Questions About Microcsoft Validation tool
Discussion in 'Windows XP' started by Milt, 2005/10/19.
  1. 2005/10/22
    Milt
    Milt Inactive Thread Starter
    Christer,
    I don't really want that in my MBR when I do the final. So If I FDISK the MBR (FDISK /MBR) I will erase the mark and probably get the nag screen everytime I use GHOST 03?
    Also, why did you assume I was using Ghost 9/10 since I said I make a 'base image'. All I meant from that is that it is the first level image to roll back to-just basic XP install.
    Milt
  2. 2005/10/22
    Christer
    Christer Geek Member Staff
    Milt,
    I would try DELPART which is better suited for NTFS partitions. Since it wipes the partition, I believe it wipes the MBR. If you use it, let me know the result.
    In Ghost 9/10 the terminology is: 'Image Set' consisting of a 'Base Image' and 'Incremental Images'.
    Christer
    Milt
    Christer,
    I thought you would catch that (using FDISK). I do video editing, and actually am running FAT32 (I know, behind the times-loose some NTFS benifits) on the OS partition for the sake of some programs I am running. I use NTFS on the VIDEO Drives.
    That naming convention in Ghost 9/10 sounds kind of nice for a set of images. Not necessary, but handy. A base image to me is always just the original after OS install.
    Milt
  5. 2005/10/25
    Christer
    Milt,
    in the context of
    I forgot to mention that System Restore is disabled, Hibernation is disabled and the Pagefile has been excluded from the respective size of the installations. hiberfil.sys and pagefile.sys would add 1.0 x RAM and 1.5 x RAM to the size of the respective installation. Since computers have different amounts of RAM, I excluded those from the comparision. The System Volume Information folder (contains System Restore Points) will be small in the beginning (?<100 MB?) but will eventually grow, depending on settings, to 12% of disk space.
    Christer
  6. 2005/10/25
    Milt
    Christer,
    I downloaded your critical updates list last night. I downloaded to a dual boot Win98/XP machine, within 98, and saved to a folder. The following occurred:
    1.) KB887472/KB816688/KB904706: Could not be found at the download center. I copied and pasted the #'s, checked several times, and they could not be found. Are they part of one of the cumulative updates in brackets? Question:
    Using your list, do you use the cumulative updates, and if so which? I did not download any.
    2.) There were several I do not think apply to me?
    1.) 885884: Pertains to Office XP-I am runningOffice 03
    2.) 899587: Pertains to users on a Domain-I am on a peer-to-peer
    with a cable modem and rounter (4-systems)
    3.) 899591: Relates to Remote Desktop. I turn this off, is there any
    reason to update?
    4.) 893756: Pertains to telephony: I am not using.
    There many be others, but for the most part, everything else appears to be general security updates.
    3.) 887742/893803/898461: Require validation. They appear to be related to the Windows installer update.
    4.) A number of the updates never went through the 'save as' dialouge screen-I just received a sort of 'boink' sound, followed by the 'thankyou for dowloaded xxxxx update" page. Is this because the download found the updates installed in the XP partition? The following were the updates: 888113,
    885258,890859,896422,893066,901214,899591,893756,012400,899589,
    905414,905749,900725
    Milt
  7. 2005/10/25
    Christer
    Milt,
    I have downloaded all those updates from either Windows Update Catalog or Microsoft Download Center. All but the last batch were downloaded from the former. I don't know why they weren't available there so I downloaded from the latter instead.
    I thought that getting the correct version of the respective update would be easier if the search was confined to 'Windows XP'. That was wrong because some updates are for Internet Explorer, Windows Messenger and other technologies. Do the search for 'All' instead and you'll get them (I hope). Make sure that you download the correct version (for Windows XP SP2).
    You should get them searching for 'All' (KB816688 should be KB896688).
    Forget about those within brackets, they are older and have been superseeded by later updates. (I should have removed them but was too lazy.)
