Solved Problems when booting up [Rootkit]
Discussion in 'Malware and Virus Removal Archive' started by Caveman, 2011/02/06.
  1. 2011/02/06
    Caveman
    Caveman Inactive Thread Starter
    [Resolved] Problems when booting up [Rootkit]
    I'm hoping that someone on here might be able to help me with a problem that is causing me to tear out what little hair I have left.
    Over the last few days my PC which have served me for a few years has started causing a few problems when I try to power up or reboot.
    It is sticking at one of the 1st pages with the black background. Usually it will be on the page starting with 'PCI Device Listing' - 'Verifying DMI Pool Data'
    It will hang on that page for 3-4 minutes then a message showing 'Couldn't open drive multi(0)disk(0)rdisk(0)partition(1) - NTLDR: Couldn't open drive multi(0)disk(0)rdisk(0)partition(1)'
    It then freezes. Sometimes it will display the page stating that Windows has encountered an error.... then the options to start in Safe Mode, Normally or with last known good settings. Sometimes it will just change to a black screen. It freezes on these pages.
    The only way I have managed to start Windows is by continuously pressing the power reset button for about 30 minutes (And I don't think that is doing much good to the machine)
    I have tried putting the Windows disc in the tray in the hope of using the Recovery Console, but it freezes when I select to boot from CD and will not load it at all.
    It might be worth mentioning that I ran an Avast scan yesterday and it found the following viruses;
    Win32:Rootkit-gen[Rtk] and
    Win32.VB PET.Drp
    Having read various discussions about the Rootkit virus, I followed advice and turned off the System Restore and rebooted (which took 30 minutes) then turned system restore back on. I did look for ur0.com in processes but it wasn't displayed.
    Does anyone have any ideas or suggestions please?
    Thanks in advance.
  2. 2011/02/06
    Welcome to WindowsBBS :)
    I've moved your thread to the Malware & Virus Removal forum. If you can follow the instructions under .....
    Please read this as indicated at the head of the forum and post the logs requested in this thread.
    If not please wait for a response from our malware analyst.
    Caveman
    Thanks Pete. I'm downloading all the programs now and will post the logs asap.
  5. 2011/02/06
    Caveman
    Here are all the logs. 1st the MBAM log;
    Malwarebytes' Anti-Malware 1.50.1.1100
    www.malwarebytes.org
    Database version: 5689
    Windows 5.1.2600 Service Pack 3
    Internet Explorer 8.0.6001.18702
    06/02/2011 15:24:23
    mbam-log-2011-02-06 (15-24-23).txt
    Scan type: Quick scan
    Objects scanned: 167992
    Time elapsed: 33 minute(s), 10 second(s)
    Memory Processes Infected: 1
    Memory Modules Infected: 18
    Registry Keys Infected: 1
    Registry Values Infected: 2
    Folders Infected: 24
    Files Infected: 220
    c:\program files\common files\comobject\lupdater.exe (Trojan.ObCom) -> 5636 -> Unloaded process successfully.
    c:\program files\common files\comobject\freebl3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\js3250.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\mozcrt19.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\nspr4.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\nss3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\nssckbi.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\nssdbm3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\nssutil3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\plc4.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\plds4.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\smime3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\softokn3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\sqlite3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\ssl3.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\xpcom.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\xul.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\components\browserdirprovider.dll (Trojan.ObCom) -> Delete on reboot.
    c:\program files\common files\comobject\components\brwsrcmp.dll (Trojan.ObCom) -> Delete on reboot.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\TaskMngr (Trojan.ObCom) -> Value: TaskMngr -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Terminal Server\Install\Software\Microsoft\Windows\CurrentVersion\Run\NVIDIA driver monitor (Backdoor.Agent) -> Value: NVIDIA driver monitor -> Quarantined and deleted successfully.
    (No malicious items detected)
    Folders Infected:
    c:\program files\common files\comobject (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\autoconfig (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\chrome (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\dictionaries (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\extensions (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd} (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\greprefs (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\plugins (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\dtd (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\html (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\uninstall (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\chrome (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\components (PUP.PlaySushi) -> Quarantined and deleted successfully.
    Files Infected:
    c:\program files\common files\comobject\blocklist.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\LICENSE (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\accessiblemarshal.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\application.ini (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\browserconfig.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\crashreporter-override.ini (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\crashreporter.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\crashreporter.ini (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\freebl3.chk (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\freebl3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\js3250.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\lupdater.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\mozcrt19.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nspr4.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nss3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nssckbi.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nssdbm3.chk (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nssdbm3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\nssutil3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\platform.ini (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\plc4.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\plds4.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\progressbar.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\README.txt (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\smime3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\softokn3.chk (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\softokn3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\SP.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\sqlite3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\ssl3.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\update.locale (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\updater.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\updater.ini (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\wSock.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\xpcom.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\xul.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\browser.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\browser.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\classic.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\classic.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\comm.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\comm.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\en-US.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\en-us.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\pippki.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\pippki.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\reporter.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\reporter.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\toolkit.jar (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\chrome\toolkit.manifest (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\browser.xpt (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\browserdirprovider.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\brwsrcmp.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\components.list (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\compreg.dat (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\feedconverter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\feedprocessor.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\feedwriter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\fuelapplication.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\gpsdgeolocationprovider.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\networkgeolocationprovider.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsaddonrepository.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsbadcerthandler.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsblocklistservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsbrowsercontenthandler.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsbrowserglue.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nscontentdispatchchooser.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nscontentprefservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsdownloadmanagerui.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsextensionmanager.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsformautocomplete.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nshandlerservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nshelperappdlg.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nslivemarkservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nslogininfo.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsloginmanager.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsloginmanagerprompter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsmicrosummaryservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsplacesautocomplete.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsplacesdbflush.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsplacestransactionsservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsprivatebrowsingservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsproxyautoconfig.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssafebrowsingapplication.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssearchservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssessionstartup.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssessionstore.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssetdefaultbrowser.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssidebar.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nstaggingservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nstrytoclose.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsupdateservice.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsupdateservicestub.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsupdatetimermanager.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\jsconsole-clhandler.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsdefaultclh.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nssearchsuggestions.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsurlclassifierlib.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsurlclassifierlistmanager.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nsurlformatter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\nswebhandlerapp.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\pluginglue.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\storage-legacy.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\storage-mozstorage.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\txexsltregexfunctions.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\webcontentconverter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\components\xpti.dat (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\autoconfig\platform.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\autoconfig\prefcalls.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref\channel-prefs.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref\firefox-branding.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref\firefox-l10n.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref\firefox.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\pref\reporter.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\bookmarks.html (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\localstore.rdf (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\mimetypes.rdf (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\prefs.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\chrome\userchrome-example.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\defaults\profile\chrome\usercontent-example.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\dictionaries\en-US.aff (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\dictionaries\en-US.dic (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}\icon.png (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}\install.rdf (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}\preview.png (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\greprefs\all.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\greprefs\security-prefs.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\greprefs\xpinstall.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\certutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\ctypes.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\debug.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\distribution.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\downloadlastdir.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\downloadutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\fileutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\iso8601dateutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\lightweightthemeconsumer.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\lightweightthememanager.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\microformats.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\NetUtil.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\networkprioritizer.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\openlocationlasturl.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\placesdbutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\pluralform.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\spatialnavigation.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\utils.js (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\windowdraggingutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\windowspreviewpertab.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\modules\xpcomutils.jsm (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\plugins\npbasic.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\plugins\npnul32.dll (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-after-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\arrow.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\arrowd.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\broken-image.png (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\charsetalias.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\charsetdata.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\contenteditable.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\designmode.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\editoroverride.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\forms.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\grabber.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\hiddenwindow.html (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\html.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\langgroups.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\language.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\loading-image.png (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\mathml.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\quirk.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\svg.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-after-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-after.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-before-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-before-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-column-before.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-after-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-after-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-after.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-before-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-before-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-add-row-before.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-column-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-column-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-column.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-row-active.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-row-hover.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\table-remove-row.gif (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\ua.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\viewsource.css (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\wincharset.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\dtd\mathml.dtd (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\dtd\xhtml11.dtd (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\html40latin1.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\html40special.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\html40symbols.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\htmlentityversions.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\mathml20.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\entitytables\transliterate.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfont.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfontstandardsymbolsl.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfontstixnonunicode.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfontstixsize1.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfontsymbol.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\fonts\mathfontunicode.properties (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\res\html\folder.png (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\amazondotcom.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\answers.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\creativecommons.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\eBay.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\google.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\wikipedia.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\searchplugins\yahoo.xml (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\program files\common files\comobject\uninstall\helper.exe (Trojan.ObCom) -> Quarantined and deleted successfully.
    c:\WINDOWS\wibrf.jpg (Malware.Trace) -> Quarantined and deleted successfully.
    c:\WINDOWS\wiybr.png (Malware.Trace) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\chrome.manifest (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\install.rdf (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\chrome\pstextlinks.jar (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\components\playsushiff.dll (PUP.PlaySushi) -> Quarantined and deleted successfully.
    c:\documents and settings\stuart brodie\application data\Mozilla\extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\components\playsushiff.xpt (PUP.PlaySushi) -> Quarantined and deleted successfully.
    Other logs to follow....
