
    "{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
    "{83877DB1-8B77-45BC-AB43-2BAC22E093E0}" = Adobe Bridge CS4
    "{842B4B72-9E8F-4962-B3C1-1C422A5C4434}" = Suite Shared Configuration CS4
    "{873B6C52-4EAF-4FA8-A156-907FE78D74F3}" = NI LabWindows/CVI Code Generator
    "{87532CAB-7932-4F84-8937-823337622807}" = Adobe Illustrator CS4
    "{88635CC8-FBE4-4741-A030-7A5E36988CA3}" = NI Dynamic Signal Acquisition Installer 1.10.0
    "{89B920B6-ECF2-43FB-AF9C-8DD1843FC9A3}" = NI MIO Device Drivers 1.13.0
    "{89DE67AD-08B8-4699-A55D-CA5C0AF82BF3}" = ATI AVIVO Codecs
    "{8A702909-3A7D-4ABD-846B-1869A49D850B}" = NI MDF Support
    "{8ACC73AA-6511-7C55-B1A9-8E5D1DEAFAA3}" = The Lord of the Rings FREE Trial
    "{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
    "{8AE51614-30BE-4F0F-B50F-459AB979D219}" = NI LabVIEW 8.5
    "{8C8D1F1E-DC31-44F2-97F5-0D84CE49BB56}" = NI Uninstaller
    "{8E0D1E76-BB9B-4D5C-B46F-21771677E3E4}" = NI DHV GPL 108f1
    "{8E25212F-D6E5-4504-BE07-0F03A603B5E5}" = NI-APAL Error Files 1.2.0f0
    "{8F722FA9-B994-4C9B-B292-FD32D6206EDF}" = ASUS WLAN Card Utilities/Driver
    "{8FA9410D-5894-4191-B8A4-CCEFAE34051C}" = NI OPC Support
    "{90120000-0010-0409-0000-0000000FF1CE}" = Microsoft Software Update for Web Folders (English) 12
    "{90120000-0011-0000-0000-0000000FF1CE}" = Microsoft Office Professional Plus 2007
    "{90120000-0015-0409-0000-0000000FF1CE}" = Microsoft Office Access MUI (English) 2007
    "{90120000-0016-0409-0000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2007
    "{90120000-0018-0409-0000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2007
    "{90120000-0019-0409-0000-0000000FF1CE}" = Microsoft Office Publisher MUI (English) 2007
    "{90120000-001A-0409-0000-0000000FF1CE}" = Microsoft Office Outlook MUI (English) 2007
    "{90120000-001B-0409-0000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2007
    "{90120000-001F-0409-0000-0000000FF1CE}" = Microsoft Office Proof (English) 2007
    "{90120000-001F-040C-0000-0000000FF1CE}" = Microsoft Office Proof (French) 2007
    "{90120000-001F-0C0A-0000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2007
    "{90120000-002C-0409-0000-0000000FF1CE}" = Microsoft Office Proofing (English) 2007
    "{90120000-0044-0409-0000-0000000FF1CE}" = Microsoft Office InfoPath MUI (English) 2007
    "{90120000-006E-0409-0000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2007
    "{90120000-00A1-0000-0000-0000000FF1CE}" = Microsoft Office OneNote 2007
    "{90120000-00A1-0409-0000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2007
    "{90120000-0115-0409-0000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2007
    "{90120000-0117-0409-0000-0000000FF1CE}" = Microsoft Office Access Setup Metadata MUI (English) 2007
    "{911F2BEE-4919-4BA3-A097-B014070FD738}" = NI Assistant Framework LabVIEW Code Generator 8.0
    "{9198EBF1-7EBB-40D4-87C8-7415CF8AE448}" = NI MXS
    "{92228315-BA53-4061-A404-0F05A72E946B}" = NI Logos XT Support
    "{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}" = Microsoft_VC80_CRT_x86
    "{92FA4246-7317-4A35-A74C-EF7D15B28C03}" = NI PXI Platform Services for Windows 2.3.1
