Solved Need help~win32/alureon
Discussion in 'Malware and Virus Removal Archive' started by Justmenyou, 2010/05/15.
  1. 2010/05/16
    Download OTL to your Desktop.
    * Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    * Under the Custom Scan box paste this in:
    netsvcs
    %SYSTEMDRIVE%\*.exe
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    nvstor32.sys
    /md5stop
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.dll /lockedfiles
    %systemroot%\Tasks\*.job /lockedfiles
    %systemroot%\system32\drivers\*.sys /lockedfiles
    %systemroot%\System32\config\*.sav
    CREATERESTOREPOINT
    * Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  2. 2010/05/16
    Justmenyou
    Justmenyou Inactive Thread Starter
    I've tried running it twice, it starts but then it hangs?!? In task manager it is not responding.
    I suspect, you may have some other computer issues beside actual infection, but let's try something else.
    Let's see, if we can look at your computer booting from an external source.
    You will need USB flash drive to move information from bad computer to a working computer.
    You need to download two programs.
    First
    ISO Burner this will allow you to burn REATOGO-X-PE ISO to a cd and make it bootable. Just install the programm, from there on it's fairly automatic (Instructions)
    Second
    • Download OTLPE.iso and burn to a CD using ISO Burner. NOTE: This file is 270.3 MB in size so it may take some time to download.
    • When downloaded double click and this will then open ISOBurner to burn the file to CD
    • Reboot your system (Non working computer) using the boot CD you just created.
      • Note. If you do not know how to set your computer to boot from CD follow the steps HERE
    • Your system should now display a REATOGO-X-PE desktop.
    • Double-click on the OTLPE icon.
    • When asked Do you wish to load the remote registry, select Yes
    • When asked Do you wish to load remote user profile(s) for scanning, select Yes
    • Ensure the box Automatically Load All Remaining Users is checked and press OK
    • OTL should now start. Change the following settings
      • Change Drivers to All
      • Change Registry to All
      • Under Custom Scan box paste this in:
        netsvcs
        %SYSTEMDRIVE%\*.exe
        /md5start
        eventlog.dll
        scecli.dll
        netlogon.dll
        cngaudit.dll
        sceclt.dll
        ntelogon.dll
        logevent.dll
        iaStor.sys
        nvstor.sys
        atapi.sys
        IdeChnDr.sys
        viasraid.sys
        AGP440.sys
        vaxscsi.sys
        nvatabus.sys
        viamraid.sys
        nvata.sys
        nvgts.sys
        iastorv.sys
        ViPrt.sys
        eNetHook.dll
        ahcix86.sys
        KR10N.sys
        nvstor32.sys
        ahcix86s.sys
        nvrd32.sys
        symmpi.sys
        adp3132.sys
        mv61xx.sys
        userinit.exe
        explorer.exe
        /md5stop
    • Press Run Scan to start the scan.
    • When finished, the file will be saved in drive C:\OTL.txt
    • Copy this file to your USB drive.
    • Please post the contents of the C:\OTL.txt file in your reply.
  5. 2010/05/16
    Justmenyou
    Ugh, other issues. Convinced this machine must be female LOL
    Okay lasted log~
    OTL logfile created on: 5/16/2010 9:32:55 PM - Run
    OTLPE by OldTimer - Version 3.1.39.0 Folder = X:\Programs\OTLPE
    Microsoft Windows XP Service Pack 3 (Version = 5.1.2600) - Type = SYSTEM
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00001009 | Country: Canada | Language: ENC | Date Format: dd/MM/yyyy
    639.00 Mb Total Physical Memory | 417.00 Mb Available Physical Memory | 65.00% Memory free
    583.00 Mb Paging File | 443.00 Mb Available in Paging File | 76.00% Paging File free
    Paging file location(s): C:\pagefile.sys 960 1920 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 74.50 Gb Total Space | 58.83 Gb Free Space | 78.97% Space Free | Partition Type: NTFS
    D: Drive not present or media not loaded
    E: Drive not present or media not loaded
    F: Drive not present or media not loaded
    G: Drive not present or media not loaded
    H: Drive not present or media not loaded
    I: Drive not present or media not loaded
    Drive X: | 280.77 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
    Computer Name: REATOGO
    Current User Name: SYSTEM
    Logged in as Administrator.
    Current Boot Mode: Normal
    Scan Mode: All users
    Company Name Whitelist: Off
    Skip Microsoft Files: Off
    File Age = 30 Days
    Output = Standard
    Using ControlSet: ControlSet004
    SRV - File not found [Auto] -- -- (gupdate) Google Update Service (gupdate)
    SRV - [2010/02/13 18:28:09 | 001,181,328 | ---- | M] (Lavasoft) [Auto] -- C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe -- (Lavasoft Ad-Aware Service)
    SRV - [2009/08/24 09:18:21 | 000,297,752 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto] -- C:\Program Files\AVG\AVG8\avgwdsvc.exe -- (avg8wd)
    SRV - [2009/08/24 09:18:17 | 000,908,056 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto] -- C:\Program Files\AVG\AVG8\avgemc.exe -- (avg8emc)
    SRV - [2009/07/20 12:28:10 | 000,121,360 | ---- | M] (Logitech, Inc.) [On_Demand] -- C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe -- (LBTServ)
    SRV - [2009/05/19 11:36:18 | 000,240,512 | ---- | M] (Microsoft Corporation) [Auto] -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe -- (SeaPort)
    SRV - [2009/03/30 16:28:36 | 001,533,808 | ---- | M] (Microsoft Corporation) [Auto] -- C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE -- (wlidsvc)
    SRV - [2008/11/09 16:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
    SRV - [2006/03/30 09:15:44 | 000,096,341 | ---- | M] (Canon Inc.) [Auto] -- C:\Program Files\Canon\CAL\CALMAIN.exe -- (CCALib8)
    SRV - [2006/03/03 21:03:10 | 000,069,632 | ---- | M] (HP) [Auto] -- C:\WINDOWS\system32\HPZipm12.exe -- (Pml Driver HPZ12)
    ========== Driver Services (All) ==========
    DRV - File not found [Kernel | On_Demand] -- -- (WDICA)
    DRV - File not found [Kernel | Disabled] -- -- (ViaIde)
    DRV - File not found [Kernel | Disabled] -- -- (ultra)
    DRV - File not found [Kernel | Disabled] -- -- (TosIde)
    DRV - File not found [Kernel | Disabled] -- -- (symc8xx)
    DRV - File not found [Kernel | Disabled] -- -- (symc810)
    DRV - File not found [Kernel | Disabled] -- -- (sym_u3)
    DRV - File not found [Kernel | Disabled] -- -- (sym_hi)
    DRV - File not found [Kernel | Disabled] -- -- (Sparrow)
    DRV - File not found [Kernel | Disabled] -- -- (Simbad)
    DRV - File not found [Kernel | Disabled] -- -- (ql1280)
    DRV - File not found [Kernel | Disabled] -- -- (ql1240)
    DRV - File not found [Kernel | Disabled] -- -- (ql12160)
    DRV - File not found [Kernel | Disabled] -- -- (Ql10wnt)
    DRV - File not found [Kernel | Disabled] -- -- (ql1080)
    DRV - File not found [Kernel | Disabled] -- -- (perc2hib)
    DRV - File not found [Kernel | Disabled] -- -- (perc2)
    DRV - File not found [Kernel | On_Demand] -- -- (PDRFRAME)
    DRV - File not found [Kernel | On_Demand] -- -- (PDRELI)
    DRV - File not found [Kernel | On_Demand] -- -- (PDFRAME)
    DRV - File not found [Kernel | On_Demand] -- -- (PDCOMP)
    DRV - File not found [Kernel | Disabled] -- -- (PCIIde)
    DRV - File not found [Kernel | System] -- -- (PCIDump)
    DRV - File not found [Kernel | Disabled] -- -- (mraid35x)
    DRV - File not found [Kernel | System] -- -- (lbrtfdc)
    DRV - File not found [Kernel | Disabled] -- -- (ini910u)
    DRV - File not found [Kernel | Disabled] -- -- (i2omp)
    DRV - File not found [Kernel | System] -- -- (i2omgmt)
    DRV - File not found [Kernel | Disabled] -- -- (hpn)
    DRV - File not found [Kernel | Disabled] -- -- (dpti2o)
    DRV - File not found [Kernel | Disabled] -- -- (dac960nt)
    DRV - File not found [Kernel | Disabled] -- -- (dac2w2k)
    DRV - File not found [Kernel | Disabled] -- -- (Cpqarray)
    DRV - File not found [Kernel | Disabled] -- -- (CmdIde)
    DRV - File not found [Kernel | System] -- -- (Changer)
    DRV - File not found [Kernel | Disabled] -- -- (cd20xrnt)
    DRV - File not found [Kernel | On_Demand] -- -- (catchme)
    DRV - File not found [Kernel | Disabled] -- -- (Atdisk)
    DRV - File not found [Kernel | Disabled] -- -- (asc3550)
    DRV - File not found [Kernel | Disabled] -- -- (asc3350p)
