Solved Recovered from virus, Now IE8 will not work
Discussion in 'Malware and Virus Removal Archive' started by SVEN, 2010/07/14.
  1. 2010/07/16
    SVEN
    SVEN Well-Known Member Thread Starter
    Hi Bromi
    Here is the log:
    GMER 1.0.15.15281 - http://www.gmer.net
    Rootkit scan 2010-07-16 09:40:49
    Windows 5.1.2600 Service Pack 3
    Running: vn0q8w74.exe; Driver: C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\kxlyiaoc.sys
    ---- System - GMER 1.0.15 ----
    SSDT F8D12A76 ZwCreateKey
    SSDT F8D12A6C ZwCreateThread
    SSDT F8D12A7B ZwDeleteKey
    SSDT F8D12A85 ZwDeleteValueKey
    SSDT F8D12A8A ZwLoadKey
    SSDT F8D12A58 ZwOpenProcess
    SSDT F8D12A5D ZwOpenThread
    SSDT F8D12A94 ZwReplaceKey
    SSDT F8D12A8F ZwRestoreKey
    SSDT F8D12A80 ZwSetValueKey
    SSDT \??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS (SASKUTIL.SYS/SUPERAdBlocker.com and SUPERAntiSpyware.com) ZwTerminateProcess [0xEFC5A950]
    ---- Kernel code sections - GMER 1.0.15 ----
    .text ntoskrnl.exe!_abnormal_termination + 428 804E2A94 1 Byte [80]
    init C:\windows\System32\DRIVERS\mohfilt.sys entry point in "init" section [0xF88FB760]
    ---- EOF - GMER 1.0.15 ----
    Also, in my E-Mail it will not show any pictures any more.
    I don't know where to change that, or is that related to my problem with IE8
    Sven
  2. 2010/07/16
    What email program do you use?
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    SVEN
    i use outlook express.
    i can not download to my desktop, so i will download to a differend computer and tranfer. is that o.k.?
  5. 2010/07/16
    SVEN
    here it is
    ComboFix 10-07-15.05 - Sven Albrecht 07/16/2010 10:28:46.2.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.230 [GMT -7:00]
    Running from: c:\documents and settings\Sven Albrecht\Desktop\ComboFix.exe
    AV: AntiVir Desktop *On-access scanning disabled* (Outdated) {AD166499-45F9-482A-A743-FDD3350758C7}
    c:\windows\xpsp1hfm.log
    ((((((((((((((((((((((((( Files Created from 2010-06-16 to 2010-07-16 )))))))))))))))))))))))))))))))
    2010-07-16 15:32 . 2010-04-29 22:39 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2010-07-16 15:32 . 2010-07-16 15:32 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2010-07-16 15:32 . 2010-04-29 22:39 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
    2010-07-14 22:38 . 2010-06-14 14:31 744448 ------w- c:\windows\system32\dllcache\helpsvc.exe
    2010-07-12 17:34 . 2010-07-12 17:34 -------- d-----w- c:\program files\Hitman Pro 3.5
    2010-07-09 23:30 . 2010-07-09 23:30 -------- d-----w- C:\$AVG8.VAULT$
    2010-07-09 23:22 . 2010-07-09 23:22 -------- d-----w- c:\documents and settings\All Users\Application Data\avg8
    2010-07-08 23:28 . 2010-07-15 15:42 -------- d-----w- c:\documents and settings\Sven Albrecht\Local Settings\Application Data\cqdhsggfv
    2010-07-06 23:44 . 2010-05-07 23:03 -------- d-----w- c:\program files\SUPERAntiSpyware
    2010-06-14 14:31 . 2002-08-29 11:00 744448 ----a-w- c:\windows\PCHealth\HelpCtr\Binaries\helpsvc.exe
    2010-05-26 13:11 . 2010-05-26 13:11 503808 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\Sun\Java\Deployment\SystemCache\6.0\46\f84c6ae-65781f07-n\msvcp71.dll
    2010-05-26 13:11 . 2010-05-26 13:11 499712 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\Sun\Java\Deployment\SystemCache\6.0\46\f84c6ae-65781f07-n\jmc.dll
    2010-05-26 13:11 . 2010-05-26 13:11 348160 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\Sun\Java\Deployment\SystemCache\6.0\46\f84c6ae-65781f07-n\msvcr71.dll
    2010-05-26 13:11 . 2010-05-26 13:11 61440 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\Sun\Java\Deployment\SystemCache\6.0\50\5535ab32-3c44011e-n\decora-sse.dll
    2010-05-26 13:11 . 2010-05-26 13:11 12800 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\Sun\Java\Deployment\SystemCache\6.0\50\5535ab32-3c44011e-n\decora-d3d.dll
    2010-05-21 21:14 . 2009-10-02 17:00 221568 ------w- c:\windows\system32\MpSigStub.exe
    2010-05-07 23:05 . 2010-05-07 23:05 63488 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\SD10006.dll
    2010-05-07 23:05 . 2010-05-07 23:05 52224 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\SD10005.dll
    2010-05-07 23:05 . 2010-05-07 23:05 117760 ----a-w- c:\documents and settings\Sven Albrecht\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2010-05-06 10:41 . 2004-02-07 01:05 916480 ----a-w- c:\windows\system32\wininet.dll
    2010-05-02 05:22 . 2002-08-29 11:00 1851264 ----a-w- c:\windows\system32\win32k.sys
    2010-04-20 05:30 . 2002-08-29 11:00 285696 ----a-w- c:\windows\system32\atmfd.dll
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2010-05-07 2017280]
    "IntelMeM "= "c:\program files\Intel\Modem Event Monitor\IntelMEM.exe" [2003-09-04 221184]
    "dla "= "c:\windows\system32\dla\tfswctrl.exe" [2003-08-06 114741]
    "DVDSentry "= "c:\windows\System32\DSentry.exe" [2003-08-13 28672]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2004-03-17 77824]
    "mmtask "= "c:\program files\MusicMatch\MusicMatch Jukebox\mmtask.exe" [2003-10-06 53248]
    "UpdateManager "= "c:\program files\Common Files\Sonic\Update Manager\sgtray.exe" [2003-08-19 110592]
    "NeroFilterCheck "= "c:\windows\system32\NeroCheck.exe" [2001-07-09 155648]
    "igfxtray "= "c:\windows\system32\igfxtray.exe" [2005-09-20 94208]
    "igfxpers "= "c:\windows\system32\igfxpers.exe" [2005-09-20 114688]
    "Windows Defender "= "c:\program files\Windows Defender\MSASCui.exe" [2006-11-04 866584]
    "ContentTransferWMDetector.exe "= "c:\program files\Sony\Content Transfer\ContentTransferWMDetector.exe" [2008-07-12 423200]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2004-03-17 151597]
    "CanonSolutionMenu "= "c:\program files\Canon\SolutionMenu\CNSLMAIN.exe" [2008-03-10 689488]
    "CanonMyPrinter "= "c:\program files\Canon\MyPrinter\BJMyPrt.exe" [2009-07-06 1848648]
    "Adobe Reader Speed Launcher "= "c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2010-06-20 35760]
    "Adobe ARM "= "c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-06-09 976832]
    "SunJavaUpdateSched "= "c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-02-18 248040]
    "avgnt "= "c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2010-03-02 282792]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "DWQueuedReporting "= "c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-03-13 39264]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "RunNarrator "= "Narrator.exe" [2008-04-14 53760]
    c:\documents and settings\Sven Albrecht\Start Menu\Programs\Startup\
    Shortcut to MSOFFICE.EXE.lnk - c:\microsoft office\Office10\MSOFFICE.EXE [2001-2-13 226720]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\explorer]
    "UseDesktopIniCache "= 1 (0x1)
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2009-09-03 22:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
    BootExecute REG_MULTI_SZ autocheck autochk *\0aswBoot.exe /A:* /L:1033 /heur:80 /pup /archives /IA:0 /KBD:2 /dir:C:\Program
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\beep.sys]
    @= "beep "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
    @= "Service "
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
    backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^Sven Albrecht^Start Menu^Programs^Startup^Shortcut Bar.lnk]
    path=c:\documents and settings\Sven Albrecht\Start Menu\Programs\Startup\Shortcut Bar.lnk
    backup=c:\windows\pss\Shortcut Bar.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
    "Pml Driver HPZ12 "=2 (0x2)
    "aspnet_state "=3 (0x3)
    "c:\\Program Files\\EarthLink TotalAccess\\TaskPanl.exe "=
    "c:\\Program Files\\Real\\RealPlayer\\realplay.exe "=
    "c:\\WINDOWS\\SYSTEM32\\mmc.exe "=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "8097:TCP "= 8097:TCP:EarthLink UHP Modem Support
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [2/17/2010 11:25 AM 12872]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [5/6/2010 5:10 PM 68168]
    R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [4/9/2010 12:35 PM 135336]
    R2 nxsIO32;NextSensor Kernel I/O Driver;c:\windows\SYSTEM32\DRIVERS\nxsIO32.sys [2/27/2006 1:40 PM 2208]
    R2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [11/3/2006 7:19 PM 13592]
    S3 OSCI_DRVNT;OSCI_DRVNT;c:\windows\SYSTEM32\DRIVERS\OSCI_DRVNT.sys [7/5/2007 11:24 AM 6784]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    getPlusHelper REG_MULTI_SZ getPlusHelper
    2010-07-16 c:\windows\Tasks\MP Scheduled Scan.job
    - c:\program files\Windows Defender\MpCmdRun.exe [2006-11-04 02:20]
    uStart Page = hxxp://www.google.com/
    uInternet Connection Wizard,ShellNext = iexplore
    uInternet Settings,ProxyServer = http=127.0.0.1:5577
    uInternet Settings,ProxyOverride = <local>
    IE: &ieSpell Options - c:\program files\ieSpell\iespell.dll/SPELLOPTION.HTM
    IE: Check &Spelling - c:\program files\ieSpell\iespell.dll/SPELLCHECK.HTM
    IE: E&xport to Microsoft Excel - c:\micros~1\Office10\EXCEL.EXE/3000
    TCP: {8FA5322C-C36E-4393-BCE7-9B8836E141A6} = 66.51.205.100,66.51.206.100
    DPF: {D34151C8-0C6C-4A7D-B677-4FCC9552E957} - hxxp://www.bcnx.com/SunInfoConnect_www.bcnx.com_medium.cab
    FF - ProfilePath - c:\documents and settings\Sven Albrecht\Application Data\Mozilla\Firefox\Profiles\cikbrq55.default\
    FF - prefs.js: browser.startup.homepage - hxxp://start.earthlink.net/
    FF - plugin: c:\program files\Canon\Easy-PhotoPrint EX\NPEZFFPI.DLL
    FF - plugin: c:\program files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