  6. 2011/02/06
    Caveman
    GMER log - Part 1
    GMER 1.0.15.15530 - http://www.gmer.net
    Rootkit scan 2011-02-06 17:53:00
    Windows 5.1.2600 Service Pack 3 Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3 Hitachi_HDP725025GLA380 rev.GM2OA52A
    Running: 27tyxko1.exe; Driver: C:\DOCUME~1\STUART~1\LOCALS~1\Temp\fxrcypog.sys
    ---- System - GMER 1.0.15 ----
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwAllocateVirtualMemory [0xF38BE728]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwAssignProcessToJobObject [0xF396CFE4]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwClose [0xF38C57EA]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwCreateFile [0xF396D996]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwCreateKey [0xF38C56A2]
    SSDT \??\C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\19917\RapportCerberus_19917.sys (RapportCerberus/Trusteer Ltd.) ZwCreateThread [0xF78EB864]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwDeleteFile [0xF396DAF6]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwDeleteKey [0xF38C5CA8]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwDeleteValueKey [0xF38C5BBE]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwDuplicateObject [0xF38C5276]
    SSDT spoy.sys ZwEnumerateKey [0xF7375DA4]
    SSDT spoy.sys ZwEnumerateValueKey [0xF7376132]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwFreeVirtualMemory [0xF38BE7D8]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwLoadKey [0xF3971500]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwOpenFile [0xF396DA5A]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwOpenKey [0xF38C577E]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwOpenProcess [0xF38C51B2]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwOpenThread [0xF38C5218]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwProtectVirtualMemory [0xF38BE870]
    SSDT spoy.sys ZwQueryKey [0xF737620A]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwQueryValueKey [0xF38C58C2]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwRenameKey [0xF38C5D76]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwReplaceKey [0xF3971412]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwRestoreKey [0xF38C5880]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwSetContextThread [0xF396CF8A]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwSetInformationFile [0xF396DB56]
    SSDT \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwSetValueKey [0xF38C5A04]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwSuspendThread [0xF396CF26]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwTerminateProcess [0xF396CE7A]
    SSDT \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys (RapportPG/Trusteer Ltd.) ZwTerminateThread [0xF396CEC2]
    INT 0x62 ? 873D8BF8
    INT 0x64 ? 87109F00
    INT 0x74 ? 87109F00
    INT 0x82 ? 873D8BF8
    INT 0x84 ? 87109F00
    INT 0xA4 ? 87109F00
    INT 0xB4 ? 873D8BF8
    INT 0xB4 ? 873D8BF8
    INT 0xB4 ? 87109F00
    INT 0xB4 ? 87109F00
    INT 0xB4 ? 873D8BF8
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwCreateProcessEx [0xF38D282E]
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwCreateSection [0xF38D2652]
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ZwLoadDriver [0xF38D278C]
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) NtCreateSection
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ObInsertObject
    Code \SystemRoot\System32\Drivers\aswSP.SYS (avast! self protection module/AVAST Software) ObMakeTemporaryObject
    ---- Kernel code sections - GMER 1.0.15 ----
    .text ntkrnlpa.exe!ZwCallbackReturn + 2C48 805044E4 4 Bytes JMP 48F38C57
    .text ntkrnlpa.exe!ZwCallbackReturn + 2E08 805046A4 4 Bytes CALL 683D3A34
    ? spoy.sys The system cannot find the file specified. !
    .text C:\WINDOWS\System32\DRIVERS\nv4_mini.sys section is writeable [0xF62B13A0, 0x5FE082, 0xE8000020]
    .text USBPORT.SYS!DllUnload F626E8AC 5 Bytes JMP 871094E0
    ---- User code sections - GMER 1.0.15 ----
    .text C:\WINDOWS\system32\spoolsv.exe[828] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\spoolsv.exe[828] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[840] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\alg.exe[920] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\winlogon.exe[968] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\services.exe[1016] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\lsass.exe[1028] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\nvsvc32.exe[1192] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1256] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\svchost.exe[1304] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program
  7. 2011/02/06
    Caveman
    Caveman Inactive Thread Starter
    GMER log part 2..
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MsMpEng.exe[1344] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ntdll.dll!KiUserApcDispatcher 7C90E450 5 Bytes JMP 00414C10 C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe (RapportMgmtService/Trusteer Ltd.)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] kernel32.dll!LoadLibraryExW 7C801AF5 5 Bytes JMP 716B0022
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!GetGUIThreadInfo + FB 7E428023 6 Bytes JMP 716E001E
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] WS2_32.dll!getaddrinfo 71AB2A6F 5 Bytes JMP 71650022
    .text C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe[1384] WS2_32.dll!gethostbyname 71AB5355 5 Bytes JMP 71680022
    .text C:\WINDOWS\System32\svchost.exe[1452] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1452] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1688] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[1732] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Alwil Software\Avast5\AvastSvc.exe[1920] kernel32.dll!SetUnhandledExceptionFilter 7C84495D 4 Bytes [C2, 04, 00, 90] {RET 0x4; NOP }
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe[2172] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe[2188] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\LightScribe\LSSrvc.exe[2324] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE[2380] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wbem\wmiprvse.exe[2412] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe[2428] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ntdll.dll!LdrUnloadDll
  8. 2011/02/06
    Caveman
    GMER log part 3...
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\Explorer.EXE[2480] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe[2588] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrA.exe[2636] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\PnkBstrB.exe[2756] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\WinPcap\rpcapd.exe[2784] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Messenger\msmsgs.exe[2816] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[2824] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE[2948] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Documents and Settings\Stuart Brodie\Desktop\27tyxko1.exe[3096] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Documents and Settings\Stuart Brodie\Desktop\27tyxko1.exe[3096] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] kernel32.dll!WriteFile 7C810E27 7 Bytes JMP 00585C0C C:\WINDOWS\system32\MSSRCH.DLL (mssrch.dll/Microsoft Corporation)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\SearchIndexer.exe[3184] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe[3572] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program
  9. 2011/02/06
    Caveman
    Caveman Inactive Thread Starter
    GMER log part 4...
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Logitech\SetPoint\SetPoint.exe[3824] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ntdll.dll!KiUserApcDispatcher 7C90E450 5 Bytes JMP 004397C0 C:\Program Files\Trusteer\Rapport\bin\RapportService.exe (RapportService/Trusteer Ltd.)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] kernel32.dll!LoadLibraryExW 7C801AF5 5 Bytes JMP 716B0022
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] WS2_32.dll!getaddrinfo 71AB2A6F 5 Bytes JMP 71680022
    .text C:\Program Files\Trusteer\Rapport\bin\RapportService.exe[3992] WS2_32.dll!gethostbyname 71AB5355 5 Bytes JMP 716E0022
    .text C:\WINDOWS\System32\svchost.exe[4072] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\System32\svchost.exe[4072] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe[4136] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE[4376] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe[4504] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program
  10. 2011/02/06
    One of our trained malware analysts will take a look at your logs ASAP, but it may be a day or so before you get a response as they are always very busy. All logs are dealt with in the order received.
    Thank you for your patience.
  11. 2011/02/06
