Possible Spyware CPU running at 100%
Discussion in 'Malware and Virus Removal Archive' started by Master Green, 2007/07/23.
  1. 2007/07/28
    noahdfear
    noahdfear Inactive
    1. Download FIXPATH2.ZIP
    http://internet.cybermesa.com/~bstewart/files/fixpath2.zip
    2. Extract the files to a folder in C:\, like C:\FIXPATH2 (make a folder like that to extract the files to).
    3. Open a command prompt window by going to start > run and copy and type: cmd
    In the command prompt, type: cd C:\
    So you should get C:\>
    Then type: cd FIXPATH2
    So you should get: C:\>fixpath2
    Then type: FIXPATH.EXE
    It will display some preliminary information, and ask if it should continue and check for errors. Click Yes.
    If it successfully updates the Path value in the registry, you will need to
    reboot for the change to take effect.
    Run the set command again and post the Path info
  2. 2007/07/28
    Master Green
    Master Green Inactive Thread Starter
    Noahdfear,
    Here is the second report you requested from the set command:(I could not get just the path copied for you so I had to include the whole thing again).
    P.S...Do you still want me to run the combofix ??? After this ???
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Owner>set
    ALLUSERSPROFILE=C:\Documents and Settings\All Users
    APPDATA=C:\Documents and Settings\Owner\Application Data
    CLIENTNAME=Console
    CommonProgramFiles=C:\Program Files\Common Files
    COMPUTERNAME=YOUR-XB2X7J77GN
    ComSpec=C:\WINDOWS\system32\cmd.exe
    HOMEDRIVE=C:
    HOMEPATH=\Documents and Settings\Owner
    LOGONSERVER=\\YOUR-XB2X7J77GN
    NUMBER_OF_PROCESSORS=1
    OS=Windows_NT
    Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\Wbem;C:/WINDOWS/system32
    /rundll32.exe C:pROGRA~1\Yahoo!\Common\yammapi.dll
    PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
    PROCESSOR_ARCHITECTURE=x86
    PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
    PROCESSOR_LEVEL=15
    PROCESSOR_REVISION=0209
    PROMPT=$P$G
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\WINDOWS
    TEMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
    TMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
    USERDOMAIN=YOUR-XB2X7J77GN
    USERNAME=Owner
    USERPROFILE=C:\Documents and Settings\Owner
    windir=C:\WINDOWS
    noahdfear
    noahdfear Inactive
    That's better. Commands for system operations, such as dfrg.msc and ping should work right from the Run line again. :)
    Yes, please run ComboFix and post the main.txt log.
    Also, did you do a search for HOSTS yet? Results?
  5. 2007/07/28
    Master Green
    Noahdfear,
    Here is the combofix log:
    CLIENTNAME=Console
    HOMEDRIVE=C:
    OS=Windows_NT
    PROCESSOR_LEVEL=15
    PROMPT=$P$G
    SESSIONNAME=Console
    SystemDrive=C:
    USERNAME=Owner
    windir=C:\WINDOWS
  6. 2007/07/28
    Master Green
    Noahdfear,
    Every time I try to send the Combofix log it just reboots right back to the post page, I have tried 3 or 4 times and it won't submit...It shows alot of files quarntined...
  7. 2007/07/28
    Master Green
    Noahdfear,
    Also, I can still access Yahoo but not the email and the same error message comes up when I try to defrag...
    I have to step out for a little while, well check back as soon as I can.
  8. 2007/07/28
    noahdfear
    noahdfear Inactive
    Open a New Reply, then open the main.txt log. Click somewhere within the log (anywhere) then press Ctrl+A. That should highlight everything. Now press Ctrl+C. Click back in the New Reply window (click inside the reply box) and press Ctrl+V, then submit. If the log is too big, it may not all post. If so, you will need tp post the rest in another new reply.
    Can you access yahoo by going to yahoo.com, or are you still using the numbered address?
  9. 2007/07/28
    Master Green
    Noahdfear,
    I guess what the problem was, it's too long so you will recieve it in two parts:
    2001-02-27 03:55 384 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\progress.xip.vir
    2002-06-10 05:13 269 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\business_promo.xip.vir
    2002-10-24 05:55 51 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_bar.xip.vir
    2002-10-24 05:56 51 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_logos.xip.vir
    2002-10-24 05:56 51 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_other.xip.vir
    2003-07-17 06:46 3432 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_weather.xip.vir
    2003-09-14 03:17 188 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\linkpathlegal.xip.vir
    2003-09-17 06:37 1232 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_bbar1.xip.vir
    2003-09-17 08:11 137 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\hotbar-premium.xip.vir
    2003-09-17 08:11 65 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\ads.xip.vir
    2004-07-27 01:09 8572 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\icons2.xip.vir
    2005-03-09 05:12 229 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\hotbar_promo.xip.vir
    2005-07-11 05:26 23444 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_3000.xip.vir
    2005-07-11 05:26 61095 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_1000.xip.vir
    2005-07-11 05:26 83545 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_2000.xip.vir
    2005-08-09 05:30 7406 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\s_icons_buttons.xip.vir
    2005-09-18 07:27 2338 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\BtnTrans.xip.vir
    2005-09-18 07:27 7319 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\BtnTrans1.xip.vir
    2005-10-07 06:00 1239 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\referencehotxp.png.vir
    2005-10-07 06:00 1267 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\highlightxp.png.vir
    2005-10-07 06:00 1272 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\HighlightHot.bmp.vir
    2005-10-07 06:00 1286 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\Highlight.bmp.vir
    2005-10-07 06:00 1392 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\Reference.bmp.vir
    2005-10-07 06:00 1392 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\ReferenceHot.bmp.vir
    2005-10-07 06:00 1420 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\FindIt.bmp.vir
    2005-10-07 06:00 1420 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\FindItHot.bmp.vir
    2005-10-07 06:00 1492 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\finditxp.png.vir
    2005-10-07 06:00 1568 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\weatherxp.png.vir
    2005-10-07 06:00 553 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\highlighthotxp.png.vir
    2005-10-07 06:00 837 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\findithotxp.png.vir
    2005-10-07 06:00 862 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\weatherhotxp.png.vir
    2005-10-07 06:00 924 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\referencexp.png.vir
    2005-10-14 14:06 1016 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\Weather.bmp.vir
    2005-11-22 13:32 1020 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\mainconfirm.lua.vir
    2005-11-22 13:32 10260 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\drumbeat.ogg.vir
    2005-11-22 13:32 1059 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\eye3.png.vir
    2005-11-22 13:32 1074 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseblue1.png.vir
    2005-11-22 13:32 10796 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\trifield.jpg.vir
    2005-11-22 13:32 1092 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\help-bb_large.png.vir
    2005-11-22 13:32 1102 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousegreen1.png.vir
    2005-11-22 13:32 1103 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\eye4.png.vir
    2005-11-22 13:32 1108 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\eye1.png.vir
    2005-11-22 13:32 1116 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\eye2.png.vir
    2005-11-22 13:32 112 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\rotatingpyramid.mesh.vir
    2005-11-22 13:32 1122 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetlehover1.png.vir
    2005-11-22 13:32 1126 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\boardfill.png.vir
    2005-11-22 13:32 1137 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\global-hs-bb_small.png.vir
    2005-11-22 13:32 11470 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\areabomb.ogg.vir
    2005-11-22 13:32 11630 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\circledoor.jpg.vir
    2005-11-22 13:32 1191 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousered1.png.vir
    2005-11-22 13:32 1195 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetlehover2.png.vir
    2005-11-22 13:32 1197 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseyellow1.png.vir
    2005-11-22 13:32 12278 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\statues\statue1\statue01_dirty.jpg.vir
    2005-11-22 13:32 128 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\doorlights.txt.vir
    2005-11-22 13:32 1283 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\buckettriangle.png.vir
    2005-11-22 13:32 1306 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\artifacts-bb.png.vir
    2005-11-22 13:32 1314 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\bar.jpg.vir
    2005-11-22 13:32 1323 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\quitconfirm.lua.vir
    2005-11-22 13:32 1428 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\areashockwave.png.vir
    2005-11-22 13:32 14609 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\hiscore.lua.vir
    2005-11-22 13:32 1486 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\sliderknobover.png.vir
    2005-11-22 13:32 1527 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\helptips\arrowkeys.png.vir
    2005-11-22 13:32 1538 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\tritop.png.vir
    2005-11-22 13:32 1556 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared5.png.vir
    2005-11-22 13:32 1560 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\sliderknob.png.vir
    2005-11-22 13:32 1597 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\characters\bast\look\bl0001.png.vir
