Solved Problem with Internet Security 2010
Discussion in 'Malware and Virus Removal Archive' started by cecelikeike, 2010/01/19.
  1. 2010/01/21
    That won't do. What happened?
  2. 2010/01/21
    cecelikeike
    cecelikeike Inactive Thread Starter
    Not sure, I disabled Avira, then scanned just those that you said. Do you want me to run it again?
    Look. You keep disregarding my instructions.
    In Kaspersky manual, I didn't ask to scan selected areas.
    I'm getting little bit tired with you doing other things, than asked to.
    Please, re-read my post #38 and proceed accordingly.
  5. 2010/01/21
    cecelikeike
    Broni I really appreciate your help, I do what you say, now when I quote what I did, it doesn't mean I did it verbatim, I followed what you are saying. I make sure to check what needs to be checked before I do anything. I realize I don't want to waste your time, cause, it is time consuming. Seeing how I am using avira, the guard is inactive. That means disabled right?
  6. 2010/01/21
    No, you don't follow my instructions from the very beginning and I have to either repeat my instructions twice, or I have to stop you from doing other things, than asked.
    Kaspersky scan says:
    Why did you stop it?
    You have to run full scan and nothing less.
    Yes.
  7. 2010/01/21
    cecelikeike
    Ok My apologies, I am rerunning the scan now
  8. 2010/01/21
    cecelikeike
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Thursday, January 21, 2010
    Operating system: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Thursday, January 21, 2010 21:45:36
    Records in database: 3355350
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    C:\
    D:\
    E:\
    Scan statistics:
    Objects scanned: 43085
    Threats found: 0
    Infected objects found: 0
    Suspicious objects found: 0
    Scan duration: 01:13:20
    No threats found. Scanned area is clean.
    Selected area has been scanned.
  9. 2010/01/21
    Very good :)
    Please, post fresh HijackThis log.
  10. 2010/01/21
    cecelikeike
    Scan saved at 4:03:54 PM, on 1/21/2010
    MSIE: Internet Explorer v7.00 (7.00.6000.16705)
    C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    C:\Program Files\AVG\AVG9\avgchsvx.exe
    C:\Program Files\AVG\AVG9\avgrsx.exe
    C:\Program Files\AVG\AVG9\avgcsrvx.exe
    C:\Program Files\Avira\AntiVir Desktop\sched.exe
    C:\WINDOWS\system32\agrsmsvc.exe
    C:\Program Files\Avira\AntiVir Desktop\avguard.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\Intel\AMT\atchksrv.exe
    C:\WINDOWS\system32\bmwebcfg.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    C:\Program Files\Intel\AMT\LMS.exe
    C:\Program Files\Maxtor\Sync\SyncServices.exe
    C:\WINDOWS\system32\o2flash.exe
    C:\Program Files\Fujitsu\PSUtility\PSUService.exe
    C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    C:\WINDOWS\system32\stacsv.exe
    C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
    C:\Program Files\Intel\AMT\UNS.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
    C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnf.exe
    C:\Program Files\Avira\AntiVir Desktop\avcenter.exe
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    C:\Program Files\Java\jre6\bin\java.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/?fr=fp-yma3
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\YTSingleInstance.dll
    O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
    O3 - Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
    O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_60D6097707281E79.dll/cmsidewiki.html
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: Add to EverNote - {A5ABA0BB-F195-40d8-A5E9-0801153E6597} - C:\Program Files\EverNote\EverNote\enbar.dll
    O9 - Extra 'Tools' menuitem: Add to EverNote - {A5ABA0BB-F195-40d8-A5E9-0801153E6597} - C:\Program Files\EverNote\EverNote\enbar.dll
    O10 - Unknown file in Winsock LSP: bmnet.dll
    O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1222216759625
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - http://dl8-cdn-01.sun.com/s/ESD5/JS...2/&filename=jinstall-6u11-windows-i586-jc.cab
    O16 - DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} (Photo Upload Plugin Class) - http://images3.pnimedia.com/ProductAssets/costcous/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {DEA6994F-3ED5-40BC-B5E3-0FD02411B1B4} (Photo Upload Plugin Class) - http://www.costcophotocenter.com/upload/activex/v3_0_0_1/PhotoCenter_ActiveX_Control.cab?