    Caveman
    GMER log...final part..
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\ndis_events.exe[4544] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Windows Defender\MSASCui.exe[4664] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\RTHDCPL.EXE[4676] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\ctfmon.exe[5024] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\RUNDLL32.EXE[5308] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe[5996] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] kernel32.dll!SetUnhandledExceptionFilter 7C84495D 5 Bytes [33, C0, C2, 04, 00] {XOR EAX, EAX; RET 0x4}
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\program files\real\realplayer\update\realsched.exe[7680] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe[8112] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ntdll.dll!LdrLoadDll 7C9163C3 5 Bytes JMP 64D06950 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ntdll.dll!LdrUnloadDll 7C91738B 5 Bytes JMP 64D069B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] USER32.dll!SetWindowsHookExW 7E42820F 5 Bytes JMP 64D0BB30 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] USER32.dll!UnhookWindowsHookEx 7E42D5F3 5 Bytes JMP 64D0BCB0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] USER32.dll!SetWindowsHookExA 7E431211 5 Bytes JMP 64D0B9B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] USER32.dll!SetWinEventHook 7E4317F7 5 Bytes JMP 64D0B720 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] USER32.dll!UnhookWinEvent 7E4318AC 5 Bytes JMP 64D0B8A0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!SetServiceObjectSecurity 77E36D81 5 Bytes JMP 64D09D40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!ChangeServiceConfigA 77E36E69 5 Bytes JMP 64D07AE0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!ChangeServiceConfigW 77E37001 5 Bytes JMP 64D07ED0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!ChangeServiceConfig2A 77E37101 5 Bytes JMP 64D08290 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!ChangeServiceConfig2W 77E37189 5 Bytes JMP 64D083C0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!CreateServiceA 77E37211 5 Bytes JMP 64D06E40 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!CreateServiceW 77E373A9 5 Bytes JMP 64D072B0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    .text C:\WINDOWS\system32\wscntfy.exe[11088] ADVAPI32.dll!DeleteService 77E374B1 5 Bytes JMP 64D078E0 C:\Program Files\Alwil Software\Avast5\snxhk.dll (avast! snxhk/AVAST Software)
    ---- Kernel IAT/EAT - GMER 1.0.15 ----
    IAT atapi.sys[HAL.dll!READ_PORT_UCHAR] [F735E042] spoy.sys
    IAT atapi.sys[HAL.dll!READ_PORT_BUFFER_USHORT] [F735E13E] spoy.sys
    IAT atapi.sys[HAL.dll!READ_PORT_USHORT] [F735E0C0] spoy.sys
    IAT atapi.sys[HAL.dll!WRITE_PORT_BUFFER_USHORT] [F735E800] spoy.sys
    IAT atapi.sys[HAL.dll!WRITE_PORT_UCHAR] [F735E6D6] spoy.sys
    ---- User IAT/EAT - GMER 1.0.15 ----
    IAT C:\WINDOWS\system32\services.exe[1016] @ C:\WINDOWS\system32\services.exe [ADVAPI32.dll!CreateProcessAsUserW] 00600002
    IAT C:\WINDOWS\system32\services.exe[1016] @ C:\WINDOWS\system32\services.exe [KERNEL32.dll!CreateProcessW] 00600000
    ---- Devices - GMER 1.0.15 ----
    Device aswSP.SYS (avast! self protection module/AVAST Software)
    Device 873D71F8
    Device Ntfs.sys (NT File System Driver/Microsoft Corporation)
    AttachedDevice \Driver\Tcpip \Device\Ip aswTdi.SYS (avast! TDI Filter Driver/AVAST Software)
    Device \Driver\usbuhci \Device\USBPDO-0 8713D1F8
    Device \Driver\usbuhci \Device\USBPDO-1 8713D1F8
    Device \Driver\usbuhci \Device\USBPDO-2 8713D1F8
    Device \Driver\usbuhci \Device\USBPDO-3 8713D1F8
    Device \Driver\usbehci \Device\USBPDO-4 870ED500
    AttachedDevice \Driver\Tcpip \Device\Tcp aswTdi.SYS (avast! TDI Filter Driver/AVAST Software)
    Device \Driver\usbuhci \Device\USBPDO-5 8713D1F8
    Device \Driver\usbuhci \Device\USBPDO-6 8713D1F8
    Device \Driver\Ftdisk \Device\HarddiskVolume1 873681F8
    Device \Driver\usbehci \Device\USBPDO-7 870ED500
    Device \Driver\NetBT \Device\NetBT_Tcpip_{4A50AAA5-5728-49F4-96A9-CBCE88FEBCFA} 86C701F8
    Device \Driver\Ftdisk \Device\HarddiskVolume2 873681F8
    Device \Driver\Cdrom \Device\CdRom0 870D7500
    Device \Driver\atapi \Device\Ide\IdeDeviceP0T0L0-3 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdePort0 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdeDeviceP2T0L0-1b [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdePort1 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdePort2 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdePort3 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\atapi \Device\Ide\IdeDeviceP3T0L0-10 [F72D7B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
    Device \Driver\NetBT \Device\NetBT_Tcpip_{2B999677-CC3E-49A5-9AB9-B10696C13742} 86C701F8
    Device \Driver\NetBT \Device\NetBt_Wins_Export 86C701F8
    Device \Driver\NetBT \Device\NetbiosSmb 86C701F8
    AttachedDevice \Driver\Tcpip \Device\Udp aswTdi.SYS (avast! TDI Filter Driver/AVAST Software)
    AttachedDevice \Driver\Tcpip \Device\RawIp aswTdi.SYS (avast! TDI Filter Driver/AVAST Software)
    Device \Driver\usbuhci \Device\USBFDO-0 8713D1F8
    Device \Driver\usbuhci \Device\USBFDO-1 8713D1F8
    Device \FileSystem\MRxSmb \Device\LanmanDatagramReceiver 86C521F8
    Device \Driver\usbuhci \Device\USBFDO-2 8713D1F8
    Device 86C521F8
    Device \Driver\usbuhci \Device\USBFDO-3 8713D1F8
    Device \Driver\usbehci \Device\USBFDO-4 870ED500
    Device \Driver\Ftdisk \Device\FtControl 873681F8
    Device \Driver\usbuhci \Device\USBFDO-5 8713D1F8
    Device \Driver\usbuhci \Device\USBFDO-6 8713D1F8
    Device \Driver\usbehci \Device\USBFDO-7 870ED500
    Device \FileSystem\Cdfs \Cdfs 86C3D500
    ---- Registry - GMER 1.0.15 ----
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 1
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x8A 0x6A 0x9D 0xA9 ...
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@u0 0x5B 0x45 0x00 0x00 ...
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@h0 0
    Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@hdf12 0x35 0xF0 0x43 0x96 ...
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 1
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x8A 0x6A 0x9D 0xA9 ...
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@u0 0x5B 0x45 0x00 0x00 ...
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@h0 0
    Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@hdf12 0x35 0xF0 0x43 0x96 ...
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s1 771343423
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s2 285507792
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@h0 2
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 1
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x8A 0x6A 0x9D 0xA9 ...
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@u0 0x5B 0x45 0x00 0x00 ...
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@h0 0
    Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@hdf12 0x35 0xF0 0x43 0x96 ...
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 1
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x8A 0x6A 0x9D 0xA9 ...
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC (not active ControlSet)
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@u0 0x5B 0x45 0x00 0x00 ...
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@h0 0
    Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC@hdf12 0x35 0xF0 0x43 0x96 ...
    ---- Files - GMER 1.0.15 ----
    File C:\Documents and Settings\Stuart Brodie\Local Settings\Temporary Internet Files\Content.IE5\UF6TGKB4\109[1] 77 bytes
    ---- EOF - GMER 1.0.15 ----
  12. 2011/02/06
    Caveman
    MBR check -
    MBRCheck, version 1.2.3
    (c) 2010, AD
    Command-line:
    Windows Version: Windows XP Home Edition
    Windows Information: Service Pack 3 (build 2600)
    Logical Drives Mask: 0x000001fc
    Kernel Drivers (total 133):
    0x804D7000 \WINDOWS\system32\ntkrnlpa.exe
    0x806E4000 \WINDOWS\system32\hal.dll
    0xF7A50000 \WINDOWS\system32\KDCOM.DLL
    0xF7960000 \WINDOWS\system32\BOOTVID.dll
    0xF735C000 spoy.sys
    0xF7A52000 \WINDOWS\System32\Drivers\WMILIB.SYS
    0xF7344000 \WINDOWS\System32\Drivers\SCSIPORT.SYS
    0xF7316000 ACPI.sys
    0xF7305000 pci.sys
    0xF7550000 ohci1394.sys
    0xF7560000 \WINDOWS\System32\DRIVERS\1394BUS.SYS
    0xF7570000 isapnp.sys
    0xF7B18000 pciide.sys
    0xF77D0000 \WINDOWS\System32\DRIVERS\PCIIDEX.SYS
    0xF7A54000 viaide.sys
    0xF7580000 MountMgr.sys
    0xF72E6000 ftdisk.sys
    0xF77D8000 PartMgr.sys
    0xF77E0000 videX32.sys
    0xF7590000 VolSnap.sys
    0xF72CE000 atapi.sys
    0xF75A0000 disk.sys
    0xF75B0000 \WINDOWS\System32\DRIVERS\CLASSPNP.SYS
    0xF72AE000 fltmgr.sys
    0xF729C000 sr.sys
    0xF75C0000 xfilt.sys
    0xF7285000 KSecDD.sys
    0xF71F8000 Ntfs.sys
    0xF71CB000 NDIS.sys
    0xF75D0000 RapportKELL.sys
