Problems with pc due to a strange program
Discussion in 'Other PC Software' started by Kayz, 2003/04/09.
  1. 2003/04/11
    BruceKrymow
    BruceKrymow Inactive
    Hi, Kayz ~
    You have yet another trojan or virus. :(
    I am a little pi55ed right now as I addressed this issue w/ a lengthy post last night addressing this issue. I see I may have scr3wed up :eek: due to the 60 second rule and it did not make it, but I will repost it later, OK?
  2. 2003/04/11
    BruceKrymow
    Hi, Kayz ~
    OK, here's the scoop - what you have is known as JS_TRAFFICHBAR.A trojan or Trojan.WinREG.STW variant that is a parasitic program that spys on you & sends ads. This is often through b.s. programs like TinyBar, ZeroPopup and a few others, but they all hijack your browser to the stupid znext.com, spy and eat up bandwidth by sending your browsing habits back to homebase. :eek:
    Here are a few pages for info and manual removal:Click here to test for the parasite and then click on 'ZeroPopup' and 'TinyBar' on the lower left-hand bottom of the page for further good info.
    The best documented automatic hijack remover for this particular pest can be removed with HijackThis. Read the directions under the Hijack Removal heading.
    Kayz
    Kayz Inactive Thread Starter
    Ok Ive done all the scanning with SPybot, Ad-Aware, and NAV and the ones you all have given me over I dont know how many times now. The only one I didnt try was the HijackThis one. I dont know what exactly to look for but I also question Ive looked for all the required things of the tool bar mentioned in each tutorial and chose the max setting in Ad-Aware yet from
    http://www.anti-trojan.net/at.asp?l=en&t=onlinecheck I keep gettin a 1033 NetSpy Trojan So I dont know if its still the same spyware but I have 1 type of spyware on here none the less. I'm starting to get ****** here and I will send a list of what came up on the HijackThis list in the morning Im tired and agitated now by this stuff so I deeply thank you Mike and Bruce for helping me and sorry to you both for putting you through much trouble if any.
  5. 2003/04/12
    mflynn
    mflynn Inactive
    Ok Kayz
    First stop running the other steps we gave over and over as this is a waste of time. Twice thru is enough!
    It is time we have more info on what is starting up so download STARTUP LIST.
    <http://www.spywareinfo.com/~merijn/files/startuplist.zip>
    StartupList does nothing but grab all Autoload (startups) and puts them in a Wordpad file so that you can then copy it and paste it back to us in a message so that we can advise on a problem here. So get this to us!
    NOW confirm this to us. You have 2 issues now (1) the znext search problem and (2) the 1033 netspy. Is this correct?
    First let me mention that is is very easy to get a false positve on a trojan.
    So let us get it out of the way first. Down load the below then install, then immediately do the online update(it is a 30 day free trial).
    The Cleaner 3.5
    http://www.moosoft.com/thecleaner/download.php
    So post the Startup list back to us, then run The Cleaner and get back after that with the results.
    A Trojan or worm is more of a priority than the ZNEXT thing since it appears to be only a nuisance. So after handleing the the 1033 netspy we will get back to that.
    Again do not waste your time running these things over and over do the above and get back to us.
