Solved Msa.exe Help please!
Discussion in 'Malware and Virus Removal Archive' started by jboy09, 2009/08/22.
  1. 2009/08/22
    jboy09
    jboy09 Inactive Thread Starter
    [Resolved] Msa.exe Help please!
    Hi there,
    I got a virus msa.exe on my pc. I googled it and followed the instructions here:http://www.xp-vista.com/spyware-removal/msantivirus-ms-antivirus-removal-instructions
    This did not remove the virus though. I then tried running Anti-Malware but it wouldnt even open. I then tried running SuperAntiSpyware. Again it wouldnt run. I then found an alternativer version of it which would run but close down about a minute into a scan after it found Rootkit.Agent/Gen-UACFake. Then it would restart my pc and nothing would of changed.
    It also runs several versions of IE8 in the background when i first log on and i wont let me install any new software for example, my printer. Can someone help me please?
  2. 2009/08/22
    Welcome to WindowsBBS :)
    Thread moved to the Malware & Virus Removal forum .....
    Please read this as indicated at the head of the forum and post the logs requested in this thread.
    jboy09
    Err... sorry to be as idiot but how do i disable script blocking?
    I use Firefox and have AVGFree on my PC if this is relevant to it.
  5. 2009/08/23
    If you use Windows Defender, or Spybot, disable those.
  6. 2009/08/23
    jboy09
    Hey, i dont have either. I saved things like SpyNoMore and SpyHunter but im not running them.
  7. 2009/08/23
    Then go ahead with DDS.
  8. 2009/08/23
    jboy09
    Nothing happens. I click run, the wee screen comes up, then nothing happens. :confused:
  9. 2009/08/23
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
  10. 2009/08/23
    jboy09
    I disabled avg and my windows firewall but but Combofix wouldnt run. It's shown in the task manager but nothing appears on screen.
  11. 2009/08/23
    Delete downloaded Combofix file.
    Download fresh copy from HERE.
    I renamed the file for a reason.
  12. 2009/08/23
    jboy09
    OK here's the log file from the Combofix, gonna post the MyHijackThis one shortly. I disabled AVG during teh Combofix scan as i'd forgot i'd turned it back on affter the 1st attempt.
    ComboFix 09-08-22.06 - Mincey 23/08/2009 19:40.1.2 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.44.1033.18.1022.627 [GMT 1:00]
    Running from: d:\documents and settings\Mincey\Desktop\3hy5dr3y.exe
    AV: AVG Anti-Virus Free *On-access scanning enabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
    * Created a new restore point
    c:\program files\Zumie
    c:\recycler\S-1-5-21-1391838957-3040609247-2995674385-1006
    c:\recycler\S-1-5-21-3364321261-3860717988-1829214129-1003
    c:\windows\run.log
    c:\windows\system32\drivers\UACcomhsnlgub.sys
    c:\windows\system32\UACbayvtsmtoy.dll
    c:\windows\system32\UACfkkjyxewtv.dll
    c:\windows\system32\uacinit.dll
    c:\windows\system32\UACjgsumsrsbe.dll
    c:\windows\system32\UACqbitihxbjt.dll
    c:\windows\system32\UACtpysvcioyk.dat
    c:\windows\system32\UACylabgrufcs.db
    Infected copy of c:\windows\system32\eventlog.dll was found and disinfected
    Restored copy from - c:\windows\ServicePackFiles\i386\eventlog.dll
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
    -------\Service_UACd.sys
    -------\Legacy_UACd.sys
    -------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226ED}
    -------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
    ((((((((((((((((((((((((( Files Created from 2009-07-23 to 2009-08-23 )))))))))))))))))))))))))))))))
    2009-08-23 10:12 . 2009-08-23 10:12 -------- d-----w- C:\rsit
    2009-08-22 18:58 . 2009-08-22 18:58 1152 ----a-w- c:\windows\system32\windrv.sys
    2009-08-22 18:58 . 2009-08-23 18:43 -------- d-----w- c:\program files\SpyNoMore
    2009-08-22 18:55 . 2009-08-22 18:57 -------- d-----w- d:\documents and settings\Mincey\Application Data\GetRightToGo
    2009-08-21 15:08 . 2009-08-21 15:08 -------- d-----w- d:\documents and settings\GoodToBeDrunk09\Local Settings\Application Data\Apple Computer
    2009-08-21 15:08 . 2009-08-21 15:08 -------- d-sh--w- d:\documents and settings\GoodToBeDrunk09\IETldCache
    2009-08-21 14:38 . 2009-08-21 14:38 -------- d-----w- c:\program files\Enigma Software Group
    2009-08-21 14:29 . 2009-08-21 14:29 -------- d-----w- d:\documents and settings\Mincey\Local Settings\Application Data\PCHealth