    2005-11-22 13:32 161 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\scenes\page1-0.xml.vir
    2005-11-22 13:32 1660 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\checkdown.png.vir
    2005-11-22 13:32 1702 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared1.png.vir
    2005-11-22 13:32 17202 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\upsell\image1.jpg.vir
    2005-11-22 13:32 17358 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\large_dialog.jpg.vir
    2005-11-22 13:32 18029 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\upsell\image0.jpg.vir
    2005-11-22 13:32 18505 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\upsell\image3.jpg.vir
    2005-11-22 13:32 1854 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\global-hs-bb_large.png.vir
    2005-11-22 13:32 1872 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetlehover4.png.vir
    2005-11-22 13:32 1878 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetlehover3.png.vir
    2005-11-22 13:32 18873 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\bonusrow.ogg.vir
    2005-11-22 13:32 18876 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\upsell\image2.jpg.vir
    2005-11-22 13:32 1944 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\redrollover.png.vir
    2005-11-22 13:32 19664 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\leveldesign.lua.vir
    2005-11-22 13:32 2002 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-bluerollover.png.vir
    2005-11-22 13:32 2009 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowleft_down.png.vir
    2005-11-22 13:32 2014 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowright_down.png.vir
    2005-11-22 13:32 2022 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowup_down.png.vir
    2005-11-22 13:32 2025 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowleft_up.png.vir
    2005-11-22 13:32 2029 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowright_up.png.vir
    2005-11-22 13:32 2030 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared4.png.vir
    2005-11-22 13:32 2045 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowright_over.png.vir
    2005-11-22 13:32 2050 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowdown_down.png.vir
    2005-11-22 13:32 2052 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\bluearrowleft_over.png.vir
    2005-11-22 13:32 2064 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowup_up.png.vir
    2005-11-22 13:32 208 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\textfield.png.vir
    2005-11-22 13:32 2082 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowup_over.png.vir
    2005-11-22 13:32 2093 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowdown_up.png.vir
    2005-11-22 13:32 2095 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-redrollover.png.vir
    2005-11-22 13:32 2105 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowdown_over.png.vir
    2005-11-22 13:32 21161 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\fonts\lithos.mvec.vir
    2005-11-22 13:32 21197 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\full_screen_dialog.jpg.vir
    2005-11-22 13:32 212 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\pyramid.mesh.vir
    2005-11-22 13:32 2137 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-greenrollover.png.vir
  10. 2007/07/28
    Master Green
    Part 2 (Combofix log)
    2005-11-22 13:32 216 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\scarabpanel.mesh.vir
    2005-11-22 13:32 2245 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-yellowrollover.png.vir
    2005-11-22 13:32 2248 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared2.png.vir
    2005-11-22 13:32 22610 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\fonts\jackarmstrong.mvec.vir
    2005-11-22 13:32 2275 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared3.png.vir
    2005-11-22 13:32 2305 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-blue.png.vir
    2005-11-22 13:32 23802 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\strings.xml.vir
    2005-11-22 13:32 2391 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\characters\kristine\look\kl0001.png.vir
    2005-11-22 13:32 2410 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-green.png.vir
    2005-11-22 13:32 2411 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\areabomb.png.vir
    2005-11-22 13:32 2427 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\brick2.png.vir
    2005-11-22 13:32 2453 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\options.lua.vir
    2005-11-22 13:32 2455 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-red.png.vir
    2005-11-22 13:32 2462 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotright_over.png.vir
    2005-11-22 13:32 2485 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\local-hs-bb.png.vir
    2005-11-22 13:32 2511 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\hidden-artifact_icon.png.vir
    2005-11-22 13:32 2526 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotleft_over.png.vir
    2005-11-22 13:32 2540 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\plain_tri-yellow.png.vir
    2005-11-22 13:32 2572 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\mainpuzzle.lua.vir
    2005-11-22 13:32 2577 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\maincontinue.lua.vir
    2005-11-22 13:32 2603 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\maingames.lua.vir
    2005-11-22 13:32 2618 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_tail.png.vir
    2005-11-22 13:32 2648 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\sliderrail.png.vir
    2005-11-22 13:32 2666 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\bluerollover.png.vir
    2005-11-22 13:32 2667 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotright_down.png.vir
    2005-11-22 13:32 2670 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\red.png.vir
    2005-11-22 13:32 2674 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotleft_down.png.vir
    2005-11-22 13:32 2690 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\urnplatform.png.vir
    2005-11-22 13:32 2718 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotleft_up.png.vir
    2005-11-22 13:32 2721 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\rotright_up.png.vir
    2005-11-22 13:32 2732 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\characters\anwar\look\pl0001.png.vir
    2005-11-22 13:32 2736 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\areabombrollover.png.vir
    2005-11-22 13:32 2782 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\green.png.vir
    2005-11-22 13:32 2822 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\greenrollover.png.vir
    2005-11-22 13:32 2874 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\wildrollover.png.vir
    2005-11-22 13:32 2882 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\blue.png.vir
    2005-11-22 13:32 2893 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\yellowrollover.png.vir
    2005-11-22 13:32 2898 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\yellow.png.vir
    2005-11-22 13:32 2902 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\brick1.png.vir
    2005-11-22 13:32 2910 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\wild.png.vir
    2005-11-22 13:32 2941 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_starter.png.vir
    2005-11-22 13:32 296 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\tm.png.vir
    2005-11-22 13:32 29882 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\chamber1.jpg.vir
    2005-11-22 13:32 2995 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\brick.png.vir
    2005-11-22 13:32 3146 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\style.lua.vir
    2005-11-22 13:32 326 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\rubble.png.vir
    2005-11-22 13:32 3315 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\scarabpostovr.png.vir
    2005-11-22 13:32 3332 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\helptip.ogg.vir
    2005-11-22 13:32 334 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseblue3.png.vir
    2005-11-22 13:32 334 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseyellow3.png.vir
    2005-11-22 13:32 3356 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\levels\levels.dat.vir
    2005-11-22 13:32 3448 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\upsell.lua.vir
    2005-11-22 13:32 3454 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\mainarcade.lua.vir
    2005-11-22 13:32 3500 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\storyplayer.lua.vir
    2005-11-22 13:32 3552 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\timericon.png.vir
    2005-11-22 13:32 3583 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\statues\statue1\arm01_dirty.png.vir
    2005-11-22 13:32 3601 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\orange-button_over.png.vir
    2005-11-22 13:32 361 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\scenes\page1-1.xml.vir
    2005-11-22 13:32 3637 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\orange-button_down.png.vir
    2005-11-22 13:32 3679 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\bonustimer.ogg.vir
    2005-11-22 13:32 3769 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\orange-button_up.png.vir
    2005-11-22 13:32 3832 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\dialogbox.ogg.vir
    2005-11-22 13:32 3884 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\rotateboardleft.ogg.vir
    2005-11-22 13:32 38908 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\chamber0.jpg.vir
    2005-11-22 13:32 4015 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\scarabpost.png.vir
    2005-11-22 13:32 4026 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1a.ogg.vir
    2005-11-22 13:32 4107 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\start.lua.vir
    2005-11-22 13:32 4142 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\simplebutton_over.png.vir
    2005-11-22 13:32 4144 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\simplebutton_down.png.vir
    2005-11-22 13:32 41803 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\scenes\panel1-1-1.png.vir
    2005-11-22 13:32 4198 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\simplebutton_up.png.vir