    Mike
  6. 2003/04/12
    Kayz
    Well the Pop-up of Znext has stopped and the registry files and other extensions that were given to me have all been taken out. This is the results from the list-
    StartupList report, 4/12/03, 10:37:50 AM
    StartupList version: 1.52
    Started from : C:\WINDOWS\DESKTOP\STARTUPLIST.EXE
    Detected: Windows 98 SE (Win9x 4.10.2222A)
    Detected: Internet Explorer v6.00 (6.00.2600.0000)
    * Using default options
    C:\WINDOWS\SYSTEM\KERNEL32.DLL
    C:\WINDOWS\SYSTEM\MSGSRV32.EXE
    C:\WINDOWS\SYSTEM\MPREXE.EXE
    C:\WINDOWS\SYSTEM\mmtask.tsk
    C:\WINDOWS\SYSTEM\MSTASK.EXE
    C:\WINDOWS\EXPLORER.EXE
    C:\WINDOWS\TASKMON.EXE
    C:\WINDOWS\SYSTEM\SYSTRAY.EXE
    C:\PROGRAM FILES\MICROSOFT HARDWARE\KEYBOARD\TYPE32.EXE
    C:\WINDOWS\LOADQM.EXE
    C:\PROGRAM FILES\MICROSOFT HARDWARE\MOUSE\POINT32.EXE
    C:\PROGRAM FILES\NORTON ANTIVIRUS\NAVAPW32.EXE
    C:\PROGRAM FILES\MSN MESSENGER\MSNMSGR.EXE
    C:\PROGRAM FILES\WEBSHOTS\WEBSHOTSTRAY.EXE
    C:\WINDOWS\SYSTEM\WMIEXE.EXE
    C:\WINDOWS\SYSTEM\DDHELP.EXE
    Listing of startup folders:
    Shell folders Startup:
    [C:\WINDOWS\Start Menu\Programs\StartUp]
    Webshots.lnk = C:\Program Files\Webshots\WebshotsTray.exe
    Autorun entries from Registry:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Run
    ScanRegistry = C:\WINDOWS\scanregw.exe /autorun
    TaskMonitor = C:\WINDOWS\taskmon.exe
    SystemTray = SysTray.Exe
    LoadPowerProfile = Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
    IntelliType = "C:\Program Files\Microsoft Hardware\Keyboard\type32.exe "
    LoadQM = loadqm.exe
    QuickTime Task = "C:\WINDOWS\SYSTEM\QTTASK.EXE" -atboottime
    POINTER = point32.exe
    NAV Agent = C:\PROGRA~1\NORTON~1\NAVAPW32.EXE
    DeadAIM = rundll32.exe C:\PROGRA~1\AIM95\DeadAIM.ocm,ExportedCheckODLs
    fsvyuwg = "C:\WINDOWS\SYSTEM\FSVYUWG.exe "
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices
    SchedulingAgent = mstask.exe
    ScriptBlocking = "C:\Program Files\Common Files\Symantec Shared\Script Blocking\SBServ.exe" -reg
    HKCU\Software\Microsoft\Windows\CurrentVersion\Run
    msnmsgr = "C:\PROGRAM FILES\MSN MESSENGER\MSNMSGR.EXE" /background
    McAfee.InstantUpdate.Monitor = "C:\Program Files\McAfee\McAfee Shared Components\Instant Updater\RuLaunch.exe" /startmonitor
    Load/Run keys from C:\WINDOWS\WIN.INI:
    load=
    run=hpfsched
    C:\WINDOWS\WININIT.BAK listing:
    (Created 10/4/2003, 23:52:46)
    [Rename]
    NUL=c:\windows\system\ieacce~1.dll
    Enumerating Browser Helper Objects:
    NAV Helper - C:\Program Files\Norton AntiVirus\NavShExt.dll - {BDF3E430-B101-42AD-A544-FADC6B084872}
    Enumerating Task Scheduler jobs:
    Tune-up Application Start.job
    Symantec NetDetect.job
    Norton AntiVirus - Scan my computer.job
    Enumerating Download Program Files:
    [Shockwave Flash Object]
    InProcServer32 = C:\WINDOWS\SYSTEM\MACROMED\FLASH\FLASH.OCX
    CODEBASE = http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    [QuickTime Object]
    InProcServer32 = C:\WINDOWS\SYSTEM\QTPLUGIN.OCX
    CODEBASE = http://www.apple.com/qtactivex/qtplugin.cab
    [Shockwave ActiveX Control]
    InProcServer32 = C:\WINDOWS\SYSTEM\MACROMED\DIRECTOR\SWDIR.DLL
    CODEBASE = http://download.macromedia.com/pub/shockwave/cabs/director/swdir.cab
    [Update Class]
    InProcServer32 = C:\WINDOWS\SYSTEM\IUCTL.DLL
    CODEBASE = http://v4.windowsupdate.microsoft.com/CAB/x86/ansi/iuctl.CAB?37603.718912037
    [{4E888414-DB8F-11D1-9CD9-00C04F98436A}]
    CODEBASE = https://webresponse.one.microsoft.com/oas/ActiveX/winrep.cab
    [HouseCall Control]
    InProcServer32 = C:\WINDOWS\DOWNLO~1\XSCAN53.OCX
    CODEBASE = http://a840.g.akamai.net/7/840/537/2003031901/housecall.antivirus.com/housecall/xscan53.cab
    [Live365Player Class]
    InProcServer32 = C:\WINDOWS\DOWNLOADED PROGRAM FILES\PLAY365.DLL