    ---- FIREFOX POLICIES ----
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "ui.use_native_colors ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.lu ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.nu ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.nz ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgberp4a5d4ar ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--p1ai ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.xn--mgbayh7gpa ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.IDN.whitelist.tel ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.auth.force-generic-ntlm ", false);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.proxy.type ", 5);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "dom.ipc.plugins.timeoutSecs ", 45);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "svg.smil.enabled ", false);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "accelerometer.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref ", true);
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.ssl.renego_unrestricted_hosts ", " ");
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.ssl.treat_unsafe_negotiation_as_broken ", false);
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.ssl.require_safe_negotiation ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name ", "chrome://browser/locale/browser.properties ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description ", "chrome://browser/locale/browser.properties ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "plugins.update.notifyUser ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled.nptest.dll ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled.npswf32.dll ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled.npctrl.dll ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled.npqtplugin.dll ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "dom.ipc.plugins.enabled ", false);
    Toolbar-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
    WebBrowser-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
    AddRemove-HijackThis - c:\documents and settings\Sven Albrecht\Desktop\HijackThis.exe
    Rootkit scan 2010-07-16 10:34
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
    @Denied: (A 2) (Everyone)
    @= "FlashBroker "
    "LocalizedString "= "@c:\\windows\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe,-101 "
    [HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
    "Enabled "=dword:00000001
    [HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
    @= "c:\\windows\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe "
    [HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
    @= "{FAB3E735-69C7-453B-A446-B6823C6DF1C9} "
    [HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
    @= "IFlashBroker4 "
    [HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
    @= "{00020424-0000-0000-C000-000000000046} "
    [HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
    "Version "= "1.0 "
    - - - - - - - > 'winlogon.exe'(664)
    c:\windows\system32\WININET.dll
    Completion time: 2010-07-16 10:37:16
    ComboFix-quarantined-files.txt 2010-07-16 17:37
    Pre-Run: 107,572,838,400 bytes free
    Post-Run: 107,693,961,216 bytes free
    - - End Of File - - 0FE02AFEED2A300D6F7926DACCDB1B80
  6. 2010/07/16
    SVEN
    Combo fix did the job!!!
    I am on line on the infected computer.
    Let me know if I have to do somthing else
    Sven
  7. 2010/07/16
    Good news :)
    We'll keep checking to make sure, nothing is lurking out there....
    1. Please open Notepad
    • Click Start , then Run
    • Type notepad .exe in the Run Box.
    2. Now copy/paste the entire content of the codebox below into the Notepad window:
    Folders::
    C:\$AVG8.VAULT$
    DDS::
    3. Save the above as CFScript.txt
    4. Then drag the CFScript.txt into ComboFix.exe as depicted in the animation below. This will start ComboFix again.
    5. After reboot, (in case it asks to reboot), please post the following reports/logs into your next reply:
    • Combofix.txt
  8. 2010/07/16
    SVEN
    here is the new log
    ComboFix 10-07-15.05 - Sven Albrecht 07/16/2010 11:48:53.3.1 - x86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.255 [GMT -7:00]
    Command switches used :: c:\documents and settings\Sven Albrecht\Desktop\CFScript.txt
    AV: AntiVir Desktop *On-access scanning disabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
    2010-07-16 15:32 . 2010-07-16 18:36 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2010-07-16 18:41 . 2010-05-07 23:03 -------- d-----w- c:\program files\SUPERAntiSpyware
    ((((((((((((((((((((((((((((( SnapShot@2010-07-16_17.34.24 )))))))))))))))))))))))))))))))))))))))))
    + 2010-07-16 18:37 . 2010-07-16 18:37 16384 c:\windows\Temp\Perflib_Perfdata_7cc.dat
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2010-07-16 2403568]
    @= "beep "
    @= "Service "
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [5/6/2010 5:10 PM 67656]
    S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [2/17/2010 11:25 AM 12872]
    Rootkit scan 2010-07-16 11:54
    hidden files: 0
    @= "FlashBroker "
    @= "IFlashBroker4 "
    "Version "= "1.0 "
    - - - - - - - > 'explorer.exe'(512)
    c:\windows\system32\ieframe.dll
    c:\windows\system32\webcheck.dll
    c:\windows\system32\WPDShServiceObj.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    Completion time: 2010-07-16 11:57:16
    ComboFix-quarantined-files.txt 2010-07-16 18:57
    ComboFix2.txt 2010-07-16 17:37
    Pre-Run: 107,696,553,984 bytes free
    Post-Run: 107,684,376,576 bytes free
    - - End Of File - - FC29E1B9B1E16D4509677FDA2A1E895C
  9. 2010/07/16
    Good :)
    Uninstall Combofix:
    Go Start > Run [Vista users, go Start> "Start search"]
    Type in:
    Combofix /Uninstall
    Note the space between the "Combofix" and the "/Uninstall "
    Click OK (Vista users - press Enter).
    Restart computer.
    Download OTL to your Desktop.
    * Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    * Under the Custom Scan box paste this in:
    netsvcs
    drivers32 /all
    %SYSTEMDRIVE%\*.*
    %systemroot%\system32\Spool\prtprocs\w32x86\*.dll
    %systemroot%\system32\*.wt
    %systemroot%\system32\*.ruy
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\system32\spool\prtprocs\w32x86\*.tmp
    %systemroot%\*. /mp /s
    /md5start
    /md5stop
    CREATERESTOREPOINT
    %systemroot%\system32\*.dll /lockedfiles
    %systemroot%\Tasks\*.job /lockedfiles
    %systemroot%\System32\config\*.sav
    %systemroot%\system32\user32.dll /md5
    %systemroot%\system32\ws2_32.dll /md5
    %systemroot%\system32\ws2help.dll /md5
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    * Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  10. 2010/07/16
    SVEN
    Here are the logs
    OTL Extras logfile created on: 7/16/2010 12:33:14 PM - Run 1
    OTL by OldTimer - Version 3.2.9.0 Folder = C:\Documents and Settings\Sven Albrecht\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    510.00 Mb Total Physical Memory | 209.00 Mb Available Physical Memory | 41.00% Memory free
    1.00 Gb Paging File | 1.00 Gb Available in Paging File | 68.00% Paging File free
    Paging file location(s): C:\pagefile.sys 768 1536 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\windows | %ProgramFiles% = C:\Program Files
    Drive C: | 111.79 Gb Total Space | 100.60 Gb Free Space | 89.99% Space Free | Partition Type: NTFS
    Drive D: | 10.42 Gb Total Space | 2.43 Gb Free Space | 23.31% Space Free | Partition Type: NTFS
    Drive E: | 64.08 Gb Total Space | 58.88 Gb Free Space | 91.89% Space Free | Partition Type: NTFS
    F: Drive not present or media not loaded
    G: Drive not present or media not loaded
    H: Drive not present or media not loaded
    I: Drive not present or media not loaded
    Drive Z: | 111.79 Gb Total Space | 100.60 Gb Free Space | 89.99% Space Free | Partition Type: NTFS
    Computer Name: INTERTRADEINC
    Current User Name: Sven Albrecht
    Logged in as Administrator.
    Current Boot Mode: Normal
    Scan Mode: Current user
    Company Name Whitelist: On
    Skip Microsoft Files: On
    File Age = 90 Days
    Output = Standard
    Quick Scan
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    [HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
    .html [@ = htmlfile] -- Reg Error: Key error. File not found
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    comfile [open] -- "%1" %*
    exefile [open] -- "%1" %*
    htmlfile [edit] -- "C:\Microsoft Office\Office10\msohtmed.exe" %1 (Microsoft Corporation)
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l (Microsoft Corporation)
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    "AntiVirusOverride" = 0
    "FirewallOverride" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:*:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:*:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:*:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:*:Enabled:mad:xpsp2res.dll,-22002
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "1900:UDP" = 1900:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22007
    "2869:TCP" = 2869:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22008
    "139:TCP" = 139:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22002
    "8097:TCP" = 8097:TCP:*:Enabled:EarthLink UHP Modem Support
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\Program Files\EarthLink TotalAccess\TaskPanl.exe" = C:\Program Files\EarthLink TotalAccess\TaskPanl.exe:*:Enabled:TaskPanl -- (EarthLink, Inc.)
