Solved Problems when booting up [Rootkit]
Discussion in 'Malware and Virus Removal Archive' started by Caveman, 2011/02/06.
  1. 2011/02/13
    Caveman
    Caveman Inactive Thread Starter
    I uninstalled the program 'Virgin Media Wireless Manager' and let Windows configure my wireless network before I read your post. It works! I can only assume that the program itself had somehow become corrupted. I will re-install it later if necessary. I have re-run both commands and will post the logs below. I am still having problems with the computer freezing on reboot though, but something I noticed yesterday was that a game disc was left in the tray and it rebooted quite easily. Without it, or with the Windows CD, I'm having problems. I have also re-installed Avast Anti-Virus now.
    Anyway, here are the logs...
    Pinging google.com [74.125.230.113] with 32 bytes of data:
    Reply from 74.125.230.113: bytes=32 time=19ms TTL=53
    Reply from 74.125.230.113: bytes=32 time=24ms TTL=53
    Reply from 74.125.230.113: bytes=32 time=35ms TTL=53
    Ping statistics for 74.125.230.113:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 19ms, Maximum = 35ms, Average = 24ms
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : irongiant
    Node Type . . . . . . . . . . . . : Unknown
    Ethernet adapter Local Area Connection 2:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter
    Physical Address. . . . . . . . . : 00-19-DB-29-81-97
    Ethernet adapter Wireless Network Connection 2:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek RTL8187B Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter
    Physical Address. . . . . . . . . : 00-11-3B-17-C5-D7
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.1.3
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCP Server . . . . . . . . . . . : 192.168.1.1
    DNS Servers . . . . . . . . . . . : 192.168.1.1
    Lease Obtained. . . . . . . . . . : 13 February 2011 10:10:52
    Lease Expires . . . . . . . . . . : 14 February 2011 10:10:52
  2. 2011/02/13
    Caveman
    Another thought, could the rebooting problems, given that the date in CMOS resets to 01/01/2006, be related to the CMOS battery?
    I'm glad to see your connection back :)
    As for rebooting...let's finish cleaning process and we'll go from there.
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Click the Scan All Users checkbox.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  5. 2011/02/13
    Caveman
    OTL Log in 2 parts as it is too long....
    OTL logfile created on: 13/02/2011 19:17:49 - Run 1
    OTL by OldTimer - Version 3.2.20.6 Folder = C:\Documents and Settings\Stuart Brodie\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
    1,022.00 Mb Total Physical Memory | 491.00 Mb Available Physical Memory | 48.00% Memory free
    2.00 Gb Paging File | 2.00 Gb Available in Paging File | 77.00% Paging File free
    Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 232.88 Gb Total Space | 82.86 Gb Free Space | 35.58% Space Free | Partition Type: NTFS
    Drive D: | 76.69 Gb Total Space | 19.97 Gb Free Space | 26.04% Space Free | Partition Type: NTFS
    Drive E: | 542.30 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
    Computer Name: IRONGIANT | User Name: Stuart Brodie | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2011/02/13 19:16:21 | 000,602,624 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Stuart Brodie\Desktop\OTL.exe
    PRC - [2011/01/13 08:47:34 | 003,396,624 | ---- | M] (AVAST Software) -- C:\Program Files\Alwil Software\Avast5\AvastUI.exe
    PRC - [2011/01/13 08:47:33 | 000,040,384 | ---- | M] (AVAST Software) -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
    PRC - [2010/12/22 16:41:38 | 000,274,608 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Real\RealPlayer\Update\realsched.exe
    PRC - [2010/10/03 22:43:16 | 001,266,920 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\RapportService.exe
    PRC - [2010/10/03 22:43:16 | 000,767,208 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe
    PRC - [2010/08/05 07:46:02 | 000,583,640 | ---- | M] (PC Tools) -- C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe
    PRC - [2010/04/16 18:36:42 | 000,026,480 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Live\Contacts\wlcomm.exe
    PRC - [2009/09/23 13:38:18 | 000,935,208 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe
    PRC - [2009/06/23 17:40:12 | 000,127,352 | ---- | M] (CinemaNow, Inc.) -- C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemaNowSvc.exe
    PRC - [2008/05/02 01:44:08 | 000,805,392 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Logitech\SetPoint\SetPoint.exe
    PRC - [2008/05/02 01:40:56 | 000,076,304 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.exe
    PRC - [2008/04/14 00:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2007/06/28 13:09:36 | 000,794,624 | ---- | M] (Realtek Semiconductor Corp.) -- C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe
    PRC - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MsMpEng.exe
    PRC - [2005/02/16 06:15:20 | 000,081,920 | ---- | M] (InstallShield Software Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    MOD - [2011/02/13 19:16:21 | 000,602,624 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Stuart Brodie\Desktop\OTL.exe
    MOD - [2011/01/13 08:47:35 | 000,189,728 | ---- | M] (AVAST Software) -- C:\Program Files\Alwil Software\Avast5\snxhk.dll
    MOD - [2010/12/22 16:44:31 | 000,040,448 | ---- | M] (RealNetworks, Inc.) -- C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\Chrome\Hook\rpchromebrowserrecordhelper.dll
    MOD - [2010/10/03 22:43:42 | 000,431,336 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\rooksbas.dll
    MOD - [2010/08/23 16:12:02 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
    MOD - [2009/07/12 01:12:06 | 000,632,656 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\msvcr80.dll
    MOD - [2009/07/12 00:02:02 | 000,653,120 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\msvcr90.dll
    MOD - [2009/07/12 00:02:00 | 000,569,664 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\msvcp90.dll
    MOD - [2008/05/02 01:42:50 | 000,045,584 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Logitech\SetPoint\lgscroll.dll
    SRV - File not found [Auto | Stopped] -- -- (rpcapd) Remote Packet Capture Protocol v.0 (experimental)
    SRV - File not found [On_Demand | Stopped] -- -- (AppMgmt)
    SRV - [2011/01/13 08:47:33 | 000,040,384 | ---- | M] (AVAST Software) [Auto | Running] -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe -- (avast! Antivirus)
    SRV - [2010/10/03 22:43:16 | 000,767,208 | ---- | M] (Trusteer Ltd.) [Auto | Running] -- C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe -- (RapportMgmtService)
    SRV - [2010/08/05 07:46:02 | 000,583,640 | ---- | M] (PC Tools) [Auto | Running] -- C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe -- (PCToolsSSDMonitorSvc)
    SRV - [2010/03/18 12:16:28 | 000,753,504 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe -- (WPFFontCache_v0400)
    SRV - [2010/03/18 12:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
    SRV - [2009/09/24 10:59:26 | 001,695,368 | ---- | M] (NanJing Nagasoft Co, LTD.) [Auto | Stopped] -- C:\WINDOWS\system32\nagasoft\vjocx.dll -- (vvdsvc)
    SRV - [2009/09/23 13:38:18 | 000,935,208 | ---- | M] (Nero AG) [Auto | Running] -- C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe -- (Nero BackItUp Scheduler 4.0)
    SRV - [2009/06/23 17:40:12 | 000,127,352 | ---- | M] (CinemaNow, Inc.) [Auto | Running] -- C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemaNowSvc.exe -- (CinemaNow Service)
    SRV - [2008/05/02 01:42:06 | 000,121,360 | ---- | M] (Logitech, Inc.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe -- (LBTServ)
    SRV - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MsMpEng.exe -- (WinDefend)
    DRV - File not found [Kernel | On_Demand | Running] -- -- (AFGSp50)
    DRV - [2011/01/13 08:41:16 | 000,294,608 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswSP.sys -- (aswSP)
    DRV - [2011/01/13 08:40:16 | 000,047,440 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswTdi.sys -- (aswTdi)
    DRV - [2011/01/13 08:40:04 | 000,100,176 | ---- | M] (AVAST Software) [File_System | Auto | Running] -- C:\WINDOWS\System32\drivers\aswmon2.sys -- (aswMon2)
    DRV - [2011/01/13 08:37:30 | 000,023,632 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswRdr.sys -- (aswRdr)
    DRV - [2011/01/13 08:37:11 | 000,029,392 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aavmker4.sys -- (Aavmker4)
    DRV - [2011/01/13 08:37:09 | 000,017,744 | ---- | M] (AVAST Software) [File_System | Auto | Running] -- C:\WINDOWS\System32\drivers\aswFsBlk.sys -- (aswFsBlk)
    DRV - [2011/01/08 03:27:00 | 009,888,672 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
    DRV - [2010/12/27 14:47:56 | 000,012,928 | ---- | M] (Trusteer Ltd.) [Kernel | On_Demand | Running] -- C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportMS\21923\RapportIaso.sys -- (RapportIaso)
    DRV - [2010/12/03 19:07:23 | 000,137,544 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\PnkBstrK.sys -- (PnkBstrK)
    DRV - [2010/10/03 22:54:04 | 000,034,792 | ---- | M] (Trusteer Ltd.) [Kernel | System | Running] -- C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\19917\RapportCerberus_19917.sys -- (RapportCerberus_19917)
    DRV - [2010/10/03 22:43:44 | 000,169,320 | ---- | M] (Trusteer Ltd.) [Kernel | System | Running] -- C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys -- (RapportPG)
    DRV - [2010/10/03 22:43:44 | 000,059,240 | ---- | M] (Trusteer Ltd.) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\RapportKELL.sys -- (RapportKELL)
    DRV - [2010/04/12 08:44:34 | 000,059,388 | ---- | M] (PowerISO Computing, Inc.) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\scdemu.sys -- (SCDEmu)
    DRV - [2010/03/31 05:58:48 | 000,342,784 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RTL8187B.sys -- (RTL8187B)