    "{931AB7EA-3656-4BB7-864D-022B09E3DD67}" = Adobe Linguistics CS4
    "{93971826-093B-43E7-BA90-7A507D5E2339}" = NI LabVIEW SignalExpress 2.5
    "{943CC0C0-2253-4FE0-9493-DD386F7857FD}" = Nero Express
    "{94D398EB-D2FD-4FD1-B8C4-592635E8A191}" = Adobe CMaps CS4
    "{951B982C-04C6-40AD-88EB-E79DA4E229BF}" = NI-DAQ Provider for MAX
    "{95F1D58C-3A9C-4505-A554-A10322E4766B}" = NI-ORB 1.7.0f0
    "{961D53EA-40DC-4156-AD74-25684CE05F81}" = Nero Installer
    "{97C686BD-6FF3-4E3B-830D-552FE06128AA}" = NI LabVIEW 8.5 Templates
    "{98618CFE-CACD-48C4-85EA-F9197FFEDD0C}" = NI Assistant Framework LabVIEW Code Generator 6.1
    "{99011A6E-5200-11DE-BDB8-7ACD56D89593}" = Rosetta Stone Version 3
    "{99052DB7-9592-4522-A558-5417BBAD48EE}" = Microsoft ActiveSync
    "{995E87FC-1E2B-463C-890A-94D39B761C43}" = NI-TNR Driver
    "{99A125D2-366A-49BE-A144-B6CFB9668A90}" = IVI Shared Component
    "{99BF51E3-3CEE-97A5-D948-E91A0BDE9DEF}" = Catalyst Control Center Graphics Full Existing
    "{9A25302D-30C0-39D9-BD6F-21E6EC160475}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
    "{9A4642B8-AAEE-AEC2-DE72-FA3511CCC427}" = CCC Help Spanish
    "{9A5277BD-4C24-40C7-AEF2-9FA6C6229EC6}" = NI LabVIEW SignalExpress 2.5 LabVIEW Support
    "{9A875B56-A35C-46BA-A3AA-DF8D03EE9F2F}" = Nero ControlCenter
    "{9A990C4C-C1CA-450B-B816-1B56EF14D538}" = NI-DAQmx Switch Core 1.12.0
    "{9B5B156B-9A4B-48FB-AA59-47B221495A7B}" = Logitech GamePanel Software 3.01
    "{9BB86C70-E1EF-7457-46DC-0093B5269458}" = ATI Catalyst Install Manager
    "{9C008728-2EF9-44A7-9149-EEC43B9F87AF}" = NI LabVIEW 8.5 Menus
    "{9F3223E7-98DF-32F3-1AE7-C65AED05D665}" = Catalyst Control Center Graphics Full New
    "{9F3523F8-DAD7-AE52-6DA7-45CDDDF33726}" = Advertising Center
    "{9FBEC876-60EB-4BAC-BF51-E7EF29C1D71A}" = NI Assistant Framework LabVIEW Code Generator 8.2
    "{A040AC77-C1AA-4CC9-8931-9F648AF178F6}" = VC 9.0 Runtime
    "{A2B13DC5-3998-4D83-AD5C-D66679A1205C}" = NI-FieldPoint 6.0
    "{A2B333B8-0797-42EB-A68E-39DCAB6D9DD6}" = NI-DCPower 1.1.2
    "{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{A429C2AE-EBF1-4F81-A221-1C115CAADDAD}" = QuickTime
    "{A4ED947E-EC39-44F4-A576-44FA9E9F4AE3}" = NI Logos LabVIEW 8.5 Support
    "{A6EC82A0-1414-475D-8AFD-469089F3080D}" = Adobe Contribute CS4
    "{A73BEC3C-40A0-480E-87EF-EFCD33629088}" = NeroExpress
    "{A78FE97A-C0C8-49CE-89D0-EDD524A17392}" = PDF Settings CS5
    "{A8399F58-234A-48C6-BA55-30C15738BF3C}" = Nero CoverDesigner
    "{A8F2089B-1F79-4BF6-B385-A2C2B0B9A74D}" = ImagXpress
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}" = Apple Mobile Device Support
    "{AAEAC72F-9B68-464A-BC8B-587946B99B4E}" = NI MAX LabVIEW Support
    "{AB98CF0B-1DBB-4F9A-ABDE-625217C8D34A}" = NI Measurements eXtensions for PAL 1.7.0
    "{ABCE1FFB-A320-44ED-BEE8-68AF1791B35E}" = NI LabVIEW 8.5 MeasAppChm File
    "{ABFAA6D6-7832-4C57-BF92-BA4A7244DE7C}" = NI LabVIEW 8.5 iMath
    "{AC76BA86-1033-F400-7760-000000000004}" = Adobe Acrobat 9 Pro - English, Français, Deutsch
    "{AD00DADD-2F4B-6E10-B9DA-472DAEE0E446}" = CCC Help Finnish
    "{ADF04B79-2737-4D79-A683-79F7DD3E1BB1}" = NI-MRU 2.8.0f1