    2009-08-21 14:18 . 2009-08-21 14:18 -------- d-----w- C:\2581d93b6df95d6a9d8c86259f0b
    2009-08-21 13:44 . 2009-08-21 13:44 -------- d-----w- c:\windows\system32\XPSViewer
    2009-08-21 13:44 . 2009-08-21 13:44 -------- d-----w- c:\program files\MSBuild
    2009-08-21 13:44 . 2009-08-21 13:44 -------- d-----w- c:\program files\Reference Assemblies
    2009-08-17 18:23 . 2009-08-17 18:25 -------- d-----w- d:\documents and settings\Mincey\Application Data\Spotify
    2009-08-17 18:23 . 2009-08-17 18:23 -------- d-----w- d:\documents and settings\Mincey\Local Settings\Application Data\Spotify
    2009-08-17 18:23 . 2009-08-17 18:23 -------- d-----w- c:\program files\Spotify
    2009-08-12 20:38 . 2009-07-10 13:27 1315328 ------w- c:\windows\system32\dllcache\msoe.dll
    2009-08-10 14:56 . 2009-08-23 16:37 0 ----a-w- d:\documents and settings\Mincey\Local Settings\Application Data\prvlcl.dat
    2009-08-09 18:14 . 2009-08-09 18:14 -------- d-sh--w- d:\documents and settings\LocalService.NT AUTHORITY.000\IETldCache
    2009-08-09 02:33 . 2009-08-09 02:33 -------- d-----w- d:\documents and settings\NetworkService.NT AUTHORITY.000\Local Settings\Application Data\Google
    2009-08-09 02:33 . 2009-08-09 02:33 -------- d-----w- d:\documents and settings\LocalService.NT AUTHORITY.000\Local Settings\Application Data\Google
    2009-08-09 02:31 . 2009-08-09 02:31 -------- d-----w- c:\windows\system32\wbem\Repository
    2009-08-07 17:44 . 2009-08-07 17:44 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\SUPERAntiSpyware.com
    2009-08-07 17:44 . 2009-08-22 18:42 -------- d-----w- c:\program files\SUPERAntiSpyware
    2009-08-07 17:44 . 2009-08-07 17:44 -------- d-----w- d:\documents and settings\Mincey\Application Data\SUPERAntiSpyware.com
    2009-08-07 17:43 . 2009-08-07 17:43 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
    2009-08-05 15:20 . 2009-08-05 15:20 -------- d-sh--w- d:\documents and settings\NetworkService.NT AUTHORITY\IETldCache
    2009-08-05 09:01 . 2009-08-05 09:01 204800 ------w- c:\windows\system32\dllcache\mswebdvd.dll
    2009-08-04 17:03 . 2009-08-04 17:03 -------- d-----w- d:\documents and settings\Mincey\Application Data\Malwarebytes
    2009-08-04 17:03 . 2009-08-03 12:36 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-08-04 17:02 . 2009-08-03 12:36 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-08-03 21:09 . 2009-08-03 21:09 -------- d-sh--w- d:\documents and settings\LocalService.NT AUTHORITY\IETldCache
    2009-08-03 18:55 . 2009-08-09 02:32 -------- d-sh--w- d:\documents and settings\LocalService.NT AUTHORITY
    2009-08-03 18:55 . 2009-08-09 02:32 -------- d-sh--w- d:\documents and settings\NetworkService.NT AUTHORITY
    2009-07-28 20:36 . 2009-07-28 20:36 -------- d-sh--w- d:\documents and settings\Mincey\PrivacIE
    2009-08-23 18:47 . 2008-07-22 12:45 -------- d-----w- c:\program files\DNA
    2009-08-23 18:36 . 2009-01-16 14:06 -------- d-----w- d:\documents and settings\Mincey\Application Data\DNA
    2009-08-23 16:45 . 2008-07-29 17:03 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-08-23 14:40 . 2008-07-29 19:04 -------- d-----w- c:\program files\Trend Micro
    2009-08-23 10:02 . 2008-10-05 18:00 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\Google Updater
    2009-08-22 19:29 . 2009-01-19 15:29 -------- d-----w- d:\documents and settings\Mincey\Application Data\foobar2000
    2009-08-22 19:08 . 2009-01-16 14:05 72024 -c--a-w- d:\documents and settings\Mincey\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2009-08-21 15:28 . 2009-07-09 16:49 11952 ----a-w- c:\windows\system32\avgrsstx.dll
    2009-08-21 15:28 . 2009-07-09 16:49 335240 ----a-w- c:\windows\system32\drivers\avgldx86.sys
    2009-08-21 15:28 . 2009-07-09 16:49 27784 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
    2009-08-20 22:18 . 2009-01-15 01:03 -------- d-----w- c:\program files\Peer2Peer-EN
    2009-08-20 22:05 . 2009-08-09 02:16 784491 ----a-w- c:\windows\system32\xa.tmp
    2009-08-20 18:38 . 2009-01-16 14:10 -------- d-----w- d:\documents and settings\Mincey\Application Data\BitTorrent
    2009-08-20 17:09 . 2009-01-25 19:01 -------- d-----w- c:\program files\LDC Driving Test Complete
    2009-08-19 17:02 . 2009-02-27 13:10 -------- d-----w- d:\documents and settings\Mincey\Application Data\LimeWire