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
    O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
    O23 - Service: Avira AntiVir Scheduler (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
    O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Intel(R) Active Management Technology System Status Service (atchksrv) - Intel Corporation - C:\Program Files\Intel\AMT\atchksrv.exe
    O23 - Service: AT&T RcAppSvc (ATTRcAppSvc) - PCTEL - C:\Program Files\AT&T\Communication Manager\RcAppSvc.exe
    O23 - Service: AVG Free WatchDog (avg9wd) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG9\avgwdsvc.exe
    O23 - Service: Bytemobile Web Configurator (bmwebcfg) - Bytemobile, Inc. - C:\WINDOWS\system32\bmwebcfg.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: Intel(R) Active Management Technology Local Management Service (LMS) - Intel Corporation - C:\Program Files\Intel\AMT\LMS.exe
    O23 - Service: Maxtor Service (Maxtor Sync Service) - Seagate Technology LLC - C:\Program Files\Maxtor\Sync\SyncServices.exe
    O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
    O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
    O23 - Service: o2flash - O2Micro International - C:\WINDOWS\system32\o2flash.exe
    O23 - Service: Pml Driver HPH11 - HP - C:\WINDOWS\system32\HPHipm11.exe
    O23 - Service: PowerSavingUtilityService - FUJITSU LIMITED - C:\Program Files\Fujitsu\PSUtility\PSUService.exe
    O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    O23 - Service: SigmaTel Audio Service (STacSV) - SigmaTel, Inc. - C:\WINDOWS\system32\stacsv.exe
    O23 - Service: TOSHIBA Bluetooth Service - TOSHIBA CORPORATION - C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
    O23 - Service: Intel(R) Active Management Technology User Notification Service (UNS) - Intel Corporation - C:\Program Files\Intel\AMT\UNS.exe
    O23 - Service: Yahoo! Updater (YahooAUService) - Yahoo! Inc. - C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
    End of file - 10213 bytes
  11. 2010/01/21
    OK. At what point did you manage to install TWO antivirus programs?
    AVG and Avira.
    I specifically told you on page 1 of this thread not to install AVG.
    OMG! What's wrong with you?
    Download and install AVG Remover: http://www.avg.com/us-en/download-tools
    When done, post fresh HJT log.
  12. 2010/01/21
    cecelikeike
    Scan saved at 4:44:50 PM, on 1/21/2010
    O20 - Winlogon Notify: avgrsstarter - avgrsstx.dll (file missing)
    End of file - 9804 bytes
  13. 2010/01/21
    Verify your Java version here: http://www.java.com/en/download/installed.jsp
    Update, if necessary.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    - O20 - Winlogon Notify: avgrsstarter - avgrsstx.dll (file missing)
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    - O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    - O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    5. Click on Fix checked button.
    6. Restart computer.
    7. Post new HijackThis log.
  14. 2010/01/21
    cecelikeike
    Scan saved at 5:08:20 PM, on 1/21/2010
    End of file - 9104 bytes
  15. 2010/01/21
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  16. 2010/01/21
    cecelikeike
    Of all the programs I downloaded, which ones should I keep, and which ones should I get rid of?
  17. 2010/01/21
    Malwarebytes and Superantispyware are keepers. You should run them occasionally, or when you feel like your computer misbehave.
    Run TFC weekly.
    All others can go.
    Let me know, how your computer is doing.
  18. 2010/01/21
    cecelikeike
    THANK YOU VERY MUCH! I bet you couldn't wait to get rid of me!!!! Again much appreciated.
  19. 2010/01/21
    You're welcome :)
    I must admit, you're a tough case, but as my nature goes, I can get upset (for a reason...hmmmm), but I don't carry grudges, so all forgiven :)
    Happy surfing :)
  20. 2010/01/21
    cecelikeike
    In honor of you, I am going to get hooked on phonics!!!!! You must have 10 kids to have the patience you do!!!!!!!!! Take care
  21. 2010/01/21
    Hahahahaha....
    2 kids only :)
