Solved need help with deleting viruses
Discussion in 'Malware and Virus Removal Archive' started by kravetzroman, 2011/06/05.
  1. 2011/06/06
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
  2. 2011/06/06
    kravetzroman
    kravetzroman Inactive Thread Starter
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: All Users
    User: Default
    User: Default User
    User: LogMeInRemoteUser
    User: Public
    User: Roman
    ->Temp folder emptied: 975070 bytes
    ->Temporary Internet Files folder emptied: 7085122 bytes
    ->Java cache emptied: 0 bytes
    ->Google Chrome cache emptied: 79426896 bytes
    ->Flash cache emptied: 2223 bytes
    Windows Temp folder emptied: 3492 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 83.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default
    User: Default User
    User: Public
    User: Roman
    OTL by OldTimer - Version 3.2.23.0 log created on 06072011_020330
    Whenever ready....
  5. 2011/06/07
    kravetzroman
    No BSOD so far !!!!!
    Thanks!!!!!!
  6. 2011/06/07
    Well done :)
    Good luck and stay safe :)