    "{AEB9948B-4FF2-47C9-990E-47014492A0FE}" = MSXML 6.0 Parser
    "{AEDD4A30-A875-72AF-CF6B-0276377CF285}" = CCC Help German
    "{B05599F2-55E3-47D2-9047-AE171F35A90B}" = NI Logos 4.9
    "{B05DE7B7-0B40-4411-BD4B-222CAE2D8F15}" = Adobe MotionPicture Color Files CS4
    "{B095B0A4-50A5-46D7-9988-D038FEB040C0}" = Adobe Encore CS4 Library
    "{B13A7C41581B411290FBC0395694E2A9}" = DivX Converter
    "{B15381DD-FF97-4FCD-A881-ED4DB0975500}" = Adobe Color Video Profiles AE CS4
    "{B169BC97-B8AA-4ACA-9CF2-9D0FF5BABDF7}" = Adobe Premiere Pro CS4 Functional Content
    "{B21BDC7C-49A1-4155-9425-2F9DED3CD5ED}" = Adobe Setup
    "{B29AD377-CC12-490A-A480-1452337C618D}" = Connect
    "{B2C12C8D-65DC-40BD-B309-5ADB0C6C8D8F}" = Nero WaveEditor
    "{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
    "{B5770FD5-7345-47E0-BEB8-54522270D58F}" = AVG 2011
    "{B59C4A37-E4EA-41E8-922F-EF8E6762412F}" = NI-MDBG 1.7.0f0
    "{B62ADCC0-38E1-74E1-643B-E14F48F9A3B7}" = CCC Help Italian
    "{B6440D7E-E115-4B11-8935-54A329E364E0}" = NI LabVIEW 8.5 gMath
    "{B6CDE57D-9384-4AFD-8731-48955D6FFCBD}" = NI ModInst 1.4.2
    "{B6E680C6-B9C5-42D0-9907-491C2200E4F8}" = NI-MXLC 1.0.0f1
    "{B7050CBDB2504B34BC2A9CA0A692CC29}" = DivX Web Player
    "{B7944A61-5832-40F1-B052-1D0BAB45EF95}" = NI LabVIEW 8.5 Simulation
    "{B923FEDA-7B00-1967-6176-9D022C82AE98}" = CCC Help Greek
    "{B9F4561A-924D-4510-A85A-BB0960C338CB}" = Adobe Asset Services CS4
    "{BAF78226-3200-4DB4-BE33-4D922A799840}" = Windows Presentation Foundation
    "{BB4E33EC-8181-4685-96F7-8554293DEC6A}" = Adobe Output Module
    "{BB5AC3FF-D750-477F-9437-2EF59CDF9103}" = NI-DAQmx Documentation
    "{BB6B7CF3-6231-4F11-8F5B-8A7F10F3F587}" = NI Assistant Framework
    "{BBD7DFEC-5B6C-E396-A06B-09C74F8D46C9}" = CCC Help Chinese Traditional
    "{BCD82AB5-670D-4242-90FA-1F97103C16CD}" = Movie Templates - Starter Kit
    "{BE66348A-E83F-4982-941F-DFF2F742B851}" = Microsoft Office Live Meeting 2007
    "{BE9CEAAA-F069-4331-BF2F-8D350F6504F4}" = Adobe Media Encoder CS4 Additional Exporter
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{C10E500D-6B58-36D9-ECDB-B8C5323BE84A}" = ccc-utility
    "{C19BE821-89B1-4A96-AC7C-873810C0CB5F}" = ContentSAFER for Wizmax
    "{C20CE592-B0F8-4D20-BF31-0151CA6331A6}" = Samsung Media Studio
    "{C2404A93-1951-47D2-9C02-22F3766258D8}" = NI-DAQmx 8.6
    "{C4908416-75CE-456B-9AA5-531DE7FF6415}" = NI LabVIEW 8.5 User.lib
    "{C4FBCEA7-E603-4994-9748-23F6FB9B24FC}" = NI LVBrokerAux 8.2.1
    "{C52E3EC1-048C-45E1-8D53-10B0C6509683}" = Adobe Default Language CS4
    "{C5D0A6E9-9B1B-4463-BFDC-2969EB353434}" = NI-FGEN Driver 146f1
    "{C70C9D30-6DB4-445F-AAAB-E21FB8783569}" = NI IVI Class Drivers
    "{C7E05341-311B-4D55-A22A-073468D5BB05}" = NI FieldPoint MAX Provider
    "{C86E7C99-E4AD-79C7-375B-1AEF9A91EC2B}" = Acrobat.com
    "{C938BE91-3BB5-4B84-9EF6-88F0505D0038}" = Adobe Premiere Pro CS4 Third Party Content
    "{C950420B-4182-49EA-850A-A6A2ABF06C6B}" = Marvell Miniport Driver
    "{C97C567B-27AC-461D-933A-BF4396540980}" = NI-HSD Driver 182f1
    "{C99C89A3-119A-45E6-B26E-DD5643CAA0C5}" = Menu Templates - Starter Kit
    "{C9A019F0-B88F-464B-813A-C60293FEEC58}" = NI Fusion Standard Library Installer 1.5.1
