Solved msnmsgr.exe
Discussion in 'Malware and Virus Removal Archive' started by TexasStormChase, 2007/09/15.
  1. 2007/09/16
    TexasStormChase
    TexasStormChase Inactive Thread Starter
    Did that and it came up with a warning thats said this action is only vaild for products that are curently instaled. Forgive the spelling.
  2. 2007/09/16
    noahdfear
    noahdfear Inactive
    Please click Start>Run and type regedit then hit enter. Navigate to the following key by clicking the corresponding + signs.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
    Click the + sign on the Uninstall key, then see if you have a key named
    {571700F0-DB9D-4B3A-B03D-35A14BB5939F}
    If so, click on it, then look at the UninstallString value. Does it match the one you just used from the Run line? Does the DisplayName value show it as Windows Live Messenger?
    TexasStormChase
    That key was not there. :(
  5. 2007/09/16
    noahdfear
    noahdfear Inactive
    Click on the first subkey under the Uninstall key, then look at the DisplayName value in the right pane. You need to find Windows Live Messenger. Use your down arrow key to scroll down the list of subkeys. Let me know when/if you find it.
  6. 2007/09/16
    TexasStormChase
    I looked under all the sub keys under uninstal and nothing for windows live or msn
  7. 2007/09/16
    noahdfear
    noahdfear Inactive
    This is very odd. Click on the uppermost entry in the regedit tree, My Computer. Then click Edit>Find.
    Copy the string below and paste it in, then hit enter.
    When it stops at a key or value, right click the key and select Copy Key Name. Open a blank notepad, then right click>Paste.
    Pressing Enter or F3 repeatedly will advanced Find to the next instance. Repeat the copy name procedure.
    *In the event that a value is found and highlighted, it's difficult to tell which key it's under. Look at the bottom left of the window frame, the Status Bar, for the current path.
    Once you are prompted that it's finished searching the registry, post the contents of the notepad.
  8. 2007/09/16
    TexasStormChase
    C:\WINDOWS\Installer\{571700F0-DB9D-4B3A-B03D-35A14BB5939F}\MsblIco.Exe
    It only found 1.
  9. 2007/09/16
    noahdfear
    noahdfear Inactive
    You needed to be doing that search within the registry editor. At the top of the directory tree in the left pane is My Computer.
  10. 2007/09/16
    TexasStormChase
    Hopfully I got it this time it only found one agine
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{571700F0-DB9D-4B3A-B03D-35A14BB5939F}
  11. 2007/09/16
    noahdfear
    noahdfear Inactive
    Getting stranger all the time :rolleyes:
    I need to review a bit. Please answer yes or no to each.
    1. Add/Remove programs lists Windows Live Messenger?
    2. Selecting the entry in Add/Remove will not do anything.
    3. You cannot delete the contents of the Windows Live folder? (don't try again)
    4. Is Messenger still working?
    5. You still have ComboFix?
    Please post a fresh HijackThis log.
  12. 2007/09/16
    TexasStormChase
    1. Yes
    2. Yes
    3. Yes
    4. Yes
    5. Yes
  13. 2007/09/16
    TexasStormChase
    HiJack log file
    Scan saved at 2:56:52 PM, on 9/16/2007
    MSIE: Internet Explorer v7.00 (7.00.6000.16512)
    c:\program files\common files\logitech\lvmvfm\LVPrcSrv.exe
    C:\HP\KBD\KBD.EXE
    C:\WINDOWS\system32\LVCOMSX.EXE
    C:\WINDOWS\system32\ElkCtrl.exe
    C:\PROGRA~1\Grisoft\AVG7\avgcc.exe
    C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
    C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe
    C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
    C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
    C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
    C:\Program Files\MSN Messenger\msnmsgr.exe
    C:\Program Files\MSN Messenger\msvs.exe
    C:\WINDOWS\system32\msiexec.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr8/*http://www.yahoo.com
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr8/*http://www.yahoo.com/ext/search/search.html
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/customize/ycomp/defaults/su/*http://www.yahoo.com
    R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
    O1 - Hosts: 216.19.0.250 idenupdate.motorola.com
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: Malicious Scripts Scanner - {55EA1964-F5E4-4D6A-B9B2-125B37655FCB} - C:\Documents and Settings\All Users\Application Data\Prevx\pxbho.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - (no file)
    O2 - BHO: (no name) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - (no file)
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn0\yt.dll
    O3 - Toolbar: (no name) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - (no file)
    O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
