Inactive PC RX Invasion?
Discussion in 'Malware and Virus Removal Archive' started by virginia, 2010/11/27.
  1. 2010/11/30
    Looking back at the error from your reply #17....
    Did you open "cmd" as Administrator (in Vista, while holding CTRL, and SHIFT, press Enter)?
  2. 2010/12/01
    Just as a double check, I went back this morning and repeated the instructions and got the same result. I made sure I was logged in as administrator and used the Control, Shift, Enter.
    In the string of instructions that you had me use, the term "reset" is used twice. Is that correct?
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  5. 2010/12/02
    Here is the OTL log - Extras to Follow:
    OTL.Txt:
    OTL logfile created on: 12/2/2010 9:21:46 AM - Run 1
    OTL by OldTimer - Version 3.2.17.3 Folder = C:\Users\Neal\Desktop
    Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18975)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    3.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 83.00% Memory free
    6.00 Gb Paging File | 5.00 Gb Available in Paging File | 88.00% Paging File free
    Paging file location(s): ?:\pagefile.sys
    %SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files
    Drive C: | 288.04 Gb Total Space | 209.42 Gb Free Space | 72.70% Space Free | Partition Type: NTFS
    Drive D: | 10.00 Gb Total Space | 5.85 Gb Free Space | 58.45% Space Free | Partition Type: NTFS
    Computer Name: NEAL-PC | User Name: Neal | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: Current user | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2010/12/01 21:51:58 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Users\Neal\Desktop\OTL.exe
    PRC - [2010/06/29 12:48:45 | 002,403,568 | ---- | M] (SUPERAntiSpyware.com) -- C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    PRC - [2009/11/30 10:44:05 | 000,198,160 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    PRC - [2009/09/13 18:52:50 | 001,048,392 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Security Essentials\msseces.exe
    PRC - [2009/07/02 17:36:52 | 000,017,904 | ---- | M] (Microsoft Corporation) -- c:\Program Files\Microsoft Security Essentials\MsMpEng.exe
    PRC - [2009/05/19 10:36:18 | 000,240,512 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    PRC - [2009/04/11 01:28:15 | 000,117,248 | ---- | M] () -- \\?\C:\Windows\System32\wbem\WMIADAP.EXE
    PRC - [2009/04/11 01:27:36 | 002,926,592 | ---- | M] (Microsoft Corporation) -- C:\Windows\explorer.exe
    PRC - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
    PRC - [2008/01/17 07:22:20 | 004,907,008 | ---- | M] (Realtek Semiconductor) -- C:\Windows\RtHDVCpl.exe
    PRC - [2007/12/05 06:17:24 | 000,077,824 | ---- | M] (Andrea Electronics Corporation) -- C:\Windows\System32\AERTSrv.exe
    PRC - [2006/11/03 18:02:14 | 000,050,688 | ---- | M] (Avanquest Software ) -- C:\Program Files\Digital Line Detect\DLG.exe
    PRC - [2006/10/03 11:37:04 | 000,081,920 | ---- | M] (Macrovision Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
    MOD - [2010/12/01 21:51:58 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Users\Neal\Desktop\OTL.exe
    MOD - [2010/08/31 10:43:52 | 001,686,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll
    SRV - [2010/07/14 21:10:21 | 000,030,192 | ---- | M] (Google) [On_Demand | Stopped] -- C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe -- (GoogleDesktopManager-051210-111108)
    SRV - [2010/03/18 12:16:28 | 000,753,504 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe -- (WPFFontCache_v0400)
    SRV - [2010/03/18 12:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
    SRV - [2009/09/24 20:27:04 | 000,793,088 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Windows\System32\FntCache.dll -- (FontCache)
    SRV - [2009/08/05 22:48:42 | 000,704,864 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Live\Family Safety\fsssvc.exe -- (fsssvc)
    SRV - [2009/07/02 17:36:52 | 000,017,904 | ---- | M] (Microsoft Corporation) [Auto | Running] -- c:\Program Files\Microsoft Security Essentials\MsMpEng.exe -- (MsMpSvc)
    SRV - [2009/05/19 10:36:18 | 000,240,512 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe -- (SeaPort)
    SRV - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto | Running] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
    SRV - [2008/01/19 02:38:24 | 000,272,952 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
    SRV - [2007/12/05 06:17:24 | 000,077,824 | ---- | M] (Andrea Electronics Corporation) [Auto | Running] -- C:\Windows\System32\AERTSrv.exe -- (AERTFilters)
    SRV - [2007/10/25 14:27:54 | 000,266,240 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Live\installer\WLSetupSvc.exe -- (WLSetupSvc)
    SRV - [2007/09/02 17:03:02 | 000,016,936 | ---- | M] (Citrix Online, a division of Citrix Systems, Inc.) [On_Demand | Stopped] -- C:\Program Files\Citrix\GoToAssist\480\g2aservice.exe -- (GoToAssist)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\nwlnkfwd.sys -- (NwlnkFwd)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\nwlnkflt.sys -- (NwlnkFlt)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\ipinip.sys -- (IpInIp)
    DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Users\Neal\AppData\Local\Temp\catchme.sys -- (catchme)
    DRV - File not found [Kernel | Disabled | Stopped] -- C:\Windows\System32\drivers\blbdrive.sys -- (blbdrive)
    DRV - [2010/05/10 13:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/02/17 13:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2009/08/05 22:48:42 | 000,054,632 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\fssfltr.sys -- (fssfltr)
    DRV - [2009/07/14 17:54:00 | 009,557,216 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\nvlddmkm.sys -- (nvlddmkm)
    DRV - [2009/06/18 18:48:04 | 000,042,480 | ---- | M] (Microsoft Corporation) [File_System | On_Demand | Stopped] -- C:\Windows\System32\drivers\MpNWMon.sys -- (MpNWMon)
    DRV - [2009/04/30 23:01:36 | 000,265,496 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\lvrs.sys -- (LVRS)
    DRV - [2009/04/30 22:55:34 | 000,013,976 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\lv302af.sys -- (pepifilter)
    DRV - [2009/04/30 10:47:20 | 000,040,480 | ---- | M] (COMODO Security Solutions Inc.) [Kernel | Boot | Running] -- C:\Windows\System32\drivers\csdf.sys -- (csdf)
    DRV - [2009/04/30 10:46:06 | 000,037,920 | ---- | M] (COMODO Security Solutions Inc.) [Kernel | Boot | Running] -- C:\Windows\System32\drivers\crpf.sys -- (crpf)
    DRV - [2009/04/10 23:42:54 | 000,073,216 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\USBAUDIO.sys -- (usbaudio) USB Audio Driver (WDM)
    DRV - [2008/01/24 11:06:40 | 002,054,872 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\RTKVHDA.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
    DRV - [2007/10/12 01:00:44 | 000,041,752 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\LVUSBSta.sys -- (LVUSBSta)
    DRV - [2007/10/12 00:56:00 | 001,279,000 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\LV302V32.SYS -- (PID_PEPI) Logitech QuickCam IM(PID_PEPI)
    DRV - [2007/08/28 04:01:00 | 000,020,152 | ---- | M] (VIA Technologies, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\viaide.sys -- (viaide)
    DRV - [2007/08/28 04:01:00 | 000,019,128 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\cmdide.sys -- (cmdide)
    DRV - [2007/08/28 04:01:00 | 000,017,592 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\aliide.sys -- (aliide)
    DRV - [2007/03/23 06:09:16 | 000,129,832 | ---- | M] (NVIDIA Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nvrd32.sys -- (nvrd32)
    DRV - [2007/03/23 06:09:16 | 000,101,160 | ---- | M] (NVIDIA Corporation) [Kernel | Boot | Running] -- C:\Windows\system32\drivers\nvstor32.sys -- (nvstor32)
    DRV - [2007/03/15 08:57:30 | 001,059,112 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\nvmfdx32.sys -- (NVENETFD)
    DRV - [2007/02/09 11:34:16 | 000,051,768 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\drivers\DRVNDDM.SYS -- (DRVNDDM)