    2005-11-22 13:32 4210 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowright_down.png.vir
    2005-11-22 13:32 4210 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\statues\statue0\snake_dirty.png.vir
    2005-11-22 13:32 4220 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowleft_down.png.vir
    2005-11-22 13:32 4277 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\smoke.png.vir
    2005-11-22 13:32 4305 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowleft_up.png.vir
    2005-11-22 13:32 4309 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowright_up.png.vir
    2005-11-22 13:32 4335 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowleft_over.png.vir
    2005-11-22 13:32 4336 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\smoke2.png.vir
    2005-11-22 13:32 4342 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\arrowright_over.png.vir
    2005-11-22 13:32 4381 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\pause.lua.vir
    2005-11-22 13:32 4389 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\smoke3.png.vir
    2005-11-22 13:32 4413 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\hiscoresubmit.lua.vir
    2005-11-22 13:32 4504 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1b.ogg.vir
    2005-11-22 13:32 4526 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\gameover.lua.vir
    2005-11-22 13:32 45580 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\mainmenu.jpg.vir
    2005-11-22 13:32 462 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\cursor.png.vir
    2005-11-22 13:32 4643 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\scorecloud.png.vir
    2005-11-22 13:32 4659 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_4.png.vir
    2005-11-22 13:32 471 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetleshock1.png.vir
    2005-11-22 13:32 471 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\checkup.png.vir
    2005-11-22 13:32 4746 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\urnglow.png.vir
    2005-11-22 13:32 477 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetleshock4.png.vir
    2005-11-22 13:32 4775 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_1.png.vir
    2005-11-22 13:32 4808 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\timerglow.png.vir
    2005-11-22 13:32 4820 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_2.png.vir
    2005-11-22 13:32 4853 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\bolt_3.png.vir
    2005-11-22 13:32 4914 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\warning.ogg.vir
    2005-11-22 13:32 49660 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\scenes\panel1-0-1.png.vir
    2005-11-22 13:32 5012 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\genericbucket.png.vir
    2005-11-22 13:32 5078 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\timer.png.vir
    2005-11-22 13:32 5079 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\powerup.ogg.vir
    2005-11-22 13:32 515 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\p1icon.png.vir
    2005-11-22 13:32 522 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\bricktip.png.vir
  11. 2007/07/28
    Master Green
    Part 3 (Combofix log)
    2005-11-22 13:32 5308 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\game.lua.vir
    2005-11-22 13:32 5706 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\redbucket.png.vir
    2005-11-22 13:32 5723 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\statues\statue1\mask01_1.png.vir
    2005-11-22 13:32 5744 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\disk.mesh.vir
    2005-11-22 13:32 575 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousered3.png.vir
    2005-11-22 13:32 5769 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\bluebucket.png.vir
    2005-11-22 13:32 5790 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\colorchain.ogg.vir
    2005-11-22 13:32 58345 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\music\mainmenumusic.ogg.vir
    2005-11-22 13:32 5876 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\long_button_down.png.vir
    2005-11-22 13:32 58873 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\splash\playfirst_logo.jpg.vir
    2005-11-22 13:32 597 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\smallyellow.png.vir
    2005-11-22 13:32 5975 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2a.ogg.vir
    2005-11-22 13:32 6018 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1c.ogg.vir
    2005-11-22 13:32 6054 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\instructions.lua.vir
    2005-11-22 13:32 6062 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\greenbucket.png.vir
    2005-11-22 13:32 6090 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\long_button_over.png.vir
    2005-11-22 13:32 6155 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\yellowbucket.png.vir
    2005-11-22 13:32 618 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\error.lua.vir
    2005-11-22 13:32 62 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\equilateraltriangle.mesh.vir
    2005-11-22 13:32 62 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\flattri.mesh.vir
    2005-11-22 13:32 6209 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\buttons\long_button_up.png.vir
    2005-11-22 13:32 6314 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\beetlezap.ogg.vir
    2005-11-22 13:32 6398 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\warning2.ogg.vir
    2005-11-22 13:32 646 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetleshock2.png.vir
    2005-11-22 13:32 647 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\smallgreen.png.vir
    2005-11-22 13:32 6505 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2b.ogg.vir
    2005-11-22 13:32 658 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\chainlink.png.vir
    2005-11-22 13:32 658 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\hiscoreinfo.lua.vir
    2005-11-22 13:32 6650 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2c.ogg.vir
    2005-11-22 13:32 670 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousegreen3.png.vir
    2005-11-22 13:32 6787 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\crackedstopper.png.vir
    2005-11-22 13:32 684 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\smallred.png.vir
    2005-11-22 13:32 6843 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\sfx\flash.png.vir
    2005-11-22 13:32 6899 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\levelover.lua.vir
    2005-11-22 13:32 6948 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\fillrow.ogg.vir
    2005-11-22 13:32 6955 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\warning.png.vir
    2005-11-22 13:32 7151 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\stopper.png.vir
    2005-11-22 13:32 7419 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\bucketfilled.ogg.vir
    2005-11-22 13:32 7475 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\greybomb.png.vir
    2005-11-22 13:32 758 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\screens\maphelptip.lua.vir
    2005-11-22 13:32 7588 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\clearpyramid.ogg.vir
    2005-11-22 13:32 759 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetleshock3.png.vir
    2005-11-22 13:32 76 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\setup.xml.vir
    2005-11-22 13:32 763 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\smallblue.png.vir
    2005-11-22 13:32 7723 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\helptips\helptip.jpg.vir
    2005-11-22 13:32 812 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\beetletatoo.png.vir
    2005-11-22 13:32 817 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousegreen2.png.vir
    2005-11-22 13:32 818 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseyellow2.png.vir
    2005-11-22 13:32 84 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\models\quad.mesh.vir
    2005-11-22 13:32 858 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mouseblue2.png.vir
    2005-11-22 13:32 860 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\urns\chaintip.png.vir
    2005-11-22 13:32 889 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\help-bb_small.png.vir
    2005-11-22 13:32 926 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\brick3.png.vir
    2005-11-22 13:32 930 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\triangles\clearanim\cleared6.png.vir
    2005-11-22 13:32 931 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\trails\mousered2.png.vir
    2005-11-22 13:32 942 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\beetles\dirt.png.vir
    2005-11-22 13:32 9727 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\hexfield.jpg.vir
    2005-11-22 13:32 9737 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\backgrounds\small_dialog.jpg.vir
    2005-11-22 13:32 9802 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\gateopen.ogg.vir
    2005-11-22 13:32 9959 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\assets\audio\sfx\timerup.ogg.vir
    2005-11-22 13:34 1052672 --a------ C:\Qoobox\Quarantine\C\WINDOWS\DOWNLO~1\TriJinx.1.0.0.55\TriJinx.exe.vir
    2006-07-17 05:19 14692 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\top7.xip.vir
    2006-11-17 08:44 1354 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\epiRSS.png.vir
    2006-11-17 08:44 1357 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\epiSearch.png.vir
    2006-11-17 08:44 1456 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\epiSearch.bmp.vir
    2006-11-17 08:44 1500 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\epiRSS.bmp.vir
    2007-01-03 02:14 7554 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\email-t1-bg.xip.vir
    2007-01-03 04:58 2494 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\t2_bg.xip.vir
    2007-01-04 01:09 1271 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\tsd_bg.xip.vir
    2007-01-11 10:03 648 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\buttons\starware_toolbar_icon.bmp.vir
    2007-01-19 14:34 10792 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\travel.xml.vir
    2007-01-19 14:34 376 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\error.xml.vir
    2007-01-19 14:34 6200 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\related.xml.vir