    O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
    O4 - HKLM\..\Run: [LVCOMSX] C:\WINDOWS\system32\LVCOMSX.EXE
    O4 - HKLM\..\Run: [LogitechCameraService(E)] C:\WINDOWS\system32\ElkCtrl.exe /automation
    O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVG7\avgcc.exe /STARTUP
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe "
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [DriverMagicLogon] "C:\Program Files\SymplisIT\DriverMagic\dmschedule.exe" /boot
    O4 - HKLM\..\Run: [PrevxOne] "C:\Program Files\Prevx2\PXConsole.exe "
    O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
    O4 - HKCU\..\Run: [P2kAutostart] C:\Documents and Settings\Owner\My Documents\Moto V3R\p2k-commander_3.3\p2k-commander 3.3.0 Beta\P2kAutostart.exe
    O4 - HKCU\..\Run: [Yahoo! Pager] "C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" -quiet
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKUS\S-1-5-19\..\Run: [AVG7_Run] C:\PROGRA~1\Grisoft\AVG7\avgw.exe /RUNONCE (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [AVG7_Run] C:\PROGRA~1\Grisoft\AVG7\avgw.exe /RUNONCE (User 'NETWORK SERVICE')
    O4 - HKUS\S-1-5-18\..\Run: [AVG7_Run] C:\PROGRA~1\Grisoft\AVG7\avgw.exe /RUNONCE (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [AVG7_Run] C:\PROGRA~1\Grisoft\AVG7\avgw.exe /RUNONCE (User 'Default user')
    O4 - .DEFAULT User Startup: AutoPlay.exe (User 'Default user')
    O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~1\Office12\EXCEL.EXE/3000
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
    O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~1\Office12\ONBttnIE.dll
    O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~1\Office12\ONBttnIE.dll
    O9 - Extra button: PalTalk - {4EAFEF58-EEFA-4116-983D-03B49BCBFFFE} - C:\Program Files\Paltalk Messenger\Paltalk.exe (file missing)
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~1\Office12\REFIEBAR.DLL
    O9 - Extra button: Trend Micro Security Services - {D5E1CDC8-64B9-4f8c-8155-FC3B6D6749F7} - http://tmss.trendmicro.com/dashboard/dashboard.aspx?EHAACHHDAADFCCJDFFBIIGJBEGHHEGFBBBHIE (file missing)
    O9 - Extra 'Tools' menuitem: Trend Micro Security Services - {D5E1CDC8-64B9-4f8c-8155-FC3B6D6749F7} - http://tmss.trendmicro.com/dashboard/dashboard.aspx?EHAACHHDAADFCCJDFFBIIGJBEGHHEGFBBBHIE (file missing)
    O9 - Extra button: Run IMVU - {d9288080-1baa-4bc4-9cf8-a92d743db949} - C:\Documents and Settings\Owner\Start Menu\Programs\IMVU\Run IMVU.lnk
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\WINDOWS\System32\shdocvw.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\WINDOWS\System32\shdocvw.dll
    O9 - Extra button: @C:\Program Files\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O9 - Extra 'Tools' menuitem: @C:\Program Files\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O15 - Trusted Zone: http://www.amandastable.com
    O16 - DPF: {01016526-5E80-11D8-9E86-0007E96C65AE} (SmartAccess Ctl Class) - https://install.charter.com/diskless/bin/ssctlsma.dll
    O16 - DPF: {02AA9E0F-B4EB-4BE9-A769-FD09543FEEC2} (UniInstaller Class) - http://webcamnow.com/fs5/voice/voice-installer.cab
    O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} - http://qtinstall.info.apple.com/qtactivex/QTPlugin.cab
    O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
    O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/english/kavwebscan_unicode.cab
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
    O16 - DPF: {200B3EE9-7242-4EFD-B1E4-D97EE825BA53} (VerifyGMN Class) - http://h20270.www2.hp.com/ediags/gmn/install/hpobjinstaller_gmn.cab
    O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/yinst20040510.cab
    O16 - DPF: {410A8B3C-7CCB-40E8-8B11-28B099E5C488} (Trend Micro Security Services Control) - http://tmss.trendmicro.com/Dashboard/controls/activex_11/en-US/TMSSReportW.CAB
    O16 - DPF: {49232000-16E4-426C-A231-62846947304B} - http://ipgweb.cce.hp.com/rdqcpc/downloads/sysinfo.cab
    O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://by107fd.bay107.hotmail.msn.com/resources/MsnPUpld.cab
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1137113942564
    O16 - DPF: {74C861A1-D548-4916-BC8A-FDE92EDFF62C} - http://mediaplayer.walmart.com/installer/install.cab
    O16 - DPF: {7B297BFD-85E4-4092-B2AF-16A91B2EA103} (WScanCtl Class) - http://www.ca.com/us/securityadvisor/virusinfo/webscan.cab
    O16 - DPF: {9732FB42-C321-11D1-836F-00A0C993F125} (mhLabel Class) - http://www.pcpitstop.com/mhLbl.cab
    O16 - DPF: {9CCE3B43-4DE0-4236-A84E-108CA848EE6A} (WebCam Control) - http://webcamnow.com/fs5/ax/ActiveXWebCam.cab
    O16 - DPF: {AB86CE53-AC9F-449F-9399-D8ABCA09EC09} (Get_ActiveX Control) - https://h17000.www1.hp.com/ewfrf-JAVA/Secure/HPGetDownloadManager.ocx
    O16 - DPF: {AF2E62B6-F9E1-4D4F-A10A-9DC8E6DCBCC0} - http://update.videoegg.com/Install/Windows/Initial/VideoEggPublisher.exe