    DRV - [2007/02/08 19:05:30 | 000,028,120 | ---- | M] (Roxio) [File_System | System | Running] -- C:\Windows\System32\drivers\DLARTL_M.SYS -- (DLARTL_M)
    DRV - [2007/02/08 19:05:30 | 000,012,856 | ---- | M] (Roxio) [File_System | System | Running] -- C:\Windows\System32\drivers\DLACDBHM.SYS -- (DLACDBHM)
    DRV - [2006/11/02 04:51:45 | 000,900,712 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ql2300.sys -- (ql2300)
    DRV - [2006/11/02 04:51:38 | 000,420,968 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adp94xx.sys -- (adp94xx)
    DRV - [2006/11/02 04:51:34 | 000,316,520 | ---- | M] (Emulex) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\elxstor.sys -- (elxstor)
    DRV - [2006/11/02 04:51:32 | 000,297,576 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpahci.sys -- (adpahci)
    DRV - [2006/11/02 04:51:25 | 000,235,112 | ---- | M] (ULi Electronics Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\uliahci.sys -- (uliahci)
    DRV - [2006/11/02 04:51:25 | 000,232,040 | ---- | M] (Intel Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iastorv.sys -- (iaStorV)
    DRV - [2006/11/02 04:51:00 | 000,147,048 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpu320.sys -- (adpu320)
    DRV - [2006/11/02 04:50:45 | 000,115,816 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ulsata2.sys -- (ulsata2)
    DRV - [2006/11/02 04:50:41 | 000,112,232 | ---- | M] (VIA Technologies Inc.,Ltd) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\vsmraid.sys -- (vsmraid)
    DRV - [2006/11/02 04:50:35 | 000,106,088 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ql40xx.sys -- (ql40xx)
    DRV - [2006/11/02 04:50:35 | 000,098,408 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ulsata.sys -- (UlSata)
    DRV - [2006/11/02 04:50:35 | 000,098,408 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpu160m.sys -- (adpu160m)
    DRV - [2006/11/02 04:50:24 | 000,088,680 | ---- | M] (NVIDIA Corporation) [Kernel | Boot | Running] -- C:\Windows\system32\drivers\nvraid.sys -- (nvraid)
    DRV - [2006/11/02 04:50:19 | 000,045,160 | ---- | M] (IBM Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nfrd960.sys -- (nfrd960)
    DRV - [2006/11/02 04:50:17 | 000,041,576 | ---- | M] (Intel Corp./ICP vortex GmbH) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iirsp.sys -- (iirsp)
    DRV - [2006/11/02 04:50:16 | 000,071,784 | ---- | M] (Silicon Integrated Systems) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sisraid4.sys -- (SiSRaid4)
    DRV - [2006/11/02 04:50:13 | 000,040,040 | ---- | M] (NVIDIA Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nvstor.sys -- (nvstor)
    DRV - [2006/11/02 04:50:11 | 000,071,272 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\djsvs.sys -- (aic78xx)
    DRV - [2006/11/02 04:50:10 | 000,067,688 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\arcsas.sys -- (arcsas)
    DRV - [2006/11/02 04:50:10 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_scsi.sys -- (LSI_SCSI)
    DRV - [2006/11/02 04:50:10 | 000,038,504 | ---- | M] (Silicon Integrated Systems Corp.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sisraid2.sys -- (SiSRaid2)
    DRV - [2006/11/02 04:50:10 | 000,037,480 | ---- | M] (Hewlett-Packard Company) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\hpcisss.sys -- (HpCISSs)
    DRV - [2006/11/02 04:50:09 | 000,067,688 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\arc.sys -- (arc)
    DRV - [2006/11/02 04:50:09 | 000,035,944 | ---- | M] (Integrated Technology Express, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iteraid.sys -- (iteraid)
    DRV - [2006/11/02 04:50:07 | 000,035,944 | ---- | M] (Integrated Technology Express, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iteatapi.sys -- (iteatapi)
    DRV - [2006/11/02 04:50:05 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_sas.sys -- (LSI_SAS)
    DRV - [2006/11/02 04:50:05 | 000,035,944 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\symc8xx.sys -- (Symc8xx)
    DRV - [2006/11/02 04:50:04 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_fc.sys -- (LSI_FC)
    DRV - [2006/11/02 04:50:03 | 000,034,920 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sym_u3.sys -- (Sym_u3)
    DRV - [2006/11/02 04:49:59 | 000,033,384 | ---- | M] (LSI Logic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\mraid35x.sys -- (Mraid35x)
    DRV - [2006/11/02 04:49:56 | 000,031,848 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sym_hi.sys -- (Sym_hi)
    DRV - [2006/11/02 04:49:53 | 000,028,776 | ---- | M] (LSI Logic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\megasas.sys -- (megasas)
    DRV - [2006/11/02 03:25:24 | 000,071,808 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brserid.sys -- (Brserid) Brother MFC Serial Port Interface Driver (WDM)
    DRV - [2006/11/02 03:24:47 | 000,011,904 | ---- | M] (Brother Industries Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brusbser.sys -- (BrUsbSer)
    DRV - [2006/11/02 03:24:46 | 000,005,248 | ---- | M] (Brother Industries, Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brfiltup.sys -- (BrFiltUp)
    DRV - [2006/11/02 03:24:45 | 000,013,568 | ---- | M] (Brother Industries, Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brfiltlo.sys -- (BrFiltLo)
    DRV - [2006/11/02 03:24:44 | 000,062,336 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brserwdm.sys -- (BrSerWdm)
    DRV - [2006/11/02 03:24:44 | 000,012,160 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brusbmdm.sys -- (BrUsbMdm)
    DRV - [2006/11/02 02:36:50 | 000,020,608 | ---- | M] (N-trig Innovative Technologies) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ntrigdigi.sys -- (ntrigdigi)
    DRV - [2006/11/02 02:36:43 | 002,028,032 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\atikmdag.sys -- (R300)
    DRV - [2006/11/02 02:30:55 | 000,200,704 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\e1e6032.sys -- (e1express) Intel(R)
    DRV - [2006/11/02 02:30:54 | 000,117,760 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\E1G60I32.sys -- (E1G60) Intel(R)
    DRV - [2006/10/26 15:22:02 | 000,009,400 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLADResM.SYS -- (DLADResM)
    DRV - [2006/10/26 15:21:34 | 000,094,648 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLAUDFAM.SYS -- (DLAUDFAM)
    DRV - [2006/10/26 15:21:34 | 000,035,096 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLABMFSM.SYS -- (DLABMFSM)
    DRV - [2006/10/26 15:21:32 | 000,097,848 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLAUDF_M.SYS -- (DLAUDF_M)
    DRV - [2006/10/26 15:21:30 | 000,026,296 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLAOPIOM.SYS -- (DLAOPIOM)
    DRV - [2006/10/26 15:21:28 | 000,032,472 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLABOIOM.SYS -- (DLABOIOM)
    DRV - [2006/10/26 15:21:26 | 000,014,520 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLAPoolM.SYS -- (DLAPoolM)
    DRV - [2006/10/26 15:21:24 | 000,104,536 | ---- | M] (Roxio) [File_System | Auto | Running] -- C:\Windows\System32\DLA\DLAIFS_M.SYS -- (DLAIFS_M)
    DRV - [2006/10/18 13:09:26 | 000,986,624 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSX_DPV.sys -- (HSF_DPV)
    DRV - [2006/10/18 13:08:18 | 000,258,048 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSXHWBS2.sys -- (HSXHWBS2)
    DRV - [2006/10/18 13:08:04 | 000,659,968 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSX_CNXT.sys -- (winachsf)
    DRV - [2006/08/04 19:39:10 | 000,008,192 | ---- | M] (Conexant Systems, Inc.) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\XAudio.sys -- (XAudio)
    DRV - [2006/07/21 10:21:26 | 000,099,176 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\Windows\System32\Drivers\DRVMCDB.SYS -- (DRVMCDB)
    DRV - [2006/06/26 09:33:36 | 001,952,816 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\LVMVdrv.sys -- (LVMVDrv)
    DRV - [2006/06/26 09:33:28 | 001,587,632 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\Lvckap.sys -- (LVcKap)
    IE - HKLM\..\URLSearchHook: {066ee30f-9dad-42bf-84f1-8ccbc2f0d817} - C:\Program Files\New_York_Radio\tbNew1.dll (Conduit Ltd.)