    DRV - [2010/03/20 20:27:08 | 000,691,696 | ---- | M] () [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\sptd.sys -- (sptd)
    DRV - [2008/10/09 15:42:42 | 000,017,408 | ---- | M] (Windows (R) Codename Longhorn DDK provider) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\KMWDFILTER.sys -- (KMWDFILTER)
    DRV - [2008/02/29 02:13:24 | 000,036,880 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LMouFilt.Sys -- (LMouFilt)
    DRV - [2008/02/29 02:13:16 | 000,035,344 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LHidFilt.Sys -- (LHidFilt)
    DRV - [2007/07/10 01:56:00 | 004,449,280 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
    DRV - [2007/06/01 14:28:38 | 000,095,488 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Rtnicxp.sys -- (RTL8023xp)
    DRV - [2006/10/18 09:39:58 | 000,017,920 | ---- | M] (VIA Technologies,Inc) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\xfilt.sys -- (xfilt)
    DRV - [2006/10/17 12:22:26 | 000,009,216 | ---- | M] (VIA Technologies, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\videX32.sys -- (videX32)
    DRV - [2005/02/02 09:33:18 | 000,026,752 | ---- | M] (IC Plus Corp. ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ipfnd51.sys -- (ip100xp)
    DRV - [2005/01/07 17:07:18 | 000,138,752 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Hdaudbus.sys -- (HDAudBus)
    DRV - [2004/08/04 05:31:32 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\rtl8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-1935655697-117609710-725345543-1004\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.msn.co.uk/
    IE - HKU\S-1-5-21-1935655697-117609710-725345543-1004\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..extensions.enabledItems: {AB2CE124-6272-4b12-94A9-7303C7397BD1}:4.2.0.5198
    FF - prefs.js..extensions.enabledItems: textlinks@playsushi.com:1.2.1
    FF - prefs.js..extensions.enabledItems: engine@conduit.com:3.2.5.2
    FF - prefs.js..extensions.enabledItems: {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}:3.2.5.2
    FF - prefs.js..extensions.enabledItems: {ABDE892B-13A8-4d1b-88E6-365A6E755758}:14.0.1
    FF - HKLM\software\mozilla\Firefox\Extensions\\{ABDE892B-13A8-4d1b-88E6-365A6E755758}: C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\Firefox\Ext [2010/12/22 16:44:39 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2011/01/11 12:39:55 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2011/01/11 12:39:54 | 000,000,000 | ---D | M]
    [2010/02/07 16:28:16 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Extensions
    [2011/01/01 14:52:45 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions
    [2010/05/07 10:41:48 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
    [2010/12/11 08:30:38 | 000,000,000 | ---D | M] (uTorrentBar Community Toolbar) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions\{bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}
    [2010/12/11 08:30:39 | 000,000,000 | ---D | M] (Conduit Engine) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions\engine@conduit.com
    [2010/02/21 11:36:56 | 000,000,000 | ---D | M] (TVU Web Player) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions\firefox@tvunetworks.com
    [2010/09/16 17:12:47 | 000,000,000 | ---D | M] (PlaySushi TextLinks) -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\extensions\textlinks@playsushi.com
    [2010/05/26 14:18:50 | 000,002,333 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Mozilla\Firefox\Profiles\zigbgyy8.default\searchplugins\askcom.xml
    [2011/01/01 14:52:45 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
    [2010/06/03 10:44:08 | 000,000,000 | ---D | M] (Skype extension for Firefox) -- C:\Program Files\Mozilla Firefox\extensions\{AB2CE124-6272-4b12-94A9-7303C7397BD1}
    [2002/03/15 12:53:24 | 000,679,936 | ---- | M] () -- C:\Program Files\Mozilla Firefox\plugins\NPSWF32.dll
    O1 HOSTS File: ([2011/02/12 17:17:19 | 000,000,736 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll (RealPlayer)
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - No CLSID value found.
    O2 - BHO: (Skype add-on for Internet Explorer) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O4 - HKLM..\Run: [avast5] C:\Program Files\Alwil Software\Avast5\avastUI.exe (AVAST Software)
    O4 - HKLM..\Run: [ISUSPM Startup] C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (InstallShield Software Corporation)
    O4 - HKLM..\Run: [Kernel and Hardware Abstraction Layer] C:\WINDOWS\KHALMNPR.Exe (Logitech, Inc.)
    O4 - HKLM..\Run: [Name of App] C:\Program Files\SAMSUNG\FW LiveUpdate\FWManager.exe ( )
    O4 - HKLM..\Run: [NvCplDaemon] C:\WINDOWS\System32\NvCpl.dll (NVIDIA Corporation)
    O4 - HKLM..\Run: [NvMediaCenter] C:\WINDOWS\System32\NvMcTray.dll (NVIDIA Corporation)
    O4 - HKLM..\Run: [nwiz] C:\Program Files\NVIDIA Corporation\nView\nwiz.exe ()
    O4 - HKLM..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE (PowerISO Computing, Inc.)
    O4 - HKLM..\Run: [TkBellExe] C:\program files\real\realplayer\update\realsched.exe (RealNetworks, Inc.)
    O4 - HKU\S-1-5-21-1935655697-117609710-725345543-1004..\Run: [igndlm.exe] C:\Program Files\Download Manager\DLM.exe (IGN Entertainment)
    O4 - HKU\S-1-5-21-1935655697-117609710-725345543-1004..\RunOnce: [FlashPlayerUpdate] C:\WINDOWS\System32\Macromed\Flash\FlashUtil10l_ActiveX.exe (Adobe Systems, Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe (Logitech, Inc.)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Micronet SP907GK Wireless Network Utility.lnk = C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe (Realtek Semiconductor Corp.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
    O7 - HKU\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-18\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-19\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\S-1-5-20\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\S-1-5-21-1935655697-117609710-725345543-1004\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-1935655697-117609710-725345543-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-21-1935655697-117609710-725345543-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-21-1935655697-117609710-725345543-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra Button: Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O9 - Extra 'Tools' menuitem : Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\WINDOWS\system32\nwprovau.dll (Microsoft Corporation)
    O16 - DPF: {0067DBFC-A752-458C-AE6E-B9C7E63D4824} http://www.logitech.com/devicedetector/plugins/LogitechDeviceDetection32.cab (Device Detection)
    O16 - DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} http://download.microsoft.com/download/C/B/F/CBF23A2C-3E55-4664-BC5C-762780D79BA0/OGAControl.cab (Office Genuine Advantage Validation Tool)
    O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab (Shockwave ActiveX Control)
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} http://download.microsoft.com/downl...-48D9-9B0E-1719D1177202/LegitCheckControl.cab (Windows Genuine Advantage Validation Tool)
    O16 - DPF: {1E3F1348-4370-4BBE-A67A-CC7ED824CA85} http://download.microsoft.com/downl...75-4d5b-a6dd-9c4bc923683e/Selfhelpcontrol.cab (Microsoft Genuine Advantage Self Support Tool)
    O16 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} http://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab (System Requirements Lab Class)
    O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} http://www.fileplanet.com/fpdlmgr/cabs/FPDC_2.3.10.115.cab (CDownloadCtrl Object)
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1265459512921 (WUWebControl Class)
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1265463721312 (MUWebControl Class)
    O16 - DPF: {74DBCB52-F298-4110-951D-AD2FF67BC8AB} http://www.nvidia.com/content/DriverDownload/nforce/NvidiaSmartScan.cab (NVIDIA Smart Scan)
    O16 - DPF: {809A6301-7B40-4436-A02C-87B8D3D7D9E3} http://zone.msn.com/bingame/zpagames/zpa_dmno.cab55579.cab (ZPA_DMNO Object)
    O16 - DPF: {80B626D6-BC34-4BCF-B5A1-7149E4FD9CFA} http://zone.msn.com/bingame/zpagames/GAME_UNO1.cab60096.cab (UnoCtrl Class)
    O16 - DPF: {8C279F4E-917E-4CD2-8DF0-D9C73C0CE763} http://zone.msn.com/bingame/zpagames/zpa_wof.cab55579.cab (ZPA_WheelOfFortune Object)
    O16 - DPF: {95B5D20C-BD31-4489-8ABF-F8C8BE748463} http://zone.msn.com/bingame/zpagames/zpa_hrtz.cab99160.cab (MSN Games – Hearts)
    O16 - DPF: {9BDF4724-10AA-43D5-BD15-AEA0D2287303} http://zone.msn.com/bingame/zpagames/zpa_txhe.cab79352.cab (MSN Games – Texas Holdem Poker)
    O16 - DPF: {A4110378-789B-455F-AE86-3A1BFC402853} http://zone.msn.com/bingame/zpagames/zpa_shvl.cab55579.cab (ZPA_SHVL Object)
    O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} http://cdn2.zone.msn.com/binFramework/v10/ZPAFramework.cab102118.cab (MSN Games - Installer)
    O16 - DPF: {D4003189-95B1-4A2F-9A87-F2B03665960D} http://www.vexcast.com/download/vexcast.cab (VodClient Control Class)
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
    O16 - DPF: {E77F23EB-E7AB-4502-8F37-247DBAF1A147} http://gfx2.hotmail.com/mail/w4/pr01/photouploadcontrol/MSNPUpld.cab (Windows Live Hotmail Photo Upload Tool)
    O16 - DPF: {FD0EBBED-0C42-4D0F-82DA-44399B5C420A} http://downloads.virginmedia.com/CST/ver1/xp_mail.cab (Reg Error: Key error.)
    O16 - DPF: {FF3C5A9F-5A99-4930-80E8-4709194C2AD3} http://zone.msn.com/bingame/zpagames/ZPA_Backgammon.cab64162.cab (MSN Games – Backgammon)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
    O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files\Common Files\Skype\Skype4COM.dll (Skype Technologies)
    O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O18 - Protocol\Handler\vsharechrome {3F3A4B8A-86FC-43A4-BB00-6D7EBE9D4484} - Reg Error: Key error. File not found
    O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - Winlogon\Notify\LBTWlgn: DllName - c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll - c:\Program Files\Common Files\Logishrd\Bluetooth\LBTWLgn.dll (Logitech, Inc.)