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {E8F628B5-259A-4734-97EE-BA914D7BE941} (Driver Agent ActiveX Control) - http://www.driveragent.com/files/driveragent.cab
    O16 - DPF: {FFFFFFFF-CACE-BABE-BABE-00AA0055595A} - http://www.trueswitch.com/sbc/TrueInstallSBC.exe
    O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
    O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
    O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: Logitech Process Monitor (LVPrcSrv) - Logitech Inc. - c:\program files\common files\logitech\lvmvfm\LVPrcSrv.exe
    O23 - Service: PREVXAgent - Prevx - C:\Program Files\Prevx2\PXAgent.exe
    End of file - 10628 bytes
    Msn messenger was not turned on but it is showing as running
  14. 2007/09/16
    noahdfear
    noahdfear Inactive
    Out of curiosity, did the problem with messenger begin before or after you installed IMVU?
    OK, if you're up for it, we're going to rip out Windows Live Messenger. Proceed as follows if your willing.
    First we need to disable Spybot's TeaTimer.
    • Open Spybot Search & Destroy.
    • In the Mode menu click "Advanced mode" if not already selected.
    • Choose "Yes" at the Warning prompt.
    • Expand the "Tools" menu.
    • Click "Resident ".
    • Uncheck the "Resident "TeaTimer" (Protection of overall system settings) active." box.
    • In the File menu click "Exit" to exit Spybot Search & Destroy.
    Reboot.
    Copy the following bolded command.
    sc stop WLSetupSvc
    Click Start>Run and paste it in, then hit enter.
    Now copy the next one and paste it in then hit enter.
    sc delete WLSetupSvc
    Scan again with HijackThis and place a check next to the following entries, close all other windows then click Fix Checked.
    Close HijackThis.
    Copy the contents of the code box below and paste it into a blank notepad, then save it to your desktop as;
    Filename: CFScript.txt
    Save As Type: All Files (*.*)
    Folder::
    C:\Program Files\Windows Live\Messenger
    Registry::
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
     "Usnsvc "=-
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button. Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log and a fresh HijackThis log.
    Please do not click on the ComboFix window while it is running a scan. This can cause it to stall.
  15. 2007/09/16
    TexasStormChase
    Combofix
    ComboFix 07-09-14.2 - "Owner" 2007-09-16 15:55:32.4 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.189 [GMT -5:00]
    Command switches used :: C:\Documents and Settings\Owner\Desktop\CFScript.txt
    * Created a new restore point
    C:\Program Files\Windows Live\Messenger\msnmsgr.zip
    ((((((((((((((((((((((((( Files Created from 2007-08-16 to 2007-09-16 )))))))))))))))))))))))))))))))
    2007-09-15 23:18 <DIR> d-------- C:\BackUpMSNCleaner
    2007-09-15 21:55 <DIR> d-------- C:\WINDOWS\SYSTEM32\Kaspersky Lab
    2007-09-15 21:55 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Kaspersky Lab
    2007-09-15 21:18 <DIR> d-------- C:\Deckard
    2007-09-15 20:18 51,200 --a------ C:\WINDOWS\NirCmd.exe
    2007-09-15 19:34 <DIR> d-------- C:\DOCUME~1\Owner\APPLIC~1\Prevx
    2007-09-15 19:31 <DIR> d-------- C:\Program Files\Prevx2
    2007-09-15 19:31 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Prevx
    2007-09-15 18:09 <DIR> d-------- C:\DOCUME~1\Owner\APPLIC~1\Google
    2007-09-15 18:01 <DIR> d-------- C:\Program Files\Google
    2007-09-15 18:01 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Google
    2007-09-15 18:00 626,688 --a------ C:\WINDOWS\SYSTEM32\msvcr80.dll
    2007-09-14 12:38 <DIR> d-------- C:\Program Files\IMVU
    2007-09-05 20:23 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\F-Secure
    2007-09-05 20:21 <DIR> d-------- C:\Program Files\Charter High-Speed Security Suite
    2007-09-05 20:20 <DIR> d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\fssg
    2007-09-05 14:44 <DIR> d-------- C:\Program Files\Common Files\SupportSoft
    2007-09-05 14:44 <DIR> d-------- C:\Program Files\CHARTER
    2007-08-23 07:29 <DIR> d-------- C:\Program Files\Common Files\xing shared
    2007-08-16 16:17 51,568 --a------ C:\WINDOWS\SYSTEM32\sirenacm.dll
    2007-09-16 15:59 --------- d-------- C:\Program Files\Windows Live
    2007-09-16 15:47 --------- d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Spybot - Search & Destroy
    2007-09-16 14:54 --------- d-------- C:\Program Files\MSN Messenger
    2007-09-16 13:48 --------- d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller
    2007-09-16 13:38 --------- d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\WLInstaller
    2007-09-15 19:55 --------- d-------- C:\Program Files\Trend Micro
    2007-09-14 13:04 --------- d-------- C:\DOCUME~1\Owner\APPLIC~1\IMVU
    2007-09-05 20:12 --------- d-------- C:\Program Files\Yahoo!