    IE - HKLM\..\URLSearchHook: {2c9881ab-280a-43df-8e13-8655994b16e9} - C:\Program Files\Classical_Music_Radio\tbCla0.dll (Conduit Ltd.)
    IE - HKLM\..\URLSearchHook: {54d0da58-64e7-4408-be1f-72659f70fcbe} - C:\Program Files\24MusicBar\tb24M1.dll (Conduit Ltd.)
    IE - HKLM\..\URLSearchHook: {69224684-5682-419b-9fe4-ef7946ee3319} - C:\Program Files\AOL Radio Toolbar\aolradiotb.dll (AOL Inc.)
    IE - HKLM\..\URLSearchHook: {9dbb9aeb-5a16-4989-a66f-c0f1c909d647} - C:\Program Files\Free_Radio_TV\tbFree.dll (Conduit Ltd.)
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.inbox.com/homepage.aspx?tbid=80119
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
    IE - HKCU\..\URLSearchHook: {2c9881ab-280a-43df-8e13-8655994b16e9} - C:\Program Files\Classical_Music_Radio\tbCla0.dll (Conduit Ltd.)
    IE - HKCU\..\URLSearchHook: {54d0da58-64e7-4408-be1f-72659f70fcbe} - C:\Program Files\24MusicBar\tb24M1.dll (Conduit Ltd.)
    IE - HKCU\..\URLSearchHook: {D3D233D5-9F6D-436C-B6C7-E63F77503B30} - C:\Program Files\Inbox Toolbar\Inbox.dll (Inbox.com, Inc.)
    IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn2\yt.dll (Yahoo! Inc.)
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    ========== FireFox ==========
    FF - prefs.js..browser.search.defaultenginename: "MyStart Search "
    FF - prefs.js..browser.search.defaulturl: "http://search.yahoo.com/search?ei=UTF-8&fr=ytff-yma3&p= "
    FF - prefs.js..browser.search.selectedEngine: "MyStart Search "
    FF - prefs.js..browser.startup.homepage: "http://mystart.incredimail.com/ "
    FF - prefs.js..keyword.URL: "http://mystart.incredimail.com/?loc=ff_address_bar&search= "
    [2010/07/25 18:36:33 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Mozilla\Extensions
    [2010/07/25 18:36:33 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Neal\AppData\Roaming\Mozilla\Extensions\{xradio@xradio.org}
    [2009/10/16 10:35:06 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\extensions
    [2007/09/10 20:40:26 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
    [2008/11/04 10:33:14 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
    [2009/01/05 10:30:41 | 000,000,000 | ---D | M] (AOL Radio Toolbar) -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\extensions\{6ad56361-628f-471b-8f9d-4c338973a87d}
    [2010/10/27 14:51:32 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\extensions\inboxcomtoolbar@inbox.com
    [2009/01/05 10:30:48 | 000,000,998 | ---- | M] () -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\searchplugins\aolsearch.gif
    [2009/01/05 10:30:49 | 000,000,291 | ---- | M] () -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\searchplugins\aolsearch.src
    [2009/02/23 07:19:49 | 000,002,137 | ---- | M] () -- C:\Users\Neal\AppData\Roaming\Mozilla\Firefox\Profiles\lowxx2al.default\searchplugins\MyStart Search.xml
    [2007/12/19 07:57:38 | 000,310,272 | ---- | M] () -- C:\Program Files\Mozilla Firefox\plugins\npGoogleGadgetPluginFirefoxWin.dll
    [2008/08/02 11:07:07 | 000,000,686 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\GoogleDesktopMozilla.png
    [2008/08/02 11:07:07 | 000,000,531 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\GoogleDesktopMozilla.src
    O1 HOSTS File: ([2010/11/27 16:28:03 | 000,000,027 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
    O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn2\yt.dll (Yahoo! Inc.)
    O2 - BHO: (New York Radio Toolbar) - {066ee30f-9dad-42bf-84f1-8ccbc2f0d817} - C:\Program Files\New_York_Radio\tbNew1.dll (Conduit Ltd.)
    O2 - BHO: (Adobe PDF Reader Link Helper) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (StumbleUpon Launcher) - {145B29F4-A56B-4b90-BBAC-45784EBEBBB7} - C:\Program Files\StumbleUpon\StumbleUponIEBar.dll (stumbleupon.com)
    O2 - BHO: (AOL Radio Toolbar Loader) - {2abdb2f7-4cbf-4939-ba12-fddc827b6a2d} - C:\Program Files\AOL Radio Toolbar\aolradiotb.dll (AOL Inc.)
    O2 - BHO: (Classical Music Radio Toolbar) - {2c9881ab-280a-43df-8e13-8655994b16e9} - C:\Program Files\Classical_Music_Radio\tbCla0.dll (Conduit Ltd.)
    O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll (RealPlayer)
    O2 - BHO: (24MusicBar Toolbar) - {54d0da58-64e7-4408-be1f-72659f70fcbe} - C:\Program Files\24MusicBar\tb24M1.dll (Conduit Ltd.)
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - No CLSID value found.
    O2 - BHO: (Search Helper) - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll (Microsoft Corporation)
    O2 - BHO: (SSVHelper Class) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - c:\Program Files\Java\jre1.6.0\bin\ssv.dll (Sun Microsystems, Inc.)
    O2 - BHO: (Free Radio TV Toolbar) - {9dbb9aeb-5a16-4989-a66f-c0f1c909d647} - C:\Program Files\Free_Radio_TV\tbFree.dll (Conduit Ltd.)
    O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\Program Files\Google\GoogleToolbar1.dll (Google Inc.)
    O2 - BHO: (CBrowserHelperObject Object) - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\BAE\BAE.dll (Dell Inc.)
    O2 - BHO: () - {D3D233D5-9F6D-436C-B6C7-E63F77503B30} - C:\Program Files\Inbox Toolbar\Inbox.dll (Inbox.com, Inc.)