    2009-08-09 02:31 . 2009-01-13 19:13 -------- d-----w- c:\program files\LimeWire
    2009-08-05 09:01 . 2004-08-10 15:38 204800 ----a-w- c:\windows\system32\mswebdvd.dll
    2009-08-03 20:31 . 2009-02-18 17:44 -------- d-----w- c:\program files\avisplit
    2009-08-03 17:34 . 2008-07-28 19:28 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\avg8
    2009-07-23 17:44 . 2009-07-23 17:44 -------- d-----w- c:\program files\ffdshow
    2009-07-21 18:10 . 2008-07-19 02:35 -------- d--h--w- c:\program files\InstallShield Installation Information
    2009-07-21 17:20 . 2009-07-09 16:49 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\AVG Security Toolbar
    2009-07-17 19:01 . 2004-08-10 15:37 58880 ----a-w- c:\windows\system32\atl.dll
    2009-07-16 16:24 . 2008-07-19 02:35 -------- d-----w- c:\program files\Java
    2009-07-13 22:43 . 2004-08-10 15:38 286208 ----a-w- c:\windows\system32\wmpdxm.dll
    2009-07-09 16:49 . 2009-07-09 16:49 108552 ----a-w- c:\windows\system32\drivers\avgtdix.sys
    2009-07-09 16:44 . 2009-07-08 20:36 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\Norton
    2009-07-09 16:42 . 2008-07-19 02:35 -------- d-----w- c:\program files\Common Files\Symantec Shared
    2009-07-09 16:42 . 2009-07-08 20:40 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\{7B6BA59A-FB0E-4499-8536-A7420338BF3B}
    2009-07-09 16:21 . 2009-01-15 07:26 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\Symantec
    2009-07-08 20:33 . 2009-07-08 20:33 -------- d-----w- d:\docume~1\ALLUSE~1\APPLIC~1\NortonInstaller
    2009-07-03 17:09 . 2004-08-10 15:38 915456 ----a-w- c:\windows\system32\wininet.dll
    2009-06-25 08:25 . 2004-08-10 15:38 54272 ----a-w- c:\windows\system32\wdigest.dll
    2009-06-25 08:25 . 2004-08-10 15:38 56832 ----a-w- c:\windows\system32\secur32.dll
    2009-06-25 08:25 . 2004-08-10 15:38 147456 ----a-w- c:\windows\system32\schannel.dll
    2009-06-25 08:25 . 2004-08-10 15:38 136192 ----a-w- c:\windows\system32\msv1_0.dll
    2009-06-25 08:25 . 2004-08-10 15:37 730112 ----a-w- c:\windows\system32\lsasrv.dll
    2009-06-25 08:25 . 2004-08-10 15:37 301568 ----a-w- c:\windows\system32\kerberos.dll
    2009-06-24 11:18 . 2004-08-10 15:37 92928 ----a-w- c:\windows\system32\drivers\ksecdd.sys
    2009-06-16 14:36 . 2004-08-10 15:38 119808 ----a-w- c:\windows\system32\t2embed.dll
    2009-06-16 14:36 . 2004-08-10 15:37 81920 ----a-w- c:\windows\system32\fontsub.dll
    2009-06-12 12:31 . 2004-08-10 15:38 76288 ----a-w- c:\windows\system32\telnet.exe
    2009-06-10 14:13 . 2004-08-10 15:37 84992 ----a-w- c:\windows\system32\avifil32.dll
    2009-06-10 08:19 . 2004-08-10 15:54 2066432 ----a-w- c:\windows\system32\mstscax.dll
    2009-06-10 06:14 . 2004-08-10 15:38 132096 ----a-w- c:\windows\system32\wkssvc.dll
    2009-06-03 19:09 . 2004-08-10 15:38 1291264 ------w- c:\windows\system32\quartz.dll
    2009-06-02 17:11 . 2009-07-23 17:44 85504 ----a-w- c:\windows\system32\ff_vfw.dll
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
    "{A3BC75A2-1F87-4686-AA43-5347D756017C} "= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-06-14 1004800]
    [HKEY_CLASSES_ROOT\clsid\{a3bc75a2-1f87-4686-aa43-5347d756017c}]
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}]
    2009-06-14 15:07 1004800 ----a-w- c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{da21bd13-ca22-42e3-a071-98f08f1ca1e7}]
    2009-08-20 22:18 2215960 ----a-w- c:\program files\Peer2Peer-EN\tbPee0.dll
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
    "{da21bd13-ca22-42e3-a071-98f08f1ca1e7} "= "c:\program files\Peer2Peer-EN\tbPee0.dll" [2009-08-20 2215960]
    "{CCC7A320-B3CA-4199-B1A6-9F516DD69829} "= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-06-14 1004800]
    [HKEY_CLASSES_ROOT\clsid\{da21bd13-ca22-42e3-a071-98f08f1ca1e7}]
    [HKEY_CLASSES_ROOT\clsid\{ccc7a320-b3ca-4199-b1a6-9f516dd69829}]
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
    "{DA21BD13-CA22-42E3-A071-98F08F1CA1E7} "= "c:\program files\Peer2Peer-EN\tbPee0.dll" [2009-08-20 2215960]
    "MSMSGS "= "c:\program files\Messenger\msmsgs.exe" [2008-04-14 1695232]
    "BitTorrent DNA "= "c:\program files\DNA\btdna.exe" [2009-01-16 342848]
    "swg "= "c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-07-18 68856]
    "Sony Ericsson PC Suite "= "c:\program files\Sony Ericsson\Sony Ericsson PC Suite\SEPCSuite.exe" [2008-07-02 393216]
