Solved Possible infection
Discussion in 'Malware and Virus Removal Archive' started by gpb59, 2014/05/15.
  1. 2014/05/17
    gpb59
    gpb59 Well-Known Member Thread Starter
    C:\AdwCleaner\Quarantine\C\ProgramData\Tarma Installer\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}\_Setupx.dll.vir Win32/Adware.Yontoo.B application cleaned by deleting - quarantined
  2. 2014/05/17
    Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions (if present).
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
    gpb59
    thank you very much, did I have any of these trojans, rootkits or bootkits ?
  5. 2014/05/17
    No. Your passwords are safe.
    Good luck and stay safe :)
