Solved Problem help
Discussion in 'Malware and Virus Removal Archive' started by Mapguy, 2010/11/26.
  1. 2010/11/27
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
  2. 2010/11/27
    Mapguy
    Mapguy Inactive Thread Starter
    otl reset
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: Administrator
    ->FireFox cache emptied: 0 bytes
    User: All Users
    User: Default User
    User: LocalService
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: Marc
    ->Temp folder emptied: 1003062 bytes
    ->Temporary Internet Files folder emptied: 9030899 bytes
    ->Flash cache emptied: 772 bytes
    User: NetworkService
    Windows Temp folder emptied: 4401069 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 26558856 bytes
    RecycleBin emptied: 283868 bytes
    Total Files Cleaned = 39.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Marc
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.17.3 log created on 11272010_124959
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\SAMYI6WZ\drts[1].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\M4O8772F\audmeasure[2].gif moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\M4O8772F\drts[2].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\M4O8772F\iframes_api_loader[1].html moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\M4O8772F\L[6].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\M4O8772F\p-01-0VIaSjnOLg[3].gif moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\JMDABIM2\96461-active-problem-help-2[1].html moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\JMDABIM2\ads[4].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\JMDABIM2\iframescript[2].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\EVI7IYHP\audmeasure[1].gif moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\EVI7IYHP\L[7].htm moved successfully.
    C:\Documents and Settings\Marc\Local Settings\Temporary Internet Files\Content.IE5\EVI7IYHP\p-01-0VIaSjnOLg[1].gif moved successfully.
    Go on....
  5. 2010/11/27
    Mapguy
    Follow up
    OTL Clean done
    Tools and logs removed.
    Should I remove ESET and SecurityCheck too?
    Windows & office updated.
    Working on the balance.
    Computer is stable and running good again.
  6. 2010/11/27
    Good news :)
    You may.
    Good luck and stay safe :)