    "C:\Program Files\Real\RealPlayer\realplay.exe" = C:\Program Files\Real\RealPlayer\realplay.exe:*:Enabled:RealOne Player -- (RealNetworks, Inc.)
    "C:\WINDOWS\SYSTEM32\mmc.exe" = C:\WINDOWS\SYSTEM32\mmc.exe:*:Enabled:Microsoft Management Console -- (Microsoft Corporation)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{00203668-8170-44A0-BE44-B632FA4D780F}" = Adobe AIR
    "{04410044-9149-45C6-A806-F2BF9CFCE762}" = Microsoft Encarta Encyclopedia Standard 2004
    "{0F756CD9-4A1E-409B-B101-601DDC4C03AA}" = Qualxserve Service Agreement
    "{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MP620_series" = Canon MP620 series MP Drivers
    "{11F1920A-56A2-4642-B6E0-3B31A12C9288}" = Dell Solution Center
    "{121634B0-2F4A-11D3-ADA3-00C04F52DD53}" = Windows Installer Clean Up
    "{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    "{25F9791C-B446-462D-BDC6-F95BCBB81851}" = EarthLink Spyware Blocker
    "{26A24AE4-039D-4CA4-87B4-2F83216019FF}" = Java(TM) 6 Update 20
    "{279C4248-7769-45CA-A03F-E8339954C4F3}" = EarthLink Redistributed
    "{2A011F38-2F3B-484F-9595-E8462430F0BF}" = ELNBonus
    "{2C0A655C-61E7-428A-8ED2-23A3D20E7DD2}" = Data Lifeguard Tools
    "{2F72E05E-2371-4C05-9091-B643A9456267}" = EarthLink Setup
    "{3454F318-1008-46A9-A1F5-69C5F8AB3BCF}" = Deal Info
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{35BDEFF1-A610-4956-A00D-15453C116395}" = Internet Explorer Default Page
    "{3F92ABBB-6BBF-11D5-B229-002078017FBF}" = Modem On Hold
    "{43DCF766-6838-4F9A-8C91-D92DA586DFA7}" = Microsoft Windows Journal Viewer
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{50915408-4940-4C36-B4CC-0D9944FA4C59}" = EarthLink FastLane
    "{51487A3E-7A7D-46D8-B7E5-7F85B57B8C2F}" = EarthLink Common
    "{54DD126C-E5F5-404C-B4B7-66DF7FD4F2FF}" = MSSoap
    "{62329568-19B5-43CF-9524-3EE4DD709D01}" = EarthLink Toolbar
    "{63569CE9-FA00-469C-AF5C-E5D4D93ACF91}" = Windows Genuine Advantage v1.3.0254.0
    "{66910000-8B30-4973-A159-6371345AFFA5}" = WebReg
    "{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD
    "{68D60342-7686-45C9-B8EB-40EF843D0460}" = Dell Networking Guide
    "{76EFFC7C-17A6-479D-9E47-8E658C1695AE}" = Windows Backup Utility
    "{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    "{77DCDCE3-2DED-62F3-8154-05E745472D07}" = Acrobat.com
    "{79500098-252F-47C3-B773-E6EFEBBD1D92}" = EarthLink Update Manager
    "{7A0EFAFB-AC4B-4B88-8C6B-6731BE88DB68}" = Modem Event Monitor
    "{7F142D56-3326-11D5-B229-002078017FBF}" = Modem Helper
    "{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
    "{8A708DD8-A5E6-11D4-A706-000629E95E20}" = Intel(R) Extreme Graphics 2 Driver
    "{90280409-6000-11D3-8CFE-0050048383C9}" = Microsoft Office XP Professional with FrontPage
    "{90D55A3F-1D99-4C94-A77E-46DC14F0BF08}" = Help and Support Customization
    "{91130409-6000-11D3-8CFE-0050048383C9}" = Microsoft Office XP Small Business
    "{98DF85D9-96C0-4F57-A92E-C3539477EF5E}" = DVDSentry
    "{A06275F4-324B-4E85-95E6-87B2CD729401}" = Windows Defender
    "{A5CC2A09-E9D3-49EC-923D-03874BBD4C2C}" = Windows Defender Signatures
    "{A790BEB1-BCCF-4EC6-807B-5708B36E8A79}" = Intel(R) PROSet
    "{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3.3
    "{AC76BA86-7AD7-5464-3428-900000000004}" = Spelling Dictionaries Support For Adobe Reader 9
    "{ACF2AD4B-9374-4B72-B79B-A743CD41F2A4}" = EarthLink TaskPanel
    "{B5FDA445-CAC4-4BA6-A8FB-A7212BD439DE}" = Microsoft XML Parser
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware Free Edition
    "{CF40ACC5-E1BB-4aff-AC72-04C2F616BCA7}" = getPlus(R) for Adobe
    "{CFADE4AF-C0CF-4A04-A776-741318F1658F}" = Content Transfer
    "{D9C3CDEB-BC7F-4CB3-BC92-719B365DF28E}" = EarthLink IM
    "{DBDB8C5A-E0B9-4C10-A649-59D962E3A07F}" = EarthLink Webspace
    "{F91E1833-2D7C-4725-B98A-C779FEC41946}" = EarthLink MDAC
    "{FC4ED75D-916C-4A8C-BB67-3C6F6E06D62B}" = Banctec Service Agreement
    "{FCE65C4E-B0E8-4FBD-AD16-EDCBE6CD591F}" = HighMAT Extension to Microsoft Windows XP CD Writing Wizard
    "Adobe AIR" = Adobe AIR
    "Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
    "Avira AntiVir Desktop" = Avira AntiVir Personal - Free Antivirus
    "Canon MP620 series User Registration" = Canon MP620 series User Registration
    "Canon_IJ_Network_Scan_UTILITY" = Canon IJ Network Scan Utility
    "Canon_IJ_Network_UTILITY" = Canon IJ Network Tool
    "CanonMyPrinter" = Canon Utilities My Printer
    "CanonSolutionMenu" = Canon Utilities Solution Menu
    "com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
    "CompuPic" = CompuPic
    "EarthLink TotalAccess 2004" = EarthLink Software
    "EASEUS Data Recovery Wizard Professional 5.0.1_is1" = EASEUS Data Recovery Wizard Professional 5.0.1
    "Easy-PhotoPrint EX" = Canon Utilities Easy-PhotoPrint EX
    "EVEREST Home Edition_is1" = EVEREST Home Edition v2.20
    "FormDocs" = FormDocs 6.5
    "IDNMitigationAPIs" = Microsoft Internationalized Domain Names Mitigation APIs
    "ie7" = Windows Internet Explorer 7
    "ie8" = Windows Internet Explorer 8
    "ieSpell" = ieSpell 2.1.1 (build 325)
    "Intel(R) 537EP V9x DF PCI Modem" = Intel(R) 537EP V9x DF PCI Modem
    "MP Navigator EX 2.0" = Canon MP Navigator EX 2.0
    "MSCompPackV1" = Microsoft Compression Client Pack 1.0 for Windows XP
    "Nero - Burning Rom!UninstallKey" = Nero OEM
    "NeroVision!UninstallKey" = NeroVision Express 2
    "NLSDownlevelMapping" = Microsoft National Language Support Downlevel APIs
    "NMPUninstallKey" = Nero Media Player
    "PropFix" = Microsoft Office 97 Unique Identifier Removal Tool
    "PROSet" = Intel(R) PRO Network Adapters and Drivers
    "QuickTime" = QuickTime
    "RealPlayer 6.0" = RealOne Player
    "StreetPlugin" = Learn2 Player (Uninstall Only)
    "ViewpointMediaPlayer" = Viewpoint Media Player (Remove Only)
    "Windows Media Format Runtime" = Windows Media Format 11 runtime
    "Windows Media Player" = Windows Media Player 11
    "Windows XP Service Pack" = Windows XP Service Pack 3
    "WMFDist11" = Windows Media Format 11 runtime
    "wmp11" = Windows Media Player 11
    "Wudf01000" = Microsoft User-Mode Driver Framework Feature Pack 1.0
    "XQXSetup_is1" = Xteq Systems X-Setup 6.3
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 1/28/2010 8:31:26 PM | Computer Name = INTERTRADEINC | Source = Application Error | ID = 1000
    Description = Faulting application googleearth.exe, version 5.1.3533.1731, faulting
    module msvcr80.dll, version 8.0.50727.762, fault address 0x00008a8c.
    Error - 1/28/2010 8:31:32 PM | Computer Name = INTERTRADEINC | Source = Application Error | ID = 1001
    Description = Fault bucket 1566600331.
    Error - 2/8/2010 5:59:19 PM | Computer Name = INTERTRADEINC | Source = Application Error | ID = 1000
    Description = Faulting application iexplore.exe, version 8.0.6001.18702, faulting
    module avgssie.dll, version 8.5.0.427, fault address 0x00017eb1.
    Error - 3/8/2010 6:05:50 PM | Computer Name = INTERTRADEINC | Source = Application Error | ID = 1000
    Error - 4/29/2010 4:57:48 PM | Computer Name = INTERTRADEINC | Source = crypt32 | ID = 131080
    Description = Failed auto update retrieval of third-party root list sequence number
    from: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootseq.txt>
    with error: This operation returned because the timeout period expired.
