Solved PC Infected by Tech Support Scam Popup and More?
Discussion in 'Malware and Virus Removal Archive' started by Mr. Chip, 2015/10/25.
  1. 2015/10/27
    Mr. Chip Lifetime Subscription
    Mr. Chip Well-Known Member Thread Starter
    FSS.txt
    Farbar Service Scanner Version: 26-07-2015
    Ran by Stan (administrator) on 27-10-2015 at 08:15:25
    Running from "C:\Users\Stan\Desktop "
    Microsoft Windows 7 Professional Service Pack 1 (X64)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo.com is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Policy:
    Action Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Windows Defender:
    Other Services:
    File Check:
    C:\Windows\System32\nsisvc.dll => File is digitally signed
    C:\Windows\System32\drivers\nsiproxy.sys => File is digitally signed
    C:\Windows\System32\dhcpcore.dll => File is digitally signed
    C:\Windows\System32\drivers\afd.sys => File is digitally signed
    C:\Windows\System32\drivers\tdx.sys => File is digitally signed
    C:\Windows\System32\Drivers\tcpip.sys => File is digitally signed
    C:\Windows\System32\dnsrslvr.dll => File is digitally signed
    C:\Windows\System32\mpssvc.dll => File is digitally signed
    C:\Windows\System32\bfe.dll => File is digitally signed
    C:\Windows\System32\drivers\mpsdrv.sys => File is digitally signed
    C:\Windows\System32\SDRSVC.dll => File is digitally signed
    C:\Windows\System32\vssvc.exe => File is digitally signed
    C:\Windows\System32\wscsvc.dll => File is digitally signed
    C:\Windows\System32\wbem\WMIsvc.dll => File is digitally signed
    C:\Windows\System32\wuaueng.dll => File is digitally signed
    C:\Windows\System32\qmgr.dll => File is digitally signed
    C:\Windows\System32\es.dll => File is digitally signed
    C:\Windows\System32\cryptsvc.dll => File is digitally signed
    C:\Program Files\Windows Defender\MpSvc.dll => File is digitally signed
    C:\Windows\System32\ipnathlp.dll => File is digitally signed
    C:\Windows\System32\iphlpsvc.dll => File is digitally signed
    C:\Windows\System32\svchost.exe => File is digitally signed
    C:\Windows\System32\rpcss.dll => File is digitally signed
    **** End of log ****
  2. 2015/10/27
    TFC Ran - Did not Need a Reboot
    There was no log file, but here is a copy of the output:
    Getting user folders.
    Stopping running processes.
    Emptying Temp folders.
    User: All Users
    User: Default
    ->Flash cache emptied: 57311 bytes
    User: Default User
    User: Public
    User: Stan
    ->Temp folder emptied: 198732 bytes
    ->Temporary Internet Files folder emptied: 65769689 bytes
    ->Flash cache emptied: 58319 bytes
    %systemroot%\System32 (64bit) .tmp files removed: 0 bytes
    Windows Temp folder emptied: 4674 bytes
    %systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33298 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 42304214 bytes
    Emptying RecycleBin. Do not interrupt.
    RecycleBin emptied: 0 bytes
    Process complete!
    Total Files Cleaned = 103.00 mb
    Sophos Scan
    Hi Broni,
    The Sophos scan completed and it says the Number of Threats Found = 0. The details button was grayed out and I did not see any log file.
  5. 2015/10/27
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Scan without installing plugin" and then on "Scan now ")
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  6. 2015/10/27
    Broni,
    This is great news. I will start your wrap up steps now and can bring the PC back to my in-laws tonight. One question, as part of this process did we find out what actually caused the PC to be infected with the malware? My father in law has very basic PC knowledge and is unlikely to run your recommended weekly scans. I can try to remember to run TFC and JRT each time I am at his place, but that may only be once or twice a month.
    I could purchase a MBAM license for him. Then I can set MBAM to run weekly and to auto update. I have set F-prot to update and run regular scans. Would doing this for MBAM be very helpful?
  7. 2015/10/27
    It's impossible to trace infection source. Could be just one careless click.
    Paid MBAM version is definitely worth few bucks.
    Good luck and stay safe :)
  8. 2015/10/29
    Thanks again, Broni. I purchased a two year MBAM subscription for my father in law. Just finished installing some Windows updates. I will be bringing the computer back to them tomorrow. Have a great day!!
  9. 2015/10/29
    Same to you :)
