Other devices have yellow exclamations
Discussion in 'Windows XP' started by lftovr1nchnz, 2006/04/09.
  1. 2006/04/09
    lftovr1nchnz
    lftovr1nchnz Inactive Thread Starter
    in my Device Manager, the Ethernet Controller, Multimedia Audio Controller, SM Bus Controller, and Video Controller (VGA Compatible) all have yellow exclamation points next to them. what should i do? if anyone can help me, i'd really really appreciate it.
  2. 2006/04/09
    Miz
    Miz Inactive Alumni
    Those yellow marks mean you need to install, or re-install the drivers for each of those components.
    If you have a Dell, the drivers will be on a CD that came with the computer. It may be labeled "Resource" but it will say on it somewhere that it contains the drivers for your computer.
    If you don't have such a CD or any CDs with drivers for the network card (aka, network adapter), sound card or video card (aka, display adapter), if you know the make and model of each, you can download the drivers from their manufacturer's websites.
    Miz,
    lftovr1nchnz
    thank you. so do i just put that disk in and let it run? or do i have to uninstall them first?
  5. 2006/04/10
    Log in as Administrator, put the cd in & just let it run.
  6. 2006/04/10
    Miz
    Miz Inactive Alumni
    When the CD starts up, it will display a page with some helpful information on how to use the CD. Read that and if you have any questions about how to proceed, post back.
    Miz,
    #5
  7. 2006/04/10
    lftovr1nchnz
    thanks to both of you...i'm going to try it later tonight. hopefully this solves it. *cross your fingers*
  8. 2006/04/11
    lftovr1nchnz
    still have a problem...i put in the cd and it didn't run. then when i restarted the computer and let the Found New Hardware Wizard search the cd for the drivers, it didn't find them on there. what should i do now? can i get them online?
  9. 2006/04/11
    Miz
    Miz Inactive Alumni
    Put the CD in the CD drive, open My Computer and then double click on the drive the CD's in.
    Hopefully, that will start it up so you can read the instructions it displays and then install the drivers for your computer's hardware.
    It contains drivers for quite a bit of different hardware because they ship that same CD with a lot of different Dell models. Don't let that confuse you. Just read the instructions on how you make sure it delivers the right drivers for the hardware that's on your computer.
    Miz,
    #8
  10. 2006/04/12
    lftovr1nchnz
    i just realized i'm not completely sure which cd to put in. do i put in the one labeled "Resources" or "Drivers & Utilities "?
  11. 2006/04/12
    Put in the one which says 'Drivers & Utiltities'.