    You should always apply the latest cumulative update (it contains all previous ones). Going by my list will accomplish that.
    Get them and install them. The fact that you aren't 'using it' now doesn't mean that you won't 'use it' in the future and by then you will have forgotten about the vulnerability and the notification has been disabled by denying the update from automatic updates. In addition to that, someone could exploit the vulnerability even if you aren't 'using it'. Well, I think so and better safe than sorry.
    The exception may be 885884, from my notes:
    There was a lot of discussions about those updates and there was a thread going on it. My notes are ...... :confused: ...... but both KB832332 and KB832332v2 are in my 'Superseeded' folder whereas KB885884 is still among those to install. I seem to remember being offered that update (kb885884) even if Office is not installed but you could try leaving it out.
    Even Description of the critical update for Office XP on Windows XP Service Pack 2 and Description of the Office XP security update: October 12, 2004 are confusing.
    Do it within XP and if it has not been validated, go ahead and do it!
    I didn't try them all but sampled a few and there were no problems.
    (The 'boink' sound could be the download prevention thingy in XP-SP2. Check for a yellow-ish bar at the top of the window and accept the download.)
    Christer
  8. 2005/10/25
    Christer
    Further investigation gave the reason for kb832332v2 being in my 'Superseeded' folder: It has been superseeded by kb873352.
    I think that kb885884 is still 'needed' but I don't know why ...... :confused: ...... since it has been installed on my system but there is nothing in the uninstall folder (which means that the update didn't update anything).
    According to Microsoft Security Bulletin MS04-028, Office 2003 is also affected and should apply kb838905 but I don't think that you will be prompted for kb885884 through automatic update. You could try skipping it.
    If you're interested, the discussion on the whole mess is in JPEG Processing (GDI+) Security Update
    Christer
  9. 2005/10/26
    Christer
    I have reviewed my list and checked for updates that are substituting previous ones and found five that can be removed:
    kb890175 substituted by kb896358
    kb890047 substituted by kb893086
    kb873333 substituted by kb902400
    kb893086 substituted by kb900725
    kb899588 substituted by kb905749
    This is the reduced list:
    040924-885884 (?)
    041015-887472
    041021-886185
    041028-885835
    041029-885836
    041103-887742
    041116-888113
    041117-873339
    041207-888302
    050111-891781
    050119-885250
    050321-890859
    050503-893803 (#1)
    050507-894391
    050510-896422
    050511-896428
    050517-890046
    050517-898461 (#2)
    050525-893066
    050527-896358
    050629-901214
    050630-896423
    050630-899587
    050630-899591
    050709-893756
    050726-902400
    050818-899589
    050822-905414
    050823-905749
    050830-904706
    050910-901017
    050928-900725
    051005-896688
    Install #1 > #2 > then in order of date, (?) may be excluded if Office XP is not installed.
    Christer
  10. 2005/11/01
    Milt
    Christer,
    I have been away since this thread was active last week. I saw your last post-thanks for all the work and updating, I will go through the revised list!
    Milt
  11. 2005/11/03
    skeet6961
    skeet6961 Inactive
    ok. sound like u've got a plan ... i still don't see what any of this has to do w/ activation tho. it will not affect any of these variables u mention.
    i should add that i've got a valid copy of xp pro that i reinstall all the time. i've been on the phone w/ ms activation so many times it's silly. i told them that at one point and, while it used to take 3x to start objecting to my 'change of hardware', it no longer does. least thru the last 10x installs.
    it seems they got tired of me as well ;)
  12. 2005/11/03
    phillracer
    phillracer Inactive
    Hi all,
    I haven't yet installed the Validation tool. But about a week ago my updates tried to run - they didn't load but after about three days it downloaded 7updates. Has this happened to anyone else?
    It seemed weird as I thought we would not be offered any updates unless we installed the validation.
