Solved Malware/Keeps rebooting after blue screen
Discussion in 'Malware and Virus Removal Archive' started by Woodstock, 2011/03/23.
  1. 2011/03/26
    Woodstock
    Woodstock Inactive Thread Starter
    C:\Documents and Settings\Ben Sage\My Documents\Downloads\cole2k.media.-.codec.pack.v7.9.0.-advanced-.setup.exe Win32/Adware.Toolbar.Dealio application deleted - quarantined
    C:\Documents and Settings\Ben Sage\My Documents\Downloads\MsgPlusLive-482.exe a variant of Win32/Adware.CiDHelp application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{CF9D6E0D-86A7-42BD-B236-6E50A61850F2}\RP13\A0029709.exe Win32/Bamital.DX trojan deleted - quarantined
    C:\System Volume Information\_restore{CF9D6E0D-86A7-42BD-B236-6E50A61850F2}\RP13\A0029710.exe Win32/Bamital.DX trojan deleted - quarantined
    C:\_OTL\MovedFiles\03242011_011555\C_Documents and Settings\Ben Sage\Application Data\B6B3E9022EE7D45D04CA529B991EB4D8\enemies-names.txt Win32/Adware.AntimalwareDoctor.AE.Gen application cleaned by deleting - quarantined
    C:\_OTL\MovedFiles\03242011_011555\C_Documents and Settings\Ben Sage\Application Data\B6B3E9022EE7D45D04CA529B991EB4D8\local.ini Win32/Adware.AntimalwareDoctor.AE.Gen application cleaned by deleting - quarantined
  2. 2011/03/26
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
    Woodstock
    Re-boots are slow
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: Administrator
    ->Java cache emptied: 0 bytes
    User: All Users
    User: Ben Sage
    ->Temp folder emptied: 1055082 bytes
    ->Temporary Internet Files folder emptied: 7453858 bytes
    ->FireFox cache emptied: 0 bytes
    ->Flash cache emptied: 405 bytes
    User: Default User
    User: LocalService
    User: NetworkService
    ->Temp folder emptied: 6078 bytes
    Windows Temp folder emptied: 1157011 bytes
    RecycleBin emptied: 815 bytes
    Total Files Cleaned = 9.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Ben Sage
    User: Default User
    User: LocalService
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.22.3 log created on 03272011_005918
    C:\Documents and Settings\Ben Sage\Local Settings\Temporary Internet Files\Content.IE5\RR2OXJXW\98331-active-malware-keeps-rebooting-after-blue-screen-5[1].htm moved successfully.
    C:\Documents and Settings\Ben Sage\Local Settings\Temporary Internet Files\AntiPhishing\A0AB7674-8D67-4F4D-B5E1-96FAEADFB79D.dat moved successfully.
  5. 2011/03/26
    As I said, adding some more RAM would help.
    Your computer was severely infected, you couldn't even boot it, so you may consider yourself lucky to be where you're right now.
    If there are no other issues, I'd like to mark this thread as resolved.
  6. 2011/03/26
    Woodstock
    thank you very much for your time and knowledge
  7. 2011/03/26
    You're very welcome :)
    Good luck and stay safe :)