    "SUPERAntiSpyware "= "c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2009-08-05 1830128]
    "ctfmon.exe "= "c:\windows\system32\ctfmon.exe" [2008-04-14 15360]
    "PHIME2002ASync "= "c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
    "PHIME2002A "= "c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
    "NvCplDaemon "= "c:\windows\system32\NvCpl.dll" [2006-04-27 7573504]
    "NvMediaCenter "= "c:\windows\system32\NvMcTray.dll" [2006-04-27 86016]
    "Vade Retro Outlook Express "= "c:\progra~1\GOTOSO~1\VADERE~1\Vaderetro_oe.exe" [2004-10-04 310272]
    "DetectorApp "= "c:\program files\Sonic\DigitalMedia LE v7\MyDVD LE\DetectorApp.exe" [2005-10-20 102400]
    "OmniPass "= "c:\apps\Softex\OmniPass\scureapp.exe" [2006-01-30 1978368]
    "PCMService "= "c:\apps\Powercinema\PCMService.exe" [2006-02-23 147456]
    "IMJPMIG8.1 "= "c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-04 208952]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2009-01-18 185872]
    "O2 "= "c:\program files\O2\bin\sprtcmd.exe" [2008-03-28 198184]
    "Adobe Photo Downloader "= "c:\program files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe" [2007-03-09 63712]
    "AppleSyncNotifier "= "c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-02-06 177472]
    "QuickTime Task "= "c:\program files\QuickTime\QTTask.exe" [2009-01-05 413696]
    "iTunesHelper "= "c:\program files\iTunes\iTunesHelper.exe" [2009-03-12 342312]
    "AVG8_TRAY "= "c:\progra~1\AVG\AVG8\avgtray.exe" [2009-08-21 2007832]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2009-05-21 148888]
    "SpyHunter Security Suite "= "c:\program files\Enigma Software Group\SpyHunter\SpyHunter3.exe" [2009-04-02 868352]
    "SNM "= "c:\program files\SpyNoMore\SNM.exe" [2009-08-22 1068496]
    "SMSERIAL "= "sm56hlpr.exe" - c:\windows\sm56hlpr.exe [2005-10-18 557056]
    "nwiz "= "nwiz.exe" - c:\windows\system32\nwiz.exe [2006-04-27 1519616]
    "High Definition Audio Property Page Shortcut "= "HDAShCut.exe" - c:\windows\system32\HdAShCut.exe [2005-01-07 61952]
    "RTHDCPL "= "RTHDCPL.EXE" - c:\windows\RTHDCPL.exe [2005-12-09 15691264]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "CTFMON.EXE "= "c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
    d:\docume~1\ALLUSE~1\STARTM~1\Programs\Startup\
    NETGEAR WG111v3 Smart Wizard.lnk - c:\program files\NETGEAR\WG111v3\WG111v3.exe [2006-5-29 1527808]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2008-12-22 11:05 356352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\OPXPGina]
    2006-01-30 07:53 49152 ----a-w- c:\apps\Softex\OmniPass\OPXPGina.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
    2009-08-21 15:28 11952 ----a-w- c:\windows\system32\avgrsstx.dll
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "%ProgramFiles%\\AOL 9.0\\aol.exe "=
    "%ProgramFiles%\\UBISOFT\\Splinter Cell Pandora Tomorrow\\logo_ubi.exe "=
    "%ProgramFiles%\\UBISOFT\\Splinter Cell Pandora Tomorrow\\pandora.exe "=
    "c:\\Program Files\\Vuze\\Azureus.exe "=
    "c:\\Program Files\\DNA\\btdna.exe "=
    "c:\\Program Files\\BitTorrent\\bittorrent.exe "=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\Program Files\\O2\\bin\\wificfg.exe "=
    "c:\\Program Files\\O2\\agent\\bin\\bcont.exe "=
    "c:\\Program Files\\Common Files\\SupportSoft\\bin\\ssrc.exe "=
    "c:\\Program Files\\O2\\agent\\bin\\bcont_nm.exe "=
    "c:\\Program Files\\Mozilla Firefox\\firefox.exe "=
    "c:\\Program Files\\Sony Ericsson\\Sony Ericsson Media Manager\\MediaManager.exe "=
    "c:\\Program Files\\Sony Ericsson\\Update Service\\Update Service.exe "=
    "c:\\Program Files\\Bonjour\\mDNSResponder.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    "c:\\Program Files\\AVG\\AVG8\\avgemc.exe "=
    "c:\\Program Files\\AVG\\AVG8\\avgupd.exe "=
    "c:\\Program Files\\AVG\\AVG8\\avgnsx.exe "=
    "c:\\Program Files\\Spotify\\spotify.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "63633:TCP "= 63633:TCP:BitToorent
    R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [09/07/2009 17:49 335240]
    R1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [09/07/2009 17:49 108552]
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [05/08/2009 16:06 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [05/08/2009 16:06 74480]
