Need Help Again for Virus's, Spyware, and Such.
Discussion in 'Malware and Virus Removal Archive' started by Pepse, 2008/01/27.
  1. 2008/02/04
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi Pepse
    Just navigate to the files and delete them.
    C:\WINNT\system32\Perflib_Perfdata_474.dat
    C:\WINNT\system32\Perflib_Perfdata_208.dat
    C:\WINNT\eraseme_51362.exe
    Go to your C Drive >WINNT >System32 folders and look for the files.
    Geri
  2. 2008/02/05
    Pepse
    Pepse Well-Known Member Thread Starter
    Well, I went there and I could only find and delete the C:\WINNT\eraseme_51362.exe file. The only file that comes close to those other 2 is C:\WINNT\system32\Perflib_Perfdata_200 . Any other ideas? I could cut and paste the C:\WINNT\system32 page if need be.
    Pepse.
    Hi Pepse
    OK, That's OK those files are not really bad ones. The eraseme_51362.exe was bad, good that it's gone.
    Please delete these.
    C:\WINNT\QTFont.qfn
    C:\WINNT\QTFont.for
    Then lets get a on-line scan.
    Please do an online scan with Kaspersky WebScanner
    Click on "Accept" If your pop "“up blocker blocks the ActiveX download, allow it, click on "Accept" again
    You will be promted to install an ActiveX component from Kaspersky, Click Yes or Install.
    • The program will launch and then begin downloading the latest definition files:
    • Once the files have been downloaded click on NEXT
    • Now click on Scan Settings
    • In the scan settings make that the following are selected:
      • Scan using the following Anti-Virus database:
      • Extended (if available otherwise Standard)
      • Scan Options:
      • Scan Archives
        Scan Mail Bases
    • Click OK
    • Now under select a target to scan:
      • Select My Computer
    • This will start the program and scan your system.
    • The scan will take a while so be patient and let it run.
    • Once the scan is complete it will display if your system has been infected.
      • Now click on the Save as Text button:
    • Save the file to your desktop.
    • Copy and paste that information in your next post.
    Geri
  5. 2008/02/06
    Pepse
    First thing to say before I post the scan log is of the 2 items to remove only C:\WINNT\QTFont.for was there and is removed. Here is the scan from Kapersky:
    KASPERSKY ONLINE SCANNER REPORT
    Wednesday, February 06, 2008 11:56:17 AM
    Operating System: Microsoft Windows 2000 Professional, Service Pack 4 (Build 2195)
    Kaspersky Online Scanner version: 5.0.98.0
    Kaspersky Anti-Virus database last update: 6/02/2008
    Kaspersky Anti-Virus database records: 550947
    Scan Settings:
    Scan using the following antivirus database: extended
    Scan Archives: true
    Scan Mail Bases: true
    Scan Target - My Computer:
    A:\
    C:\
    D:\
    Scan Statistics:
    Total number of scanned objects: 24084
    Number of viruses found: 3
    Number of infected objects: 3
    Number of suspicious objects: 0
    Duration of the scan process: 00:48:32
    Infected Object Name / Virus Name / Last Action
    C:\Documents and Settings\Administrator\Cookies\index.dat Object is locked skipped
    C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
    C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
    C:\Documents and Settings\Administrator\Local Settings\History\History.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\Administrator\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\Administrator\NTUSER.DAT Object is locked skipped
    C:\Documents and Settings\Administrator\ntuser.dat.LOG Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\aswResp.dat Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\Avast4.db Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\log\AshWebSv.ws Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\log\aswMaiSv.log Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\log\nshield.log Object is locked skipped