    O24 - Desktop WallPaper: C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O28 - HKLM ShellExecuteHooks: {091EB208-39DD-417D-A5DD-7E2C2D8FB9CB} - C:\Program Files\Windows Defender\MpShHook.dll (Microsoft Corporation)
    O28 - HKLM ShellExecuteHooks: {56F9679E-7826-4C84-81F3-532071A8BCC5} - C:\Program Files\Windows Desktop Search\MsnlNamespaceMgr.dll (Microsoft Corporation)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2010/02/04 21:48:29 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O32 - AutoRun File - [1999/06/14 02:55:32 | 000,000,000 | R--D | M] - E:\Autorun -- [ CDFS ]
    O32 - AutoRun File - [1999/06/13 19:56:36 | 000,061,440 | R--- | M] () - E:\Autorun.exe -- [ CDFS ]
    O32 - AutoRun File - [1999/05/30 19:08:48 | 000,011,478 | R--- | M] () - E:\Autorun.ico -- [ CDFS ]
    O32 - AutoRun File - [1999/05/03 16:12:46 | 000,000,073 | R--- | M] () - E:\AUTORUN.INF -- [ CDFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.ac3acm - C:\WINDOWS\System32\ac3acm.acm (fccHandler)
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\System32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.lameacm - C:\WINDOWS\System32\lameACM.acm (http://www.mp3dev.org/)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.DIVX - C:\WINDOWS\System32\divx.dll (DivXNetworks, Inc.)
    Drivers32: VIDC.FFDS - C:\WINDOWS\System32\ff_vfw.dll ()
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: VIDC.IV41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.VP60 - C:\WINDOWS\System32\vp6vfw.dll (On2.com)
    Drivers32: vidc.VP61 - C:\WINDOWS\System32\vp6vfw.dll (On2.com)
    Drivers32: vidc.VP62 - C:\WINDOWS\System32\vp6vfw.dll (On2.com)
    Drivers32: VIDC.XVID - C:\WINDOWS\System32\xvidvfw.dll ()
    Drivers32: VIDC.YV12 - C:\WINDOWS\System32\yv12vfw.dll (www.helixcommunity.org)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (56308550258917376)
    ========== Files/Folders - Created Within 30 Days ==========
    [2011/02/13 19:16:03 | 000,602,624 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Stuart Brodie\Desktop\OTL.exe
    [2011/02/13 16:20:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Bullfrog
    [2011/02/13 16:20:57 | 000,000,000 | ---D | C] -- C:\Program Files\Bullfrog
    [2011/02/13 10:16:08 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\avast! Free Antivirus
    [2011/02/13 10:16:07 | 000,294,608 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswSP.sys
    [2011/02/13 10:16:07 | 000,017,744 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswFsBlk.sys
    [2011/02/13 10:16:05 | 000,023,632 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswRdr.sys
    [2011/02/13 10:16:04 | 000,047,440 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswTdi.sys
    [2011/02/13 10:16:03 | 000,100,176 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswmon2.sys
    [2011/02/13 10:16:03 | 000,094,544 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aswmon.sys
    [2011/02/13 10:16:02 | 000,029,392 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\drivers\aavmker4.sys
    [2011/02/13 10:15:39 | 000,038,848 | ---- | C] (AVAST Software) -- C:\WINDOWS\avastSS.scr
    [2011/02/13 10:15:38 | 000,188,216 | ---- | C] (AVAST Software) -- C:\WINDOWS\System32\aswBoot.exe
    [2011/02/12 19:23:23 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\NtmsData
    [2011/02/12 17:29:11 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\CatRoot2
    [2011/02/08 16:09:01 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2011/02/07 22:10:51 | 000,000,000 | ---D | C] -- C:\WINDOWS\temp
    [2011/02/07 20:04:41 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2011/02/07 20:00:36 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2011/02/07 20:00:36 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2011/02/07 20:00:36 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2011/02/07 20:00:36 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2011/02/07 19:59:00 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2011/02/07 19:58:27 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2011/02/06 14:48:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Application Data\Malwarebytes
    [2011/02/06 14:48:08 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2011/02/06 14:48:07 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    [2011/02/06 14:48:03 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2011/02/06 14:48:03 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2011/02/06 14:43:18 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Desktop\Removal
    [2011/02/06 09:34:18 | 000,000,000 | ---D | C] -- C:\WINDOWS\pss
    [2011/01/31 19:46:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Application Data\Kalypso Media
    [2011/01/31 19:13:12 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Start Menu\Programs\House MD
    [2011/01/31 09:15:57 | 000,382,552 | ---- | C] (Symantec Corporation) -- C:\Documents and Settings\Stuart Brodie\Desktop\Norton.exe
    [2011/01/31 09:02:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Start Menu\Programs\Project Rescue Africa
    [2011/01/31 09:01:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Start Menu\Programs\Mahjong Memoirs
    [2011/01/31 09:01:26 | 000,000,000 | ---D | C] -- C:\WINDOWS\Mahjong Memoirs
    [2011/01/31 08:58:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\uTorrentBar
    [2011/01/30 18:08:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Application Data\Dekovir
    [2011/01/30 17:22:15 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Application Data\Green Clover Games
    [2011/01/30 17:22:15 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Green Clover Games
    [2011/01/24 19:41:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Stuart Brodie\Desktop\Documents
    [2011/01/18 15:32:34 | 000,000,000 | ---D | C] -- C:\NVIDIA
    [2011/01/18 15:30:11 | 000,000,000 | ---D | C] -- C:\Program Files\SystemRequirementsLab
    [4 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
    [1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2011/02/13 19:17:46 | 000,000,302 | ---- | M] () -- C:\WINDOWS\tasks\RealUpgradeScheduledTaskS-1-5-21-1935655697-117609710-725345543-1004.job
    [2011/02/13 19:17:46 | 000,000,294 | ---- | M] () -- C:\WINDOWS\tasks\RealUpgradeLogonTaskS-1-5-21-1935655697-117609710-725345543-1004.job
    [2011/02/13 18:40:00 | 000,000,898 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2011/02/13 13:40:00 | 000,000,894 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2011/02/13 10:50:28 | 000,000,784 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Microsoft\Internet Explorer\Quick Launch\Malwarebytes' Anti-Malware.lnk
    [2011/02/13 10:42:09 | 000,001,813 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Chrome.lnk
    [2011/02/13 10:16:04 | 000,002,626 | ---- | M] () -- C:\WINDOWS\System32\CONFIG.NT
    [2011/02/13 01:54:03 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
    [2011/02/12 19:31:36 | 000,000,462 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\SamsungLiveUpdateConfig.ini
    [2011/02/12 19:23:13 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2011/02/12 19:23:11 | 000,298,048 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2011/02/12 19:11:15 | 007,348,224 | ---- | M] () -- C:\WINDOWS\sectest.db
    [2011/02/12 17:46:24 | 000,023,392 | ---- | M] () -- C:\WINDOWS\System32\nscompat.tlb
    [2011/02/12 17:46:24 | 000,016,832 | ---- | M] () -- C:\WINDOWS\System32\amcompat.tlb
    [2011/02/12 17:20:07 | 000,013,646 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2011/02/12 17:17:19 | 000,000,736 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2011/02/11 22:58:02 | 000,527,358 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2011/02/11 22:58:02 | 000,096,148 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2011/02/07 20:04:47 | 000,000,420 | RHS- | M] () -- C:\boot.ini
    [2011/02/06 15:26:02 | 000,054,016 | ---- | M] () -- C:\WINDOWS\System32\drivers\svwlyil.sys
    [2011/02/06 10:08:41 | 000,069,662 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Desktop\PageDefrag.zip
    [2011/02/06 10:07:36 | 001,309,050 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Desktop\DuplicateCleaner_setup.exe
    [2011/02/06 09:35:17 | 000,000,304 | ---- | M] () -- C:\Boot.bak
    [2011/02/01 09:55:03 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
    [2011/01/31 19:13:12 | 000,001,492 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Desktop\House MD.lnk
    [2011/01/31 13:35:09 | 000,027,136 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2011/01/31 09:16:07 | 000,382,552 | ---- | M] (Symantec Corporation) -- C:\Documents and Settings\Stuart Brodie\Desktop\Norton.exe
    [2011/01/27 19:17:45 | 000,252,080 | ---- | M] () -- C:\WINDOWS\System32\nvdrsdb1.bin
    [2011/01/27 19:17:45 | 000,000,001 | ---- | M] () -- C:\WINDOWS\System32\nvdrssel.bin
    [2011/01/18 15:33:58 | 000,252,080 | ---- | M] () -- C:\WINDOWS\System32\nvdrsdb0.bin
    [2011/02/13 10:50:28 | 000,000,784 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Microsoft\Internet Explorer\Quick Launch\Malwarebytes' Anti-Malware.lnk
    [2011/02/12 19:09:21 | 007,348,224 | ---- | C] () -- C:\WINDOWS\sectest.db
    [2011/02/12 17:00:48 | 000,007,486 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\reset.log
    [2011/02/11 22:57:58 | 000,049,275 | ---- | C] () -- C:\WINDOWS\System32\wfospf.mib
    [2011/02/11 22:57:58 | 000,038,608 | ---- | C] () -- C:\WINDOWS\System32\nipx.mib
    [2011/02/11 22:57:58 | 000,034,317 | ---- | C] () -- C:\WINDOWS\System32\msiprip2.mib
    [2011/02/11 22:57:58 | 000,026,236 | ---- | C] () -- C:\WINDOWS\System32\wins.mib
    [2011/02/11 22:57:58 | 000,013,767 | ---- | C] () -- C:\WINDOWS\System32\msipbtp.mib
    [2011/02/11 22:57:58 | 000,004,332 | ---- | C] () -- C:\WINDOWS\System32\smi.mib
    [2011/02/11 22:57:57 | 000,107,882 | ---- | C] () -- C:\WINDOWS\System32\mib_ii.mib
    [2011/02/11 22:57:57 | 000,048,593 | ---- | C] () -- C:\WINDOWS\System32\hostmib.mib
    [2011/02/11 22:57:57 | 000,030,448 | ---- | C] () -- C:\WINDOWS\System32\mcastmib.mib
    [2011/02/11 22:57:57 | 000,026,100 | ---- | C] () -- C:\WINDOWS\System32\lmmib2.mib
    [2011/02/11 22:57:57 | 000,021,386 | ---- | C] () -- C:\WINDOWS\System32\mipx.mib
    [2011/02/11 22:57:57 | 000,016,617 | ---- | C] () -- C:\WINDOWS\System32\authserv.mib
    [2011/02/11 22:57:57 | 000,015,799 | ---- | C] () -- C:\WINDOWS\System32\ipforwd.mib
    [2011/02/11 22:57:57 | 000,015,597 | ---- | C] () -- C:\WINDOWS\System32\accserv.mib
    [2011/02/11 22:57:57 | 000,010,313 | ---- | C] () -- C:\WINDOWS\System32\mripsap.mib
    [2011/02/11 22:57:57 | 000,004,597 | ---- | C] () -- C:\WINDOWS\System32\dhcp.mib
    [2011/02/11 22:57:57 | 000,000,581 | ---- | C] () -- C:\WINDOWS\System32\msft.mib
    [2011/02/07 23:02:35 | 000,000,330 | -H-- | C] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
    [2011/02/07 20:04:47 | 000,000,304 | ---- | C] () -- C:\Boot.bak
    [2011/02/07 20:04:42 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2011/02/07 20:00:36 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2011/02/07 20:00:36 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2011/02/07 20:00:36 | 000,089,088 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2011/02/07 20:00:36 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2011/02/07 20:00:36 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2011/02/06 15:26:02 | 000,054,016 | ---- | C] () -- C:\WINDOWS\System32\drivers\svwlyil.sys
    [2011/02/06 10:08:39 | 000,069,662 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Desktop\PageDefrag.zip
    [2011/02/06 10:07:22 | 001,309,050 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Desktop\DuplicateCleaner_setup.exe
    [2011/01/31 19:13:12 | 000,001,492 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Desktop\House MD.lnk
    [2011/01/23 08:56:00 | 000,000,294 | ---- | C] () -- C:\WINDOWS\tasks\RealUpgradeLogonTaskS-1-5-21-1935655697-117609710-725345543-1004.job
