Solved New PC Running Slow and Freezing Up
Discussion in 'Malware and Virus Removal Archive' started by Rackster, 2013/05/22.
  1. 2013/05/25
    Rackster
    Rackster Inactive Thread Starter
    ESERT online scanner won't run. I agree to terms of service, click start and it goes to new box with an icon in top left corner that disappears in a minute or so then box stays blank.Waited an hour with nothing. Going to try one more time.
  2. 2013/05/25
    Try different browser.
    Rackster
    Can I download chrome?
  5. 2013/05/25
    You sure can.
  6. 2013/05/25
    Rackster
    Downloaded Chrome and ran ESET Scanner and it came up clean,so no file to post!!
  7. 2013/05/25
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure Windows Updates are current.
    4. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    5. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. (Windows XP only) Run defrag at your convenience.
    12. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    13. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    14. Please, let me know, how your computer is doing.
  8. 2013/05/26
    Rackster
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: All Users
    User: Default
    User: Default User
    User: Holt
    ->Temp folder emptied: 423420103 bytes
    ->Temporary Internet Files folder emptied: 19504244 bytes
    ->Google Chrome cache emptied: 8264679 bytes
    ->Flash cache emptied: 3661 bytes
    User: Public
    %systemroot%\System32 (64bit) .tmp files removed: 0 bytes
    Windows Temp folder emptied: 4061 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 128 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 430.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default
    User: Default User
    User: Holt
    User: Public
    [EMPTYJAVA]
    User: All Users
    User: Default
    User: Default User
    User: Holt
    User: Public
    Total Java Files Cleaned = 0.00 mb
    Restore point Set: OTL Restore Point
    OTL by OldTimer - Version 3.2.69.0 log created on 05262013_055055
    C:\Users\Holt\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
    File move failed. C:\windows\temp\UploadUI.log scheduled to be moved on reboot.
    File move failed. C:\windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat scheduled to be moved on reboot.
    PendingFileRenameOperations files...
  9. 2013/05/26
    Rackster
    PC is running like a charm. Thank you very much for your help in resolving my issues. You're help was greatly appreciated,thanks again!
  10. 2013/05/26
    Way to go!! [​IMG]
    Good luck and stay safe :)