    "{CA3B6B06-5FA5-4C1B-87FC-44C050E1B563}" = NI IVI Compliance Package 3.1
    "{CB30938E-2BCE-4837-9FEB-EB5DAB000235}" = LucisArt 3 ED/SE
    "{CB7CD3CF-C7F5-A6E6-F02E-C186963D74EA}" = CCC Help Czech
    "{CC75AB5C-2110-4A7F-AF52-708680D22FE8}" = Photoshop Camera Raw
    "{CD1826A5-CFCC-4C6E-9F9D-E181876162EA}" = Nero Rescue Agent
    "{CD4F4410-8BF7-A637-36AF-EDC2BE68BD47}" = CCC Help Thai
    "{CD7FE5D3-4678-4C79-B9EA-32D14E9BE583}" = NI IVI Online Help
    "{CD8DC58F-465B-4E04-853C-C43E7950FA86}" = NI LabVIEW Run-Time Engine 7.0
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{CE67C9DC-19D9-1B7D-911F-D5382AFC1EAF}" = CCC Help Japanese
    "{D17DE20F-BF2B-459C-86D4-DCB3F665BF6C}" = NI-DAQ Document Set
    "{D1A19B02-817E-4296-A45B-07853FD74D57}" = Microsoft_VC80_MFC_x86
    "{D2B84C1E-DD92-442A-9229-42C0A426E57F}" = NI LabVIEW SignalExpress 2.5 Tools
    "{D2EB6337-42E5-4D6E-B01F-2FF9E30F4A06}" = NI Web Pipeline
    "{D335CCE7-749E-4958-A48C-6F4E804F56C9}" = NI Instrument IO Assistant for LabVIEW 7.1
    "{D3B1C799-CB73-42DE-BA0F-2344793A095C}" = Catalyst Control Center - Branding
    "{D3FE1E36-DF92-442F-AAE6-FFF4D5913834}" = NI LabVIEW Merge Utility 8.5.0
    "{D499F8DE-3F31-4900-9157-61061613704B}" = Adobe Premiere Pro CS4
    "{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}" = Microsoft_VC80_MFCLOC_x86
    "{D9529709-28B0-4DA1-8749-8924C11AAFF2}" = NI Registration Wizard
    "{DA34FE93-5DC5-48E0-ACC8-A5389E05BB51}" = iTunes
    "{DB2C5648-700D-4AEF-83E1-70C72F0C34FA}" = NI Math Kernel Libraries
    "{DBCC73BA-C69A-4BF5-B4BF-F07501EE7039}" = AnswerWorks 5.0 English Runtime
    "{DC785DB7-D389-48C3-B146-96FE99BF4E2B}" = Vegas Pro 9.0
    "{DD4727FC-A2B4-4639-8365-8D092A3BC3E8}" = NI STC 1.2.0
    "{DEB90B8E-0DCB-48CE-B90E-8842A2BD643E}" = Adobe Media Encoder CS4
    "{DEBA1F73-FA74-4B62-A2CF-A83A02C967B4}" = NI-Tuner 1.6.6
    "{DEC25D81-2317-47F6-8B26-D54A939DA1EE}" = NI LabVIEW C Interface
    "{DED53B0B-B67C-4244-AE6A-D6FD3C28D1EF}" = Ad-Aware
    "{E046A9E5-3991-40F6-91D2-57A28B4ACC60}" = NI Remote PXI Provider for MAX
    "{E06E2236-C964-8694-0D39-9CFE6245B628}" = CCC Help Dutch
    "{E2883E8F-472F-4fb0-9522-AC9BF37916A7}" = Adobe Download Manager
    "{E4A8DD87-A746-4443-BF25-CAF99CED6767}" = Nero Disc Copy Gadget
    "{E5B1DA8B-D2C2-4E4F-82CF-28C169FD4598}" = NI Assistant Framework LabVIEW Code Generator 7.1
    "{E5FF4ACF-89A3-4FF9-AD1F-A3F1DD5CF5F5}" = NI-VISA Server 4.2
    "{E6BBBB50-76E9-4F2F-AA8C-3FDDEB978A87}" = NI Assistant Framework LabVIEW Code Generator 8.5
    "{E86156E5-9859-440D-8876-26CED1349802}" = Nero WaveEditor Help
    "{E896DA69-F993-440E-8515-EB197EFB284F}" = BlackBerry Device Software v4.5.0 for the BlackBerry 8320 smartphone
    "{E8EE9410-8AC4-4F43-A626-DDECA75C79F3}" = Adobe Setup
    "{EB9E7F70-8F2E-412A-A182-FAC85345FDCC}" = NI Assistant Framework LabVIEW Code Generator 7.0
    "{EC610AB8-3B18-4AD9-BCE5-8D014C94CD64}" = NI Example Finder 8.5
    "{ED2A3C11-3EA8-4380-B59C-F2C1832731B0}" = Quicken 2009
    "{ED5D6398-693D-B981-426C-4F3642A66E7E}" = Skins
    "{EDF51FA5-6909-47E1-AAFE-411BA8900AA1}" = NI-DAQmx - LabVIEW shared documentation