    [2011/01/18 15:33:05 | 000,003,630 | ---- | C] () -- C:\WINDOWS\System32\nvinfo.pb
    [2010/12/05 08:47:43 | 000,002,552 | ---- | C] () -- C:\WINDOWS\Wavemix.ini
    [2010/12/05 08:47:42 | 000,000,162 | ---- | C] () -- C:\WINDOWS\Powertcp.ini
    [2010/12/02 22:06:35 | 000,472,048 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\FontCache3.0.0.0.dat
    [2010/06/02 09:56:29 | 000,000,180 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\setup.log
    [2010/06/02 09:56:26 | 000,000,760 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\setup_ldm.iss
    [2010/05/11 15:06:22 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\downloads.m3u
    [2010/05/05 14:18:39 | 000,347,472 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\MB.SAV
    [2010/05/03 18:13:36 | 000,138,056 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\PnkBstrK.sys
    [2010/05/03 18:13:36 | 000,137,544 | ---- | C] () -- C:\WINDOWS\System32\drivers\PnkBstrK.sys
    [2010/03/21 15:55:11 | 000,020,102 | ---- | C] () -- C:\Program Files\Readme.txt
    [2010/03/21 15:55:11 | 000,010,960 | ---- | C] () -- C:\Program Files\EULA.txt
    [2010/03/20 20:27:08 | 000,691,696 | ---- | C] () -- C:\WINDOWS\System32\drivers\sptd.sys
    [2010/03/20 13:31:32 | 000,000,131 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\default.rss
    [2010/02/27 14:33:57 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\rx_image32.Cache
    [2010/02/14 12:47:44 | 000,000,100 | ---- | C] () -- C:\WINDOWS\SIERRA.INI
    [2010/02/08 18:51:20 | 000,000,334 | ---- | C] () -- C:\WINDOWS\WININIT.INI
    [2010/02/08 13:22:20 | 000,000,069 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2010/02/07 16:16:57 | 000,178,176 | ---- | C] () -- C:\WINDOWS\System32\unrar.dll
    [2010/02/07 16:16:57 | 000,000,038 | ---- | C] () -- C:\WINDOWS\avisplitter.ini
    [2010/02/07 16:16:50 | 000,881,664 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
    [2010/02/07 16:16:50 | 000,205,824 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
    [2010/02/07 16:16:49 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
    [2010/02/07 16:16:46 | 000,085,504 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll
    [2010/02/07 15:20:27 | 000,027,136 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2010/02/07 09:26:14 | 000,000,462 | ---- | C] () -- C:\Documents and Settings\Stuart Brodie\Application Data\SamsungLiveUpdateConfig.ini
    [2010/02/07 08:03:33 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2010/02/04 22:06:13 | 000,363,520 | ---- | C] () -- C:\WINDOWS\System32\psisdecd.dll
    [2010/02/04 21:57:11 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\vuins32.dll
    [2010/02/04 21:53:54 | 000,002,653 | ---- | C] () -- C:\WINDOWS\Ascd_tmp.ini
    [2010/02/04 21:53:53 | 000,005,824 | ---- | C] () -- C:\WINDOWS\System32\drivers\ASUSHWIO.SYS
    [2010/02/04 21:41:39 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2009/08/03 15:07:42 | 000,403,816 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.DLL
    [2009/08/02 23:21:54 | 000,197,912 | ---- | C] () -- C:\WINDOWS\System32\physxcudart_20.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelTraditionalChinese.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSwedish.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSpanish.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSimplifiedChinese.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelPortugese.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelKorean.dll
    [2009/08/02 23:21:54 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelJapanese.dll
    [2009/08/02 23:21:52 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelGerman.dll
    [2009/08/02 23:21:52 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelFrench.dll
    [2007/09/27 10:51:02 | 000,020,698 | ---- | C] () -- C:\WINDOWS\System32\idxcntrs.ini
    [2007/09/27 10:48:48 | 000,030,628 | ---- | C] () -- C:\WINDOWS\System32\gsrvctr.ini
    [2007/09/27 10:48:28 | 000,031,698 | ---- | C] () -- C:\WINDOWS\System32\gthrctr.ini
    [2007/06/28 16:43:00 | 000,286,720 | ---- | C] () -- C:\WINDOWS\System32\nvnt4cpl.dll
    [2004/01/30 15:07:46 | 000,245,408 | ---- | C] () -- C:\WINDOWS\System32\unicows.dll
    [2003/01/07 15:05:08 | 000,002,695 | ---- | C] () -- C:\WINDOWS\System32\OUTLPERF.INI
    [1997/06/14 01:56:08 | 000,056,832 | ---- | C] () -- C:\WINDOWS\System32\iyvu9_32.dll
    [2010/12/02 15:58:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AA3DeployClient
    [2010/09/08 15:10:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AlawarWrapper
    [2011/02/13 10:15:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Alwil Software
    [2010/05/16 18:59:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ashampoo
    [2010/02/27 14:00:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\CinemaNow
    [2010/03/20 20:26:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\DAEMON Tools Pro
    [2010/06/11 17:45:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Deadtime Stories
    [2010/12/06 07:45:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Electronic Arts
    [2010/04/06 15:22:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\GameHouse
    [2010/09/05 19:12:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Gamers Digital
    [2011/01/30 17:22:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Green Clover Games
    [2010/06/07 19:58:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Harley-Davidson_ Race to the Rally Saves
    [2010/06/03 15:23:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\HipSoft
    [2010/02/08 13:19:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\LightScribe
    [2010/12/05 09:13:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Ludia
    [2010/12/04 08:30:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\MumboJumbo
    [2010/04/15 20:01:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Namco
    [2010/08/02 07:08:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Nexon
    [2010/08/02 07:08:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\NexonEU
    [2010/02/27 13:59:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PhotoShow Shared Assets
    [2011/02/08 15:31:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PlayFirst
    [2010/04/17 14:17:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Playrix Entertainment
    [2010/02/11 18:48:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PoBros
    [2010/02/26 21:02:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\QB9
    [2010/02/27 14:38:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
    [2011/02/11 23:16:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
    [2010/04/08 18:54:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Top Evidence
    [2010/05/20 18:52:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TreeCardGames
    [2010/06/14 05:54:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Trusteer
    [2010/05/07 10:10:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Ubisoft
    [2010/02/27 14:04:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Uninstall
    [2010/05/27 13:30:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WildTangent
    [2010/03/07 18:58:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WinAVI
    [2010/07/13 05:54:29 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Default User\Application Data\Trusteer
    [2010/07/04 12:13:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\AMozilla
    [2010/02/07 15:36:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\AnvSoft
    [2010/05/16 19:00:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Ashampoo
    [2010/05/22 20:16:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\AviDvdBurner
    [2010/08/27 10:36:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Big Fish Games
    [2010/02/07 09:21:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
    [2010/03/20 20:33:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\DAEMON Tools Pro
    [2010/03/13 11:24:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\DarkParablesBriarRose_BFG
    [2011/01/30 18:08:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Dekovir
    [2010/05/28 20:00:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\ERS G-Studio
    [2010/04/30 05:58:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Freeze Tag
    [2010/09/05 19:12:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Gamers Digital
    [2010/06/22 11:58:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Games
    [2010/02/16 20:45:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\GamesCafe
    [2010/04/02 19:52:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Gearbox Software
    [2010/10/09 07:44:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\GOL_byHasbro
    [2011/01/30 17:22:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Green Clover Games
    [2010/03/09 22:13:29 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\iMaxGen
    [2010/04/15 20:14:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\JournalistJourney
    [2011/01/31 19:46:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Kalypso Media
    [2010/03/19 21:06:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Ladia Group
    [2010/06/02 09:56:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Leadertech
    [2010/12/05 09:13:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Ludia
    [2010/07/04 17:39:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Magic Academy 2
    [2010/04/11 09:10:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Magic3
    [2010/11/18 09:38:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\MahJong Suite
    [2010/04/11 10:26:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\mif2000's Hamlet
    [2010/04/15 20:01:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Namco
    [2010/05/31 16:14:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\PeaZip
    [2011/02/08 15:31:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\PlayFirst
    [2010/02/11 18:48:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\PoBros
    [2010/02/26 21:02:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\QB9
    [2010/05/10 17:47:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Registry Mechanic
    [2010/11/18 21:39:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Sahmon Games
    [2010/04/17 06:26:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Scholastic
    [2010/04/01 20:07:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Settlement. Colossus
    [2010/02/27 13:59:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Simple Star
    [2010/06/04 16:53:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\SpinTop Games
    [2010/03/27 06:56:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\SquareLogic
    [2010/08/22 12:55:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Thinstall
    [2010/08/22 19:52:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\TOMI2.THE GATES OF FATE
    [2010/04/08 18:54:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Top Evidence
    [2010/06/14 05:56:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Trusteer
    [2010/05/16 19:09:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Uniblue
    [2010/08/08 12:12:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\ValuSoft
    [2010/02/05 21:12:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Virtual City
    [2010/07/24 21:08:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Vogat Interactive
    [2010/09/18 15:27:17 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\vShare
    [2010/12/13 15:43:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Wildfire
    [2010/03/07 18:58:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\WinAVI
    [2010/02/06 16:25:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Windows Desktop Search
    [2010/02/08 08:17:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Stuart Brodie\Application Data\Windows Search
    [2011/02/13 01:54:03 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\Tasks\MP Scheduled Scan.job
  6. 2011/02/13
    Caveman
    Part 2...