    O2 - BHO: (Windows Live Toolbar Helper) - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn2\YTSingleInstance.dll (Yahoo! Inc)
    O3 - HKLM\..\Toolbar: (New York Radio Toolbar) - {066ee30f-9dad-42bf-84f1-8ccbc2f0d817} - C:\Program Files\New_York_Radio\tbNew1.dll (Conduit Ltd.)
    O3 - HKLM\..\Toolbar: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O3 - HKLM\..\Toolbar: (&Google) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\Program Files\Google\GoogleToolbar1.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Classical Music Radio Toolbar) - {2c9881ab-280a-43df-8e13-8655994b16e9} - C:\Program Files\Classical_Music_Radio\tbCla0.dll (Conduit Ltd.)
    O3 - HKLM\..\Toolbar: (StumbleUpon Toolbar) - {5093EB4C-3E93-40AB-9266-B607BA87BDC8} - C:\Program Files\StumbleUpon\StumbleUponIEBar.dll (stumbleupon.com)
    O3 - HKLM\..\Toolbar: (24MusicBar Toolbar) - {54d0da58-64e7-4408-be1f-72659f70fcbe} - C:\Program Files\24MusicBar\tb24M1.dll (Conduit Ltd.)
    O3 - HKLM\..\Toolbar: (AOL Radio Toolbar) - {9167da98-6f9b-46f1-991d-826cae46cab6} - C:\Program Files\AOL Radio Toolbar\aolradiotb.dll (AOL Inc.)
    O3 - HKLM\..\Toolbar: (Free Radio TV Toolbar) - {9dbb9aeb-5a16-4989-a66f-c0f1c909d647} - C:\Program Files\Free_Radio_TV\tbFree.dll (Conduit Ltd.)
    O3 - HKLM\..\Toolbar: (&Inbox Toolbar) - {D7E97865-918F-41E4-9CD0-25AB1C574CE8} - C:\Program Files\Inbox Toolbar\Inbox.dll (Inbox.com, Inc.)
    O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn2\yt.dll (Yahoo! Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (New York Radio Toolbar) - {066EE30F-9DAD-42BF-84F1-8CCBC2F0D817} - C:\Program Files\New_York_Radio\tbNew1.dll (Conduit Ltd.)
    O3 - HKCU\..\Toolbar\WebBrowser: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O3 - HKCU\..\Toolbar\WebBrowser: (&Google) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - c:\Program Files\Google\GoogleToolbar1.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (Classical Music Radio Toolbar) - {2C9881AB-280A-43DF-8E13-8655994B16E9} - C:\Program Files\Classical_Music_Radio\tbCla0.dll (Conduit Ltd.)
    O3 - HKCU\..\Toolbar\WebBrowser: (24MusicBar Toolbar) - {54D0DA58-64E7-4408-BE1F-72659F70FCBE} - C:\Program Files\24MusicBar\tb24M1.dll (Conduit Ltd.)
    O3 - HKCU\..\Toolbar\WebBrowser: (AOL Radio Toolbar) - {9167DA98-6F9B-46F1-991D-826CAE46CAB6} - C:\Program Files\AOL Radio Toolbar\aolradiotb.dll (AOL Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (Free Radio TV Toolbar) - {9DBB9AEB-5A16-4989-A66F-C0F1C909D647} - C:\Program Files\Free_Radio_TV\tbFree.dll (Conduit Ltd.)
    O3 - HKCU\..\Toolbar\WebBrowser: (&Inbox Toolbar) - {D7E97865-918F-41E4-9CD0-25AB1C574CE8} - C:\Program Files\Inbox Toolbar\Inbox.dll (Inbox.com, Inc.)
    O4 - HKLM..\Run: [ECenter] c:\DELL\E-Center\EULALauncher.exe ( )
    O4 - HKLM..\Run: [Google Desktop Search] C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (Google)
    O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (Macrovision Corporation)
    O4 - HKLM..\Run: [Malwarebytes Anti-Malware (reboot)] C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe (Malwarebytes Corporation)
    O4 - HKLM..\Run: [MSSE] c:\Program Files\Microsoft Security Essentials\msseces.exe (Microsoft Corporation)
    O4 - HKLM..\Run: [RtHDVCpl] C:\Windows\RtHDVCpl.exe (Realtek Semiconductor)
    O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
    O4 - HKCU..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe (SUPERAntiSpyware.com)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O9 - Extra 'Tools' menuitem : Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - c:\Program Files\Java\jre1.6.0\bin\npjpi160.dll (Sun Microsystems, Inc.)
    O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra Button: StumbleUpon - {75C9223A-409A-4795-A3CA-08DE6B075B4B} - C:\Program Files\StumbleUpon\StumbleUponIEBar.dll (stumbleupon.com)
    O15 - HKCU\..Trusted Domains: localhost ([]http in Local intranet)
    O15 - HKCU\..Trusted Ranges: GD ([http] in Local intranet)
    O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 65.106.7.196 65.106.1.196
    O18 - Protocol\Handler\belarc {6318E0AB-2E93-11D1-B8ED-00608CC9A71F} - C:\Program Files\Belarc\Advisor\System\BAVoilaX.dll (Belarc, Inc.)
    O18 - Protocol\Handler\inbox {37540F19-DD4C-478B-B2DF-C19281BCAF27} - C:\Program Files\Inbox Toolbar\Inbox.dll (Inbox.com, Inc.)
    O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
    O20 - AppInit_DLLs: (C:\PROGRA~1\Google\GOOGLE~2\GoogleDesktopNetwork3.dll) - C:\Program Files\Google\Google Desktop Search\GoogleDesktopNetwork3.dll (Google)
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
    O24 - Desktop WallPaper: C:\Users\Neal\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
    O24 - Desktop BackupWallPaper: C:\Users\Neal\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
    O28 - HKLM ShellExecuteHooks: {AEB6717E-7E19-11d0-97EE-00C04FD91972} - Reg Error: Key error. File not found
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2006/09/18 16:43:36 | 000,000,024 | ---- | M] () - C:\autoexec.bat -- [ NTFS ]
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs: FastUserSwitchingCompatibility - File not found
    NetSvcs: Ias - File not found
    NetSvcs: Nla - File not found
    NetSvcs: Ntmssvc - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: SRService - File not found
    NetSvcs: WmdmPmSp - File not found
    NetSvcs: LogonHours - File not found
    NetSvcs: PCAudit - File not found
    NetSvcs: helpsvc - File not found
    NetSvcs: uploadmgr - File not found
    Drivers32: msacm.l3acm - C:\Windows\System32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: MSVideo - C:\Windows\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: MSVideo8 - C:\Windows\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\Windows\System32\iccvid.dll (Radius Inc.)
    Drivers32: VIDC.I420 - C:\Windows\System32\lvcodec2.dll (Logitech Inc.)