    R2 avg8emc;AVG Free8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [09/07/2009 17:49 908056]
    R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [09/07/2009 17:49 297752]
    R2 sprtsvc_O2;SupportSoft Sprocket Service (O2);c:\program files\O2\bin\sprtsvc.exe [07/06/2007 17:19 202280]
    R3 RTL8187B;NETGEAR WG111v3 54Mbps Wireless USB 2.0 Adapter Vista Driver;c:\windows\system32\drivers\wg111v3.sys [23/04/2007 14:11 224896]
    R3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [05/08/2009 16:06 7408]
    S2 gupdate1c9938276ca1592;Google Update Service (gupdate1c9938276ca1592);c:\program files\Google\Update\GoogleUpdate.exe [20/02/2009 18:41 133104]
    *NewlyCreated* - MCHINJDRV
    *Deregistered* - mchInjDrv
    [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
    "c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll ",BrandIEActiveSetup SIGNUP
    URLSearchHooks-*{da21bd13-ca22-42e3-a071-98f08f1ca1e7} - (no file)
    HKLM-Run-ISUSPM Startup - c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe
    HKLM-Run-ISUSScheduler - c:\program files\Common Files\InstallShield\UpdateService\issch.exe
    uStart Page = hxxp://www.google.com/
    uInternet Connection Wizard,ShellNext = hxxp://google.com/
    uInternet Settings,ProxyOverride = *.local
    Trusted Zone: o2.co.uk\*.broadband
    FF - ProfilePath - d:\docume~1\Mincey\APPLIC~1\Mozilla\Firefox\Profiles\m2666m2p.default\
    FF - prefs.js: browser.search.selectedEngine - Search Solver
    FF - prefs.js: browser.startup.homepage - hxxp://autosport.com/
    FF - prefs.js: keyword.URL - about:neterror?e=query&u=
    FF - component: c:\program files\AVG\AVG8\Firefox\components\avgssff.dll
    FF - plugin: c:\program files\Google\Google Updater\2.4.1536.6592\npCIDetect13.dll
    FF - plugin: c:\program files\Google\Update\1.2.183.7\npGoogleOneClick8.dll
    FF - plugin: c:\program files\Mozilla Firefox\plugins\npbittorrent.dll
    FF - plugin: c:\program files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
    ---- FIREFOX POLICIES ----
    FF - user.js: yahoo.homepage.dontask - truec:\program files\Mozilla Firefox\greprefs\all.js - pref( "media.enforce_same_site_origin ", false);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "media.cache_size ", 51200);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "media.ogg.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "media.wave.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "media.autoplay.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "browser.urlbar.autocomplete.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "capability.policy.mailnews.*.wholeText ", "noAccess ");
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "dom.storage.default_quota ", 5120);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "content.sink.event_probe_rate ", 3);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.http.prompt-temp-redirect ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "layout.css.dpi ", -1);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "layout.css.devPixelsPerPx ", -1);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "gestures.enable_single_finger_input ", true);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "dom.max_chrome_script_run_time ", 0);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "network.tcp.sendbuffer ", 131072);
    c:\program files\Mozilla Firefox\greprefs\all.js - pref( "geo.enabled ", true);
    c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref( "security.remember_cert_checkbox_default_setting ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox-branding.js - pref( "browser.search.param.yahoo-fr ", "moz35 ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox-branding.js - pref( "browser.search.param.yahoo-fr-cjkt ", "moz35 ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "extensions.blocklist.level ", 2);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "browser.urlbar.restrict.typed ", "~ ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "browser.urlbar.default.behavior ", 0);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.history ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.formdata ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.passwords ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.downloads ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.cookies ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.cache ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.sessions ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.offlineApps ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.clearOnShutdown.siteSettings ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.history ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.formdata ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.passwords ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.downloads ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.cookies ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.cache ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.sessions ", true);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.offlineApps ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.cpd.siteSettings ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "privacy.sanitize.migrateFx3Prefs ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "browser.ssl_override_behavior ", 2);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "security.alternate_certificate_error_page ", "certerror ");
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "browser.privatebrowsing.autostart ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "browser.privatebrowsing.dont_prompt_on_enter ", false);
    c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref( "geo.wifi.uri ", "https://www.google.com/loc/json ");
    Rootkit scan 2009-08-23 19:46
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    - - - - - - - > 'winlogon.exe'(704)
    c:\windows\system32\WININET.dll
    c:\apps\Softex\OmniPass\opxpgina.dll
    - - - - - - - > 'explorer.exe'(4036)
    c:\progra~1\GOTOSO~1\VADERE~1\VrOe_hook.dll
    c:\apps\Softex\OmniPass\SCUREDLL.dll
    c:\progra~1\WINDOW~2\wmpband.dll
    c:\windows\system32\ieframe.dll
    c:\windows\system32\webcheck.dll
    c:\windows\system32\WPDShServiceObj.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    ------------------------ Other Running Processes ------------------------
    c:\progra~1\COMMON~1\AOL\ACS\AOLacsd.exe
    c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    c:\program files\Bonjour\mDNSResponder.exe
    c:\apps\Powercinema\Kernel\TV\CLCapSvc.exe
    c:\apps\Powercinema\Kernel\CLML_NTService\CLMLServer.exe
    c:\program files\Java\jre6\bin\jqs.exe
    c:\program files\Google\Update\1.2.183.7\GoogleCrashHandler.exe
    c:\program files\Common Files\Nero\Nero BackItUp 4\NBService.exe
    c:\apps\Softex\OmniPass\OmniServ.exe
    c:\program files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
    c:\program files\Sonic\DigitalMedia LE v7\MyDVD LE\USBDeviceService.exe
    c:\apps\Powercinema\Kernel\TV\CLSched.exe
    c:\program files\AVG\AVG8\avgrsx.exe
    c:\progra~1\AVG\AVG8\avgnsx.exe
    c:\program files\AVG\AVG8\avgcsrvx.exe
    c:\apps\Softex\OmniPass\OPXPApp.exe
    c:\windows\system32\wscntfy.exe
    c:\program files\iPod\bin\iPodService.exe
    Completion time: 2009-08-23 19:50 - machine was rebooted
    ComboFix-quarantined-files.txt 2009-08-23 18:50
    Pre-Run: 18,213,249,024 bytes free
    Post-Run: 18,094,215,168 bytes free
    347 --- E O F --- 2009-08-23 14:51
  13. 2009/08/23
    jboy09
    Hey, posted the log (twice i fear). I dont know where's it went too but im guessing you guys have access to it?
  14. 2009/08/23
    As a new member with less than 10 posts any post you make which contains a URL requires approval (moderation) before it is visible.
  15. 2009/08/23
    jboy09
    Ok no probs man
  16. 2009/08/23
    1. Please open Notepad
    • Click Start , then Run
    • Type notepad .exe in the Run Box.
    2. Now copy/paste the entire content of the codebox below into the Notepad window:
    File::
    Folder::
    Driver::
    Registry::
    RegLockDel::
    3. Save the above as CFScript.txt
    4. Then drag the CFScript.txt into ComboFix.exe as depicted in the animation below. This will start ComboFix again.
    5. After reboot, (in case it asks to reboot), please post the following reports/logs into your next reply:
    • Combofix.txt
    • A new HijackThis log.
    Download HijackThis:
    http://www.trendsecure.com/portal/en-US/tools/security_tools/hijackthis/download
    by clicking on Download HijackThis Installer
    Install, and run it.
    Post HijackTHis log.
    Do NOT attempt to fix anything!