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2011/02/13 15:37:18 | 000,000,000 | ---- | M] () -- C:\AILog.txt
    [2010/02/04 21:48:29 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2010/02/09 19:02:47 | 000,006,127 | R--- | M] () -- C:\CLDMA.LOG
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2006/01/01 00:12:38 | 000,028,908 | ---- | M] () -- C:\ComboFix.txt
    [2010/02/04 21:48:29 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2011/02/12 19:13:47 | 000,000,015 | ---- | M] () -- C:\DAF-interface-resetlog.txt
    [2010/02/04 21:48:29 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
    [2011/02/13 10:42:01 | 000,001,364 | ---- | M] () -- C:\ipconfig_all.txt
    [2010/03/21 15:43:28 | 005,207,213 | ---- | M] () -- C:\mcdbp.log
    [2003/03/18 21:20:00 | 001,060,864 | ---- | M] (Microsoft Corporation) -- C:\mfc71.dll
    [2010/02/04 21:48:29 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
    [2010/02/06 12:49:58 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2010/02/06 14:04:32 | 000,250,048 | RHS- | M] () -- C:\ntldr
    [2011/02/12 19:23:10 | 1610,612,736 | -HS- | M] () -- C:\pagefile.sys
    [2010/03/01 18:08:04 | 000,017,408 | ---- | M] (Microsoft Corporation) -- C:\psapi.dll
    < %systemroot%\Fonts\*.com >
    [2006/04/18 14:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 13:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 14:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 13:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2011/02/12 17:46:34 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 12:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2007/04/09 13:23:54 | 000,028,552 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\mdippr.dll
    [2008/07/06 10:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    [2011/01/13 08:47:35 | 000,038,848 | ---- | M] (AVAST Software) -- C:\WINDOWS\avastSS.scr
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    [2011/02/08 19:24:19 | 000,001,746 | -H-- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Microsoft\LastFlashConfig.WFC
    < %PROGRAMFILES%\*.* >
    [2003/09/03 07:46:54 | 000,010,960 | ---- | M] () -- C:\Program Files\EULA.txt
    [2003/12/18 11:33:46 | 000,020,102 | ---- | M] () -- C:\Program Files\Readme.txt
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2010/02/04 21:39:50 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2010/02/04 21:39:50 | 000,602,112 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2010/02/04 21:39:50 | 000,446,464 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2010/02/06 14:10:46 | 000,000,272 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2011/02/12 18:47:46 | 000,000,177 | -HS- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2010/02/04 21:51:47 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2011/02/12 18:47:46 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Stuart Brodie\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2011/02/13 19:17:45 | 000,540,672 | ---- | M] () -- C:\Documents and Settings\Stuart Brodie\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2007/06/26 22:10:26 | 000,317,440 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2008/04/14 00:11:51 | 000,033,792 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2003/03/31 12:00:00 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2002/08/20 12:32:18 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2002/08/20 12:32:22 | 000,000,807 | ---- | M] () -- C:\Program Files\Messenger\mailtmpl.txt
    [2008/05/02 14:01:49 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2008/04/13 17:30:28 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2008/04/14 00:12:28 | 001,695,232 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2002/08/20 15:08:38 | 000,069,663 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgsin.exe
    [2003/03/31 12:00:00 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2003/03/31 12:00:00 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2003/03/31 12:00:00 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2002/08/20 12:32:20 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/07/17 18:41:04 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    ========== Alternate Data Streams ==========
    @Alternate Data Stream - 98 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:7CA7BED1
    @Alternate Data Stream - 98 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:78E0DF72
    @Alternate Data Stream - 85 bytes -> C:\Documents and Settings\All Users\Desktop:$SS_DESCRIPTOR_PBPUV9VK9V89VMRV5V4REABYEKLPH9E48E2R0T5PL34DBWFLM3TLVVVVVVVVVVJVK
    @Alternate Data Stream - 240 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:D1B5B4F1
    @Alternate Data Stream - 177 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:370EF5E8
    @Alternate Data Stream - 161 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:FB1B13D8
    @Alternate Data Stream - 161 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:5AE33054
    @Alternate Data Stream - 139 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:FB65A4AA
    @Alternate Data Stream - 138 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:4DCAC4BC
    @Alternate Data Stream - 124 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:57B2B96C
    @Alternate Data Stream - 122 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:D31BE97C
    @Alternate Data Stream - 109 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:260575F1
    @Alternate Data Stream - 108 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:6F1F66C0
    < End of report >
  7. 2011/02/13
    Caveman
    Caveman Inactive Thread Starter
    Extras Log...
    OTL Extras logfile created on: 13/02/2011 19:17:49 - Run 1
    OTL by OldTimer - Version 3.2.20.6 Folder = C:\Documents and Settings\Stuart Brodie\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
    1,022.00 Mb Total Physical Memory | 491.00 Mb Available Physical Memory | 48.00% Memory free
    2.00 Gb Paging File | 2.00 Gb Available in Paging File | 77.00% Paging File free
    Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 232.88 Gb Total Space | 82.86 Gb Free Space | 35.58% Space Free | Partition Type: NTFS
    Drive D: | 76.69 Gb Total Space | 19.97 Gb Free Space | 26.04% Space Free | Partition Type: NTFS
    Drive E: | 542.30 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
    Computer Name: IRONGIANT | User Name: Stuart Brodie | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    .txt [@ = NFOPad] -- C:\Program Files\NFOPad\NFOPad.exe (True Human Design)
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [+ Add to separate archive(s)] -- "C:\Program Files\PeaZip\PEAZIP.EXE" "-add2archive" "%1" (Giorgio Tani)
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    "AntiVirusOverride" = 0
    "FirewallOverride" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{01501EBA-EC35-4F9F-8889-3BE346E5DA13}" = MSXML4 Parser
    "{045A0141-9149-45C6-A806-F2BF9CFCE762}" = Microsoft Encarta Premium Suite - WE 2004
    "{048298C9-A4D3-490B-9FF9-AB023A9238F3}" = Steam
    "{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}" = Windows Live ID Sign-in Assistant
    "{0C826C5B-B131-423A-A229-C71B3CACCD6A}" = CDDRV_Installer
    "{11F5D779-7BD9-465A-BBC4-10701386BCB9}" = FW LiveUpdate
    "{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
    "{1DD81E7D-0D28-4CEB-87B2-C041A4FCB215}" = Rapport
    "{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    "{205C6BDD-7B73-42DE-8505-9A093F35A238}" = Windows Live Upload Tool
    "{20D4A895-748C-4D88-871C-FDB1695B0169}" = Platform
    "{22B775E7-6C42-4FC5-8E10-9A5E3257BD94}" = MSVCRT
    "{28C2DED6-325B-4CC7-983A-1777C8F7FBAB}" = RealUpgrade 1.1
    "{2F1E5C4C-B20C-42C3-B5F1-1FE2CA207AFE}" = Email Updater
    "{3101CB58-3482-4D21-AF1A-7057FC935355}" = KhalInstallWrapper
    "{3175E049-F9A9-4A3D-8F19-AC9FB04514D1}" = Windows Live Communications Platform
    "{33CF58F5-48D8-4575-83D6-96F574E4D83A}" = Nero DriveSpeed
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{359CFC0A-BEB1-440D-95BA-CF63A86DA34F}" = Nero Recode
    "{368BA326-73AD-4351-84ED-3C0A7A52CC53}" = Nero Rescue Agent
    "{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
    "{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}" = erLT
    "{4286E640-B5FB-11DF-AC4B-005056C00008}" = Google Earth
    "{43E39830-1826-415D-8BAE-86845787B54B}" = Nero Vision
    "{474F25F5-BDC9-40E5-B1B6-F6BF23FC106F}" = Windows Live Essentials
    "{4A7FDA4D-F4D7-4A49-934A-066D59A43C7E}" = SmartSound Quicktracks Plugin
    "{53735ECE-E461-4FD0-B742-23A352436D3A}" = Logitech Updater
    "{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
    "{57752979-A1C9-4C02-856B-FBB27AC4E02C}" = QuickTime
    "{595A3116-40BB-4E0F-A2E8-D7951DA56270}" = NeroExpress
    "{5A2BC38A-406C-4A5B-BF45-6991F9A05325}_is1" = PeaZip 2.9.1
    "{62AC81F6-BDD3-4110-9D36-3E9EAAB40999}" = Nero CoverDesigner
    "{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
    "{6421F085-1FAA-DE13-D02A-CFB412C522A4}" = Acrobat.com
    "{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD
    "{6956856F-B6B3-4BE0-BA0B-8F495BE32033}" = Apple Software Update
    "{6C122441-1861-4CD7-B1C5-A163A6984E12}" = CinemaNow Media Manager
    "{6D8DDB4A-C263-40DE-BA16-AFDAD159D59A}" = Tom Clancy's Splinter Cell Conviction
    "{7299052b-02a4-4627-81f2-1818da5d550d}" = Microsoft Visual C++ 2005 Redistributable
    "{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    "{7748AC8C-18E3-43BB-959B-088FAEA16FB2}" = Nero StartSmart
    "{7770E71B-2D43-4800-9CB3-5B6CAAEBEBEA}" = RealNetworks - Microsoft Visual C++ 2008 Runtime
    "{7829DB6F-A066-4E40-8912-CB07887C20BB}" = Nero BurnRights
    "{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110094687}" = Cubis Gold
    "{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110126437}" = 5 Spots
    "{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11019760}" = 5 Spots II
    "{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11028247}" = Cubis Gold 2
    "{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
    "{869200DB-287A-4DC0-B02B-2B6787FBCD4C}" = Nero DiscSpeed
    "{888F1505-C2B3-4FDE-835D-36353EBD4754}" = Ubisoft Game Launcher
    "{89A15676-78AE-4D51-BF5B-DEE3E0D46C94}" = Roxio Creator 2010 Pro
    "{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
    "{8E5233E1-7495-44FB-8DEB-4BE906D59619}" = Junk Mail filter update
    "{90110409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Professional Edition 2003
    "{90120000-0020-0409-0000-0000000FF1CE}" = Compatibility Pack for the 2007 Office system
    "{909B62B0-8ACA-4061-A83B-09CAEF609619}" = MSXML 6.0 Parser
    "{91D0985C-CF1E-4AD3-AC28-F9787718C71F}" = DVDFab Platinum
    "{95120000-00B9-0409-0000-0000000FF1CE}" = Microsoft Application Error Reporting
    "{981029E0-7FC9-4CF3-AB39-6F133621921A}" = Skype Toolbars
    "{9A25302D-30C0-39D9-BD6F-21E6EC160475}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
    "{9E82B934-9A25-445B-B8DF-8012808074AC}" = Nero PhotoSnap
    "{A06275F4-324B-4E85-95E6-87B2CD729401}" = Windows Defender
    "{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}" = Segoe UI
    "{A209525B-3377-43F4-B886-32F6B6E7356F}" = Nero WaveEditor
    "{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{A8F2089B-1F79-4BF6-B385-A2C2B0B9A74D}" = ImagXpress
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AC76BA86-7AD7-1033-7B44-A94000000001}" = Adobe Reader 9.4.1
    "{AF9E97C1-7431-426D-A8D5-ABE40995C0B1}" = DirectX 9 Runtime
    "{B1ADF008-E898-4FE2-8A1F-690D9A06ACAF}" = DolbyFiles
    "{B2EC4A38-B545-4A00-8214-13FE0E915E6D}" = Advertising Center
    "{B2FE1952-0186-46c3-BAEC-A80AA35AC5B8}_Display.ControlPanel" = NVIDIA Control Panel 266.58
    "{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver" = NVIDIA Graphics Driver 266.58
    "{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NView" = NVIDIA nView 135.50
    "{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_installer" = NVIDIA Install Application
    "{B57EAFF2-D6EE-4C6C-9175-ED9F17BFC1BC}" = Windows Live Messenger
    "{B78120A0-CF84-4366-A393-4D0A59BC546C}" = Menu Templates - Starter Kit
    "{bd2d1966-42b7-43c8-b561-f1f278f15c84}" = Nero 9 Trial
    "{BD5CA0DA-71AD-43DA-B19E-6EEE0C9ADC9A}" = Nero ControlCenter
    "{BE686891-3C56-4714-AFEF-341A7867BA80}" = Micronet SP907GK Wireless Network Utility
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{C5A7CB6C-E76D-408F-BA0E-85605420FE9D}" = SoundTrax
    "{C5C1C0F0-D62F-4DBF-81D4-D7EF397C228B}" = NVIDIA PhysX
    "{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}" = Microsoft .NET Framework 1.1
    "{CC8E94A2-55C7-4460-953C-2A790180578C}" = LightScribe System Software
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D025A639-B9C9-417D-8531-208859000AF8}" = NeroBurningROM
    "{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.2
    "{D18BBE5F-167B-4148-8011-074818D2DEDB}_is1" = Din's Curse 1.001
    "{D9DCF92E-72EB-412D-AC71-3B01276E5F8B}" = Nero ShowTime
    "{E100A066-697B-419D-BC40-CDB1B00975A2}" = Harley-Davidson Race to the Rally
    "{E3E71D07-CD27-46CB-8448-16D4FB29AA13}" = Microsoft WSE 3.0 Runtime
    "{E498385E-1C51-459A-B45F-1721E37AA1A0}" = Movie Templates - Starter Kit
    "{E6158D07-2637-4ECF-B576-37C489669174}" = Windows Live Call
    "{E8A80433-302B-4FF1-815D-FCC8EAC482FF}" = Nero Installer
    "{ECC3713C-08A4-40E3-95F1-7D0704F1CE5E}" = PL-2303 USB-to-Serial
    "{EE6097DD-05F4-4178-9719-D3170BF098E8}" = Apple Application Support
    "{F0E12BBA-AD66-4022-A453-A1C8A0C4D570}" = Microsoft Choice Guard
    "{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}" = Realtek High Definition Audio Driver
    "{F2835483-37F2-4123-B4FE-0E77D58447F2}" = Far Cry 2
    "{F29B21BD-CAA6-445F-8EF7-A7E2B9D8B14E}" = Logitech SetPoint
    "{F40BBEC7-C2A4-4A00-9B24-7A055A2C5262}" = Microsoft Office Live Add-in 1.5
    "{FBCDFD61-7DCF-4E71-9226-873BA0053139}" = Nero InfoTool
    "7-Zip" = 7-Zip 4.65
    "82A44D22-9452-49FB-00FB-CEC7DCAF7E23" = EA SPORTS online 2008
    "Adobe AIR" = Adobe AIR
    "Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
    "Adobe Flash Player Plugin" = Adobe Flash Player 10 Plugin
    "Adobe Shockwave Player" = Adobe Shockwave Player 11.5
    "Age of Empires 2.0" = Microsoft Age of Empires II
    "Age of Empires Gold 1.0" = Microsoft Age of Empires Gold
    "Age of Empires II: The Conquerors Expansion 1.0" = Microsoft Age of Empires II: The Conquerors Expansion
    "Age of Mythology 1.0" = Age of Mythology
    "Age of Mythology Expansion Pack 1.0" = Age of Mythology - The Titans Expansion
    "Alien Shooter_is1" = Alien Shooter
    "Any DVD Converter Professional_is1" = Any DVD Converter Professional 4.0.3
    "Ashampoo Burning Studio 9_is1" = Ashampoo Burning Studio 9.21
    "avast5" = avast! Free Antivirus
    "AVI DVD Burner_is1" = AVI DVD Burner v5.3.0.31
    "AVS Update Manager_is1" = AVS Update Manager 1.0
    "AVS4YOU Software Navigator_is1" = AVS4YOU Software Navigator 1.3
    "AVS4YOU Video Converter 6_is1" = AVS Video Converter 6
    "BrothersInArms" = Brothers In Arms
    "Build A Lot 4-Power source ." = Build A Lot 4-Power source .
    "Build a Lot 5 Elizabethan Era1.0" = Build a Lot 5 Elizabethan Era
    "Build-a-lot 2 - Town of the Year [h33t] [oi812heet]" = Build-a-lot 2 - Town of the Year [h33t] [oi812heet]
    "Build-a-lot 3 - Passport to Europe 1.00" = Build-a-lot 3 - Passport to Europe 1.00
    "CLUE Classic1.0" = CLUE Classic
    "com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
    "Comanche 4" = Comanche 4
    "Combat Arms EU" = Combat Arms EU
    "Cooking Dash 2 - DinerTown Studios H33T" = Cooking Dash 2 - DinerTown Studios H33T
    "Delta Force - Black Hawk Down" = Delta Force - Black Hawk Down (remove only)
    "Diner Dash 5 - Boom Collectors Edition" = Diner Dash 5 - Boom Collectors Edition
    "DivX Codec" = DivX Codec
    "Download Manager" = Download Manager 2.3.10
    "Dungeon Keeper II" = Dungeon Keeper 2
    "DVD Shrink_is1" = DVD Shrink 3.2
    "DVD to VCD AVI DivX Converter v3.2 (build 062)" = DVD to VCD AVI DivX Converter v3.2 (build 062)
    "EADM" = EA Download Manager
    "Elf Bowling Holiday Pack 1.00" = Elf Bowling Holiday Pack 1.00
    "feeding frenzy 2 shipwreck showdown sceneXtra" = feeding frenzy 2 shipwreck showdown sceneXtra
    "feeding frenzy sceneXtra" = feeding frenzy sceneXtra
    "Fragile Ball_is1" = Fragile Ball v1.06
    "Google Chrome" = Google Chrome
    "Hazen - The Dark Whispers_is1" = Hazen - The Dark Whispers
    "Heart's Medicine - Season One Just For Fun Games" = Heart's Medicine - Season One Just For Fun Games
    "Homeworld" = Homeworld
    "Homeworld2" = Homeworld2
    "House MD1.0" = House MD
    "ie8" = Windows Internet Explorer 8
    "InstallShield_{20D4A895-748C-4D88-871C-FDB1695B0169}" = VIA Platform Device Manager
    "InstallShield_{4A7FDA4D-F4D7-4A49-934A-066D59A43C7E}" = SmartSound Quicktracks Plugin
    "KLiteCodecPack_is1" = K-Lite Mega Codec Pack 5.5.1
    "LHTTSENG" = L&H TTS3000 British English
    "LIFE QUEST Final" = LIFE QUEST Final
    "Luxor 4 Quest For The Afterlife 1.00" = Luxor 4 Quest For The Afterlife 1.00
    "Magic ISO Maker v5.5 (build 0281)" = Magic ISO Maker v5.5 (build 0281)
    "Mahjong Memoirs1.0" = Mahjong Memoirs
    "MahJong Suite_is1" = MahJong Suite 2010 v7.1
    "Mahjong Towers Eternity 1.00" = Mahjong Towers Eternity 1.00
    "MahjongChamp" = Mahjong Champ
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "Microsoft .NET Framework 1.1 (1033)" = Microsoft .NET Framework 1.1
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
    "Mozilla Firefox (3.6.3)" = Mozilla Firefox (3.6.3)
    "MSCompPackV1" = Microsoft Compression Client Pack 1.0 for Windows XP
    "Mystery Case Files - Madame Fate 1.00" = Mystery Case Files - Madame Fate 1.00
    "Mystery Case Files - Prime Suspects 1.00" = Mystery Case Files - Prime Suspects 1.00
    "Mystery Case Files - Ravenhearst 1.00" = Mystery Case Files - Ravenhearst 1.00
    "Mystery in London1.0" = Mystery in London
    "NFOPad" = NFOPad 1.56
    "NVIDIA nView Desktop Manager" = NVIDIA nView Desktop Manager
    "Pandora's Box 1.0" = Microsoft Pandora's Box
    "PowerISO" = PowerISO
    "Project Rescue Africa1.0" = Project Rescue Africa
    "PunkBusterSvc" = PunkBuster Services
    "QBeez 2_is1" = QBeez 2
    "Rapport_msi" = Rapport
    "Real Crimes Jack the Ripper1.0" = Real Crimes Jack the Ripper
    "RealPlayer 12.0" = RealPlayer
    "Registry Mechanic_is1" = Registry Mechanic 10.0
    "Roads of Rome II Just For Fun Games" = Roads of Rome II Just For Fun Games
    "Roads of Rome Just For Fun Games" = Roads of Rome Just For Fun Games
    "Rome The Curse of the Necklace 1.00" = Rome The Curse of the Necklace 1.00
    "Settlement Colossus ." = Settlement Colossus .
    "Shockwave" = Shockwave
    "Snail Mail {h33t} {oi812heet}" = Snail Mail {h33t} {oi812heet}
    "SopCast" = SopCast 3.2.9
    "SystemRequirementsLab" = System Requirements Lab
    "Tales of Monkey Island" = Tales of Monkey Island
    "Text Twist 2 1.00" = Text Twist 2 1.00
    "The Fall Trilogy Chapter 2 Reconstruction 1.00" = The Fall Trilogy Chapter 2 Reconstruction 1.00
    "The Game of Life 1.00" = The Game of Life 1.00
    "Tiberian Sun" = Command & Conquer Tiberian Sun
    "Tumble_0" = Tumble Bugs
    "Tumblebugs_0" = Tumblebugs 2
    "TVUPlayer" = TVUPlayer 2.5.0.1
    "ValGor Dark Lord of Magic 1.00" = ValGor Dark Lord of Magic 1.00
    "Veetle TV" = Veetle TV 0.9.18
    "Virtual City ." = Virtual City .
    "VN_VUIns_Rhine_VIA" = VIA Rhine-Family Fast-Ethernet Adapter
    "vShare" = vShare Plugin
    "Wdf01005" = Microsoft Kernel-Mode Driver Framework Feature Pack 1.5
    "WinAVI Video Converter 10.0_is1" = WinAVI Video Converter
    "Windows Media Format Runtime" = Windows Media Format 11 runtime
    "Windows Media Player" = Windows Media Player 11
    "Windows XP Service Pack" = Windows XP Service Pack 3
    "WinLiveSuite_Wave3" = Windows Live Essentials
    "WMFDist11" = Windows Media Format 11 runtime
    "wmp11" = Windows Media Player 11
    "WOLAPI" = Westwood Shared Internet Components
    "WT011606" = Snowboard SuperJam
    "Wudf01000" = Microsoft User-Mode Driver Framework Feature Pack 1.0
    "Zuma's Revenge! - Adventure H33T" = Zuma's Revenge! - Adventure H33T
    ========== HKEY_USERS Uninstall List ==========
    [HKEY_USERS\S-1-5-21-1935655697-117609710-725345543-1004\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "2a4f70b48f669acd" = AA3Deploy
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 09/02/2011 21:45:03 | Computer Name = IRONGIANT | Source = MPSampleSubmission | ID = 5000
    Description = EventType mptelemetry, P1 8024402c, P2 endsearch, P3 search, P4 1.1.1593.0,
    P5 mpsigdwn.dll, P6 1.1.1593.0, P7 windows defender, P8 NIL, P9 NIL, P10 NIL.
    Error - 11/02/2011 18:59:26 | Computer Name = IRONGIANT | Source = Application Hang | ID = 1002
    Description = Hanging application helpctr.exe, version 5.1.2600.5512, hang module
    hungapp, version 0.0.0.0, hang address 0x00000000.
    Error - 11/02/2011 22:06:02 | Computer Name = IRONGIANT | Source = MPSampleSubmission | ID = 5000
    Error - 31/12/2005 20:02:39 | Computer Name = IRONGIANT | Source = Windows Search Service | ID = 3038
    Description = The gatherer is unable to read the registry DocIdMapFile. Context:
    Application, SystemIndex Catalog Details: The system cannot find the file specified.
    (0x80070002)
    Error - 31/12/2005 20:02:43 | Computer Name = IRONGIANT | Source = Windows Search Service | ID = 3028
    Description = The gatherer object cannot be initialized. Context: Windows Application,
    SystemIndex Catalog Details: The registry value cannot be read because the configuration
    is invalid. Recreate the content index configuration by removing the content index.
    (0x80040d03)
    Error - 31/12/2005 20:02:43 | Computer Name = IRONGIANT | Source = Windows Search Service | ID = 3058
    Description = The application cannot be initialized. Context: Windows Application
    Details:
    The
    registry value cannot be read because the configuration is invalid. Recreate the
    content index configuration by removing the content index. (0x80040d03)
    Error - 12/02/2011 13:21:27 | Computer Name = IRONGIANT | Source = Windows Search Service | ID = 3024
    Description = The update cannot be started because the content sources cannot be
    accessed. Fix the errors and try the update again. Context: Application, SystemIndex
    Catalog
    Error - 12/02/2011 21:54:02 | Computer Name = IRONGIANT | Source = MPSampleSubmission | ID = 5000
    Error - 13/02/2011 06:14:52 | Computer Name = IRONGIANT | Source = crypt32 | ID = 131083
    Description = Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab>
    with error: An internal certificate chaining error has occurred.
    Error - 13/02/2011 13:22:24 | Computer Name = IRONGIANT | Source = Application Error | ID = 1000
    Description = Faulting application dkii.icd, version 0.0.0.0, faulting module dkii.icd,
    version 0.0.0.0, fault address 0x0000c585.
    [ System Events ]
    Error - 13/02/2011 06:29:25 | Computer Name = IRONGIANT | Source = Service Control Manager | ID = 7023
    Description = The Background Intelligent Transfer Service service terminated with
    the following error: %%2
    Error - 13/02/2011 06:29:55 | Computer Name = IRONGIANT | Source = DCOM | ID = 10010
    Description = The server {4991D34B-80A1-4291-83B6-3328366B9097} did not register
    with DCOM within the required timeout.
    Error - 13/02/2011 06:40:01 | Computer Name = IRONGIANT | Source = Service Control Manager | ID = 7023
    Error - 13/02/2011 06:40:30 | Computer Name = IRONGIANT | Source = DCOM | ID = 10010
    Error - 13/02/2011 06:40:31 | Computer Name = IRONGIANT | Source = Service Control Manager | ID = 7023
    Error - 13/02/2011 06:41:00 | Computer Name = IRONGIANT | Source = DCOM | ID = 10010
    Error - 13/02/2011 09:40:00 | Computer Name = IRONGIANT | Source = Service Control Manager | ID = 7023
    Error - 13/02/2011 09:40:30 | Computer Name = IRONGIANT | Source = DCOM | ID = 10010
    Error - 13/02/2011 10:57:42 | Computer Name = IRONGIANT | Source = Cdrom | ID = 262151
    Description = The device, \Device\CdRom0, has a bad block.
    Error - 13/02/2011 11:44:34 | Computer Name = IRONGIANT | Source = Cdrom | ID = 262151
    < End of report >
  8. 2011/02/13
    1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    Run OTL
      :OTL
      O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - No CLSID value found.