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/12/02 09:19:31 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Users\Neal\Desktop\OTL.exe
    [2010/11/28 18:48:05 | 000,000,000 | ---D | C] -- C:\Users\Neal\Desktop\RkU37300505
    [2010/11/28 18:47:38 | 000,000,000 | ---D | C] -- C:\RkUnhooker
    [2010/11/28 18:41:04 | 000,000,000 | ---D | C] -- C:\Users\Neal\Desktop\tdsskiller
    [2010/11/27 18:56:34 | 000,000,000 | ---D | C] -- C:\Windows\temp
    [2010/11/27 16:41:40 | 000,000,000 | ---D | C] -- C:\Users\Neal\AppData\Local\temp
    [2010/11/27 16:41:08 | 000,000,000 | -HSD | C] -- C:\$RECYCLE.BIN
    [2010/11/27 16:35:52 | 000,000,000 | ---D | C] -- C:\ComboFix
    [2010/11/27 16:35:35 | 000,212,480 | ---- | C] (SteelWerX) -- C:\Windows\SWXCACLS.exe
    [2010/11/27 16:14:49 | 000,161,792 | ---- | C] (SteelWerX) -- C:\Windows\SWREG.exe
    [2010/11/27 16:14:49 | 000,136,704 | ---- | C] (SteelWerX) -- C:\Windows\SWSC.exe
    [2010/11/27 16:14:49 | 000,031,232 | ---- | C] (NirSoft) -- C:\Windows\NIRCMD.exe
    [2010/11/27 16:14:47 | 000,000,000 | ---D | C] -- C:\Windows\ERDNT
    [2010/11/27 16:13:11 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2010/11/27 12:43:34 | 000,446,464 | ---- | C] (OldTimer Tools) -- C:\Users\Neal\Desktop\TFC.exe
    [2010/11/23 19:36:22 | 000,000,000 | ---D | C] -- C:\Users\Neal\AppData\Roaming\SUPERAntiSpyware.com
    [2010/11/23 19:36:22 | 000,000,000 | ---D | C] -- C:\ProgramData\SUPERAntiSpyware.com
    [2010/11/23 19:36:02 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
    [2010/11/23 19:35:44 | 009,070,816 | ---- | C] (SUPERAntiSpyware.com) -- C:\Users\Neal\Desktop\SUPERAntiSpyware.exe
    [2010/11/23 19:13:44 | 000,000,000 | ---D | C] -- C:\Program Files\Microsoft Security Essentials
    [2010/11/23 14:28:12 | 000,000,000 | ---D | C] -- C:\Users\Neal\AppData\Roaming\Malwarebytes
    [2010/11/23 14:28:07 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbamswissarmy.sys
    [2010/11/23 14:28:06 | 000,019,160 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\System32\drivers\mbam.sys
    [2010/11/23 14:28:06 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2010/11/23 14:28:06 | 000,000,000 | ---D | C] -- C:\ProgramData\Malwarebytes
    [3 C:\Windows\System32\*.tmp files -> C:\Windows\System32\*.tmp -> ]
    [2 C:\Windows\*.tmp files -> C:\Windows\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2010/12/02 09:22:35 | 000,604,264 | ---- | M] () -- C:\Windows\System32\perfh009.dat
    [2010/12/02 09:22:35 | 000,103,964 | ---- | M] () -- C:\Windows\System32\perfc009.dat
    [2010/12/02 09:18:08 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
    [2010/11/30 09:46:13 | 000,003,696 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
    [2010/11/30 09:46:13 | 000,003,696 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
    [2010/11/30 09:46:02 | 3152,535,552 | -HS- | M] () -- C:\hiberfil.sys
    [2010/11/28 18:06:34 | 000,158,300 | ---- | M] () -- C:\Users\Neal\Desktop\RkU37300505.zip
    [2010/11/28 18:01:36 | 001,228,013 | ---- | M] () -- C:\Users\Neal\Desktop\tdsskiller.zip
    [2010/11/27 18:56:54 | 000,313,112 | ---- | M] () -- C:\Windows\System32\FNTCACHE.DAT
    [2010/11/27 16:28:03 | 000,000,027 | ---- | M] () -- C:\Windows\System32\drivers\etc\hosts
    [2010/11/27 15:50:20 | 003,981,232 | R--- | M] () -- C:\Users\Neal\Desktop\ComboFix.exe
    [2010/11/27 13:15:22 | 141,171,884 | ---- | M] () -- C:\Windows\MEMORY.DMP
    [2010/11/25 11:36:36 | 000,296,448 | ---- | M] () -- C:\Users\Neal\Desktop\brruow9e.exe
    [2010/11/25 11:33:48 | 000,446,464 | ---- | M] (OldTimer Tools) -- C:\Users\Neal\Desktop\TFC.exe
    [2010/11/23 19:36:11 | 000,001,762 | ---- | M] () -- C:\Users\Public\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/11/23 19:13:45 | 000,000,904 | ---- | M] () -- C:\Users\Public\Desktop\Microsoft Security Essentials.lnk
    [2010/11/23 14:28:10 | 000,000,780 | ---- | M] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/11/19 15:15:59 | 000,000,420 | -H-- | M] () -- C:\Windows\tasks\User_Feed_Synchronization-{06D25A4B-108D-4D04-9982-FB3495F7EE48}.job
    [2010/11/19 15:14:36 | 000,000,878 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
    [2010/11/19 15:14:06 | 000,002,708 | ---- | M] () -- C:\Windows\crpf.bin
    [2010/11/19 15:06:00 | 000,000,882 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
    [2010/11/19 10:44:21 | 000,000,680 | ---- | M] () -- C:\Users\Neal\AppData\Local\d3d9caps.dat
    [2010/11/19 08:27:30 | 016,998,798 | ---- | M] () -- C:\Windows\csdf.dat
    [2010/11/19 08:27:30 | 007,770,640 | ---- | M] () -- C:\Windows\csdf_sdum.dat
    [2010/11/16 11:04:48 | 000,000,190 | ---- | M] () -- C:\Users\Neal\Desktop\Online Radio - Free Internet Radio Stations - AOL Music.url
    [2010/11/10 11:35:31 | 000,001,933 | ---- | M] () -- C:\Users\Public\Desktop\Google Chrome.lnk
    [2010/11/08 01:20:24 | 000,089,088 | ---- | M] () -- C:\Windows\MBR.exe
    [2010/11/28 20:12:26 | 000,000,065 | ---- | C] () -- C:\Users\Neal\GooglePing.txt
    [2010/11/28 18:39:38 | 000,158,300 | ---- | C] () -- C:\Users\Neal\Desktop\RkU37300505.zip
    [2010/11/28 18:39:26 | 001,228,013 | ---- | C] () -- C:\Users\Neal\Desktop\tdsskiller.zip
    [2010/11/27 16:14:49 | 000,256,512 | ---- | C] () -- C:\Windows\PEV.exe
    [2010/11/27 16:14:49 | 000,098,816 | ---- | C] () -- C:\Windows\sed.exe
    [2010/11/27 16:14:49 | 000,089,088 | ---- | C] () -- C:\Windows\MBR.exe
    [2010/11/27 16:14:49 | 000,080,412 | ---- | C] () -- C:\Windows\grep.exe
    [2010/11/27 16:14:49 | 000,068,096 | ---- | C] () -- C:\Windows\zip.exe
    [2010/11/27 16:11:14 | 003,981,232 | R--- | C] () -- C:\Users\Neal\Desktop\ComboFix.exe
    [2010/11/27 13:15:24 | 3152,535,552 | -HS- | C] () -- C:\hiberfil.sys
    [2010/11/27 13:01:06 | 000,296,448 | ---- | C] () -- C:\Users\Neal\Desktop\brruow9e.exe
    [2010/11/23 19:36:11 | 000,001,762 | ---- | C] () -- C:\Users\Public\Desktop\SUPERAntiSpyware Free Edition.lnk
    [2010/11/23 19:13:45 | 000,000,904 | ---- | C] () -- C:\Users\Public\Desktop\Microsoft Security Essentials.lnk
    [2010/11/23 14:28:09 | 000,000,780 | ---- | C] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
    [2010/11/19 08:20:25 | 016,998,798 | ---- | C] () -- C:\Windows\csdf.dat
    [2010/11/19 08:20:25 | 007,770,640 | ---- | C] () -- C:\Windows\csdf_sdum.dat