    "{EE353798-E875-42E0-B58D-7E6696182EA8}" = Adobe Media Encoder CS4 Dolby
    "{EE59E3BD-6B7D-4BBB-B9CD-20EA7AEF1E10}" = BlackBerry Desktop Software 5.0
    "{F08FF422-BDBC-4816-810A-085880C15FC6}" = NI Software Provider for MAX
    "{F0E64E2E-3A60-40D8-A55D-92F6831875DA}" = Adobe Search for Help
    "{F28D6E4E-EA52-49F5-B5E8-EDA4F380F83A}" = NI DN 2.0 installer
    "{F29B21BD-CAA6-445F-8EF7-A7E2B9D8B14E}" = Logitech SetPoint
    "{F333A33D-125C-32A2-8DCE-5C5D14231E27}" = Visual C++ 2008 x86 Runtime - (v9.0.30729)
    "{F333A33D-125C-32A2-8DCE-5C5D14231E27}.vc_x86runtime_30729_01" = Visual C++ 2008 x86 Runtime - v9.0.30729.01
    "{F4AEDCEC-88CD-4408-80F4-6E7560AE2122}" = NI Variable Engine LabVIEW 8.5 Support
    "{F53F6769-AC46-49E3-ABE3-2C8AFD39D0DD}" = Nero Vision
    "{F566E322-AA55-4AAE-A3E8-43B1786710A5}" = NI Measurement & Automation Explorer 4.3
    "{F5A5B4B5-46A2-4489-958B-C44B89B27C38}" = NI-653x Installer 1.7.0
    "{F5EEC475-6464-4072-95C1-A39DC929CDED}" = NI LabVIEW SignalExpress 2.5 Core LabVIEW Support
    "{F600CCF3-9C88-4A22-B0B4-DDA82E997118}" = Adobe After Effects CS4 Template Projects & Footage
    "{F6E99614-F042-4459-82B7-8B38B2601356}" = Adobe Flash CS4
    "{F7EC885B-6F58-45B2-9E6A-D4A957EB8333}_is1" = yDGpatch v1.2
    "{F8EF2B3F-C345-4F20-8FE4-791A20333CD5}" = Adobe ExtendScript Toolkit CS4
    "{F93C84A6-0DC6-42AF-89FA-776F7C377353}" = Adobe PDF Library Files CS4
    "{F9B5C5D0-CE08-4C05-909F-F00B0AF22D88}" = BlackBerry Device Software v5.0.0 for the BlackBerry 9700 smartphone
    "{FA2C691D-06C2-AD09-CC57-EC1AE4C110FA}" = Catalyst Control Center HydraVision Full
    "{FA4B42B5-F071-4757-B166-F8B219D40136}" = NI-RFSA 2.0.6
    "{FADFF346-8180-4F39-AEC7-FE81087315BC}" = NI LabVIEW 8.5 CINtools
    "{FB2A5FCC-B81B-48C2-A009-7804694D83E9}" = Adobe Encore CS4 Codecs
    "{FC6AAE10-A081-42C7-9CD3-ED1D80C30941}" = ITE IT8212 ATA RAID Controller
    "{FC7E30E4-E72F-45EC-9822-FC41C41E9DFA}" = Traditional NI-DAQ 7.4.4 (Legacy)
    "{FC9144C1-F70B-47CF-BCDC-FEFE4C0BA7D1}" = NI LabVIEW 8.5 Instr.lib
    "{FCDD51BB-CAD0-4BB1-B7DF-CE86D1032794}" = Adobe Fonts All
    "{FDA3B45E-073C-4394-90F5-44887B54CC2C}" = NI LabVIEW 8.5 Device Detection and Deployment Support
    "{FDD1F9E8-A174-4A6C-A185-C5AC913D64C3}" = NI Measurement Studio Max Configuration Support for VS2005
    "{FDD55D26-9325-11D6-BCEF-005004748D87}" = SI3114
    "{FDEABB07-6AC3-41E1-A17C-CA5D9707EF72}" = NI-RPC 3.4.0f1 for Phar Lap ETS
    "{FE6D95B0-EC3D-EBE6-014B-1DDFB262F004}" = CCC Help Polish
    "70DBC326-7505-4913-A0C1-C6BD87C1859D_is1" = freeSSHd 1.2.6
  7. 2010/10/25
    nysoprano
    OTL extra cont...
    "Ad-Aware" = Ad-Aware
    "Adobe AIR" = Adobe AIR
    "Adobe Audition 3.0" = Adobe Audition 3.0
    "Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
    "Adobe Flash Player Plugin" = Adobe Flash Player 10 Plugin
    "Adobe_1f3d5fcc5fe78dc374b6ccbd2d399ba" = Adobe Encore CS4 Library
    "Adobe_360f1c6ef75d7a91261c7e6612f0e46" = Adobe After Effects CS4 Template Projects & Footage
    "Adobe_b2d6abde968e6f277ddbfd501383e02" = Adobe Creative Suite 4 Master Collection
    "Antares Autotune VST_is1" = Antares Autotune VST v5.09
    "ASIO4ALL" = ASIO4ALL