    NOTE. If you're using Vista, right click on HijackThis, and click Run as Administrator
  17. 2009/08/23
    jboy09
    Hey heres the HiJackThis log:
    Scan saved at 21:03:48, on 23/08/2009
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    c:\APPS\Powercinema\Kernel\TV\CLCapSvc.exe
    c:\APPS\Powercinema\Kernel\CLML_NTService\CLMLServer.exe
    C:\Program Files\Google\Update\GoogleUpdate.exe
    C:\Program Files\Google\Update\1.2.183.7\GoogleCrashHandler.exe
    C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe
    C:\Apps\Softex\OmniPass\Omniserv.exe
    C:\Program Files\O2\bin\sprtsvc.exe
    C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
    C:\Program Files\Sonic\DigitalMedia LE v7\MyDVD LE\USBDeviceService.exe
    c:\APPS\Powercinema\Kernel\TV\CLSched.exe
    C:\PROGRA~1\AVG\AVG8\avgemc.exe
    C:\PROGRA~1\AVG\AVG8\avgrsx.exe
    C:\PROGRA~1\AVG\AVG8\avgnsx.exe
    C:\Program Files\AVG\AVG8\avgcsrvx.exe
    C:\Apps\Softex\OmniPass\OPXPApp.exe
    C:\WINDOWS\sm56hlpr.exe
    C:\WINDOWS\RTHDCPL.EXE
    C:\PROGRA~1\GOTOSO~1\VADERE~1\Vaderetro_oe.exe
    C:\APPS\Powercinema\PCMService.exe
    C:\Program Files\O2\bin\sprtcmd.exe
    C:\Program Files\QuickTime\QTTask.exe
    C:\PROGRA~1\AVG\AVG8\avgtray.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\DNA\btdna.exe
    C:\Program Files\Sony Ericsson\Sony Ericsson PC Suite\SEPCSuite.exe
    C:\Program Files\NETGEAR\WG111v3\WG111v3.exe
    C:\WINDOWS\explorer.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\WINDOWS\system32\NOTEPAD.EXE
    D:\Documents and Settings\Mincey\Desktop\HiJackThis\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://google.com/
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    R3 - URLSearchHook: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
    R3 - URLSearchHook: (no name) - *{CFBFAE00-17A6-11D0-99CB-00C04FD64497} - (no file)
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
    O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
    O2 - BHO: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.15642\swg.dll
    O2 - BHO: Shareware.Pro-EN Toolbar - {da21bd13-ca22-42e3-a071-98f08f1ca1e7} - C:\Program Files\Peer2Peer-EN\tbPee0.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: Shareware.Pro-EN Toolbar - {da21bd13-ca22-42e3-a071-98f08f1ca1e7} - C:\Program Files\Peer2Peer-EN\tbPee0.dll
    O3 - Toolbar: AVG Security Toolbar - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
    O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
    O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
    O4 - HKLM\..\Run: [SMSERIAL] sm56hlpr.exe
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAShCut.exe
    O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
    O4 - HKLM\..\Run: [Vade Retro Outlook Express] "C:\PROGRA~1\GOTOSO~1\VADERE~1\Vaderetro_oe.exe "
    O4 - HKLM\..\Run: [DetectorApp] C:\Program Files\Sonic\DigitalMedia LE v7\MyDVD LE\DetectorApp.exe
    O4 - HKLM\..\Run: [OmniPass] C:\Apps\Softex\OmniPass\scureapp.exe
    O4 - HKLM\..\Run: [PCMService] "c:\APPS\Powercinema\PCMService.exe "
    O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32 "
    O4 - HKLM\..\Run: [O2] "C:\Program Files\O2\bin\sprtcmd.exe" /P O2
    O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe "
    O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKLM\..\Run: [SpyHunter Security Suite] C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter3.exe
    O4 - HKLM\..\Run: [SNM] C:\Program Files\SpyNoMore\SNM.exe /startup
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe "
    O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    O4 - HKCU\..\Run: [Sony Ericsson PC Suite] "C:\Program Files\Sony Ericsson\Sony Ericsson PC Suite\SEPCSuite.exe" /systray /nologon
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
    O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
    O4 - Global Startup: NETGEAR WG111v3 Smart Wizard.lnk = C:\Program Files\NETGEAR\WG111v3\WG111v3.exe
    O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
    O14 - IERESET.INF: START_PAGE_URL=file://C:\APPS\IE\offline\uk.htm
    O15 - Trusted Zone: http://*.broadband.o2.co.uk
    O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
    O23 - Service: AOL Connectivity Service (AOL ACS) - America Online, Inc. - C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
    O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - c:\APPS\Powercinema\Kernel\TV\CLCapSvc.exe
    O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - c:\APPS\Powercinema\Kernel\TV\CLSched.exe
    O23 - Service: CyberLink Media Library Service - Cyberlink - c:\APPS\Powercinema\Kernel\CLML_NTService\CLMLServer.exe
    O23 - Service: Google Update Service (gupdate1c9938276ca1592) (gupdate1c9938276ca1592) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
    O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: Nero BackItUp Scheduler 4.0 - Nero AG - C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe
    O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: Softex OmniPass Service (omniserv) - Softex Inc. - C:\Apps\Softex\OmniPass\Omniserv.exe
    O23 - Service: SupportSoft Sprocket Service (O2) (sprtsvc_O2) - SupportSoft, Inc. - C:\Program Files\O2\bin\sprtsvc.exe
    O23 - Service: SupportSoft RemoteAssist - SupportSoft, Inc. - C:\Program Files\Common Files\Supportsoft\bin\ssrc.exe
    O23 - Service: Ulead Burning Helper (UleadBurningHelper) - Ulead Systems, Inc. - C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
    O23 - Service: USBDeviceService - Unknown owner - C:\Program Files\Sonic\DigitalMedia LE v7\MyDVD LE\USBDeviceService.exe
    End of file - 10492 bytes
  18. 2009/08/23
    jboy09
    And the combofix.txt log:
    ComboFix 09-08-22.06 - Mincey 23/08/2009 20:46.2.2 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.44.1033.18.1022.493 [GMT 1:00]
    Command switches used :: d:\documents and settings\Mincey\My Documents\Bruce In Dublin 2009\CFScript.txt
    AV: AVG Anti-Virus Free *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
    FILE ::
    "c:\windows\system32\xa.tmp "
    2009-08-22 18:58 . 2009-08-23 19:50 -------- d-----w- c:\program files\SpyNoMore
    2009-08-10 14:56 . 2009-08-23 19:37 0 ----a-w- d:\documents and settings\Mincey\Local Settings\Application Data\prvlcl.dat
    2009-08-23 19:47 . 2009-01-16 14:06 -------- d-----w- d:\documents and settings\Mincey\Application Data\DNA
    2009-07-03 17:09 . 2004-08-10 15:38 915456 ------w- c:\windows\system32\wininet.dll
    Rootkit scan 2009-08-23 20:51
    hidden files: 0
    Completion time: 2009-08-23 20:52
    ComboFix-quarantined-files.txt 2009-08-23 19:52
    ComboFix2.txt 2009-08-23 18:50
    Pre-Run: 18,106,789,888 bytes free
    Post-Run: 18,090,057,728 bytes free
    288 --- E O F --- 2009-08-23 14:51
  19. 2009/08/23
    Uninstall Combofix:
    Go Start > Run
    Type in:
    combofix /u
    Note the space between the "combofix" and the "/u "
    Restart computer.