    0xF7A56000 \WINDOWS\System32\Drivers\USBD.SYS
    0xF71B1000 Mup.sys
    0xF7630000 \SystemRoot\System32\DRIVERS\intelppm.sys
    0xF62B1000 \SystemRoot\System32\DRIVERS\nv4_mini.sys
    0xF629D000 \SystemRoot\System32\DRIVERS\VIDEOPRT.SYS
    0xF7640000 \SystemRoot\System32\DRIVERS\imapi.sys
    0xF7650000 \SystemRoot\System32\DRIVERS\cdrom.sys
    0xF7660000 \SystemRoot\System32\DRIVERS\redbook.sys
    0xF627A000 \SystemRoot\System32\DRIVERS\ks.sys
    0xF7850000 \SystemRoot\System32\DRIVERS\usbuhci.sys
    0xF6256000 \SystemRoot\System32\DRIVERS\USBPORT.SYS
    0xF7858000 \SystemRoot\System32\DRIVERS\usbehci.sys
    0xF7670000 \SystemRoot\System32\DRIVERS\fetnd5bv.sys
    0xF6231000 \SystemRoot\System32\DRIVERS\HDAudBus.sys
    0xF7680000 \SystemRoot\System32\DRIVERS\nic1394.sys
    0xF7690000 \SystemRoot\System32\DRIVERS\serial.sys
    0xF7179000 \SystemRoot\System32\DRIVERS\serenum.sys
    0xF7C2E000 \SystemRoot\System32\DRIVERS\audstub.sys
    0xF76A0000 \SystemRoot\System32\DRIVERS\rasl2tp.sys
    0xF7175000 \SystemRoot\System32\DRIVERS\ndistapi.sys
    0xF621A000 \SystemRoot\System32\DRIVERS\ndiswan.sys
    0xF76B0000 \SystemRoot\System32\DRIVERS\raspppoe.sys
    0xF76C0000 \SystemRoot\System32\DRIVERS\raspptp.sys
    0xF7870000 \SystemRoot\System32\DRIVERS\TDI.SYS
    0xF6209000 \SystemRoot\System32\DRIVERS\psched.sys
    0xF76D0000 \SystemRoot\System32\DRIVERS\msgpc.sys
    0xF7878000 \SystemRoot\System32\DRIVERS\ptilink.sys
    0xF7880000 \SystemRoot\System32\DRIVERS\raspti.sys
    0xF76E0000 \SystemRoot\System32\DRIVERS\termdd.sys
    0xF7888000 \SystemRoot\System32\DRIVERS\kbdclass.sys
    0xF7890000 \SystemRoot\System32\DRIVERS\mouclass.sys
    0xF7A9C000 \SystemRoot\System32\DRIVERS\swenum.sys
    0xF61AB000 \SystemRoot\System32\DRIVERS\update.sys
    0xF7169000 \SystemRoot\System32\DRIVERS\mssmbios.sys
    0xF7700000 \SystemRoot\System32\Drivers\NDProxy.SYS
    0xF7720000 \SystemRoot\System32\DRIVERS\usbhub.sys
    0xF3C20000 \SystemRoot\system32\drivers\RtkHDAud.sys
    0xF3BFC000 \SystemRoot\system32\drivers\portcls.sys
    0xF7730000 \SystemRoot\system32\drivers\drmk.sys
    0xF7AB0000 \SystemRoot\System32\Drivers\Fs_Rec.SYS
    0xF7B9E000 \SystemRoot\System32\Drivers\Null.SYS
    0xF7AB2000 \SystemRoot\System32\Drivers\Beep.SYS
    0xF78C0000 \SystemRoot\System32\DRIVERS\HIDPARSE.SYS
    0xF78C8000 \SystemRoot\System32\drivers\vga.sys
    0xF7AB4000 \SystemRoot\System32\Drivers\mnmdd.SYS
    0xF7AB6000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
    0xF78D0000 \SystemRoot\System32\Drivers\Msfs.SYS
    0xF78D8000 \SystemRoot\System32\Drivers\Npfs.SYS
    0xF7A3C000 \SystemRoot\System32\DRIVERS\rasacd.sys
    0xF3BA1000 \SystemRoot\System32\DRIVERS\ipsec.sys
    0xF3B48000 \SystemRoot\System32\DRIVERS\tcpip.sys
    0xF7750000 \SystemRoot\System32\Drivers\aswTdi.SYS
    0xF3B22000 \SystemRoot\System32\DRIVERS\ipnat.sys
    0xF3AD2000 \SystemRoot\System32\DRIVERS\netbt.sys
    0xF7760000 \SystemRoot\System32\DRIVERS\wanarp.sys
    0xF78E0000 \SystemRoot\System32\Drivers\aswRdr.SYS
    0xF3AB0000 \SystemRoot\System32\drivers\afd.sys
    0xF7770000 \SystemRoot\System32\DRIVERS\netbios.sys
    0xF7780000 \SystemRoot\System32\DRIVERS\arp1394.sys
    0xF77A0000 \SystemRoot\System32\Drivers\SCDEmu.SYS
    0xF3995000 \SystemRoot\System32\DRIVERS\rdbss.sys
    0xF396C000 \??\C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys
    0xF78E8000 \??\C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\19917\RapportCerberus_19917.sys
    0xF38FC000 \SystemRoot\System32\DRIVERS\mrxsmb.sys
    0xF77B0000 \SystemRoot\System32\Drivers\Fips.SYS
    0xF38B5000 \SystemRoot\System32\Drivers\aswSP.SYS
    0xF78F8000 \SystemRoot\System32\Drivers\Aavmker4.SYS
    0xF7930000 \SystemRoot\System32\DRIVERS\usbccgp.sys
    0xF6C90000 \SystemRoot\System32\Drivers\Cdfs.SYS
    0xF39C8000 \SystemRoot\System32\DRIVERS\hidusb.sys
    0xF6C80000 \SystemRoot\System32\DRIVERS\HIDCLASS.SYS
    0xF3839000 \SystemRoot\system32\DRIVERS\RTL8187B.sys
    0xF7940000 \SystemRoot\system32\DRIVERS\LHidFilt.Sys
    0xF6C70000 \SystemRoot\system32\DRIVERS\WDFLDR.SYS
    0xF37BE000 \SystemRoot\system32\DRIVERS\Wdf01000.sys
    0xF39C0000 \SystemRoot\System32\DRIVERS\kbdhid.sys
    0xF38B1000 \SystemRoot\System32\DRIVERS\mouhid.sys
    0xF7950000 \SystemRoot\system32\DRIVERS\LMouFilt.Sys
    0xF37A6000 \SystemRoot\System32\Drivers\dump_atapi.sys
    0xF7B0C000 \SystemRoot\System32\Drivers\dump_WMILIB.SYS
    0xBF800000 \SystemRoot\System32\win32k.sys
    0xF389D000 \SystemRoot\System32\drivers\Dxapi.sys
    0xF7828000 \SystemRoot\System32\watchdog.sys
    0xBD000000 \SystemRoot\System32\drivers\dxg.sys
    0xF7BF3000 \SystemRoot\System32\drivers\dxgthk.sys
    0xBD012000 \SystemRoot\System32\nv4_disp.dll
    0xBFFA0000 \SystemRoot\System32\ATMFD.DLL
    0xB7E02000 \SystemRoot\System32\Drivers\aswFsBlk.SYS
    0xF7938000 \SystemRoot\system32\DRIVERS\AegisP.sys
    0xB7BEA000 \SystemRoot\system32\DRIVERS\EAPPkt.sys
    0xB7CAE000 \SystemRoot\System32\DRIVERS\ndisuio.sys
    0xB7AAB000 \SystemRoot\System32\Drivers\aswMon2.SYS
    0xB743E000 \SystemRoot\System32\DRIVERS\mrxdav.sys
    0xB7401000 \SystemRoot\system32\drivers\wdmaud.sys
    0xB789B000 \SystemRoot\system32\drivers\sysaudio.sys
    0xB7011000 \SystemRoot\System32\DRIVERS\srv.sys
    0xF7830000 \SystemRoot\system32\drivers\npf.sys
    0xB69F1000 \SystemRoot\System32\Drivers\HTTP.sys
    0xB730B000 \SystemRoot\System32\Drivers\AFGSp50.sys
    0xAF1A3000 \??\C:\DOCUME~1\STUART~1\LOCALS~1\Temp\fxrcypog.sys
    0xB221B000 \??\C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportMS\21923\RapportIaso.sys
    0xAE810000 \SystemRoot\system32\drivers\kmixer.sys
    0x7C900000 \WINDOWS\system32\ntdll.dll
    Processes (total 57):
    0 System Idle Process
    4 System
    740 C:\WINDOWS\system32\smss.exe
    944 csrss.exe
    968 C:\WINDOWS\system32\winlogon.exe
    1016 C:\WINDOWS\system32\services.exe
    1028 C:\WINDOWS\system32\lsass.exe
    1192 C:\WINDOWS\system32\nvsvc32.exe
    1256 C:\WINDOWS\system32\svchost.exe
    1304 svchost.exe
    1344 C:\Program Files\Windows Defender\MsMpEng.exe
    1384 C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe
    1452 C:\WINDOWS\system32\svchost.exe
    1688 svchost.exe
    1732 svchost.exe
    1920 C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
    828 C:\WINDOWS\system32\spoolsv.exe
    840 svchost.exe
    2172 C:\Program Files\Virgin Broadband Wireless\AffinegyService.exe
    2188 C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemaNowSvc.exe
    2324 C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    2380 C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    2428 C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe
    2588 C:\Program Files\Common Files\PC Tools\sMonitor\StartManSvc.exe
    2636 C:\WINDOWS\system32\PnkBstrA.exe
    2756 C:\WINDOWS\system32\PnkBstrB.exe
    2784 C:\Program Files\WinPcap\rpcapd.exe
    2824 C:\WINDOWS\system32\svchost.exe
    2948 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
    3184 C:\WINDOWS\system32\searchindexer.exe
    3572 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE
    920 alg.exe
    2412 wmiprvse.exe
    4072 C:\WINDOWS\system32\svchost.exe
    2480 C:\WINDOWS\explorer.exe
    3992 C:\Program Files\Trusteer\Rapport\bin\RapportService.exe
    4676 C:\WINDOWS\RTHDCPL.exe
    5996 C:\Program Files\Virgin Broadband Wireless\Wireless Manager.exe
    4136 C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
    4664 C:\Program Files\Windows Defender\MSASCui.exe
    4544 C:\Program Files\Virgin Broadband Wireless\ndis_events.exe
    4504 C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    5024 C:\WINDOWS\system32\ctfmon.exe
    7680 C:\Program Files\Real\RealPlayer\Update\realsched.exe
    5308 C:\WINDOWS\system32\rundll32.exe
    2816 C:\Program Files\Messenger\msmsgs.exe
    3824 C:\Program Files\Logitech\SetPoint\SetPoint.exe
    8112 C:\Program Files\Micronet SP907GK Wireless Network Utility\RtWLan.exe
    4376 C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.exe
    4220 C:\PROGRA~1\ALWILS~1\Avast5\AvastUI.exe
    12272 C:\Program Files\Virgin Broadband Wireless\wpa_supplicant.exe
    1856 C:\Program Files\Internet Explorer\iexplore.exe
    8452 C:\Program Files\Internet Explorer\iexplore.exe
    8240 C:\Program Files\Internet Explorer\iexplore.exe
    2108 C:\WINDOWS\system32\searchprotocolhost.exe
    6728 searchfilterhost.exe
    7808 C:\Documents and Settings\Stuart Brodie\Desktop\MBRCheck.exe
    \\.\C: --> \\.\PhysicalDrive0 at offset 0x00000000`00007e00 (NTFS)
    \\.\D: --> \\.\PhysicalDrive1 at offset 0x00000000`00007e00 (NTFS)
    PhysicalDrive0 Model Number: HitachiHDP725025GLA380, Rev: GM2OA52A
    PhysicalDrive1 Model Number: HDS722580VLAT20, Rev: V32OA60A
    Size Device Name MBR Status
    232 GB \\.\PhysicalDrive0 Windows XP MBR code detected
    SHA1: DA38B874B7713D1B51CBC449F4EF809B0DEC644A
    76 GB \\.\PhysicalDrive1 Windows XP MBR code detected
    Done!
