Resolved pc stuck in standby mode
Discussion in 'Windows XP' started by cecoleman, 2011/08/21.
  1. 2011/08/21
    cecoleman
    cecoleman Inactive Thread Starter
    my xp desktop is stuck in the standby mode the botton is in and my pc will not shut down or boot back up correctly.
    please help
    system info:
    emachine-W3650
    intel-celeron(R)cpu 440@2.00GHZ
    2.00GHz,0.99gb of ram
    Realtek sound card
    windows xp service pack3
  2. 2011/08/21
    wildfire
    wildfire Getting Old
    Hi cecoleman,
    We encourage all members to enter their system details, it could help resolving this and any future issues you may have.
    What happens if you remove power completely from the mains, or if a laptop (you see why we need specs ;)) remove the battery and charger. Leave it for ~30 seconds and reconnect power then try to switch on?
    The button should not "stay in" unless it is jammed. If I am reading correctly, you need to find a way to release or un-jam it. I have had that once or twice and if the button gets stuck, the computer won't work correctly.
    Most desktop computers have a removable or pull-off front. That can cause problems if it is loose. If it is just "stuck ", get a pin or needle to get it back out and investigate why it is happening.
    cecoleman likes this.
