Solved Please Help, I'm Completely Stumped (Trojan.Bankpatch.C!inf)
Discussion in 'Malware and Virus Removal Archive' started by Timmy12, 2010/01/19.
  1. 2010/01/25
    Timmy12
    Timmy12 Inactive Thread Starter
    also, one last thing that is driving me nuts, and i have no idea if it is related to this virus is that when i try to visit a specific website i keep getting this "The connection to the server was reset while the page was loading." and it's driving me nuts. I get it on all internet browsers on my computer and only when connected to my home network. Any suggestions?
  2. 2010/01/25
    Regarding connection issues, you'll probably have to start another topic in general forum.
    For now, let's go through final cleaning steps.
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Unless you installed Viewpoint Manager knowledgeably...
    Go Start>Control Panel>Add\Remove (Programs and Features in Vista), and...
    Uninstall any of the following programs associated with Viewpoint:
    * Viewpoint Manager
    * Viewpoint Media Player
    * Viewpoint Toolbar
    This program does not do anything bad such as deliver ads or spy on you, but it is considered foistware ( "drive-by-install ") as it is installed without your consent through programs like AOl, AIM, Compuserve, etc.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    - O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    - O4 - HKLM\..\Run: [HP Health Check Scheduler] c:\Program Files (x86)\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe
    - O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Java\jre6\bin\jusched.exe "
    - O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe "
    - O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe "
    - O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files (x86)\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
    - O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe
    - O4 - HKCU\..\Run: [Google Update] "C:\Users\Timmy\AppData\Local\Google\Update\GoogleUpdate.exe" /c
    - O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
    - O20 - Winlogon Notify: !SASWinLogon - C:\Program Files (x86)\SUPERAntiSpyware\SASWINLO.DLL
    5. Click on Fix checked button.
    6. Restart computer.
    7. Post new HijackThis log.
    Timmy12
    Scan saved at 10:31:42 PM, on 1/25/2010
    Platform: Windows Vista SP1 (WinNT 6.00.1905)
    MSIE: Internet Explorer v8.00 (8.00.6001.18882)
    C:\Program Files (x86)\DigitalPersona\Bin\DpAgent.exe
    C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\ccSvcHst.exe
    C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAAnotif.exe
    C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch Buttons\QLBCTRL.exe
    C:\Program Files (x86)\Adobe\Reader 8.0\Reader\reader_sl.exe
    C:\Program Files (x86)\Trend Micro\HijackThis\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=en_us&c=83&bd=Pavilion&pf=cnnb
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=en_us&c=83&bd=Pavilion&pf=cnnb
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=en_us&c=83&bd=Pavilion&pf=cnnb
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=en_us&c=83&bd=Pavilion&pf=cnnb
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: Symantec NCO BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\coIEPlg.dll
    O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\IPSBHO.DLL
    O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll
    O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
    O3 - Toolbar: Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\coIEPlg.dll
    O4 - HKLM\..\Run: [UCam_Menu] "C:\Program Files (x86)\CyberLink\YouCam\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\YouCam" update "Software\CyberLink\YouCam\2.0 "
    O4 - HKLM\..\Run: [DpAgent] C:\Program Files (x86)\DigitalPersona\Bin\dpagent.exe
    O4 - HKLM\..\Run: [QlbCtrl.exe] "C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe" /Start
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
    O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
    O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\Office12\EXCEL.EXE/3000
    O8 - Extra context menu item: Send image to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
    O8 - Extra context menu item: Send page to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\Office12\REFIEBAR.DLL
    O9 - Extra button: Send To Bluetooth - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O9 - Extra 'Tools' menuitem: Send to &Bluetooth Device... - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
    O13 - Gopher Prefix:
    O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll
    O18 - Protocol: symres - {AA1061FE-6C41-421F-9344-69640C9732AB} - C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\coIEPlg.dll
    O23 - Service: Andrea ST Filters Service (AESTFilters) - Unknown owner - C:\Windows\System32\DriverStore\FileRepository\stwrt64.inf_58be29c0\AESTSr64.exe (file missing)
    O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Unknown owner - C:\Windows\system32\agr64svc.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
    O23 - Service: Com4QLBEx - Hewlett-Packard Development Company, L.P. - C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch Buttons\Com4QLBEx.exe
    O23 - Service: @dfsrres.dll,-101 (DFSR) - Unknown owner - C:\Windows\system32\DFSR.exe (file missing)
    O23 - Service: Biometric Authentication Service (DpHost) - DigitalPersona, Inc. - C:\Program Files (x86)\DigitalPersona\Bin\DpHostW.exe
    O23 - Service: Futronic FinLogon Integration Service (ftrFLIntegrationService) - Futronic Technology Company Ltd. - C:\Windows\SysWOW64\ftrFLIntegrationService.exe
    O23 - Service: HP Health Check Service - Hewlett-Packard - c:\Program Files (x86)\Hewlett-Packard\HP Health Check\hphc_service.exe
    O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe
    O23 - Service: HP Service (hpsrv) - Unknown owner - C:\Windows\system32\Hpservice.exe (file missing)
    O23 - Service: Intel(R) Matrix Storage Event Monitor (IAANTMON) - Intel Corporation - C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
    O23 - Service: Norton 360 (N360) - Symantec Corporation - C:\Program Files (x86)\Norton 360\Engine\3.5.2.11\ccSvcHst.exe
    O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
    O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: Recovery Service for Windows - Unknown owner - C:\Windows\SMINST\BLService.exe
    O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\SLsvc.exe,-101 (slsvc) - Unknown owner - C:\Windows\system32\SLsvc.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
    O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
    O23 - Service: Audio Service (STacSV) - Unknown owner - C:\Windows\System32\DriverStore\FileRepository\stwrt64.inf_58be29c0\STacSV64.exe (file missing)
    O23 - Service: Symantec RemoteAssist - Symantec, Inc. - C:\Program Files (x86)\Common Files\Symantec Shared\Support Controls\ssrc.exe
    O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
    O23 - Service: Validity Fingerprint Service (vfsFPService) - Validity Sensors, Inc. - C:\Windows\system32\vfsFPService.exe
    O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files (x86)\Viewpoint\Common\ViewpointService.exe
    O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
    O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
    O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
    End of file - 9883 bytes
  5. 2010/01/25
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  6. 2010/01/25
    Timmy12
    cool. thank you very much for your help. seems to me like everything is ok. The only thing i notice is that if i go into norton, and look at my history, it shows the trojan.bankpatch.C!inf thing as still being in my computer and not able to be removed. But i wonder if it's just part of the history or something. I'm not sure tho.
    Now i just gotta figure out this network problem. It's driving me nuts
  7. 2010/01/25
    I'm not familiar with Norton at all, but it must be just some info, since no other scan shows it.
    Happy surfing :)