    2007-02-09 14:22 2885 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\819382.sdf.vir
    2007-02-09 14:23 104 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ASPL1.dat.vir
    2007-02-09 14:23 1062 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2460565.sdf.vir
    2007-02-09 14:23 1902 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\79246.vir
    2007-02-09 14:23 1909 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\32377.vir
    2007-02-09 14:23 1960 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\20153.vir
    2007-02-09 14:23 1965 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\748127.vir
    2007-02-09 14:23 2034 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\7515.vir
    2007-02-09 14:24 1906 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\1000048639.vir
    2007-02-09 14:24 1954 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\84293.vir
    2007-02-09 14:24 1960 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\622354.vir
    2007-02-09 14:24 1972 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\351786.vir
    2007-05-15 05:04 140532 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\keywords.xip.vir
    2007-05-15 05:04 637488 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\keywords1.xip.vir
    2007-05-26 07:24 1997 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1385370.sdf.vir
    2007-06-22 10:48 2028 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2208948.sdf.vir
    2007-06-22 10:49 525772 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\keywords.idx.vir
    2007-06-22 10:51 1887 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\7228.vir
    2007-06-22 10:51 1892 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\59598.vir
    2007-06-22 10:51 1919 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\15541.vir
  12. 2007/07/28
    Master Green
    Part 4 (combofix log)
    2007-06-22 10:51 1937 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\18991.vir
    2007-06-22 10:51 1940 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\4142.vir
    2007-06-22 10:51 1958 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\4157.vir
    2007-06-22 10:51 2008 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2763070.sdf.vir
    2007-06-22 10:57 2103 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\890068.sdf.vir
    2007-06-22 10:58 291 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1066422.sdf.vir
    2007-06-23 01:49 12151 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_bbar1.res.vir
    2007-06-23 01:49 164777 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_1000.res.vir
    2007-06-23 01:49 209637 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_2000.res.vir
    2007-06-23 01:49 2585 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\progress.res.vir
    2007-06-23 01:49 2675 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\tsd_bg.res.vir
    2007-06-23 01:49 328 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\linkpathlegal.txt.vir
    2007-06-23 01:49 32934 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\s_icons_buttons.res.vir
    2007-06-23 01:49 35442 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_weather.res.vir
    2007-06-23 01:49 378 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar_promo.htm.vir
    2007-06-23 01:49 399069 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\sales_buttons.res.vir
    2007-06-23 01:49 492 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\business_promo.htm.vir
    2007-06-23 01:49 5239 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\buttondir.txt.vir
    2007-06-23 01:49 525772 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\keywords.idx.vir
    2007-06-23 01:49 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_bar.res.vir
    2007-06-23 01:49 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_logos.res.vir
    2007-06-23 01:49 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_other.res.vir
    2007-06-23 01:49 6590 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\t2_bg.res.vir
    2007-06-23 01:49 6797 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\layout.cdf.vir
    2007-06-23 01:49 8853636 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\keywords1.dat.vir
    2007-06-23 01:49 95919 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_3000.res.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_511745-514279.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz1.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz10.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz11.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz12.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz13.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz14.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz15.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz16.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz17.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz18.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz19.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz2.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz20.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz3.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz4.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz5.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz6.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz7.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz8.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz9.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_categorize.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_comparison.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_em_PROFL_CA_flow_b_IEB.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_explorer-Mails.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_explorer-people.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_favorites.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Games.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Hide.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Hotmail.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_hsskin.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemster.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemsterie.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemsteruk.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jobsearch.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_new.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_premium.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_reun.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_ringtones.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_SearchBoxTrapper.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_searchfor.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_searchgo.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_weather.mnu.vir
    2007-06-23 01:50 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_yellowpages.mnu.vir
    2007-06-23 01:50 12622 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_hotbarcom.mnu.vir
    2007-06-23 01:50 137 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\ads.cdf.vir
    2007-06-23 01:50 21704 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\default.cdf.vir
    2007-06-23 01:50 269 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar-premium.cdf.vir
    2007-06-23 01:50 42 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-def-511724-9595.mnu.vir
    2007-06-23 01:50 44 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-def-511724-548964.mnu.vir
    2007-06-23 01:50 44684 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-t1-bg.res.vir
    2007-06-23 01:50 48 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar-premium-hotbar-premium.mnu.vir
    2007-06-23 01:50 487 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Mails.mnu.vir
    2007-06-23 01:50 5154 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\components.cdf.vir
    2007-06-23 01:50 58575 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\theweb.mnu.vir
    2007-06-23 01:50 59785 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\top7.cdf.vir
    2007-06-23 01:50 60789 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\icons2.res.vir
    2007-06-23 01:50 62049 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Top7_theweb.mnu.vir
    2007-06-23 01:50 8735 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\btntrans.idx.vir
    2007-06-23 04:01 27 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ustat\3577.dat.vir
    2007-06-26 00:52 46217 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\sales_buttons.xip.vir
    2007-07-01 07:40 2117 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\layout.xip.vir
    2007-07-01 07:40 4329 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\default.xip.vir
    2007-07-03 22:19 143 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\samplegroups2.xip.vir
    2007-07-08 03:15 1432 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\buttondir.xip.vir
    2007-07-08 05:51 12151 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_bbar1.res.vir
    2007-07-08 05:51 164777 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_1000.res.vir
    2007-07-08 05:51 209637 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_2000.res.vir
    2007-07-08 05:51 2406 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1383602.sdf.vir
    2007-07-08 05:51 2585 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\progress.res.vir
    2007-07-08 05:51 2675 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\tsd_bg.res.vir
    2007-07-08 05:51 328 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\linkpathlegal.txt.vir
    2007-07-08 05:51 32934 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\s_icons_buttons.res.vir
    2007-07-08 05:51 35442 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_weather.res.vir
    2007-07-08 05:51 378 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar_promo.htm.vir
    2007-07-08 05:51 399072 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\sales_buttons.res.vir
    2007-07-08 05:51 492 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\business_promo.htm.vir
    2007-07-08 05:51 5239 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\buttondir.txt.vir
    2007-07-08 05:51 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_bar.res.vir