    DRV - File not found [Kernel | Disabled] -- -- (asc)
    DRV - File not found [Kernel | Disabled] -- -- (amsint)
    DRV - File not found [Kernel | Disabled] -- -- (AliIde)
    DRV - File not found [Kernel | Disabled] -- -- (aic78xx)
    DRV - File not found [Kernel | Disabled] -- -- (aic78u2)
    DRV - File not found [Kernel | Disabled] -- -- (Aha154x)
    DRV - File not found [Kernel | Disabled] -- -- (adpu160m)
    DRV - File not found [Kernel | Disabled] -- -- (abp480n5)
    DRV - File not found [Kernel | Disabled] -- -- (Abiosdsk)
    DRV - [2010/05/15 14:59:08 | 000,096,512 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\ATAPI.SYS -- (atapi)
    DRV - [2010/02/24 09:11:07 | 000,455,680 | ---- | M] (Microsoft Corporation) [File_System | System] -- C:\WINDOWS\system32\drivers\mrxsmb.sys -- (MRxSmb)
    DRV - [2009/12/31 12:50:03 | 000,353,792 | ---- | M] (Microsoft Corporation) [File_System | On_Demand] -- C:\WINDOWS\system32\drivers\srv.sys -- (Srv)
    DRV - [2009/12/02 09:19:06 | 000,064,288 | ---- | M] (Lavasoft AB) [File_System | Boot] -- C:\WINDOWS\system32\drivers\Lbd.sys -- (Lbd)
    DRV - [2009/10/20 12:20:16 | 000,265,728 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\http.sys -- (HTTP)
    DRV - [2009/08/24 09:18:36 | 000,335,240 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System] -- C:\WINDOWS\System32\Drivers\avgldx86.sys -- (AvgLdx86)
    DRV - [2009/08/24 09:18:36 | 000,027,784 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System] -- C:\WINDOWS\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
    DRV - [2009/07/06 17:42:37 | 000,108,552 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System] -- C:\WINDOWS\System32\Drivers\avgtdix.sys -- (AvgTdiX)
    DRV - [2009/06/24 07:18:41 | 000,092,928 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\ksecdd.sys -- (KSecDD)
    DRV - [2009/06/17 12:56:24 | 000,079,248 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\LMouKE.Sys -- (LMouKE)
    DRV - [2009/06/17 12:55:34 | 000,010,384 | ---- | M] (Logitech, Inc.) [Kernel | Auto] -- C:\WINDOWS\system32\drivers\LBeepKE.sys -- (LBeepKE)
    DRV - [2009/06/17 12:55:26 | 000,063,248 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\L8042mou.Sys -- (L8042mou)
    DRV - [2009/06/17 12:55:18 | 000,020,240 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\L8042Kbd.sys -- (L8042Kbd)
    DRV - [2009/03/25 06:29:52 | 000,130,432 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\Rtnicxp.sys -- (RTL8023xp)
    DRV - [2008/08/14 06:04:36 | 000,138,496 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\System32\drivers\afd.sys -- (AFD)
    DRV - [2008/06/20 07:51:12 | 000,361,600 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\tcpip.sys -- (Tcpip)
    DRV - [2008/04/13 20:13:22 | 000,139,656 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\rdpwd.sys -- (RDPWD)
    DRV - [2008/04/13 20:13:21 | 000,021,896 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\tdtcp.sys -- (TDTCP)
    DRV - [2008/04/13 20:13:20 | 000,040,840 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\termdd.sys -- (TermDD)
    DRV - [2008/04/13 20:13:20 | 000,012,040 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\tdpipe.sys -- (TDPIPE)
    DRV - [2008/04/13 15:28:39 | 000,175,744 | ---- | M] (Microsoft Corporation) [File_System | System] -- C:\WINDOWS\system32\drivers\rdbss.sys -- (Rdbss)
    DRV - [2008/04/13 15:21:00 | 000,162,816 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\netbt.sys -- (NetBT)
    DRV - [2008/04/13 15:20:42 | 000,091,520 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ndiswan.sys -- (NdisWan)
    DRV - [2008/04/13 15:20:37 | 000,182,656 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\ndis.sys -- (NDIS)
    DRV - [2008/04/13 15:19:48 | 000,048,384 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\raspptp.sys -- (PptpMiniport) WAN Miniport (PPTP)
    DRV - [2008/04/13 15:19:43 | 000,051,328 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\rasl2tp.sys -- (Rasl2tp) WAN Miniport (L2TP)
    DRV - [2008/04/13 15:19:42 | 000,075,264 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\ipsec.sys -- (IPSec)
    DRV - [2008/04/13 15:18:00 | 000,052,480 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\i8042prt.sys -- (i8042prt)
    DRV - [2008/04/13 15:17:18 | 000,083,072 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\wdmaud.sys -- (wdmaud)
    DRV - [2008/04/13 15:17:05 | 000,105,344 | ---- | M] (Microsoft Corporation) [File_System | Boot] -- C:\WINDOWS\system32\drivers\mup.sys -- (Mup)
    DRV - [2008/04/13 15:15:55 | 000,060,800 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\sysaudio.sys -- (sysaudio)
    DRV - [2008/04/13 15:15:53 | 000,574,976 | ---- | M] (Microsoft Corporation) [File_System | Disabled] -- C:\WINDOWS\system32\drivers\ntfs.sys -- (Ntfs)
    DRV - [2008/04/13 15:15:45 | 000,064,512 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\serial.sys -- (Serial)
    DRV - [2008/04/13 15:14:29 | 000,143,744 | ---- | M] (Microsoft Corporation) [File_System | Disabled] -- C:\WINDOWS\system32\drivers\fastfat.sys -- (Fastfat)
    DRV - [2008/04/13 15:14:21 | 000,063,744 | ---- | M] (Microsoft Corporation) [File_System | Disabled] -- C:\WINDOWS\system32\drivers\cdfs.sys -- (Cdfs)
    DRV - [2008/04/13 15:00:19 | 000,030,080 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\modem.sys -- (Modem)
    DRV - [2008/04/13 14:57:32 | 000,041,472 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\raspppoe.sys -- (RasPppoe)
    DRV - [2008/04/13 14:57:29 | 000,040,576 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ndproxy.sys -- (NDProxy)
    DRV - [2008/04/13 14:57:27 | 000,014,336 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\asyncmac.sys -- (AsyncMac)
    DRV - [2008/04/13 14:57:27 | 000,010,112 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ndistapi.sys -- (NdisTapi)
    DRV - [2008/04/13 14:57:21 | 000,034,560 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\wanarp.sys -- (Wanarp)
    DRV - [2008/04/13 14:57:15 | 000,152,832 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ipnat.sys -- (IpNat)
    DRV - [2008/04/13 14:57:07 | 000,020,864 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ipinip.sys -- (IpInIp)
    DRV - [2008/04/13 14:56:38 | 000,069,120 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\psched.sys -- (PSched)
    DRV - [2008/04/13 14:56:32 | 000,035,072 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\msgpc.sys -- (Gpc)
    DRV - [2008/04/13 14:56:02 | 000,034,688 | ---- | M] (Microsoft Corporation) [File_System | System] -- C:\WINDOWS\system32\drivers\netbios.sys -- (NetBIOS)
    DRV - [2008/04/13 14:55:58 | 000,014,592 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ndisuio.sys -- (Ndisuio)
    DRV - [2008/04/13 14:54:28 | 000,011,264 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\irenum.sys -- (IRENUM)
    DRV - [2008/04/13 14:53:34 | 000,036,608 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ip6fw.sys -- (Ip6Fw)
    DRV - [2008/04/13 14:51:25 | 000,059,904 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\atmarpc.sys -- (Atmarpc)
    DRV - [2008/04/13 14:47:38 | 000,025,856 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\usbprint.sys -- (usbprint)
    DRV - [2008/04/13 14:45:40 | 000,032,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\usbccgp.sys -- (usbccgp)
    DRV - [2008/04/13 14:45:38 | 000,026,368 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\USBSTOR.SYS -- (USBSTOR)
    DRV - [2008/04/13 14:45:37 | 000,059,520 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\usbhub.sys -- (usbhub)
    DRV - [2008/04/13 14:45:35 | 000,020,608 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\usbuhci.sys -- (usbuhci)
    DRV - [2008/04/13 14:45:34 | 000,015,104 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\usbscan.sys -- (usbscan)
    DRV - [2008/04/13 14:45:13 | 000,002,944 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\drmkaud.sys -- (drmkaud)
    DRV - [2008/04/13 14:45:09 | 000,172,416 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\kmixer.sys -- (kmixer)
    DRV - [2008/04/13 14:45:09 | 000,056,576 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\swmidi.sys -- (swmidi)
    DRV - [2008/04/13 14:45:07 | 000,006,272 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\splitter.sys -- (splitter)
