My IE has gone crazy, please help !
Discussion in 'Internet Explorer & Microsoft Edge' started by gomcse, 2003/10/05.
  1. 2003/10/05
    gomcse
    gomcse Inactive Thread Starter
    Hello to all,
    The following is the text in the pop up when I click on Internet Explorer :
    “Microsoft Internet Explorer has encountered a problem & needs to close. We are sorry for the inconvenience.
    If you were in the middle of something, the information you were working on might be lost.
    [Box with check mark] restart Microsoft Internet Explorer.
    We have created an error report that you can send to help us improve Microsoft Internet Explorer. We will treat this report as confidential & anonymous.
    To see what data this error report contains click here
    Send Error Report Don’t Sendâ€
    Could you please advise how I can get rid of this annoyance because I can’t get into Internet Explorer.
    Thanks very much.
  2. 2003/10/05
    jerry4dos
    jerry4dos Inactive
    Have you tried to REPAIR Internet Explorer? Use the ADD/REMOVE programs icon in the MY COMPUTER CONTROL PANEL.
    Which version of IE and what OS? The repair function differs in XP from other OS's
  5. 2003/10/05
    Johanna
    Johanna Inactive Alumni
    Do NOT try to repair IE with XP. JMO! :D
    Johanna
  6. 2003/10/05
    gomcse
    Hello to all,
    Thanks for all your prompt replies and it work now.
    Thanks again for your help !
  7. 2003/10/14
    JamesOne
    JamesOne Inactive
    I have the identical problem gomcse had. It sounds like he was able to fix it but I have been unable to. Can someone help me. I have IE v6.0 and Windows XP home.
    James
  8. 2003/10/14
    Lonny Jones
    Lonny Jones Inactive Alumni
    James
    when that happens ,use the click here then the moreinfo
    or detailed info(cant remember what its called)
    and write down the dll or exe ,ocx what ever it is ,
    there should be two mentioed
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;276550
    then post them here for us to see
    also describe any other problems even if they seam unrelated
    Lonny
  9. 2003/10/14
    JamesOne
    JamesOne Inactive
    Lonny, as requested:
    Error signature
    AppName: iexplore.exe
    AppVer: 6.0.2800.1106
    ModName: unknown
    ModVer: 0.0.0.0
    Offset: 033b5540
    James
  10. 2003/10/14
    Lonny Jones
    There should have been more than that ?
    search your pc for a file called "dw.log "
    and post the info partaining t the date the error uccured
    ie the latest one.Might as well post two of them we dont need all the extra content just the exe's dll's or what haveyou
    since you posted back so fast I wonder ,, how often they happen?
    and if you can repet them by doing the same things,,
    Meanwhile I dont know XP very well , so give it some time and those who do will get with..You post after posting what I asked for
    Here is one of mine as an example(usualy there not much to worry about.
    Application Failure iexplore.exe 6.0.2800.1106 in mshtml.dll
    Lonny
  11. 2003/10/14
    JamesOne
    JamesOne Inactive
    I have no file on my computer named "dw.log ".
    You asked how often I get this error. I get it everytime I use IE. Sometimes it closes down IE and sometimes it doesn't. I have had to install Netscape to use as a browser.
    You mentioned that there should be more information provided. There is a link that I can click on when I get the error called "To view technical information about the error report, click here "
    When I do that a gadzillion lines of information appear.
    James
  12. 2003/10/14
    Lonny Jones
    Sorry for the misinformation, "dw.log ". exists as far as I know one all win 9x systems I was hoping it would to on XP.
    Till the XP people get with,, you can search (look around there is tons and tons of info here)
    And cleanup your PC
    Even if your current av program is up to date and you Have run a full system SCAN ??? Have you ?
    also get one online scan
    there are several to choose from,, stay away from your av's online as it would be possible the same
    So get a second opinion
    also have you ran either SpyBot or Adaware Both have a free
    version the second one mentioned being for beginners to intermediate PC user the first for advanced. I use them both.
    Links are in below and In my Sig
    Trend AntiVirus: http://housecall.antivirus.com
    Command AntiVirus: http://www.commandondemand.com/eval/index.cfm
    Symantec: http://security2.norton.com/ssc/home.asp
    Lonny
