Pagefile on drive other than C:
Discussion in 'Windows XP' started by tnf150boy, 2003/03/10.
  1. 2003/04/11
    Christer
    Christer Geek Member Staff
    Hi Abraxas!
    Yes, but I´ve only got one physical HardDrive with three partitons. As I understand it, in terms of access speed, it doesn´t matter on which partition I put it.
    Christer
    Edited:
    Unless, as You´ve pointed out previously, it is put in a separate partition at the front of the drive. In front of the system partiton too, that is.
  2. 2003/04/11
    miniB
    miniB Inactive
    Didn't realise
    Hi
    I didn't realise you are in Sweden ! I was about to tell you to look out for the coupon on Crucial - I got £3 off each of the memory cards !
    Your right about the one hard drive - I am the same thus the advice was to keep it on 'C'
    I will read the country of origin next time :eek:
    Christer
    Well, we don´t get those coupons in Sweden but I haven´t bought anything yet in a computer store without getting at least 10% off the price.
    Ghost 2003 cost SEK799 (~$94) but I carried it away for SEK649 (~$76) ...... :D ...... some 20% off!
    Christer
  5. 2004/07/11
    river65661
    river65661 Inactive
    primary or logical
    Should an alternate hard drive pagefile be formatted as a primary or logical partition?
  6. 2004/07/11
    Christer
    I would partition the harddrive as an extended partition with the required number of logical partitions, including the partition dedicated to the pagefile.
    I now have two harddrives but the pagefile is still on C: where the installer put it.
    The second harddrive is in a mobile rack and interchangeable with other harddrives. In my case, it would require one partition for the pagefile on each harddrive and I doubt that the performance increase would be noticeable.
    An additional benefit of using Norton Ghost is that restoring an Image, relocates the pagefile to the optimum position on C: (at the front) and if You make it semi-fixed in size (768 - 1536 MB in my case), it will stay in an unfragmented state.
    Christer
