Solved redirect/ fake virus scanner problem..
Discussion in 'Malware and Virus Removal Archive' started by gideon01, 2010/03/26.
  1. 2010/03/28
    gideon01
    gideon01 Inactive Thread Starter
    yup redirected me to a fake virus scanner page this time.
  2. 2010/03/28
    Please download OTM
    • Save it to your desktop.
    • Please double-click OTM to run it. (Note: If you are running on Vista, right-click on the file and choose Run As Administrator).
    • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose Copy):
    :Processes
    :Services
    :Reg
    :Files
    C:\WINDOWS\system32\drivers\iaStor.sys|C:\WINDOWS\system32\ReinstallBackups\0014\DriverFiles\iaStor.sys /replace
    :Commands
    [purity]
    [emptytemp]
    [Reboot]
    • Return to OTM, right click in the "Paste Instructions for Items to be Moved" window (under the yellow bar) and choose Paste.
    • Click the red Moveit! button.
    • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
    • Close OTM and reboot your PC.
    Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes. In this case, after the reboot, open Notepad (Start->All Programs->Accessories->Notepad), click File->Open, in the File Name box enter *.log and press the Enter key, navigate to the C:\_OTMoveIt\MovedFiles folder, and open the newest .log file present, and copy/paste the contents of that document back here in your next post.
    gideon01
    ->Temporary Internet Files folder emptied: 8095821 bytes
    ->Java cache emptied: 14459 bytes
    ->FireFox cache emptied: 43498560 bytes
    ->Flash cache emptied: 1257 bytes
    User: LocalService
    ->Temp folder emptied: 1062860 bytes
    User: NetworkService
    ->Temp folder emptied: 995304 bytes
    ->Java cache emptied: 0 bytes
    Windows Temp folder emptied: 1024072 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 716 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 53.00 mb
    OTM by OldTimer - Version 3.1.10.1 log created on 03282010_184327
    Files moved on Reboot...
    C:\Documents and Settings\home\Local Settings\Temp\~DF43A.tmp moved successfully.
    C:\Documents and Settings\home\Local Settings\Application Data\Mozilla\Firefox\Profiles\lkk0n11m.default\Cache\_CACHE_001_ moved successfully.
    C:\Documents and Settings\home\Local Settings\Application Data\Mozilla\Firefox\Profiles\lkk0n11m.default\Cache\_CACHE_002_ moved successfully.
    C:\Documents and Settings\home\Local Settings\Application Data\Mozilla\Firefox\Profiles\lkk0n11m.default\Cache\_CACHE_003_ moved successfully.
    C:\Documents and Settings\home\Local Settings\Application Data\Mozilla\Firefox\Profiles\lkk0n11m.default\Cache\_CACHE_MAP_ moved successfully.
    C:\Documents and Settings\home\Local Settings\Application Data\Mozilla\Firefox\Profiles\lkk0n11m.default\urlclassifier3.sqlite moved successfully.
    File C:\WINDOWS\temp\ZLT0624f.TMP not found!
  5. 2010/03/28
    Nothing happened.
    Make sure, you copy EVERYTHING inside code box.
    Try again.
  6. 2010/03/28
    gideon01
    All processes killed
    ========== PROCESSES ==========
    ========== FILES ==========
    File C:\WINDOWS\system32\drivers\iaStor.sys successfully replaced with C:\WINDOWS\system32\ReinstallBackups\0014\DriverFiles\iaStor.sys
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: home
    ->Temp folder emptied: 1145154 bytes
    ->FireFox cache emptied: 20869464 bytes
    ->Flash cache emptied: 568 bytes
    User: LocalService
    ->Temp folder emptied: 2051048 bytes
    ->Temp folder emptied: 994744 bytes
    Windows Temp folder emptied: 1013992 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 412 bytes
    RecycleBin emptied: 34286 bytes
    Total Files Cleaned = 25.00 mb
    OTM by OldTimer - Version 3.1.10.1 log created on 03282010_190101
    C:\Documents and Settings\home\Local Settings\Temp\~DFD29A.tmp moved successfully.
    File C:\WINDOWS\temp\ZLT067cb.TMP not found!
  7. 2010/03/28
    It worked now :)
    How is redirection?
  8. 2010/03/28
    gideon01
    still redirecting ... this ***** LoL its only doing it with google so far =(
    figures its screwing with something i use alot.
    if i click the link that google has on its searches i get redirected, but if i copy and paste the link from the google search directly to my address bar it goes to the right place.
  9. 2010/03/28
    Download Dr.Web CureIt to the desktop:
    ftp://ftp.drweb.com/pub/drweb/cureit/drweb-cureit.exe
    • Doubleclick the drweb-cureit.exe file and click Scan to run express scan. Click OK in pop-up window to allow scan.
    • This will scan the files currently running in memory and when something is found, click the Yes button when it asks you if you want to cure it. This is only a short scan.
    • Once the short scan has finished, select Complete scan.
    • Click the green arrow [​IMG] at the right, and the scan will start.
    • Click Yes to all if it asks if you want to cure/move the file.
    • When the scan has finished, in the menu, click File and choose Save report list
    • Save the report to your desktop. The report will be called DrWeb.csv
    • Close Dr.Web Cureit.
    • [color=5]Important![/color] Reboot your computer because it could be possible that files in use will be moved/deleted during reboot.
    • Copy and paste that log in the next reply. You can use Notepad to open the DrWeb.cvs report.
    NOTE. During the scan, pop-up window will open asking for full version purchase. Simply close the window by clicking on X in upper right corner.
    Post fresh HijackThis log as well.
  10. 2010/03/28
    gideon01
    no viruses found, save report list is greyed out so cant get a report
  11. 2010/03/28
    I'm running out of tools here....
    I can't see anything wrong with your computer.
    Give me fresh HJT log, please.
  12. 2010/03/28
    gideon01
    i did a full system scan with the dr .webcureit ,it found 2 trojans.
    here's the log
    RegUBP2b-home.reg;C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy\Snapshots2;Trojan.StartPage.1505;Deleted.;
    A0007805.reg;C:\System Volume Information\_restore{68414456-E059-4322-8DE2-002DF6625E69}\RP8;Trojan.StartPage.1505;Deleted.;
  13. 2010/03/28
    gideon01
    Scan saved at 11:15:18 PM, on 3/28/2010
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\WINDOWS\system32\nvsvc32.exe
    C:\Program Files\AVG\AVG9\avgchsvx.exe
    C:\Program Files\AVG\AVG9\avgrsx.exe
    C:\Program Files\AVG\AVG9\avgcsrvx.exe
    C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe
    C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
    C:\Program Files\CheckPoint\ZAForceField\ForceField.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\AVG\AVG9\avgwdsvc.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\Program Files\Intel\Intel Application Accelerator\iaantmon.exe
    C:\WINDOWS\system32\SearchIndexer.exe
    C:\Program Files\AVG\AVG9\avgemc.exe
    C:\Program Files\AVG\AVG9\avgnsx.exe
    C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
    C:\Program Files\Intel\Intel Application Accelerator\iaanotif.exe
    C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
    C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe
    C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    C:\Program Files\Windows Desktop Search\WindowsSearch.exe
    C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.whtm.com
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://windowsupdate.microsoft.com/
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    O2 - BHO: (no name) - {25526b16-f633-481c-8891-b9f8903112a4} - (no file)
    O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: ZoneAlarm Toolbar Registrar - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: ZoneAlarm Toolbar - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll
    O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
    O4 - HKLM\..\Run: [IAAnotif] C:\Program Files\Intel\Intel Application Accelerator\iaanotif.exe
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [ZoneAlarm Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe "
    O4 - HKLM\..\Run: [ISW] "C:\Program Files\CheckPoint\ZAForceField\ForceField.exe" /icon= "hidden "
    O4 - HKLM\..\Run: [WinPatrol] C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe -expressboot
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O17 - HKLM\System\CCS\Services\Tcpip\..\{7076810B-EFD8-4D07-9781-31A5C01D8A1A}: NameServer = 217.23.14.75,4.2.2.1,192.168.2.1
    O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll
    O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: AVG Free E-mail Scanner (avg9emc) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG9\avgemc.exe
    O23 - Service: AVG Free WatchDog (avg9wd) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG9\avgwdsvc.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: IAA Event Monitor (IAANTMon) - Intel Corporation - C:\Program Files\Intel\Intel Application Accelerator\iaantmon.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: ZoneAlarm Toolbar IswSvc (IswSvc) - Check Point Software Technologies - C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
    O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: TrueVector Internet Monitor (vsmon) - Check Point Software Technologies LTD - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    End of file - 6788 bytes
  14. 2010/03/28
    Disable TeaTimer, as it'll interfere with the cleaning process:
    Right click Spybot's TeaTimer System Tray Icon.
    Click Exit Spybot-S&D Resident.
    TeaTimer closes.
    NOTE. If on re-boot, Spybot inquires about registry change(s), allow it.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    4. Click on Fix checked button.
    5. Restart computer.
    6. Post new HijackThis log.
  15. 2010/03/29
    gideon01
    Scan saved at 6:15:27 AM, on 3/29/2010
    End of file - 6619 bytes
  16. 2010/03/29
    gideon01
    the redirect seems to be ok on internet explorer ,and with firefox . yaaay
    since i put adaware,zonealarm ,winpatrol on my pc dont know if its my internet or firefox but my tabs dont always load. is there a conflict with one of those and firefox ?
  17. 2010/03/29
    Very good :)
    I think, you had issues with DNS being hijacked, which, most likely, was fixed by deleting O17 entry.
    Just to make sure...
    Go Start>Run (Start search in Vista), type in:
    cmd
    Click OK (in Vista, while holding CTRL, and SHIFT, press Enter).
    In Command Prompt window, type in following commands, and hit Enter after each one:
    ipconfig /flushdns
    ipconfig /registerdns
    ipconfig /release
    ipconfig /renew
    Turn off computer. Disconnect router, and modem from power source for 1 minute. At the same time disconnect ethernet cable as well.
    Reconnect everything.
    Restart computer.
    As for web pages not loading, it seems to be a conflict between AVG and ZoneAlarm, which I observed lately.
    Uninstall AVG, using AVG Remover: http://www.avg.com/us-en/download-tools and see, if it helps.
  18. 2010/03/29
    gideon01
    removing avg seemed to have fixed it, both browsers are working great now.
    is there a free antivirus that dont have any conflicts with zone alarm?
  19. 2010/03/29
    gideon01
    yes
    yes its solved both browsers still working great. thanks a ton for everything :)
  21. 2010/03/30
    Wonderful :)
    Last step....
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