    2007-07-08 05:51 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_logos.res.vir
    2007-07-08 05:51 62 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_other.res.vir
    2007-07-08 05:51 6445 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\layout.cdf.vir
    2007-07-08 05:51 6590 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\t2_bg.res.vir
    2007-07-08 05:51 851 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\samplegroups2.txt.vir
    2007-07-08 05:51 95919 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_3000.res.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_511745-514279.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz1.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz10.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz11.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz12.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz13.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz14.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz15.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz16.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz17.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz18.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz19.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz2.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz20.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz3.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz4.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz5.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz6.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz7.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz8.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz9.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_categorize.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_comparison.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_em_PROFL_CA_flow_b_IEB.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_explorer-Mails.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_explorer-people.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_favorites.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Games.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Hide.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Hotmail.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_hsskin.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemster.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemsterie.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemsteruk.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jobsearch.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_new.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_premium.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_reun.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_ringtones.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_SearchBoxTrapper.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_searchfor.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_searchgo.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_weather.mnu.vir
    2007-07-08 05:52 0 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_yellowpages.mnu.vir
    2007-07-08 05:52 112113 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\600583.sdf.vir
    2007-07-08 05:52 12622 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_hotbarcom.mnu.vir
    2007-07-08 05:52 137 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\ads.cdf.vir
    2007-07-08 05:52 1910 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\17040.vir
    2007-07-08 05:52 1939 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\45833.vir
    2007-07-08 05:52 1942 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\32293.vir
    2007-07-08 05:52 1942 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\748893.vir
    2007-07-08 05:52 21387 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\default.cdf.vir
    2007-07-08 05:52 269 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar-premium.cdf.vir
    2007-07-08 05:52 42 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-def-511724-9595.mnu.vir
    2007-07-08 05:52 44 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-def-511724-548964.mnu.vir
    2007-07-08 05:52 44684 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-t1-bg.res.vir
    2007-07-08 05:52 48 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar-premium-hotbar-premium.mnu.vir
    2007-07-08 05:52 4800 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\components.cdf.vir
    2007-07-08 05:52 487 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Mails.mnu.vir
    2007-07-08 05:52 58575 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\theweb.mnu.vir
    2007-07-08 05:52 59785 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\top7.cdf.vir
    2007-07-08 05:52 60789 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\icons2.res.vir
    2007-07-08 05:52 62049 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Top7_theweb.mnu.vir
    2007-07-08 05:52 8735 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\btntrans.idx.vir
    2007-07-08 05:52 8853636 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\keywords1.dat.vir
    2007-07-08 05:54 11372 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\625696.sdf.vir
    2007-07-08 06:03 1883 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\13932.vir
    2007-07-08 06:03 1908 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\44750.vir
    2007-07-08 06:03 1910 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1391073.sdf.vir
    2007-07-08 06:03 1921 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\12457.vir
    2007-07-08 06:03 1928 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\44878.vir
    2007-07-08 06:03 1934 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\27060.vir
    2007-07-08 06:03 38627 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\domains.txt.vir
    2007-07-08 07:04 171 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ustat\3586.dat.vir
    2007-07-08 07:08 272466 --a------ C:\Qoobox\Quarantine\C\DOCUME~1\Bob\APPLIC~1\HbTools\HbTools.log.vir
  13. 2007/07/28
    Master Green
    Master Green Inactive Thread Starter
    Part 5 (Combofix log)
    Folder PATH listing for volume PRESARIO
    Volume serial number is 71FAE346 64CE:D752
    C:\QOOBOX
    \---Quarantine
    +---C
    | +---DOCUME~1
    | | +---ALLUSE~1
    | | | \---APPLIC~1
    | | | \---Starware337
    | | | +---buttons
    | | | | epiRSS.bmp.vir
    | | | | epiRSS.png.vir
    | | | | epiSearch.bmp.vir
    | | | | epiSearch.png.vir
    | | | | FindIt.bmp.vir
    | | | | FindItHot.bmp.vir
    | | | | findithotxp.png.vir
    | | | | finditxp.png.vir
    | | | | Highlight.bmp.vir
    | | | | highlightxp.png.vir
    | | | | Reference.bmp.vir
    | | | | referencexp.png.vir
    | | | | Weather.bmp.vir
    | | | | weatherxp.png.vir
    | | | \---contexts
    | | | error.xml.vir
    | | | related.xml.vir
    | | | travel.xml.vir
    | | \---Bob
    | | \---APPLIC~1
    | | \---HbTools
    | | | HbTools.log.vir
    | | \---v3.0
    | | \---HbTools
    | | +---dynamic
    | | | | 1066422.sdf.vir
    | | | | 1383602.sdf.vir
    | | | | 1385370.sdf.vir
    | | | | 1391073.sdf.vir
    | | | | 2208948.sdf.vir
    | | | | 2460565.sdf.vir
    | | | | 2763070.sdf.vir
    | | | | 600583.sdf.vir
    | | | | 625696.sdf.vir
    | | | | 819382.sdf.vir
    | | | | 890068.sdf.vir
    | | | | ASPL1.dat.vir
    | | | | domains.txt.vir
    | | | +---TooltipXML
    | | | | 1000048639.vir
    | | | | 12457.vir
    | | | | 13932.vir
    | | | | 15541.vir
    | | | | 17040.vir
    | | | | 18991.vir
    | | | | 20153.vir
    | | | | 27060.vir
    | | | | 32293.vir
    | | | | 32377.vir
    | | | | 351786.vir
    | | | | 4142.vir
    | | | | 4157.vir
    | | | | 44750.vir
    | | | | 44878.vir
    | | | | 45833.vir
    | | | | 59598.vir
    | | | | 622354.vir
    | | | | 7228.vir
    | | | | 748127.vir
    | | | | 748893.vir
    | | | | 7515.vir
    | | | | 79246.vir
    | | | | 84293.vir
    | | | \---ustat
    | | | 3577.dat.vir
    | | | 3586.dat.vir
    | | \---static
    | | +---1
    | | | ads.cdf.vir
    | | | btntrans.idx.vir
    | | | buttondir.txt.vir
    | | | components.cdf.vir
    | | | default.cdf.vir
    | | | Default_new.mnu.vir
    | | | email-t1-bg.res.vir
    | | | icons2.res.vir
    | | | keywords.idx.vir
    | | | keywords1.dat.vir
    | | | layout.cdf.vir
    | | | progress.res.vir
    | | | t2_bg.res.vir
    | | | theweb.mnu.vir
    | | | top7.cdf.vir
    | | | Top7_theweb.mnu.vir
    | | | tsd_bg.res.vir
    | | +---2
    | | | ads.cdf.vir
    | | | btntrans.idx.vir
    | | | buttondir.txt.vir
    | | | components.cdf.vir
    | | | default.cdf.vir
    | | | Default_new.mnu.vir
    | | | email-t1-bg.res.vir
    | | | icons2.res.vir
    | | | keywords.idx.vir
    | | | keywords1.dat.vir
    | | | layout.cdf.vir
    | | | progress.res.vir
    | | | t2_bg.res.vir
    | | | theweb.mnu.vir
    | | | top7.cdf.vir
    | | | Top7_theweb.mnu.vir
    | | | tsd_bg.res.vir
    | | \---DownLoad
    | | ads.xip.vir
    | | BtnTrans.xip.vir
    | | BtnTrans1.xip.vir
    | | business_promo.xip.vir
    | | buttondir.xip.vir
    | | default.xip.vir
    | | d_icons_buttons_1000.xip.vir
    | | d_icons_buttons_2000.xip.vir
    | | d_icons_buttons_3000.xip.vir
    | | d_icons_buttons_bar.xip.vir
    | | d_icons_buttons_bbar1.xip.vir
    | | d_icons_buttons_logos.xip.vir
    | | d_icons_buttons_other.xip.vir
    | | d_icons_weather.xip.vir
    | | email-t1-bg.xip.vir
    | | hotbar-premium.xip.vir
    | | hotbar_promo.xip.vir
    | | icons2.xip.vir
    | | keywords.xip.vir
    | | keywords1.xip.vir
    | | layout.xip.vir
    | | linkpathlegal.xip.vir
    | | progress.xip.vir
    | | s_icons_buttons.xip.vir
    | | t2_bg.xip.vir
    | | top7.xip.vir
    | | tsd_bg.xip.vir
    | \---WINDOWS
    | \---DOWNLO~1
    | \---TriJinx.1.0.0.55
    | | strings.xml.vir
    | | TriJinx.exe.vir
    | +---assets
    | | | cursor.png.vir
    | | | doorlights.txt.vir
    | | | greybomb.png.vir
    | | | p1icon.png.vir
    | | | scorecloud.png.vir
    | | | setup.xml.vir
    | | | stopper.png.vir
    | | | timer.png.vir
    | | | timerglow.png.vir
    | | | timericon.png.vir
    | | | tm.png.vir
    | | | warning.png.vir
    | | +---audio
    | | | +---music
    | | | \---sfx
  14. 2007/07/28
    Master Green
    Part 6 (Combofix log) and final part.