    DRV - [2008/04/13 14:45:01 | 000,052,864 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\dmusic.sys -- (DMusic)
    DRV - [2008/04/13 14:44:48 | 000,799,744 | ---- | M] (Microsoft Corp., Veritas Software) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\dmboot.sys -- (dmboot)
    DRV - [2008/04/13 14:44:46 | 000,153,344 | ---- | M] (Microsoft Corp., Veritas Software) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\dmio.sys -- (dmio)
    DRV - [2008/04/13 14:44:40 | 000,020,992 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\System32\drivers\vga.sys -- (VgaSave)
    DRV - [2008/04/13 14:41:01 | 000,052,352 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\volsnap.sys -- (VolSnap)
    DRV - [2008/04/13 14:40:58 | 000,042,112 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\imapi.sys -- (Imapi)
    DRV - [2008/04/13 14:40:49 | 000,019,712 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\partmgr.sys -- (PartMgr)
    DRV - [2008/04/13 14:40:48 | 000,011,392 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\sfloppy.sys -- (Sfloppy)
    DRV - [2008/04/13 14:40:47 | 000,036,352 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\disk.sys -- (Disk)
    DRV - [2008/04/13 14:40:46 | 000,062,976 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\cdrom.sys -- (Cdrom)
    DRV - [2008/04/13 14:40:29 | 000,005,504 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\intelide.sys -- (IntelIde)
    DRV - [2008/04/13 14:40:27 | 000,057,600 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\redbook.sys -- (redbook)
    DRV - [2008/04/13 14:40:25 | 000,027,392 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\fdc.sys -- (Fdc)
    DRV - [2008/04/13 14:40:25 | 000,020,480 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\flpydisk.sys -- (Flpydisk)
    DRV - [2008/04/13 14:40:12 | 000,015,744 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\serenum.sys -- (serenum)
    DRV - [2008/04/13 14:40:10 | 000,080,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\parport.sys -- (Parport)
    DRV - [2008/04/13 14:39:53 | 000,004,352 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\swenum.sys -- (swenum)
    DRV - [2008/04/13 14:39:52 | 000,007,552 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mskssrv.sys -- (MSKSSRV)
    DRV - [2008/04/13 14:39:51 | 000,004,992 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mspqm.sys -- (MSPQM)
    DRV - [2008/04/13 14:39:50 | 000,005,376 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mspclock.sys -- (MSPCLOCK)
    DRV - [2008/04/13 14:39:48 | 000,024,576 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\kbdclass.sys -- (Kbdclass)
    DRV - [2008/04/13 14:39:48 | 000,023,040 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\mouclass.sys -- (Mouclass)
    DRV - [2008/04/13 14:39:46 | 000,384,768 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\update.sys -- (Update)
    DRV - [2008/04/13 14:39:46 | 000,042,368 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\mountmgr.sys -- (MountMgr)
    DRV - [2008/04/13 14:36:52 | 000,073,472 | ---- | M] (Microsoft Corporation) [File_System | Boot] -- C:\WINDOWS\system32\drivers\sr.sys -- (sr)
    DRV - [2008/04/13 14:36:46 | 000,015,488 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mssmbios.sys -- (mssmbios)
    DRV - [2008/04/13 14:36:44 | 000,068,224 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\pci.sys -- (PCI)
    DRV - [2008/04/13 14:36:43 | 000,120,192 | ---- | M] (Microsoft Corporation) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\pcmcia.sys -- (Pcmcia)
    DRV - [2008/04/13 14:36:41 | 000,037,248 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\isapnp.sys -- (isapnp)
    DRV - [2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\agp440.sys -- (agp440)
    DRV - [2008/04/13 14:36:35 | 000,187,776 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\acpi.sys -- (ACPI)
    DRV - [2008/04/13 14:33:28 | 000,044,544 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\fips.sys -- (Fips)
    DRV - [2008/04/13 14:32:59 | 000,129,792 | ---- | M] (Microsoft Corporation) [File_System | Boot] -- C:\WINDOWS\system32\drivers\fltmgr.sys -- (FltMgr)
    DRV - [2008/04/13 14:32:44 | 000,180,608 | ---- | M] (Microsoft Corporation) [File_System | On_Demand] -- C:\WINDOWS\system32\drivers\mrxdav.sys -- (MRxDAV)
    DRV - [2008/04/13 14:32:39 | 000,030,848 | ---- | M] (Microsoft Corporation) [File_System | System] -- C:\WINDOWS\system32\drivers\npfs.sys -- (Npfs)
    DRV - [2008/04/13 14:32:39 | 000,019,072 | ---- | M] (Microsoft Corporation) [File_System | System] -- C:\WINDOWS\system32\drivers\msfs.sys -- (Msfs)
    DRV - [2008/04/13 14:32:36 | 000,066,048 | ---- | M] (Microsoft Corporation) [File_System | Disabled] -- C:\WINDOWS\system32\drivers\udfs.sys -- (Udfs)
    DRV - [2008/04/13 14:31:30 | 000,035,840 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\processr.sys -- (Processor)
    DRV - [2008/04/13 12:39:23 | 000,142,592 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\aec.sys -- (aec)
    DRV - [2008/04/13 12:39:15 | 000,020,480 | ---- | M] (Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\secdrv.sys -- (Secdrv)
    DRV - [2008/02/27 13:49:00 | 000,003,840 | ---- | M] () [Kernel | System] -- C:\WINDOWS\System32\Drivers\BANTExt.sys -- (BANTExt)
    DRV - [2006/10/18 20:00:00 | 000,038,528 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\wpdusb.sys -- (WpdUsb)
    DRV - [2006/09/28 19:00:34 | 000,082,944 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\WudfRd.sys -- (WudfRd)
    DRV - [2006/09/28 18:55:50 | 000,077,568 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\WudfPf.sys -- (WudfPf)
    DRV - [2004/08/04 08:00:00 | 000,125,056 | ---- | M] (Microsoft Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\ftdisk.sys -- (Ftdisk)
    DRV - [2004/08/04 08:00:00 | 000,032,896 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ipfltdrv.sys -- (IpFilterDriver)
    DRV - [2004/08/04 08:00:00 | 000,032,512 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\nwlnkfwd.sys -- (NwlnkFwd)
    DRV - [2004/08/04 08:00:00 | 000,018,688 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\cdaudio.sys -- (Cdaudio)
    DRV - [2004/08/04 08:00:00 | 000,017,792 | ---- | M] (Parallel Technologies, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ptilink.sys -- (Ptilink)
    DRV - [2004/08/04 08:00:00 | 000,016,512 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\raspti.sys -- (Raspti)
    DRV - [2004/08/04 08:00:00 | 000,013,952 | ---- | M] (Microsoft Corporation) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\cbidf2k.sys -- (cbidf2k)
    DRV - [2004/08/04 08:00:00 | 000,012,416 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\nwlnkflt.sys -- (NwlnkFlt)
    DRV - [2004/08/04 08:00:00 | 000,011,648 | ---- | M] (Microsoft Corporation) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\acpiec.sys -- (ACPIEC)
    DRV - [2004/08/04 08:00:00 | 000,008,832 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\rasacd.sys -- (RasAcd)
    DRV - [2004/08/04 08:00:00 | 000,007,936 | ---- | M] (Microsoft Corporation) [Recognizer | System] -- C:\WINDOWS\system32\drivers\fs_rec.sys -- (Fs_Rec)
    DRV - [2004/08/04 08:00:00 | 000,006,784 | ---- | M] (Microsoft Corporation) [Kernel | Auto] -- C:\WINDOWS\system32\drivers\parvdm.sys -- (ParVdm)
    DRV - [2004/08/04 08:00:00 | 000,005,888 | ---- | M] (Microsoft Corp., Veritas Software.) [Kernel | Disabled] -- C:\WINDOWS\system32\drivers\dmload.sys -- (dmload)
    DRV - [2004/08/04 08:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\rdpcdd.sys -- (RDPCDD)
    DRV - [2004/08/04 08:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\mnmdd.sys -- (mnmdd)
    DRV - [2004/08/04 08:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\beep.sys -- (Beep)
    DRV - [2004/08/04 08:00:00 | 000,002,944 | ---- | M] (Microsoft Corporation) [Kernel | System] -- C:\WINDOWS\system32\drivers\null.sys -- (Null)
    DRV - [2004/08/04 08:00:00 | 000,002,864 | ---- | M] (Microsoft Corporation) [Adapter | On_Demand] -- C:\WINDOWS\system32\winsock.dll -- (Winsock)
    DRV - [2004/08/03 18:31:34 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\RTL8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
    DRV - [2004/08/03 18:29:56 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
    DRV - [2001/08/17 09:59:44 | 000,003,072 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\audstub.sys -- (audstub)