    "ATI Display Driver" = ATI Display Driver
    "AVG" = AVG 2011
    "BlackBerry_{EE59E3BD-6B7D-4BBB-B9CD-20EA7AEF1E10}" = BlackBerry Desktop Software 5.0
    "CamStudio" = CamStudio
    "chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Adobe Community Help
    "C-Media Audio Driver" = C-Media High Definition Audio Driver
    "com.adobe.amp.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Adobe Media Player
    "com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
    "Comical_is1" = Comical 0.8
    "CrackMem_is1" = CrackMem
    "DivX Plus DirectShow Filters" = DivX Plus DirectShow Filters
    "DivX Setup.divx.com" = DivX Setup
    "Flickr Uploadr" = Flickr Uploadr 3.2.1
    "Focus Magic_is1" = Focus Magic 3.02
    "Google Calendar Sync" = Google Calendar Sync
    "Google Updater" = Google Updater
    "GrabIt_is1" = GrabIt 1.7.2 Beta 4 (build 997)
    "hphuni04" = Photosmart 130,230,7150,7345,7350,7550 (Remove only)
    "Hugin_is1" = Hugin 0.7.0 (SVN 3465)
    "ie8" = Windows Internet Explorer 8
    "ImagenomicPortraitureLightroomPlugin" = Imagenomic Portraiture 2.2 Lightroom Plug-in (build 2207)
    "IviSharedComponent" = IVI Shared Components
    "LingvoSoft Learner's Suite 2008 English<->Persian (Farsi) for Windows" = LingvoSoft Learner's Suite 2008 English<->Persian (Farsi) for Windows
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "MatlabR14" = MATLAB Family of Products Release 14
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Mozilla Firefox (3.6.11)" = Mozilla Firefox (3.6.11)
    "NI Uninstaller" = National Instruments Software
    "ONENOTE" = Microsoft Office OneNote 2007
    "PhotomatixPro3_is1" = Photomatix Pro version 3.0
    "PhotomatixPro3x32_is1" = Photomatix Pro version 3.2.8
    "PowerISO" = PowerISO
    "PROPLUS" = Microsoft Office Professional Plus 2007
    "PuTTY_is1" = PuTTY development snapshot 2009-10-01:r8666
    "Spb TV" = Spb TV
    "Spb Wallet" = Spb Wallet
    "Spb Wallet_is1" = Spb Wallet 1.5.1
    "Steam App 220" = Half-Life 2
    "Steam App 320" = Half-Life 2: Deathmatch
    "Steam App 380" = Half-Life 2: Episode One
    "Steam App 400" = Portal
    "Steam App 420" = Half-Life 2: Episode Two
    "Steam App 440" = Team Fortress 2
    "SUPER ©" = SUPER © Version 2010.bld.37 (Jan 2, 2010)
    "Trapcode 3DStroke" = Trapcode 3DStroke
    "Trapcode Particular" = Trapcode Particular
    "Tweak UI 2.10" = Tweak UI
    "Uninstaller_B37CC000_Code Composer Studio Platinum v3.1 Evaluation Tools" = Code Composer Studio Platinum v3.1 Evaluation Tools (Shared Components)
    "Virtual DJ - Atomix Productions" = Virtual DJ - Atomix Productions
    "VLC media player" = VLC media player 1.0.0
    "Wdf01005" = Microsoft Kernel-Mode Driver Framework Feature Pack 1.5
    "Winamp" = Winamp
    "Windows Media Format Runtime" = Windows Media Format 11 runtime
    "WinRAR archiver" = WinRAR archiver
    "WMFDist11" = Windows Media Format 11 runtime
    "World of Warcraft" = World of Warcraft
    "Wudf01000" = Microsoft User-Mode Driver Framework Feature Pack 1.0
    "www.software-for-blackberry.com" = CryptMagicDesktop
    "XpsEPSC" = XML Paper Specification Shared Components Pack 1.0