    | | | \---sfx
    | | | areabomb.ogg.vir
    | | | beetlezap.ogg.vir
    | | | bonusrow.ogg.vir
    | | | bonustimer.ogg.vir
    | | | colorchain.ogg.vir
    | | | dialogbox.ogg.vir
    | | | drumbeat.ogg.vir
    | | | fillrow.ogg.vir
    | | | gateopen.ogg.vir
    | | | helptip.ogg.vir
    | | | powerup.ogg.vir
    | | | timerup.ogg.vir
    | | | warning.ogg.vir
    | | | warning2.ogg.vir
    | | +---backgrounds
    | | | bar.jpg.vir
    | | | chamber0.jpg.vir
    | | | chamber1.jpg.vir
    | | | circledoor.jpg.vir
    | | | hexfield.jpg.vir
    | | | local-hs-bb.png.vir
    | | | mainmenu.jpg.vir
    | | | textfield.png.vir
    | | | trifield.jpg.vir
    | | +---beetles
    | | | beetletatoo.png.vir
    | | | dirt.png.vir
    | | | scarabpost.png.vir
    | | | tritop.png.vir
    | | +---buttons
    | | | arrowup_up.png.vir
    | | | checkdown.png.vir
    | | | checkup.png.vir
    | | | rotleft_up.png.vir
    | | | rotright_up.png.vir
    | | | sliderknob.png.vir
    | | | sliderrail.png.vir
    | | +---characters
    | | | +---anwar
    | | | | \---look
    | | | | pl0001.png.vir
    | | | +---bast
    | | | | \---look
    | | | | bl0001.png.vir
    | | | \---kristine
    | | | \---look
    | | | kl0001.png.vir
    | | +---fonts
    | | | lithos.mvec.vir
    | | +---helptips
    | | | arrowkeys.png.vir
    | | | helptip.jpg.vir
    | | +---levels
    | | | levels.dat.vir
    | | +---models
    | | | disk.mesh.vir
    | | | flattri.mesh.vir
    | | | pyramid.mesh.vir
    | | | quad.mesh.vir
    | | +---scenes
    | | | page1-0.xml.vir
    | | | page1-1.xml.vir
    | | | panel1-0-1.png.vir
    | | | panel1-1-1.png.vir
    | | +---sfx
    | | | bolt_1.png.vir
    | | | bolt_2.png.vir
    | | | bolt_3.png.vir
    | | | bolt_4.png.vir
    | | | bolt_tail.png.vir
    | | | flash.png.vir
    | | | rubble.png.vir
    | | | smoke.png.vir
    | | | smoke2.png.vir
    | | | smoke3.png.vir
    | | +---splash
    | | +---statues
    | | | +---statue0
    | | | | snake_dirty.png.vir
    | | | \---statue1
    | | | arm01_dirty.png.vir
    | | | mask01_1.png.vir
    | | +---trails
    | | | mouseblue1.png.vir
    | | | mouseblue2.png.vir
    | | | mouseblue3.png.vir
    | | | mousegreen1.png.vir
    | | | mousegreen2.png.vir
    | | | mousegreen3.png.vir
    | | | mousered1.png.vir
    | | | mousered2.png.vir
    | | | mousered3.png.vir
    | | +---triangles
    | | | | areabomb.png.vir
    | | | | blue.png.vir
    | | | | boardfill.png.vir
    | | | | brick.png.vir
    | | | | brick1.png.vir
    | | | | brick2.png.vir
    | | | | brick3.png.vir
    | | | | bricktip.png.vir
    | | | | eye1.png.vir
    | | | | eye2.png.vir
    | | | | eye3.png.vir
    | | | | eye4.png.vir
    | | | | green.png.vir
    | | | | red.png.vir
    | | | | redrollover.png.vir
    | | | | wild.png.vir
    | | | | yellow.png.vir
    | | | \---clearanim
    | | | cleared1.png.vir
    | | | cleared2.png.vir
    | | | cleared3.png.vir
    | | | cleared4.png.vir
    | | | cleared5.png.vir
    | | | cleared6.png.vir
    | | +---upsell
    | | | image0.jpg.vir
    | | | image1.jpg.vir
    | | | image2.jpg.vir
    | | | image3.jpg.vir
    | | \---urns
    | | bluebucket.png.vir
    | | chainlink.png.vir
    | | chaintip.png.vir
    | | greenbucket.png.vir
    | | redbucket.png.vir
    | | smallblue.png.vir
    | | smallgreen.png.vir
    | | smallred.png.vir
    | | smallyellow.png.vir
    | | urnglow.png.vir
    | | urnplatform.png.vir
    | \---screens
    | error.lua.vir
    | game.lua.vir
    | gameover.lua.vir
    | hiscore.lua.vir
    | hiscoreinfo.lua.vir
    | leveldesign.lua.vir
    | levelover.lua.vir
    | mainarcade.lua.vir
    | mainconfirm.lua.vir
    | maingames.lua.vir
    | mainpuzzle.lua.vir
    | maphelptip.lua.vir
    | options.lua.vir
    | pause.lua.vir
    | quitconfirm.lua.vir
    | start.lua.vir
    | storyplayer.lua.vir
    | style.lua.vir
    | upsell.lua.vir
    \---Registry_backups
    [/code]
  15. 2007/07/28
    noahdfear
    noahdfear Inactive
    That looks like the extra.txt log. Please find and post the main.txt log.
  16. 2007/07/28
    noahdfear
    noahdfear Inactive
    Sorry ....... that was the quarantine log. I need to see the combofix.txt :eek:
  17. 2007/07/28
    Master Green
    Noahdfear,
    I'm not sure if this is what you are requesting because I can not find anything that is or related to main.txt log:
    "Owner" - 2007-07-28 13:31:43 - ComboFix 07-07-23.6 - Service Pack 1 NTFS
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\error.xml
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\related.xml
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\Starware337\contexts\travel.xml
    C:\DOCUME~1\Bob\APPLIC~1\HbTools
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\HbTools.log
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1066422.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1383602.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1385370.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\1391073.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2208948.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2460565.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\2763070.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\600583.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\625696.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\819382.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\890068.sdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ASPL1.dat
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\domains.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\1000048639
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\12457
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\13932
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\15541
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\17040
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\18991
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\20153
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\27060
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\32293
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\32377
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\351786
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\4142
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\4157
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\44750
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\44878
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\45833
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\59598
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\622354
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\7228
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\748127
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\748893
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\7515
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\79246
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\TooltipXML\84293
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ustat\3577.dat
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\dynamic\ustat\3586.dat
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\ads.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\btntrans.idx
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\business_promo.htm
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\buttondir.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\components.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_1000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_2000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_3000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_bar.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_bbar1.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_logos.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_buttons_other.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\d_icons_weather.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\default.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_511745-514279.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz1.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz10.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz11.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz12.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz13.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz14.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz15.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz16.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz17.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz18.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz19.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz2.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz20.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz3.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz4.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz5.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz6.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz7.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz8.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_bidz9.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_categorize.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_comparison.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_em_PROFL_CA_flow_b_IEB.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_explorer-Mails.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_explorer-people.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_favorites.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Games.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Hide.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_hotbarcom.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Hotmail.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_hsskin.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemster.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemsterie.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jemsteruk.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_jobsearch.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_Mails.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_new.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_premium.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_reun.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_ringtones.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_SearchBoxTrapper.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_searchfor.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_searchgo.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_weather.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Default_yellowpages.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-def-511724-548964.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-def-511724-9595.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\email-t1-bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar-premium-hotbar-premium.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar-premium.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\hotbar_promo.htm
