Physical Location of Recycle Bin on C: Drive
Discussion in 'Legacy Windows' started by klarsen, 2005/09/27.
  1. 2005/09/27
    klarsen
    klarsen Inactive Thread Starter
    I inadvertantly deleted the VMM32.vxd file. This is the file which loads all of
    the device drivers for Windows ME. Needless to say, the computer will no longer load windows. I am able to get a DOS prompt using a start up disk. I would like to restore the file from the recycle bin to the system directory using dos commands, but I am not sure of where the recycle bin is located on the c: drive.
    Any ideas would be appreciated.
  2. 2005/09/27
    charlesvar
    charlesvar Inactive Alumni
    Hello klarsen,
    Its a hidden folder on the C drive called Recycle
    Forgot: Bring up the drive > Tools > Folder options > View tab and tick show hidden files and folders.
    FYI: a restoration program:
    http://www.snapfiles.com/get/restoration.html
    Regards - Charles
    TopFarmer
    TopFarmer Well-Known Member
    klarsen
    Thanks TopFarmer! That was exactly what I was looking for! :)