    [2010/11/19 08:18:09 | 000,002,708 | ---- | C] () -- C:\Windows\crpf.bin
    [2009/09/24 09:16:11 | 000,117,248 | ---- | C] () -- C:\Windows\System32\EhStorAuthn.dll
    [2009/08/03 14:07:42 | 000,403,816 | ---- | C] () -- C:\Windows\System32\OGACheckControl.dll
    [2009/04/30 22:39:36 | 000,082,289 | ---- | C] () -- C:\Windows\System32\lvcoinst.ini
    [2008/01/15 16:05:09 | 000,000,680 | ---- | C] () -- C:\Users\Neal\AppData\Local\d3d9caps.dat
    [2007/09/02 16:33:10 | 000,056,056 | ---- | C] () -- C:\Windows\System32\DLAAPI_W.DLL
    [2007/09/02 16:33:03 | 000,000,280 | ---- | C] () -- C:\Windows\wininit.ini
    [2007/08/30 14:09:12 | 000,000,147 | ---- | C] () -- C:\Windows\QUICKEN.INI
    [2007/08/30 12:31:30 | 000,025,600 | ---- | C] () -- C:\Users\Neal\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2007/03/19 05:04:58 | 000,003,584 | ---- | C] () -- C:\Windows\System32\namResES.dll
    [2007/03/19 05:04:58 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResIT.dll
    [2007/03/19 05:04:58 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResFR.dll
    [2007/03/19 05:04:58 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResENG.dll
    [2007/03/19 05:04:58 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResDE.dll
    [2007/03/19 05:04:56 | 000,003,584 | ---- | C] () -- C:\Windows\System32\namResPTB.dll
    [2007/03/19 05:04:56 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResZHC.dll
    [2007/03/19 05:04:56 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResKO.dll
    [2007/03/19 05:04:56 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResJA.dll
    [2007/03/19 05:04:54 | 000,022,016 | ---- | C] () -- C:\Windows\System32\nam_page.dll
    [2007/03/19 05:04:54 | 000,003,072 | ---- | C] () -- C:\Windows\System32\namResZHT.dll
    [2006/11/07 14:25:58 | 000,000,000 | ---- | C] () -- C:\Windows\System32\px.ini
    [2006/11/02 07:35:32 | 000,005,632 | ---- | C] () -- C:\Windows\System32\sysprepMCE.dll
    [2006/11/02 05:25:44 | 000,159,744 | ---- | C] () -- C:\Windows\System32\atitmmxx.dll
    [2006/11/02 02:40:29 | 000,013,750 | ---- | C] () -- C:\Windows\System32\pacerprf.ini
    [2006/09/16 23:36:50 | 000,520,192 | ---- | C] () -- C:\Windows\System32\CddbPlaylist2Roxio.dll
    [2006/09/16 23:36:50 | 000,204,800 | ---- | C] () -- C:\Windows\System32\CddbFileTaggerRoxio.dll
    [2006/06/26 09:33:40 | 000,023,472 | ---- | C] () -- C:\Windows\System32\drivers\LVPr2Mon.sys
    [2010/07/26 08:44:31 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Babylon
    [2010/07/25 18:51:21 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Bandoo
    [2010/07/25 18:34:32 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\HBLite
    [2010/07/27 10:28:50 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\Tific
    [2010/07/25 18:36:31 | 000,000,000 | ---D | M] -- C:\Users\Neal\AppData\Roaming\xradio
    [2010/11/19 15:12:56 | 000,032,622 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
    [2010/11/19 15:15:59 | 000,000,420 | -H-- | M] () -- C:\Windows\Tasks\User_Feed_Synchronization-{06D25A4B-108D-4D04-9982-FB3495F7EE48}.job
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2006/09/18 16:43:36 | 000,000,024 | ---- | M] () -- C:\autoexec.bat
    [2009/04/11 01:36:36 | 000,333,257 | RHS- | M] () -- C:\bootmgr
    [2006/11/10 08:22:24 | 000,008,192 | R-S- | M] () -- C:\BOOTSECT.BAK
    [2010/11/27 16:41:39 | 000,012,400 | ---- | M] () -- C:\ComboFix.txt
    [2006/09/18 16:43:37 | 000,000,010 | ---- | M] () -- C:\config.sys
    [2007/08/28 04:06:11 | 000,004,462 | RH-- | M] () -- C:\dell.sdr
    [2010/02/27 13:00:41 | 000,000,000 | ---- | M] () -- C:\lvcoinst.log
    [2007/09/03 22:00:22 | 000,005,743 | ---- | M] () -- C:\NealAddressesComma.csv
    [2009/09/16 16:33:22 | 000,262,144 | ---- | M] () -- C:\ntuser.dat
    [2009/09/16 16:33:22 | 000,005,120 | -H-- | M] () -- C:\ntuser.dat.LOG1
    [2008/07/23 12:35:37 | 000,000,000 | -H-- | M] () -- C:\ntuser.dat.LOG2
    [2008/07/23 12:35:39 | 000,065,536 | -HS- | M] () -- C:\ntuser.dat{108f1907-5734-11dd-9e6b-001aa05814ae}.TM.blf
    [2008/07/23 12:35:39 | 000,524,288 | -HS- | M] () -- C:\ntuser.dat{108f1907-5734-11dd-9e6b-001aa05814ae}.TMContainer00000000000000000001.regtrans-ms
    [2008/07/23 12:35:39 | 000,524,288 | -HS- | M] () -- C:\ntuser.dat{108f1907-5734-11dd-9e6b-001aa05814ae}.TMContainer00000000000000000002.regtrans-ms
    [2009/09/16 16:33:20 | 000,065,536 | -HS- | M] () -- C:\ntuser.dat{108f190b-5734-11dd-9e6b-001aa05814ae}.TM.blf
    [2009/09/16 16:33:20 | 000,524,288 | -HS- | M] () -- C:\ntuser.dat{108f190b-5734-11dd-9e6b-001aa05814ae}.TMContainer00000000000000000001.regtrans-ms
    [2008/07/23 12:35:40 | 000,524,288 | -HS- | M] () -- C:\ntuser.dat{108f190b-5734-11dd-9e6b-001aa05814ae}.TMContainer00000000000000000002.regtrans-ms
    [2010/11/30 09:46:01 | 3466,338,304 | -HS- | M] () -- C:\pagefile.sys
    [2008/08/24 14:22:59 | 000,000,232 | -H-- | M] () -- C:\sqmdata00.sqm
    [2008/08/24 14:22:59 | 000,000,244 | -H-- | M] () -- C:\sqmnoopt00.sqm
    [2010/11/28 18:45:25 | 000,060,064 | ---- | M] () -- C:\TDSSKiller.2.4.9.0_28.11.2010_18.41.12_log.txt
    < %systemroot%\Fonts\*.com >
    [2006/11/02 07:37:12 | 000,026,040 | ---- | M] () -- C:\Windows\Fonts\GlobalMonospace.CompositeFont
    [2006/11/02 07:37:12 | 000,026,489 | ---- | M] () -- C:\Windows\Fonts\GlobalSansSerif.CompositeFont
    [2006/11/02 07:37:12 | 000,029,779 | ---- | M] () -- C:\Windows\Fonts\GlobalSerif.CompositeFont
    [2009/10/14 11:15:17 | 000,037,665 | ---- | M] () -- C:\Windows\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2006/09/18 16:37:34 | 000,000,065 | ---- | M] () -- C:\Windows\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/01/19 02:34:28 | 000,089,600 | ---- | M] (Hewlett-Packard Corporation) -- C:\Windows\System32\spool\prtprocs\w32x86\HPZPPLHN.DLL
    [2006/11/02 07:35:48 | 000,022,528 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\spool\prtprocs\w32x86\jnwppr.dll
    [2006/10/26 19:56:12 | 000,033,104 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\spool\prtprocs\w32x86\msonpppr.dll
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    [2009/07/10 12:15:46 | 000,306,544 | ---- | M] (Microsoft Corporation) -- C:\Windows\WLXPGSS.SCR
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    [2008/07/07 10:45:06 | 000,000,174 | -HS- | M] () -- C:\Program Files\desktop.ini
