MSN & ICS Problems
Discussion in 'Malware and Virus Removal Archive' started by Liam, 2004/12/24.
  1. 2004/12/24
    Liam Lifetime Subscription
    Liam Inactive Thread Starter
    Hello
    I am having trouble with MSN Messenger over my network. I can not sign in, or go on the msn site.
    The internet is shared on my dad's pc, and he can sign in to MSN fine. I tried to put the internet on mine and share it, and both mine and my dad's computer could sign in. This is very confusing. I have norton running, but it is configured to allow other PCs connect. I am able to access the internet on the computer, but not MSN...
    Please help me.. :(
    EDIT - I am running Windows XP Professional on both PCs w/ norton Internet Security 2003. Merry Christmas :)
    Liam,
  2. 2004/12/24
    Take a look Here for the port that MSN Messenger requires be open in your firewall and also for a link to more details about IM use.
    Thanks for your reply, Newt...
    I'm afraid that hasnt helped. I am still unable to connect to MSN Messenger, or even the Microsoft or MSN site.... :(
    Liam
    P.S. Hope you had a great christmas!! ;)
    Liam,
    That begins to smell like spyware/malware blocking those sites and probably your AIM app as well.
    Not sure what your usual anti-spyware precautions are but I'm moving this to the spyware removal section of the forum for now.
    Please download, update, and run both Ad-aware SE v1.5 and Spybot Search & Destroy v1.3 and let them clean what they find. Then get Hijackthis v1.99, unzip it to a normal folder (so not a temp folder and not on or under the desktop) and post a scan log.
    charlesvar
    charlesvar Inactive Alumni
    Hello Liam,
    Another possibility is if you're running SP2, windows firewall my be running because NIS2003 is not being recognized by the Security Center.
    So if that is true, bring up the firewall and look in the exceptions tab. MSN Messenger is there and blocked by default and should be checked, meaning it's an exception to default blocking.
    Regards - Charles
  7. 2004/12/27
    HijackThis Logs
    Hello!
    Thanks for the reply. Here are the logs for both PCs...
    My PC
    Logfile of HijackThis v1.99.0
    Scan saved at 18:49:21, on 27/12/2004
    Platform: Windows XP (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 (6.00.2600.0000)
    C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
    C:\Program Files\Norton Internet Security\NISUM.EXE
    C:\WINDOWS\System32\RUNDLL32.EXE
    C:\Program Files\TGTSoft\StyleXP\StyleXP.exe
    C:\Program Files\CursorXP\CursorXP.exe
    C:\WINDOWS\System32\CAP3RSK.EXE
    C:\WINDOWS\system32\spool\drivers\w32x86\3\CAP3LAK.EXE
    C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\CAP3SWK.EXE
    C:\Program Files\Norton Internet Security\ccPxySvc.exe
    C:\Program Files\Norton AntiVirus\navapsvc.exe
    C:\WINDOWS\System32\nvsvc32.exe
    C:\WINDOWS\System32\r_server.exe
    C:\WINDOWS\System32\msiexec.exe
    C:\Program Files\Common Files\VideoMate\ComproScheduler.exe
    C:\Program Files\Common Files\VideoMate\ComproRemote.exe
    C:\PROGRA~1\MOZILL~1\FIREFOX.EXE
    C:\Program Files\MSN Messenger\msnmsgr.exe
    C:\HijackThis\HijackThis.exe
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\system32\NeroCheck.exe
    O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe "
    O4 - HKLM\..\Run: [CAP3ON] C:\WINDOWS\System32\spool\drivers\w32x86\3\CAP3ONN.EXE
    O4 - HKLM\..\Run: [DXDllRegExe] C:\WINDOWS\System32\dxdllreg.exe
    O4 - HKLM\..\Run: [Ulead AutoDetector] C:\Program Files\Ulead Systems\Ulead Photo Explorer 8.0 SE\Monitor.exe
    O4 - HKCU\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NVMCTRAY.DLL,NvTaskbarInit
    O4 - HKCU\..\Run: [STYLEXP] C:\Program Files\TGTSoft\StyleXP\StyleXP.exe -Hide
    O4 - HKCU\..\Run: [CursorXP] C:\Program Files\CursorXP\CursorXP.exe
    O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
    O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    O4 - Global Startup: Canon LASER SHOT LBP-1120 Status Window.LNK = C:\WINDOWS\system32\spool\drivers\w32x86\3\CAP3LAK.EXE
    O4 - Global Startup: ComproRemote.lnk = C:\Program Files\Common Files\VideoMate\ComproRemote.exe
    O4 - Global Startup: ComproScheduler.lnk = C:\Program Files\Common Files\VideoMate\ComproScheduler.exe
    O4 - Global Startup: TweakYC.lnk = ?