    2007-09-05 20:12 --------- d-------- C:\Program Files\Common Files\Scanner
    2007-08-23 07:31 --------- d-------- C:\DOCUME~1\Owner\APPLIC~1\Real
    2007-08-23 07:28 --------- d-------- C:\Program Files\Real
    2007-08-23 07:27 --------- d-------- C:\Program Files\Common Files\Real
    2007-08-15 07:51 --------- d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Microsoft Help
    2007-07-30 19:19 92504 --a------ C:\WINDOWS\SYSTEM32\dllcache\cdm.dll
    2007-07-30 19:19 92504 --a------ C:\WINDOWS\SYSTEM32\cdm.dll
    2007-07-30 19:19 549720 --a------ C:\WINDOWS\SYSTEM32\wuapi.dll
    2007-07-30 19:19 549720 --a------ C:\WINDOWS\SYSTEM32\dllcache\wuapi.dll
    2007-07-30 19:19 53080 --a------ C:\WINDOWS\SYSTEM32\wuauclt.exe
    2007-07-30 19:19 53080 --a------ C:\WINDOWS\SYSTEM32\dllcache\wuauclt.exe
    2007-07-30 19:19 43352 --a------ C:\WINDOWS\SYSTEM32\wups2.dll
    2007-07-30 19:19 325976 --a------ C:\WINDOWS\SYSTEM32\wucltui.dll
    2007-07-30 19:19 325976 --a------ C:\WINDOWS\SYSTEM32\dllcache\wucltui.dll
    2007-07-30 19:19 271224 --a------ C:\WINDOWS\SYSTEM32\mucltui.dll
    2007-07-30 19:19 207736 --a------ C:\WINDOWS\SYSTEM32\muweb.dll
    2007-07-30 19:19 203096 --a------ C:\WINDOWS\SYSTEM32\wuweb.dll
    2007-07-30 19:19 203096 --a------ C:\WINDOWS\SYSTEM32\dllcache\wuweb.dll
    2007-07-30 19:19 1712984 --a------ C:\WINDOWS\SYSTEM32\wuaueng.dll
    2007-07-30 19:19 1712984 --a------ C:\WINDOWS\SYSTEM32\dllcache\wuaueng.dll
    2007-07-30 19:18 33624 --a------ C:\WINDOWS\SYSTEM32\wups.dll
    2007-07-30 19:18 33624 --a------ C:\WINDOWS\SYSTEM32\dllcache\wups.dll
    2007-07-21 21:43 --------- d--h----- C:\Program Files\InstallShield Installation Information
    2007-07-21 21:43 --------- d-------- C:\Program Files\QuickTime
    2007-07-21 20:20 --------- d-------- C:\Program Files\SymplisIT
    2007-07-19 01:59 3583488 --a------ C:\WINDOWS\SYSTEM32\dllcache\mshtml.dll
    2007-07-12 18:31 765952 --a------ C:\WINDOWS\SYSTEM32\dllcache\vgx.dll
    2007-06-27 09:34 823808 --a------ C:\WINDOWS\SYSTEM32\dllcache\wininet.dll
    2007-06-27 09:34 671232 --a------ C:\WINDOWS\SYSTEM32\dllcache\mstime.dll
    2007-06-27 09:34 6058496 --------- C:\WINDOWS\SYSTEM32\dllcache\ieframe.dll
    2007-06-27 09:34 52224 --------- C:\WINDOWS\SYSTEM32\dllcache\msfeedsbs.dll
    2007-06-27 09:34 477696 --a------ C:\WINDOWS\SYSTEM32\dllcache\mshtmled.dll
    2007-06-27 09:34 459264 --------- C:\WINDOWS\SYSTEM32\dllcache\msfeeds.dll
    2007-06-27 09:34 44544 --a------ C:\WINDOWS\SYSTEM32\dllcache\iernonce.dll
    2007-06-27 09:34 384512 --a------ C:\WINDOWS\SYSTEM32\dllcache\iedkcs32.dll
    2007-06-27 09:34 383488 --------- C:\WINDOWS\SYSTEM32\dllcache\ieapfltr.dll
    2007-06-27 09:34 27648 --a------ C:\WINDOWS\SYSTEM32\dllcache\jsproxy.dll
    2007-06-27 09:34 267776 --------- C:\WINDOWS\SYSTEM32\dllcache\iertutil.dll
    2007-06-27 09:34 232960 --a------ C:\WINDOWS\SYSTEM32\dllcache\webcheck.dll
    2007-06-27 09:34 230400 --a------ C:\WINDOWS\SYSTEM32\dllcache\ieaksie.dll
    2007-06-27 09:34 193024 --a------ C:\WINDOWS\SYSTEM32\dllcache\msrating.dll
    2007-06-27 09:34 153088 --a------ C:\WINDOWS\SYSTEM32\dllcache\ieakeng.dll
    2007-06-27 09:34 132608 --a------ C:\WINDOWS\SYSTEM32\dllcache\extmgr.dll
    2007-06-27 09:34 124928 --a------ C:\WINDOWS\SYSTEM32\dllcache\advpack.dll
    2007-06-27 09:34 1152000 --a------ C:\WINDOWS\SYSTEM32\dllcache\urlmon.dll
    2007-06-27 09:34 105984 --a------ C:\WINDOWS\SYSTEM32\dllcache\url.dll
    2007-06-27 09:34 102400 --a------ C:\WINDOWS\SYSTEM32\dllcache\occache.dll
    2007-06-27 03:27 63488 --a------ C:\WINDOWS\SYSTEM32\dllcache\ie4uinit.exe