    DDS txt log
    DDS (Ver_10-12-12.02) - NTFSx86
    Run by Stuart Brodie at 18:47:22.14 on 06/02/2011
    Internet Explorer: 8.0.6001.18702
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.44.1033.18.1022.281 [GMT 0:00]
    AV: avast! Antivirus *Enabled/Updated* {7591DB91-41F0-48A3-B128-1A293FD8233D}
    C:\WINDOWS\System32\nvsvc32.exe
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    svchost.exe
    svchost.exe
    svchost.exe
    C:\Program Files\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe
    C:\WINDOWS\System32\svchost.exe -k imgsvc
    C:\WINDOWS\system32\SearchIndexer.exe
    C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
    C:\WINDOWS\System32\svchost.exe -k HTTPFilter
    C:\Program Files\Alwil Software\Avast5\AvastUI.exe
    C:\WINDOWS\system32\SearchProtocolHost.exe
    C:\Documents and Settings\Stuart Brodie\Desktop\dds.scr
    uStart Page = hxxp://www.msn.co.uk/
    uInternet Connection Wizard,ShellNext = iexplore
    BHO: vShare Plugin: {043c5167-00bb-4324-af7e-62013faedacf} - c:\program files\vshare\vshare_toolbar.dll
    BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
    BHO: PlaySushi: {21608b66-026f-4dcb-9244-0daca328dced} - c:\program files\playsushi\PSText.dll
    BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\documents and settings\all users\application data\real\realplayer\browserrecordplugin\ie\rpbrowserrecordplugin.dll
    BHO: {5C255C8A-E604-49b4-9D64-90988571CECB} - No File
    BHO: Windows Live ID Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - c:\program files\common files\microsoft shared\windows live\WindowsLiveLogin.dll
    BHO: Skype add-on for Internet Explorer: {ae805869-2e5c-4ed4-8f7b-f1f7851a4497} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    TB: vShare Plugin: {043c5167-00bb-4324-af7e-62013faedacf} - c:\program files\vshare\vshare_toolbar.dll
    TB: {D4027C7F-154A-4066-A1AD-4243D8127440} - No File
    EB: Encarta &Researcher: {9455301c-cf6b-11d3-a266-00c04f689c50} - c:\program files\common files\microsoft shared\encarta researcher\EROPROJ.DLL
    EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
    uRun: [MSMSGS] "c:\program files\messenger\msmsgs.exe" /background
    uRun: [LightScribe Control Panel] c:\program files\common files\lightscribe\LightScribeControlPanel.exe -hidden
    uRun: [igndlm.exe] c:\program files\download manager\DLM.exe /windowsstart /startifwork
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    uRun: [NVIDIA driver monitor] c:\windows\nvsvc32.exe
    mRun: [RTHDCPL] RTHDCPL.EXE
    mRun: [Alcmtr] ALCMTR.EXE
    mRun: [avast5] c:\progra~1\alwils~1\avast5\avastUI.exe /nogui
    mRun: [Wireless Manager] "c:\program files\virgin broadband wireless\Wireless Manager.exe" startup
    mRun: [Name of App] c:\program files\samsung\fw liveupdate\FWManager.exe r
    mRun: [RemoteControl] "c:\program files\cyberlink\powerdvd\PDVDServ.exe "
    mRun: [Windows Defender] "c:\program files\windows defender\MSASCui.exe" -hide
    mRun: [PWRISOVM.EXE] c:\program files\poweriso\PWRISOVM.EXE
    mRun: [Kernel and Hardware Abstraction Layer] KHALMNPR.EXE
    mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
    mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
    mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe "
    mRun: [Adobe ARM] "c:\program files\common files\adobe\arm\1.0\AdobeARM.exe "
    mRun: [TkBellExe] "c:\program files\real\realplayer\update\realsched.exe" -osboot
    mRun: [QuickTime Task] "c:\program files\quicktime\qttask.exe" -atboottime
    mRun: [NvMediaCenter] RUNDLL32.EXE c:\windows\system32\NvMcTray.dll,NvTaskbarInit
    mRun: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
    mRun: [nwiz] c:\program files\nvidia corporation\nview\nwiz.exe /installquiet
    mRun: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
    mRun: [Malwarebytes' Anti-Malware (reboot)] "c:\program files\malwarebytes' anti-malware\mbam.exe" /runcleanupscript
    mRunOnce: [Malwarebytes' Anti-Malware] c:\program files\malwarebytes' anti-malware\mbamgui.exe /install /silent
    dRun: [DWQueuedReporting] "c:\progra~1\common~1\micros~1\dw\dwtrig20.exe" -t
    dRun: [ctfmon.exe] c:\windows\system32\CTFMON.EXE
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\logite~1.lnk - c:\program files\logitech\setpoint\SetPoint.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micron~1.lnk - c:\program files\micronet sp907gk wireless network utility\RtWLan.exe
    StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\window~1.lnk - c:\program files\windows desktop search\WindowsSearch.exe
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~4\office11\EXCEL.EXE/3000
    IE: Google Sidewiki... - c:\program files\google\google toolbar\component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll/cmsidewiki.html
    IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
    IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
    IE: {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - {5F7B1267-94A9-47F5-98DB-E99415F33AEC} - c:\program files\windows live\writer\WriterBrowserExtension.dll
    IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~4\office11\REFIEBAR.DLL
    IE: {9455301C-CF6B-11D3-A266-00C04F689C50} - {9455301C-CF6B-11D3-A266-00C04F689C50} - c:\program files\common files\microsoft shared\encarta researcher\EROPROJ.DLL
    IE: {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - c:\program files\playsushi\PSText.dll
    DPF: {0067DBFC-A752-458C-AE6E-B9C7E63D4824} - hxxp://www.logitech.com/devicedetector/plugins/LogitechDeviceDetection32.cab
    DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} - hxxp://download.microsoft.com/download/C/B/F/CBF23A2C-3E55-4664-BC5C-762780D79BA0/OGAControl.cab
    DPF: {166B1BCA-3F9C-11CF-8075-444553540000} - hxxp://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/C/0/C/C0CBBA88-A6F2-48D9-9B0E-1719D1177202/LegitCheckControl.cab
    DPF: {1E3F1348-4370-4BBE-A67A-CC7ED824CA85} - hxxp://download.microsoft.com/download/7/4/9/749b0dc5-2175-4d5b-a6dd-9c4bc923683e/Selfhelpcontrol.cab
    DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} - hxxp://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab
    DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} - hxxp://www.fileplanet.com/fpdlmgr/cabs/FPDC_2.3.10.115.cab
    DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} - hxxp://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1265459512921
    DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - hxxp://www.update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1265463721312
    DPF: {74DBCB52-F298-4110-951D-AD2FF67BC8AB} - hxxp://www.nvidia.com/content/DriverDownload/nforce/NvidiaSmartScan.cab
    DPF: {809A6301-7B40-4436-A02C-87B8D3D7D9E3} - hxxp://zone.msn.com/bingame/zpagames/zpa_dmno.cab55579.cab
    DPF: {80B626D6-BC34-4BCF-B5A1-7149E4FD9CFA} - hxxp://zone.msn.com/bingame/zpagames/GAME_UNO1.cab60096.cab
    DPF: {8C279F4E-917E-4CD2-8DF0-D9C73C0CE763} - hxxp://zone.msn.com/bingame/zpagames/zpa_wof.cab55579.cab
    DPF: {95B5D20C-BD31-4489-8ABF-F8C8BE748463} - hxxp://zone.msn.com/bingame/zpagames/zpa_hrtz.cab99160.cab
    DPF: {9BDF4724-10AA-43D5-BD15-AEA0D2287303} - hxxp://zone.msn.com/bingame/zpagames/zpa_txhe.cab79352.cab
    DPF: {A4110378-789B-455F-AE86-3A1BFC402853} - hxxp://zone.msn.com/bingame/zpagames/zpa_shvl.cab55579.cab
    DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} - hxxp://cdn2.zone.msn.com/binFramework/v10/ZPAFramework.cab102118.cab
    DPF: {D4003189-95B1-4A2F-9A87-F2B03665960D} - hxxp://www.vexcast.com/download/vexcast.cab
    DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - hxxp://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    DPF: {E77F23EB-E7AB-4502-8F37-247DBAF1A147} - hxxp://gfx2.hotmail.com/mail/w4/pr01/photouploadcontrol/MSNPUpld.cab
    DPF: {FD0EBBED-0C42-4D0F-82DA-44399B5C420A} - hxxp://downloads.virginmedia.com/CST/ver1/xp_mail.cab
    DPF: {FF3C5A9F-5A99-4930-80E8-4709194C2AD3} - hxxp://zone.msn.com/bingame/zpagames/ZPA_Backgammon.cab64162.cab
    Handler: msero - {B0D92A71-886B-453B-A649-1B91F93801E7} - c:\program files\common files\microsoft shared\encarta researcher\MSERO.DLL
    Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
    Handler: vsharechrome - {3F3A4B8A-86FC-43A4-BB00-6D7EBE9D4484} - c:\program files\vshare\vshare_toolbar.dll
    Notify: LBTWlgn - c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: Windows Desktop Search Namespace Manager: {56f9679e-7826-4c84-81f3-532071a8bcc5} - c:\program files\windows desktop search\MSNLNamespaceMgr.dll
    SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\wifd1f~1\MpShHook.dll
    mASetup: {10880D85-AAD9-4558-ABDC-2AB1552D831F} - "c:\program files\common files\lightscribe\LSRunOnce.exe "
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\stuart~1\applic~1\mozilla\firefox\profiles\zigbgyy8.default\
    FF - component: c:\documents and settings\all users\application data\real\realplayer\browserrecordplugin\firefox\ext\components\nprpffbrowserrecordext.dll