    DRV - [2001/08/17 09:28:02 | 000,907,456 | ---- | M] (Conexant) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\HCF_MSFT.sys -- (HCF_MSFT)
    DRV - [2001/08/17 08:20:04 | 000,096,256 | ---- | M] (Intel Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ac97intc.sys -- (ac97intc) Intel(r) 82801 Audio Driver Install Service (WDM)
    DRV - [2001/08/13 17:17:34 | 000,737,973 | ---- | M] (Conexant) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\winachcf.sys -- (Winachcf)
    ========== Standard Registry (All) ==========
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\WINDOWS\system32\blank.htm
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
    IE - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ca.yahoo.com
    IE - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm
    IE - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm
    IE - HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Search Page = http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
    IE - HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Local Page = C:\WINDOWS\system32\blank.htm
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Search Page = http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page = http://ca.yahoo.com
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = http://ca.msn.com/?lang=en-ca&OCID=FW69157
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache AcceptLangs = en-ca
    IE - HKU\Kelly_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache_TIMESTAMP = 34 2B E2 A6 78 69 CA 01 [binary data]
    IE - HKU\Kelly_ON_C\..\URLSearchHook: {CFBFAE00-17A6-11D0-99CB-00C04FD64497} - C:\WINDOWS\system32\ieframe.dll (Microsoft Corporation)
    IE - HKU\Kelly_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\systemprofile_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    FF - HKLM\software\mozilla\Firefox\Extensions\\{20a82645-c095-46ed-80e3-08825760534b}: c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\ [2009/10/26 03:00:57 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Firefox\Extensions\\jqs@sun.com: C:\Program Files\Java\jre6\lib\deploy\jqs\ff [2009/07/08 13:53:55 | 000,000,000 | ---D | M]
    [2010/05/15 15:20:27 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2009/07/14 10:53:59 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
    [2009/08/28 15:02:11 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
    [2009/11/03 16:28:45 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
    [2009/10/11 05:17:27 | 000,411,368 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeploytk.dll
    [2009/02/27 13:13:42 | 000,103,792 | ---- | M] (Adobe Systems Inc.) -- C:\Program Files\Mozilla Firefox\plugins\nppdf32.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin2.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin3.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin4.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin5.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin6.dll
    [2009/12/02 22:10:15 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npqtplugin7.dll
    O1 HOSTS File: ([2010/05/16 12:09:53 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
    O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
    O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
    O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (AVG Technologies CZ, s.r.o.)
    O2 - BHO: (Spybot-S&D IE Protection) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - No CLSID value found.
    O2 - BHO: (Search Helper) - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll (Microsoft Corporation)
    O2 - BHO: (Windows Live ID Sign-in Helper) - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll (Microsoft Corporation)
    O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
    O2 - BHO: (Windows Live Toolbar Helper) - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O2 - BHO: (JQSIEStartDetectorImpl Class) - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll (Sun Microsystems, Inc.)
    O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll (Yahoo! Inc)
    O3 - HKLM\..\Toolbar: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
    O3 - HKU\Kelly_ON_C\..\Toolbar\WebBrowser: (&Address) - {01E04581-4EEE-11D0-BFE9-00AA005B4383} - C:\WINDOWS\system32\browseui.dll (Microsoft Corporation)
    O3 - HKU\Kelly_ON_C\..\Toolbar\WebBrowser: (&Links) - {0E5CBF21-D15F-11D0-8301-00AA005B4383} - C:\WINDOWS\system32\shell32.dll (Microsoft Corporation)
    O3 - HKU\Kelly_ON_C\..\Toolbar\WebBrowser: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
    O4 - HKLM..\Run: [QuickTime Task] C:\Program Files\QuickTime\qttask.exe (Apple Inc.)
    O4 - HKLM..\Run: [SoundMan] C:\WINDOWS\SOUNDMAN.EXE (Realtek Semiconductor Corp.)
    O4 - HKLM..\Run: [YSearchProtection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe (Yahoo! Inc)
    O4 - HKU\.DEFAULT..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
    O4 - HKU\Administrator_ON_C..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
    O4 - HKU\Kelly_ON_C..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
    O4 - HKU\Kelly_ON_C..\Run: [Search Protection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe (Yahoo! Inc)
    O4 - HKU\systemprofile_ON_C..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: dontdisplaylastusername = 0
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticecaption =
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticetext =
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: shutdownwithoutlogon = 1
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: undockwithoutlogon = 1
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableRegistryTools = 0
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\Administrator_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\Kelly_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\Kelly_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\Kelly_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O7 - HKU\Kelly_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: disableregistrytools = 0
    O7 - HKU\LocalService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\NetworkService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O7 - HKU\systemprofile_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
    O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
    O9 - Extra 'Tools' menuitem : @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\network diagnostic\xpnetdiag.exe (Microsoft Corporation)
    O9 - Extra Button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (Microsoft Corporation)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\WINDOWS\system32\winrnr.dll (Microsoft Corporation)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\WINDOWS\system32\mswsock.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\WINDOWS\system32\rsvpsp.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000011 - C:\WINDOWS\system32\rsvpsp.dll (Microsoft Corporation)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_17-windows-i586.cab (Java Plug-in 1.6.0_17)
    O16 - DPF: {CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0-windows-i586.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_07-windows-i586.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_17-windows-i586.cab (Java Plug-in 1.6.0_17)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_17-windows-i586.cab (Java Plug-in 1.6.0_17)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.2.1
    O18 - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\belarc {6318E0AB-2E93-11D1-B8ED-00608CC9A71F} - C:\Program Files\Belarc\Advisor\System\BAVoilaX.dll (Belarc, Inc.)
    O18 - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\WINDOWS\system32\msvidctl.dll (Microsoft Corporation)
    O18 - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\gopher {79eac9e4-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\http\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\http\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\https\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\https\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\ipp - No CLSID value found
    O18 - Protocol\Handler\ipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\WINDOWS\system32\itss.dll (Microsoft Corporation)
    O18 - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll (AVG Technologies CZ, s.r.o.)
