Resolved Missing Related Icon/Button in Customize Toolbar
Discussion in 'Windows XP' started by lj50, 2004/09/09.
  1. 2004/09/12
    noahdfear
    noahdfear Inactive
    Ah well, I see those links are dead. :rolleyes: Did you make sure the related.htm file is present? The link for download doesn't appear to be working (at least not for me), so if you need a copy of the file, someone can put up an attachment for it. I have one. In addition to adding the registry entry, I had to also do Method 2 from Zander's link for the related icon to show up as a customise option.
    This link, http://www.pestpatrol.com/pestinfo/a/alexa.asp, also shows a workaround to data being sent to MSN or Alexa.
    Note that the per-user reg file will not be targeted by Ad-aware.
  2. 2004/09/12
    surferdude2
    surferdude2 Inactive
    I used the "Per user" file and it was indeed targeted by Ad-Aware so perhaps the game has changed since that info was printed.
    noahdfear
    noahdfear Inactive
    Hmm....suppose that's possible. However, I notice that Ad-aware targeted an HKEY_Users entry for you, rather than the HKEY_Current_User entry that the reg file enters. :confused:
  5. 2004/09/12
    noahdfear
    noahdfear Inactive
    I see now that the HKEY_Users entry is also present after adding the HKEY_Current_User entry on my machine. Wonder if allowing Ad-aware to remove the one will affect the other??
  6. 2004/09/12
    surferdude2
    I tested that and it affects all users. The button disappears and the option to install it as well. And the Registry entries are also gone!
  7. 2004/09/12
    surferdude2
    Soooo, I suppose you could say the feature is the result of a browser hi-jack even though the original hi-jacking was done by M$. :) Semantics, one mans' hi-jack is another mans' feature, go figure. I think I'll dump it now that I've beat it to death. I never had it that I know of until now so I won't miss it much. I'm sure it saps a little processor time while doing its hunting.
  8. 2004/09/12
    noahdfear
    noahdfear Inactive
    Yep......I got the same results allowing Ad-aware to remove the HKEY_USERS entry. Took out the whole thing. So it would need to be put on the ignore list to keep or deselected for removal with each scan.
  9. 2004/09/13
    lj50 Lifetime Subscription
    lj50 SuperGeek WindowsBBS Team Member Thread Starter
    Mine didn't work either. Dumped it out of the reg. I guess you could keep it for cosmetic purposes. Maybe I'll reinstall it and fiddle with when I have a little more time to devote to it. I put it on a disk. Create a exclusionary rule in NIS if it's possible. I just accessed related.htm SP2 is restricting its use.
  10. 2004/09/13
    surferdude2
    Actually, mine worked just as it was supposed to but then I don't have SP2 installed so that may be the factor that is stopping yours. SP2 seems to affect many areas that aren't fully defined as yet. :) I'm holding off on it, at least until I understand fully what it will affect. I'm sure it'll be incorporated in such a way that I'll eventually need it to access the Updater site but for the time being I'll let it twist in the wind.
  11. 2004/09/13
    Did it work right away or did you have to create rules for your firewall or antivirus. I found Related.htm tried to access it but SP2 has a new security bar. It has an option to allow blocked content for that file(I think, not to sure). I don't want to allow blocked content and then later find out I allowed all sorts of weirdness onto my machine because it unblocked everything. Well tried unblocking the content related still did not work. So SP2 must have a strangle hold on it.
  12. 2004/09/13
    surferdude2
    It works right out of the gate for me, no problem with the firewall or AV. I can turn it on and off by simply running contradicting .reg files such as :
    for ON:
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Extensions\{c95fe080-8f5d-11d2-a20b-00aa003c157a}]
     "MenuText "= "@shdoclc.dll,-864 "
     "MenuStatusBar "= "@shdoclc.dll,-865 "
     "Script "=hex(2):43,3a,5c,57,49,4e,44,4f,57,53,5c,77,65,62,5c,72,65,6c,61,74,65,64,2e,68,74,6d,00
     "clsid "= "{1FBA04EE-3024-11D2-8F1F-0000F87ABD16} "
     "Icon "= ",4 "
     "HotIcon "= ",4 "
     "ButtonText "= "@shdoclc.dll,-866 "
    and for OFF:
    [-HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Extensions\{c95fe080-8f5d-11d2-a20b-00aa003c157a}]
     "Icon "= ",4 "
     "HotIcon "= ",4 "
    (The only difference being the minus sign after the bracket in the second .reg file.)
  13. 2004/09/13
    Where did you add this code in notepad commandline or directly in the reg.
  14. 2004/09/13
    noahdfear
    noahdfear Inactive
    Save the code to two separate notepads, with a .reg extension, file type All Files (*.*) So, RelatedOn.reg and RelatedOff.reg would be an example. Double click to merge whenever you want to use them. You will need to open a new IE window to see the change.