    CODEBASE = http://www.live365.com/players/play365.cab
    [Symantec RuFSI Registry Information Class]
    InProcServer32 = C:\WINDOWS\DOWNLOADED PROGRAM FILES\RUFSI.DLL
    CODEBASE = http://security.symantec.com/SSC/SharedContent/common/bin/cabsa.cab
    [PWLNINST Control]
    InProcServer32 = C:\WINDOWS\PWLN\PWLNINST.OCX
    CODEBASE = http://www.plato.com/pwln/02000050/cab/pwlninst.cab
    [AvxScanOnline Control]
    InProcServer32 = C:\WINDOWS\DOWNLO~1\BITDEF~1.OCX
    CODEBASE = http://www.bitdefender.com/scan/Msie/bitdefender.cab
    Enumerating ShellServiceObjectDelayLoad items:
    WebCheck: C:\WINDOWS\SYSTEM\WEBCHECK.DLL
    End of report, 5,666 bytes
    Report generated in 1.255 seconds
    Command line options:
    /verbose - to add additional info on each section
    /complete - to include empty sections and unsuspicious data
    /full - to include several rarely-important sections
    /force9x - to include Win9x-only startups even if running on WinNT
    /forcent - to include WinNT-only startups even if running on Win9x
    /forceall - to include all Win9x and WinNT startups, regardless of platform
    /history - to list version history only
  7. 2003/04/12
    Kayz
    ok (sorry for double posting) I ran The Cleaner updated it and then checked to see if the Net Spy was still around and its not showing up now. Thanks again Mike I hope Im not putting you through any trouble through this.
  8. 2003/04/12
    mflynn
    mflynn Inactive
    Ok!
    Good to hear that the ZNEXT is finally gone.
    So what about the 1033 NetSpy Trojan. This could be much more troubling than ZNEXT.
    Did you download and run The Cleaner to check for the 1033 NetSpy Trojan?
    If not that is the "NEXT BIG THING ".
    The above needs done ASAP, the below is for later.
    Now just for your info.
    Do you actually use MSM messenger (the reason I ask is that it gets installed automatically sometimes). If you use it OK, if not it is an unnessesary resource user.
    I noticed that you have DeadAim that stops ads from AOL instant messenger, but I saw no indication that you use AIM.
    I would not have webshots on my computer for pay!
    The references to taskmon and hpfsched are unnessesary and slow your computer down.
    AFTER you handle this netspy let me know what you wish to do here and i will help you clean these up.
    Mike
  9. 2003/04/12
    Kayz
    Yes I do use MSN Messenger and I used Dead Aim last night. Webshots is on there because the actual owner of the computer thought it would be nice to have on here so they decided to put it up on the computer : \. As for the two files that slows down my computer Ill stop them from running. Again thank you. The Trojan didnt show up in the scan so its gone and Im in the clear now. Thank you.
  10. 2003/04/12
    BruceKrymow
    Please elaborate.
  11. 2003/04/12
    mflynn
    mflynn Inactive
    I admin 62 networks ( over 1000 W/S) in 6 states, a year ago I had a seires of lockups and Viri hits at 2 different locations. The Viri hits seemed to come from the Webshot computers out of 35 w/s at this 1 location, only the WebShot computers had the Viri.
    After removal which their uninstall does not complete, it takes manual registry cleaning to completely remove. Another thing I detest (not doing a proper uninstall)!
    Additionally after removal all the users commented that their computers were noticeably faster. I noticed it also.
    Then later I had 2 more different networks have a similar hits all on the computers that had webshots, and after cleaning I mandated no more webshots.
    Then a month or 2 later after that, a couple of users from the first group above got more Viri when they reinstalled WebShots.
    At least 2 different Virus scanners were in effect at different stations, Norton and ETrust Anti Viruus (Inoculatit). It would clean most Viri but they would show up again the next day or after a reboot!