    2007-06-27 03:27 625152 --a------ C:\WINDOWS\SYSTEM32\dllcache\iexplore.exe
    2007-06-27 03:27 13824 --------- C:\WINDOWS\SYSTEM32\dllcache\ieudinit.exe
    2007-06-27 02:00 161792 --a------ C:\WINDOWS\SYSTEM32\dllcache\ieakui.dll
    2007-06-26 22:10 317440 --a------ C:\WINDOWS\SYSTEM32\dllcache\unregmp2.exe
    2007-06-26 01:08 1104896 --a------ C:\WINDOWS\SYSTEM32\msxml3.dll
    2007-06-26 01:08 1104896 --a------ C:\WINDOWS\SYSTEM32\dllcache\msxml3.dll
    2007-06-19 08:31 282112 --a------ C:\WINDOWS\SYSTEM32\gdi32.dll
    2007-06-19 08:31 282112 --a------ C:\WINDOWS\SYSTEM32\dllcache\gdi32.dll
    2007-02-01 13:09 9232 --a------ C:\DOCUME~1\Owner\mqdmmdfl.sys
    2007-02-01 13:09 92064 --a------ C:\DOCUME~1\Owner\mqdmmdm.sys
    2007-02-01 13:09 79328 --a------ C:\DOCUME~1\Owner\mqdmserd.sys
    2007-02-01 13:09 66656 --a------ C:\DOCUME~1\Owner\mqdmbus.sys
    2007-02-01 13:09 6208 --a------ C:\DOCUME~1\Owner\mqdmcmnt.sys
    2007-02-01 13:09 5936 --a------ C:\DOCUME~1\Owner\mqdmwhnt.sys
    2007-02-01 13:09 4048 --a------ C:\DOCUME~1\Owner\mqdmcr.sys
    2007-02-01 13:09 25600 --a------ C:\DOCUME~1\Owner\usbsermptxp.sys
    2007-02-01 13:09 22768 --a------ C:\DOCUME~1\Owner\usbsermpt.sys
    2006-02-01 17:48 218112 --a------ C:\Program Files\HijackThis.exe
    2006-02-01 17:33 212849 --a------ C:\Program Files\hijackthis.zip
    ((((((((((((((((((((((((((((( snapshot_2007-09-15_203230.35 )))))))))))))))))))))))))))))))))))))))))
    ----a-w 300,680 2007-03-06 23:59:11 C:\WINDOWS\Downloaded Program Files\arclib.dll
    ----a-w 9,389,832 2007-07-17 02:44:47 C:\WINDOWS\Downloaded Program Files\vet.dat
    ----a-w 1,353,016 2007-07-13 04:11:05 C:\WINDOWS\Downloaded Program Files\vete.dll
    ----a-w 180,282 2006-11-20 17:02:34 C:\WINDOWS\Downloaded Program Files\webscan.dll
    ----a-r 29,926 2007-09-16 18:43:42 C:\WINDOWS\Installer\{508CE775-4BA4-4748-82DF-FE28DA9F03B0}\MsblIco.Exe
    ----a-w 17,215,856 2007-08-31 17:23:40 C:\WINDOWS\SoftwareDistribution\Download\Install\MU_WLMessenger.exe
    ----a-w 213,048 2005-05-24 16:27:16 C:\WINDOWS\SYSTEM32\Kaspersky Lab\Kaspersky Online Scanner\kavss.dll
    ----a-w 94,208 2007-09-07 16:29:00 C:\WINDOWS\SYSTEM32\Kaspersky Lab\Kaspersky Online Scanner\kavuninstall.exe
    ----a-w 946,176 2007-09-07 16:29:00 C:\WINDOWS\SYSTEM32\Kaspersky Lab\Kaspersky Online Scanner\kavwebscan.dll
    "KBD "= "C:\HP\KBD\KBD.EXE" [2005-02-02 17:44]
    "PS2 "= "C:\WINDOWS\system32\ps2.exe" [2004-10-25 16:17]
    "LVCOMSX "= "C:\WINDOWS\system32\LVCOMSX.EXE" [2005-12-09 15:32]
    "LogitechCameraService(E) "= "C:\WINDOWS\system32\ElkCtrl.exe" [2004-11-01 17:22]
    "AVG7_CC "= "C:\PROGRA~1\Grisoft\AVG7\avgcc.exe" [2007-09-14 08:42]
    "SunJavaUpdateSched "= "C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe" [2007-07-12 04:00]
    "Adobe Reader Speed Launcher "= "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-05-11 03:06]
    "DriverMagicLogon "= "C:\Program Files\SymplisIT\DriverMagic\dmschedule.exe" [2005-10-14 09:01]
    "TkBellExe "= "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" [2007-08-23 07:26]
    "PrevxOne "= "C:\Program Files\Prevx2\PXConsole.exe" [2007-09-14 15:03]
    "ISUSPM "= "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" [2006-09-11 04:40]
    "ctfmon.exe "= "C:\WINDOWS\system32\ctfmon.exe" [2004-08-04 02:56]
    "P2kAutostart "= "C:\Documents and Settings\Owner\My Documents\Moto V3R\p2k-commander_3.3\p2k-commander 3.3.0 Beta\P2kAutostart.exe" []
    "Yahoo! Pager "= "C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" [2007-03-27 15:22]
    "SpybotSD TeaTimer "= "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [2007-08-31 16:46]