    O18 - Protocol\Handler\livecall {828030A1-22C1-4009-854F-8E305202313F} - C:\Program Files\Windows Live\Messenger\msgrapp.14.0.8089.0726.dll (Microsoft Corporation)
    O18 - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\WINDOWS\system32\inetcomm.dll (Microsoft Corporation)
    O18 - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Handler\msdaipp - No CLSID value found
    O18 - Protocol\Handler\msdaipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\msdaipp\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
    O18 - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\WINDOWS\system32\itss.dll (Microsoft Corporation)
    O18 - Protocol\Handler\msnim {828030A1-22C1-4009-854F-8E305202313F} - C:\Program Files\Windows Live\Messenger\msgrapp.14.0.8089.0726.dll (Microsoft Corporation)
    O18 - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\sysimage {76E67A63-06E9-11D2-A840-006008059382} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\WINDOWS\system32\msvidctl.dll (Microsoft Corporation)
    O18 - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\WINDOWS\system32\mshtml.dll (Microsoft Corporation)
    O18 - Protocol\Handler\wia {13F3EA8B-91D7-4F0A-AD76-D2853AC8BECE} - C:\WINDOWS\system32\wiascr.dll (Microsoft Corporation)
    O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
    O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\WINDOWS\System32\mscoree.dll (Microsoft Corporation)
    O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\WINDOWS\System32\mscoree.dll (Microsoft Corporation)
    O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\WINDOWS\System32\mscoree.dll (Microsoft Corporation)
    O18 - Protocol\Filter\Class Install Handler {32B533BB-EDAE-11d0-BD5A-00AA00B92AF1} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Filter\deflate {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Filter\gzip {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Filter\lzdhtml {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\WINDOWS\system32\urlmon.dll (Microsoft Corporation)
    O18 - Protocol\Filter\text/webviewhtml {733AC4CB-F1A4-11d0-B951-00A0C90312E1} - C:\WINDOWS\system32\shell32.dll (Microsoft Corporation)
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: UserInit - (C:\WINDOWS\system32\userinit.exe) - C:\WINDOWS\system32\userinit.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: UIHost - (logonui.exe) - C:\WINDOWS\System32\logonui.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\WINDOWS\System32\shell32.dll (Microsoft Corporation)
    O20 - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl ") - C:\WINDOWS\System32\sysdm.cpl (Microsoft Corporation)
    O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
    O20 - Winlogon\Notify\crypt32chain: DllName - crypt32.dll - C:\WINDOWS\System32\crypt32.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\cryptnet: DllName - cryptnet.dll - C:\WINDOWS\System32\cryptnet.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\cscdll: DllName - cscdll.dll - C:\WINDOWS\System32\cscdll.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\dimsntfy: DllName - %SystemRoot%\System32\dimsntfy.dll - C:\WINDOWS\system32\dimsntfy.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\LBTWlgn: DllName - c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll - c:\Program Files\Common Files\Logishrd\Bluetooth\LBTWLgn.dll (Logitech, Inc.)
    O20 - Winlogon\Notify\ScCertProp: DllName - wlnotify.dll - C:\WINDOWS\System32\wlnotify.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\Schedule: DllName - wlnotify.dll - C:\WINDOWS\System32\wlnotify.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\sclgntfy: DllName - sclgntfy.dll - C:\WINDOWS\System32\sclgntfy.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\SensLogn: DllName - WlNotify.dll - C:\WINDOWS\System32\wlnotify.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\termsrv: DllName - wlnotify.dll - C:\WINDOWS\System32\wlnotify.dll (Microsoft Corporation)
    O20 - Winlogon\Notify\wlballoon: DllName - wlnotify.dll - C:\WINDOWS\System32\wlnotify.dll (Microsoft Corporation)
    O21 - SSODL: CDBurn - {fbeb8a05-beee-4442-804e-409d6c4515e9} - C:\WINDOWS\system32\shell32.dll (Microsoft Corporation)
    O21 - SSODL: PostBootReminder - {7849596a-48ea-486e-8937-a2a3009f31a9} - C:\WINDOWS\system32\shell32.dll (Microsoft Corporation)
    O21 - SSODL: SysTray - {35CEC8A3-2BE6-11D2-8773-92E220524153} - C:\WINDOWS\system32\stobject.dll (Microsoft Corporation)
    O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\WINDOWS\system32\webcheck.dll (Microsoft Corporation)
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll (Microsoft Corporation)
    O22 - SharedTaskScheduler: {438755C2-A8BA-11D1-B96B-00A0C90312E1} - Browseui preloader - C:\WINDOWS\system32\browseui.dll (Microsoft Corporation)
    O22 - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\WINDOWS\system32\browseui.dll (Microsoft Corporation)
    O28 - HKLM ShellExecuteHooks: {AEB6717E-7E19-11d0-97EE-00C04FD91972} - C:\WINDOWS\System32\shell32.dll (Microsoft Corporation)
    O29 - HKLM SecurityProviders - (msapsspc.dll) - C:\WINDOWS\System32\msapsspc.dll (Microsoft Corporation)
    O29 - HKLM SecurityProviders - (schannel.dll) - C:\WINDOWS\System32\schannel.dll (Microsoft Corporation)
    O29 - HKLM SecurityProviders - (digest.dll) - C:\WINDOWS\System32\digest.dll (Microsoft Corporation)
    O29 - HKLM SecurityProviders - (msnsspc.dll) - C:\WINDOWS\System32\msnsspc.dll (Microsoft Corporation)
    O30 - LSA: Authentication Packages - (msv1_0) - C:\WINDOWS\System32\msv1_0.dll (Microsoft Corporation)
    O30 - LSA: Security Packages - (kerberos) - C:\WINDOWS\System32\kerberos.dll (Microsoft Corporation)
    O30 - LSA: Security Packages - (msv1_0) - C:\WINDOWS\System32\msv1_0.dll (Microsoft Corporation)
    O30 - LSA: Security Packages - (schannel) - C:\WINDOWS\System32\schannel.dll (Microsoft Corporation)
    O30 - LSA: Security Packages - (wdigest) - C:\WINDOWS\System32\wdigest.dll (Microsoft Corporation)
    O31 - SafeBoot: AlternateShell - cmd.exe
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2009/07/06 17:26:09 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O32 - AutoRun File - [2006/03/24 07:06:41 | 000,000,053 | R--- | M] () - X:\AUTORUN.INF -- [ CDFS ]
    O34 - HKLM BootExecute: (lsdelete) - C:\WINDOWS\System32\lsdelete.exe ()
    O37 - HKLM\...com [@ = comfile] -- "%1" %*
  6. 2010/05/16
    Justmenyou
    NetSvcs: 6to4 - File not found
    NetSvcs: Ias - C:\WINDOWS\system32\ias [2009/07/06 17:25:25 | 000,000,000 | ---D | M]
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: Wmi - C:\WINDOWS\system32\wmi.dll (Microsoft Corporation)
    NetSvcs: WmdmPmSp - File not found
    ========== Files/Folders - Created Within 30 Days ==========
    [2010/05/16 18:49:09 | 000,571,392 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Kelly\Desktop\OTL.exe
    [2010/05/16 15:55:47 | 000,000,000 | -HSD | C] -- C:\Documents and Settings\NetworkService\Cookies
    [2010/05/16 14:07:59 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2010/05/16 12:19:57 | 000,000,000 | -HSD | C] -- C:\WINDOWS\system32\config\systemprofile\Cookies
    [2010/05/15 16:14:52 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2010/05/15 16:10:35 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/05/15 15:26:35 | 000,178,000 | ---- | C] (Kaspersky Lab) -- C:\Documents and Settings\Kelly\Desktop\TDSSKiller.exe
    [2010/05/15 15:26:35 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Kelly\Desktop\tdsskiller
    [2010/05/15 09:37:01 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\MpEngineStore
    [4 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
    [1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
    ========== Files - Modified Within 30 Days ==========
    [2010/05/16 20:22:47 | 000,229,376 | ---- | M] () -- C:\Documents and Settings\NetworkService\NTUSER.DAT
    [2010/05/16 20:22:47 | 000,229,376 | ---- | M] () -- C:\Documents and Settings\LocalService\ntuser.dat
    [2010/05/16 20:22:45 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/05/16 20:22:25 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
    [2010/05/16 20:22:02 | 000,000,426 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{7F6A97A9-F505-4CAE-B79C-F354FEF11EB8}.job
    [2010/05/16 20:21:51 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Kelly\ntuser.ini
    [2010/05/16 20:21:50 | 005,242,880 | ---- | M] () -- C:\Documents and Settings\Kelly\ntuser.dat
    [2010/05/16 18:49:17 | 000,571,392 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Kelly\Desktop\OTL.exe
    [2010/05/16 18:34:02 | 060,054,673 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
    [2010/05/16 17:25:22 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Daily 4).job
    [2010/05/16 15:17:46 | 000,522,738 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