    Error - 6/10/2010 1:00:25 PM | Computer Name = INTERTRADEINC | Source = MPSampleSubmission | ID = 5000
    Description =
    Error - 7/9/2010 1:00:02 PM | Computer Name = INTERTRADEINC | Source = MPSampleSubmission | ID = 5000
    Description =
    Error - 7/14/2010 6:13:56 PM | Computer Name = INTERTRADEINC | Source = MPSampleSubmission | ID = 5000
    Description =
    Error - 7/15/2010 11:41:42 AM | Computer Name = INTERTRADEINC | Source = crypt32 | ID = 131083
    Description = Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab>
    with error: A required certificate is not within its validity period when verifying
    against the current system clock or the timestamp in the signed file.
    [ System Events ]
    Error - 7/14/2010 5:53:45 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Description = The following boot-start or system-start driver(s) failed to load:
    Beep
    Error - 7/14/2010 5:54:46 PM | Computer Name = INTERTRADEINC | Source = Windows Update Agent | ID = 16
    Description = Unable to Connect: Windows is unable to connect to the automatic updates
    service and therefore cannot download and install updates according to the set
    schedule. Windows will continue to try to establish a connection.
    Error - 7/14/2010 7:14:52 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/15/2010 11:41:29 AM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/15/2010 6:28:43 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/16/2010 11:27:58 AM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/16/2010 11:48:01 AM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/16/2010 12:47:45 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/16/2010 2:37:40 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7026
    Beep
    Error - 7/16/2010 2:42:16 PM | Computer Name = INTERTRADEINC | Source = Service Control Manager | ID = 7000
    Description = The SASDIFSV service failed to start due to the following error: %%183
    < End of report >
  11. 2010/07/16
    SVEN
    Log #2
    OTL logfile created on: 7/16/2010 12:33:14 PM - Run 1
    File Age = 90 Days
    Output = Standard
    Quick Scan
    PRC - [2010/07/16 12:31:11 | 000,574,976 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Sven Albrecht\Desktop\OTL.exe
    PRC - [2010/04/19 10:32:11 | 000,267,432 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe
    PRC - [2010/03/02 10:28:31 | 000,282,792 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
    PRC - [2010/02/24 09:28:09 | 000,135,336 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\sched.exe
    PRC - [2010/01/14 21:11:00 | 000,076,968 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avshadow.exe
    PRC - [2009/07/06 10:07:00 | 001,848,648 | ---- | M] (CANON INC.) -- C:\Program Files\Canon\MyPrinter\BJMYPRT.EXE
    PRC - [2008/07/11 17:51:32 | 000,423,200 | ---- | M] (Sony Corporation) -- C:\Program Files\Sony\Content Transfer\ContentTransferWMDetector.exe
    PRC - [2008/04/13 17:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2006/11/03 19:20:12 | 000,866,584 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MSASCui.exe
    PRC - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MsMpEng.exe
    PRC - [2006/03/03 21:03:10 | 000,069,632 | ---- | M] (HP) -- C:\WINDOWS\SYSTEM32\HPZipm12.exe
    PRC - [2004/03/16 18:07:01 | 000,151,597 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    PRC - [2003/08/13 09:27:40 | 000,028,672 | ---- | M] (Dell - Advanced Desktop Engineering) -- C:\WINDOWS\SYSTEM32\DSentry.exe
    PRC - [2001/02/13 00:58:54 | 000,226,720 | ---- | M] (Microsoft Corporation) -- C:\Microsoft Office\Office10\MSOFFICE.EXE
    MOD - [2010/07/16 12:31:11 | 000,574,976 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Sven Albrecht\Desktop\OTL.exe
    MOD - [2001/08/18 11:00:00 | 000,106,547 | ---- | M] (Microsoft Corporation) -- C:\Program Files\X-Setup\bin\msscript.ocx
    SRV - File not found [Disabled | Stopped] -- C:\windows\System32\hidserv.dll -- (HidServ)
    SRV - File not found [Disabled | Stopped] -- C:\windows\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe -- (aspnet_state)
    SRV - File not found [Disabled | Stopped] -- C:\windows\System32\appmgmts.dll -- (AppMgmt)
    SRV - [2010/04/19 10:32:11 | 000,267,432 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe -- (AntiVirService)
    SRV - [2010/03/29 08:51:54 | 000,068,000 | ---- | M] (NOS Microsystems Ltd.) [On_Demand | Stopped] -- C:\Program Files\NOS\bin\getPlus_Helper.dll -- (getPlusHelper) getPlus(R)
    SRV - [2010/02/24 09:28:09 | 000,135,336 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\sched.exe -- (AntiVirSchedulerService)
    SRV - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MsMpEng.exe -- (WinDefend)
    SRV - [2006/03/03 21:03:10 | 000,069,632 | ---- | M] (HP) [Unknown | Running] -- C:\WINDOWS\SYSTEM32\HPZipm12.exe -- (Pml Driver HPZ12)
    SRV - [2003/03/03 12:33:40 | 000,143,360 | ---- | M] (Intel(R) Corporation) [On_Demand | Stopped] -- C:\Program Files\Intel\NCS\Sync\NetSvc.exe -- (NetSvc)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\windows\TEMP\WinIo.sys -- (WINIO)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\windows\System32\DRIVERS\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\windows\System32\DRIVERS\wATV03nt.sys -- (iAimTV2)
    DRV - File not found [Kernel | On_Demand | Running] -- C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\catchme.sys -- (catchme)
    DRV - [2010/07/16 11:41:42 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/03/01 09:05:24 | 000,124,784 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\avipbb.sys -- (avipbb)
    DRV - [2010/02/17 11:25:50 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Stopped] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2010/02/16 13:24:01 | 000,060,936 | ---- | M] (Avira GmbH) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\avgntflt.sys -- (avgntflt)
    DRV - [2009/05/11 11:49:19 | 000,011,608 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\Program Files\Avira\AntiVir Desktop\avgio.sys -- (avgio)
    DRV - [2009/05/11 09:12:49 | 000,028,520 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\ssmdrv.sys -- (ssmdrv)
    DRV - [2009/01/05 13:28:41 | 000,028,256 | ---- | M] (MusicMatch, Inc.) [Kernel | On_Demand | Running] -- C:\windows\System32\drivers\MxlW2k.sys -- (MxlW2k)
    DRV - [2008/04/13 11:36:39 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\amdagp.sys -- (amdagp)
    DRV - [2008/04/13 11:36:39 | 000,040,960 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\sisagp.sys -- (sisagp)
    DRV - [2007/07/05 11:24:43 | 000,006,784 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\OSCI_DRVNT.sys -- (OSCI_DRVNT)
    DRV - [2006/02/27 13:40:22 | 000,002,208 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\nxsIO32.sys -- (nxsIO32)
    DRV - [2004/07/27 09:01:13 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\nv4_mini.sys -- (nv)
    DRV - [2004/07/27 09:00:23 | 000,161,020 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\i81xnt5.sys -- (i81x)
    DRV - [2004/07/27 08:59:55 | 000,033,599 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv04nt.sys -- (iAimTV3)
    DRV - [2004/07/27 08:59:53 | 000,029,311 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv01nt.sys -- (iAimTV0)
    DRV - [2004/07/27 08:59:51 | 000,023,615 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wch7xxnt.sys -- (iAimTV4)
    DRV - [2004/07/27 08:59:50 | 000,019,455 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wvchntxx.sys -- (iAimFP4)
    DRV - [2004/07/27 08:59:48 | 000,019,551 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\watv02nt.sys -- (iAimTV1)
    DRV - [2004/07/27 08:59:45 | 000,012,415 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv01nt.sys -- (iAimFP0)
    DRV - [2004/07/27 08:59:45 | 000,012,127 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv02nt.sys -- (iAimFP1)
    DRV - [2004/07/27 08:59:45 | 000,012,063 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wsiintxx.sys -- (iAimFP3)
    DRV - [2004/07/27 08:59:44 | 000,011,775 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\wadv05nt.sys -- (iAimFP2)
    DRV - [2004/03/05 23:15:34 | 000,647,929 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC52.sys -- (IntelC52)
    DRV - [2004/03/05 23:14:42 | 001,233,525 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC51.sys -- (IntelC51)
    DRV - [2004/03/05 23:13:52 | 000,060,949 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC53.sys -- (IntelC53)
    DRV - [2004/03/05 23:13:38 | 000,037,048 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\mohfilt.sys -- (mohfilt)
    DRV - [2003/08/06 00:04:00 | 000,100,373 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnudfa.sys -- (tfsnudfa)
    DRV - [2003/08/06 00:04:00 | 000,098,068 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnudf.sys -- (tfsnudf)
    DRV - [2003/08/06 00:04:00 | 000,083,284 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnifs.sys -- (tfsnifs)
    DRV - [2003/08/06 00:04:00 | 000,034,837 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsncofs.sys -- (tfsncofs)
    DRV - [2003/08/06 00:04:00 | 000,025,685 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnboio.sys -- (tfsnboio)
    DRV - [2003/08/06 00:04:00 | 000,014,229 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnopio.sys -- (tfsnopio)
    DRV - [2003/08/06 00:04:00 | 000,006,357 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsnpool.sys -- (tfsnpool)
    DRV - [2003/08/06 00:04:00 | 000,004,117 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsndrct.sys -- (tfsndrct)
