Not Responding
Discussion in 'Internet Explorer & Microsoft Edge' started by Nanashi, 2004/05/09.
  1. 2004/05/17
    Nanashi
    Nanashi Inactive Thread Starter
    I'm still having the same problem... :(
    This is really bugging me out.. arg...
    I would format the comp but i have way too many things I wanna keep.. I wont' be able to back it up in mere cd or two..
    Ahhh maybe I should borrow a winxp cd and do system restore/repair?
  2. 2004/05/17
    Lonny Jones
    Lonny Jones Inactive Alumni
    Hi Nanashi
    I suggest uninstalling Kazaa even the light version and any programs you have installed since the problems started to, if you need a filesharring program we can link you to several (free) safer alternatives
    make a new log with all the programs you normaly have running Please.
    Did you take the suggestin to install eTrust EZ Armor Security Suite from Computer Associates ? and ran a full scan ?
    roy66
    roy66 Well-Known Member
    Nanashi,
    I've been experiencing much the same problem as you.
    I got around it with System restore.
    I just went back a couple of days and now everything is fine.
    The problem is probably associated with a software conflict fro something you've downloaded.
    Nothing to lose, you can always come back to your current settings .
    roy66
  5. 2004/05/18
    Nanashi
    The problem began way before the kazaa was installed
    I tried the system restore thing, but during one of the instructions I was told to do, I disabled the system restore thing at one point, so it won't go back to state before that... :(
    Ah.. maybe I should get winxp cd somewhere and do repair from that?
  6. 2004/05/18
    Johanna
    Johanna Inactive Alumni
    Try System File Check first, before an XP repair.
    Start > Run > cmd
    sfc /scannow
    you'll need your XP cd.
    sfc - system file checker, retrieves the correct version of the file from %Systemroot%\System32\Dllcache or the Windows installation source files, and then replaces the incorrect file.
    If you want to see what was replaced, right click My Computer > manage, expand event viewer > system.
    Then try to repair IE from the link I posted above, if that doesn't work.
    Johanna