    [2010/05/16 15:17:46 | 000,441,564 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/05/16 15:17:46 | 000,071,396 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/05/16 15:15:56 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Weekly).job
    [2010/05/16 15:15:54 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Daily 3).job
    [2010/05/16 15:15:53 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Daily 2).job
    [2010/05/16 15:15:52 | 000,000,472 | ---- | M] () -- C:\WINDOWS\tasks\Ad-Aware Update (Daily 1).job
    [2010/05/16 12:17:52 | 000,053,960 | ---- | M] () -- C:\Documents and Settings\Kelly\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    [2010/05/16 12:10:14 | 000,000,227 | ---- | M] () -- C:\WINDOWS\system.ini
    [2010/05/16 12:09:53 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
    [2010/05/16 10:33:10 | 000,294,400 | ---- | M] () -- C:\Documents and Settings\Kelly\Desktop\exeHelper.com
    [2010/05/16 03:02:17 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
    [2010/05/15 16:56:24 | 000,525,824 | ---- | M] () -- C:\Documents and Settings\Kelly\Desktop\dds.scr
    [2010/05/15 16:14:57 | 000,000,281 | RHS- | M] () -- C:\boot.ini
    [2010/05/15 15:26:35 | 000,178,000 | ---- | M] (Kaspersky Lab) -- C:\Documents and Settings\Kelly\Desktop\TDSSKiller.exe
    [2010/05/15 15:25:04 | 000,154,469 | ---- | M] () -- C:\Documents and Settings\Kelly\Desktop\tdsskiller.zip
    [2010/05/15 15:15:26 | 000,013,646 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/05/15 03:06:59 | 000,000,172 | ---- | M] () -- C:\WINDOWS\System32\MRT.INI
    [2010/05/14 15:51:16 | 000,198,552 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2010/05/14 15:20:46 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Administrator\ntuser.ini
    [2010/05/14 15:20:44 | 003,184,656 | -H-- | M] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\IconCache.db
    [2010/05/13 16:14:09 | 000,001,519 | ---- | M] () -- C:\Documents and Settings\Kelly\Desktop\Notepad.lnk
    [2010/05/11 19:37:03 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
    [2010/05/05 20:47:29 | 000,000,664 | ---- | M] () -- C:\WINDOWS\System32\d3d9caps.dat
    [2010/05/16 21:28:48 | 000,008,192 | -H-- | C] () -- C:\WINDOWS\system32\config\systemprofile\ntuser.dat.LOG
    [2010/05/16 10:33:09 | 000,294,400 | ---- | C] () -- C:\Documents and Settings\Kelly\Desktop\exeHelper.com
    [2010/05/15 16:56:10 | 000,525,824 | ---- | C] () -- C:\Documents and Settings\Kelly\Desktop\dds.scr
    [2010/05/15 16:14:57 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2010/05/15 16:14:53 | 000,260,272 | ---- | C] () -- C:\cmldr
    [2010/05/15 15:25:03 | 000,154,469 | ---- | C] () -- C:\Documents and Settings\Kelly\Desktop\tdsskiller.zip
    [2010/05/13 16:14:09 | 000,001,519 | ---- | C] () -- C:\Documents and Settings\Kelly\Desktop\Notepad.lnk
    [2010/05/11 16:20:17 | 000,000,426 | -H-- | C] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{7F6A97A9-F505-4CAE-B79C-F354FEF11EB8}.job
    [2010/05/05 15:09:44 | 000,000,472 | ---- | C] () -- C:\WINDOWS\tasks\Ad-Aware Update (Weekly).job
    [2010/05/05 15:09:42 | 000,000,472 | ---- | C] () -- C:\WINDOWS\tasks\Ad-Aware Update (Daily 4).job
    [2010/04/14 21:49:00 | 000,000,172 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
    [2010/02/15 04:00:23 | 000,229,376 | ---- | C] () -- C:\Documents and Settings\LocalService\ntuser.dat
    [2010/02/13 13:59:20 | 005,242,880 | ---- | C] () -- C:\Documents and Settings\Kelly\ntuser.dat
    [2010/02/02 09:40:50 | 000,003,840 | ---- | C] () -- C:\WINDOWS\System32\drivers\BANTExt.sys
    [2010/02/01 16:38:38 | 000,000,178 | -HS- | C] () -- C:\Documents and Settings\Administrator\ntuser.ini
    [2010/02/01 16:38:33 | 000,524,288 | -H-- | C] () -- C:\Documents and Settings\Administrator\ntuser.dat
    [2010/02/01 16:38:33 | 000,065,536 | -H-- | C] () -- C:\Documents and Settings\Administrator\NTUSER.DAT.LOG
    [2010/02/01 16:35:36 | 000,026,625 | ---- | C] () -- C:\WINDOWS\System32\knvep32.dll
    [2010/02/01 16:33:13 | 000,147,456 | ---- | C] () -- C:\WINDOWS\System32\RTLCPAPI.dll
    [2010/01/18 07:55:41 | 003,747,840 | ---- | C] () -- C:\WINDOWS\system32\config\systemprofile\ntuser.dat
    [2009/11/25 12:07:25 | 000,003,584 | ---- | C] () -- C:\Documents and Settings\Kelly\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2009/08/18 00:52:53 | 000,015,110 | ---- | C] () -- C:\Documents and Settings\Kelly\Local Settings\Application Data\slot1.mm1
    [2009/07/24 18:04:55 | 000,077,824 | ---- | C] () -- C:\WINDOWS\System32\hpzids01.dll
    [2009/07/07 17:16:36 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2009/07/06 17:32:06 | 000,000,178 | -HS- | C] () -- C:\Documents and Settings\Kelly\ntuser.ini
    [2009/07/06 17:32:04 | 000,020,480 | -H-- | C] () -- C:\Documents and Settings\Kelly\NTUSER.DAT.LOG
    [2009/07/06 17:30:02 | 000,000,020 | -HS- | C] () -- C:\Documents and Settings\LocalService\ntuser.ini
    [2009/07/06 17:30:01 | 000,008,192 | -H-- | C] () -- C:\Documents and Settings\LocalService\ntuser.dat.LOG
    [2009/07/06 17:29:52 | 000,000,020 | -HS- | C] () -- C:\Documents and Settings\NetworkService\ntuser.ini
    [2009/07/06 17:29:51 | 000,229,376 | ---- | C] () -- C:\Documents and Settings\NetworkService\NTUSER.DAT
    [2009/07/06 17:29:51 | 000,008,192 | -H-- | C] () -- C:\Documents and Settings\NetworkService\ntuser.dat.LOG
    [2009/03/03 12:18:04 | 000,073,728 | ---- | C] () -- C:\WINDOWS\System32\RtNicProp32.dll
    [2010/01/12 23:36:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\Canon
    [2010/01/12 23:38:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\Image Zone Express
    [2009/10/19 16:18:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\Leadertech
    [2010/01/20 18:17:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\LimeWire
    [2009/07/09 09:51:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\OpenOffice.org
    [2009/08/13 16:11:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\Printer Info Cache
    [2009/10/09 17:52:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Kelly\Application Data\SanDisk
    [2010/05/16 15:15:52 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Daily 1).job
    [2010/05/16 15:15:53 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Daily 2).job
    [2010/05/16 15:15:54 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Daily 3).job
    [2010/05/16 17:25:22 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Daily 4).job
    [2010/05/16 15:15:56 | 000,000,472 | ---- | M] () -- C:\WINDOWS\Tasks\Ad-Aware Update (Weekly).job
    [2010/05/16 20:22:02 | 000,000,426 | -H-- | M] () -- C:\WINDOWS\Tasks\User_Feed_Synchronization-{7F6A97A9-F505-4CAE-B79C-F354FEF11EB8}.job
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.exe >
    < MD5 for: AGP440.SYS >
    [2004/08/04 08:00:00 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp2.cab:AGP440.sys
    [2009/07/07 12:16:16 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:AGP440.sys
    [2009/07/07 12:16:16 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:AGP440.sys
    [2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\ERDNT\cache\agp440.sys
    [2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\ServicePackFiles\i386\agp440.sys
    [2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\system32\drivers\agp440.sys
    [2004/08/03 19:07:42 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=2C428FA0C3E3A01ED93C9B2A27D8D4BB -- C:\WINDOWS\$NtServicePackUninstall$\agp440.sys
    [2004/08/03 19:07:42 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=2C428FA0C3E3A01ED93C9B2A27D8D4BB -- C:\WINDOWS\system32\ReinstallBackups\0002\DriverFiles\i386\AGP440.SYS
    < MD5 for: ATAPI.SYS >
    [2004/08/04 08:00:00 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp2.cab:atapi.sys
    [2009/07/07 12:16:16 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:atapi.sys
    [2009/07/07 12:16:16 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:atapi.sys
    [2010/05/15 14:59:08 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\ERDNT\cache\ATAPI.SYS
    [2008/04/13 14:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\ServicePackFiles\i386\atapi.sys
    [2010/01/20 16:56:20 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\dllcache\atapi.sys
    [2010/05/15 14:59:08 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\drivers\ATAPI.SYS
    [2004/08/04 08:00:00 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\$NtServicePackUninstall$\atapi.sys
    < MD5 for: EVENTLOG.DLL >
    [2008/04/13 20:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\ERDNT\cache\eventlog.dll
    [2008/04/13 20:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\ServicePackFiles\i386\eventlog.dll
    [2008/04/13 20:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\system32\eventlog.dll
    [2004/08/04 08:00:00 | 000,055,808 | ---- | M] (Microsoft Corporation) MD5=82B24CB70E5944E6E34662205A2A5B78 -- C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll
    < MD5 for: EXPLORER.EXE >