    FF - component: c:\documents and settings\all users\application data\real\realplayer\browserrecordplugin\firefox\ext\components\nprpffbrowserrecordlegacyext.dll
    FF - component: c:\documents and settings\stuart brodie\application data\mozilla\firefox\profiles\zigbgyy8.default\extensions\{bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}\components\RadioWMPCoreGecko19.dll
    FF - component: c:\documents and settings\stuart brodie\application data\mozilla\firefox\profiles\zigbgyy8.default\extensions\engine@conduit.com\components\RadioWMPCoreGecko19.dll
    FF - component: c:\documents and settings\stuart brodie\application data\mozilla\firefox\profiles\zigbgyy8.default\extensions\textlinks@playsushi.com\components\PlaySushiFF.dll
    FF - component: c:\program files\mozilla firefox\extensions\{ab2ce124-6272-4b12-94a9-7303c7397bd1}\components\SkypeFfComponent.dll
    FF - plugin: c:\documents and settings\all users\application data\nexoneu\ngm\npNxGameeu.dll
    FF - plugin: c:\documents and settings\all users\application data\real\realplayer\browserrecordplugin\mozillaplugins\nprphtml5videoshim.dll
    FF - plugin: c:\program files\download manager\npfpdlm.dll
    FF - plugin: c:\program files\google\google earth\plugin\npgeplugin.dll
    FF - plugin: c:\program files\google\update\1.2.183.39\npGoogleOneClick8.dll
    FF - plugin: c:\program files\microsoft\office live\npOLW.dll
    FF - plugin: c:\program files\veetle\player\npvlc.dll
    FF - plugin: c:\program files\veetle\plugins\npVeetle.dll
    FF - plugin: c:\program files\veetle\vlcbroadcast\npvbp.dll
    FF - plugin: c:\windows\system32\tvuax\npTVUAx.dll
    FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\mozilla firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
    FF - Ext: Skype extension for Firefox: {AB2CE124-6272-4b12-94A9-7303C7397BD1} - c:\program files\mozilla firefox\extensions\{AB2CE124-6272-4b12-94A9-7303C7397BD1}
    FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\DotNetAssistantExtension
    FF - Ext: RealPlayer Browser Record Plugin: {ABDE892B-13A8-4d1b-88E6-365A6E755758} - c:\documents and settings\all users\application data\real\realplayer\browserrecordplugin\firefox\Ext
    FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - %profile%\extensions\{20a82645-c095-46ed-80e3-08825760534b}
    FF - Ext: PlaySushi TextLinks : textlinks@playsushi.com - %profile%\extensions\textlinks@playsushi.com
    FF - Ext: Conduit Engine : engine@conduit.com - %profile%\extensions\engine@conduit.com
    FF - Ext: uTorrentBar Community Toolbar: {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc} - %profile%\extensions\{bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}
    ---- FIREFOX POLICIES ----
    FF - user.js: google.toolbar.linkdoctor.enabled - false
    R0 RapportKELL;RapportKELL;c:\windows\system32\drivers\RapportKELL.sys [2010-10-3 59240]
    R0 xfilt;VIA SATA IDE Hot-plug Driver;c:\windows\system32\drivers\xfilt.sys [2010-2-4 17920]
    R1 aswSP;aswSP;c:\windows\system32\drivers\aswSP.sys [2010-2-6 294608]
    R1 RapportCerberus_19917;RapportCerberus_19917;c:\documents and settings\all users\application data\trusteer\rapport\store\exts\rapportcerberus\19917\RapportCerberus_19917.sys [2010-10-3 34792]
    R1 RapportPG;RapportPG;c:\program files\trusteer\rapport\bin\RapportPG.sys [2010-10-3 169320]
    R2 aswFsBlk;aswFsBlk;c:\windows\system32\drivers\aswFsBlk.sys [2010-2-6 17744]
    R2 avast! Antivirus;avast! Antivirus;c:\program files\alwil software\avast5\AvastSvc.exe [2010-2-6 40384]
    R2 CinemaNow Service;CinemaNow Service;c:\program files\cinemanow\cinemanow media manager\CinemaNowSvc.exe [2009-6-23 127352]
    R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [2010-2-6 38144]
    R2 NPF;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [2010-2-6 32512]
    R3 RapportIaso;RapportIaso;c:\documents and settings\all users\application data\trusteer\rapport\store\exts\rapportms\21923\RapportIaso.sys [2010-12-27 12928]
    R3 RTL8187B;Realtek RTL8187B Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter;c:\windows\system32\drivers\RTL8187B.sys [2010-2-6 342784]
    S0 SahdIa32;HDD Filter Driver;c:\windows\system32\drivers\sahdia32.sys --> c:\windows\system32\drivers\SahdIa32.sys [?]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
    S2 gupdate;Google Update Service (gupdate);c:\program files\google\update\GoogleUpdate.exe [2010-4-9 136176]
    S3 ip100xp;IC Plus IP100 10/100 Fast Ethernet Adapter NT Driver;c:\windows\system32\drivers\ipfnd51.sys [2010-2-6 26752]
    S3 PciCon;PciCon;\??\e:\pcicon.sys --> e:\PciCon.sys [?]
    =============== File Associations ===============
    .txt=NFOPad
    2011-02-06 15:26:02 54016 ----a-w- c:\windows\system32\drivers\svwlyil.sys
    2011-02-06 14:48:32 -------- d-----w- c:\docume~1\stuart~1\applic~1\Malwarebytes
    2011-02-06 14:48:08 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2011-02-06 14:48:07 -------- d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
    2011-02-06 14:48:03 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
    2011-02-06 14:48:03 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2011-02-06 09:34:18 -------- d-----w- c:\windows\pss
    2011-02-04 09:21:30 5890896 ----a-w- c:\docume~1\alluse~1\applic~1\microsoft\windows defender\definition updates\{af5d4860-0d4d-4858-9f1b-a5fd244f95e3}\mpengine.dll
    2011-01-31 19:46:32 -------- d-----w- c:\docume~1\stuart~1\applic~1\Kalypso Media
    2011-01-31 19:31:54 74072 ----a-w- c:\windows\system32\XAPOFX1_5.dll
    2011-01-31 19:31:54 527192 ----a-w- c:\windows\system32\XAudio2_7.dll
    2011-01-31 19:31:53 239960 ----a-w- c:\windows\system32\xactengine3_7.dll
    2011-01-31 19:31:51 2106216 ----a-w- c:\windows\system32\D3DCompiler_43.dll
    2011-01-31 19:31:50 1868128 ----a-w- c:\windows\system32\d3dcsx_43.dll
    2011-01-31 19:31:48 248672 ----a-w- c:\windows\system32\d3dx11_43.dll
    2011-01-31 19:31:47 470880 ----a-w- c:\windows\system32\d3dx10_43.dll
    2011-01-31 19:31:46 1998168 ----a-w- c:\windows\system32\D3DX9_43.dll
    2011-01-31 09:01:26 -------- d-----w- c:\windows\Mahjong Memoirs
    2011-01-31 08:58:20 -------- d-----w- c:\docume~1\stuart~1\locals~1\applic~1\uTorrentBar
    2011-01-30 18:08:58 -------- d-----w- c:\docume~1\stuart~1\applic~1\Dekovir
    2011-01-30 17:22:15 -------- d-----w- c:\docume~1\stuart~1\applic~1\Green Clover Games
    2011-01-30 17:22:15 -------- d-----w- c:\docume~1\alluse~1\applic~1\Green Clover Games
    2011-01-18 15:33:05 941160 ----a-w- c:\windows\system32\nvdispco322090.dll
    2011-01-18 15:33:05 837736 ----a-w- c:\windows\system32\nvgenco322040.dll
    2011-01-18 15:32:34 -------- d-----w- C:\NVIDIA
    2011-01-18 15:30:11 -------- d-----w- c:\program files\SystemRequirementsLab
    2011-01-07 19:56:54 81920 ----a-w- c:\windows\system32\nvwddi.dll
    2011-01-07 19:56:50 580200 ----a-w- c:\windows\system32\easyUpdatusAPIU.dll
    2011-01-07 19:56:48 277608 ----a-w- c:\windows\system32\nvmccs.dll
    2011-01-07 19:56:48 156776 ----a-w- c:\windows\system32\nvsvc32.exe
    2011-01-07 19:56:48 145000 ----a-w- c:\windows\system32\nvcolor.exe
    2011-01-07 19:56:48 13880424 ----a-w- c:\windows\system32\nvcpl.dll
    2011-01-07 19:56:48 111208 ----a-w- c:\windows\system32\nvmctray.dll
    2011-01-27 19:17:45 252080 ----a-w- c:\windows\system32\nvdrsdb1.bin
    2011-01-27 19:17:45 1 ----a-w- c:\windows\system32\nvdrssel.bin
    2011-01-18 15:33:58 252080 ----a-w- c:\windows\system32\nvdrsdb0.bin
    2011-01-13 08:47:35 38848 ----a-w- c:\windows\avastSS.scr
    2011-01-08 03:27:00 6397824 ----a-w- c:\windows\system32\nv4_disp.dll
    2011-01-08 03:27:00 61440 ----a-w- c:\windows\system32\OpenCL.dll
    2011-01-08 03:27:00 4980736 ----a-w- c:\windows\system32\nvcuda.dll
    2011-01-08 03:27:00 2916968 ----a-w- c:\windows\system32\nvcuvid.dll
    2011-01-08 03:27:00 2292678 ----a-w- c:\windows\system32\nvdata.bin
    2011-01-08 03:27:00 2251368 ----a-w- c:\windows\system32\nvcuvenc.dll
    2011-01-08 03:27:00 1958400 ----a-w- c:\windows\system32\nvapi.dll
    2011-01-08 03:27:00 14671872 ----a-w- c:\windows\system32\nvoglnt.dll
    2011-01-08 03:27:00 13004800 ----a-w- c:\windows\system32\nvcompiler.dll
    2010-12-07 12:07:44 499712 ------w- c:\windows\system32\msvcp71.dll
    2010-12-07 12:07:44 348160 ------w- c:\windows\system32\msvcr71.dll
    2010-12-03 19:52:02 189480 -c--a-w- c:\windows\system32\PnkBstrB.xtr
    2010-12-03 19:52:02 189480 ----a-w- c:\windows\system32\PnkBstrB.exe
    2010-12-02 16:56:57 138056 -c--a-w- c:\docume~1\stuart~1\applic~1\PnkBstrK.sys
    2010-12-02 16:56:29 75064 ----a-w- c:\windows\system32\PnkBstrA.exe
    2010-12-02 16:11:57 3360624 ----a-w- c:\windows\system32\pbsvc.exe
    2010-11-29 17:38:30 94208 ----a-w- c:\windows\system32\QuickTimeVR.qtx
    2010-11-29 17:38:30 69632 ----a-w- c:\windows\system32\QuickTime.qts
    2010-11-18 18:12:44 81920 ------w- c:\windows\system32\isign32.dll
    2010-11-09 14:52:35 249856 ----a-w- c:\windows\system32\odbc32.dll
    ============= FINISH: 18:49:49.37 ===============
    DDS attach file...