    Additionally only a short time ago it came bundled with GATOR, not any longer but they have that mentality.
    http://info-center.ccit.arizona.edu/~ccitinfo/newsletters/march2002/problems_with_webshots.html
    In short degrades performance, keeps the door ajar! Just trips my 2 triggers, performance and security!
    Mike
  12. 2003/04/12
    mflynn
    mflynn Inactive
    OK Kayz
    I will close this case! Smile!
    Good luck.
    To remove Taskmon you should boot to safe mode. Search for taskmon.exe and delete it.
    Then browse to c:\windows\ and delete the entire Applog folder.
    To remove the hpfsched go to
    start-run
    type sysedit
    click win.ini
    delete the line that says run=hpfsched
    Mike
    PS I just noticed this
    Do you have both Norton and McAfee?????????????
    Bye
    Mike
  13. 2003/04/12
    BruceKrymow
    Hi, Mike ~
    I thought Kayz said they just installed Norman, too, so is that 3 now??? I don't see it in the report.
    I would recommend killing off the Quicktime - NO reason for that to run at start up - Tune up application, and dump some of the ActiveX controls.
    Regarding Webshots, I see your point. I am a Webshots user, but then I know how to use progz like that in such a fashion w/o installing third-party wares, not at start-up, not enabling open connections and w/o using any resources.
  14. 2003/04/12
    AAPlus
    AAPlus Inactive
    Hello,Kayz
    If you like have a try at this
    download 'Hijack This!'.
    Unzip, doubleclick HijackThis.exe, and hit "Scan ".
    When the scan is finished, the "Scan" button will change into a "Save Log" button.
    Press that, save the log somewhere, and please show us its contents.
    Good luck
  15. 2003/04/12
    mflynn
    mflynn Inactive
    Yes Kayz
    Relax the pressure is off, seems everything is fixed, the rest we are telling you about are only to improve the system performance and stability.
    Bruce pointed out the qtask, I saw it but forgot to list it. Totally useless, worse a slowdown so get rid if it also.
    And if you had McAfee in the past part of it is still loading. Whats up?
    Mike
  16. 2003/04/13
    Kayz
    Only thing I have from McAffee was this Internet Security program by them and I downloaded it into my computer but I took it off. I dont know why its still hanging around in my system but Ill go ahead and take it off since I dont run McAffee. I think I just forgot to do a complete uninstall I guess I dont remember all I know is that I dont like using McAffee for anything since it was slowing my computer down extremely. But anyways thank you for suggesting those things to me and taking your time get me the info and to make my computer Trojan free. Thank you I wish I could repay the favor.
  17. 2003/04/13
    mflynn
    mflynn Inactive
    Your thanks is my pay!
    Mike
  18. 2003/04/13
    Kayz
    Jesus ok I got something in my Internet Temp. Files that is called a x0r.exe and a warning came up saying the file carried something called Backdoor something I wasnt able to see it for I was typing an address trying to get away from the site since it wasnt really giving me results and I hit enter on 'ignore the problem ' on TC active or Monitor one of the two, so I did all the programs and it hasnt gotten rid of it. I scanned and again I have a 1033 Net Spy
  19. 2003/04/13
    BruceKrymow
    Hi, Kayz ~
    Is 'TC active or Monitor' part of Norman or Norton or McAfee?
    Why did you hit enter on 'ignore the problem ' ? You have the 'Backdoor' trojan. You should let your anti-virus quarantine, clean and/or remove it.
  20. 2003/04/13
    mflynn
    mflynn Inactive
    That is the resident portion of The Cleaner 3.5 that I had her install after she found the netspy.
    Appearently it is doing it's job. I in fact forgot about the resident portion because I do not install that part.
    Bruce and Kayz I am headed out to Dinner so I will be out for an hour or so.
    If you don't get it by then I will try.
    Mike
  21. 2003/04/13
    Kayz
    Umm Im a guy first off , for Bruce I was typing the address quickly without looking up at the moment and accidently hit enter but it was to late and my system lagged when it read that problem and then the window closed.
    As for my name I got it from Kamikaze and I just took the Kaze part by spelling it Kayz.