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\icons2.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\keywords.idx
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\keywords1.dat
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\layout.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\linkpathlegal.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\progress.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\s_icons_buttons.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\sales_buttons.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\t2_bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\theweb.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\top7.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\Top7_theweb.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\1\tsd_bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\ads.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\btntrans.idx
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\business_promo.htm
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\buttondir.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\components.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_1000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_2000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_3000.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_bar.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_bbar1.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_logos.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_buttons_other.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\d_icons_weather.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\default.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_511745-514279.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz1.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz10.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz11.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz12.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz13.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz14.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz15.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz16.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz17.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz18.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz19.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz2.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz20.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz3.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz4.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz5.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz6.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz7.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz8.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_bidz9.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_categorize.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_comparison.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_em_PROFL_CA_flow_b_IEB.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_explorer-Mails.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_explorer-people.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_favorites.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Games.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Hide.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_hotbarcom.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Hotmail.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_hsskin.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemster.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemsterie.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jemsteruk.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_jobsearch.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_Mails.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_new.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_premium.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_reun.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_ringtones.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_SearchBoxTrapper.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_searchfor.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_searchgo.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_weather.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Default_yellowpages.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-def-511724-548964.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-def-511724-9595.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\email-t1-bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar-premium-hotbar-premium.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar-premium.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\hotbar_promo.htm
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\icons2.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\keywords.idx
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\keywords1.dat
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\layout.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\linkpathlegal.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\progress.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\s_icons_buttons.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\sales_buttons.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\t2_bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\theweb.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\top7.cdf
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\Top7_theweb.mnu
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\2\tsd_bg.res
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\ads.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\BtnTrans.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\BtnTrans1.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\business_promo.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\buttondir.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_1000.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_2000.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_3000.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_bar.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_bbar1.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_logos.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_buttons_other.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\d_icons_weather.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\default.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\email-t1-bg.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\hotbar-premium.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\hotbar_promo.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\icons2.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\keywords.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\keywords1.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\layout.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\linkpathlegal.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\progress.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\s_icons_buttons.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\sales_buttons.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\samplegroups2.txt
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\samplegroups2.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\t2_bg.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\top7.xip
    C:\DOCUME~1\Bob\APPLIC~1\HbTools\v3.0\HbTools\static\DownLoad\tsd_bg.xip
  18. 2007/07/28
    Master Green
    Part 2
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\music\mainmenumusic.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\areabomb.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\beetlezap.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\bonusrow.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\bonustimer.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\bucketfilled.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\clearpyramid.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1a.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1b.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle1c.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2a.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2b.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\cleartriangle2c.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\colorchain.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\dialogbox.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\drumbeat.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\fillrow.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\gateopen.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\helptip.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\powerup.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\rotateboardleft.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\timerup.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\warning.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\audio\sfx\warning2.ogg
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\doorlights.txt
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\fonts\jackarmstrong.mvec
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\fonts\lithos.mvec
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\levels\levels.dat
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\disk.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\equilateraltriangle.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\flattri.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\pyramid.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\quad.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\rotatingpyramid.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\models\scarabpanel.mesh
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\scenes\page1-0.xml
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\scenes\page1-1.xml
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\assets\setup.xml
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\error.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\game.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\gameover.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\hiscore.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\hiscoreinfo.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\hiscoresubmit.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\instructions.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\leveldesign.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\levelover.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\mainarcade.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\mainconfirm.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\maincontinue.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\maingames.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\mainpuzzle.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\maphelptip.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\options.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\pause.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\quitconfirm.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\start.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\storyplayer.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\style.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\screens\upsell.lua