    DRV - [2003/08/06 00:04:00 | 000,002,233 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\dla\tfsndres.sys -- (tfsndres)
    DRV - [2003/07/31 02:21:00 | 000,084,576 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\windows\system32\drivers\drvmcdb.sys -- (drvmcdb)
    DRV - [2003/07/14 10:28:40 | 000,005,621 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\sscdbhk5.sys -- (sscdbhk5)
    DRV - [2003/07/14 10:28:22 | 000,023,219 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\ssrtln.sys -- (ssrtln)
    DRV - [2003/06/20 01:56:00 | 000,040,448 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\drvnddm.sys -- (drvnddm)
    DRV - [2002/11/08 12:45:06 | 000,017,217 | ---- | M] (Dell Computer Corporation) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\omci.sys -- (omci)
    DRV - [2001/08/17 13:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\sparrow.sys -- (Sparrow)
    DRV - [2001/08/17 13:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\sym_u3.sys -- (sym_u3)
    DRV - [2001/08/17 13:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\sym_hi.sys -- (sym_hi)
    DRV - [2001/08/17 13:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\symc8xx.sys -- (symc8xx)
    DRV - [2001/08/17 13:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\symc810.sys -- (symc810)
    DRV - [2001/08/17 12:57:38 | 000,016,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\MODEMCSA.sys -- (MODEMCSA)
    DRV - [2001/08/17 12:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\ultra.sys -- (ultra)
    DRV - [2001/08/17 12:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\ql12160.sys -- (ql12160)
    DRV - [2001/08/17 12:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\ql1080.sys -- (ql1080)
    DRV - [2001/08/17 12:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\ql1280.sys -- (ql1280)
    DRV - [2001/08/17 12:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\dac2w2k.sys -- (dac2w2k)
    DRV - [2001/08/17 12:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\mraid35x.sys -- (mraid35x)
    DRV - [2001/08/17 12:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\asc.sys -- (asc)
    DRV - [2001/08/17 12:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\asc3550.sys -- (asc3550)
    DRV - [2001/08/17 12:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\aliide.sys -- (AliIde)
    DRV - [2001/08/17 12:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\windows\System32\DRIVERS\cmdide.sys -- (CmdIde)
    DRV - [2001/08/17 11:11:06 | 000,066,591 | ---- | M] (3Com Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\SYSTEM32\DRIVERS\EL90XBC5.SYS -- (EL90XBC)
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.google.com/
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..browser.startup.homepage: "http://start.earthlink.net/ "
    FF - prefs.js..extensions.enabledItems: jqs@sun.com:1.0
    [2010/07/15 14:35:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Mozilla\Extensions
    [2006/04/28 11:45:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Mozilla\Firefox\Profiles\cikbrq55.default\extensions
    O1 HOSTS File: ([2010/07/16 10:34:15 | 000,000,027 | ---- | M]) - C:\WINDOWS\SYSTEM32\DRIVERS\ETC\hosts
    O2 - BHO: (PnIEBrowserHelperObj Class) - {4B5F2E08-6F39-479a-B547-B2026E4C7EDF} - C:\Program Files\EarthLink TotalAccess\PnEL.dll (EarthLink, Inc.)
    O2 - BHO: (DriveLetterAccess) - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\SYSTEM32\dla\tfswshx.dll (Sonic Solutions)
    O3 - HKLM\..\Toolbar: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - No CLSID value found.
    O3 - HKLM\..\Toolbar: (EarthLink Toolbar) - {D7F30B62-8269-41AF-9539-B2697FA7D77E} - C:\Program Files\EarthLink TotalAccess\PnEL.dll (EarthLink, Inc.)
    O3 - HKCU\..\Toolbar\ShellBrowser: (EarthLink Toolbar) - {D7F30B62-8269-41AF-9539-B2697FA7D77E} - C:\Program Files\EarthLink TotalAccess\PnEL.dll (EarthLink, Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (EarthLink Toolbar) - {D7F30B62-8269-41AF-9539-B2697FA7D77E} - C:\Program Files\EarthLink TotalAccess\PnEL.dll (EarthLink, Inc.)
    O4 - HKLM..\Run: [avgnt] C:\Program Files\Avira\AntiVir Desktop\avgnt.exe (Avira GmbH)
    O4 - HKLM..\Run: [CanonMyPrinter] C:\Program Files\Canon\MyPrinter\BJMyPrt.exe (CANON INC.)
    O4 - HKLM..\Run: [CanonSolutionMenu] C:\Program Files\Canon\SolutionMenu\CNSLMAIN.exe (CANON INC.)
    O4 - HKLM..\Run: [ContentTransferWMDetector.exe] C:\Program Files\Sony\Content Transfer\ContentTransferWMDetector.exe (Sony Corporation)
    O4 - HKLM..\Run: [DVDSentry] C:\WINDOWS\SYSTEM32\DSentry.exe (Dell - Advanced Desktop Engineering)
    O4 - HKLM..\Run: [NeroFilterCheck] C:\WINDOWS\SYSTEM32\NeroCheck.exe (Ahead Software Gmbh)
    O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
    O4 - HKLM..\Run: [UpdateManager] C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe (Sonic Solutions)
    O4 - HKLM..\Run: [Windows Defender] C:\Program Files\Windows Defender\MSASCui.exe (Microsoft Corporation)
    O4 - HKCU..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERANTISPYWARE.EXE (SUPERAntiSpyware.com)
    O4 - Startup: C:\Documents and Settings\Sven Albrecht\Start Menu\Programs\Startup\Shortcut to MSOFFICE.EXE.lnk = C:\Microsoft Office\Office10\MSOFFICE.EXE (Microsoft Corporation)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: UseDesktopIniCache = 1
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: &ieSpell Options - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: Check &Spelling - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Microsoft Office\Office10\EXCEL.EXE (Microsoft Corporation)
    O9 - Extra Button: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O9 - Extra 'Tools' menuitem : ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O9 - Extra 'Tools' menuitem : ieSpell Options - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} http://go.microsoft.com/fwlink/?linkid=48835 (Windows Genuine Advantage Validation Tool)
    O16 - DPF: {3E68E405-C6DE-49FF-83AE-41EE9F4C36CE} http://office.microsoft.com/officeupdate/content/opuc2.cab (Office Update Installation Engine)
    O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} http://download.bitdefender.com/resources/scanner/sources/en/scan8/oscan8.cab (BDSCANONLINE Control)
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} http://v5.windowsupdate.microsoft.c...ls/en/x86/client/wuweb_site.cab?1091044601515 (WUWebControl Class)
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1137428743093 (MUWebControl Class)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?38070.5747569444 (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA} http://java.sun.com/update/1.5.0/jinstall-1_5_0_02-windows-i586.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} http://wwwimages.adobe.com/www.adobe.com/products/acrobat/nos/gp.cab (Reg Error: Key error.)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: {D34151C8-0C6C-4A7D-B677-4FCC9552E957} http://www.bcnx.com/SunInfoConnect_www.bcnx.com_medium.cab (Reg Error: Key error.)
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.2.1 192.168.2.1 66.51.205.100 156.154.71.16
    O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - File not found
    O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - File not found
    O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - File not found
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\windows\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll (SUPERAntiSpyware.com)
    O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\windows\System32\igfxdev.dll (Intel Corporation)
    O24 - Desktop WallPaper: C:\WINDOWS\ITI.BMP
    O24 - Desktop BackupWallPaper: C:\WINDOWS\ITI.BMP
    O28 - HKLM ShellExecuteHooks: {091EB208-39DD-417D-A5DD-7E2C2D8FB9CB} - C:\Program Files\Windows Defender\MpShHook.dll (Microsoft Corporation)
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O32 - AutoRun File - [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () - D:\AUTOEXEC.BAT -- [ NTFS ]
    O34 - HKLM BootExecute: (aswBoot.exe /A:* /L:1033 /heur:80 /pup /archives /IA:0 /KBD:2 /dir:C:\Program) - File not found
    O37 - HKLM\...com [@ = comfile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - C:\windows\System32\appmgmts.dll File not found
    NetSvcs: HidServ - C:\windows\System32\hidserv.dll File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: Wmi - C:\windows\System32\wmi.dll (Microsoft Corporation)
    NetSvcs: WmdmPmSp - File not found
    NetSvcs: Ip6FwHlp - File not found
    Drivers32: midi - C:\windows\System32\wdmaud.drv (Microsoft Corporation)
    Drivers32: midimapper - C:\windows\System32\midimap.dll (Microsoft Corporation)
    Drivers32: mixer - C:\windows\System32\wdmaud.drv (Microsoft Corporation)
    Drivers32: msacm.iac2 - C:\windows\System32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.imaadpcm - C:\windows\System32\imaadp32.acm (Microsoft Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\SYSTEM32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.msadpcm - C:\windows\System32\msadp32.acm (Microsoft Corporation)
    Drivers32: msacm.msaudio1 - C:\windows\System32\msaud32.acm (Microsoft Corporation)
    Drivers32: msacm.msg711 - C:\windows\System32\MSG711.ACM (Microsoft Corporation)
    Drivers32: msacm.msg723 - C:\windows\System32\MSG723.ACM (Microsoft Corporation)
    Drivers32: msacm.msgsm610 - C:\windows\System32\MSGSM32.ACM (Microsoft Corporation)
    Drivers32: msacm.sl_anet - C:\windows\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\windows\System32\TSSOFT32.ACM (DSP GROUP, INC.)