    "YInstHelper" = Yahoo! Install Manager
    "ZoneAlarm Security Suite" = ZoneAlarm Security Suite
    ========== HKEY_CURRENT_USER Uninstall List ==========
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "Google Chrome" = Google Chrome
    "uTorrent" = µTorrent
    "Winamp Detect" = Winamp Detector Plug-in
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 10/22/2010 9:52:11 PM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    Error - 10/22/2010 10:27:34 PM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    Error - 10/22/2010 11:25:16 PM | Computer Name = ALX | Source = crypt32 | ID = 131080
    Description = Failed auto update retrieval of third-party root list sequence number
    from: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootseq.txt>
    with error: This operation returned because the timeout period expired.
    Error - 10/22/2010 11:26:04 PM | Computer Name = ALX | Source = crypt32 | ID = 131080
    with error: The server name or address could not be resolved
    Error - 10/23/2010 1:31:25 AM | Computer Name = ALX | Source = crypt32 | ID = 131080
    Error - 10/23/2010 1:32:11 AM | Computer Name = ALX | Source = crypt32 | ID = 131080
    Error - 10/23/2010 2:00:30 AM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    Error - 10/24/2010 7:35:00 AM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    Error - 10/24/2010 3:20:53 PM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    Error - 10/24/2010 10:11:12 PM | Computer Name = ALX | Source = matlabserver | ID = 0
    Description =
    [ OSession Events ]
    Error - 1/18/2010 5:58:30 AM | Computer Name = ALX | Source = Microsoft Office 12 Sessions | ID = 7001
    Description = ID: 6, Application Name: Microsoft Office Outlook, Application Version:
    12.0.4518.1014, Microsoft Office Version: 12.0.4518.1014. This session lasted 1038
    seconds with 600 seconds of active time. This session ended with a crash.
    [ System Events ]
    Error - 9/18/2010 1:14:03 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Description = The server {8BC3F05E-D86B-11D0-A075-00C04FB68820} did not register
    with DCOM within the required timeout.
    Error - 9/18/2010 1:28:13 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/18/2010 3:49:29 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/18/2010 4:32:43 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/18/2010 2:33:14 PM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/18/2010 11:00:00 PM | Computer Name = ALX | Source = Schedule | ID = 7901
    Description = The At1.job command failed to start due to the following error: %%2147942402
    Error - 9/19/2010 1:37:49 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/19/2010 1:49:34 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/19/2010 2:15:19 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    Error - 9/19/2010 3:55:43 AM | Computer Name = ALX | Source = DCOM | ID = 10010
    < End of report >
  8. 2010/10/25
    You're running very low on C drive free space:
    Update your Java version here: http://www.java.com/en/download/installed.jsp
    Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    OTL log looks perfectly fine.