    Print these instructions out.
    NOTE. If any of the programs listed below refuse to run, try renaming executive file to something else; for instance, rename hijackthis.exe to scanner.exe
    ***VERY IMPORTANT! Make sure, you update Superantispyware, and Malwarebytes before running the scans.***
    STEP 1. Download SUPERAntiSpyware Free for Home Users:
    http://www.superantispyware.com/
    * Double-click SUPERAntiSpyware.exe and use the default settings for installation.
    * An icon will be created on your desktop. Double-click that icon to launch the program.
    * If asked to update the program definitions, click "Yes ". If not, update the definitions before scanning by selecting "Check for Updates ". (If you encounter any problems while downloading the updates, manually download and unzip them from here: http://www.superantispyware.com/definitions.html.)
    * Close SUPERAntiSpyware.
    PHYSICALLY DISCONNECT FROM THE INTERNET
    Restart computer in Safe Mode.
    To enter Safe Mode, restart computer, and keep tapping F8 key, until menu appears; select Safe Mode; you'll see "Safe Mode" in all four corners of your screen
    * Open SUPERAntiSpyware.
    * Click Scan your Computer... button.
    * Click Scanning Preferences/Control Center... button.
    * Under General and Startup tab, make sure, Start SUPERAntiSpyware when Windows starts option is UN-checked.
    * Click the Scanning Control tab.
    * Under Scanner Options make sure the following are checked (leave all others unchecked):
    - Close browsers before scanning.
    - Terminate memory threats before quarantining.
    * Click the Close button to leave the control center screen.
    * On the left, make sure you check C:\Fixed Drive.
    * On the right, choose Perform Complete Scan.
    * Click Next to start the scan. Please be patient while it scans your computer.
    * After the scan is complete, a Scan Summary box will appear with potentially harmful items that were detected. Click OK.
    * Make sure everything has a checkmark next to it and click Next.
    * A notification will appear that Quarantine and Removal is Complete. Click OK and then click the Finish button to return to the main menu.
    * If asked if you want to reboot, click Yes.
    * To retrieve the removal information after reboot, launch SUPERAntispyware again.
    - Click Preferences, then click the Statistics/Logs tab.
    - Under Scanner Logs, double-click SUPERAntiSpyware Scan Log.
    - If there are several logs, click the current dated log and press View log. A text file will open in your default text editor.
    - Please copy and paste the Scan Log results in your next reply.
    * Click Close to exit the program.
    Post SUPERAntiSpyware log.
    RECONNECT TO THE INTERNET
    RESTART COMPUTER!
    STEP 2. Download Malwarebytes' Anti-Malware: http://www.malwarebytes.org/mbam.php to your desktop.
    (Malwarebytes is free to use as a manual scanner. Payment is only required if you wish to have it run and update automatically which is not necessary for our purposes)
    * Double-click mbam-setup.exe and follow the prompts to install the program.
    * At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
    * If an update is found, it will download and install the latest version.
    * Once the program has loaded, select Perform full scan, then click Scan.
    * When the scan is complete, click OK, then Show Results to view the results.
    * Be sure that everything is checked, and click Remove Selected.
    * When completed, a log will open in Notepad.
    * Post the log back here.
    The log can also be found here:
    C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt
    Or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
    RESTART COMPUTER!
    STEP 3.
    Post HijackThis log.
    Do NOT attempt to "fix" anything!
  20. 2009/08/23
    jboy09
    Hey i really appreciate the help so far, but i cant reboot in safe mode. Whenever i press f8 a couple ptions come up but none say safe mode :confused:
  21. 2009/08/23
    You don't press F8, you keep tapping F8 key, when the computer starts. It's often matter of timing.
    What brand of computer is it? With some brands, you should start tapping F8 key at manufacturer logo.