    Drivers32: vidc.cvid - C:\windows\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.I420 - C:\windows\System32\msh263.drv (Microsoft Corporation)
    Drivers32: vidc.iv31 - C:\windows\System32\IR32_32.DLL ()
    Drivers32: vidc.iv32 - C:\windows\System32\IR32_32.DLL ()
    Drivers32: vidc.iv41 - C:\windows\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\windows\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.iyuv - C:\windows\System32\iyuv_32.dll (Microsoft Corporation)
    Drivers32: vidc.M261 - C:\windows\System32\msh261.drv (Microsoft Corporation)
    Drivers32: vidc.M263 - C:\windows\System32\msh263.drv (Microsoft Corporation)
    Drivers32: vidc.mrle - C:\windows\System32\msrle32.dll (Microsoft Corporation)
    Drivers32: vidc.msvc - C:\windows\System32\msvidc32.dll (Microsoft Corporation)
    Drivers32: vidc.uyvy - C:\windows\System32\msyuv.dll (Microsoft Corporation)
    Drivers32: vidc.yuy2 - C:\windows\System32\msyuv.dll (Microsoft Corporation)
    Drivers32: vidc.yvu9 - C:\windows\System32\tsbyuv.dll (Microsoft Corporation)
    Drivers32: vidc.yvyu - C:\windows\System32\msyuv.dll (Microsoft Corporation)
    Drivers32: wave - C:\windows\System32\wdmaud.drv (Microsoft Corporation)
    Drivers32: wave1 - C:\windows\System32\SERWVDRV.DLL (Microsoft Corporation)
    Drivers32: wavemapper - C:\windows\System32\MSACM32.DRV (Microsoft Corporation)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (17183584330711040)
    ========== Files/Folders - Created Within 90 Days ==========
    [2010/07/16 12:31:05 | 000,574,976 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Sven Albrecht\Desktop\OTL.exe
    [2010/07/16 08:32:52 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2010/07/12 10:34:10 | 000,000,000 | ---D | C] -- C:\Program Files\Hitman Pro 3.5
    [2010/07/09 16:30:00 | 000,000,000 | ---D | C] -- C:\$AVG8.VAULT$
    [2010/07/09 16:22:43 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\avg8
    [2010/07/08 16:28:57 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\cqdhsggfv
    [2010/06/23 08:48:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Sven Albrecht\My Documents\RSVP PIcs
    [2010/05/07 16:03:43 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
    [2010/05/07 16:03:30 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Sven Albrecht\Application Data\SUPERAntiSpyware.com
    [2010/05/07 16:03:30 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
    [2010/05/07 16:02:47 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Wise Installation Wizard
    [7 C:\windows\*.tmp files -> C:\windows\*.tmp -> ]
    [16 C:\windows\System32\*.tmp files -> C:\windows\System32\*.tmp -> ]
    ========== Files - Modified Within 90 Days ==========
    [2010/07/16 12:35:01 | 009,961,472 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\NTUSER.DAT
    [2010/07/16 11:57:17 | 000,000,006 | -H-- | M] () -- C:\windows\tasks\SA.DAT
    [2010/07/16 11:54:40 | 000,000,227 | ---- | M] () -- C:\windows\system.ini
    [2010/07/16 11:40:07 | 000,000,330 | -H-- | M] () -- C:\windows\tasks\MP Scheduled Scan.job
    [2010/07/16 11:37:55 | 000,001,170 | ---- | M] () -- C:\windows\System32\WPA.DBL
    [2010/07/16 11:36:56 | 000,002,048 | --S- | M] () -- C:\windows\BOOTSTAT.DAT
    [2010/07/16 11:36:54 | 534,827,008 | -HS- | M] () -- C:\hiberfil.sys
    [2010/07/16 11:36:16 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Sven Albrecht\NTUSER.INI
    [2010/07/16 10:34:15 | 000,000,027 | ---- | M] () -- C:\windows\System32\drivers\ETC\hosts
    [2010/07/08 15:20:08 | 000,014,336 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\My Documents\Lotto Payout.xls
    [2010/06/16 16:39:43 | 000,041,472 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\My Documents\catalog Letter.doc
    [2010/06/11 10:16:04 | 000,203,328 | ---- | M] () -- C:\windows\System32\FNTCACHE.DAT
    [2010/06/10 10:03:50 | 000,001,374 | ---- | M] () -- C:\windows\imsins.BAK
    [2010/06/03 14:13:41 | 000,193,024 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\My Documents\zip code tax.doc
    [2010/06/03 13:57:07 | 000,158,208 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\My Documents\Zip Codes.xls
    [2010/06/01 16:24:02 | 000,109,568 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\My Documents\zip code.doc
    [2010/06/03 14:13:41 | 000,193,024 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\My Documents\zip code tax.doc
    [2010/06/01 16:24:01 | 000,109,568 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\My Documents\zip code.doc
    [2010/06/01 16:16:13 | 000,158,208 | ---- | C] () -- C:\Documents and Settings\Sven Albrecht\My Documents\Zip Codes.xls
    [2009/01/05 15:44:10 | 000,000,453 | ---- | C] () -- C:\windows\bdoscandellang.ini
    [2008/03/25 11:10:01 | 000,000,097 | ---- | C] () -- C:\windows\System32\PICSDK.ini
    [2008/03/25 11:08:47 | 000,000,044 | ---- | C] () -- C:\windows\EPCX8400.ini
    [2007/07/05 11:24:43 | 000,006,784 | ---- | C] () -- C:\windows\System32\drivers\OSCI_DRVNT.sys
    [2006/02/27 13:40:22 | 000,002,208 | ---- | C] () -- C:\windows\System32\drivers\nxsIO32.sys
    [2005/10/20 15:28:14 | 000,000,037 | ---- | C] () -- C:\windows\cdplayer.ini
    [2005/05/20 14:37:11 | 000,049,152 | ---- | C] () -- C:\windows\System32\TVicHW32.dll
    [2005/03/24 12:05:26 | 000,000,116 | ---- | C] () -- C:\windows\NeroDigital.ini
    [2004/10/20 08:22:22 | 000,000,078 | ---- | C] () -- C:\windows\qwimp.ini
    [2004/10/11 08:50:04 | 000,001,081 | ---- | C] () -- C:\windows\QUICKEN.INI
    [2004/05/18 20:03:48 | 000,053,248 | ---- | C] () -- C:\windows\System32\zlib.dll
    [2004/05/03 08:41:06 | 000,000,061 | ---- | C] () -- C:\windows\bi_group.ini
    [2004/04/30 16:23:33 | 000,257,536 | ---- | C] () -- C:\windows\System32\biimg.dll
    [2004/04/30 16:23:33 | 000,073,728 | ---- | C] () -- C:\windows\System32\bieresnt.dll
    [2004/04/14 16:12:24 | 000,000,000 | ---- | C] () -- C:\windows\Webspace.INI
    [2004/03/25 13:57:53 | 000,001,992 | ---- | C] () -- C:\windows\wskat.ini
    [2004/03/24 15:48:35 | 000,001,793 | ---- | C] () -- C:\windows\System32\fxsperf.ini
    [2004/03/24 11:30:44 | 000,000,034 | ---- | C] () -- C:\windows\AuthMgr.INI
    [2004/03/23 14:25:20 | 000,000,738 | ---- | C] () -- C:\windows\ODBC.INI
    [2004/03/23 09:39:54 | 000,000,002 | ---- | C] () -- C:\windows\msoffice.ini
    [2004/03/16 18:16:24 | 000,000,061 | ---- | C] () -- C:\windows\smscfg.ini
    [2004/03/16 18:04:28 | 000,000,304 | ---- | C] () -- C:\windows\wininit.ini
    [2004/03/16 18:01:14 | 000,000,780 | ---- | C] () -- C:\windows\orun32.ini
    [2004/03/16 17:45:55 | 000,363,520 | ---- | C] () -- C:\windows\System32\psisdecd.dll
    [2004/03/16 17:33:52 | 000,000,550 | ---- | C] () -- C:\windows\System32\OEMINFO.INI
    [2003/08/13 21:54:00 | 000,000,000 | ---- | C] () -- C:\windows\System32\px.ini
    [2001/07/07 03:00:00 | 000,003,399 | ---- | C] () -- C:\windows\System32\hptcpmon.ini
    [2000/09/13 18:15:38 | 000,053,248 | ---- | C] () -- C:\windows\System32\pagesync.dll
    [1996/11/17 01:00:00 | 000,022,016 | ---- | C] () -- C:\windows\System32\ODBCSTF.DLL
    [1996/11/17 01:00:00 | 000,022,016 | ---- | C] () -- C:\windows\System32\DOCOBJ.DLL
    [1996/11/17 01:00:00 | 000,012,288 | ---- | C] () -- C:\windows\System32\HLINKPRX.DLL
    [1979/12/31 23:00:00 | 000,012,288 | ---- | C] () -- C:\windows\System32\e100bmsg.dll
    [2010/04/08 16:37:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Alwil Software
    [2005/07/18 15:30:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\BF8051E7-626F-4a11-AF7A-625A7B555862
    [2009/12/11 15:29:56 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\CanonBJ
    [2009/12/22 15:59:07 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\CanonIJEGV
    [2010/02/02 15:43:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\EPSON
    [2005/07/18 15:30:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
    [2005/07/27 16:04:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Bild.de Radio
    [2010/03/22 12:02:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Canon
    [2008/10/07 15:21:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
    [2009/03/11 11:59:48 | 000,000,000 | -HSD | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Earthlink
    [2009/03/05 12:53:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\EarthLink Toolbar
    [2006/03/03 09:30:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\ieSpell
    [2007/07/02 11:34:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Image Zone Express
    [2005/07/18 15:31:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Leadertech
    [2005/07/18 15:31:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\Learn2.com
    [2006/04/12 15:09:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Sven Albrecht\Application Data\PCTV4Me