    Boot Device: \Device\HarddiskVolume1
    Install Date: 04/02/2010 21:49:36
    System Uptime: 06/02/2011 11:50:13 (7 hours ago)
    Motherboard: FUJITSU SIEMENS | | MS-7293
    Processor: Intel(R) Celeron(R) CPU E1200 @ 1.60GHz | Socket 775 | 1596/50mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 233 GiB total, 54.484 GiB free.
    D: is FIXED (NTFS) - 77 GiB total, 18.811 GiB free.
    E: is CDROM ()
    F: is CDROM ()
    G: is CDROM ()
    H: is CDROM ()
    I: is CDROM ()
    ==== Disabled Device Manager Items =============
    Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
    Description: IC Plus IP100 10/100 Fast Ethernet Adapter
    Device ID: PCI\VEN_13F0&DEV_0200&SUBSYS_020113F0&REV_31\4&71586A9&0&2899
    Manufacturer: IC Plus Corp.
    Name: IC Plus IP100 10/100 Fast Ethernet Adapter
    PNP Device ID: PCI\VEN_13F0&DEV_0200&SUBSYS_020113F0&REV_31\4&71586A9&0&2899
    Service: ip100xp
    ==== System Restore Points ===================
    RP1: 06/02/2011 12:04:51 - System Checkpoint
    ==== Installed Programs ======================
    4.0.0.529
    5 Spots
    5 Spots II
    7-Zip 4.65
    AA3Deploy
    Acrobat.com
    Adobe AIR
    Adobe Flash Player 10 ActiveX
    Adobe Flash Player 10 Plugin
    Adobe Reader 9.4.1
    Adobe Shockwave Player 11.5
    Advertising Center
    Age of Mythology
    Age of Mythology - The Titans Expansion
    Alien Shooter
    Ancient Rome
    Any DVD Converter Professional 4.0.3
    Apple Application Support
    Apple Software Update
    Ashampoo Burning Studio 9.21
    µTorrent
    avast! Free Antivirus
    AVI DVD Burner v5.3.0.31
    AVS Update Manager 1.0
    AVS Video Converter 6
    AVS4YOU Software Navigator 1.3
    Brothers In Arms
    Build-a-lot 2 - Town of the Year [h33t] [oi812heet]
    Build-a-lot 3 - Passport to Europe 1.00
    Build A Lot
    Build A Lot 4-Power source .
    Build a Lot 5 Elizabethan Era
    CDDRV_Installer
    CLUE Classic
    Comanche 4
    Combat Arms EU
    Command & Conquer Tiberian Sun
    Compatibility Pack for the 2007 Office system
    Cooking Dash 2 - DinerTown Studios H33T
    Cubis Gold
    Cubis Gold 2
    Delta Force - Black Hawk Down (remove only)
    Din's Curse 1.001
    Diner Dash 5 - Boom Collectors Edition
    DirectX 9 Runtime
    DivX Codec
    DolbyFiles
    Download Manager 2.3.10
    DVD Shrink 3.2
    DVD to VCD AVI DivX Converter v3.2 (build 062)
    DVDFab Platinum
    EA Download Manager
    EA SPORTS online 2008
    Elf Bowling Holiday Pack 1.00
    Email Updater
    erLT
    Every Day Genius Square Logic
    Far Cry 2
    feeding frenzy 2 shipwreck showdown sceneXtra
    feeding frenzy sceneXtra
    Fragile Ball v1.06
    FW LiveUpdate
    Google Chrome
    Google Earth
    Google Update Helper
    Harley-Davidson Race to the Rally
    Hazen - The Dark Whispers
    Heart's Medicine - Season One Just For Fun Games
    Homeworld
    Homeworld2
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
    Hotfix for Windows Media Format 11 SDK (KB929399)
    Hotfix for Windows Media Player 11 (KB939683)
    Hotfix for Windows XP (KB2158563)
    Hotfix for Windows XP (KB2443685)
    Hotfix for Windows XP (KB915800-v4)
    Hotfix for Windows XP (KB952287)
    Hotfix for Windows XP (KB954550-v5)
    Hotfix for Windows XP (KB961118)
    Hotfix for Windows XP (KB976002-v5)
    Hotfix for Windows XP (KB976098-v2)
    Hotfix for Windows XP (KB979306)
    Hotfix for Windows XP (KB981793)
    House MD
    I Spy Mystery
    ImagXpress
    Junk Mail filter update
    K-Lite Mega Codec Pack 5.5.1
    KhalInstallWrapper
    L&H TTS3000 British English
    LIFE QUEST Final
    LightScribe System Software
    Logitech SetPoint
    Logitech Updater
    Luxor 4 Quest For The Afterlife 1.00
    Magic ISO Maker v5.5 (build 0281)
    Mahjong Champ
    Mahjong Memoirs
    MahJong Suite 2010 v7.1
    Mahjong Towers Eternity 1.00
    Menu Templates - Starter Kit
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Security Update (KB2416447)
    Microsoft .NET Framework 1.1 Security Update (KB979906)
    Microsoft .NET Framework 2.0 Service Pack 2
    Microsoft .NET Framework 3.0 Service Pack 2
    Microsoft .NET Framework 4 Client Profile
    Microsoft Age of Empires Gold
    Microsoft Age of Empires II
    Microsoft Age of Empires II: The Conquerors Expansion
    Microsoft Application Error Reporting
    Microsoft Base Smart Card Cryptographic Service Provider Package
    Microsoft Choice Guard
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Encarta Premium Suite - WE 2004
    Microsoft Kernel-Mode Driver Framework Feature Pack 1.5
    Microsoft Office Live Add-in 1.5
    Microsoft Office Professional Edition 2003
    Microsoft Pandora's Box
    Microsoft Silverlight
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    Microsoft WSE 3.0 Runtime
    Movie Templates - Starter Kit
    Mozilla Firefox (3.6.3)
    MSVCRT
    MSXML 4.0 SP2 (KB954430)
    MSXML 4.0 SP2 (KB973688)
    MSXML 6.0 Parser
    MSXML4 Parser
    Mystery Case Files - Madame Fate 1.00
    Mystery Case Files - Prime Suspects 1.00
    Mystery Case Files - Ravenhearst 1.00
    Mystery in London
    Nero 9 Trial
    Nero BurnRights
    Nero ControlCenter
    Nero CoverDesigner
    Nero DiscSpeed
    Nero DriveSpeed
    Nero InfoTool
    Nero Installer
    Nero PhotoSnap
    Nero Recode
    Nero Rescue Agent
    Nero ShowTime
    Nero StartSmart
    Nero Vision
    Nero WaveEditor
    NeroBurningROM
    NeroExpress
    neroxml
    NFOPad 1.56
    NVIDIA Control Panel 266.58
    NVIDIA Graphics Driver 266.58
    NVIDIA Install Application
    NVIDIA nView 135.50
    NVIDIA nView Desktop Manager
    NVIDIA PhysX
    PeaZip 2.9.1
    PL-2303 USB-to-Serial
    Platform
    Playsushi
    PowerDVD
    PowerISO
    Project Rescue Africa
    PunkBuster Services
    QBeez 2
    QuickTime
    Rapport
    Real Crimes Jack the Ripper
    RealNetworks - Microsoft Visual C++ 2008 Runtime
    RealPlayer
    Realtek High Definition Audio Driver
    RealUpgrade 1.1
    Registry Mechanic 10.0
    Roads of Rome II Just For Fun Games
    Roads of Rome Just For Fun Games
    Rome The Curse of the Necklace 1.00
    Roxio Creator 2010 Pro
    Security Update for Microsoft .NET Framework 3.5 SP1 (KB2416473)
    Security Update for Windows Internet Explorer 8 (KB2183461)
    Security Update for Windows Internet Explorer 8 (KB2360131)
    Security Update for Windows Internet Explorer 8 (KB2416400)
    Security Update for Windows Internet Explorer 8 (KB971961)
    Security Update for Windows Internet Explorer 8 (KB976325)
    Security Update for Windows Internet Explorer 8 (KB978207)
    Security Update for Windows Internet Explorer 8 (KB981332)
    Security Update for Windows Internet Explorer 8 (KB982381)
    Security Update for Windows Media Player (KB2378111)
    Security Update for Windows Media Player (KB952069)
    Security Update for Windows Media Player (KB954155)
    Security Update for Windows Media Player (KB968816)
    Security Update for Windows Media Player (KB973540)
    Security Update for Windows Media Player (KB975558)
    Security Update for Windows Media Player (KB978695)
    Security Update for Windows Media Player 11 (KB954154)
    Security Update for Windows Search 4 - KB963093
    Security Update for Windows XP (KB2079403)
    Security Update for Windows XP (KB2115168)
    Security Update for Windows XP (KB2121546)
    Security Update for Windows XP (KB2160329)
    Security Update for Windows XP (KB2229593)
    Security Update for Windows XP (KB2259922)
    Security Update for Windows XP (KB2279986)
    Security Update for Windows XP (KB2286198)
    Security Update for Windows XP (KB2296011)
    Security Update for Windows XP (KB2296199)
    Security Update for Windows XP (KB2347290)
    Security Update for Windows XP (KB2360937)
    Security Update for Windows XP (KB2387149)
    Security Update for Windows XP (KB2419632)
    Security Update for Windows XP (KB2423089)
    Security Update for Windows XP (KB2436673)
    Security Update for Windows XP (KB2440591)
    Security Update for Windows XP (KB2443105)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB941569)
    Security Update for Windows XP (KB946648)
    Security Update for Windows XP (KB950762)
    Security Update for Windows XP (KB950974)
    Security Update for Windows XP (KB951066)
    Security Update for Windows XP (KB951376-v2)
    Security Update for Windows XP (KB951748)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB952954)
    Security Update for Windows XP (KB955069)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB956744)
    Security Update for Windows XP (KB956802)
    Security Update for Windows XP (KB956803)
    Security Update for Windows XP (KB956844)
    Security Update for Windows XP (KB957097)
    Security Update for Windows XP (KB958644)
    Security Update for Windows XP (KB958687)
    Security Update for Windows XP (KB958869)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB960859)
    Security Update for Windows XP (KB961501)
    Security Update for Windows XP (KB969059)
    Security Update for Windows XP (KB969947)
    Security Update for Windows XP (KB970238)
    Security Update for Windows XP (KB970430)
    Security Update for Windows XP (KB971468)
    Security Update for Windows XP (KB971486)
    Security Update for Windows XP (KB971557)
    Security Update for Windows XP (KB971633)
    Security Update for Windows XP (KB971657)
    Security Update for Windows XP (KB972270)
    Security Update for Windows XP (KB973354)
    Security Update for Windows XP (KB973507)
    Security Update for Windows XP (KB973525)
    Security Update for Windows XP (KB973869)
    Security Update for Windows XP (KB973904)
    Security Update for Windows XP (KB974112)
    Security Update for Windows XP (KB974318)
    Security Update for Windows XP (KB974392)
    Security Update for Windows XP (KB974571)
    Security Update for Windows XP (KB975025)
    Security Update for Windows XP (KB975467)
    Security Update for Windows XP (KB975560)
    Security Update for Windows XP (KB975561)
    Security Update for Windows XP (KB975562)
    Security Update for Windows XP (KB975713)
    Security Update for Windows XP (KB977165)
    Security Update for Windows XP (KB977816)
    Security Update for Windows XP (KB977914)
    Security Update for Windows XP (KB978037)
    Security Update for Windows XP (KB978251)
    Security Update for Windows XP (KB978262)
    Security Update for Windows XP (KB978338)
    Security Update for Windows XP (KB978542)
    Security Update for Windows XP (KB978601)
    Security Update for Windows XP (KB978706)
    Security Update for Windows XP (KB979309)
    Security Update for Windows XP (KB979482)
    Security Update for Windows XP (KB979559)
    Security Update for Windows XP (KB979683)
    Security Update for Windows XP (KB979687)
    Security Update for Windows XP (KB980195)
    Security Update for Windows XP (KB980218)
    Security Update for Windows XP (KB980232)
    Security Update for Windows XP (KB980436)
    Security Update for Windows XP (KB981322)
    Security Update for Windows XP (KB981852)
    Security Update for Windows XP (KB981957)
    Security Update for Windows XP (KB981997)
    Security Update for Windows XP (KB982132)
    Security Update for Windows XP (KB982214)
    Security Update for Windows XP (KB982665)
    Security Update for Windows XP (KB982802)
    Segoe UI
    Settlement Colossus .
