Solved PC Mightymax [How to remove?]
Discussion in 'Malware and Virus Removal Archive' started by BillB, 2008/03/04.
  1. 2008/03/17
    noahdfear
    noahdfear Inactive
    Try the uninstall link on the Start>All Programs>PC Mightymax
  2. 2008/03/17
    BillB Lifetime Subscription
    BillB Well-Known Member Thread Starter
    I tried that too, it can't find the uninstall program.
    noahdfear
    noahdfear Inactive
    Please email me a copy of that msi installer.
  5. 2008/03/17
    Hi Dave,
    It's on the way to you.
  6. 2008/03/18
    noahdfear
    noahdfear Inactive
    Ughhh ....... since it does show up in Add/Remove, download Revouninstaller (there's a standalone version - Portable) and run it. PC Mightymax should show up. Select it and click Uninstall. Choose the Advanced mode after clicking Yes to the 'Are you sure' prompt, then click Next. Allow it to scan for files and registry items and remove whatever it finds.
    Let me know how that goes.
  7. 2008/03/19
    It didn't show up in the list, I told it to refresh a couple times, still no go.
  8. 2008/03/19
    noahdfear
    noahdfear Inactive
    Download RegSeeker and do a 'Find in registry' for PC Mightymax. Select the Classes_Root, Current_User and Local_Machines hives, Values, Data and Keys. Once the scan is finished, click Select>Select All, then click Action>Export selected items. It will place the export in the RegSeeker>Backups folder. Please zip that reg file and email it to me.
  9. 2008/03/20
    Dave,
  10. 2008/03/21
    I received two messages that the mail was not deliverable so I am trying it again.
  11. 2008/03/21
    Dave,
    Everytime I try to send the zip file, the email comes back. Here's the delivery report that is returned;
    Reporting-MTA: dns; mail.infinisource.com
    X-Postfix-Queue-ID: 0FCAC1A5811F
    X-Postfix-Sender: rfc822;
    Arrival-Date: Fri, 21 Mar 2008 13:20:20 -0500 (CDT)
    Content-Type: text/plain
    Final-Recipient: rfc822;
    Original-Recipient: rfc822;
    Action: failed
    Status: 5.7.1
    Remote-MTA: dns; 127.0.0.1
    Diagnostic-Code: smtp; 550 5.7.1 Message content rejected, id=21794-06 -
    BANNED: P=p004,L=1,M=multipart/mixed |
    P=p003,L=1/2,M=application/x-zip-compressed,T=zip,N=regseek.Z...
  12. 2008/03/21
    noahdfear
    noahdfear Inactive
    Try sending it here.
  13. 2008/03/22
    noahdfear
    noahdfear Inactive
    Now, highlight and copy the contents of the code box below.
    cd  "%userprofile%\desktop "
    reg query  "HKEY_CLASSES_ROOT\CLSID\{275DBBA0-805A-11CF-91F7-C2863C385E30}" /s>peek.txt
    reg query  "HKEY_CLASSES_ROOT\CLSID\{6262D3A0-531B-11CF-91F6-C2863C385E30}" /s>>peek.txt
    reg query  "HKEY_CLASSES_ROOT\CLSID\{6319EEA0-531B-11CF-91F6-C2863C385E30}" /s>>peek.txt
    reg query  "HKEY_CLASSES_ROOT\TypeLib\{5E9E78A0-531B-11CF-91F6-C2863C385E30}" /s>>peek.txt
    reg query  "HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\F0FA5D49EE6E57A4EB13C9C9A978DA54" /s>>peek.txt
    reg query  "HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags" /s>>peek.txt
    exit
    cls
    Click Start>Run and type cmd then hit enter to open a command window. Right click and paste the copied text in the window. It will close and create peek.txt on the desktop. Send me that text file please.
    BTW, there are no entries in the export for the HKEY_LOCAL_MACHINE hive. You did have that hive selected when you did the RegSeeker search?
  14. 2008/03/23
    Hi Dave,
    Here is the peek file. Yep, I did have the local machine hive checked.
  15. 2008/03/23
    noahdfear
    noahdfear Inactive
    Highlight and copy the following bolded command.
    regsvr32 /u "C:\Program Files\PC MightyMax 2007\MSFLXGRD.OCX "
    Click Start>Run and paste the command in the Run dialog then hit enter.
    Highlight and copy the contents of the quote box below to a blank notepad. Save it to the desktop as;
    Filename: fix.reg
    Save as type: All Files (*.*)
    Double click fix.reg and allow it to merge with the registry.
    regsvr32 "C:\WINDOWS\system32\MSFLXGRD.OCX "
    Delete the following folders.
    C:\Documents and Settings\username\Start Menu\Programs\PC MightyMax
    C:\WINDOWS\Downloaded Installations\{clsid folder containing installer}
    Reboot and see if PC Mightymax is gone.
  16. 2008/03/24
    Hi Dave,
    The second command failed with module not found error. Mightymax seems to be gone, regseeker still finds a lot of entries for it though. I can't find any running processes for it, so hopefully it's dead.
  17. 2008/03/24
    noahdfear
    noahdfear Inactive
    Hi Bill,
    Please do a search for the file MSFLXGRD.OCX
    Export the RegSeeker findings and send my way again, please.
  18. 2008/03/25
    Hi Dave,
    That file was found in this path;
    c:\system32\redist\ms\system
    I've emailed the regseeker results to you at the last email address you provided.
  19. 2008/03/25
    noahdfear
    noahdfear Inactive
    Please copy that file to the system32 folder, then run the command again.
    I'll look over the RegSeeker export this evening.
  20. 2008/03/25
    The command ran successfully this time.
  21. 2008/03/26
    noahdfear
    noahdfear Inactive
    Hi Bill,
    If you still have the fix.reg file on the desktop, right click and Edit then replace everything with the contents of the code box below and save. Otherwise, create a new fix.reg file.
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\TrayNotify]
     "IconStreams "=hex:00
     "PastIconsStream "=hex:00
    [-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{94D5AF0F-E6EE-4A75-BE31-9C9C9A87AD45}]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSaveMRU\*]
     "f "=-
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSaveMRU\msi]
     "a "=-
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU]
     "h "=-
     "i "=-
     "m "=-
    Now open RegSeeker and select Histories>Clean StreamMRU/Streams Keys. If a new search finds anything, it will be of little to no significance.