    C:\DOCUME~1\ALLUSE~1\STARTM~1\Programs\Startup\
    WinZip Quick Pick.lnk - C:\Program Files\WinZip\WZQKPICK.EXE [2007-09-16 10:19:06]
    C:\DOCUME~1\ADMINI~1\STARTM~1\Programs\Startup\
    AutoPlay.exe [2001-09-17 14:22:52]
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
    "NoDispBackgroundPage "=0 (0x0)
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
    backup=C:\WINDOWS\pss\Adobe Reader Speed Launch.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^AT&T Self Support Tool.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\AT&T Self Support Tool.lnk
    backup=C:\WINDOWS\pss\AT&T Self Support Tool.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
    backup=C:\WINDOWS\pss\HP Digital Imaging Monitor.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Image Zone Fast Start.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Image Zone Fast Start.lnk
    backup=C:\WINDOWS\pss\HP Image Zone Fast Start.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^SlipStream.lnk]
    path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\SlipStream.lnk
    backup=C:\WINDOWS\pss\SlipStream.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^OneNote 2007 Screen Clipper and Launcher.lnk]
    path=C:\Documents and Settings\Owner\Start Menu\Programs\Startup\OneNote 2007 Screen Clipper and Launcher.lnk
    backup=C:\WINDOWS\pss\OneNote 2007 Screen Clipper and Launcher.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^SpywareGuard.lnk]
    path=C:\Documents and Settings\Owner\Start Menu\Programs\Startup\SpywareGuard.lnk
    backup=C:\WINDOWS\pss\SpywareGuard.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^TrueAssistant.lnk]
    path=C:\Documents and Settings\Owner\Start Menu\Programs\Startup\TrueAssistant.lnk
    backup=C:\WINDOWS\pss\TrueAssistant.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Aim6]
    "C:\Program Files\Common Files\AOL\Launch\AOLLaunch.exe" /d locale=en-US ee://aol/imApp
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BitTorrent]
    "C:\Program Files\BitTorrent\bittorrent.exe" --force_start_minimized
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BMUpdate]
    C:\WINDOWS\System32\BMUpdate.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HDDHealth]
    C:\Program Files\HDD Health\hddhealth.exe -wl
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HostManager]
    C:\Program Files\Common Files\AOL\1139540311\ee\AOLSoftware.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HotKeysCmds]
    C:\WINDOWS\System32\hkcmd.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
    C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\hpsysdrv]
    c:\windows\system\hpsysdrv.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IgfxTray]
    C:\WINDOWS\System32\igfxtray.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMC]
    C:\Program Files\FriendFinder\FriendFinder Messenger 30\imc.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IPHSend]
    C:\Program Files\Common Files\AOL\IPHSend\IPHSend.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\KBD]
    C:\HP\KBD\KBD.EXE
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LogitechCameraAssistant]
    C:\Program Files\Logitech\Video\CameraAssistant.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LogitechVideo[inspector]]
    C:\Program Files\Logitech\Video\InstallHelper.exe /inspect
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MCAgentExe]
    c:\PROGRA~1\mcafee.com\agent\McAgent.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MCUpdateExe]
    c:\PROGRA~1\mcafee.com\agent\mcupdate.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Works Update Detection]