    Shockwave
    Skype Toolbars
    Skype™ 4.2
    SmartSound Quicktracks Plugin
    Snail Mail {h33t} {oi812heet}
    Snowboard SuperJam
    SopCast 3.2.9
    SoundTrax
    Steam
    System Requirements Lab
    Tales of Monkey Island
    Text Twist 2 1.00
    The Fall Trilogy Chapter 2 Reconstruction 1.00
    The Game of Life 1.00
    Tom Clancy's Splinter Cell Conviction
    Tumble Bugs
    Tumblebugs 2
    TVUPlayer 2.5.0.1
    Ubisoft Game Launcher
    Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
    Update for Microsoft Windows (KB971513)
    Update for Windows Internet Explorer 8 (KB2447568)
    Update for Windows Internet Explorer 8 (KB976662)
    Update for Windows Internet Explorer 8 (KB978506)
    Update for Windows Internet Explorer 8 (KB980182)
    Update for Windows Internet Explorer 8 (KB982632)
    Update for Windows XP (KB2141007)
    Update for Windows XP (KB2345886)
    Update for Windows XP (KB2467659)
    Update for Windows XP (KB951978)
    Update for Windows XP (KB955759)
    Update for Windows XP (KB961503)
    Update for Windows XP (KB967715)
    Update for Windows XP (KB968389)
    Update for Windows XP (KB971737)
    Update for Windows XP (KB973687)
    Update for Windows XP (KB973815)
    ValGor Dark Lord of Magic 1.00
    Veetle TV 0.9.18
    VIA Platform Device Manager
    VIA Rhine-Family Fast-Ethernet Adapter
    Virtual City .
    vShare Plugin
    WebFldrs XP
    Westwood Shared Internet Components
    WinAVI Video Converter
    Windows Defender
    Windows Genuine Advantage Validation Tool (KB892130)
    Windows Live Call
    Windows Live Communications Platform
    Windows Live Essentials
    Windows Live ID Sign-in Assistant
    Windows Live Mail
    Windows Live Messenger
    Windows Live Upload Tool
    Windows Live Writer
    Windows Management Framework Core
    Windows Media Format 11 runtime
    Windows Search 4.0
    Windows XP Service Pack 3
    Wireless Manager
    Zuma's Revenge! - Adventure H33T
    ==== Event Viewer Messages From Past Week ========
    31/01/2011 08:47:09, error: DCOM [10005] - DCOM got error "%1055" attempting to start the service winmgmt with arguments " " in order to run the server: {8BC3F05E-D86B-11D0-A075-00C04FB68820}
    02/02/2011 11:54:37, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
    01/02/2011 20:35:34, error: SideBySide [59] - Resolve Partial Assembly failed for Microsoft.VC90.DebugCRT. Reference error message: The referenced assembly is not installed on your system. .
    01/02/2011 20:35:34, error: SideBySide [59] - Generate Activation Context failed for c:\program files\real\realplayer\plugins\rmxrend.dll. Reference error message: The operation completed successfully. .
    01/02/2011 20:35:34, error: SideBySide [32] - Dependent Assembly Microsoft.VC90.DebugCRT could not be found and Last Error was The referenced assembly is not installed on your system.
    01/02/2011 15:18:49, error: System Error [1003] - Error code 1000008e, parameter1 c0000005, parameter2 00010003, parameter3 b6e48ba4, parameter4 00000000.
    ==== End Of File ===========================
  13. 2011/02/06
    I see you have P2P software ( Limewire, BitTorrent, uTorrent etc… ) installed on your machine. We are not here to pass judgment on file-sharing as a concept. However, we will warn you that engaging in this activity and having this kind of software installed on your machine will always make you more susceptible to re-infections. It may be contributing to your current situation. This page will give you further information.
    Please note: Even if you are using a "safe" P2P program, it is only the program that is safe. You will be sharing files from uncertified sources, and these are often infected. The bad guys use P2P filesharing as a major conduit to spread their wares and their infections.
    References for the risk of these programs are here, and here.
    I would strongly recommend that you uninstall them,
    Note: Please be advised that continued use of these programs after being warned of the danger of infections from them, may result in the discontinued help of future cleaning of your system here at WindowsBBS Malware and Virus removal.
    A Malware expert will have a look at your log in due course.
  14. 2011/02/06
    Caveman
    Caveman Inactive Thread Starter
    Pete. Thanks for the comment - the P2P program has been removed - I forgot it was there. One thing, when I ran the Malwarebytes Anti-Malware scan, it removed a large number of files and then prompted me to reboot to complete the removals. Due to the difficulties I've had rebooting, I have not done this yet. Would this create a problem?
  15. 2011/02/06
    I should wait for advice from our Malware Analyst - malware is not my area of expertise :)
  16. 2011/02/06
    Welcome aboard :)
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    Please download Rootkit Unhooker from one of the following links and save it to your desktop.
    In order to use this tool if you downloaded from either of the second two links, you will need to extract the RKUnhookerLE.exe file using a program capable of extracing ZIP and RAR compressed files. If you don't have an extraction program, you can downlaod, install and use the free 7-zip utility.
    • Double-click on RKUnhookerLE.exe to start the program.
      Vista/Windows 7 users right-click and select Run As Administrator.
    • Click the Report tab, then click Scan.
    • Check Drivers, Stealth, and uncheck the rest.
    • Click OK.
    • Wait until it's finished and then go to File > Save Report.
    • Save the report to your Desktop.
    • Copy and paste the contents of the report into your next reply.
    -- Note: You may get this warning...just ignore it, click OK and continue: "Rootkit Unhooker has detected a parasite inside itself! It is recommended to remove parasite, okay? ".
    [color= "Blue"]**Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**[/color]
    2. Close any open browsers.
      • Click on [color= "Red"]this link[/color] to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • [color= "Red"]WARNING:[/color] Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG users: ComboFix will not run until AVG is uninstalled as a protective measure against the anti-virus. This is because AVG "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode.
    2. Delete Combofix file, download fresh one, but rename combofix.exe to your_name.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    Rkill.com
    Rkill.scr
    Rkill.exe
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  17. 2011/02/06
    Welcome aboard :)
    • Click OK.
    NOTE.
    Do NOT run it yet.
    Rkill.com
    Rkill.scr
    Rkill.exe
  18. 2011/02/06
    Caveman
    Hi Broni
    Thanks for the reply. Do you want me to paste the Rootkit Unhooker report before I proceed to the Combofix step?
  19. 2011/02/06
    You may as well. It really doesn't matter.
  20. 2011/02/07
    Caveman
    Broni, I have a problem!
    I ran Rootkit unhooker as stated and saved the log file. I uninstalled Avast as stated in your instructions andI then ran Combofix. It prompted me to install the Recovery Console, which I did and then proceeded with its scan.
    At some stage during the scan, I left the room and came back to find that it had attempted to reboot the system. Now it is stuck on the boot page and will not get past it - it is frozen there and after a while displays the message about Couldn't open drive(0).....etc.
    Any suggestions? I've been restarting for about 30 minutes now without any success.
  21. 2011/02/07
    If you have Windows XP CD....
    1. Insert the Windows XP bootable CD into the computer.
    2. When prompted to press any key to boot from the CD, press any key.
    3. Once in the Windows XP setup menu press the "R" key to repair Windows.
    4. Log into your Windows installation by pressing the "1" key and pressing enter.
    5. You will then be prompted for your administrator password, enter that password.
    6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
    7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
    I'll be gone pretty soon for couple of hours....