    [2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\ERDNT\cache\explorer.exe
    [2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\explorer.exe
    [2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\ServicePackFiles\i386\explorer.exe
    [2004/08/04 08:00:00 | 001,032,192 | ---- | M] (Microsoft Corporation) MD5=A0732187050030AE399B241436565E64 -- C:\WINDOWS\$NtServicePackUninstall$\explorer.exe
    < MD5 for: NETLOGON.DLL >
    [2008/04/13 20:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\ERDNT\cache\netlogon.dll
    [2008/04/13 20:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\ServicePackFiles\i386\netlogon.dll
    [2008/04/13 20:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\system32\netlogon.dll
    [2004/08/04 08:00:00 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=96353FCECBA774BB8DA74A1C6507015A -- C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll
    < MD5 for: SCECLI.DLL >
    [2004/08/04 08:00:00 | 000,180,224 | ---- | M] (Microsoft Corporation) MD5=0F78E27F563F2AAF74B91A49E2ABF19A -- C:\WINDOWS\$NtServicePackUninstall$\scecli.dll
    [2008/04/13 20:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\ERDNT\cache\scecli.dll
    [2008/04/13 20:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\ServicePackFiles\i386\scecli.dll
    [2008/04/13 20:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\system32\scecli.dll
    < MD5 for: USERINIT.EXE >
    [2004/08/04 08:00:00 | 000,024,576 | ---- | M] (Microsoft Corporation) MD5=39B1FFB03C2296323832ACBAE50D2AFF -- C:\WINDOWS\$NtServicePackUninstall$\userinit.exe
    [2008/04/13 20:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\ERDNT\cache\userinit.exe
    [2008/04/13 20:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\ServicePackFiles\i386\userinit.exe
    [2008/04/13 20:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\system32\userinit.exe
    < %systemroot%\*. /mp /s >
    < %systemroot%\system32\*.dll /lockedfiles >
    [2008/06/20 13:46:57 | 000,147,968 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\dnsapi.dll
    [2010/02/25 11:54:36 | 011,070,976 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\ieframe.dll
    [2010/02/25 02:24:35 | 001,985,536 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\iertutil.dll
    [2008/04/13 20:12:00 | 000,274,944 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\mstask.dll
    [2008/04/13 20:12:02 | 000,067,072 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\ntdsapi.dll
    [2008/06/17 15:02:19 | 008,461,312 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\WINDOWS\system32\shell32.dll
    [1 C:\WINDOWS\system32\*.tmp files -> C:\WINDOWS\system32\*.tmp -> ]
    < %systemroot%\Tasks\*.job /lockedfiles >
    < %systemroot%\system32\drivers\*.sys /lockedfiles >
    < %systemroot%\System32\config\*.sav >
    [2009/07/06 13:11:15 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2009/07/06 13:11:15 | 000,634,880 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2009/07/06 13:11:15 | 000,868,352 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < End of report >
  7. 2010/05/16
    Do this on the computer you are posting from:
    Copy the text in the codebox below:
    :OTL
    O16 - DPF: {CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jin...ndows-i586.cab  (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jin...ndows-i586.cab (Reg Error: Key error.)
    :Services
    :Reg
    :Files
    C:\WINDOWS\system32\drivers\ATAPI.SYS|C:\WINDOWS\ServicePackFiles\i386\atapi.sys /replace
    :Commands
    [purity]
    [emptytemp]
    Open Notepad and paste it.
    Save the document as Fix.txt on to a USB flash drive
    On the infected computer the following...
    Run OTLPE
    • Insert USB stick and find the file Fix.txt. Drag the file Fix.txt and drop it under the Custom Scans/Fixes box at the bottom.
      • (The content of Fix.txt should appear in the box)
    • Post the log produced (you'll need to transfer it with USB stick)
    • Reboot normally into windows.
    Download GMER: http://www.gmer.net/files.php, by clicking on Download EXE button.
    Alternative downloads:
    - http://majorgeeks.com/GMER_d5198.html
    - http://www.softpedia.com/get/Interne...ers/GMER.shtml
    Double click on downloaded .exe file, select Rootkit tab and click the Scan button.
    Do NOT use the computer while GMER is running!
    When scan is completed, click Save button, and save the results as gmer.log
    Warning ! Please, do not select the "Show all" checkbox during the scan.
    Post the log.
    IMPORTANT! If for some reason GMER refuses to run, try again.
    If it still fails, try to UN-check "Devices" in right pane.
    If still no joy, try to run it from Safe Mode.
  8. 2010/05/16
    Justmenyou
    Justmenyou Inactive Thread Starter
    ========== OTL ==========
    Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\Administrator_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\Kelly_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\LocalService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\NetworkService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\systemprofile_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\Administrator_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\Kelly_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\LocalService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\NetworkService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_USERS\systemprofile_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
    C:\WINDOWS\Downloaded Program Files\gp.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\Administrator_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\Kelly_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\LocalService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\NetworkService_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_USERS\systemprofile_ON_C\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\ipp\ deleted successfully.
    File Protocol\Handler\ipp - No CLSID value found not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\msdaipp\ deleted successfully.
    File Protocol\Handler\msdaipp - No CLSID value found not found.
    C:\WINDOWS\system32\knvep32.dll moved successfully.
    ========== FILES ==========
    File C:\WINDOWS\system32\drivers\ATAPI.SYS successfully replaced with C:\WINDOWS\ServicePackFiles\i386\atapi.sys
    [EMPTYTEMP]
    User: Administrator
    ->Temporary Internet Files folder emptied: 247159 bytes
    ->Flash cache emptied: 41044 bytes
    User: All Users
    User: Default User
    User: Kelly
    ->Temp folder emptied: 660 bytes
    ->Temporary Internet Files folder emptied: 12966317 bytes
    ->Java cache emptied: 20638102 bytes
    ->FireFox cache emptied: 94508385 bytes
    ->Flash cache emptied: 2164022 bytes
    User: LocalService
    ->Temporary Internet Files folder emptied: 1966214 bytes
    ->Java cache emptied: 0 bytes
    ->Flash cache emptied: 8645 bytes
    User: NetworkService
    ->Java cache emptied: 23957 bytes
    ->Flash cache emptied: 19017 bytes
    User: Spencer
    ->Temporary Internet Files folder emptied: 5548174 bytes
    ->Java cache emptied: 9799 bytes
    ->FireFox cache emptied: 66036361 bytes
    ->Flash cache emptied: 43061 bytes
    %systemroot% .tmp files removed: 2162283 bytes
    %systemroot%\System32 .tmp files removed: 2577 bytes
    Windows Temp folder emptied: 16384 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 52129282 bytes
    Total Files Cleaned = 247.00 mb
    OTLPE by OldTimer - Version 3.1.39.0 log created on 05162010_232119
  9. 2010/05/16
    Justmenyou
    No problem using gmer~
    GMER 1.0.15.15281 - http://www.gmer.net
    Rootkit scan 2010-05-17 00:57:32
    Windows 5.1.2600 Service Pack 3
    Running: t13o58b7.exe; Driver: C:\DOCUME~1\Kelly\LOCALS~1\Temp\kfliapod.sys
    ---- System - GMER 1.0.15 ----
    SSDT Lbd.sys (Boot Driver/Lavasoft AB) ZwCreateKey [0xF8A4087E]
    SSDT Lbd.sys (Boot Driver/Lavasoft AB) ZwSetValueKey [0xF8A40BFE]
    ---- Kernel code sections - GMER 1.0.15 ----
    .text ntoskrnl.exe!_abnormal_termination + F0 804E275C 1 Byte [7E]
    ---- Devices - GMER 1.0.15 ----
    AttachedDevice \Driver\Tcpip \Device\Ip avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
    AttachedDevice \Driver\Tcpip \Device\Tcp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
    AttachedDevice \Driver\Tcpip \Device\Tcp Lbd.sys (Boot Driver/Lavasoft AB)
    AttachedDevice \Driver\Tcpip \Device\Udp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
    AttachedDevice \Driver\Tcpip \Device\Udp Lbd.sys (Boot Driver/Lavasoft AB)
    AttachedDevice \Driver\Tcpip \Device\RawIp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
    AttachedDevice \Driver\Tcpip \Device\RawIp Lbd.sys (Boot Driver/Lavasoft AB)
    AttachedDevice \FileSystem\Fastfat \Fat fltmgr.sys (Microsoft Filesystem Filter Manager/Microsoft Corporation)
    ---- EOF - GMER 1.0.15 ----
  10. 2010/05/16
    It looks clean.