    [2010/07/16 11:40:07 | 000,000,330 | -H-- | M] () -- C:\windows\Tasks\MP Scheduled Scan.job
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2010/03/25 10:48:25 | 000,000,281 | RHS- | M] () -- C:\BOOT.INI
    [2002/09/03 07:38:46 | 000,000,512 | -HS- | M] () -- C:\BOOTSECT.DOS
    [2004/08/03 23:00:00 | 000,260,272 | ---- | M] () -- C:\cmldr
    [2010/07/16 11:57:17 | 000,011,702 | ---- | M] () -- C:\ComboFix.txt
    [2002/09/03 07:59:58 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2004/03/16 17:37:10 | 000,005,848 | RH-- | M] () -- C:\DELL.SDR
    [2004/04/06 16:26:22 | 000,005,205 | -H-- | M] () -- C:\ffastun.ffa
    [2004/04/06 16:26:22 | 000,417,792 | -H-- | M] () -- C:\ffastun.ffl
    [2004/04/06 16:26:22 | 000,204,800 | -H-- | M] () -- C:\ffastun.ffo
    [2004/04/06 16:26:22 | 001,441,792 | -H-- | M] () -- C:\ffastun0.ffx
    [2002/09/03 07:59:58 | 000,000,000 | -H-- | M] () -- C:\IO.SYS
    [2004/03/16 18:06:41 | 000,000,843 | -H-- | M] () -- C:\IPH.PH
    [2002/09/03 07:59:58 | 000,000,000 | -H-- | M] () -- C:\MSDOS.SYS
    [2004/07/27 09:11:17 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2008/05/29 10:25:27 | 000,250,048 | RHS- | M] () -- C:\NTLDR
    [2004/04/29 09:02:43 | 000,000,481 | -H-- | M] () -- C:\os657885.bin
    [2010/07/16 11:36:53 | 805,306,368 | -HS- | M] () -- C:\pagefile.sys
    [2006/08/14 08:42:13 | 000,002,824 | ---- | M] () -- C:\pc-decrapifier.log
    [2004/03/16 18:08:19 | 000,000,087 | ---- | M] () -- C:\SystemInfo.ini
    < %systemroot%\system32\Spool\prtprocs\w32x86\*.dll >
    [2003/12/01 12:24:36 | 000,015,016 | ---- | M] (Black Ice Software) -- C:\WINDOWS\SYSTEM32\SPOOL\PRTPROCS\W32X86\biepront.dll
    [2008/10/08 14:00:00 | 000,027,136 | ---- | M] (CANON INC.) -- C:\WINDOWS\SYSTEM32\SPOOL\PRTPROCS\W32X86\CNMPD9D.DLL
    [2008/10/08 14:00:00 | 000,069,632 | ---- | M] (CANON INC.) -- C:\WINDOWS\SYSTEM32\SPOOL\PRTPROCS\W32X86\CNMPP9D.DLL
    [2006/04/10 14:02:32 | 000,074,240 | ---- | M] (Hewlett-Packard Corporation) -- C:\WINDOWS\SYSTEM32\SPOOL\PRTPROCS\W32X86\hpzpp054.dll
    [2007/10/20 18:21:50 | 000,278,016 | ---- | M] (Hewlett-Packard Corporation) -- C:\WINDOWS\SYSTEM32\SPOOL\PRTPROCS\W32X86\hpzpp5mu.dll
    < %systemroot%\system32\*.wt >
    < %systemroot%\system32\*.ruy >
    < %systemroot%\Fonts\*.com >
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.tmp >
    < %systemroot%\*. /mp /s >
    < %systemroot%\system32\*.dll /lockedfiles >
    [16 C:\windows\system32\*.tmp files -> C:\windows\system32\*.tmp -> ]
    < %systemroot%\Tasks\*.job /lockedfiles >
    < %systemroot%\System32\config\*.sav >
    [2002/09/03 07:47:18 | 000,094,208 | ---- | M] () -- C:\WINDOWS\SYSTEM32\CONFIG\DEFAULT.SAV
    [2002/09/03 07:47:18 | 000,602,112 | ---- | M] () -- C:\WINDOWS\SYSTEM32\CONFIG\SOFTWARE.SAV
    [2002/09/03 07:47:18 | 000,380,928 | ---- | M] () -- C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM.SAV
    < %systemroot%\system32\user32.dll /md5 >
    [2008/04/13 17:12:08 | 000,578,560 | ---- | M] (Microsoft Corporation) MD5=B26B135FF1B9F60C9388B4A7D16F600B -- C:\WINDOWS\SYSTEM32\user32.dll
    < %systemroot%\system32\ws2_32.dll /md5 >
    [2008/04/13 17:12:10 | 000,082,432 | ---- | M] (Microsoft Corporation) MD5=2CCC474EB85CEAA3E1FA1726580A3E5A -- C:\WINDOWS\SYSTEM32\ws2_32.dll
    < %systemroot%\system32\ws2help.dll /md5 >
    [2008/04/13 17:12:10 | 000,019,968 | ---- | M] (Microsoft Corporation) MD5=9789E95E1D88EEB4B922BF3EA7779C28 -- C:\WINDOWS\SYSTEM32\ws2help.dll
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < End of report >
  12. 2010/07/16
    Your computer would benefit form another 512MB of RAM.
    Update your Java version here: http://www.java.com/en/download/installed.jsp
    Uninstall all previous Java versions, through Add\Remove (Programs & Features in Vista/7).
    Run OTL
      :OTL
      O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} http://v4.windowsupdate.microsoft.co...070.5747569444  (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA} http://java.sun.com/update/1.5.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} http://wwwimages.adobe.com/www.adobe...bat/nos/gp.cab  (Reg Error: Key error.)
      O16 - DPF: {D34151C8-0C6C-4A7D-B677-4FCC9552E957} http://www.bcnx.com/SunInfoConnect_w...com_medium.cab  (Reg Error: Key error.)
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [resethosts]
      [Reboot]
    • Open OTL again and click the Quick Scan button. Post the log it produces in your next reply.
  13. 2010/07/16
    SVEN
    SVEN Well-Known Member Thread Starter
    here is the log
    All processes killed
    ========== OTL ==========
    Service catchme stopped successfully!
    Service catchme deleted successfully!
    File C:\DOCUME~1\SVENAL~1\LOCALS~1\Temp\catchme.sys not found.
    Service WINIO stopped successfully!
    Service WINIO deleted successfully!
    File C:\windows\TEMP\WinIo.sys not found.
    Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{A057A204-BACC-4D26-9990-79A187E2698E} deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}\ not found.
    Starting removal of ActiveX control {9F1C11AA-197B-4942-BA54-47A8489BB47F}
    C:\WINDOWS\Downloaded Program Files\iuctl.inf moved successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{9F1C11AA-197B-4942-BA54-47A8489BB47F}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9F1C11AA-197B-4942-BA54-47A8489BB47F}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{9F1C11AA-197B-4942-BA54-47A8489BB47F}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7}
    C:\windows\Downloaded Program Files\gp.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7}\ not found.
    Starting removal of ActiveX control {D34151C8-0C6C-4A7D-B677-4FCC9552E957}
    C:\WINDOWS\Downloaded Program Files\SunInfoConnect.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{D34151C8-0C6C-4A7D-B677-4FCC9552E957}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D34151C8-0C6C-4A7D-B677-4FCC9552E957}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D34151C8-0C6C-4A7D-B677-4FCC9552E957}\ not found.
    Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
    C:\windows\Downloaded Program Files\CONFLICT.1\gp.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Filter\application/octet-stream\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{1E66F26B-79EE-11D2-8710-00C04F79ED0D}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Filter\application/x-complus\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{1E66F26B-79EE-11D2-8710-00C04F79ED0D}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Filter\application/x-msdownload\ deleted successfully.
    C:\$AVG8.VAULT$ folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\update\prepare folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\update\download\ads folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\update\download folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\update\backup folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\update folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Temp folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\scanlogs folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Lsdb\Prev folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Lsdb folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Log folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc\Queue\TEMP folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc\Queue\OUT folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc\Queue\ACTIVE folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc\Queue folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc\Log folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\emc folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Dumps folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\CfgAll folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\Cfg folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\AvgApi folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\AvgAm folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8\admincli folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\avg8 folder moved successfully.
    C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\cqdhsggfv folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell\AOL9 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\Welcome\BH00 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\Welcome folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_03 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_02 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_01 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_00 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint folder moved successfully.