    Last scans...
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  9. 2010/10/29
    nysoprano
    Updated Java and removed all old version.
    Results of screen317's Security Check version 0.99.5
    Windows XP Service Pack 3
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Security Center service is not running! This report may not be accurate!
    Windows Firewall Disabled!
    AVG 2011
    WMI entry may not exist for antivirus; attempting automatic update.
    Anti-malware/Other Utilities Check:
    Ad-Aware
    Java(TM) 6 Update 22
    Out of date Java installed!
    Adobe Flash Player 10.1.85.3
    Mozilla Firefox (3.6.12) Firefox Out of Date!
    Process Check:
    objlist.exe by Laurent
    Ad-Aware AAWService.exe
    Ad-Aware AAWTray.exe
    AVG avgwdsvc.exe
    AVG avgtray.exe
    AVG avgrsx.exe
    AVG avgnsx.exe
    AVG avgemc.exe
    Zone Labs ZoneAlarm zlclient.exe
    DNS Vulnerability Check:
    Unknown. This method cannot test your vulnerability to DNS cache poisoning. (Wireless connection?)
    ``````````End of Log````````````
  10. 2010/10/29
    That looks good.
    Go on...
  11. 2010/11/01
    nysoprano
    Sorry it took long, had to restart several times since it was taking forever to complete.
    C:\Qoobox\Quarantine\C\WINDOWS\system32\Drivers\InCDPass.sys.vir Win32/Olmarik.ZC trojan
    I:\New Downloads\Programs\Sony Vegas Pro 8.0b Build 217-AVCHD-MPG-AC3 FIXED\Keygen.exe a variant of Win32/Keygen.AR application
  12. 2010/11/01
    You must really watch out what you're downloading and from where:
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
  13. 2010/11/01
    nysoprano
    All processes killed
    ========== OTL ==========
    ========== FILES ==========
    I:\New Downloads\Programs\Sony Vegas Pro 8.0b Build 217-AVCHD-MPG-AC3 FIXED\Keygen.exe moved successfully.
    [EMPTYTEMP]
    User: Administrator
    ->Temp folder emptied: 3323148 bytes
    ->Temporary Internet Files folder emptied: 2890552 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 94181219 bytes
    ->Google Chrome cache emptied: 0 bytes
    ->Flash cache emptied: 3699 bytes
    User: All Users
    User: Default User
    User: Ellie
    ->FireFox cache emptied: 0 bytes
    User: LocalService
    User: NetworkService
    Windows Temp folder emptied: 89659 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 96.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: Ellie
    User: LocalService
    OTL by OldTimer - Version 3.2.17.1 log created on 11012010_205048
    C:\Documents and Settings\Administrator\Local Settings\Temp\~DF54B.tmp moved successfully.
    File\Folder C:\WINDOWS\temp\hsperfdata_SYSTEM\2856 not found!
    File\Folder C:\WINDOWS\temp\ZLT06cd5.TMP not found!
  14. 2010/11/01
    I'll be waiting for your final word :)
  15. 2010/11/01
    nysoprano
    [EMPTYTEMP]
    User: Administrator
    ->Temp folder emptied: 455424 bytes
    ->Temporary Internet Files folder emptied: 206701 bytes
    ->FireFox cache emptied: 5649709 bytes
    User: All Users
    User: Default User
    User: Ellie
    User: LocalService
    Windows Temp folder emptied: 21948 bytes
    Total Files Cleaned = 6.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: Ellie
    User: LocalService
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.17.1 log created on 11012010_211018
    C:\Documents and Settings\Administrator\Local Settings\Temp\~DFD8F7.tmp moved successfully.
    File\Folder C:\WINDOWS\temp\hsperfdata_SYSTEM\2820 not found!
    File\Folder C:\WINDOWS\temp\ZLT06130.TMP not found!
  16. 2010/11/01
    nysoprano
    Thank you very much for all your help!!!
    I thought i had to do a system wipe and kept putting it off until i found this website. Thank you again!
  17. 2010/11/01
    You're very welcome :)
    Good luck and stay safe :)