      O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
      O16 - DPF: {FD0EBBED-0C42-4D0F-82DA-44399B5C420A} http://downloads.virginmedia.com/CST/ver1/xp_mail.cab (Reg Error: Key error.)
      @Alternate Data Stream - 85 bytes -> C:\Documents and Settings\All Users\Desktop:$SS_DESCRIPTOR_PBPUV9VK9V89VMRV5V4REABYEKLPH9E48E2R0T5PL34DBW FLM3TLVVVVVVVVVVJVK
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Last scans....
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
      NOTE SecurityCheck may produce some false warning(s), so leave the results reading to me.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
  9. 2011/02/14
    Caveman
    Java steps done.
    OTL Log...
    All processes killed
    ========== OTL ==========
    Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
    Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
    Registry error reading value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\DownloadInformation\\INF .
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Starting removal of ActiveX control {FD0EBBED-0C42-4D0F-82DA-44399B5C420A}
    C:\WINDOWS\Downloaded Program Files\download_xp.inf moved successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{FD0EBBED-0C42-4D0F-82DA-44399B5C420A}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{FD0EBBED-0C42-4D0F-82DA-44399B5C420A}\ not found.
    Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{FD0EBBED-0C42-4D0F-82DA-44399B5C420A}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{FD0EBBED-0C42-4D0F-82DA-44399B5C420A}\ not found.
    C:\WINDOWS\002235_.tmp deleted successfully.
    C:\WINDOWS\005017_.tmp deleted successfully.
    C:\WINDOWS\SET3.tmp deleted successfully.
    C:\WINDOWS\SET7.tmp deleted successfully.
    C:\WINDOWS\System32\CONFIG.TMP deleted successfully.
    C:\WINDOWS\system32\drivers\svwlyil.sys moved successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:7CA7BED1 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:78E0DF72 deleted successfully.
    Unable to delete ADS C:\Documents and Settings\All Users\Desktop:$SS_DESCRIPTOR_PBPUV9VK9V89VMRV5V4REABYEKLPH9E48E2R0T5PL34DBW FLM3TLVVVVVVVVVVJVK .
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:D1B5B4F1 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:370EF5E8 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:FB1B13D8 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:5AE33054 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:FB65A4AA deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:4DCAC4BC deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:57B2B96C deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:D31BE97C deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:260575F1 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:6F1F66C0 deleted successfully.
    [EMPTYTEMP]
    User: All Users
    User: Default User
    ->Temporary Internet Files folder emptied: 67 bytes
    ->Flash cache emptied: 41620 bytes
    User: LocalService
    ->Temp folder emptied: 66016 bytes
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: NetworkService
    ->Temp folder emptied: 13122 bytes
    ->Temporary Internet Files folder emptied: 49286 bytes
    User: Stuart Brodie
    ->Temp folder emptied: 11626307 bytes
    ->Temporary Internet Files folder emptied: 248964216 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 98610607 bytes
    ->Google Chrome cache emptied: 86042984 bytes
    ->Flash cache emptied: 1201926 bytes
    Windows Temp folder emptied: 2755499 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33728 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 429.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: LocalService
    User: Stuart Brodie
    OTL by OldTimer - Version 3.2.20.6 log created on 02142011_193857
    File move failed. C:\WINDOWS\temp\_avast5_\Webshlock.txt scheduled to be moved on reboot.
    C:\WINDOWS\temp\Perflib_Perfdata_ba4.dat moved successfully.
    Security Check log...
    Results of screen317's Security Check version 0.99.7
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Firewall Enabled!
    Anti-malware/Other Utilities Check:
    Java(TM) 6 Update 23
    Out of date Java installed!
    Adobe Flash Player 10.0.42.34
    Adobe Reader 9.4.1
    Out of date Adobe Reader installed!
    Process Check:
    objlist.exe by Laurent
    Windows Defender MSMpEng.exe
    Windows Defender MsMpEng.exe
    Alwil Software Avast5 AvastSvc.exe
    Alwil Software Avast5 avastUI.exe
    ``````````End of Log````````````
    Temp File Cleaner done.
    I will start the ESET scanner shortly & paste the results in the morning.
  10. 2011/02/14
    Update Firefox to the latest 3.6.13 version.
    Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions.
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader (33.5 MB), download and install Foxit PDF Reader(3.5MB) from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or other garbage.
  11. 2011/02/15
    Caveman
    ESET log
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\Game Pack.rar Win32/ReflexiveArcade application
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXAuthor.exe NSIS/TrojanDownloader.Agent.NBS.Gen trojan
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXInstaller.exe NSIS/TrojanDownloader.Agent.NBS.Gen trojan
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\For Backup\Build A Lot 4-Power Source\Build A Lot 4-Power source.exe a variant of Win32/Kryptik.GTW trojan
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\For Backup\QBEEZ 2 FULL GAME\QBEEZ 2\GAME\Keygen.exe a variant of Win32/Keygen.BG application
    C:\Program Files\Games\Build A Lot 4-Power source\Buildalot4.exe a variant of Win32/Kryptik.GTW trojan
    C:\Program Files\Games\Cooking Dash 2 - DinerTown Studios\cookingdash2.exe a variant of Win32/Kryptik.GTW trojan
    C:\Program Files\Ubisoft\Tom Clancy's Splinter Cell Conviction\src\system\ubiorbitapi_r2.dll a variant of Win32/Packed.VMProtect.AAA trojan
    C:\System Volume Information\_restore{C12F34CB-2335-49E8-9024-0865B2C7801E}\RP10\A0005666.exe a variant of Win32/Keygen.BG application
    D:\Shared\Alien Shooter ALL a variant of Win32/Keygen.BG application
    D:\Shared\Alien Shooter ALL (my collection) -7in1- and Bonus\Games\Alien Shooter ALL\Alien Shooter ALL\Alien Shooter v1.1 Keygen.exe a variant of Win32/Keygen.BG application
    D:\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXAuthor.exe NSIS/TrojanDownloader.Agent.NBS.Gen trojan
    D:\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXInstaller.exe NSIS/TrojanDownloader.Agent.NBS.Gen trojan
    D:\Shared\For Backup\Build A Lot 4-Power Source\Build A Lot 4-Power source.exe a variant of Win32/Kryptik.GTW trojan
    D:\Shared\For Backup\QBEEZ 2 FULL GAME\QBEEZ 2\GAME\Keygen.exe a variant of Win32/Keygen.BG application
  12. 2011/02/15
    Caveman
    Firefox & Adobe Reader updated
  13. 2011/02/15
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
  14. 2011/02/16
    Caveman
    OTL Logs... I'll complete the other steps tomorrow
    ========== FILES ==========
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\Game Pack.rar moved successfully.
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXAuthor.exe moved successfully.
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXInstaller.exe moved successfully.
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\For Backup\Build A Lot 4-Power Source\Build A Lot 4-Power source.exe moved successfully.
    C:\Documents and Settings\Stuart Brodie\Desktop\Shared\For Backup\QBEEZ 2 FULL GAME\QBEEZ 2\GAME\Keygen.exe moved successfully.
    C:\Program Files\Games\Build A Lot 4-Power source\Buildalot4.exe moved successfully.
    C:\Program Files\Games\Cooking Dash 2 - DinerTown Studios\cookingdash2.exe moved successfully.
    C:\Program Files\Ubisoft\Tom Clancy's Splinter Cell Conviction\src\system\ubiorbitapi_r2.dll moved successfully.
    File\Folder C:\System Volume Information\_restore{C12F34CB-2335-49E8-9024-0865B2C7801E}\RP10\A0005666.exe not found.
    File\Folder D:\Shared\Alien Shooter ALL (my collection) -7in1- and Bonus\Games\Alien Shooter ALL\Alien Shooter ALL\Alien Shooter v1.1 Keygen.exe not found.
    D:\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXAuthor.exe moved successfully.
    D:\Shared\DivX Professional AuthoR\DivX Professional AuthoR\DivXInstaller.exe moved successfully.
    D:\Shared\For Backup\Build A Lot 4-Power Source\Build A Lot 4-Power source.exe moved successfully.
    D:\Shared\For Backup\QBEEZ 2 FULL GAME\QBEEZ 2\GAME\Keygen.exe moved successfully.
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: LocalService
    ->Temp folder emptied: 896 bytes
    User: Stuart Brodie
    ->Temp folder emptied: 589600 bytes
    ->Temporary Internet Files folder emptied: 18283544 bytes
    ->FireFox cache emptied: 0 bytes
    ->Google Chrome cache emptied: 0 bytes
    ->Flash cache emptied: 456 bytes
    Windows Temp folder emptied: 33576 bytes
    Total Files Cleaned = 18.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: LocalService
    User: Stuart Brodie
    OTL by OldTimer - Version 3.2.20.6 log created on 02162011_220811
    C:\WINDOWS\temp\Perflib_Perfdata_d78.dat moved successfully.
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: LocalService
    User: Stuart Brodie
    ->Temp folder emptied: 587891 bytes
    ->Temporary Internet Files folder emptied: 2028923 bytes
    Windows Temp folder emptied: 16384 bytes
    Total Files Cleaned = 3.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: LocalService
    User: Stuart Brodie
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.20.6 log created on 02162011_221507
    C:\WINDOWS\temp\Perflib_Perfdata_9c4.dat moved successfully.
  15. 2011/02/16
    No problem :)
    Caveman likes this.
  16. 2011/02/17
    Caveman
    OTL cleanup done & recommended programs installed.
    I'll post again in a few days and let you know how it has been behaving, but I would like to thank you for your help with this so far.
  17. 2011/02/17
    You're very welcome :)
    Let me know.....
  18. 2011/02/22
    The issue seems to be resolved.