    c:\Program Files\Microsoft Works\WkDetect.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Motive SmartBridge]
    C:\PROGRA~1\SBCSEL~1\SMARTB~1\MotiveSB.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSKAGENTEXE]
    C:\PROGRA~1\McAfee\SPAMKI~1\MSKAgent.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
    "C:\Program Files\Messenger\Msmsgs.exe" /background
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MySpaceIM]
    C:\Program Files\MySpace\IM\MySpaceIM.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MyWebSearch Email Plugin]
    C:\PROGRA~1\MYWEBS~1\bar\2.bin\mwsoemon.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
    C:\WINDOWS\system32\NeroCheck.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
    RUNDLL32.EXE NvQTwk,NvCplDaemon initialize
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PhotoShow Deluxe Media Manager]
    C:\PROGRA~1\Nero\data\Xtras\mssysmgr.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ProfileWatcher]
    C:\Program Files\ProfileWatcher\profilewatcher.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PS2]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
    "C:\Program Files\QuickTime\qttask.exe" -atboottime
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Recguard]
    C:\WINDOWS\SMINST\RECGUARD.EXE
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\S3TRAY2]
    S3tray2.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Skype]
    "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SlipStream]
    "C:\Program Files\SlipStream Web Accelerator\slipcore.exe "
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
    C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TkBellExe]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Uniblue Registry Booster2]
    C:\Program Files\Uniblue\RegistryBooster2\RegistryBooster.exe /S
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\updateMgr]
    "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_8 -reboot 1
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Yahoo! Pager]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
    "NVSvc "=2 (0x2)
    "ImapiService "=3 (0x3)
    "Fax "=2 (0x2)
    "Pctspk "=2 (0x2)
    "LexBceS "=2 (0x2)
    "AVGEMS "=2 (0x2)
    "Avg7UpdSvc "=2 (0x2)
    "Avg7Alrt "=2 (0x2)
    R0 PrevxDriver;PREVX Kernel Mode Agent;C:\WINDOWS\system32\DRIVERS\pxfsf.sys
    R1 PREVXTdi;PREVX TDI filter;C:\WINDOWS\system32\DRIVERS\pxtdi.sys
    R1 PXRDDriver;PREVX Rootkitscan driver;C:\WINDOWS\system32\DRIVERS\pxrd.sys
    R3 LVPrcMon;Logitech LVPrcMon Driver;\??\C:\WINDOWS\system32\drivers\LVPrcMon.sys
    R3 Ptserlp;PCTEL Serial Device Driver for PCI;C:\WINDOWS\system32\DRIVERS\ptserlp.sys
    S0 black;black;C:\WINDOWS\system32\drivers\BlackDrv.sys
    S3 BLKWGD;Belkin Wireless G Desktop Card Service;C:\WINDOWS\system32\DRIVERS\BLKWGD.sys
    S3 BVRPMPR5;BVRPMPR5 NDIS Protocol Driver;\??\D:\INSTAL~E\Core\BVRPMPR5.SYS
    S3 DCamUSBVeo532;Veo Web Camera;C:\WINDOWS\system32\Drivers\ubVeo532.sys
    S3 PCDRDRV;Pcdr CPU Helper Driver;C:\WINDOWS\system32\drivers\PCDRDRV.sys
    S3 PREVXEmulator;PREVX Emulator driver;C:\WINDOWS\system32\DRIVERS\PxEmu.sys
    S3 RapFile;RapFile;\??\C:\WINDOWS\system32\drivers\RapFile.sys
    S3 RapNet;RapNet;\??\C:\WINDOWS\system32\drivers\RapNet.sys
    S3 wlanndi5;wlanndi5 NDIS Protocol Driver;\??\C:\WINDOWS\system32\wlanndi5.SYS
    S4 Pctspk;PCTEL Speaker Phone;C:\WINDOWS\system32\pctspk.exe
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\D]
    AutoRun\command- D:\setup.exe /s
    catchme 0.3.1061 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2007-09-16 16:00:07
    Windows 5.1.2600 Service Pack 2 NTFS
    scanning hidden processes ...