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\strings.xml
    C:\WINDOWS\DOWNLO~1.\TriJinx.1.0.0.55\TriJinx.exe
  19. 2007/07/28
    Master Green
    Part 3 (Final)
    ((((((((((((((((((((((((( Files Created from 2007-06-28 to 2007-07-28 )))))))))))))))))))))))))))))))
    2007-07-28 13:29 51,200 --a------ C:\WINDOWS\nircmd.exe
    2007-07-28 12:59 <DIR> d-------- C:\fixpath2
    2007-07-26 16:52 557,056 --a------ C:\DOCUME~1\ADMINI~1\NTUSER.DAT
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\WINDOWS
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\APPLIC~1\Symantec
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\APPLIC~1\Sonic
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\APPLIC~1\SampleView
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\APPLIC~1\Real
    2007-07-26 16:52 <DIR> d-------- C:\DOCUME~1\ADMINI~1\APPLIC~1\interMute
    2007-07-26 15:47 <DIR> d-------- C:\WINDOWS\system32\ActiveScan
    2007-07-24 23:24 499,712 --a------ C:\WINDOWS\system32\msvcp71.dll
    2007-07-24 23:24 348,160 --a------ C:\WINDOWS\system32\msvcr71.dll
    2007-07-24 22:56 <DIR> d-------- C:\WINDOWS\system32\NtmsData
    2007-07-22 18:17 <DIR> d-------- C:\Program Files\Enigma Software Group
    2007-07-19 17:05 <DIR> d-------- C:\Program Files\Lavasoft
    2007-07-19 17:05 <DIR> d-------- C:\Program Files\Common Files\Wise Installation Wizard
    2007-07-19 17:05 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Lavasoft
    2007-07-19 17:03 <DIR> d-------- C:\Program Files\SpywareGuard
    2007-07-19 16:59 <DIR> d-------- C:\Program Files\SpywareBlaster
    2007-07-18 18:48 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Spybot - Search & Destroy
    2007-07-18 17:30 <DIR> d-------- C:\WINDOWS\pss
    2007-07-16 12:37 <DIR> d-------- C:\Program Files\ACW
    2007-07-15 11:50 593,408 --a------ C:\WINDOWS\system32\h323msp.dll
    2007-07-15 11:50 548,352 --a------ C:\WINDOWS\system32\rtcdll.dll
    2007-07-15 11:50 439,808 --a------ C:\WINDOWS\system32\ipnathlp.dll
    2007-07-15 11:50 36,864 --a------ C:\WINDOWS\system32\mf3216.dll
    2007-07-15 10:53 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Office Genuine Advantage
    2007-07-15 10:29 991,232 --a------ C:\WINDOWS\system32\esent.dll
    2007-07-15 07:09 86,016 --a------ C:\WINDOWS\unvise32qt.exe
    2007-07-15 07:08 <DIR> d-------- C:\WINDOWS\system32\QuickTime
    2007-07-15 06:46 208,896 --a------ C:\WINDOWS\system32\wmpns.dll
    2007-07-14 08:43 2,641,973 --a------ C:\WINDOWS\system32\opapi11.dll
    2007-07-14 07:45 <DIR> d-------- C:\WINDOWS\system32\bits
    2007-07-14 07:31 <DIR> d-------- C:\WINDOWS\system32\PreInstall
    2007-07-14 07:30 22,752 --a------ C:\WINDOWS\system32\spupdsvc.exe
    2007-07-14 07:20 7,680 --------- C:\WINDOWS\system32\bitsprx2.dll
    2007-07-14 07:20 7,168 --------- C:\WINDOWS\system32\bitsprx3.dll
    2007-07-14 07:20 331,776 --a------ C:\WINDOWS\system32\winhttp.dll
    2007-07-14 07:20 17,408 --a------ C:\WINDOWS\system32\qmgrprxy.dll
    2007-07-14 04:16 <DIR> d-------- C:\WINDOWS\system32\SoftwareDistribution
    2007-07-14 04:14 549,720 --a------ C:\WINDOWS\system32\wuapi.dll
    2007-07-14 04:14 33,624 --a------ C:\WINDOWS\system32\wups.dll
    2007-07-14 04:14 325,976 --a------ C:\WINDOWS\system32\wucltui.dll
    2007-07-14 04:14 203,096 --a------ C:\WINDOWS\system32\wuweb.dll
    2007-07-14 04:14 186,136 --a------ C:\WINDOWS\system32\wuaueng1.dll
    2007-07-14 04:14 167,704 --a------ C:\WINDOWS\system32\wuauclt1.exe
    2007-07-13 12:10 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\WeatherStudio Desktop(2)
    2007-07-10 08:35 2,097,152 --a------ C:\DOCUME~1\Owner\ntuser.dat
    2007-07-10 08:24 57,856 --a------ C:\WINDOWS\system32\drivers\drmk.sys
    2007-07-10 08:24 134,272 --a------ C:\WINDOWS\system32\drivers\portcls.sys
    2007-07-10 08:23 51,072 --a------ C:\WINDOWS\system32\drivers\i8042prt.sys
    2007-07-10 08:23 23,424 --a------ C:\WINDOWS\system32\drivers\kbdclass.sys
    2007-07-10 08:17 56,832 --a------ C:\WINDOWS\system32\drivers\sysaudio.sys
    2007-07-10 08:17 54,272 --a------ C:\WINDOWS\system32\drivers\swmidi.sys
    2007-07-10 08:17 50,048 --a------ C:\WINDOWS\system32\drivers\DMusic.sys
    2007-07-10 08:17 24,960 --a------ C:\WINDOWS\system32\drivers\usbprint.sys
    2007-07-10 08:17 2,816 --a------ C:\WINDOWS\system32\drivers\drmkaud.sys
    2007-07-10 08:08 <DIR> dr-hs---- C:\cmdcons
    2007-07-10 06:41 <DIR> dr-hsc--- C:\WINDOWS\system32\dllcache
    2007-07-25 05:59:08 -------- d--h--w C:\Program Files\InstallShield Installation Information
    2007-07-25 01:46:59 -------- d-----w C:\Program Files\Canon
    2007-07-25 01:30:52 -------- d-----w C:\Program Files\Oberon Media
    2007-07-25 01:26:36 -------- d-----w C:\Program Files\Coupons
    2007-07-22 13:29:46 -------- d-----w C:\Program Files\hbinst
    2007-07-20 00:59:18 -------- d-----w C:\Program Files\Symantec
    2007-07-16 12:57:23 1,385,744 ----a-w C:\WINDOWS\system32\msvbvm60.dll
    2007-07-15 17:44:33 -------- d-----w C:\Program Files\Messenger
    2007-07-15 14:10:07 -------- d-----w C:\Program Files\QuickTime
    2007-07-14 22:06:30 -------- d-----w C:\Program Files\Google
    2007-07-14 11:15:03 -------- d--h--w C:\Program Files\WindowsUpdate
    2007-07-13 14:00:18 -------- d-----w C:\Program Files\Easy Internet signup
    2007-07-10 15:48:10 4,123 ----a-w C:\WINDOWS\viassary-hp.reg
    2007-07-10 15:32:51 3,642 --sha-r C:\WINDOWS\system32\drivers\HP_DW254A-ABA SR1010N NA510_YC_Pres_QMXK412_E42NAheRET3_4_IGamila Giovani Neon series_SMICRO-STAR INTERNATIONAL CO., LTD_V030_B3.08_T040225_WXH1_L409_M248_J40_7Intel_8Celeron_92.7_1_N10EC8139_P_Z11C1044C_K_A808624C5.MRK
    2007-07-10 14:03:10 -------- d-----w C:\Program Files\Windows NT
    2007-07-10 14:03:06 -------- d-----w C:\Program Files\Movie Maker
    2007-06-23 12:46:37 -------- d-----w C:\Program Files\The Weather Channel FW
    2007-06-23 12:46:18 -------- d-----w C:\Program Files\The Weather Channel Toolbar
    2007-06-04 22:18:48 9,344 ----a-w C:\WINDOWS\system32\drivers\NSDriver.sys
    2007-06-04 22:17:02 8,320 ----a-w C:\WINDOWS\system32\drivers\AWRTRD.sys
    2007-06-04 22:14:56 6,272 ----a-w C:\WINDOWS\system32\drivers\AWRTPD.sys
    "KBD "= "C:\HP\KBD\KBD.EXE" [2003-02-11 20:02]
    "UpdateManager "= "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" [2003-08-19 09:01]
    "TkBellExe "= "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" [2004-01-26 05:29]
    "VTTimer "= "VTTimer.exe" []
    "AlcxMonitor "= "ALCXMNTR.EXE" [2003-04-03 21:35 C:\WINDOWS\ALCXMNTR.EXE]
    "SunJavaUpdateSched "= "C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe" [2007-07-12 04:00]
    "AVG7_CC "= "C:\PROGRA~1\Grisoft\AVG7\avgcc.exe" [2007-07-27 00:41]
    "RecordNow! "=" " []
    "MSMSGS "= "C:\Program Files\Messenger\MSMSGS.exe" [2004-11-15 16:18]
    C:\Documents and Settings\Owner\Start Menu\Programs\Startup\
    SpywareGuard.lnk - C:\Program Files\SpywareGuard\sgmain.exe [2003-08-29 19:05:35]
    wkcalrem.LNK - C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkCalRem.exe [2002-07-11 04:03:34]
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
    Quicken Scheduled Updates.lnk - C:\Program Files\Quicken\bagent.exe [2003-07-30 05:49:48]
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\minimal\aawservice]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Compaq Connections.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Compaq Connections.lnk
    backup=C:\WINDOWS\pss\Compaq Connections.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^MyWebSearch Email Plugin.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\MyWebSearch Email Plugin.lnk
    backup=C:\WINDOWS\pss\MyWebSearch Email Plugin.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^MyWebSearch Email Plugin.lnk]
    path=C:\Documents and Settings\Owner\Start Menu\Programs\Startup\MyWebSearch Email Plugin.lnk
    backup=C:\WINDOWS\pss\MyWebSearch Email Plugin.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^spamsubtract.lnk]
    path=C:\Documents and Settings\Owner\Start Menu\Programs\Startup\spamsubtract.lnk
    backup=C:\WINDOWS\pss\spamsubtract.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\hpsysdrv]
    c:\windows\system\hpsysdrv.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LTMSG]
    LTMSG.exe 7
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PhotoShow Deluxe Media Manager]
    C:\PROGRA~1\Comcast\COMCAS~1\data\xtras\mssysmgr.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Reminder]
    "C:\Windows\Creator\Remind_XP.exe "
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SpyHunter]
    C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WeatherStudio Desktop]
    "C:\Program Files\WeatherStudio Desktop\WeatherStudio Desktop.exe "
    R0 fasttx2k;fasttx2k;C:\WINDOWS\System32\DRIVERS\fasttx2k.sys
    R1 AFS2K;AFS2k;C:\WINDOWS\System32\drivers\AFS2K.sys
    R3 ALCXSENS;Service for WDM 3D Audio Driver;C:\WINDOWS\System32\drivers\ALCXSENS.SYS
    R3 ltmodem5;Agere Modem Driver;C:\WINDOWS\System32\DRIVERS\ltmdmnt.sys
    R3 MxlW2k;MxlW2k;C:\WINDOWS\System32\drivers\MxlW2k.sys
    R3 Ps2;PS2;C:\WINDOWS\System32\DRIVERS\PS2.sys
    R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver;C:\WINDOWS\System32\DRIVERS\usbehci.sys
    R3 usbhub;USB2 Enabled Hub;C:\WINDOWS\System32\DRIVERS\usbhub.sys
    R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver;C:\WINDOWS\System32\DRIVERS\usbuhci.sys
    S3 Fax;Fax;C:\WINDOWS\system32\fxssvc.exe
    S3 usbohci;Microsoft USB Open Host Controller Miniport Driver;C:\WINDOWS\System32\DRIVERS\usbohci.sys
    S3 usbprint;Microsoft USB PRINTER Class;C:\WINDOWS\System32\DRIVERS\usbprint.sys
    S3 viagfx;viagfx;C:\WINDOWS\System32\DRIVERS\vtmini.sys
    2007-07-13 14:00:17 C:\WINDOWS\tasks\Easy Internet Sign-up.job
    2007-06-15 06:20:53 C:\WINDOWS\tasks\McDefragTask.job
    2007-07-01 06:00:27 C:\WINDOWS\tasks\McQcTask.job
    catchme 0.3.1061 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2007-07-28 13:37:29
    Windows 5.1.2600 Service Pack 1 NTFS
    scanning hidden processes ...
    scanning hidden registry entries ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    Completion time: 2007-07-28 13:38:40
    C:\ComboFix-quarantined-files.txt ... 2007-07-28 13:38
    --- E O F ---
  20. 2007/07/28
    noahdfear
    noahdfear Inactive
    Yes! That's the one I wanted. :)
    Will take me some time to analyze. In the meantime, copy the following bolded blue text to a blank notepad, then save it to the desktop as;
    Filename: hosts.bat
    Save As Type: All Files (*.*)
    dir %Systemdrive%\HOSTS /a h /s > c:\hosts.txt
    start notepad c:\hosts.txt
    cls
    exit
    Double click the bat file. It should run and close quickly. Post the contents of the hosts.txt that opens.
  21. 2007/07/28
    Master Green
    Noahdfear,
    Thank you for everything, I saved the last to a notepad and it's on the desktop as an Icon "Hosts "...Will check back this evening for further instructions...