    ========== FILES ==========
    [EMPTYTEMP]
    User: Administrator
    ->Temporary Internet Files folder emptied: 67 bytes
    User: All Users
    User: Default User
    ->Temporary Internet Files folder emptied: 32768 bytes
    User: LocalService
    ->Temp folder emptied: 65536 bytes
    ->Temporary Internet Files folder emptied: 78991 bytes
    User: NetworkService
    ->Temp folder emptied: 896 bytes
    ->Temporary Internet Files folder emptied: 32835 bytes
    User: Sven Albrecht
    ->Temp folder emptied: 9252166 bytes
    ->Temporary Internet Files folder emptied: 1383600 bytes
    ->Java cache emptied: 75064200 bytes
    ->FireFox cache emptied: 4328807 bytes
    ->Flash cache emptied: 1860722 bytes
    %systemroot% .tmp files removed: 309433 bytes
    %systemroot%\System32 .tmp files removed: 2577 bytes
    Windows Temp folder emptied: 808 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 67 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 88.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Sven Albrecht
    C:\windows\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    OTL by OldTimer - Version 3.2.9.0 log created on 07162010_143012
  14. 2010/07/16
    ...and:
  15. 2010/07/16
    SVEN
    here it is
    OTL logfile created on: 7/16/2010 2:47:30 PM - Run 2
    OTL by OldTimer - Version 3.2.9.0 Folder = C:\Documents and Settings\Sven Albrecht\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    510.00 Mb Total Physical Memory | 196.00 Mb Available Physical Memory | 38.00% Memory free
    1.00 Gb Paging File | 1.00 Gb Available in Paging File | 64.00% Paging File free
    Paging file location(s): C:\pagefile.sys 768 1536 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\windows | %ProgramFiles% = C:\Program Files
    Drive C: | 111.79 Gb Total Space | 100.57 Gb Free Space | 89.96% Space Free | Partition Type: NTFS
    Drive D: | 10.42 Gb Total Space | 2.43 Gb Free Space | 23.31% Space Free | Partition Type: NTFS
    Drive E: | 64.08 Gb Total Space | 58.88 Gb Free Space | 91.89% Space Free | Partition Type: NTFS
    F: Drive not present or media not loaded
    G: Drive not present or media not loaded
    H: Drive not present or media not loaded
    I: Drive not present or media not loaded
    Drive Z: | 111.79 Gb Total Space | 100.57 Gb Free Space | 89.96% Space Free | Partition Type: NTFS
    Computer Name: INTERTRADEINC
    Current User Name: Sven Albrecht
    Logged in as Administrator.
    Current Boot Mode: Normal
    Scan Mode: Current user
    Company Name Whitelist: On
    Skip Microsoft Files: On
    File Age = 90 Days
    Output = Standard
    Quick Scan
    PRC - [2010/07/16 11:41:42 | 002,403,568 | ---- | M] (SUPERAntiSpyware.com) -- C:\Program Files\SUPERAntiSpyware\SUPERANTISPYWARE.EXE
    DRV - [2010/02/17 11:25:50 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    O1 HOSTS File: ([2010/07/16 14:31:19 | 000,000,098 | ---- | M]) - C:\WINDOWS\SYSTEM32\DRIVERS\ETC\Hosts
    O1 - Hosts: ::1 localhost
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_21-windows-i586.cab (Java Plug-in 1.6.0_21)
    O16 - DPF: {CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_21-windows-i586.cab (Java Plug-in 1.6.0_21)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_21-windows-i586.cab (Java Plug-in 1.6.0_21)
    [2010/07/16 14:31:18 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2010/07/16 14:30:12 | 000,000,000 | ---D | C] -- C:\_OTL
    [2010/07/16 14:27:29 | 000,153,376 | ---- | C] (Oracle) -- C:\windows\System32\javaws.exe
    [2010/07/16 14:27:29 | 000,145,184 | ---- | C] (Oracle) -- C:\windows\System32\javaw.exe
    [2010/07/16 14:27:29 | 000,145,184 | ---- | C] (Oracle) -- C:\windows\System32\java.exe
    [2010/04/22 12:41:27 | 000,423,656 | ---- | C] (Oracle) -- C:\windows\System32\deployJava1.dll
    [2010/07/16 14:37:27 | 000,000,330 | -H-- | M] () -- C:\windows\tasks\MP Scheduled Scan.job
    [2010/07/16 14:35:14 | 000,001,170 | ---- | M] () -- C:\windows\System32\WPA.DBL
    [2010/07/16 14:34:21 | 000,000,006 | -H-- | M] () -- C:\windows\tasks\SA.DAT
    [2010/07/16 14:34:16 | 000,002,048 | --S- | M] () -- C:\windows\BOOTSTAT.DAT
    [2010/07/16 14:34:15 | 534,827,008 | -HS- | M] () -- C:\hiberfil.sys
    [2010/07/16 14:33:25 | 009,961,472 | ---- | M] () -- C:\Documents and Settings\Sven Albrecht\NTUSER.DAT
    [2010/07/16 14:33:25 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Sven Albrecht\NTUSER.INI
    [2010/07/16 14:31:19 | 000,000,098 | ---- | M] () -- C:\windows\System32\drivers\ETC\Hosts
    [2010/06/22 04:36:38 | 000,153,376 | ---- | M] (Oracle) -- C:\windows\System32\javaws.exe
    [2010/06/22 04:36:37 | 000,145,184 | ---- | M] (Oracle) -- C:\windows\System32\javaw.exe
    [2010/06/22 04:36:36 | 000,145,184 | ---- | M] (Oracle) -- C:\windows\System32\java.exe
    [2010/06/22 04:36:29 | 000,423,656 | ---- | M] (Oracle) -- C:\windows\System32\deployJava1.dll
    [2010/06/22 02:24:28 | 000,073,728 | ---- | M] (Oracle) -- C:\windows\System32\javacpl.cpl
    [2010/07/16 14:37:27 | 000,000,330 | -H-- | M] () -- C:\windows\Tasks\MP Scheduled Scan.job
    < End of report >
  16. 2010/07/16
    Good :)
    Last scan...
    1. Download Temp File Cleaner (TFC)
    2. Go to Kaspersky website and perform an online antivirus scan.
    1. Disable your active antivirus program.
    2. Read through the requirements and privacy statement and click on Accept button.
    3. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
    4. When the downloads have finished, click on Settings.
    5. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
      [*] Archives
      [*] Mail databases
    6. Click on My Computer under Scan.
    7. Once the scan is complete, it will display the results. Click on View Scan Report.
    8. You will see a list of infected items there. Click on Save Report As....
    9. Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button. Then post it here.
  17. 2010/07/16
    SVEN
    Hi Broni,
    I just left the office and Kaspersky was running the scan. It tock forever to download the files because we have the slowest internet connection you can buy.
    When I left, it had 11% scanned and that tock 45 minutes. So the scan will go on without me all night. On Saturday morning about 9:30 AM I will be in the office and look at the result and upload the log. I know already now that we have 2 infections. I will be there for about 45 minutes. If you should be on line at that time we can try and eradicate this virus, but if not then we will have to pick this up in about 2 weeks.
    Regardless, I appreciate all the help you have given me.
    Thank you very much.
    Sven
  18. 2010/07/16
    You're very welcome :)
    By now, your computer should be pretty much clean, so no worries.
    I should be around that time tomorrow morning.
  19. 2010/07/17
    SVEN
    Hi Broni
    Here is the result from the scan:
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Saturday, July 17, 2010
    Operating system: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Friday, July 16, 2010 19:11:52
    Records in database: 4225683
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    F:\
    G:\
    H:\
    I:\
    Z:\
    Scan statistics:
    Objects scanned: 101234
    Threats found: 2
    Infected objects found: 2
    Suspicious objects found: 2
    Scan duration: 02:40:52
    File name / Threat / Threats count
    C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Identities\{8D32DF8B-D3B8-4783-A0C5-FE37E2FC8659}\Microsoft\Outlook Express\Deleted Items.bak Infected: Trojan-Spy.HTML.Paylap.tk 1
    C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Identities\{8D32DF8B-D3B8-4783-A0C5-FE37E2FC8659}\Microsoft\Outlook Express\Deleted Items.bak Suspicious: Trojan-Spy.HTML.Fraud.gen 1
    C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Identities\{8D32DF8B-D3B8-4783-A0C5-FE37E2FC8659}\Microsoft\Outlook Express\Deleted Items.dbx Infected: Trojan-Spy.HTML.Paylap.tk 1
    C:\Documents and Settings\Sven Albrecht\Local Settings\Application Data\Identities\{8D32DF8B-D3B8-4783-A0C5-FE37E2FC8659}\Microsoft\Outlook Express\Deleted Items.dbx Suspicious: Trojan-Spy.HTML.Fraud.gen 1
    Selected area has been scanned.
    Sven
  20. 2010/07/17
    Wonderful :)
    It looks like you'll have a peaceful vacation time :)
    The only bad items are listed in Outlook Express Deleted Items.bak folder.
    Empty that folder and you should be good to go.
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
    6. Download, and install WOT (Web OF Trust): Safe Browsing Tool | WOT Web of Trust. It'll warn you (in most cases) about dangerous web sites.
    8. Read How did I get infected?, With steps so it does not happen again!: How did I get infected?
  21. 2010/07/17
    SVEN
    Thanks Broni
    I found the file that is listed and i will do the cleaup and restorepoint cleanup.
    thanks for all your help.
    Sven