    HKCU\Software\Microsoft\Windows\CurrentVersion\Run
    P2kAutostart = C:\Documents and Settings\Owner\My Documents\Moto V3R\p2k-commander_3.3\p2k-commander 3.3.0 Beta\P2kAutostart.exe?0???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
    scanning hidden files ...
    Completion time: 2007-09-16 16:02:36
    C:\ComboFix-quarantined-files.txt ... 2007-09-16 16:02
    C:\ComboFix2.txt ... 2007-09-15 23:43
    C:\ComboFix3.txt ... 2007-09-15 20:33
    --- E O F ---
  16. 2007/09/16
    TexasStormChase
    Hijackthis log file
    Scan saved at 4:10:39 PM, on 9/16/2007
    C:\HP\KBD\KBD.EXE
    C:\WINDOWS\explorer.exe
    C:\Program Files\internet explorer\iexplore.exe
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    End of file - 10535 bytes
  17. 2007/09/16
    TexasStormChase
    I just downloaded imvu 3 or so days ago. this problum with MSN has been going on for a few weeks I just did not think any thing about it untill Last night.
  18. 2007/09/16
    noahdfear
    noahdfear Inactive
    And now it's running from the msn messenger folder! Well lets kill that bit too! :D
    File::
    C:\WINDOWS\SoftwareDistribution\Download\Install\M U_WLMessenger.exe
    Folder::
    Registry::
    [-HKEY_CLASSES_ROOT\CLSID\{FC9FB64A-1EB2-4CCF-AF5E-1A497A9B5C2D}]
    [-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Live]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved]
     "{FC9FB64A-1EB2-4CCF-AF5E-1A497A9B5C2D} "=-
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usnjsvc]
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button. Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log and another fresh HijackThis log..
  19. 2007/09/16
    TexasStormChase
    Combo fix
    ComboFix 07-09-14.2 - "Owner" 2007-09-16 16:42:14.5 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.260 [GMT -5:00]
    FILE::
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\Logs\2007-07-01_15-28_3350.log
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\MsiLogs\AD-{A26D7C8B-875D-48E2-BED1-7168268D022A}_8_5_1235_0517_07012007_16-05.log
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\MsiLogs\I-{A26D7C8B-875D-48E2-BED1-7168268D022A}_8_5_1235_0517_07012007_16-05.log
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\MsiSources\Install_{33F8EAD4-B6EC-498B-B487-696B973D1C0C}.msi
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\Product\{31BB3B1C-5A3D-4E68-82A1-3C166F03C379}_4_100_313_1_43c51626.msi
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\Product\{A26D7C8B-875D-48E2-BED1-7168268D022A}_8_5_1235_0517_43c51645.msi
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\Product\{E6BBF698-F2F2-420C-920F-D9C9183E2E5F}_1_0_690_43c515f7.msi
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WindowsLiveInstaller\Temp\WLS31.tmp
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WLInstaller\WLI_BS_2007-07-01_15-27-34.log
    C:\DOCUME~1\ALLUSE~1\APPLIC~1\WLInstaller\WLI_BS_2007-09-16_13-38-23.log
    2007-09-16 16:28 --------- d-------- C:\DOCUME~1\ALLUSE~1\APPLIC~1\Spybot - Search & Destroy
    C:\HP\KBD\KBD.EXE
    S3tray2.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SpybotSD TeaTimer]
    "NVSvc "=2 (0x2)
    "Fax "=2 (0x2)
    "Pctspk "=2 (0x2)
    "LexBceS "=2 (0x2)
    "AVGEMS "=2 (0x2)
    "Avg7Alrt "=2 (0x2)
    Rootkit scan 2007-09-16 16:48:59
    Completion time: 2007-09-16 16:52:14 - machine was rebooted
    C:\ComboFix-quarantined-files.txt ... 2007-09-16 16:51
    --- E O F ---
  20. 2007/09/16
    TexasStormChase
    Hijackthis log
    Scan saved at 4:58:47 PM, on 9/16/2007
    C:\HP\KBD\KBD.EXE
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
    O2 - BHO: (no name) - {9030D464-4C02-4ABF-8ECC-5164760863C6} - (no file)
    End of file - 9830 bytes
  21. 2007/09/16
    noahdfear
    noahdfear Inactive
    Scan again with HijackThis and fix the following entries.
    Download GMER
    Unzip it to the desktop.
    Open the program and click on the Rootkit tab.
    Make sure all the boxes on the right of the screen are checked, EXCEPT for "˜Show All’.
    Click on Scan.
    When the scan has completed, click Copy and paste the results (if any) into this topic.