    O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
    O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
    O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
    O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
    O23 - Service: Adobe LM Service - Unknown - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
    O23 - Service: Symantec Event Manager - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    O23 - Service: Symantec Password Validation Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
    O23 - Service: Symantec Proxy Service - Symantec Corporation - C:\Program Files\Norton Internet Security\ccPxySvc.exe
    O23 - Service: Macromedia Licensing Service - Unknown - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
    O23 - Service: Norton AntiVirus Auto Protect Service - Symantec Corporation - C:\Program Files\Norton AntiVirus\navapsvc.exe
    O23 - Service: Norton Internet Security Accounts Manager - Symantec Corporation - C:\Program Files\Norton Internet Security\NISUM.EXE
    O23 - Service: NVIDIA Display Driver Service - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
    O23 - Service: Remote Administrator Service - Unknown - C:\WINDOWS\System32\r_server.exe
    O23 - Service: ScriptBlocking Service - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
    O23 - Service: StyleXPService - Unknown - C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
    Dad's PC
    Scan saved at 18:59:26, on 27/12/2004
    C:\Program Files\Microsoft IntelliType Pro\type32.exe
    C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
    C:\Program Files\Norton SystemWorks\Norton Ghost\GhostStartService.exe
    C:\PROGRA~1\NORTON~3\SPEEDD~1\nopdb.exe
    C:\hjack\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = wmplayer.exe //ICWLaunch
    O4 - HKLM\..\Run: [type32] "C:\Program Files\Microsoft IntelliType Pro\type32.exe "
    O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe "
    O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe
    O4 - HKLM\..\Run: [SSC_UserPrompt] C:\Program Files\Common Files\Symantec Shared\Security Center\UsrPrmpt.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\OFFICE11\REFIEBAR.DLL
    O17 - HKLM\System\CCS\Services\Tcpip\..\{A1C49C83-DD0B-4FAF-9E16-5970229E0B39}: NameServer = 194.74.65.68 194.72.9.34
    O23 - Service: GhostStartService - Symantec Corporation - C:\Program Files\Norton SystemWorks\Norton Ghost\GhostStartService.exe
    O23 - Service: Symantec Network Drivers Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    O23 - Service: Speed Disk service - Symantec Corporation - C:\PROGRA~1\NORTON~3\SPEEDD~1\nopdb.exe
    O23 - Service: SymWMI Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
    Liam,
    #6
  8. 2004/12/27
    Thanks for your reply.. I have actually reformatted my PC w/o installing SP2, although before, the security center was recognizing norton and XP's firewall was turned off..
    Liam
    Liam,
    #7
  9. 2004/12/27
    charlesvar
    Hi Liam,
    Did you look in the Hosts file to see if its being blocked there?
    Regards - Charles
  10. 2004/12/27
    Hi Charles,
    What do you mean by the hosts file? :eek:
    Liam,
    #9
  11. 2004/12/27
    charlesvar
    Hi Liam,
    Hosts is located in \WINDOWS\System32\Drivers\etc\HOSTS and opens with Notepad.
    Should look something like this:
    # Copyright (c) 1993-1999 Microsoft Corp.
    # This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    # This file contains the mappings of IP addresses to host names. Each
    # entry should be kept on an individual line. The IP address should
    # be placed in the first column followed by the corresponding host name.
    # The IP address and the host name should be separated by at least one
    # space.
    # Additionally, comments (such as these) may be inserted on individual
    # lines or following the machine name denoted by a '#' symbol.
    # For example:
    # 102.54.94.97 rhino.acme.com # source server
    # 38.25.63.10 x.acme.com # x client host
    127.0.0.1 localhost
    That 127.0.0.1 entry is the only one you should have.
    Regards - Charles
  12. 2004/12/27
    Hi Charles,
    it is the same as the one you posted.... ;)
  13. 2004/12/27
    charlesvar
    Hi Liam,
    Look thru this thread http://www.windowsbbs.com/showthread.php?t=39081 It will give you an idea of what the HOSTS file can be used for, in that case, it's used for blocking sites. My post #6 advises downloading a program to find all instances of HOSTS if any exist besides the legitimate one.
    The reason I'm persuing this idea is because your symptoms sound very much like a classic HOSTS blocking of specific IP addresses or Domains, in this case MS.
    Regards - Charles
  14. 2004/12/30
    Thanks Newt and Charles for your suggestions and help...
    I have found out that my dad's PC needed to have Service Pack 1 installed :eek:
    Thanks again! Have a happy new year! :) :D ;) :cool:
