Resolved recycle bin on drive C: is corrupted
Discussion in 'Windows XP' started by 810311, 2011/01/12.
  1. 2011/02/06
    810311
    810311 Inactive Thread Starter
    BlitzBlank 1.0.0.32
    File/Registry Modification Engine native application
    MoveFileOnReboot: sourceFile = "\??\c:\recycler ", destinationFile = "(null) ", replaceWithDummy = 0
  2. 2011/02/06
    How is recycle bin doing now?
    810311
    There's no "recycle bin corrupted" message but when I delete files they got deleted without going into recycle bin even thou "Do not move files to the Recycle Bin" is unchecked.
  5. 2011/02/06
    I assume, you have Recycle Bin back on your desktop now?
    Let's try Recycle Bin fix now.
    Attached is zipped file.
    Unzip it and double click on fix.reg file.
    Allow registry merge.
    Restart computer.
    • fix.zip
      File size:
      751 bytes
    810311
    Yes, Recycle Bin is on my desktop.
    I just did fix.reg and after restart I got "Recycle Bin on /C: corrupted" again.
    P.S. When I used BlitzBlank before, the message disappeared thou....
  7. 2011/02/07
    What is Recycle Bin size set to?
  8. 2011/02/07
    810311
    size 50
  9. 2011/02/07
    Try to create new user with admin rights and see how things work there.
  10. 2011/02/07
    810311
    how do I do this ? I am on Windows XP - never did that before.
    thanks broni.
  11. 2011/02/07
    810311 likes this.
