Minidump for BSOD on Shutdowns
Discussion in 'Windows XP' started by cal1981, 2006/10/27.
  1. 2006/11/03
    cal1981
    cal1981 Inactive Thread Starter
    Bill, I have another minidump file form my typical shutdown crash last night. It's pretty much the same BUT, for the first time time the problem seems to be identified as "OVERLAPPED_MODULE: Address regions for 'kmixer' and 'kmixer.sys' overlap" I don't know if this has contributed to all of the other BSODs but here is the file:
    Microsoft (R) Windows Debugger Version 6.6.0007.5
    Loading Dump File [C:\WINDOWS\Minidump\Mini110306-01.dmp]
    Symbol search path is: SRV*C:\program files\symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is:
    Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 2600.xpsp_sp2_gdr.050301-1519
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x805624a0
    Debug session time: Fri Nov 3 05:37:30.843 2006 (GMT-8)
    System Uptime: 0 days 0:15:19.552
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 10000050, {e3903000, 1, 805d711a, 1}
    Could not read faulting driver name
    Probably caused by : ntkrnlmp.exe ( nt!CmpCopyCell+72 )
    Followup: MachineOwner
    1: kd> !analyze -V
    Unknown option '-V'
    1: kd> !analyze
    1: kd> !analyze -v
    PAGE_FAULT_IN_NONPAGED_AREA (50)
    Invalid system memory was referenced. This cannot be protected by try-except,
    it must be protected by a Probe. Typically the address is just plain bad or it
    is pointing at freed memory.
    Arguments:
    Arg1: e3903000, memory referenced.
    Arg2: 00000001, value 0 = read operation, 1 = write operation.
    Arg3: 805d711a, If non-zero, the instruction address which referenced the bad memory
    address.
    Arg4: 00000001, (reserved)
    Debugging Details:
    WRITE_ADDRESS: e3903000
    FAULTING_IP:
    nt!CmpCopyCell+72
    805d711a f3a5 rep movs dword ptr es:[edi],dword ptr [esi]
    MM_INTERNAL_CODE: 1
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0x50
    PROCESS_NAME: winlogon.exe
    LAST_CONTROL_TRANSFER: from 805d71f3 to 805d711a
    STACK_TEXT:
    ec35fb78 805d71f3 00523020 00000004 e1327008 nt!CmpCopyCell+0x72
    ec35fbac 805d7c60 01cfeb60 00403080 00522338 nt!CmpCopyValue+0xc0
    ec35fbf4 805d7d0b e2cfeb60 00403020 005222d8 nt!CmpCopyKeyPartial+0x16f
    ec35fc34 805d77ed e137b000 00000400 00000007 nt!CmpCopySyncTree2+0x25a
    ec35fc64 8065b1d5 e2cfeb60 00000020 e1327008 nt!CmpCopySyncTree+0x4f
    ec35fc98 8065315f 00000020 000006b0 00000003 nt!CmSaveKey+0xde
    ec35fcbc 804dd99f e37f0430 000006b0 ec35fd54 nt!NtSaveKey+0x78
    ec35fcbc 804e42bf e37f0430 000006b0 ec35fd54 nt!KiFastCallEntry+0xfc
    ec35fd3c 8065312c 00000094 000006b0 806530e7 nt!ZwSaveKey+0x11
    ec35fd54 804dd99f 00000094 000006b0 0006f8b8 nt!NtSaveKey+0x45
    ec35fd54 7c90eb94 00000094 000006b0 0006f8b8 nt!KiFastCallEntry+0xfc
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    0006f8b8 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    nt!CmpCopyCell+72
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250f77
    SYMBOL_NAME: nt!CmpCopyCell+72
    FAILURE_BUCKET_ID: 0x50_W_nt!CmpCopyCell+72
    Could either XP's audio drivers and/or the SB Audigy's drivers be corrupt? Thanks.
  2. 2006/11/03
    Bill Castner
    Bill Castner Inactive
    Updating the Creative drivers is always a good idea.
    In addition, do the free registration at this site and download DocMemory. Unzip, run the utility to create a bootable floppy, reset your BIOS boot order to Floppy drive first, and reboot and run an extended Memory test:
    http://www.simmtester.com/PAGE/products/doc/docinfo.asp
    (I would not put much concern behind the kmixer kmixer.sys issue).
    cal1981
    After weeks of shutdown BSODs with the cause being almost impossible to pin down, and the probability of of a corrupt OS growing stronger, I bit the bullet and gave up the ghost. I took my MPC recovery, driver and software CDs out, gulped and reinstalled XP SP1. Two hours later, after applying SP2 and letting Windows and Office Update apply over 80 security patches, I had a clean XP system. That was the easy part, although by reflex, I still hold my breath during a shutdown or restart. Restoring all of my installed programs and recustomizing everything to my liking is the hard part. Bill, I can't thank you enough for the help that you've given me. All of us in the windows community appreciate the time that you and your fellow experts devote to trying to help us work through all of Windows' "features" (LOL).