    Download Temp File Cleaner (TFC)
    Disable your antivirus program.
    Go to Kaspersky website and perform an online antivirus scan.
    1. Read through the requirements and privacy statement and click on Accept button.
    2. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
    3. When the downloads have finished, click on Settings.
    4. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
      [*] Archives
      [*] Mail databases
    5. Click on My Computer under Scan.
    6. Once the scan is complete, it will display the results. Click on View Scan Report.
    7. You will see a list of infected items there. Click on Save Report As....
    8. Save this report to a convenient place. Change the Files of type to Text file (.txt before clicking on the Save button. Then post it here.
    Post fresh HijackThis log as well.
  11. 2010/05/17
    Justmenyou
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Monday, May 17, 2010
    Operating system: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Monday, May 17, 2010 08:44:01
    Records in database: 4118241
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    Scan statistics:
    Objects scanned: 55599
    Threats found: 2
    Infected objects found: 4
    Suspicious objects found: 0
    Scan duration: 02:33:56
    File name / Threat / Threats count
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\20\110fbf54-74d6d8a1 Infected: Exploit.Java.Agent.f 1
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\33\35fae0a1-3c5bd5cb Infected: Exploit.Java.Agent.a 1
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\33\35fae0a1-3c5bd5cb Infected: Exploit.Java.Agent.f 1
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\54\445d036-18300673 Infected: Exploit.Java.Agent.f 1
    Selected area has been scanned.
  12. 2010/05/17
    Justmenyou
    Logfile of Trend Micro HijackThis v2.0.4
    Scan saved at 1:17:26 PM, on 17/05/2010
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    C:\WINDOWS\system32\HPZipm12.exe
    C:\PROGRA~1\AVG\AVG8\avgrsx.exe
    C:\PROGRA~1\AVG\AVG8\avgnsx.exe
    C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
    C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
    C:\PROGRA~1\AVG\AVG8\avgemc.exe
    C:\Program Files\Canon\CAL\CALMAIN.exe
    C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
    C:\Program Files\AVG\AVG8\avgcsrvx.exe
    C:\Program Files\Windows Live\Toolbar\wltuser.exe
    C:\Program Files\AVG\AVG8\avgtray.exe
    C:\Program Files\AVG\AVG8\avgui.exe
    C:\Program Files\Lavasoft\Ad-Aware\Ad-Aware.exe
    C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
    C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
    C:\Documents and Settings\Kelly\Local Settings\Temporary Internet Files\Content.IE5\G9L2PRF0\HiJackThis[1].exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://ca.yahoo.com
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ca.yahoo.com
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
    O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll
    O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\yt.dll
    O4 - HKLM\..\Run: [YSearchProtection] "C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe "
    O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
    O4 - HKCU\..\Run: [Search Protection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe
    O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office10\EXCEL.EXE/3000
    O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
    O20 - Winlogon Notify: avgrsstarter - avgrsstx.dll (file missing)
    O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
    O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
    O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
    O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
    O23 - Service: Google Update Service (gupdate) (gupdate) - Unknown owner - C:\Program Files\Google\Update\GoogleUpdate.exe (file missing)
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
    O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe
    O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
    O23 - Service: Yahoo! Updater (YahooAUService) - Yahoo! Inc. - C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
    End of file - 7289 bytes
  13. 2010/05/17
    Please download OTM
    • Save it to your desktop.
    • Please double-click OTM to run it. (Note: If you are running on Vista, right-click on the file and choose Run As Administrator).
    • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose Copy):
    :Processes
    :Services
    :Reg
    :Files
    :Commands
    [purity]
    [resethosts]
    [emptytemp]
    [Reboot]
    • Return to OTM, right click in the Paste Instructions for Items to be Movedwindow (under the yellow bar) and choose Paste.
    • Click the red Moveit! button.
    • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
    • Close OTM and reboot your PC.
    Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes. In this case, after the reboot, open Notepad (Start->All Programs->Accessories->Notepad), click File->Open, in the File Name box enter *.log and press the Enter key, navigate to the C:\_OTMoveIt\MovedFiles folder, and open the newest .log file present, and copy/paste the contents of that document back here in your next post.
    Verify your Java version here: http://www.java.com/en/download/installed.jsp
    Update, if necessary.
    Uninstall all previous Java versions, through Add\Remove (Programs & Features in Vista).
  14. 2010/05/17
    Justmenyou
    All processes killed
    ========== PROCESSES ==========
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\tmp folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\muffin folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\host folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\9 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\8 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\7 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\63 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\62 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\61 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\60 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\6 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\59 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\58 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\57 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\56 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\55 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\54 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\53 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\52 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\51 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\50 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\5 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\49 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\48 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\47 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\46 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\45 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\44 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\43 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\42 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\41 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\40 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\4 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\39 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\38 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\37 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\36 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\35 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\34 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\33 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\32 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\31 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\30 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\3 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\29 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\28 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\27 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\26 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\25 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\24 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\23 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\22 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\21 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\20 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\2 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\19 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\18 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\17 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\16 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\15 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\14 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\13 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\12 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\11 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\10 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\1 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\0 folder moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0 folder moved successfully.
    C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Default User
    User: Kelly
    ->Temp folder emptied: 107338122 bytes
    ->Temporary Internet Files folder emptied: 8756929 bytes
    ->Java cache emptied: 128020 bytes
    ->FireFox cache emptied: 0 bytes
    User: LocalService
    User: Spencer
    Windows Temp folder emptied: 0 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 111.00 mb
    OTM by OldTimer - Version 3.1.12.0 log created on 05172010_135722
    Files moved on Reboot...
  15. 2010/05/17
    Justmenyou
    Bless you for helping me so much, my gratitude is tenfold!!!
    No go on the Java, I got the original installer message again. If this computer has a poor outlook I can understand so please feel free to tell me to throw it the lake :)
  16. 2010/05/17
    By now, your computer is definitely malware free, so we must have some Windows issues.
    I'll mark this thread as resolved (malware-wise) and I suggest, you start new topic in Windows forum about your current issues
    You'll get more attention there. Access here is very limited (just you and me).
    Before you go there...
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  17. 2010/05/17
    Justmenyou
    Access here is very limited (just you and me) I must have had some insight when making my user name LOL Thank you for investing so much of your time for me. With gratitude towards you, I will 'pay it forward' to anyone that needs my help ♥
    Blessings!!!
  18. 2010/05/17
    I thought about very same thing...hehehe
  19. 2010/05/18
    Justmenyou
    Thank you so very much!!!
    Hello again Broni :) I am so happy to say everything is good to go!!! Just installed Java now defragmenting then my toads can play away. I read the sticky post above about protecting so this does not happen again. I updated AVG, as well as Adaware and just wanted to ask if you felt this was adequate. In the past I also ran spybot and Malwarebytes every couple of weeks.
    Second question is above when instructing me to download java and you also instructed me to remove all previous versions. Is this applicable to flash, quicktime, wmp, and even Microsoft updates like can I remove sp2 being I now have sp3?
    One more question recently someone told me I can make my computer work faster by allocating more ram from the hard drive. If so how do I do that, previously I got low memory warnings on occasion then more so after the infection.
    Thanks so so so much, blessings upon such a wonderful person extending themselves for others!!!
  20. 2010/05/18
    Basically, all applications should be kept up to date. I don't think, you can really remove SP2.
    Hard drive is much slower, than RAM, so the best course of action is to get more RAM, if you don't have enough.
    How much RAM do you have?
  21. 2010/05/18
    Justmenyou
    Thanks for replying :) So yes I can remove all previous versions of any add-ons as long as I am up-to-date.
    I have 640mb ram. I installed more then what it came with a few years ago when I updated my video card (For Sims lol My kids love that mommy is a gamer and now with my laptop and my 30th b-day present~ a wii they don't have to barter with me computer time). I was just hunting around and see you can now get gb for memory, how much is recommended? They will be mainly playing games on it.
    Also what browser do you recommend? I was using firefox but removed it after my uncle told me it was not good. Is it recommended to have just one browser or does that even matter?