    C:\Program Files\Alwil Software\Avast4\DATA\report\Resident protection.txt Object is locked skipped
    C:\Program Files\Kodak\Kodak EasyShare software\bin\Catalog\EasyShare.me Object is locked skipped
    C:\Program Files\Kodak\Kodak EasyShare software\bin\Catalog\EasyShare.mm Object is locked skipped
    C:\QooBox\Quarantine\C\Program Files\Accessories\profsysyqu.html.vir Infected: Trojan-Clicker.HTML.IFrame.dn skipped
    C:\QooBox\Quarantine\C\Program Files\ISM\bndloader.exe.vir Infected: not-a-virus:Downloader.Win32.Agent.q skipped
    C:\QooBox\Quarantine\C\Program Files\QdrPack\QdrPack12.exe.vir Infected: not-a-virus:AdWare.Win32.Agent.adm skipped
    C:\WINNT\CSC\00000001 Object is locked skipped
    C:\WINNT\Debug\ipsecpa.log Object is locked skipped
    C:\WINNT\Debug\oakley.log Object is locked skipped
    C:\WINNT\Debug\PASSWD.LOG Object is locked skipped
    C:\WINNT\SoftwareDistribution\ReportingEvents.log Object is locked skipped
    C:\WINNT\Sti_Trace.log Object is locked skipped
    C:\WINNT\system32\config\Antivirus.Evt Object is locked skipped
    C:\WINNT\system32\config\AppEvent.Evt Object is locked skipped
    C:\WINNT\system32\config\default Object is locked skipped
    C:\WINNT\system32\config\default.LOG Object is locked skipped
    C:\WINNT\system32\config\SAM Object is locked skipped
    C:\WINNT\system32\config\SAM.LOG Object is locked skipped
    C:\WINNT\system32\config\SecEvent.Evt Object is locked skipped
    C:\WINNT\system32\config\SECURITY Object is locked skipped
    C:\WINNT\system32\config\SECURITY.LOG Object is locked skipped
    C:\WINNT\system32\config\software Object is locked skipped
    C:\WINNT\system32\config\software.LOG Object is locked skipped
    C:\WINNT\system32\config\SysEvent.Evt Object is locked skipped
    C:\WINNT\system32\config\system Object is locked skipped
    C:\WINNT\system32\config\SYSTEM.ALT Object is locked skipped
    C:\WINNT\system32\Perflib_Perfdata_204.dat Object is locked skipped
    C:\WINNT\Temp\_avast4_\Webshlock.txt Object is locked skipped
    C:\WINNT\WindowsUpdate.log Object is locked skipped
    Scan process completed.
  6. 2008/02/06
    Hi Pepse
    OK.
    The Kaspersky log is clean except fot this,
    This is the quarantine folder for Combofix, so lets get rid of it.
    Click Start>Run in the run box copy and paste or type ComboFix /u then hit Enter to uninstall ComboFix and remove the files/folders it created.
    Download ATF Cleaner by Atribune and save it to your Desktop.
    This is a good tool to get rid of the temporary garbage you pick up while surfing the net.
    Double click ATF-Cleaner.exe to run the program.
    Check the boxes to the left of:
    Windows Temp
    Current User Temp
    All Users Temp
    Prefetch
    Java Cache
    Recycle bin
    The rest are optional - if you want it to remove everything check "Select All ".
    Finally, click Empty Selected. When you get the "Done Cleaning" message, click OK.
    If there are no other problems then you can do the following.
    This would be a good time to set a new system restore point for your machine.
    Set New System Restore Point Windows XP. - Set New System Restore Point Windows Vista
    Do not do this unless there are no other user accounts to be diagnosed.
    If there are any other user accounts on this machine, they too, must be cleaned with AdAware and Spybot S&D. Not all infections are global, nor are all fixes global.
    Log onto that user account, Run HJT and save log, post each user account here into this thread, but please, do only one at a time to avoid confusion. Please let us know that it is a different account.
    Please look at this link for some preventive recommendations, It could keep you from ending up back here to the Spyware and Virus Removal Forms.
    http://www.windowsbbs.com/showthread.php?t=67958
    Surf Safely
    Geri
