Need Help w/Seamonkey 1.1.2 Bookmarks Problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by njb, 2007/06/05.
  1. 2007/06/08
    Ramona
    Ramona Geek Member Alumni
    njb,
    Something in your Profile was corrupt, most likely your prefs.js file. Now that you have the problem corrected, make frequent backup copies of your entire Profiles folder. Then if a similar problem should occur, you can replace the prefs.js file with your backup first, before having to create a new Profile.
  2. 2007/06/08
    njb
    njb Inactive Thread Starter
    Thanks Raomona. The next time that will be my first action before doing anything else:)
    njb,
    #22