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2006/11/02 05:34:05 | 000,008,192 | ---- | M] () -- C:\Windows\System32\config\COMPONENTS.SAV
    [2006/11/02 05:34:05 | 000,020,480 | ---- | M] () -- C:\Windows\System32\config\DEFAULT.SAV
    [2006/11/02 05:34:05 | 000,008,192 | ---- | M] () -- C:\Windows\System32\config\SECURITY.SAV
    [2006/11/02 05:34:08 | 010,133,504 | ---- | M] () -- C:\Windows\System32\config\SOFTWARE.SAV
    [2006/11/02 05:34:08 | 001,826,816 | ---- | M] () -- C:\Windows\System32\config\SYSTEM.SAV
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2009/04/03 20:18:56 | 000,000,444 | -HS- | M] () -- C:\Users\Neal\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    < %USERPROFILE%\Desktop\*.exe >
    [2010/07/03 14:11:48 | 009,070,816 | ---- | M] (SUPERAntiSpyware.com) -- C:\Users\Neal\Desktop\SUPERAntiSpyware.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2007/08/30 18:23:03 | 000,000,402 | -HS- | M] () -- C:\Users\Neal\Favorites\desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    ========== Alternate Data Streams ==========
    @Alternate Data Stream - 1552 bytes -> C:\Users\Neal\Documents\Patriotic ~ BEYOND beautiful ~ watch this movie please.eml:OECustomProperty
    < End of report >
  6. 2010/12/02
    Extras Log:
    OTL Extras logfile created on: 12/2/2010 9:21:46 AM - Run 1
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .hlp [@ = hlpfile] -- C:\Windows\winhlp32.exe (Microsoft Corporation)
    .html [@ = FirefoxHTML] -- C:\PROGRA~1\MOZILL~1\FIREFOX.EXE File not found
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    helpfile [open] -- Reg Error: Key error.
    hlpfile [open] -- %SystemRoot%\winhlp32.exe %1 (Microsoft Corporation)
    https [open] -- C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -url "%1" File not found
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l (Microsoft Corporation)
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [cmd] -- cmd.exe /s /k pushd "%V" (Microsoft Corporation)
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /separate,/idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /separate,/e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "cval" = 1
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    "DisableMonitoring" = 1
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
    "AntiVirusOverride" = 0
    "AntiSpywareOverride" = 0
    "FirewallOverride" = 0
    "VistaSp1" = Reg Error: Unknown registry data type -- File not found
    "VistaSp2" = Reg Error: Unknown registry data type -- File not found
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "DisableNotifications" = 0
    "EnableFirewall" = 1
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    ========== Vista Active Open Ports Exception List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]
    "{8A299C9A-65DC-4BF3-80ED-C5676BB17DF2}" = lport=2869 | protocol=6 | dir=in | app=system |
    "{EDCD51CD-404B-4C8E-948C-82EBD16F6395}" = lport=1900 | protocol=17 | dir=in | svc=ssdpsrv | app=svchost.exe |
    ========== Vista Active Application Exception List ==========
    "{0078697D-106C-4518-8CCE-300E42DF1F4E}" = protocol=17 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
    "{A0061291-ADD4-4A2F-AA8D-C03C13812670}" = protocol=6 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
    "{BAD3B086-4B27-4F22-B501-20019FA8FF4A}" = dir=in | app=c:\program files\windows live\messenger\msnmsgr.exe |
    "{DE244351-2D29-4A8C-8B81-8B2737C22DEA}" = dir=in | app=c:\program files\windows live\sync\windowslivesync.exe |
    "{FD51FC9D-361C-4A05-9D84-FB140D172C6E}" = dir=in | app=c:\program files\windows live\messenger\wlcsdk.exe |
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{0394CDC8-FABD-4ed8-B104-03393876DFDF}" = Roxio Creator Tools
    "{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}" = Windows Live ID Sign-in Assistant
    "{0D397393-9B50-4c52-84D5-77E344289F87}" = Roxio Creator Data
    "{139E303E-1050-497F-98B1-9AE87B15C463}" = Windows Live Family Safety
    "{13BA7B44-B712-4DEE-A7B8-1DD564F37AE5}" = Dell System Customization Wizard
    "{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
    "{205C6BDD-7B73-42DE-8505-9A093F35A238}" = Windows Live Upload Tool
    "{22B775E7-6C42-4FC5-8E10-9A5E3257BD94}" = MSVCRT
    "{2318C2B1-4965-11d4-9B18-009027A5CD4F}" = Google Toolbar for Internet Explorer
    "{2818095F-FB6C-42C8-827E-0A406CC9AFF5}" = Quicken 2006
    "{2DFF31F9-7893-4922-AF66-C9A1EB4EBB31}" = Rhapsody Player Engine
    "{2F4C24E6-CBD4-4AAC-B56F-C9FD44DE5668}" = Roxio Drag-to-Disc
    "{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Roxio Update Manager
    "{3248F0A8-6813-11D6-A77B-00B0D0160000}" = Java(TM) SE Runtime Environment 6
    "{341201D4-4F61-4ADB-987E-9CCE4D83A58D}" = Windows Live Toolbar Extension (Windows Live Toolbar)
    "{35E1EC43-D4FC-4E4A-AAB3-20DDA27E8BB0}" = Sonic Activation Module
    "{3B4E636E-9D65-4D67-BA61-189800823F52}" = Windows Live Communications Platform
    "{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
    "{3D5044A5-97B8-45C0-B956-BB2376569188}" = Windows Live Movie Maker
    "{3E25E350-949F-4DB7-8288-2A60E018B4C1}" = Games, Music, & Photos Launcher
    "{3EE33958-7381-4E7B-A4F3-6E43098E9E9C}" = URL Assistant
    "{3F92ABBB-6BBF-11D5-B229-002078017FBF}" = NetWaiting
    "{48B3FB4D-CE22-488C-8E9F-24EBB77EAC0F}" = Microsoft Security Essentials
    "{4CBA3D4C-8F51-4D60-B27E-F6B641C571E7}" = Microsoft Search Enhancement Pack
    "{5CD29180-A95E-11D3-A4EB-00C04F7BDB2C}" = User's Guides
    "{612AD33D-9824-4E87-8396-92374E91C4BB}_is1" = Inbox Toolbar
    "{619CDD8A-14B6-43a1-AB6C-0F4EE48CE048}" = Roxio Creator Copy
    "{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
    "{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}" = Roxio Express Labeler
    "{7299052b-02a4-4627-81f2-1818da5d550d}" = Microsoft Visual C++ 2005 Redistributable
    "{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    "{7745B7A9-F323-4BB9-9811-01BF57A028DA}" = Map Button (Windows Live Toolbar)
    "{786C4AD1-DCBA-49A6-B0EF-B317A344BD66}" = Windows Live Favorites for Windows Live Toolbar
    "{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
    "{83FFCFC7-88C6-41c6-8752-958A45325C82}" = Roxio Creator Audio
    "{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
    "{880AF49C-34F7-4285-A8AD-8F7A3D1C33DC}" = Roxio Creator BDAV Plugin