  13. 2005/11/03
    skeet6961
    skeet6961 Inactive
    i'm fairly sure that u get critical updates regardless
  14. 2005/11/03
    phillracer
    phillracer Inactive
    Oh ok then. That would be good. I might install the validation tool one day.
  15. 2005/11/03
    skeet6961
    skeet6961 Inactive
    i THINK the critical updates work w/o the activation tool installed only thru 'autoupdates' ... so u can't do it manually. least that's my observation to this point. not confirmed mind u. i'm just saying that i've seen that to date.
  16. 2005/12/26
    invalid char
    invalid char Inactive
    latest CD with all updates
    so looking at this thread, everybody seems to like the idea of having a CD with all the latest updates, etc. so that it's fast/easy to do an install locally. this seems like a great idea to me too. so the obvious question is why doesnt m-soft put up an iso file with all this on it for one easy download for each major OS they support? this would seem like a no-brainer to me. each time they issue a new update, they could refresh the iso image so that it was always current. that way you could, in *one* download, always be sure of getting the latest stuff to do a new install. Think of how short this would make re-installs! W2K is now past SP4 + ie + whatever else... whew!!
    when I look at the list of what's necessary to download, it just makes me dizzy.... seems like such a hassle of downloading all these patches, etc one-by-one yourself.... and then everyone else all have to do it themselves too... what a waste of everyone's time all doing the same thing...!!
    what am i missing here? :confused:
  17. 2005/12/26
    phillracer
    phillracer Inactive
    I agree - it is a pain to have to install all the updates again. Especially on 56kb connections. Does anyone know a way of actually being able to make a clean install of XP but keep the updates that you have already downloaded?
  18. 2005/12/27
    :confused: Do you have ANY idea of the download capacity this would require???? When MS posts a new Windows Vista beta (to roughly 10-15K testers), their servers start crawling.... 30-40KB/s on my connection where I can get 250KB/s normally.
    This is obviously no solution, and would (if it would work) only be feasible for the 20-30% of users who have a broadband connection.
  19. 2005/12/27
    lj50 Lifetime Subscription
    I've only found wpa.dbl on my machine. Can't find wpa.bak. Does it matter that I don't have wpa.bak? I have a legal full OEM version of Windows XP Professional SP1. I hate using the telephone and I really do not want to hold on the line for hours with Microsoft just for an activation number. That's why I loath piracy it ruins it for everyone who purchase the products they want and need.
  20. 2005/12/27
    charlesvar
    charlesvar Inactive Alumni
    I do my updates using the Update Catalog site accessable thu the Admin options on the update site (left panel).
    I download the update setup files themselves, manually install them, then archive them.
    This is a bit of extra work - have to have AU scan, then jot down the KB #'s, but as you point out, great to have the updates handy on installs.
    Regards - Charles
  21. 2005/12/27
    invalid char
    all updates in one iso file
    Quote:
    "Do you have ANY idea of the download capacity this would require???? When MS posts a new Windows Vista beta (to roughly 10-15K testers), their servers start crawling.... 30-40KB/s on my connection where I can get 250KB/s normally.
    This is obviously no solution, and would (if it would work) only be feasible for the 20-30% of users who have a broadband connection. "
    Humm - You're in the know, but I guess I don't see why this would be so. The total bytes are the same... it's just a question of downloading endless updates one at a time, or one big file. When I have to reinstall win2k i start from my distribution disk and go through a long manual process to end up with the current rev. All i am suggesting is that m-soft make it less painful and have one click to do the sum total of all applicable downloads as one iso file. Again, no more/less bytes.... just less pain.
    Also, I have to assume that the big boys are using T3/OC3-12 connections to big iron routers and farms of servers, so I don't quite understand how this variation on the existing theme would bring the system to its knees... It's not like a new rev where everyone is d-loading at the same time.. this would be random and again, would simply replace the existing file-by-file method. Please correct me if I have the facts wrong.
