PC Pitstop Optimize
Discussion in 'Other PC Software' started by Christer, 2007/05/08.
  1. 2007/06/08
    Whiskeyman Inactive Alumni
    The tweaks are still performing fine for me. The only problems I have had since doing them was an issue with high winds and trees causing the ISP problems.
  2. 2007/06/08
    Christer
    I suspect that the problems are not at my end. I can browse one site with no problems but the next is acting up.
    Christer
    Rockster2U
    Rockster2U Geek Member
    Christer:
    A little nourishment for that analytical brain while you sort through what works best for you ------->
    I've gone from RWIN of 511104 to 255552 to 127776 and right now, perceptually, the 127776 seems to be my sweet spot. Running a speed test, 511104 still gives me the best downstream speed but the difference is negligable and as stated, perceptually (at least to my eyes) 127776 seems to be the optimum.
  5. 2007/06/11
    Christer
    Rockster,
    I have tried similar settings and found out that the recommended 1027840 works as good as any higher setting. That setting is recommended from 13000 kb/s and since the maximum selectable connection speed is 20000 kb/s, I increased the TCP Receive Window by X2 and X4 (to possibly match my 100 Mb/s) but that function is not linear which makes me shooting into the dark. I have not tested a setting lower than the recommended.
    Maybe, if I find a server that can hit my system with 100 Mb/s, will I be able to find a TCP Receive Window that is optimized.
    Christer
  6. 2007/07/24
    Christer
    Contents deleted because I'm tired and was "talking through my hat "!
    Christer
  7. 2007/07/26
    Rockster2U
    For what its worth, I've gone back to 255552 and am pretty happy - still cruising along better than my supposed 3MBS service.
    Hard Hat, Straw Hat or Felt Derby? I'm told it can make a difference.
    :rolleyes:
  8. 2007/07/27
    Christer
    Well, any proverbial hat will do but if possible, the one with the best muffling qualities should be chosen ... :cool: ... !
    Christer