    "{89CEAE14-DD0F-448E-9554-15781EC9DB24}" = Product Documentation Launcher
    "{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
    "{8A74E887-8F0F-4017-AF53-CBA42211AAA5}" = Microsoft Sync Framework Runtime Native v1.0 (x86)
    "{90120000-0016-0409-0000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2007
    "{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-0018-0409-0000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2007
    "{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-001B-0409-0000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2007
    "{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-001F-0409-0000-0000000FF1CE}" = Microsoft Office Proof (English) 2007
    "{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-001F-040C-0000-0000000FF1CE}" = Microsoft Office Proof (French) 2007
    "{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-001F-0C0A-0000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2007
    "{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-002C-0409-0000-0000000FF1CE}" = Microsoft Office Proofing (English) 2007
    "{90120000-006E-0409-0000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2007
    "{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-00A1-0409-0000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2007
    "{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-0115-0409-0000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2007
    "{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{91120000-002F-0000-0000-0000000FF1CE}" = Microsoft Office Home and Student 2007
    "{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
    "{95120000-00B9-0409-0000-0000000FF1CE}" = Microsoft Application Error Reporting
    "{995F1E2E-F542-4310-8E1D-9926F5A279B3}" = Windows Live Toolbar
    "{9ACC9F63-CF54-46D7-9140-D40E57564EDA}_is1" = COMODO System Cleaner 1.1.64946.38(32bit)
    "{A0A77CDC-2419-4D5C-AD2C-E09E5926B806}" = Microsoft Antimalware
    "{A5C4AD72-25FE-4899-B6DF-6D8DF63C93CF}" = Highlight Viewer (Windows Live Toolbar)
    "{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AC76BA86-7AD7-1033-7B44-A70800000002}" = Adobe Reader 7.0.8
    "{B139DD51-C3F1-4583-98B4-D35F64EA847F}" = Windows Easy Transfer Companion (Beta)
    "{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
    "{BD64AF4A-8C80-4152-AD77-FCDDF05208AB}" = Microsoft Sync Framework Services Native v1.0 (x86)
    "{BEF726DD-4037-4214-8C6A-E625C02D2870}" = Logitech Audio Echo Cancellation Component
    "{C8B0680B-CDAE-4809-9F91-387B6DE00F7C}" = Roxio Creator DE
    "{CA7FFA82-42CE-11D7-B82E-00010225F9EC}" = Address Book Importer
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D639085F-4B6E-4105-9F37-A0DBB023E2FB}" = Roxio MyDVD DE
    "{D6C75F0B-3BC1-4FC9-B8C5-3F7E8ED059CA}" = Windows Live Photo Gallery
    "{DBEA1034-5882-4A88-8033-81C4EF0CFA29}" = Google Toolbar for Internet Explorer
    "{E2DFE069-083E-4631-9B6C-43C48E991DE5}" = Junk Mail filter update
    "{E646DCF0-5A68-11D5-B229-002078017FBF}" = Digital Line Detect
    "{EFAD4066-CAF3-4B27-9669-12EED352C376}" = NVIDIANetworkDiagnostic
    "{F084395C-40FB-4DB3-981C-B51E74E1E83D}" = Smart Menus (Windows Live Toolbar)
    "{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
    "{F0E12BBA-AD66-4022-A453-A1C8A0C4D570}" = Microsoft Choice Guard
    "{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}" = Realtek High Definition Audio Driver
    "{F40BBEC7-C2A4-4A00-9B24-7A055A2C5262}" = Microsoft Office Live Add-in 1.5
    "{F63A3748-B93D-4360-9AD4-B064481A5C7B}" = Modem Diagnostic Tool
    "{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
    "{F7B0939E-58DF-11DF-B3A6-005056806466}" = Google Earth
    "24MusicBar Toolbar" = 24MusicBar Toolbar
    "Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
    "AOL Radio Toolbar" = AOL Radio Toolbar
    "Belarc Advisor" = Belarc Advisor 8.1
    "Classical_Music_Radio Toolbar" = Classical_Music_Radio Toolbar
    "CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1" = Conexant D850 PCI V.92 Modem
    "Firefox Windows Media Player XPI" = Firefox Windows Media Player XPI
    "Free_Radio_TV Toolbar" = Free_Radio_TV Toolbar
    "Google Chrome" = Google Chrome
    "Google Desktop" = Google Desktop
    "GoToAssist" = GoToAssist 8.0.0.480
    "HOMESTUDENTR" = Microsoft Office Home and Student 2007
    "InstallShield_{EFAD4066-CAF3-4B27-9669-12EED352C376}" = NVIDIANetworkDiagnostic
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
    "Microsoft Security Essentials" = Microsoft Security Essentials
    "New_York_Radio Toolbar" = New_York_Radio Toolbar
    "NVIDIA Drivers" = NVIDIA Drivers
    "QcDrv" = Logitech® Camera Driver
    "RealPlayer 12.0" = RealPlayer
    "RKU" = Rootkit Unhooker Uninstall
    "SoftwareUpdUtility" = Download Updater (AOL LLC)
    "StumbleUponIEToolbar" = StumbleUpon IE Toolbar
    "WinLiveSuite_Wave3" = Windows Live Essentials
    "Yahoo! Companion" = Yahoo! Toolbar
    "Yahoo! Search Defender" = Yahoo! Search Protection
    "Yahoo! Software Update" = Yahoo! Software Update
    "YInstHelper" = Yahoo! Install Manager
    ========== HKEY_CURRENT_USER Uninstall List ==========
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    ========== Last 10 Event Log Errors ==========
    Error: Unable to start EventLog service!
    < End of report >
  7. 2010/12/02
    I don't see much here.
    At this point, I have to ask you to create new topic at Vista forum in attempt to fix your internet connection issue.
    Once, it's done, please return here to continue cleaning process.
  8. 2010/12/02
    Will do. Thanks for all you have done for us. We will go see what we can do about the internet connection.
  9. 2010/12/02
    I'll keep this topic open.
  10. 2010/12/24
    Broni,
    I have my fingers crossed but I think this one is out of the woods. I opened a thread in Vista - I'll try to put a link here but I'm not sure I know how. http://www.windowsbbs.com/windows-vista/96608-cant-access-internet.html
    Bottom line - I was able to finally get a system restore prior to the time the PC Rx and other questionable things got installed. Then I was able to get to the internet and take care of AV program, Vista updates, etc and all seems to be well now. Thanks so much for your time and patience.
  11. 2010/12/24
    You're very welcome :)
    Thank you for posting back....
    Merry Christmas!
